Results 1 to 3 of 3
Thread: Readiness code: CFWA engine (1.2TDI)
    May 2019
    hello all,
    i'm new to this forum so ill will introduce myself a bit, my name is bart and i am from the netherlands, my english isnt the best but i will try to make myself clear as can be. i already have quite some experience in using vcds.
    now i have an isseu with my car, it went for MOT last friday were the technician had to preform an extra test because the readiness code wasn't completed/failed. the car made it thru the MOT without any problems and drives exellent. the problem is that the readiness code still is incomplete/failed, even after a few days of driving. i can't find a script or manual on how to set the readiness code manually. when i connect my vcds the button stays grey with a note "no scripts available".
    does anyone know how to set the readiness code on my car, a 2010 skoda fabia, with CFWA engine code? i do need to mention that my EGR-valve is blocked/disabled as the car is fitted with tuning software. last year at the MOT there was no isseu with the readiness code with the tuning software already installed.
    thanks!
    autoscan below (partly in dutch)
    Maandag,20,Mei,2019,19:03:29:01267
    VCDS -- Windows Gebaseerde VAG/VAS Emulator Loopt op Windows 10 x64
    VCDS Versie: HZH 18.2.1.0  HEX-V2 CB: 0.4411.4
    Data versie: 20180904 DS287.4
    www.Randstadcarsolutions.nl
    VIN: TMBJK65J6B3095068
    Kilometrage: 260518km   Reparatie Order:
    Chassis Type: 5J-SK25 (6R0)
    Scan: 01 03 08 09 10 15 17 19 25 2E 44 56 61 69
    VIN: TMBJK65J6B3095068   Kilometrage: 260518km
    01-Motor -- Status: OK 0000
    03-ABS Systeem -- Status: OK 0000
    04-Stuurhoek -- Status: OK 0000
    08-Airco/Verwarming -- Status: OK 0000
    09-Centr.Electr. -- Status: OK 0000
    10-Parkeerhulp -- Status: OK 0000
    17-Instrumenten -- Status: OK 0000
    19-CAN-bus Interface -- Status: OK 0000
    25-Wegrijblokkering -- Status: OK 0000
    2E-Mediaplayer 3 -- Status: OK 0000
    44-Stuurhulp -- Status: OK 0000
    61-Accuregeling -- Status: OK 0000
    69-Aanhangerfunctie -- Status: OK 0000
    Adres 01: Motor (J000-CFWA)       Labels:. 03P-906-021-CFW.clb
       Onderdeel No SW: 03P 906 021 K    HW: 03P 906 021 K
       Component: R3 1.2l TDI   H03 9979
       Revisie: 12004001    Serienummer:
       Codering: 00114014032400080000
       Werkplaats#: WSC 13765 031 00042
       ASAM Dataset: EV_ECM12TDI03103P906021K 001022
       ROD: EV_ECM12TDI03103P906021AA.rod
       VCID: 3038E0EDEAA31CB7C11-8064
    Geen Fout Code Gevonden.
    Gereedheid: 0 0 0 0 1
    Adres 03: ABS Systeem (J104)       Labels:. 6R0-907-37x-ESP82.clb
       Onderdeel No SW: 6R0 907 379 AA    HW: 6R0 907 379 AF
       Component: ESP8.2i front H05 0003
       Revisie: --------
       Codering: 410124DB417600B7822524E882D900521300
       Werkplaats#: WSC 13765 790 00015
       VCID: 7DA609D96DB121DF1A7-8028
    Adres 08: Airco/Verwarming (J255)       Labels: 6Q0-907-044.lbl
       Onderdeel No SW: 5J0 907 044 B    HW: 5J0 907 044 B
       Component: Climatronic   H08 0102
       Revisie: K0000000
       VCID: 290E0D89C9F96D7F06F-807C
    Adres 09: Centr.Electr. (J519)       Labels:. 6R0-937-08x-09.clb
       Onderdeel No SW: 6R0 937 088 F    HW: 6R0 937 088
       Component: BCM PQ25 Re4  H50 0351
       Revisie: BU050001    Serienummer: 0456 272110600
       Codering: 7A980B3808010000003801302E2B00C80E80420F7E000040000000000000
       Werkplaats#: WSC 72838 211 93661
       VCID: 41DEB5295189853F3EF-8014
       Subsysteem 1 - Onderdeel No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
       Component: J386__TSG_FT  002 3210
       Serienummer: --------------------
       Codering: 420000
       Subsysteem 2 - Onderdeel No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
       Component: J387__TSG_BT  002 3210
       Codering: 420000
       Component: J388__TSG_HL  002 3210
       Codering: 420000
       Subsysteem 5 - Onderdeel No SW: 6R0 959 812 D    HW: 6R0 959 812 D
       Component: J389__TSG_HR  002 3210
       Codering: 420000
    Adres 10: Parkeerhulp (J446)       Labels:| 5J0-919-475.clb
       Onderdeel No SW: 5J0 919 475     HW: 5J0 919 475
       Component: PARKHILFE 4K  H10 0003
       Revisie: --H10---    Serienummer: 76231027004339
       Codering: 11000B
       Werkplaats#: WSC 53433 001 1048576
       ASAM Dataset: EV_SK25XParkiAssis2 S01002
       ROD: EV_SK25XParkiAssis2.rod
       VCID: 72BC2AE5242F6EA7775-8026
    Adres 15: Airbags (J234)       Labels:| 5K0-959-655.clb
       Onderdeel No SW: 6R0 959 655 L    HW: 6R0 959 655 L
       Component: VW10AirbagT22 H09 0020
       Revisie: --------    Serienummer: 003GY001B33S
       Codering: 003232
       ROD: EV_AirbaVW10BPAVW250.rod
       VCID: 4BC2970163455F6FD43-801E
       Ongevalsensor voor zij-airbag: bestuurderszijde:
       Serienummer: 3495RRB405300IUG48RT
       Ongevalsensor voor zij-airbag: bijrijderszijde:
       Serienummer: 3505RRB405300IUGPH3R
       Ongevalsensor voor zij-airbag achterin: bestuurderszijde:
       Serienummer: 3515RRB405900IUGK05E
       Ongevalsensor voor zij-airbag achterin: bijrijderszijde:
       Serienummer: 3525RRB405900IUGEG8S
    Adres 17: Instrumenten (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Onderdeel No SW: 5J0 920 840 D    HW: 5J0 920 840 D
       Component: KOMBI         H15 0206
       Serienummer: 00000000000000
       Codering: 120A00
       Werkplaats#: WSC 13765 031 00015
       ROD: EV_Kombi_UDS_VDD_RM09_A04_SK25.rod
       VCID: 2A0CF285CC7F66670F5-807E
    Adres 19: CAN-bus Interface        Labels:. 6R0-907-530-V1.clb
       Onderdeel No SW: 6R0 907 530 B    HW: 1K0 907 951
       Component: J533  Gateway   H28 0020
       Revisie:   H28       Serienummer: 110910F2000494
       Codering: 7D2B1D00080000002302
       VCID: 323CEAE5E82F2EA7B75-8066
    Adres 25: Wegrijblokkering (J334)       Labels:| 5K0-920-xxx-25.clb
       Onderdeel No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H15 0206
       Codering: 000000
       Werkplaats#: WSC 00000 000 00000
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
       VCID: 6A8C32850CFFA667CF5-803E
    Adres 2E: Mediaplayer 3 (J650)       Labels:. 5N0-035-342.lbl
       Onderdeel No SW: 5N0 035 342 C    HW: 5N0 035 342 C
       Component: SG EXT.PLAYER H13 0111
       Revisie: A1001003    Serienummer: 7668602238
       Codering: 010000
       VCID: 270A0BB1DFED5B0F10B-8072
    Adres 44: Stuurhulp        Labels: 6Q0-423-156.clb
       Onderdeel No: 6R0 423 156 B
       Component: LenkhilfeTRW        C277
       Codering: 11210
       VCID: 2F3AE391FE5D034FD8B-807A
    Adres 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
       Onderdeel No SW: 5J0 035 161 C    HW: 5J0 035 161 C
       Component: Radio-SWING   008 0033
       Revisie: -----08S    Serienummer: SKZ4Z2K1339742
       Codering: 090004000006
       VCID: 221C1AA5B4CFBE27475-8076
    Adres 61: Accuregeling (J840)       Labels:. 1K0-907-534.clb
       Onderdeel No SW: 6R0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H28 0020
       Codering: 030B0A5A
       VCID: 74B02CFD5EBB6097659-8020
       Component: J367-BDM  H07 0125
       Serienummer: 00000000002790286184
    Adres 69: Aanhangerfunctie (J345)       Labels:. 1K0-907-383-V2.clb
       Onderdeel No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Component: Towbar module H09 0100
       Revisie: 3A001001    Serienummer: 006789XXXXXX
       Codering: 0100000100000000
       VCID: 3038E0EDEA231CB7C11-8064
    Einde-------(Verstreken Tijd: 01:20, VBatt start/eind: 11.8V/12.0V)--------
    and the readiness code
    Gereedheid Status: 00000000 00001110 11101000 11101000
    MIL Status: MIL UIT
    Uitgebreidere Componenten: Gepasseerd
    Brandstof Systeem: Gepasseerd
    Uitlaat Gas Recirculatie EGR: Mislukt of Incompleet
    Aantal EOBD-gerelateerde FTC(s): 0
    Hi and welcome.
    Admin note: When posting data in this forum, please use the English version of VCDS. You can download it from this page and it will happily coexist on your PC with the Dutch translation you are currently using.
    Now as for Readiness: If your EGR is blocked off/disabled, then there is no way that the normal software in your ECU can ever test the EGR and get a passing result. The only solutions are: 1) Restore the EGR to function, or 2) talk to your tuner about this problem and see if he can't fix this in the software in your ECU.
    May 2019
    hi uwe.
    didnt know that i could use both versions, will install the other version right away.
    think i will contact the tuner as before the egr delete i had some problems with the intake vlave being very dirty and sticking a bit.
    thanks for the reply!
  4. Likes Uwe liked this post
