GOLF 6 R Retrofit discover media with pdc with rvc
   #21
Ljubo
Croatia
C?ID=271067
Working my friend i changed to tiguan and path lines coming great. Lines works only when i code caddy or tiguan
Thanks my friend for help
   #22
Ljubo
Croatia
C?ID=271067
My friend do you know is it possible to code automatic activation when car coming near obstacles when speed not above 15kmh
   #23
siLc
Tallinn, Estonia
C?ID=330192
That is coded in PDC module, the bit is named something like "automatic activation".
   #24
Ljubo
Croatia
C?ID=271067
Ok i try to find in pdc module if have in this module thanks
   #25
Ljubo
Croatia
C?ID=271067
My module 1k8919472 not have automatic activation
   #27
Ljubo
Croatia
C?ID=271067
I have retrofitt 3D cluster from scirroco do you mean in adaptation or coding
   #28
siLc
Tallinn, Estonia
C?ID=330192
In MFA menus, there should be an option called "ParkPilot". It should contain the checkbox for automatic activation.
   #29
Ljubo
Croatia
C?ID=271067
My car is golf 6 with scirroco cluster not have menu like golf 7
   #30
Spacewalker
Poland
C?ID=159607
are you blind ???
to be clear .... if you compare to Golf 7 ......in Golf 7 - you have that function operate from RADIo , not cluster
   #31
Ljubo
Croatia
C?ID=271067
Do you mean MFA on cluster or discover media
   #33
Ljubo
Croatia
C?ID=271067
Wednesday,01,May,2019,08:14:24:60594
VCDS Version: 18.9.1.0 (x64)
VIN: WVWZZZ1KZCW047426   License Plate: DU020R
Mileage: 72080km-44788mi   Repair Order:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 4C 52 55 5F
VIN: WVWZZZ1KZCW047426   Mileage: 72080km-44788miles
Address 01: Engine (CDL)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 1K8 907 115 F    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: 5BH20---    Serial number:
   Coding: 0403000C1C0F0160
   Shop #: WSC 14133 284 419462
   VCID: 31697BCEA8C5E8C262-8064
   Part No SW: 02E 300 013 S    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2742
   Revision: 05351113    Serial number: 00001106220946
   Coding: 0000024
   VCID: 21498B8EF8255842F2-8074
   Revision: 00H31001
   Coding: 143B800D09268001280F01E6901F0141350400
   Shop #: WSC 41203 001 104857
   VCID: 7BF599E6FA09D29288-802E
   Part No SW: 1K8 907 044 A    HW: 1K8 907 044 A
   Component: Climatronic   H05 0102
   Revision: 00001K02
   Coding: 0018004002
   Shop #: WSC 00020 999 12345
   VCID: 2D5167BE7CFD8C2246-8078
   Part No SW: 1K0 937 084 F    HW: 1K0 937 084 F
   Component: BCM PQ35  B   110 0651
   Revision: 00110 AC
   Coding: 40180A3AE825F300400800C0340008E44F750488737D8D20E48420240040
   VCID: 31697BCE68C5E8C262-8064
   Component: Wischer 29061  26  0512
   Coding: 009F95
   Component: RLS 020711 05  54  0403
   Coding: 0730AD
   Component: LIN BACKUP HO  H11 9005
   Part No SW: 1K8 919 472     HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0430
   Revision: --------    Serial number: 39331412602894
   Coding: 0061190011
   ASAM Dataset: EV_EPHVA18VW364GP00 001005
   VCID: 74E7B2DADF579DEAC9-8020
   Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
   Serial number: 003G5RA7CDV
   Coding: 00003957
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 31697BCE60C5E8C262-8064
   Serial number: 3572MSME59205260ZZZM
   Serial number: 3582MSME3A143161ZZZN
   Serial number: 3512QSME78201E27ZZZW
   Serial number: 3522QSME64430D04ZZZQ
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Revision: --------    Serial number:  90422KFS000OY
   Coding: 1892140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76E388D2C92B8FFAF7-8022
   Subsystem 1 - Part No SW: 1K8 959 442     HW: 1K8 959 442
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29160002327190106443
   Coding: A5FFFF
   Part No SW: 1K8 920 885 D    HW: 1K8 920 885 D
   Component: KOMBI         37N 0725
   Coding: 170D01
   Shop #: WSC 01342 020 12345
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 004727
   VCID: 387F46EA83BF398A25-806C
   Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1674
   Revision:   H56       Serial number: 290117F1002171
   Coding: 350000
   VCID: 76E388D2C12B8FFAF7-8022
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 45813F1E0C4D5462AE-8010
   Component: IMMO          37N 0725
   Shop #: WSC 00020 999 00000
   VCID: 6ADBACA28D935B1A63-803E
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2117
   Coding: 0004214
   VCID: 326B74C2ADC3D3DA1B-8066
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 74     3201
   Revision: 00H20000
   VCID: 346772DA57D7DDEA09-8060
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Coding: 0004470
   VCID: 336571C652D9DAD210-8066
   Coding: 1475676
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Coding: 00000022
   Part No SW: 5C0 035 680 B    HW: 5C0 035 680 B
   Component: MU-S-N-ER     H22 0245
   Serial number: --------------
   Coding: 02730001FF00000011110001000808001F0100D4002001010F
   Shop #: WSC 00015 115 00001
   ROD: EV_MUStd4CTSAT_VW36.rod
   VCID: 204F8E8A3B2F514AFD-8074
   Subsystem 1 - Part No SW: 5NA 919 866 R    HW: -----------
   Component: ECE AS 19/20  --- 1115
6714 - Databus
                    Reset counter: 231
                    Mileage: 72080 km
                    Date: 2019.04.30
                    Time: 19:10:38
                    Voltage terminal 30: 11.6 V
End-------------------------(Elapsed Time: 02:34)--------------------------
Spacewalker
Poland
C?ID=159607
UWE - is genuine ... or fake ?
because I cant see he is verified user
Ljubo
Croatia
C?ID=271067
I received mail from Linda my dongle registration is ok
   #36
Ljubo
Croatia
C?ID=271067
discover media pq35 not have car menu options on radio i dont know what you mean
   #37
He registered his (genuine) system a few days ago, but did not include "please check forum status" with his registration. :rolleyes:
Now I just double-checked, and I found him, and verified him. :)
Moving this to Retrofits. :cool:
Ljubo
Croatia
C?ID=271067
thanks UWE now is it ok my status
   #39
siLc
Tallinn, Estonia
C?ID=330192
Park Pilot can be found in the instrument cluster menu, not in Discover Media PQ.
   #40
Ljubo
Croatia
C?ID=271067
I under stand what you mean but i dont have park pilot in mfa menu
