Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
Thread: GOLF 6 R Retrofit discover media with pdc with rvc
  1. #21
    Nov 2017
    Croatia
    Working my friend i changed to tiguan and path lines coming great. Lines works only when i code caddy or tiguan
    Thanks my friend for help
  2. #22
    Nov 2017
    Croatia
    My friend do you know is it possible to code automatic activation when car coming near obstacles when speed not above 15kmh
  3. #23
    Jul 2014
    Tallinn, Estonia
    That is coded in PDC module, the bit is named something like "automatic activation".
  4. #24
    Nov 2017
    Croatia
    Ok i try to find in pdc module if have in this module thanks
  5. #25
    Nov 2017
    Croatia
    My module 1k8919472 not have automatic activation
  6. #26
    Jun 2014
    Poland
    Quote Originally Posted by Ljubo View Post
    check on cluster settings, should have
  7. #27
    Nov 2017
    Croatia
    I have retrofitt 3D cluster from scirroco do you mean in adaptation or coding
  8. #28
    Jul 2014
    Tallinn, Estonia
    In MFA menus, there should be an option called "ParkPilot". It should contain the checkbox for automatic activation.
  9. #29
    Nov 2017
    Croatia
    My car is golf 6 with scirroco cluster not have menu like golf 7
  10. #30
    Jun 2014
    Poland
    are you blind ???
    to be clear .... if you compare to Golf 7 ......in Golf 7 - you have that function operate from RADIo , not cluster
