Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Audi A4 B5 2000 1.6 MAF issues
    Nov 2017
    Latvia
    Quote Originally Posted by _Val View Post
    Got similar engine ECU from A4 B6 needing EGR-OFF. Then I could switch to that ECU as a last resort for testing is this issue related to ECU itself.
    Will bench test it again to see is it iso/obd-2 compatible.
    I was busy building smoke machine which means no fuel tests for now. Not too good looking for public eyes.
    These are OBD2 mode screens from A4 B6 ALZ: it's a little advanced than A4 B5 ANA/ALZ engine ecu.
    Could be a (little) fun upgrading to this one.
    and so on...
    Mode 2: No Freeze frame data available
    Mode 9: Not supported by Control module
  2. #12
    Nov 2017
    Latvia
    Update on engine testing.
    Engine shut, fuel pump turned on manually:
    440ml fuel volume in 15 seconds.
    Engine idling:
    3.5bar at rail (FPR vacuum connected)
    4.1bar in rail (FPR vacuum disconnected)
    Engine shut:
    17:22 - 2.9bar
    17:29 - 2.7bar
    17:36 - 2.4bar
    17:56 - 2.0bar
    18:15 - 1.8bar
    Compression check:
    ------|-- 1 ------- 2 ------- 3 ------- 4 --
    try 1 | 13.0bar - 10.0bar - 13.0bar - 10.0bar
    try 2 | xxxxxxx - 12.5bar - xxxxxxx - 10.0bar
    try 3 | xxxxxxx - xxxxxxx - xxxxxxx - 14.5bar (with oil in cylinder #4)
    Injector resistance 16.4 ... 16.6 ohms
    Yeah, didn't do all 4cylinders 3x times. Maybe later with different meter.
    Autodata lists compression as 10-13bar, Elsa 10.2bar.
    Spark plug color looks identical with eye, doesn't look like it's burning oil.
    Engine or head hasn't been off for at least 7-8 years as I know. Maybe it's a time for maintenance.
    Pictures?
  3. Likes Uwe liked this post
  4. #13
    May 2016
    The fact volumetric efficiency is close to normal, then runs good with mass air unplugged, meaningn goes into some type of block learned memory, agree with JEF, probably bad MAF, or WIRING to it as good compression.
    LARIMORE
  5. #14
    Nov 2017
    Latvia
    Finally got smoke machine built, first tests showed some smoke coming out of somewhere in between engine block and gearbox under the intake manifold. Actually it was bad rubber seal of crank sender. Got it sorted. Happy as hell at that point... Thanks VAG for putting outer + inner hex on the same bolt. Inner was already bad when I tried to get it loose. Now I have only very very minor leak through top of oil pickup tube when applying a little positive pressure through smoke machine. Plugging it completely shut didn't result in fuel trim change so it's left as is.
    Back to fuel trim testing. Did several runs at idle with Delphi aftermarket. Before every log I reset adaptations in channel 00 add cleared faults.
    Also tried comparing old genuine maf but it showed -15...-20% STFT at kind of rough idle (even engine knocking a bit, increased injector timing and g/s of maf compared to beginning of the log). That resulted in no change for LTFT at all.
    MAF average 4.14g/s
    Friday	21	June	2019	12:19:52:00008-VCID:1E3368789AB7DDBF84-515A	VCDS Version: Release 19,6,0 (x64)	Data version: 20190529 DS308,0
    3B0 906 018 A		1,6l/2V SIMOS3 G00HS0009
    	Group A:	'032				Group B:	'099				Group C:	'002
    		Adaptation (Idle)	Adaptation (Partial)	 	 		Engine Speed	Coolant	Lambda Control	Lambda Control		Engine Speed	Engine Load	Injection Timing	Mass Air Flow
    	TIME	Bank 1 Sensor 1	Bank 1 Sensor 1			TIME	(G28)	Temperature (G62)		Status	TIME	(G28)			Sensor (G70)
    Marker	STAMP	 %	 %			STAMP	 /min	C	 %		STAMP	 /min	 %	 ms	 g/s
    	0,52	0	0	 	 	0,01	0	82,5	0	OFF	0,25	0	0	0	0
    	1,35	0	0	 	 	0,79	0	82,5	0	OFF	1,07	0	0	0	0
    	13,12	0	0	 	 	13,41	832	81	0	OFF	13,71	832	23,9	3,09	3,46
    	14,02	0	0	 	 	14,31	832	81	0	OFF	14,6	832	23,9	3,09	3,52
    	14,9	0	0	 	 	15,21	832	81	0	OFF	15,51	832	23,9	3,09	3,51
    	15,8	0	0	 	 	16,1	832	81	0	OFF	16,4	864	23,9	3,09	3,49
    	16,7	0	0	 	 	16,99	832	81	0	OFF	17,28	832	23,9	3,09	3,38
    	17,6	0	0	 	 	17,89	832	81	0	OFF	18,19	832	23,9	3,09	3,52
    	18,5	0	0	 	 	18,8	864	81	0	OFF	19,1	832	23,9	3,09	3,49
    	19,38	0	0	 	 	19,68	832	81	0	OFF	19,97	864	23,9	3,09	3,49
    	20,27	0	0	 	 	20,56	832	81	0	OFF	20,88	832	23,9	3,09	3,55
    	21,16	0	0	 	 	21,45	864	81	0	OFF	21,73	832	23,9	3,09	3,46
    	22,03	0	0	 	 	22,34	832	81	0	OFF	22,64	832	23,9	3,09	3,49
    	22,92	0	0	 	 	23,22	832	81	0	OFF	23,52	832	23,9	3,09	3,45
    	23,8	0	0	 	 	24,09	832	81	0	OFF	24,38	832	23,9	3,09	3,51
    	24,69	0	0	 	 	24,99	832	81	0	OFF	25,29	832	23,9	3,09	3,54
    	25,6	0	0	 	 	25,88	832	81	0	OFF	26,16	832	23,9	3,09	3,49
    	26,47	0	0	 	 	26,75	864	81	0	OFF	27,04	864	23,9	3,09	3,41
    	27,32	0	0	 	 	27,61	832	81	0	OFF	27,9	832	23,9	3,09	3,43
    	28,19	0	0	 	 	28,49	832	81	0	OFF	28,78	864	23,9	3,09	3,43
    	29,06	0	0	 	 	29,36	832	81	0	OFF	29,67	864	23,9	3,09	3,47
    	29,96	0	0	 	 	30,23	864	81	0	OFF	30,54	832	23,9	3,09	3,37
    	30,84	0	0	 	 	31,14	832	81	-0,8	ON	31,45	832	23,9	3,09	3,4
    	31,76	0	0	 	 	32,05	832	81	-3,5	ON	32,34	864	23,9	2,06	3,43
    	32,64	0	0	 	 	32,92	832	81	-5,9	ON	33,21	832	23,9	2,06	3,39
    	33,51	0	0	 	 	33,8	864	81	-8,6	ON	34,1	832	23,9	2,06	3,49
    	34,39	0	0	 	 	34,69	832	81	-11,3	ON	34,98	832	23,9	2,06	3,54
    	35,25	0	0	 	 	35,56	832	81	-14,1	ON	35,85	832	25,1	2,06	3,58
    	36,14	0	0	 	 	36,44	832	81	-16,8	ON	36,74	832	26,3	2,06	3,92
    	37,04	0	0	 	 	37,33	832	81	-19,5	ON	37,61	800	27,5	2,06	4,08
    	37,9	0	0	 	 	38,18	832	81	-17,2	ON	38,47	832	29,8	3,09	4,4
    	38,78	0	0	 	 	39,07	864	81	-14,8	ON	39,36	864	28,6	3,09	4,2
    	39,67	0	0	 	 	39,95	864	81	-12,1	ON	40,25	864	27,5	3,09	4,03
    	40,55	0	0	 	 	40,85	864	81	-9,8	ON	41,15	864	26,3	2,06	3,78
    	41,46	0	0	 	 	41,77	864	81	-12,5	ON	42,09	832	25,1	2,06	3,71
    	42,38	0	0	 	 	42,69	832	81	-15,2	ON	42,98	832	25,1	2,06	3,62
    	43,28	0	0	 	 	43,58	832	81	-18	ON	43,86	832	26,3	2,06	3,83
    	44,14	0	0	 	 	44,44	800	81	-20,7	ON	44,73	832	31	2,06	4,64
    	45,02	0	0	 	 	45,33	832	81	-18,8	ON	45,62	832	31	3,09	4,5
    	45,91	0	0	 	 	46,21	864	81	-16	ON	46,49	864	29,8	3,09	4,51
    	46,78	0	0	 	 	47,09	864	81	-13,3	ON	47,39	864	29,8	3,09	4,18
    	47,69	0	0	 	 	48	864	81	-10,5	ON	48,28	864	28,6	3,09	4,03
    	48,58	0	0	 	 	48,87	896	81	-9,8	ON	49,16	864	26,3	2,06	3,51
    	49,46	0	0	 	 	49,75	864	81	-12,5	ON	50,04	832	26,3	2,06	3,69
    	50,35	0	0	 	 	50,65	832	81	-15,2	ON	50,93	832	25,1	2,06	3,49
    	51,24	0	0	 	 	51,54	800	81	-17,6	ON	51,85	832	26,3	2,06	3,66
    	52,17	0	0	 	 	52,48	800	81	-20,7	ON	52,77	800	28,6	2,06	4,31
    	53,06	0	0	 	 	53,36	832	81	-21,1	ON	53,64	864	31,8	3,09	4,59
    	53,95	0	0	 	 	54,25	864	81	-18,4	ON	54,54	864	31	3,09	4,53
    	54,84	0	0	 	 	55,13	864	81	-15,6	ON	55,42	864	29,8	3,09	4,28
    	55,72	0	0	 	 	56,03	864	81	-12,9	ON	56,31	864	28,6	3,09	4,08
    	56,61	0	0	 	 	56,92	896	81	-10,2	ON	57,23	864	26,3	2,06	3,69
    	57,55	0	0	 	 	57,84	864	81	-13,3	ON	58,16	864	26,3	2,06	3,62
    	58,45	0	0	 	 	58,75	832	81	-16	ON	59,04	832	26,3	2,06	3,59
    	59,31	0	0	 	 	59,61	832	81	-18,4	ON	59,91	800	26,3	2,06	3,79
    	60,2	0	0	 	 	60,51	832	81	-21,1	ON	60,81	832	29,8	2,06	4,16
    	61,11	0	0	 	 	61,41	800	81	-21,1	ON	61,7	832	31,8	3,09	4,76
    	61,99	0	0	 	 	62,3	864	81	-18,4	ON	62,6	864	29,8	3,09	4,36
    	62,9	0	0	 	 	63,2	864	81	-15,6	ON	63,5	864	29,8	3,09	4,28
    	63,79	0	0	 	 	64,08	864	82,5	-12,9	ON	64,4	896	28,6	3,09	3,91
    	64,71	0	0	 	 	65,02	864	82,5	-10,5	ON	65,32	864	26,3	2,06	3,57
    	65,63	0	0	 	 	65,94	864	82,5	-13,3	ON	66,23	864	26,3	2,06	3,68
    	66,53	0	0	 	 	66,82	832	82,5	-16	ON	67,13	832	25,1	2,06	3,43
    	67,41	0	0	 	 	67,69	832	82,5	-18,8	ON	67,99	832	26,3	2,06	3,51
    	68,28	0	0	 	 	68,58	832	82,5	-21,5	ON	68,86	832	27,5	2,06	3,79
    	69,16	0	0	 	 	69,45	800	82,5	-23,8	ON	69,75	832	29,8	2,06	4,28
    	70,05	0	0	 	 	70,34	832	82,5	-22,7	ON	70,65	864	31	2,06	4,48
    	70,96	0	0	 	 	71,27	864	82,5	-19,9	ON	71,57	864	29,8	2,06	4,36
    	71,86	0	0	 	 	72,13	864	82,5	-17,2	ON	72,42	896	28,6	2,06	4,14
    	72,7	0	0	 	 	73,02	864	82,5	-14,5	ON	73,32	864	27,5	2,06	3,91
    	73,63	0	0	 	 	73,93	864	82,5	-15,2	ON	74,23	864	26,3	2,06	3,57
    	74,53	0	0	 	 	74,81	832	82,5	-18	ON	75,1	832	26,3	2,06	3,4
    	75,4	0	0	 	 	75,68	832	82,5	-20,7	ON	75,95	832	25,1	2,06	3,42
    	76,24	0	0	 	 	76,52	832	82,5	-23	ON	76,84	832	26,3	2,06	3,69
    	77,13	0	0	 	 	77,43	832	82,5	-25,8	ON	77,73	800	28,6	2,06	4,03
    	78,01	0	0	 	 	78,32	832	82,5	-24,6	ON	78,59	832	29,8	2,06	4,25
    	78,9	0	0	 	 	79,21	864	82,5	-21,9	ON	79,5	864	29,8	2,06	4,29
    	79,79	0	0	 	 	80,1	864	82,5	-19,1	ON	80,39	864	29,8	2,06	4,24
    	80,68	0	0	 	 	80,99	864	82,5	-16,4	ON	81,28	864	28,6	2,06	4,06
    	81,59	0	0	 	 	81,91	864	82,5	-14,5	ON	82,2	864	26,3	2,06	3,65
    	82,5	0	0	 	 	82,78	864	82,5	-17,2	ON	83,08	832	26,3	2,06	3,55
    	83,39	0	0	 	 	83,68	832	82,5	-19,9	ON	83,97	832	26,3	2,06	3,61
    	84,28	0	0	 	 	84,56	832	82,5	-22,7	ON	84,86	832	26,3	2,06	3,51
    	85,16	0	0	 	 	85,44	832	82,5	-25,4	ON	85,74	800	27,5	2,06	3,86
    	86,04	0	0	 	 	86,35	800	82,5	-26,2	ON	86,63	832	31	2,06	4,69
    	86,92	0	0	 	 	87,23	864	82,5	-23,4	ON	87,5	864	31	2,06	4,54
    	87,8	0	0	 	 	88,11	864	82,5	-21,1	ON	88,39	864	31	2,06	4,39
    	88,68	0	0	 	 	88,97	864	82,5	-18,4	ON	89,28	864	29,8	2,06	4,34
    	89,59	0	0	 	 	89,89	864	82,5	-15,6	ON	90,2	864	28,6	2,06	3,96
    	90,52	0	0	 	 	90,81	864	82,5	-12,9	ON	91,1	864	26,3	2,06	3,65
    	91,38	0	0	 	 	91,69	864	82,5	-15,6	ON	91,99	864	26,3	2,06	3,6
    	92,29	0	0	 	 	92,6	832	82,5	-18,4	ON	92,89	832	25,1	2,06	3,43
    	93,19	0	0	 	 	93,51	832	82,5	-21,1	ON	93,81	832	26,3	2,06	3,48
    	94,11	0	0	 	 	94,41	832	82,5	-23,8	ON	94,69	832	26,3	2,06	3,83
    	94,99	0	0	 	 	95,3	800	82,5	-26,6	ON	95,6	800	29,8	2,06	4,42
    	95,9	0	0	 	 	96,18	832	82,5	-22,7	ON	96,48	832	29,8	2,06	4,27
    	96,78	0	0	 	 	97,08	864	82,5	-18,4	ON	97,37	896	29,8	2,06	4,26
    	97,65	0	0	 	 	97,93	896	82,5	-15,2	ON	98,22	864	28,6	2,06	3,91
    	98,53	0	0	 	 	98,82	864	84	-12,5	ON	99,11	864	27,5	3,09	3,88
    	99,4	0	0	 	 	99,71	864	84	-12,5	ON	99,98	864	26,3	2,06	3,58
    	100,29	0	0	 	 	100,59	864	82,5	-15,2	ON	100,88	864	26,3	2,06	3,55
    	101,17	0	0	 	 	101,46	832	84	-18	ON	101,77	832	26,3	2,06	3,57
    	102,06	0	0	 	 	102,34	832	84	-20,7	ON	102,64	832	26,3	2,06	3,55
    	102,92	0	0	 	 	103,21	832	84	-23	ON	103,49	832	27,5	2,06	3,89
    	103,79	0	0	 	 	104,08	800	84	-25,8	ON	104,4	800	29,8	2,06	4,58
    	104,69	0	0	 	 	104,98	864	84	-23	ON	105,27	864	29,8	2,06	4,32
    	105,57	0	0	 	 	105,87	864	84	-20,3	ON	106,17	864	29,8	2,06	4,34
    	106,48	0	0	 	 	106,79	896	84	-17,6	ON	107,07	896	27,5	2,06	3,97
    	107,37	0	0	 	 	107,66	864	84	-14,8	ON	107,95	864	26,3	2,06	3,66
    	108,26	0	0	 	 	108,56	864	84	-17,2	ON	108,86	864	25,1	2,06	3,33
    	109,14	0	0	 	 	109,44	864	84	-19,9	ON	109,71	864	25,1	2,06	3,31
    	110,04	0	0	 	 	110,35	864	84	-22,7	ON	110,65	864	23,9	2,06	3,23
    	110,94	0	0	 	 	111,23	896	84	-25,4	ON	111,54	896	22,7	2,06	3,11
    	111,83	0	0	 	 	112,12	864	84	-26,6	ON	112,41	864	21,6	2,06	2,92
    	112,72	0	0	 	 	113	832	84	-26,2	ON	113,29	800	21,6	2,06	2,87
    	113,58	0	0	 	 	113,89	768	84	-27	ON	114,17	768	28,6	2,06	4,61
    	114,45	0	0	 	 	114,74	768	84	-27,3	ON	115,03	832	36,5	3,09	5,28
    	115,34	0	0	 	 	115,63	864	84	-24,6	ON	115,92	864	35,3	3,09	5,28
    	116,22	0	0	 	 	116,5	864	84	-22,7	ON	116,8	864	34,1	3,09	5,08
    	117,11	0	0	 	 	117,42	896	84	-21,1	ON	117,71	864	31,8	3,09	4,82
    	117,98	0	0	 	 	118,27	864	84	-19,5	ON	118,57	864	31	3,09	4,65
    	118,87	0	0	 	 	119,16	864	84	-17,2	ON	119,45	864	28,6	2,06	4,24
    	119,75	0	0	 	 	120,06	864	84	-14,5	ON	120,35	864	27,5	2,06	3,96
    	120,64	0	0	 	 	120,92	864	84	-11,7	ON	121,23	864	26,3	2,06	3,58
    	121,54	0	0	 	 	121,85	864	84	-13,3	ON	122,16	864	25,1	2,06	3,43
    	122,45	0	0	 	 	122,74	832	84	-16	ON	123,03	832	25,1	2,06	3,31
    	123,3	0	0	 	 	123,62	832	84	-18,4	ON	123,92	832	25,1	2,06	3,31
    	124,21	0	0	 	 	124,52	832	84	-21,1	ON	124,82	832	25,1	2,06	3,67
    	125,1	0	0	 	 	125,41	832	84	-23,8	ON	125,71	832	27,5	2,06	3,86
    	126	0	0	 	 	126,31	832	84	-25,4	ON	126,62	832	28,6	2,06	4,05
    	126,92	0	0	 	 	127,24	832	84	-22,3	ON	127,52	832	28,6	2,06	4,18
    	127,81	0	0	 	 	128,1	864	84	-19,9	ON	128,39	864	28,6	2,06	3,98
    	128,68	0	0	 	 	128,95	864	84	-17,2	ON	129,24	864	27,5	2,06	4,07
    	129,53	0	0	 	 	129,83	864	84	-14,5	ON	130,13	864	26,3	2,06	3,64
    	130,41	0	0	 	 	130,68	864	84	-13,7	ON	130,98	864	26,3	2,06	3,6
    	131,27	0	0	 	 	131,58	832	84	-16,4	ON	131,88	832	25,1	2,06	3,46
    	132,18	0	0	 	 	132,48	832	84	-19,1	ON	132,77	832	25,1	2,06	3,37
    	133,06	0	0	 	 	133,34	832	84	-21,9	ON	133,64	832	26,3	2,06	3,77
    	133,93	0	0	 	 	134,2	832	84	-24,6	ON	134,49	800	28,6	2,06	4,12
    	134,79	0	0	 	 	135,08	832	84	-23,8	ON	135,38	832	29,8	2,06	4,31
    	135,69	0	0	 	 	135,98	832	84	-21,1	ON	136,26	864	29,8	2,06	4,34
    	136,56	0	0	 	 	136,88	864	84	-18,4	ON	137,19	864	28,6	2,06	4,25
    	137,5	0	0	 	 	137,79	896	84	-15,6	ON	138,09	864	27,5	2,06	3,71
    	138,4	0	0	 	 	138,7	864	84	-13,7	ON	138,99	864	26,3	2,06	3,67
    	139,29	0	0	 	 	139,58	864	84	-16,4	ON	139,89	864	25,1	2,06	3,39
    	140,18	0	0	 	 	140,5	832	84	-19,1	ON	140,8	832	25,1	2,06	3,43
    	141,08	0	0	 	 	141,35	832	84	-21,9	ON	141,65	832	25,1	2,06	3,43
    	141,95	0	0	 	 	142,25	832	84	-24,2	ON	142,54	832	27,5	2,06	3,83
    	142,83	0	0	 	 	143,12	832	84	-26,2	ON	143,42	832	29,8	2,06	4,48
    	143,72	0	0	 	 	144,02	832	84	-23,4	ON	144,32	864	31	2,06	4,49
    	144,61	0	0	 	 	144,93	864	84	-20,7	ON	145,22	864	29,8	2,06	4,48
    	145,52	0	0	 	 	145,83	864	84	-18	ON	146,13	864	29,8	2,06	4,22
    	146,42	0	0	 	 	146,72	864	84	-15,2	ON	147,02	864	28,6	2,06	3,88
    	147,33	0	0	 	 	147,62	864	84	-12,5	ON	147,9	864	26,3	2,06	3,59
    	148,22	0	0	 	 	148,52	864	84	-14,5	ON	148,81	864	25,1	2,06	3,47
    	149,1	0	0	 	 	149,38	864	84	-17,2	ON	149,66	864	25,1	2,06	3,34
    	149,96	0	0	 	 	150,28	832	84	-19,9	ON	150,56	832	25,1	2,06	3,31
    	150,87	0	0	 	 	151,17	832	84	-22,7	ON	151,46	832	25,1	2,06	3,53
    	151,78	0	0	 	 	152,06	800	84	-25,4	ON	152,36	832	28,6	2,06	4,08
    	152,65	0	0	 	 	152,97	832	84	-24,6	ON	153,26	832	29,8	2,06	4,42
    	153,57	0	0	 	 	153,88	864	84	-21,9	ON	154,19	864	29,8	2,06	4,34
    	154,5	0	0	 	 	154,78	864	84	-19,1	ON	155,08	864	28,6	2,06	4,17
    	155,38	0	0	 	 	155,67	864	84	-16,4	ON	155,96	864	27,5	2,06	3,94
    	156,26	0	0	 	 	156,56	864	84	-13,7	ON	156,85	864	26,3	2,06	3,59
    	157,14	0	0	 	 	157,45	864	84	-15,2	ON	157,77	864	25,1	2,06	3,54
    	158,07	0	0	 	 	158,37	832	84	-18,4	ON	158,67	832	25,1	2,06	3,31
    	158,97	0	0	 	 	159,25	832	84	-21,1	ON	159,52	832	25,1	2,06	3,31
    	159,82	0	0	 	 	160,11	832	84	-23,4	ON	160,39	832	26,3	2,06	3,69
    	160,69	0	0	 	 	160,99	832	84	-26,2	ON	161,3	832	28,6	2,06	3,97
    	161,6	0	0	 	 	161,91	832	84	-24,2	ON	162,21	864	29,8	2,06	4,22
    	162,52	0	0	 	 	162,84	864	84	-21,1	ON	163,13	832	28,6	2,06	4,16
    	163,44	0	0	 	 	163,74	864	84	-18,4	ON	164,02	864	28,6	2,06	4,12
    	164,32	0	0	 	 	164,6	864	84	-16	ON	164,89	864	28,6	2,06	4,09
    	165,18	0	0	 	 	165,47	864	84	-13,3	ON	165,78	896	26,3	2,06	3,69
    	166,09	0	0	 	 	166,38	864	84	-14,1	ON	166,69	864	25,1	2,06	3,55
    	166,98	0	0	 	 	167,3	864	84	-16,8	ON	167,6	864	25,1	2,06	3,32
    	167,9	0	0	 	 	168,2	832	84	-19,5	ON	168,47	832	25,1	2,06	3,39
    	168,76	0	0	 	 	169,07	800	84	-22,3	ON	169,35	832	26,3	2,06	3,71
    	169,66	0	0	 	 	169,95	832	84	-25	ON	170,23	832	37,6	3,09	5,93
    	170,54	0	0	 	 	170,83	736	85,5	-23,4	ON	171,11	832	51,4	5,15	7,43
    	171,4	0	0	 	 	171,71	896	84	-20,7	ON	172,01	896	43,5	4,12	6,22
    	172,33	0	0	 	 	172,62	896	85,5	-18	ON	172,92	864	40	4,12	5,83
    	173,21	0	0	 	 	173,51	864	85,5	-15,2	ON	173,8	864	38,8	4,12	5,57
    	174,1	0	0	 	 	174,4	864	85,5	-12,5	ON	174,71	864	37,6	4,12	5,45
    	175,01	0	0	 	 	175,3	864	85,5	-9,8	ON	175,6	864	37,6	4,12	5,39
    	175,9	0	0	 	 	176,19	864	85,5	-7	ON	176,49	864	36,5	4,12	5,33
    	176,79	0	0	 	 	177,08	864	85,5	-9	ON	177,37	864	36,5	4,12	5,27
    	177,69	0	0	 	 	177,99	832	85,5	-11,7	ON	178,3	832	36,5	3,09	5,13
    	178,59	0	0	 	 	178,9	832	85,5	-14,5	ON	179,19	832	37,6	3,09	5,22
    	179,5	0	0	 	 	179,79	832	85,5	-15,2	ON	180,1	832	37,6	4,12	5,27
    	180,4	0	0	 	 	180,7	832	85,5	-12,5	ON	181,01	832	37,6	4,12	5,33
    	181,29	0	0	 	 	181,6	864	85,5	-10,9	ON	181,91	864	37,6	4,12	5,29
    	182,21	0	0	 	 	182,51	832	85,5	-13,7	ON	182,79	832	37,6	4,12	5,33
    	183,08	0	0	 	 	183,4	832	85,5	-16,4	ON	183,7	832	37,6	3,09	5,28
    	184,01	0	0	 	 	184,3	832	85,5	-14,1	ON	184,59	864	37,6	4,12	5,28
    	184,88	0	0	 	 	185,17	832	85,5	-11,3	ON	185,47	864	37,6	4,12	5,24
    	185,77	0	0	 	 	186,06	864	85,5	-13,3	ON	186,36	864	37,6	3,09	5,22
    	186,67	0	0	 	 	186,95	832	85,5	-16	ON	187,24	832	37,6	3,09	5,23
    	187,53	0	0	 	 	187,82	832	85,5	-16	ON	188,12	832	37,6	4,12	5,27
    	188,4	0	0	 	 	188,71	864	85,5	-13,3	ON	189,01	864	37,6	4,12	5,22
    	189,31	0	0	 	 	189,61	832	85,5	-13,7	ON	189,9	832	37,6	4,12	5,19
    	190,19	0	0	 	 	190,48	864	85,5	-16,4	ON	190,78	832	37,6	3,09	5,24
    	191,09	0	0	 	 	191,37	832	85,5	-17,6	ON	191,69	832	37,6	3,09	5,27
    	192	0	0	 	 	192,28	864	85,5	-14,8	ON	192,56	832	37,6	4,12	5,22
    	192,85	0	0	 	 	193,16	864	85,5	-12,5	ON	193,46	864	37,6	4,12	5,23
    	193,75	0	0	 	 	194,05	832	85,5	-15,2	ON	194,36	832	37,6	3,09	5,25
    	194,65	0	0	 	 	194,94	832	85,5	-17,6	ON	195,24	832	37,6	3,09	5,3
    	195,53	0	0	 	 	195,84	832	85,5	-14,8	ON	196,15	832	37,6	4,12	5,21
    	196,43	0	0	 	 	196,71	864	85,5	-12,5	ON	196,99	864	37,6	4,12	5,26
    	197,29	0	0	 	 	197,59	864	85,5	-14,1	ON	197,89	832	36,5	3,09	5,13
    	198,18	0	0	 	 	198,46	832	85,5	-16,8	ON	198,74	832	37,6	3,09	5,22
    	199,03	0	0	 	 	199,33	832	85,5	-17,6	ON	199,61	832	37,6	3,09	5,18
    	199,9	0	0	 	 	200,2	864	85,5	-14,8	ON	200,49	864	37,6	4,12	5,09
    	200,79	0	0	 	 	201,08	832	85,5	-13,7	ON	201,36	864	37,6	3,09	5,22
    	201,65	0	0	 	 	201,94	832	85,5	-16,4	ON	202,22	832	37,6	3,09	5,29
    	202,5	0	0	 	 	202,78	832	85,5	-18,8	ON	203,08	832	37,6	3,09	5,3
    	203,38	0	0	 	 	203,69	832	85,5	-16	ON	203,98	832	38,8	4,12	5,26
    	204,27	0	0	 	 	204,56	864	85,5	-13,3	ON	204,86	864	37,6	4,12	5,25
    	205,16	0	0	 	 	205,46	864	85,5	-14,5	ON	205,75	864	37,6	4,12	5,27
    	206,05	0	0	 	 	206,34	832	85,5	-17,2	ON	206,66	832	37,6	3,09	5,24
    	206,96	0	0	 	 	207,26	832	85,5	-16,8	ON	207,56	832	37,6	4,12	5,22
    	207,85	0	0	 	 	208,13	832	85,5	-14,1	ON	208,41	832	37,6	4,12	5,17
    	208,7	0	0	 	 	208,99	864	85,5	-14,5	ON	209,29	864	37,6	3,09	5,21
    	209,58	0	0	 	 	209,88	832	85,5	-17,2	ON	210,17	832	38,8	3,09	5,36
    	210,47	0	0	 	 	210,75	832	85,5	-17,6	ON	211,06	928	31,8	3,09	3,2
    	211,35	0	0	 	 	211,65	864	85,5	-16	ON	211,94	832	22,7	2,06	2,84
    	212,25	0	0	 	 	212,53	800	85,5	-18,8	ON	212,82	800	25,1	2,06	3,43
    	213,12	0	0	 	 	213,41	832	85,5	-21,1	ON	213,72	832	27,5	2,06	3,76
    	214	0	0	 	 	214,31	832	85,5	-24,2	ON	214,6	832	27,5	2,06	3,85
    	214,91	0	0	 	 	215,21	832	85,5	-24,6	ON	215,5	832	29,8	2,06	4,28
    	215,8	0	0	 	 	216,1	864	85,5	-21,9	ON	216,39	832	28,6	2,06	4,4
    	216,85	0	0	 	 	217,13	864	85,5	-18,4	ON	217,41	864	28,6	2,06	4,42
    So all other tests were done with the Delphi MAF and getting +15...+25% STFT. The only difference as far I can imagine is MAF itself and different coolant and enginebay temperature.
    MAF average 2.65g/s
    Friday	21	June	2019	12:02:49:00008-VCID:1E3368789AB7DDBF84-515A	VCDS Version: Release 19,6,0 (x64)	Data version: 20190529 DS308,0
    	0,01	0	0	 	 	0,26	0	72	0	OFF	0,53	0	0	3,09	0
    	0,79	0	0	 	 	1,06	0	72	0	OFF	1,32	0	0	3,09	0
    	13,35	0	0	 	 	13,62	864	70,5	0	OFF	13,92	864	23,9	3,09	3,26
    	14,23	0	0	 	 	14,53	832	70,5	0	OFF	14,83	832	23,9	3,09	3,13
    	15,14	0	0	 	 	15,43	864	70,5	0	OFF	15,71	832	23,9	3,09	3,36
    	16	0	0	 	 	16,31	832	70,5	0	OFF	16,61	864	23,9	3,09	3,34
    	16,9	0	0	 	 	17,23	864	70,5	0	OFF	17,54	864	23,9	3,09	3,26
    	17,86	0	0	 	 	18,16	864	70,5	0	OFF	18,46	864	23,9	3,09	3,31
    	18,76	0	0	 	 	19,07	832	70,5	0	OFF	19,37	864	23,9	3,09	3,19
    	19,67	0	0	 	 	19,95	832	70,5	0	OFF	20,23	864	23,9	3,09	3,43
    	20,51	0	0	 	 	20,8	864	70,5	0	OFF	21,1	864	23,9	3,09	3,32
    	21,41	0	0	 	 	21,72	864	70,5	0	OFF	22,03	864	23,9	3,09	3,36
    	22,34	0	0	 	 	22,63	864	70,5	0	OFF	22,94	832	23,9	3,09	3,51
    	23,24	0	0	 	 	23,54	864	70,5	0	OFF	23,82	864	23,9	3,09	3,23
    	24,11	0	0	 	 	24,4	864	70,5	0	OFF	24,69	832	22,7	3,09	3,45
    	24,98	0	0	 	 	25,29	864	70,5	0	OFF	25,56	864	23,9	3,09	3,25
    	25,86	0	0	 	 	26,17	832	70,5	0	OFF	26,47	864	23,9	3,09	3,21
    	26,78	0	0	 	 	27,07	832	70,5	0	OFF	27,39	832	22,7	3,09	3,39
    	27,68	0	0	 	 	27,97	864	70,5	0	OFF	28,27	864	23,9	3,09	3,34
    	28,58	0	0	 	 	28,87	832	70,5	0	OFF	29,17	864	23,9	3,09	3,32
    	29,46	0	0	 	 	29,77	832	72	0	OFF	30,08	864	23,9	3,09	3,14
    	30,38	0	0	 	 	30,69	832	72	0	OFF	30,98	864	23,9	3,09	3,23
    	31,28	0	0	 	 	31,59	864	72	0	OFF	31,87	864	23,9	3,09	3,36
    	32,16	0	0	 	 	32,46	832	72	0	OFF	32,75	832	23,9	3,09	3,39
    	33,05	0	0	 	 	33,34	864	72	0	OFF	33,63	864	22,7	3,09	3,29
    	33,93	0	0	 	 	34,22	864	72	0	OFF	34,51	864	22,7	3,09	3,35
    	34,82	0	0	 	 	35,12	832	72	0	OFF	35,43	832	22,7	2,06	3,28
    	35,72	0	0	 	 	36,02	832	72	0	OFF	36,32	832	22,7	3,09	3,31
    	36,62	0	0	 	 	36,91	832	72	0	OFF	37,22	864	22,7	3,09	3,33
    	37,52	0	0	 	 	37,81	832	72	0	OFF	38,12	864	23,9	3,09	3,31
    	38,43	0	0	 	 	38,73	832	72	0	OFF	39,02	832	23,9	3,09	3,42
    	39,32	0	0	 	 	39,61	832	72	0	OFF	39,9	864	23,9	3,09	3,31
    	40,21	0	0	 	 	40,52	864	72	0	OFF	40,8	864	23,9	3,09	3,51
    	41,11	0	0	 	 	41,44	864	72	0	OFF	41,74	864	23,9	3,09	3,33
    	42,04	0	0	 	 	42,34	864	72	0	OFF	42,63	832	23,9	3,09	3,28
    	42,93	0	0	 	 	43,22	864	72	0	OFF	43,51	864	23,9	3,09	3,29
    	43,81	0	0	 	 	44,1	864	72	2,3	ON	44,39	864	23,9	3,09	3,37
    	44,68	0	0	 	 	44,98	864	72	5,1	ON	45,28	896	22,7	3,09	3,19
    	45,57	0	0	 	 	45,86	864	72	7,4	ON	46,16	864	22,7	3,09	3,14
    	46,45	0	0	 	 	46,75	864	72	10,2	ON	47,04	864	21,6	3,09	2,99
    	47,33	0	0	 	 	47,61	864	72	12,9	ON	47,9	864	20,4	3,09	2,82
    	48,19	0	0	 	 	48,48	864	72	13,3	ON	48,77	864	20,4	2,06	2,88
    	49,06	0	0	 	 	49,36	832	72	10,5	ON	49,67	832	19,2	2,06	2,69
    	49,96	0	0	 	 	50,25	832	72	8,2	ON	50,53	832	21,6	2,06	3,13
    	50,81	0	0	 	 	51,09	832	72	7,8	ON	51,36	864	21,6	2,06	3,13
    	51,63	0	0	 	 	51,93	864	72	10,5	ON	52,21	864	20,4	3,09	3,02
    	52,5	0	0	 	 	52,8	864	72	13,3	ON	53,09	864	20,4	3,09	3,01
    	53,38	0	0	 	 	53,67	864	72	15,6	ON	53,97	864	20,4	3,09	2,83
    	54,27	0	0	 	 	54,57	864	72	18	ON	54,89	864	19,2	2,06	2,72
    	55,2	0	0	 	 	55,5	864	72	15,2	ON	55,79	832	19,2	2,06	2,83
    	56,09	0	0	 	 	56,37	832	72	12,5	ON	56,68	832	19,2	2,06	2,79
    	56,99	0	0	 	 	57,27	832	73,5	9,8	ON	57,57	800	19,2	2,06	2,82
    	57,87	0	0	 	 	58,18	832	73,5	12,1	ON	58,47	864	20,4	2,06	2,94
    	58,77	0	0	 	 	59,08	832	73,5	15,2	ON	59,38	864	20,4	3,09	2,96
    	59,68	0	0	 	 	59,97	864	73,5	18	ON	60,25	864	20,4	3,09	2,78
    	60,54	0	0	 	 	60,84	864	73,5	17,6	ON	61,14	864	19,2	2,06	2,83
    	61,43	0	0	 	 	61,74	832	73,5	14,8	ON	62,03	832	19,2	2,06	2,73
    	62,34	0	0	 	 	62,65	832	73,5	11,7	ON	62,94	832	19,2	2,06	2,55
    	63,24	0	0	 	 	63,54	832	73,5	13,7	ON	63,83	864	20,4	3,09	3,07
    	64,12	0	0	 	 	64,43	864	73,5	16,4	ON	64,74	864	20,4	3,09	2,98
    	65,04	0	0	 	 	65,33	864	73,5	19,1	ON	65,61	864	19,2	3,09	2,64
    	65,92	0	0	 	 	66,22	864	73,5	18	ON	66,5	864	19,2	2,06	2,64
    	66,79	0	0	 	 	67,09	864	73,5	15,6	ON	67,37	832	18,4	2,06	2,44
    	67,65	0	0	 	 	67,93	832	73,5	12,9	ON	68,23	832	19,2	2,06	2,64
    	68,53	0	0	 	 	68,83	800	73,5	10,2	ON	69,1	864	20,4	3,09	3,11
    	69,39	0	0	 	 	69,7	864	73,5	12,9	ON	70,01	864	20,4	3,09	3,24
    	70,31	0	0	 	 	70,6	864	73,5	15,6	ON	70,89	864	20,4	3,09	3,01
    	71,19	0	0	 	 	71,49	864	73,5	18,4	ON	71,79	864	19,2	3,09	2,82
    	72,07	0	0	 	 	72,39	864	73,5	18,4	ON	72,7	864	19,2	2,06	2,71
    	73,01	0	0	 	 	73,3	864	73,5	15,2	ON	73,59	832	19,2	2,06	2,61
    	73,89	0	0	 	 	74,19	832	73,5	12,5	ON	74,49	832	19,2	2,06	2,89
    	74,77	0	0	 	 	75,06	832	73,5	11,7	ON	75,35	832	19,2	2,06	2,74
    	75,63	0	0	 	 	75,93	832	75	14,5	ON	76,24	864	19,2	2,06	2,89
    	76,53	0	0	 	 	76,85	864	75	17,2	ON	77,13	864	19,2	2,06	2,83
    	77,43	0	0	 	 	77,73	864	75	19,9	ON	78,04	864	19,2	3,09	2,75
    	78,32	0	0	 	 	78,6	864	75	21,1	ON	78,91	864	18,4	2,06	2,69
    	79,22	0	0	 	 	79,51	864	75	18,4	ON	79,79	864	18,4	2,06	2,32
    	80,1	0	0	 	 	80,38	832	75	15,6	ON	80,68	832	18,4	2,06	2,76
    	80,97	0	0	 	 	81,28	832	75	12,9	ON	81,56	832	19,2	2,06	2,67
    	81,85	0	0	 	 	82,15	832	75	11,7	ON	82,46	832	19,2	2,06	2,84
    	82,76	0	0	 	 	83,07	864	75	14,5	ON	83,36	864	19,2	2,06	2,83
    	83,67	0	0	 	 	83,95	864	75	17,2	ON	84,25	864	19,2	2,06	2,74
    	84,55	0	0	 	 	84,84	864	75	19,1	ON	85,15	864	18,4	2,06	2,83
    	85,45	0	0	 	 	85,75	864	75	16,4	ON	86,05	832	18,4	2,06	2,39
    	86,36	0	0	 	 	86,64	832	75	13,7	ON	86,92	832	18,4	2,06	2,57
    	87,23	0	0	 	 	87,53	832	75	12,9	ON	87,81	864	19,2	2,06	2,69
    	88,12	0	0	 	 	88,42	864	75	15,6	ON	88,73	864	19,2	2,06	2,79
    	89,03	0	0	 	 	89,32	864	75	18	ON	89,63	864	19,2	2,06	2,83
    	89,94	0	0	 	 	90,24	864	75	21,1	ON	90,55	864	19,2	2,06	2,62
    	90,85	0	0	 	 	91,14	864	75	18,8	ON	91,44	864	18,4	2,06	2,5
    	91,73	0	0	 	 	92,02	832	75	16	ON	92,33	832	18,4	2,06	2,58
    	92,63	0	0	 	 	92,92	832	75	13,3	ON	93,23	832	18,4	2,06	2,52
    	93,51	0	0	 	 	93,79	832	75	11,3	ON	94,1	832	19,2	2,06	2,75
    	94,4	0	0	 	 	94,67	832	75	14,1	ON	94,95	832	19,2	2,06	2,78
    	95,25	0	0	 	 	95,57	864	75	16,8	ON	95,87	864	19,2	2,06	2,74
    	96,16	0	0	 	 	96,44	864	75	19,5	ON	96,73	864	18,4	2,06	2,56
    	97,03	0	0	 	 	97,34	864	75	20,3	ON	97,65	864	18,4	2,06	2,72
    	97,93	0	0	 	 	98,23	864	76,5	17,6	ON	98,52	832	17,3	2,06	2,34
    	98,79	0	0	 	 	99,11	832	76,5	14,8	ON	99,38	832	18,4	2,06	2,47
    	99,66	0	0	 	 	99,95	832	76,5	12,5	ON	100,25	832	18,4	2,06	2,69
    	100,51	0	0	 	 	100,82	832	76,5	13,7	ON	101,11	832	19,2	2,06	2,71
    	101,41	0	0	 	 	101,7	864	76,5	16,4	ON	101,99	864	19,2	2,06	2,72
    	102,3	0	0	 	 	102,6	864	76,5	19,1	ON	102,92	864	18,4	2,06	2,73
    	103,21	0	0	 	 	103,51	864	76,5	21,9	ON	103,81	864	18,4	2,06	2,54
    	104,11	0	0	 	 	104,4	864	76,5	20,3	ON	104,67	864	17,3	2,06	2,58
    	104,97	0	0	 	 	105,27	832	76,5	17,6	ON	105,58	832	17,3	2,06	2,42
    	105,87	0	0	 	 	106,17	832	76,5	14,8	ON	106,47	832	17,3	2,06	2,54
    	106,76	0	0	 	 	107,06	832	76,5	12,1	ON	107,35	832	18,4	2,06	2,62
    	107,66	0	0	 	 	107,96	832	76,5	12,9	ON	108,26	832	19,2	2,06	2,86
    	108,55	0	0	 	 	108,85	832	76,5	14,5	ON	109,14	832	19,2	2,06	2,69
    	109,45	0	0	 	 	109,73	832	76,5	17,2	ON	110,05	832	19,2	2,06	2,75
    	110,32	0	0	 	 	110,63	864	76,5	19,9	ON	110,92	864	18,4	2,06	2,86
    	111,21	0	0	 	 	111,51	864	76,5	22,7	ON	111,79	864	18,4	2,06	2,54
    	112,09	0	0	 	 	112,38	864	76,5	24,2	ON	112,68	864	18,4	2,06	2,73
    	112,97	0	0	 	 	113,28	864	76,5	21,5	ON	113,58	832	17,3	2,06	2,48
    	113,89	0	0	 	 	114,17	832	76,5	18,8	ON	114,46	832	18,4	2,06	2,46
    	114,75	0	0	 	 	115,07	832	76,5	16	ON	115,37	832	18,4	2,06	2,61
    	115,67	0	0	 	 	115,97	832	76,5	13,3	ON	116,25	832	18,4	2,06	2,58
    	116,55	0	0	 	 	116,85	832	76,5	16	ON	117,16	832	19,2	2,06	2,87
    	117,45	0	0	 	 	117,75	864	76,5	18,8	ON	118,05	864	18,4	2,06	2,66
    	118,34	0	0	 	 	118,65	832	76,5	20,7	ON	118,94	864	18,4	2,06	2,57
    	119,22	0	0	 	 	119,52	864	76,5	18,4	ON	119,82	864	18,4	2,06	2,35
    	120,12	0	0	 	 	120,41	832	76,5	15,6	ON	120,69	832	17,3	2,06	2,53
    	120,95	0	0	 	 	121,26	864	76,5	12,9	ON	121,56	864	17,3	2,06	2,42
    	121,86	0	0	 	 	122,16	864	76,5	10,2	ON	122,44	864	17,3	2,06	2,24
    	122,71	0	0	 	 	123,01	864	78	8,2	ON	123,3	864	16,1	2,06	2,24
    	123,61	0	0	 	 	123,91	832	78	7	ON	124,21	832	17,3	2,06	2,38
    	124,51	0	0	 	 	124,81	832	78	7,4	ON	125,12	832	18,4	2,06	2,64
    	125,4	0	0	 	 	125,66	832	78	11,7	ON	125,96	832	19,2	2,06	2,83
    	126,24	0	0	 	 	126,54	832	78	15,6	ON	126,83	864	19,2	2,06	2,64
    	127,11	0	0	 	 	127,4	832	78	18,4	ON	127,69	864	18,4	2,06	2,8
    	127,99	0	0	 	 	128,27	864	78	20,7	ON	128,58	864	18,4	2,06	2,69
    	128,87	0	0	 	 	129,18	864	78	24,6	ON	129,48	864	18,4	2,06	2,77
    	129,78	0	0	 	 	130,08	864	78	25,8	ON	130,36	864	17,3	2,06	2,44
    	130,66	0	0	 	 	130,95	832	78	23	ON	131,25	832	17,3	2,06	2,34
    	131,56	0	0	 	 	131,85	832	78	20,3	ON	132,16	832	17,3	2,06	2,53
    	132,44	0	0	 	 	132,73	832	78	17,6	ON	133,02	832	17,3	2,06	2,43
    	133,34	0	0	 	 	133,62	832	78	14,8	ON	133,9	832	18,4	2,06	2,64
    	134,21	0	0	 	 	134,5	832	78	16,4	ON	134,8	832	18,4	2,06	2,5
    	135,08	0	0	 	 	135,4	864	78	19,1	ON	135,69	864	18,4	2,06	2,56
    	135,97	0	0	 	 	136,27	864	78	21,9	ON	136,57	864	18,4	2,06	2,54
    	136,85	0	0	 	 	137,14	864	78	23,8	ON	137,44	864	17,3	2,06	2,38
    	137,75	0	0	 	 	138,05	832	78	21,1	ON	138,35	864	17,3	2,06	2,44
    	138,64	0	0	 	 	138,92	832	78	18,4	ON	139,22	832	17,3	2,06	2,59
    	139,5	0	0	 	 	139,81	832	78	15,6	ON	140,09	832	18,4	2,06	2,69
    	140,39	0	0	 	 	140,68	864	78	18	ON	140,99	864	18,4	2,06	2,79
    	141,29	0	0	 	 	141,59	864	78	20,7	ON	141,9	864	18,4	2,06	2,83
    	142,2	0	0	 	 	142,49	864	78	23,4	ON	142,79	864	18,4	2,06	2,66
    	143,09	0	0	 	 	143,38	864	78	22,3	ON	143,67	832	17,3	2,06	2,67
    	143,95	0	0	 	 	144,25	832	78	19,5	ON	144,54	832	17,3	2,06	2,46
    	144,83	0	0	 	 	145,13	832	78	16,8	ON	145,42	832	17,3	2,06	2,41
    	145,72	0	0	 	 	146,02	832	78	14,1	ON	146,33	832	18,4	2,06	2,5
    	146,62	0	0	 	 	146,91	864	78	16,8	ON	147,21	864	18,4	2,06	2,69
    	147,5	0	0	 	 	147,8	864	78	19,5	ON	148,11	864	18,4	2,06	2,78
    	148,4	0	0	 	 	148,69	864	78	22,3	ON	148,98	864	18,4	2,06	2,63
    	149,29	0	0	 	 	149,6	864	78	21,9	ON	149,88	864	17,3	2,06	2,42
    	150,16	0	0	 	 	150,45	832	78	19,1	ON	150,76	832	17,3	2,06	2,37
    	151,06	0	0	 	 	151,35	832	78	16,4	ON	151,66	832	17,3	2,06	2,55
    	151,94	0	0	 	 	152,24	832	78	16	ON	152,54	864	18,4	2,06	2,51
    	152,84	0	0	 	 	153,13	864	78	18,8	ON	153,43	832	18,4	2,06	2,64
    	153,72	0	0	 	 	154,02	864	78	21,5	ON	154,33	864	18,4	2,06	2,67
    	154,63	0	0	 	 	154,93	864	78	23,8	ON	155,21	864	18,4	2,06	2,56
    	155,53	0	0	 	 	155,83	864	78	21,1	ON	156,13	864	17,3	2,06	2,46
    	156,42	0	0	 	 	156,71	832	78	18,4	ON	157,01	832	17,3	2,06	2,66
    	157,3	0	0	 	 	157,61	832	78	15,6	ON	157,9	832	18,4	2,06	2,54
    	158,17	0	0	 	 	158,46	864	79,5	16,8	ON	158,74	832	18,4	2,06	2,66
    	159,03	0	0	 	 	159,33	864	79,5	19,5	ON	159,61	832	17,3	2,06	2,5
    	159,89	0	0	 	 	160,18	832	79,5	21,1	ON	160,48	864	17,3	2,06	2,55
    	160,77	0	0	 	 	161,04	832	79,5	18,4	ON	161,35	832	18,4	2,06	2,55
    	161,63	0	0	 	 	161,92	832	79,5	16,8	ON	162,23	832	18,4	2,06	2,64
    	162,52	0	0	 	 	162,83	864	79,5	19,5	ON	163,15	864	18,4	2,06	2,52
    	163,46	0	0	 	 	163,75	864	79,5	22,3	ON	164,06	864	18,4	2,06	2,57
    	164,35	0	0	 	 	164,65	864	79,5	21,9	ON	164,95	864	17,3	2,06	2,37
    	165,23	0	0	 	 	165,51	832	79,5	19,1	ON	165,79	832	17,3	2,06	2,52
    	166,06	0	0	 	 	166,36	832	79,5	16,4	ON	166,66	832	17,3	2,06	2,63
    	166,96	0	0	 	 	167,26	832	79,5	18	ON	167,54	832	18,4	2,06	2,63
    	167,83	0	0	 	 	168,12	864	79,5	20,7	ON	168,43	864	18,4	2,06	2,66
    	168,75	0	0	 	 	169,03	864	79,5	23,4	ON	169,31	864	18,4	2,06	2,53
    	169,61	0	0	 	 	169,9	864	79,5	22,3	ON	170,2	864	17,3	2,06	2,64
    	170,5	0	0	 	 	170,78	832	79,5	19,5	ON	171,08	832	17,3	2,06	2,47
    	171,37	0	0	 	 	171,68	832	79,5	17,2	ON	171,98	832	17,3	2,06	2,53
    	172,27	0	0	 	 	172,55	832	79,5	14,1	ON	172,85	832	18,4	2,06	2,63
    	173,15	0	0	 	 	173,43	864	79,5	16,4	ON	173,7	864	18,4	2,06	2,74
    	174,01	0	0	 	 	174,3	864	79,5	19,1	ON	174,6	864	18,4	2,06	2,69
    	174,89	0	0	 	 	175,18	864	79,5	21,9	ON	175,47	864	18,4	2,06	2,66
    	175,76	0	0	 	 	176,04	864	79,5	23,4	ON	176,33	864	17,3	2,06	2,51
    	176,61	0	0	 	 	176,91	832	79,5	20,7	ON	177,2	832	17,3	2,06	2,44
    	177,5	0	0	 	 	177,79	832	79,5	18	ON	178,1	832	17,3	2,06	2,44
    	178,39	0	0	 	 	178,69	832	79,5	16	ON	178,99	832	18,4	2,06	2,68
    	179,28	0	0	 	 	179,58	832	79,5	18,8	ON	179,87	864	18,4	2,06	2,66
    	180,17	0	0	 	 	180,46	864	79,5	21,1	ON	180,76	864	18,4	2,06	2,58
    	181,05	0	0	 	 	181,34	864	79,5	23,8	ON	181,65	864	17,3	2,06	2,46
    	181,95	0	0	 	 	182,25	864	79,5	21,1	ON	182,55	864	17,3	2,06	2,5
    	182,85	0	0	 	 	183,14	832	79,5	18,4	ON	183,41	832	17,3	2,06	2,32
    	183,72	0	0	 	 	184,04	832	79,5	15,6	ON	184,33	832	17,3	2,06	2,5
    	184,61	0	0	 	 	184,92	832	79,5	14,8	ON	185,21	864	18,4	2,06	2,75
    	185,52	0	0	 	 	185,83	864	79,5	17,6	ON	186,14	864	18,4	2,06	2,72
    	186,42	0	0	 	 	186,72	864	79,5	20,3	ON	187	864	18,4	2,06	2,52
    	187,3	0	0	 	 	187,6	864	79,5	23	ON	187,88	864	18,4	2,06	2,5
    	188,17	0	0	 	 	188,46	864	79,5	21,1	ON	188,76	864	17,3	2,06	2,47
    	189,06	0	0	 	 	189,37	832	79,5	18,4	ON	189,67	832	17,3	2,06	2,59
    	189,95	0	0	 	 	190,26	832	79,5	16	ON	190,55	832	17,3	2,06	2,38
    	190,83	0	0	 	 	191,11	832	79,5	18,8	ON	191,39	832	17,3	2,06	2,53
    	191,7	0	0	 	 	191,98	864	79,5	21,5	ON	192,29	864	17,3	2,06	2,44
    	192,58	0	0	 	 	192,89	864	81	22,3	ON	193,17	864	17,3	2,06	2,53
    	193,47	0	0	 	 	193,75	864	81	19,5	ON	194,03	832	17,3	2,06	2,41
    	194,33	0	0	 	 	194,63	832	81	16,8	ON	194,9	832	17,3	2,06	2,48
    	195,19	0	0	 	 	195,49	832	81	17,6	ON	195,79	832	17,3	2,06	2,58
    	196,09	0	0	 	 	196,38	832	81	20,3	ON	196,66	864	17,3	2,06	2,43
    	196,95	0	0	 	 	197,25	832	81	23	ON	197,56	864	17,3	2,06	2,43
    	197,86	0	0	 	 	198,16	864	81	20,7	ON	198,46	864	17,3	2,06	2,35
    	198,75	0	0	 	 	199,04	832	81	18	ON	199,35	832	17,3	2,06	2,64
    	199,63	0	0	 	 	199,91	832	81	16,4	ON	200,19	832	17,3	2,06	2,44
    	200,49	0	0	 	 	200,78	864	81	19,1	ON	201,07	864	17,3	2,06	2,59
    	201,36	0	0	 	 	201,65	864	81	21,9	ON	201,94	864	17,3	2,06	2,52
    	202,24	0	0	 	 	202,52	864	81	23	ON	202,82	864	17,3	2,06	2,46
    	203,12	0	0	 	 	203,41	864	81	20,3	ON	203,72	864	17,3	2,06	2,28
    	204,01	0	0	 	 	204,29	832	81	17,6	ON	204,57	800	17,3	2,06	2,38
    	204,86	0	0	 	 	205,15	832	81	15,2	ON	205,45	832	18,4	2,06	2,66
    	205,75	0	0	 	 	206,05	864	81	18,4	ON	206,35	864	18,4	2,06	2,49
    	206,64	0	0	 	 	206,94	864	81	20,7	ON	207,22	864	18,4	2,06	2,61
    	207,52	0	0	 	 	207,81	864	81	23,4	ON	208,1	864	17,3	2,06	2,38
    	208,39	0	0	 	 	208,69	864	81	21,1	ON	208,98	832	17,3	2,06	2,37
    	209,29	0	0	 	 	209,6	832	81	18,4	ON	209,89	832	17,3	2,06	2,21
    	210,2	0	0	 	 	210,49	832	81	15,6	ON	210,8	832	17,3	2,06	2,48
    	211,1	0	0	 	 	211,39	832	81	16	ON	211,69	832	17,3	2,06	2,57
    	211,98	0	0	 	 	212,26	832	81	18,4	ON	212,56	832	18,4	2,06	2,63
    	212,87	0	0	 	 	213,17	864	81	21,1	ON	213,46	864	18,4	2,06	2,66
    	213,75	0	0	 	 	214,06	864	81	23,8	ON	214,35	864	17,3	2,06	2,37
    	214,64	0	0	 	 	214,93	864	81	21,5	ON	215,21	864	17,3	2,06	2,5
    	215,49	0	0	 	 	215,77	832	81	18,8	ON	216,07	832	17,3	2,06	2,39
    	216,37	0	0	 	 	216,67	832	81	16	ON	216,98	832	17,3	2,06	2,46
    	217,28	0	0	 	 	217,58	832	81	17,6	ON	217,87	864	18,4	2,06	2,79
    	218,16	0	0	 	 	218,46	864	81	20,3	ON	218,75	864	18,4	2,06	2,83
    	219,05	0	0	 	 	219,34	864	81	22,7	ON	219,64	864	18,4	2,06	2,58
    	219,93	0	0	 	 	220,22	864	81	23,4	ON	220,51	864	17,3	2,06	2,51
    	220,82	0	0	 	 	221,11	832	81	20,7	ON	221,4	832	17,3	2,06	2,37
    	221,71	0	0	 	 	222	832	81	18	ON	222,29	832	16,1	2,06	2,14
    	222,59	0	0	 	 	222,88	832	81	15,2	ON	223,19	832	17,3	2,06	2,64
    	223,48	0	0	 	 	223,78	832	81	15,2	ON	224,08	832	18,4	2,06	2,62
    	224,37	0	0	 	 	224,66	864	81	18	ON	224,96	864	18,4	2,06	2,68
    	225,26	0	0	 	 	225,56	864	81	20,7	ON	225,87	864	18,4	2,06	2,71
    	226,16	0	0	 	 	226,45	864	81	23,4	ON	226,74	864	17,3	2,06	2,5
    	227,04	0	0	 	 	227,33	832	81	20,7	ON	227,63	864	16,1	2,06	2,26
    	227,91	0	0	 	 	228,21	832	81	18	ON	228,49	832	16,1	2,06	2,46
    	228,78	0	0	 	 	229,09	832	81	15,2	ON	229,37	832	17,3	2,06	2,67
    	229,66	0	0	 	 	229,94	864	81	16,8	ON	230,21	832	17,3	2,06	2,47
    	230,52	0	0	 	 	230,81	864	81	19,5	ON	231,11	864	17,3	2,06	2,54
    	231,41	0	0	 	 	231,72	864	81	22,3	ON	232,01	864	17,3	2,06	2,46
    	232,3	0	0	 	 	232,62	864	81	23	ON	232,91	832	17,3	2,06	2,53
    	233,22	0	0	 	 	233,53	864	81	19,9	ON	233,83	832	17,3	2,06	2,36
    	234,13	0	0	 	 	234,44	832	81	17,2	ON	234,75	832	17,3	2,06	2,49
    	235,05	0	0	 	 	235,34	832	81	17,2	ON	235,62	832	17,3	2,06	2,41
    	235,9	0	0	 	 	236,18	864	81	19,9	ON	236,47	864	17,3	2,06	2,56
    	236,77	0	0	 	 	237,07	864	81	22,7	ON	237,36	864	17,3	2,06	2,38
    	237,65	0	0	 	 	237,94	864	81	21,9	ON	238,23	864	17,3	2,06	2,43
    	238,54	0	0	 	 	238,83	832	81	19,1	ON	239,11	832	17,3	2,06	2,46
    	239,42	0	0	 	 	239,71	832	81	18	ON	240,02	832	17,3	2,06	2,46
    	240,31	0	0	 	 	240,6	832	81	20,7	ON	240,9	864	18,4	2,06	2,55
    	241,2	0	0	 	 	241,49	864	82,5	23,4	ON	241,79	864	17,3	2,06	2,61
    	242,09	0	0	 	 	242,39	864	82,5	22,7	ON	242,67	864	17,3	2,06	2,64
    	242,96	0	0	 	 	243,26	864	82,5	19,9	ON	243,54	832	17,3	2,06	2,38
    	243,85	0	0	 	 	244,14	832	82,5	17,2	ON	244,44	832	17,3	2,06	2,41
    	244,75	0	0	 	 	245,05	832	82,5	15,6	ON	245,35	832	17,3	2,06	2,51
    	245,64	0	0	 	 	245,94	832	82,5	18,4	ON	246,22	864	18,4	2,06	2,59
    	246,52	0	0	 	 	246,8	864	82,5	21,1	ON	247,09	864	18,4	2,06	2,77
    	247,39	0	0	 	 	247,71	864	82,5	23,8	ON	248,01	864	17,3	2,06	2,39
    	248,31	0	0	 	 	248,62	864	82,5	21,5	ON	248,9	832	17,3	2,06	2,4
    	249,2	0	0	 	 	249,51	832	82,5	18,8	ON	249,8	832	17,3	2,06	2,37
    	250,09	0	0	 	 	250,37	832	82,5	16	ON	250,67	832	17,3	2,06	2,35
    	250,97	0	0	 	 	251,25	832	82,5	16,8	ON	251,55	864	18,4	2,06	2,73
    	251,85	0	0	 	 	252,15	864	82,5	19,5	ON	252,45	864	18,4	2,06	2,74
    	252,75	0	0	 	 	253,04	864	82,5	22,3	ON	253,33	864	18,4	2,06	2,53
    	253,63	0	0	 	 	253,94	864	82,5	23	ON	254,23	864	17,3	2,06	2,56
    	254,51	0	0	 	 	254,81	832	82,5	20,3	ON	255,11	832	17,3	2,06	2,44
    	255,43	0	0	 	 	255,73	832	82,5	17,6	ON	256,02	832	17,3	2,06	2,48
    	256,31	0	0	 	 	256,6	832	82,5	16	ON	256,9	832	18,4	2,06	2,47
    	257,21	0	0	 	 	257,48	864	82,5	18,8	ON	257,79	864	18,4	2,06	2,62
    	258,1	0	0	 	 	258,39	864	82,5	21,5	ON	258,68	864	17,3	2,06	2,63
    	258,99	0	0	 	 	259,28	864	82,5	21,5	ON	259,58	864	17,3	2,06	2,38
    	259,86	0	0	 	 	260,14	832	82,5	18,8	ON	260,42	832	17,3	2,06	2,49
    	260,7	0	0	 	 	260,99	832	82,5	16	ON	261,3	832	18,4	2,06	2,6
    	261,59	0	0	 	 	261,88	832	82,5	18,4	ON	262,18	832	18,4	2,06	2,69
    	262,48	0	0	 	 	262,77	832	82,5	20,7	ON	263,06	864	18,4	2,06	2,69
    	263,35	0	0	 	 	263,66	832	82,5	23,4	ON	263,96	864	18,4	2,06	2,66
    	264,25	0	0	 	 	264,56	864	82,5	21,1	ON	264,87	832	18,4	2,06	2,69
    	265,15	0	0	 	 	265,44	832	82,5	18,8	ON	265,75	832	18,4	2,06	2,62
    	266,04	0	0	 	 	266,32	832	82,5	16,4	ON	266,59	832	18,4	2,06	2,57
    	266,87	0	0	 	 	267,16	864	82,5	18,8	ON	267,44	832	18,4	2,06	2,46
    	267,73	0	0	 	 	268,03	864	82,5	21,5	ON	268,33	864	18,4	2,06	2,38
    	268,61	0	0	 	 	268,91	864	82,5	23,8	ON	269,21	864	17,3	2,06	2,42
    	269,52	0	0	 	 	269,82	864	82,5	21,1	ON	270,13	832	17,3	2,06	2,46
    	270,45	0	0	 	 	270,74	832	82,5	18	ON	271,04	832	17,3	2,06	2,07
    	271,35	0	0	 	 	271,64	832	82,5	15,2	ON	271,94	832	18,4	2,06	2,52
    	272,24	0	0	 	 	272,53	832	82,5	14,5	ON	272,82	832	19,2	2,06	2,86
    	273,11	0	0	 	 	273,41	864	82,5	17,2	ON	273,71	864	19,2	2,06	2,83
    	274,01	0	0	 	 	274,3	832	82,5	19,9	ON	274,59	864	18,4	2,06	2,78
    	274,9	0	0	 	 	275,2	864	82,5	22,7	ON	275,52	864	18,4	2,06	2,63
    	275,84	0	0	 	 	276,14	864	82,5	23	ON	276,45	864	17,3	2,06	2,44
    	276,74	0	0	 	 	277,03	864	82,5	20,3	ON	277,32	864	17,3	2,06	2,3
    	277,6	0	0	 	 	277,9	832	82,5	17,6	ON	278,19	800	17,3	2,06	2,46
    	278,49	0	0	 	 	278,77	832	82,5	14,8	ON	279,04	832	18,4	2,06	2,6
    	279,35	0	0	 	 	279,64	832	82,5	17,2	ON	279,94	864	18,4	2,06	2,66
    	280,23	0	0	 	 	280,54	832	82,5	19,9	ON	280,84	832	18,4	2,06	2,6
    	281,13	0	0	 	 	281,42	864	82,5	22,7	ON	281,73	864	18,4	2,06	2,63
    	282,02	0	0	 	 	282,31	864	82,5	20,3	ON	282,61	864	18,4	2,06	2,51
    	282,88	0	0	 	 	283,17	832	82,5	17,6	ON	283,45	832	17,3	2,06	2,4
    	283,73	0	0	 	 	284,03	832	82,5	15,6	ON	284,33	832	18,4	2,06	2,56
    	284,62	0	0	 	 	284,9	832	82,5	18,4	ON	285,19	864	18,4	2,06	2,61
    	285,5	0	0	 	 	285,81	864	82,5	21,1	ON	286,12	864	18,4	2,06	2,63
    	286,4	0	0	 	 	286,71	864	82,5	23,4	ON	287	864	18,4	2,06	2,69
    	287,29	0	0	 	 	287,6	864	82,5	20,7	ON	287,9	832	17,3	2,06	2,44
    	288,2	0	0	 	 	288,51	832	82,5	18	ON	288,8	832	17,3	2,06	2,56
    	289,08	0	0	 	 	289,37	832	82,5	15,2	ON	289,65	832	17,3	2,06	2,52
    	289,95	0	0	 	 	290,25	832	82,5	17,2	ON	290,54	832	18,4	2,06	2,5
    	290,84	0	0	 	 	291,15	832	82,5	19,9	ON	291,43	864	18,4	2,06	2,64
    	291,72	0	0	 	 	292	864	82,5	22,3	ON	292,31	864	18,4	2,06	2,54
    	292,61	0	0	 	 	292,9	832	82,5	20,3	ON	293,19	864	18,4	2,06	2,6
    	293,49	0	0	 	 	293,8	832	82,5	17,2	ON	294,1	832	17,3	2,06	2,57
    	294,38	0	0	 	 	294,69	832	82,5	16,4	ON	294,98	832	18,4	2,06	2,62
    	295,27	0	0	 	 	295,55	864	82,5	18,8	ON	295,85	832	18,4	2,06	2,58
    	296,14	0	0	 	 	296,43	864	82,5	21,1	ON	296,72	864	18,4	2,06	2,47
    	297,02	0	0	 	 	297,32	864	82,5	23,8	ON	297,61	864	18,4	2,06	2,55
    	297,92	0	0	 	 	298,21	864	82,5	21,1	ON	298,52	832	18,4	2,06	2,54
    	298,82	0	0	 	 	299,12	864	82,5	18	ON	299,4	832	18,4	2,06	2,66
    	299,69	0	0	 	 	299,97	832	82,5	19,9	ON	300,25	832	18,4	2,06	2,68
    	300,55	0	0	 	 	300,83	832	82,5	22,7	ON	301,14	832	18,4	2,06	2,59
    	301,42	0	0	 	 	301,71	832	82,5	23,8	ON	302,02	864	18,4	2,06	2,52
    	302,32	0	0	 	 	302,62	864	82,5	21,1	ON	302,92	864	17,3	2,06	2,49
    	303,23	0	0	 	 	303,51	832	82,5	18,4	ON	303,81	832	18,4	2,06	2,66
    	304,09	0	0	 	 	304,38	832	82,5	18	ON	304,69	832	18,4	2,06	2,66
    	304,98	0	0	 	 	305,29	864	82,5	20,7	ON	305,57	832	18,4	2,06	2,61
    	305,87	0	0	 	 	306,17	864	82,5	23,4	ON	306,47	896	18,4	2,06	2,69
    	306,76	0	0	 	 	307,07	864	82,5	22,7	ON	307,38	864	18,4	2,06	2,6
    	307,67	0	0	 	 	307,97	864	82,5	19,9	ON	308,27	832	17,3	2,06	2,4
    	308,56	0	0	 	 	308,86	832	82,5	17,2	ON	309,13	832	17,3	2,06	2,61
    	309,44	0	0	 	 	309,72	832	82,5	18,4	ON	310	832	18,4	2,06	2,69
    	310,29	0	0	 	 	310,59	864	82,5	21,1	ON	310,88	864	18,4	2,06	2,69
    	311,18	0	0	 	 	311,48	864	82,5	23,8	ON	311,77	864	18,4	2,06	2,69
    	312,08	0	0	 	 	312,4	864	82,5	21,1	ON	312,7	864	18,4	2,06	2,5
    	312,98	0	0	 	 	313,28	864	82,5	18,4	ON	313,6	832	18,4	2,06	2,87
    	313,9	0	0	 	 	314,21	832	82,5	18,8	ON	314,48	864	18,4	2,06	2,49
    	314,79	0	0	 	 	315,07	832	82,5	21,1	ON	315,38	864	18,4	2,06	2,71
    	315,67	0	0	 	 	315,98	832	82,5	23,8	ON	316,28	864	18,4	2,06	2,66
    	316,57	0,8	0	 	 	316,86	864	82,5	20,7	ON	317,16	864	18,4	2,06	2,49
    	317,45	0,8	0	 	 	317,73	832	82,5	18	ON	318,03	832	18,4	2,06	2,39
    	318,34	1,6	0	 	 	318,65	832	84	15,2	ON	318,94	832	18,4	2,06	2,52
    	319,23	1,6	0	 	 	319,52	832	82,5	17,6	ON	319,81	832	18,4	2,06	2,54
    	320,09	0,8	0	 	 	320,39	864	82,5	20,3	ON	320,67	864	18,4	2,06	2,64
    	320,96	0,8	0	 	 	321,25	864	82,5	23	ON	321,54	864	18,4	2,06	2,63
    	321,83	0,8	0	 	 	322,13	864	84	20,3	ON	322,43	864	18,4	2,06	2,63
    	322,71	0,8	0	 	 	323,01	864	82,5	18	ON	323,29	832	18,4	2,06	2,64
    	323,58	1,6	0	 	 	323,87	832	84	15,6	ON	324,15	832	18,4	2,06	2,78
    	324,43	1,6	0	 	 	324,72	832	84	18	ON	325,02	864	18,4	2,06	2,64
    	325,31	0,8	0	 	 	325,62	864	82,5	20,7	ON	325,91	864	18,4	2,06	2,66
    	326,22	2,3	0	 	 	326,53	864	84	18,4	ON	326,82	864	18,4	2,06	2,37
    	327,13	2,3	0	 	 	327,41	832	84	15,6	ON	327,7	832	17,3	2,06	2,49
    	327,99	2,3	0	 	 	328,28	800	84	13,3	ON	328,58	832	18,4	2,06	2,69
    	328,87	2,3	0	 	 	329,18	832	84	16	ON	329,46	864	18,4	2,06	2,66
    	329,76	2,3	0	 	 	330,06	864	84	18,8	ON	330,35	864	18,4	2,06	2,67
    	330,64	2,3	0	 	 	330,93	864	84	21,5	ON	331,22	864	18,4	3,09	2,74
    	331,51	2,3	0	 	 	331,81	864	84	22,3	ON	332,1	864	17,3	2,06	2,41
    	332,4	2,3	0	 	 	332,69	832	84	19,5	ON	333	832	17,3	2,06	2,46
    	333,28	3,1	0	 	 	333,58	832	84	16,8	ON	333,88	832	17,3	2,06	2,46
    	334,18	3,1	0	 	 	334,49	832	84	14,1	ON	334,77	832	17,3	2,06	2,6
    	335,08	2,3	0	 	 	335,37	832	84	15,6	ON	335,66	832	18,4	2,06	2,81
    	335,96	2,3	0	 	 	336,23	864	84	18	ON	336,53	864	18,4	2,06	2,81
    	336,83	2,3	0	 	 	337,13	864	84	20,7	ON	337,41	864	18,4	2,06	2,57
    	337,7	3,9	0	 	 	337,98	864	84	19,9	ON	338,29	864	17,3	2,06	2,39
    	338,6	4,7	0	 	 	338,91	832	84	17,2	ON	339,17	832	17,3	2,06	2,54
    	339,47	3,9	0	 	 	339,75	832	84	14,5	ON	340,05	832	17,3	2,06	2,44
    	340,36	4,7	0	 	 	340,65	800	84	12,1	ON	340,93	832	19,2	2,06	3,03
    	341,23	3,9	0	 	 	341,53	864	84	14,8	ON	341,82	864	18,4	2,06	2,88
    	342,11	3,9	0	 	 	342,42	864	84	17,6	ON	342,72	896	18,4	2,06	2,64
    	343,03	3,9	0	 	 	343,32	864	84	20,3	ON	343,62	864	18,4	2,06	2,52
    	343,9	3,9	0	 	 	344,2	832	84	19,1	ON	344,51	832	17,3	2,06	2,32
    	344,81	4,7	0	 	 	345,11	832	84	16,4	ON	345,41	832	17,3	2,06	2,43
    	345,71	4,7	0	 	 	346,01	800	84	13,7	ON	346,32	800	18,4	2,06	2,77
    	346,6	3,9	0	 	 	346,88	832	84	12,1	ON	347,16	864	19,2	2,06	2,68
    	347,44	3,9	0	 	 	347,73	864	84	14,5	ON	348,03	864	18,4	2,06	2,78
    	348,33	3,9	0	 	 	348,63	864	84	17,2	ON	348,93	864	18,4	2,06	2,61
    	349,22	3,9	0	 	 	349,5	864	84	19,9	ON	349,81	864	17,3	2,06	2,36
    	350,08	3,9	0	 	 	350,39	864	84	18	ON	350,68	832	17,3	2,06	2,29
    	350,97	4,7	0	 	 	351,26	832	84	15,2	ON	351,56	832	17,3	2,06	2,22
    	351,83	4,7	0	 	 	352,13	832	84	12,5	ON	352,42	832	18,4	2,06	2,6
    	352,7	3,9	0	 	 	352,98	864	84	12,1	ON	353,28	832	18,4	2,06	2,72
    	353,59	3,9	0	 	 	353,88	864	84	14,8	ON	354,17	864	18,4	2,06	2,8
    	354,47	3,9	0	 	 	354,77	864	84	17,6	ON	355,07	864	18,4	2,06	2,67
    	355,36	3,9	0	 	 	355,64	864	84	20,3	ON	355,92	864	17,3	2,06	2,51
    	356,22	3,9	0	 	 	356,51	864	84	19,1	ON	356,8	864	17,3	2,06	2,44
    	357,09	3,9	0	 	 	357,4	864	84	16,8	ON	357,71	832	17,3	2,06	2,24
    	358	4,7	0	 	 	358,3	832	84	13,7	ON	358,59	832	17,3	2,06	2,72
    	358,88	3,9	0	 	 	359,17	832	84	12,5	ON	359,46	864	18,4	2,06	2,61
    	359,77	3,9	0	 	 	360,07	864	84	15,2	ON	360,37	864	18,4	2,06	2,69
    	360,66	3,9	0	 	 	360,96	864	84	18	ON	361,26	864	18,4	2,06	2,72
    	361,55	3,9	0	 	 	361,85	864	84	20,7	ON	362,14	864	17,3	2,06	2,51
    	362,43	3,9	0	 	 	362,74	864	84	18,8	ON	363,02	832	17,3	2,06	2,4
    	363,31	4,7	0	 	 	363,57	832	84	16	ON	363,88	832	17,3	2,06	2,55
    	364,18	4,7	0	 	 	364,49	832	84	13,3	ON	364,79	832	17,3	2,06	2,69
    	365,07	3,9	0	 	 	365,36	832	84	13,3	ON	365,66	864	18,4	2,06	2,66
    	365,94	3,9	0	 	 	366,24	864	84	16	ON	366,51	864	18,4	2,06	2,75
    	366,81	3,9	0	 	 	367,09	864	84	18,4	ON	367,38	864	18,4	2,06	2,72
    	367,68	3,9	0	 	 	367,98	864	84	19,5	ON	368,28	864	18,4	2,06	2,58
    	368,56	3,9	0	 	 	368,87	864	84	16,8	ON	369,19	832	17,3	2,06	2,37
    	369,49	4,7	0	 	 	369,79	832	84	14,1	ON	370,07	832	17,3	2,06	2,41
    	370,36	4,7	0	 	 	370,67	832	84	11,7	ON	370,98	832	17,3	2,06	2,43
    	371,27	3,9	0	 	 	371,58	832	84	14,5	ON	371,86	832	18,4	2,06	2,72
    	372,15	3,9	0	 	 	372,45	832	84	17,2	ON	372,73	864	17,3	2,06	2,4
    	373,04	3,9	0	 	 	373,36	864	84	19,9	ON	373,66	864	17,3	2,06	2,58
    	373,97	3,9	0	 	 	374,26	832	84	17,2	ON	374,56	864	17,3	2,06	2,46
    	374,85	3,9	0	 	 	375,16	864	84	14,5	ON	375,45	832	17,3	2,06	2,24
    	375,73	4,7	0	 	 	376,03	832	84	16,4	ON	376,33	832	17,3	2,06	2,46
    	376,64	3,9	0	 	 	376,94	832	84	19,1	ON	377,26	864	17,3	2,06	2,3
    	377,56	4,7	0	 	 	377,87	832	84	20,7	ON	378,17	832	17,3	2,06	2,39
    	378,43	4,7	0	 	 	378,73	832	84	18	ON	379,02	832	17,3	2,06	2,37
    	379,32	4,7	0	 	 	379,6	832	84	15,2	ON	379,9	832	17,3	2,06	2,5
    	380,23	4,7	0	 	 	380,52	832	84	14,1	ON	380,81	832	17,3	2,06	2,46
    	381,08	3,9	0	 	 	381,39	864	84	16,4	ON	381,69	864	17,3	2,06	2,61
    	381,98	3,9	0	 	 	382,27	864	84	19,1	ON	382,56	864	17,3	2,06	2,64
    	382,84	3,9	0	 	 	383,16	864	84	21,9	ON	383,44	864	17,3	2,06	2,46
    	383,73	3,9	0	 	 	384,03	864	84	19,1	ON	384,33	864	16,1	2,06	2,34
    	384,61	4,7	0	 	 	384,88	832	84	16,4	ON	385,18	832	16,1	2,06	2,27
    	385,49	4,7	0	 	 	385,77	832	84	13,7	ON	386,05	832	17,3	2,06	2,43
    	386,35	4,7	0	 	 	386,64	832	84	13,3	ON	386,92	832	17,3	2,06	2,46
    	387,22	3,9	0	 	 	387,5	832	84	16	ON	387,8	864	17,3	2,06	2,44
    	388,09	3,9	0	 	 	388,38	864	84	18,8	ON	388,68	864	17,3	2,06	2,54
    	388,97	3,9	0	 	 	389,27	864	84	20,7	ON	389,55	864	17,3	2,06	2,51
    	389,85	4,7	0	 	 	390,15	864	84	18	ON	390,46	832	16,1	2,06	2,3
    	390,75	4,7	0	 	 	391,06	832	84	15,2	ON	391,36	832	16,1	2,06	2,42
    	391,65	4,7	0	 	 	391,96	832	84	12,5	ON	392,25	832	17,3	2,06	2,58
    	392,56	3,9	0	 	 	392,84	864	84	15,2	ON	393,15	864	18,4	2,06	2,55
    	393,43	3,9	0	 	 	393,73	864	84	17,6	ON	394,02	864	18,4	2,06	2,56
    	394,33	3,9	0	 	 	394,63	864	84	20,3	ON	394,92	864	17,3	2,06	2,52
    	395,22	3,9	0	 	 	395,53	832	84	17,6	ON	395,83	864	17,3	2,06	2,06
    	396,12	4,7	0	 	 	396,42	832	84	14,8	ON	396,72	832	16,1	2,06	2,28
    	397	4,7	0	 	 	397,3	832	84	12,1	ON	397,6	800	17,3	2,06	2,71
    	397,88	3,9	0	 	 	398,17	832	84	14,5	ON	398,46	864	18,4	2,06	2,53
    	398,75	3,9	0	 	 	399,05	832	84	17,2	ON	399,34	864	18,4	2,06	2,64
    	399,65	3,9	0	 	 	399,95	864	84	19,9	ON	400,26	864	17,3	2,06	2,6
    	400,56	3,9	0	 	 	400,86	864	84	18,4	ON	401,16	864	17,3	2,06	2,47
    	401,47	4,7	0	 	 	401,75	832	84	15,6	ON	402,05	864	17,3	2,06	2,33
    	402,33	4,7	0	 	 	402,61	832	84	13,3	ON	402,9	832	17,3	2,06	2,5
    	403,2	3,9	0	 	 	403,5	832	84	14,5	ON	403,78	832	17,3	2,06	2,59
    	404,06	3,9	0	 	 	404,35	864	84	17,2	ON	404,63	864	18,4	2,06	2,52
    	404,92	3,9	0	 	 	405,22	864	84	19,9	ON	405,52	864	17,3	2,06	2,54
    	405,81	4,7	0	 	 	406,09	864	84	18,4	ON	406,39	864	16,1	2,06	2,21
    	406,68	4,7	0	 	 	406,98	832	84	15,6	ON	407,27	832	16,1	2,06	2,42
    	407,56	4,7	0	 	 	407,88	832	84	13,7	ON	408,18	864	17,3	2,06	2,52
    	408,47	4,7	0	 	 	408,77	832	84	16,4	ON	409,06	832	17,3	2,06	2,62
    	409,35	3,9	0	 	 	409,63	832	84	19,1	ON	409,92	864	17,3	2,06	2,42
    	410,21	3,9	0	 	 	410,49	864	84	21,5	ON	410,78	864	17,3	2,06	2,44
    	411,07	3,9	0	 	 	411,36	864	84	18,8	ON	411,66	864	17,3	2,06	2,57
    	411,95	4,7	0	 	 	412,26	832	84	16	ON	412,55	832	16,1	2,06	2,37
    	412,84	4,7	0	 	 	413,12	832	84	15,6	ON	413,43	832	17,3	2,06	2,38
    	413,72	4,7	0	 	 	414	832	84	18,4	ON	414,3	832	17,3	2,06	2,48
    	414,6	3,9	0	 	 	414,9	864	84	21,1	ON	415,2	864	17,3	2,06	2,64
    	415,48	4,7	0	 	 	415,77	864	84	19,9	ON	416,08	864	17,3	2,06	2,46
    	416,38	4,7	0	 	 	416,67	832	84	17,2	ON	416,97	832	17,3	2,06	2,59
    	417,27	3,9	0	 	 	417,53	832	84	14,8	ON	417,84	832	17,3	2,06	2,32
    	418,13	4,7	0	 	 	418,42	832	84	17,2	ON	418,72	832	17,3	2,06	2,46
    	419,02	4,7	0	 	 	419,32	864	84	19,9	ON	419,62	864	17,3	2,06	2,38
    	419,91	3,9	0	 	 	420,22	864	84	21,5	ON	420,51	864	17,3	2,06	2,34
    	420,82	4,7	0	 	 	421,12	832	84	18,8	ON	421,42	832	17,3	2,06	2,39
    	421,73	4,7	0	 	 	422,01	832	84	16	ON	422,3	832	17,3	2,06	2,32
    	422,58	4,7	0	 	 	422,88	832	84	13,3	ON	423,18	832	17,3	2,06	2,32
    	423,49	4,7	0	 	 	423,8	832	84	15,6	ON	424,09	864	17,3	2,06	2,32
    	424,37	4,7	0	 	 	424,66	864	84	18	ON	424,96	864	17,3	2,06	2,47
    	425,24	3,9	0	 	 	425,55	864	84	20,7	ON	425,86	864	17,3	2,06	2,42
    	426,18	3,9	0	 	 	426,45	864	84	22,3	ON	426,74	864	16,1	2,06	2,3
    	427,04	4,7	0	 	 	427,32	864	84	19,5	ON	427,6	832	16,1	2,06	2,18
    	427,88	4,7	0	 	 	428,17	800	84	16,8	ON	428,47	800	16,1	2,06	2,46
    	428,77	4,7	0	 	 	429,05	832	84	14,8	ON	429,36	832	17,3	2,06	2,48
    	429,67	4,7	0	 	 	429,98	832	84	17,6	ON	430,27	864	17,3	2,06	2,6
    	430,57	3,9	0	 	 	430,88	864	84	20,7	ON	431,17	864	17,3	2,06	2,61
    	431,46	3,9	0	 	 	431,74	864	84	21,5	ON	432,07	864	17,3	2,06	2,52
    	432,37	4,7	0	 	 	432,66	832	84	18,8	ON	432,98	832	16,1	2,06	2,24
    	433,28	4,7	0	 	 	433,57	832	84	16	ON	433,85	832	16,1	2,06	2,57
    	434,15	4,7	0	 	 	434,45	832	84	13,7	ON	434,75	832	17,3	2,06	2,62
    	435,05	3,9	0	 	 	435,35	864	84	16,8	ON	435,64	864	17,3	2,06	2,55
    	435,93	3,9	0	 	 	436,22	864	84	19,1	ON	436,51	864	17,3	2,06	2,48
    	436,82	3,9	0	 	 	437,11	864	84	21,9	ON	437,4	864	17,3	2,06	2,58
    	437,69	3,9	0	 	 	437,99	864	84	19,5	ON	438,29	832	16,1	2,06	2,32
    	438,59	4,7	0	 	 	438,9	864	84	16,8	ON	439,21	832	16,1	2,06	2,31
    	439,49	4,7	0	 	 	439,78	832	84	14,1	ON	440,08	832	16,1	2,06	2,32
    	440,35	4,7	0	 	 	440,64	832	84	14,1	ON	440,94	832	17,3	2,06	2,69
    	441,23	3,9	0	 	 	441,53	864	84	16,8	ON	441,83	864	17,3	2,06	2,46
    	442,14	3,9	0	 	 	442,43	864	84	19,5	ON	442,73	864	17,3	2,06	2,56
    	443,03	3,9	0	 	 	443,33	864	84	20,7	ON	443,62	864	17,3	2,06	2,43
    	443,93	4,7	0	 	 	444,23	832	84	18	ON	444,51	832	17,3	2,06	2,34
    	444,79	4,7	0	 	 	445,09	832	84	15,6	ON	445,39	832	17,3	2,06	2,33
    	445,68	4,7	0	 	 	445,98	832	84	15,6	ON	446,27	832	17,3	2,06	2,36
    	446,55	4,7	0	 	 	446,86	832	84	18	ON	447,16	864	17,3	2,06	2,54
    	447,46	4,7	0	 	 	447,76	864	84	20,7	ON	448,04	864	17,3	2,06	2,39
    	448,33	4,7	0	 	 	448,64	864	84	21,9	ON	448,94	864	17,3	2,06	2,39
    	449,24	4,7	0	 	 	449,53	864	84	19,1	ON	450,01	832	17,3	2,06	2,41
    	450,26	4,7	0	 	 	450,56	832	84	16	ON	450,86	832	16,1	2,06	2,34
    	451,17	4,7	0	 	 	451,47	832	84	17,6	ON	451,76	832	16,1	2,06	2,46
    	452,05	4,7	0	 	 	452,36	832	84	20,3	ON	452,63	864	17,3	2,06	2,33
    	452,94	4,7	0	 	 	453,25	864	84	22,7	ON	453,54	864	17,3	2,06	2,44
    	453,84	4,7	0	 	 	454,1	864	84	19,9	ON	454,4	832	17,3	2,06	2,44
    	454,71	0	0	 	 	455,06	1248	84	19,5	ON	455,34	1472	16,1	2,06	3,11
    	455,68	0	0	 	 	456,02	1664	84	14,5	ON	456,33	1696	13,7	2,06	3,72
    	456,7	0	0	 	 	457,02	1728	84	12,5	ON	457,39	1792	13,7	2,06	4,01
    	457,73	0	0	 	 	458,09	1888	84	20,3	ON	458,46	1920	13,7	2,06	4,26
    	458,8	0	0	 	 	459,14	2016	84	26,2	ON	459,48	2080	13,7	2,06	4,92
    	459,84	0	0	 	 	460,17	2112	84	16,8	ON	460,53	2112	12,5	2,06	4,43
    	460,86	0	0	 	 	461,19	2112	84	27	ON	461,52	2112	12,5	2,06	4,43
    	461,85	0	0	 	 	462,21	2080	84	19,1	ON	462,57	2048	12,5	2,06	4,16
    	462,93	0	0	 	 	463,29	2048	84	19,9	ON	463,64	2048	12,5	1,03	4,27
    	463,98	0	0	 	 	464,32	1984	84	16,8	ON	464,68	1952	12,5	1,03	4,23
    	465,03	0	0	 	 	465,38	1952	84	20,3	ON	465,72	1952	11,4	1,03	3,84
    	466,08	0	0	 	 	466,46	1856	84	14,1	ON	466,79	1856	12,5	1,03	3,83
    	467,12	0	0	 	 	467,46	1856	84	21,9	ON	467,8	1856	11,4	1,03	3,71
    	468,14	0	0	 	 	468,45	1696	84	0	OFF	468,76	1440	14,9	3,09	4,19
    	469,08	0	0	 	 	469,4	1280	84	0	ON	469,72	1216	14,9	2,06	3,15
    	470,02	3,1	0	 	 	470,31	1120	84	0,4	ON	470,62	1088	17,3	3,09	3,54
    	470,91	3,1	0	 	 	471,2	1120	84	0,8	ON	471,5	1152	17,3	3,09	3,32
    	471,81	3,1	0	 	 	472,1	1120	84	-0,8	ON	472,42	1056	14,9	2,06	2,95
    	472,71	3,9	0	 	 	473	864	84	-3,1	ON	473,28	832	18,4	2,06	3,14
    	473,56	3,9	0	 	 	473,85	864	84	-3,1	ON	474,13	832	16,1	2,06	2,24
    	474,42	4,7	0	 	 	474,71	832	84	-0,4	ON	475	832	17,3	2,06	2,43
    	475,3	4,7	0	 	 	475,59	832	84	2	ON	475,9	832	17,3	2,06	2,56
    	476,19	3,9	0	 	 	476,48	864	84	4,7	ON	476,76	832	17,3	2,06	2,51
    	477,04	3,9	0	 	 	477,34	832	84	7,4	ON	477,62	832	17,3	2,06	2,52
    	477,9	3,9	0	 	 	478,18	864	84	10,2	ON	478,48	864	18,4	2,06	2,58
    	478,79	3,9	0	 	 	479,08	864	84	12,9	ON	479,39	864	17,3	2,06	2,58
    	479,69	3,9	0	 	 	479,98	864	84	15,6	ON	480,29	864	17,3	2,06	2,5
    	480,57	4,7	0	 	 	480,89	864	84	18,4	ON	481,17	832	17,3	2,06	2,47
    	481,48	4,7	0	 	 	481,78	864	84	21,1	ON	482,09	832	16,1	2,06	2,31
    	482,39	4,7	0	 	 	482,67	832	84	18,4	ON	482,96	832	16,1	2,06	2,36
    	483,26	4,7	0	 	 	483,55	832	84	15,6	ON	483,85	832	16,1	2,06	2,3
    	484,14	4,7	0	 	 	484,44	832	84	12,9	ON	484,73	832	17,3	2,06	2,55
    	485,03	3,9	0	 	 	485,34	864	84	15,6	ON	485,82	864	17,3	2,06	2,57
    	486,07	3,9	0	 	 	486,36	864	84	19,1	ON	486,67	864	17,3	2,06	2,58
    	486,97	3,9	0	 	 	487,25	864	84	21,9	ON	487,56	864	16,1	2,06	2,29
    	487,85	4,7	0	 	 	488,14	864	84	20,7	ON	488,45	864	16,1	2,06	2,34
    	488,74	4,7	0	 	 	489,01	832	84	18	ON	489,3	832	16,1	2,06	2,24
    	489,58	4,7	0	 	 	489,88	832	84	15,6	ON	490,2	832	16,1	2,06	2,38
    	490,48	4,7	0	 	 	490,78	832	84	14,8	ON	491,07	832	18,4	2,06	2,75
    	491,38	3,9	0	 	 	491,68	864	84	17,6	ON	491,98	864	18,4	2,06	2,67
    	492,27	3,9	0	 	 	492,56	864	84	20,3	ON	492,86	864	17,3	2,06	2,16
    	493,15	4,7	0	 	 	493,46	864	84	21,9	ON	493,74	864	16,1	2,06	2,29
    	494,05	4,7	0	 	 	494,36	832	84	19,1	ON	494,66	832	16,1	2,06	2,32
    	494,96	4,7	0	 	 	495,25	832	84	16,4	ON	495,55	832	16,1	2,06	2,26
    	495,83	4,7	0	 	 	496,14	832	84	13,7	ON	496,45	832	17,3	2,06	2,59
    	496,73	3,9	0	 	 	497,05	864	84	14,1	ON	497,31	864	17,3	2,06	2,46
    	497,61	3,9	0	 	 	497,92	864	84	16,8	ON	498,22	832	17,3	2,06	2,58
    	498,52	3,9	0	 	 	498,81	864	84	19,5	ON	499,11	864	17,3	2,06	2,44
    	499,41	4,7	0	 	 	499,69	864	84	22,3	ON	499,99	864	17,3	2,06	2,43
    	500,28	4,7	0	 	 	500,58	864	84	23,4	ON	500,86	832	16,1	2,06	2,08
    	501,15	4,7	0	 	 	501,45	832	84	20,7	ON	501,74	832	16,1	2,06	2,09
    	502,04	4,7	0	 	 	502,33	832	84	18	ON	502,78	832	16,1	2,06	2,31
    	503,26	4,7	0	 	 	503,54	832	84	14,5	ON	503,86	832	17,3	2,06	2,79
    	504,15	3,9	0	 	 	504,46	864	84	17,2	ON	504,77	864	17,3	2,06	2,61
    	505,08	3,9	0	 	 	505,39	864	84	19,9	ON	505,7	864	17,3	2,06	2,6
    MAF average 3.59g/s (before started pressing on throttle)
    Friday	21	June	2019	12:45:19:00008-VCID:1E3368789AB7DDBF84-5178	VCDS Version: Release 19,6,0 (x64)	Data version: 20190529 DS308,0
    	0,53	0	0	 	 	0,01	0	72	0	OFF	0,26	0	0	0	0
    	1,32	0	0	 	 	0,79	0	72	0	OFF	1,06	0	0	0	0
    	2,23	0	0	 	 	1,6	256	72	0	OFF	1,9	928	59,2	11,33	5,64
    	3,14	0	0	 	 	2,54	960	72	0	OFF	2,85	928	28,6	3,09	4,5
    	4,02	0	0	 	 	3,43	928	72	0	OFF	3,73	896	28,6	3,09	4,17
    	4,91	0	0	 	 	4,31	896	72	0	OFF	4,61	896	26,3	3,09	3,54
    	5,81	0	0	 	 	5,2	864	72	0	OFF	5,49	864	25,1	3,09	3,38
    	6,71	0	0	 	 	6,12	864	72	0	OFF	6,42	864	25,1	3,09	3,11
    	7,61	0	0	 	 	7,01	864	72	0	OFF	7,33	864	23,9	3,09	2,96
    	8,51	0	0	 	 	7,92	832	72	0	OFF	8,2	832	23,9	3,09	2,77
    	9,39	0	0	 	 	8,79	832	72	0	OFF	9,09	832	23,9	3,09	2,8
    	10,24	0	0	 	 	9,67	832	72	0	OFF	9,94	864	25,1	3,09	2,74
    	11,11	0	0	 	 	10,54	832	72	0	OFF	10,83	832	23,9	3,09	2,86
    	11,98	0	0	 	 	11,39	832	72	0	OFF	11,69	832	25,1	3,09	3,22
    	12,84	0	0	 	 	12,26	832	72	0	OFF	12,56	832	25,1	3,09	3,34
    	13,72	0	0	 	 	13,13	864	72	0	OFF	13,43	832	25,1	3,09	3,26
    	14,61	0	0	 	 	14,02	864	72	0	OFF	14,32	832	25,1	3,09	3,47
    	15,53	0	0	 	 	14,93	864	72	0	OFF	15,22	864	25,1	3,09	3,49
    	16,42	0	0	 	 	15,84	832	72	0	OFF	16,13	832	25,1	3,09	3,58
    	17,3	0	0	 	 	16,72	832	72	0	OFF	17,01	864	25,1	3,09	3,42
    	18,17	0	0	 	 	17,59	864	72	0	OFF	17,88	864	25,1	3,09	3,55
    	19,07	0	0	 	 	18,47	864	72	0	OFF	18,76	864	25,1	3,09	3,51
    	19,94	0	0	 	 	19,36	864	70,5	0	OFF	19,64	864	25,1	3,09	3,51
    	20,81	0	0	 	 	20,22	832	70,5	0	OFF	20,52	864	25,1	3,09	3,61
    	21,7	0	0	 	 	21,1	864	70,5	0	OFF	21,4	864	25,1	3,09	3,54
    	22,61	0	0	 	 	22	864	70,5	0	OFF	22,3	864	25,1	3,09	3,52
    	23,52	0	0	 	 	22,91	864	70,5	0	OFF	23,21	864	25,1	3,09	3,62
    	24,39	0	0	 	 	23,81	832	70,5	0	OFF	24,1	864	25,1	3,09	3,43
    	25,31	0	0	 	 	24,7	864	72	0	OFF	25	864	23,9	3,09	3,4
    	26,21	0	0	 	 	25,61	864	70,5	0	OFF	25,91	832	25,1	3,09	3,4
    	27,09	0	0	 	 	26,49	864	70,5	0	OFF	26,79	864	23,9	3,09	3,42
    	27,97	0	0	 	 	27,38	864	72	0	OFF	27,66	832	23,9	3,09	3,43
    	28,86	0	0	 	 	28,26	832	72	0	OFF	28,58	864	25,1	3,09	3,44
    	29,75	0	0	 	 	29,17	832	72	0	OFF	29,45	864	26,3	3,09	3,63
    	30,67	0	0	 	 	30,06	864	72	0	OFF	30,36	832	26,3	3,09	3,83
    	31,57	0	0	 	 	30,97	832	72	0	OFF	31,26	832	25,1	3,09	3,72
    	32,49	0	0	 	 	31,86	832	72	0	OFF	32,18	832	26,3	3,09	3,66
    	33,39	0	0	 	 	32,8	864	72	0	OFF	33,09	864	26,3	3,09	3,71
    	34,28	0	0	 	 	33,69	864	72	0	OFF	34	864	25,1	3,09	3,69
    	35,19	0	0	 	 	34,58	864	72	0	OFF	34,89	864	25,1	3,09	3,65
    	36,09	0	0	 	 	35,5	864	72	0	OFF	35,79	864	25,1	3,09	3,56
    	37	0	0	 	 	36,4	832	72	0	OFF	36,69	864	25,1	3,09	3,43
    	37,85	0	0	 	 	37,29	864	72	0	OFF	37,58	864	25,1	3,09	3,56
    	38,74	0	0	 	 	38,14	832	72	0	OFF	38,43	864	25,1	3,09	3,56
    	39,62	0	0	 	 	39,03	832	72	0	OFF	39,33	832	23,9	3,09	3,44
    	40,48	0	0	 	 	39,92	864	72	0	OFF	40,2	864	23,9	3,09	3,48
    	41,4	0	0	 	 	40,79	864	72	0	OFF	41,1	832	23,9	3,09	3,48
    	42,3	0	0	 	 	41,71	864	72	0	OFF	42	832	25,1	3,09	3,54
    	43,19	0	0	 	 	42,6	864	72	0	OFF	42,9	864	23,9	3,09	3,51
    	44,1	0	0	 	 	43,5	832	72	-1,2	ON	43,81	864	25,1	3,09	3,38
    	44,99	0	0	 	 	44,38	864	72	1,6	ON	44,69	864	23,9	3,09	3,41
    	45,93	0	0	 	 	45,28	864	72	4,3	ON	45,61	896	23,9	3,09	3,35
    	46,79	0	0	 	 	46,23	896	72	7,4	ON	46,52	864	22,7	3,09	3,16
    	47,7	0	0	 	 	47,09	864	72	10,2	ON	47,4	864	21,6	3,09	2,78
    	48,56	0	0	 	 	47,99	864	72	12,9	ON	48,27	864	20,4	3,09	2,83
    	49,46	0	0	 	 	48,86	864	72	15,2	ON	49,17	864	19,2	2,06	2,76
    	50,37	0	0	 	 	49,77	864	72	18	ON	50,07	864	19,2	2,06	2,74
    	51,24	0	0	 	 	50,66	864	72	20,7	ON	50,95	864	19,2	3,09	2,69
    	52,14	0	0	 	 	51,53	864	73,5	20,3	ON	51,83	864	19,2	2,06	2,75
    	53,04	0	0	 	 	52,42	864	73,5	17,6	ON	52,73	832	19,2	2,06	2,75
    	53,9	0	0	 	 	53,32	832	73,5	14,8	ON	53,61	832	19,2	2,06	2,73
    	54,77	0	0	 	 	54,18	800	73,5	12,1	ON	54,47	832	20,4	2,06	2,96
    	55,65	0	0	 	 	55,06	832	73,5	14,1	ON	55,35	864	21,6	3,09	3,06
    	56,51	0	0	 	 	55,93	864	73,5	16,8	ON	56,22	896	20,4	3,09	3,06
    	57,38	0	0	 	 	56,82	832	73,5	19,5	ON	57,1	864	20,4	3,09	2,88
    	58,26	0	0	 	 	57,67	864	73,5	21,9	ON	57,97	864	18,4	2,06	2,66
    	59,17	0	0	 	 	58,56	864	73,5	21,1	ON	58,85	864	18,4	2,06	2,66
    	60,04	0	0	 	 	59,47	832	73,5	18,4	ON	59,74	832	18,4	2,06	2,63
    	60,92	0	0	 	 	60,33	832	73,5	15,6	ON	60,62	832	19,2	2,06	2,72
    	61,8	0	0	 	 	61,2	832	73,5	15,6	ON	61,5	832	20,4	3,09	3,09
    	62,68	0	0	 	 	62,09	864	73,5	18,4	ON	62,39	864	20,4	3,09	2,93
    	63,53	0	0	 	 	62,98	864	73,5	21,1	ON	63,25	864	20,4	3,09	3,03
    	64,42	0	0	 	 	63,82	864	73,5	23,4	ON	64,12	864	19,2	3,09	2,59
    	65,33	0	0	 	 	64,73	864	73,5	24,6	ON	65,04	864	18,4	2,06	2,74
    	66,23	0	0	 	 	65,64	864	73,5	21,9	ON	65,92	832	18,4	2,06	2,49
    	67,13	0	0	 	 	66,51	832	73,5	19,1	ON	66,82	832	18,4	2,06	2,52
    	68	0	0	 	 	67,41	832	73,5	16,4	ON	67,7	832	19,2	2,06	2,66
    	68,87	0	0	 	 	68,29	832	73,5	17,2	ON	68,58	832	20,4	3,09	3,22
    	69,78	0	0	 	 	69,18	864	75	19,9	ON	69,49	864	20,4	3,09	2,8
    	70,66	0	0	 	 	70,06	864	75	22,7	ON	70,35	864	19,2	3,09	3,03
    	71,56	0	0	 	 	70,96	864	75	25,4	ON	71,26	864	19,2	3,09	2,92
    	72,45	0	0	 	 	71,85	864	75	26,2	ON	72,16	864	18,4	3,09	2,62
    	73,32	0	0	 	 	72,74	864	75	23,4	ON	73,04	864	18,4	2,06	2,58
    	74,17	0	0	 	 	73,6	832	75	20,7	ON	73,88	832	17,3	2,06	2,36
    	75,08	0	0	 	 	74,48	832	75	18	ON	74,79	832	18,4	2,06	2,59
    	75,97	0	0	 	 	75,38	832	75	15,6	ON	75,68	832	19,2	2,06	3,06
    	76,87	0	0	 	 	76,26	864	75	18,4	ON	76,57	864	19,2	3,09	2,88
    	77,78	0	0	 	 	77,18	864	75	21,1	ON	77,48	864	19,2	3,09	2,89
    	78,64	0	0	 	 	78,06	864	75	23,8	ON	78,36	864	19,2	3,09	2,92
    	79,51	0	0	 	 	78,91	864	75	26,6	ON	79,19	864	18,4	3,09	2,51
    	80,38	0	0	 	 	79,81	864	75	26,6	ON	80,09	864	18,4	2,06	2,42
    	81,27	0	0	 	 	80,68	864	75	23,8	ON	80,99	832	17,3	2,06	2,27
    	82,18	0	0	 	 	81,58	832	75	21,1	ON	81,88	832	17,3	2,06	2,43
    	83,07	0	0	 	 	82,48	832	75	18,4	ON	82,77	832	18,4	2,06	2,74
    	83,93	0	0	 	 	83,36	832	75	15,6	ON	83,65	832	19,2	2,06	2,82
    	84,83	0	0	 	 	84,22	864	75	17,6	ON	84,53	864	19,2	2,06	2,67
    	85,72	0	0	 	 	85,13	864	76,5	20,3	ON	85,42	864	19,2	2,06	2,69
    	86,63	0	0	 	 	86,01	864	76,5	20,7	ON	86,32	864	18,4	2,06	2,81
    	87,53	0	0	 	 	86,93	864	76,5	20,7	ON	87,23	864	18,4	2,06	2,43
    	88,42	0	0	 	 	87,83	864	76,5	20,7	ON	88,12	864	18,4	2,06	2,62
    	89,34	0	0	 	 	88,73	832	76,5	18,4	ON	89,04	832	18,4	2,06	2,52
    	90,23	0	0	 	 	89,63	832	76,5	15,6	ON	89,93	832	18,4	2,06	2,64
    	91,12	0	0	 	 	90,54	832	76,5	16	ON	90,83	832	18,4	2,06	2,82
    	91,97	0	0	 	 	91,42	864	76,5	18,8	ON	91,7	864	18,4	2,06	2,62
    	92,86	0	0	 	 	92,27	832	76,5	20,7	ON	92,56	864	19,2	2,06	2,77
    	93,77	0	0	 	 	93,16	864	76,5	20,7	ON	93,46	864	18,4	2,06	2,71
    	94,66	0	0	 	 	94,07	832	76,5	20,7	ON	94,37	832	18,4	2,06	2,77
    	95,54	0	0	 	 	94,95	864	76,5	20,7	ON	95,24	832	18,4	2,06	2,72
    	96,46	0	0	 	 	95,85	832	76,5	20,7	ON	96,17	864	18,4	2,06	2,72
    	97,35	0	0	 	 	96,74	864	76,5	20,7	ON	97,04	864	18,4	2,06	2,79
    	98,21	0	0	 	 	97,64	864	76,5	20,7	ON	97,91	864	18,4	2,06	2,46
    	99,08	0	0	 	 	98,5	832	76,5	20,7	ON	98,81	864	18,4	2,06	2,61
    	99,99	0	0	 	 	99,38	864	76,5	20,7	ON	99,68	864	18,4	2,06	2,64
    	100,88	0	0	 	 	100,3	832	76,5	20,7	ON	100,59	832	18,4	2,06	2,56
    	101,8	0	0	 	 	101,17	864	76,5	20,7	ON	101,49	864	18,4	2,06	2,67
    	102,7	0	0	 	 	102,11	864	76,5	20,7	ON	102,42	864	18,4	2,06	2,67
    	103,6	0	0	 	 	102,99	864	76,5	21,5	ON	103,3	832	18,4	2,06	2,57
    	104,48	0	0	 	 	103,9	864	78	22,3	ON	104,19	864	18,4	2,06	2,62
    	105,35	0	0	 	 	104,78	832	78	23	ON	105,07	864	18,4	2,06	2,57
    	106,21	0	0	 	 	105,64	832	78	21,9	ON	105,93	832	18,4	2,06	2,57
    	107,05	0	0	 	 	106,49	832	78	19,9	ON	106,77	832	18,4	2,06	2,74
    	107,93	0	0	 	 	107,34	864	78	21,1	ON	107,64	832	18,4	2,06	2,59
    	108,82	0	0	 	 	108,23	864	78	24,6	ON	108,53	864	18,4	2,06	2,56
    	109,72	0	0	 	 	109,13	832	78	26,2	ON	109,45	864	18,4	2,06	2,64
    	110,64	0	0	 	 	110,02	864	78	24,2	ON	110,33	864	17,3	2,06	2,49
    	111,51	0	0	 	 	110,93	832	78	21,9	ON	111,22	832	17,3	2,06	2,44
    	112,4	0	0	 	 	111,82	832	78	19,1	ON	112,12	832	18,4	2,06	2,58
    	113,27	0	0	 	 	112,69	832	78	21,9	ON	112,99	832	18,4	2,06	2,66
    	114,15	0	0	 	 	113,57	864	78	24,6	ON	113,86	864	17,3	2,06	2,57
    	115,03	0	0	 	 	114,45	832	78	26,6	ON	114,75	832	17,3	2,06	2,43
    	115,89	0	0	 	 	115,31	832	78	23,8	ON	115,59	864	18,4	2,06	2,55
    	116,76	0	0	 	 	116,19	832	78	21,1	ON	116,49	832	18,4	2,06	2,52
    	117,65	0	0	 	 	117,05	832	78	20,3	ON	117,36	864	18,4	2,06	2,69
    	118,57	0	0	 	 	117,96	864	78	23	ON	118,27	864	18,4	2,06	2,62
    	119,44	0	0	 	 	118,85	864	78	25,8	ON	119,14	864	18,4	3,09	2,59
    	120,34	0	0	 	 	119,75	864	78	24,6	ON	120,04	864	18,4	2,06	2,67
    	121,25	0	0	 	 	120,64	832	78	21,9	ON	120,95	832	17,3	2,06	2,47
    	122,15	0	0	 	 	121,55	832	78	19,1	ON	121,84	832	18,4	2,06	2,68
    	123,05	0	0	 	 	122,46	864	78	19,5	ON	122,77	864	18,4	2,06	2,83
    	123,98	0	0	 	 	123,37	864	78	22,3	ON	123,68	864	19,2	3,09	2,68
    	124,89	0	0	 	 	124,27	864	78	25	ON	124,59	864	18,4	3,09	2,77
    	125,76	0	0	 	 	125,18	864	78	24,6	ON	125,47	864	18,4	2,06	2,54
    	126,65	0	0	 	 	126,06	864	78	21,9	ON	126,34	832	17,3	2,06	2,56
    	127,53	0	0	 	 	126,92	832	78	19,1	ON	127,23	832	17,3	2,06	2,66
    	128,42	0	0	 	 	127,84	832	79,5	18	ON	128,12	832	18,4	2,06	2,53
    	129,31	0	0	 	 	128,69	832	79,5	20,7	ON	129	864	18,4	2,06	2,72
    	130,21	0	0	 	 	129,61	864	79,5	23,4	ON	129,91	864	18,4	3,09	2,62
    	131,1	0	0	 	 	130,49	864	79,5	25,8	ON	130,79	896	18,4	2,06	2,52
    	131,97	0	0	 	 	131,39	864	79,5	23	ON	131,67	832	17,3	2,06	2,26
    	132,84	0	0	 	 	132,26	832	79,5	20,3	ON	132,55	832	17,3	2,06	2,58
    	133,7	0	0	 	 	133,12	832	79,5	18	ON	133,41	832	18,4	2,06	2,64
    	134,59	0	0	 	 	134,01	864	79,5	18,8	ON	134,3	832	18,4	2,06	2,57
    	135,45	0	0	 	 	134,89	864	79,5	21,5	ON	135,18	864	18,4	2,06	2,75
    	136,34	0	0	 	 	135,74	864	79,5	24,2	ON	136,04	864	18,4	2,06	2,61
    	137,24	0	0	 	 	136,63	864	79,5	23	ON	136,92	832	17,3	2,06	2,38
    	138,13	0	0	 	 	137,53	832	79,5	20,3	ON	137,83	832	17,3	2,06	2,32
    	139,01	0	0	 	 	138,42	832	79,5	17,6	ON	138,72	832	18,4	2,06	2,78
    	139,92	0	0	 	 	139,32	864	79,5	18,4	ON	139,63	864	18,4	2,06	2,79
    	140,81	0	0	 	 	140,22	864	79,5	21,1	ON	140,51	864	18,4	2,06	2,78
    	141,71	0	0	 	 	141,11	864	79,5	23,8	ON	141,39	864	18,4	2,06	2,57
    	142,6	0	0	 	 	142	864	79,5	25,8	ON	142,32	864	17,3	2,06	2,4
    	143,48	0	0	 	 	142,91	864	79,5	23	ON	143,2	864	17,3	2,06	2,34
    	144,35	0	0	 	 	143,77	832	79,5	20,3	ON	144,05	832	17,3	2,06	2,36
    	145,21	0	0	 	 	144,65	832	79,5	17,6	ON	144,95	832	18,4	2,06	2,86
    	146,1	0	0	 	 	145,51	864	79,5	18	ON	145,8	832	18,4	2,06	2,68
    	146,99	0	0	 	 	146,4	864	79,5	21,5	ON	146,69	864	18,4	2,06	2,72
    	147,89	0	0	 	 	147,28	864	79,5	24,6	ON	147,59	864	18,4	2,06	2,62
    	148,76	0	0	 	 	148,19	864	79,5	26,6	ON	148,48	864	17,3	2,06	2,44
    	149,68	0	0	 	 	149,08	864	79,5	23,8	ON	149,37	864	17,3	2,06	2,44
    	150,58	0	0	 	 	150	832	81	21,1	ON	150,27	832	17,3	2,06	2,46
    	151,48	0	0	 	 	150,87	832	81	18,8	ON	151,17	832	17,3	2,06	2,46
    	152,37	0	0	 	 	151,77	832	81	21,5	ON	152,07	832	18,4	2,06	2,66
    	153,24	0	0	 	 	152,65	864	81	24,2	ON	152,95	864	18,4	2,06	2,56
    	154,14	0	0	 	 	153,54	864	81	24,6	ON	153,85	864	17,3	2,06	2,55
    	155,03	0	0	 	 	154,45	832	81	21,9	ON	154,74	832	16,1	2,06	2,4
    	155,91	0	0	 	 	155,32	832	81	19,1	ON	155,63	832	17,3	2,06	2,46
    	156,8	0	0	 	 	156,22	832	81	16,4	ON	156,51	832	18,4	2,06	2,72
    	157,68	0	0	 	 	157,11	832	81	14,5	ON	157,4	832	18,4	2,06	2,59
    	158,56	0	0	 	 	157,97	832	81	16,8	ON	158,26	864	18,4	2,06	2,44
    	159,46	0	0	 	 	158,84	864	81	19,5	ON	159,16	896	17,3	2,06	2,39
    	160,35	0	0	 	 	159,74	896	81	18,4	ON	160,05	896	14,9	2,06	2,06
    	161,26	0	0	 	 	160,66	896	81	15,6	ON	160,96	864	13,7	2,06	2,09
    	162,12	0	0	 	 	161,53	864	81	14,1	ON	161,83	832	11,4	1,03	1,97
    	162,99	0	0	 	 	162,41	800	81	12,9	ON	162,7	800	16,1	2,06	2,18
    	163,89	0	0	 	 	163,29	800	81	11,3	ON	163,59	800	17,3	2,06	2,81
    	164,79	0	0	 	 	164,18	800	81	11,3	ON	164,49	864	21,6	3,09	2,94
    	165,68	0	0	 	 	165,08	864	81	14,1	ON	165,38	864	20,4	3,09	3,09
    	166,56	0	0	 	 	165,97	864	81	16	ON	166,25	864	20,4	3,09	3,03
    	167,44	0	0	 	 	166,85	864	81	18,4	ON	167,14	864	19,2	3,09	3,02
    	168,31	0	0	 	 	167,74	864	81	20,3	ON	168,03	864	18,4	2,06	2,61
    	169,18	0	0	 	 	168,61	864	81	22,3	ON	168,89	864	18,4	2,06	2,56
    	170,06	0	0	 	 	169,47	864	81	19,9	ON	169,76	832	17,3	2,06	2,34
    	170,95	0	0	 	 	170,37	832	81	16,8	ON	170,66	832	18,4	2,06	2,53
    	171,84	0	0	 	 	171,25	832	81	14,5	ON	171,53	832	18,4	2,06	2,54
    	172,7	0	0	 	 	172,14	832	81	14,5	ON	172,42	832	19,2	2,06	2,71
    	173,58	0	0	 	 	172,99	832	81	17,2	ON	173,29	832	19,2	2,06	2,67
    	174,47	0	0	 	 	173,87	864	81	19,9	ON	174,16	864	19,2	2,06	2,83
    	175,33	0	0	 	 	174,77	864	81	22,7	ON	175,06	864	18,4	2,06	2,61
    	176,22	0	0	 	 	175,63	864	81	24,6	ON	175,93	864	17,3	2,06	2,31
    	177,1	0	0	 	 	176,52	832	81	21,9	ON	176,82	832	17,3	2,06	2,36
    	177,96	0	0	 	 	177,39	832	81	19,5	ON	177,68	832	17,3	2,06	2,36
    	178,83	0	0	 	 	178,25	800	81	16,8	ON	178,53	800	19,2	2,06	3,23
    	179,73	0	0	 	 	179,11	864	81	19,1	ON	179,42	896	19,2	3,09	2,89
    	180,62	0	0	 	 	180,04	864	82,5	21,9	ON	180,33	864	18,4	2,06	2,88
    	181,52	0	0	 	 	180,92	864	81	24,6	ON	181,22	864	17,3	2,06	2,43
    	182,4	0	0	 	 	181,82	864	82,5	22,3	ON	182,11	864	21,6	3,09	5,56
    	183,28	0	0	 	 	182,72	896	82,5	19,5	ON	183	832	26,3	3,09	4,23
    	184,17	0	0	 	 	183,56	864	82,5	21,5	ON	183,87	864	27,5	4,12	3,91
    	185,02	0	0	 	 	184,45	832	82,5	24,2	ON	184,73	832	25,1	3,09	3,49
    	185,89	0	0	 	 	185,31	800	82,5	24,6	ON	185,6	800	25,1	3,09	3,64
    	186,78	0	0	 	 	186,18	832	82,5	21,9	ON	186,48	832	26,3	4,12	3,82
    	187,69	0	0	 	 	187,09	832	82,5	19,1	ON	187,4	832	27,5	4,12	3,83
    	188,59	0	0	 	 	187,99	832	82,5	16,4	ON	188,29	832	27,5	4,12	3,89
    	189,49	0	0	 	 	188,9	832	82,5	18,4	ON	189,21	832	28,6	4,12	3,91
    	190,34	0	0	 	 	189,76	832	82,5	21,1	ON	190,04	832	28,6	4,12	4,13
    	191,19	0	0	 	 	190,63	864	82,5	22,3	ON	190,91	832	28,6	4,12	3,99
    	192,08	0	0	 	 	191,48	832	82,5	19,5	ON	191,77	864	27,5	4,12	4,02
    	192,98	0	0	 	 	192,38	832	82,5	16,8	ON	192,67	832	28,6	4,12	3,88
    	193,83	0	0	 	 	193,26	832	82,5	16,4	ON	193,54	864	28,6	4,12	4
    	194,72	0	0	 	 	194,11	864	82,5	19,1	ON	194,41	864	27,5	4,12	3,97
    	195,63	0	0	 	 	195,01	864	82,5	21,1	ON	195,32	832	27,5	4,12	4,09
    	196,52	0	0	 	 	195,92	864	82,5	18	ON	196,22	864	28,6	4,12	3,99
    	197,39	0	0	 	 	196,82	832	82,5	15,2	ON	197,09	832	28,6	4,12	4,01
    	198,24	0	0	 	 	197,68	832	82,5	17,2	ON	197,96	832	28,6	4,12	3,98
    	199,1	0	0	 	 	198,53	864	82,5	19,9	ON	198,82	832	28,6	4,12	3,96
    	199,99	0	0	 	 	199,4	832	82,5	21,9	ON	199,69	864	28,6	4,12	3,92
    	200,88	0	0	 	 	200,29	864	82,5	19,1	ON	200,58	864	27,5	4,12	3,94
    	201,77	0	0	 	 	201,18	832	82,5	16,4	ON	201,46	832	28,6	4,12	4,03
    	202,63	0	0	 	 	202,06	832	82,5	16,4	ON	202,34	832	28,6	4,12	4,08
    	203,52	0	0	 	 	202,93	800	82,5	19,1	ON	203,23	896	35,3	5,15	4,28
    	204,44	0	0	 	 	203,84	896	82,5	21,9	ON	204,15	896	31	4,12	4,45
    	205,37	0	0	 	 	204,75	864	82,5	19,5	ON	205,06	864	31	4,12	4,41
    	206,29	0	0	 	 	205,66	864	82,5	16,8	ON	205,99	864	31	4,12	4,08
    	207,17	0	0	 	 	206,59	832	82,5	14,1	ON	206,87	832	31	4,12	4,25
    	208,04	0	0	 	 	207,46	832	82,5	15,2	ON	207,73	864	31	4,12	4,34
    	208,93	0	0	 	 	208,34	832	82,5	18	ON	208,64	832	31	4,12	4,31
    	209,84	0	0	 	 	209,23	832	82,5	20,7	ON	209,53	864	31	4,12	4,34
    	210,74	0	0	 	 	210,14	864	82,5	18,4	ON	210,43	864	31	4,12	4,32
    	211,62	0	0	 	 	211,03	832	82,5	15,6	ON	211,32	832	31	4,12	4,39
    	212,51	0	0	 	 	211,93	832	82,5	17,2	ON	212,21	832	31	4,12	4,12
    	213,39	0	0	 	 	212,81	832	82,5	19,9	ON	213,09	832	31	4,12	4,22
    	214,3	0	0	 	 	213,69	864	82,5	21,9	ON	214	864	29,8	4,12	4,19
    	215,18	0	0	 	 	214,6	832	82,5	18,8	ON	214,89	864	29,8	4,12	4,22
    	216,08	0	0	 	 	215,48	832	82,5	16	ON	215,78	832	29,8	4,12	4,27
    	216,96	0	0	 	 	216,37	832	82,5	15,6	ON	216,66	832	29,8	4,12	4,23
    	217,81	0	0	 	 	217,24	832	82,5	18,4	ON	217,51	864	31	4,12	4,24
    	218,71	0	0	 	 	218,12	832	82,5	20,7	ON	218,41	864	31	4,12	4,25
    	219,61	0	0	 	 	219	864	82,5	18,8	ON	219,31	864	29,8	4,12	4,19
    	220,53	0	0	 	 	219,92	864	82,5	15,6	ON	220,21	864	29,8	4,12	4,23
    	221,43	0	0	 	 	220,82	832	82,5	16,8	ON	221,12	832	29,8	4,12	4,13
    	222,3	0	0	 	 	221,74	832	82,5	19,5	ON	222,03	832	29,8	4,12	4,22
    	223,21	0	0	 	 	222,62	864	82,5	19,9	ON	222,91	832	29,8	4,12	4,26
    	224,1	0	0	 	 	223,52	832	82,5	17,2	ON	223,81	832	29,8	4,12	4,05
    	224,98	0	0	 	 	224,41	832	82,5	14,5	ON	224,7	832	31	4,12	4,23
    	225,85	0	0	 	 	225,26	864	82,5	17,2	ON	225,56	832	31	4,12	4,28
    	226,76	0	0	 	 	226,14	864	82,5	19,9	ON	226,45	864	31	4,12	4,32
    	227,65	0	0	 	 	227,06	832	84	18,8	ON	227,36	832	31	4,12	4,28
    	228,53	0	0	 	 	227,95	864	84	16	ON	228,24	832	31	4,12	4,34
    	229,4	0	0	 	 	228,83	832	84	15,6	ON	229,11	832	31	4,12	4,17
    	230,3	0	0	 	 	229,7	832	84	18,4	ON	230	864	31	4,12	4,19
    	231,23	0	0	 	 	230,61	864	84	20,7	ON	230,92	864	29,8	4,12	4,21
    	232,11	0	0	 	 	231,53	832	84	18	ON	231,81	832	29,8	4,12	4,17
    	233	0	0	 	 	232,4	832	84	15,2	ON	232,7	832	29,8	4,12	4,12
    	233,85	0	0	 	 	233,28	832	84	16,8	ON	233,55	832	29,8	4,12	4,36
    	234,77	0	0	 	 	234,15	864	84	19,5	ON	234,46	864	29,8	4,12	4,2
    	235,62	0	0	 	 	235,06	832	84	19,5	ON	235,34	832	29,8	4,12	4,22
    	236,46	0	0	 	 	235,9	832	84	16,8	ON	236,18	832	29,8	4,12	4,13
    	237,37	0	0	 	 	236,76	832	84	15,2	ON	237,06	832	29,8	4,12	4,28
    	238,27	0	0	 	 	237,67	832	84	18	ON	237,97	864	31	4,12	4,22
    	239,12	0	0	 	 	238,55	864	84	20,7	ON	238,83	864	29,8	4,12	4,28
    	240	0	0	 	 	239,42	832	84	18,8	ON	239,71	832	29,8	4,12	4,23
    	240,86	0	0	 	 	240,29	832	84	16	ON	240,58	832	29,8	4,12	4,14
    	241,72	0	0	 	 	241,14	832	84	18	ON	241,42	864	31	4,12	4,31
    	242,59	0	0	 	 	242	832	84	20,3	ON	242,29	832	29,8	4,12	4,09
    	243,48	0	0	 	 	242,88	864	84	18,4	ON	243,18	832	29,8	4,12	4,17
    	244,34	0	0	 	 	243,78	832	84	15,6	ON	244,06	832	31	4,12	4,24
    	245,21	0	0	 	 	244,62	832	84	17,2	ON	244,92	864	31	4,12	4,2
    	246,08	0	0	 	 	245,5	864	84	19,9	ON	245,79	864	29,8	4,12	4,14
    	246,96	0	0	 	 	246,38	864	84	18,4	ON	246,66	864	29,8	4,12	4,25
    	247,85	0	0	 	 	247,27	832	84	16	ON	247,57	832	29,8	4,12	4,2
    	248,76	0	0	 	 	248,15	832	84	16,4	ON	248,45	832	31	4,12	4,27
    	249,65	0	0	 	 	249,07	832	84	19,1	ON	249,35	864	31	4,12	4,21
    	250,56	0	0	 	 	249,96	864	84	20,7	ON	250,26	864	29,8	4,12	4,26
    	251,41	0	0	 	 	250,84	864	84	18	ON	251,12	832	29,8	4,12	4,28
    	252,3	0	0	 	 	251,71	864	84	15,2	ON	252	864	29,8	4,12	4,13
    	253,16	0	0	 	 	252,59	832	84	16,4	ON	252,87	832	31	4,12	4,24
    	254,07	0	0	 	 	253,46	832	84	18,8	ON	253,78	832	29,8	4,12	4,25
    	254,96	0	0	 	 	254,37	832	84	20,3	ON	254,67	832	29,8	4,12	4,26
    	255,87	0	0	 	 	255,27	864	84	17,6	ON	255,57	832	29,8	4,12	4,24
    	256,77	0	0	 	 	256,18	832	84	14,8	ON	256,46	832	31	4,12	4,24
    	257,65	0	0	 	 	257,07	864	84	17,6	ON	257,36	864	29,8	4,12	4,34
    	258,52	0	0	 	 	257,95	864	84	20,3	ON	258,24	832	29,8	4,12	4,31
    	259,37	0	0	 	 	258,8	832	84	18,4	ON	259,1	832	29,8	4,12	4,14
    	260,26	0	0	 	 	259,68	832	84	15,6	ON	259,98	832	31	4,12	4,17
    	261,16	0	0	 	 	260,58	832	84	16,4	ON	260,87	832	31	4,12	4,28
    	262,07	0	0	 	 	261,46	864	84	19,1	ON	261,77	864	29,8	4,12	4,27
    	262,97	0	0	 	 	262,37	864	84	19,5	ON	262,67	864	29,8	4,12	4,22
    	263,84	0	0	 	 	263,28	864	84	16,8	ON	263,56	832	29,8	4,12	4,28
    	264,72	0	0	 	 	264,12	832	84	16	ON	264,42	832	31	4,12	4,18
    	265,6	0	0	 	 	265,01	864	84	18,8	ON	265,31	864	31	4,12	4,14
    	266,51	0	0	 	 	265,91	864	84	21,1	ON	266,2	864	29,8	4,12	4,14
    	267,39	0	0	 	 	266,8	864	84	18,4	ON	267,1	864	29,8	4,12	4,03
    	268,24	0	0	 	 	267,68	832	84	15,6	ON	267,96	832	29,8	4,12	4,2
    	269,09	0	0	 	 	268,52	832	84	16	ON	268,79	832	29,8	4,12	4,14
    	270	0	0	 	 	269,4	832	84	18,8	ON	269,7	832	29,8	4,12	4,07
    	270,87	0	0	 	 	270,29	832	84	20,7	ON	270,58	864	29,8	4,12	4,14
    	271,72	0	0	 	 	271,16	832	84	18	ON	271,45	832	29,8	4,12	4,18
    	272,58	0	0	 	 	272	832	84	15,6	ON	272,28	832	29,8	4,12	4,19
    	273,47	0	0	 	 	272,88	832	84	17,6	ON	273,17	864	29,8	4,12	4,16
    	274,35	0	0	 	 	273,76	832	84	20,3	ON	274,04	864	29,8	4,12	4,22
    	275,24	0	0	 	 	274,64	864	84	19,5	ON	274,95	832	29,8	4,12	4,29
    	276,12	0	0	 	 	275,54	832	84	16,8	ON	275,84	832	31	4,12	4,28
    	277,02	0	0	 	 	276,42	832	84	17,2	ON	276,72	832	31	4,12	4,26
    	277,92	0	0	 	 	277,32	864	84	19,9	ON	277,62	864	31	4,12	4,22
    	278,81	0	0	 	 	278,22	864	84	18	ON	278,52	864	31	4,12	4,25
    	279,71	0	0	 	 	279,12	864	84	15,2	ON	279,42	864	31	4,12	4,26
    	280,58	0	0	 	 	280,01	832	84	17,2	ON	280,3	832	31	4,12	4,17
    	281,46	0	0	 	 	280,86	864	84	19,9	ON	281,15	864	29,8	4,12	4,28
    	282,36	0	0	 	 	281,77	864	84	21,5	ON	282,08	864	29,8	4,12	4,11
    	283,25	0	0	 	 	282,66	832	84	18,8	ON	282,96	832	29,8	4,12	4,38
    	284,11	0	0	 	 	283,53	832	84	16	ON	283,81	832	29,8	4,12	4,28
    	284,98	0	0	 	 	284,4	832	84	17,6	ON	284,7	832	31	4,12	4,25
    	285,87	0	0	 	 	285,27	864	84	20,3	ON	285,57	832	29,8	4,12	4,22
    	286,75	0	0	 	 	286,16	832	84	19,9	ON	286,46	864	29,8	4,12	4,2
    	287,66	0	0	 	 	287,05	864	84	17,2	ON	287,36	832	29,8	4,12	4,29
    	288,55	0	0	 	 	287,96	832	84	15,6	ON	288,26	832	29,8	4,12	4,29
    	289,44	0	0	 	 	288,86	864	84	18,4	ON	289,14	864	31	4,12	4,31
    	290,38	0	0	 	 	289,74	864	84	21,1	ON	290,07	864	29,8	4,12	4,29
    	291,28	0	0	 	 	290,67	864	85,5	18,8	ON	290,96	864	29,8	4,12	4,2
    	292,19	0	0	 	 	291,6	832	85,5	16,4	ON	291,89	832	29,8	4,12	4,21
    	293,1	0	0	 	 	292,49	832	85,5	18,4	ON	292,8	864	29,8	4,12	4,11
    	293,96	0	0	 	 	293,39	832	85,5	21,5	ON	293,67	832	29,8	4,12	4,19
    	294,86	0	0	 	 	294,27	864	85,5	19,9	ON	294,57	864	29,8	4,12	4,18
    	295,76	0	0	 	 	295,18	832	85,5	17,6	ON	295,47	864	29,8	4,12	4,14
    	296,62	0	0	 	 	296,04	832	85,5	18	ON	296,32	832	29,8	4,12	4,13
    	297,5	0	0	 	 	296,9	864	85,5	21,1	ON	297,2	864	29,8	4,12	4,13
    	298,38	0	0	 	 	297,82	832	85,5	20,3	ON	298,1	832	29,8	4,12	4,17
    	299,25	0	0	 	 	298,66	832	85,5	18	ON	298,95	832	29,8	4,12	4,22
    	300,14	0	0	 	 	299,56	832	85,5	17,6	ON	299,86	832	29,8	4,12	4,11
    	301	0	0	 	 	300,42	832	85,5	20,3	ON	300,72	864	29,8	4,12	4,11
    	301,88	0	0	 	 	301,27	832	85,5	21,5	ON	301,57	864	29,8	4,12	3,99
    	302,81	0	0	 	 	302,19	832	85,5	18,8	ON	302,51	832	29,8	4,12	4,12
    	303,67	0	0	 	 	303,09	832	85,5	16,4	ON	303,37	832	29,8	4,12	4,17
    	304,61	0	0	 	 	303,97	864	85,5	19,1	ON	304,28	832	29,8	4,12	4,25
    	305,53	1,6	0	 	 	304,92	864	85,5	21,9	ON	305,23	864	29,8	4,12	4,22
    	306,4	1,6	0	 	 	305,83	832	85,5	18,8	ON	306,12	864	29,8	4,12	4,22
    	307,28	1,6	0	 	 	306,68	832	85,5	16,4	ON	306,99	832	31	4,12	4,2
    	308,17	1,6	0	 	 	307,57	832	85,5	16,4	ON	307,86	832	31	4,12	4,19
    	309,07	1,6	0	 	 	308,48	864	85,5	18,8	ON	308,77	864	29,8	4,12	4,17
    	310	1,6	0	 	 	309,39	864	85,5	21,1	ON	309,69	864	29,8	4,12	4,2
    	310,86	1,6	0	 	 	310,3	832	85,5	18,4	ON	310,58	832	29,8	4,12	4,2
    	311,73	1,6	0	 	 	311,14	832	85,5	18,4	ON	311,43	832	29,8	4,12	4,28
    	312,61	1,6	0	 	 	312,02	832	85,5	21,1	ON	312,32	864	29,8	4,12	4,14
    	313,48	1,6	0	 	 	312,91	832	85,5	20,3	ON	313,2	832	29,8	4,12	4,11
    	314,36	1,6	0	 	 	313,78	832	85,5	17,6	ON	314,06	832	29,8	4,12	4,25
    	315,23	1,6	0	 	 	314,66	832	85,5	14,8	ON	314,95	832	29,8	4,12	4,19
    	316,11	1,6	0	 	 	315,52	832	85,5	17,6	ON	315,81	864	29,8	4,12	4,16
    	317	2,3	0	 	 	316,39	864	85,5	20,3	ON	316,69	864	29,8	4,12	4,08
    	317,89	2,3	0	 	 	317,3	832	85,5	18,4	ON	317,59	832	29,8	4,12	4,16
    	318,79	2,3	0	 	 	318,19	864	85,5	15,6	ON	318,48	832	29,8	4,12	4,21
    	319,67	2,3	0	 	 	319,08	832	85,5	16,8	ON	319,37	832	29,8	4,12	4,14
    	320,56	2,3	0	 	 	319,96	864	85,5	19,5	ON	320,26	864	29,8	4,12	4,08
    	321,44	2,3	0	 	 	320,85	864	85,5	18,4	ON	321,15	864	29,8	4,12	4,22
    	322,27	2,3	0	 	 	321,72	832	85,5	15,6	ON	322	832	29,8	4,12	4,03
    	323,17	2,3	0	 	 	322,58	832	85,5	16,8	ON	322,88	832	29,8	4,12	4,21
    	324,03	3,9	0	 	 	323,45	832	85,5	19,5	ON	323,73	832	29,8	4,12	4,24
    	324,9	3,9	0	 	 	324,33	864	85,5	18,8	ON	324,62	832	29,8	4,12	4,14
    	325,75	3,9	0	 	 	325,18	832	85,5	16	ON	325,46	832	29,8	4,12	4,16
    	326,67	3,9	0	 	 	326,05	832	85,5	13,7	ON	326,36	832	29,8	4,12	4,17
    	327,54	3,9	0	 	 	326,97	832	85,5	16,4	ON	327,26	832	29,8	4,12	4,12
    	328,41	3,9	0	 	 	327,85	832	85,5	18,4	ON	328,13	864	29,8	4,12	4,11
    	329,32	3,9	0	 	 	328,7	832	85,5	15,6	ON	329,01	864	29,8	4,12	4,13
    	330,19	3,9	0	 	 	329,62	832	85,5	13,3	ON	329,91	832	29,8	4,12	4,22
    	331,09	3,9	0	 	 	330,48	832	85,5	16	ON	330,79	832	29,8	4,12	4,27
    	331,97	5,5	0	 	 	331,39	832	85,5	18,8	ON	331,68	832	29,8	4,12	4,13
    	332,87	5,5	0	 	 	332,28	864	85,5	17,2	ON	332,58	832	29,8	4,12	4,14
    	333,79	5,5	0	 	 	333,18	832	85,5	14,5	ON	333,48	864	29,8	4,12	4,14
    	334,69	5,5	0	 	 	334,08	832	85,5	12,1	ON	334,38	832	29,8	4,12	4,27
    	335,55	5,5	0	 	 	334,99	832	85,5	14,8	ON	335,27	832	29,8	4,12	4,23
    	336,45	5,5	0	 	 	335,84	864	85,5	17,6	ON	336,14	864	29,8	4,12	4,2
    	337,35	5,5	0	 	 	336,75	864	85,5	17,6	ON	337,05	864	29,8	4,12	4,18
    	338,2	5,5	0	 	 	337,63	832	85,5	14,8	ON	337,91	832	29,8	4,12	4,12
    	339,08	5,5	0	 	 	338,51	832	85,5	13,3	ON	338,8	832	31	4,12	4,22
    	339,97	7	0	 	 	339,39	864	85,5	16	ON	339,69	864	29,8	4,12	4,14
    	340,87	7	0	 	 	340,27	864	85,5	14,8	ON	340,57	864	29,8	4,12	4,14
    	341,75	7	0	 	 	341,17	864	85,5	12,1	ON	341,46	832	29,8	4,12	4,29
    	342,63	7	0	 	 	342,03	864	85,5	11,7	ON	342,33	864	29,8	4,12	4,18
    	343,49	7	0	 	 	342,92	832	85,5	14,5	ON	343,2	864	29,8	4,12	4,12
    	344,37	7	0	 	 	343,79	864	85,5	17,2	ON	344,09	864	29,8	4,12	4,17
    	345,24	7	0	 	 	344,66	864	85,5	14,5	ON	344,96	864	29,8	4,12	4,28
    	346,12	7	0	 	 	345,52	832	85,5	11,7	ON	345,82	832	29,8	4,12	4,21
    	347	7	0	 	 	346,41	832	85,5	14,5	ON	346,71	832	29,8	4,12	4,03
    	347,9	7	0	 	 	347,3	832	85,5	17,2	ON	347,6	864	29,8	4,12	4,11
    	348,81	7	0	 	 	348,21	864	85,5	14,8	ON	348,51	864	29,8	4,12	4,13
    	349,71	7	0	 	 	349,12	832	85,5	12,1	ON	349,42	832	29,8	4,12	4,22
    	350,61	7	0	 	 	350,01	864	85,5	13,3	ON	350,31	864	29,8	4,12	4,17
    	351,48	7	0	 	 	350,89	832	85,5	16	ON	351,19	864	29,8	4,12	4,11
    	352,37	7	0	 	 	351,77	864	85,5	16,8	ON	352,08	832	28,6	4,12	4,07
    	353,27	7	0	 	 	352,66	832	85,5	14,1	ON	352,96	832	29,8	4,12	4,14
    	354,17	7	0	 	 	353,57	832	85,5	11,3	ON	353,88	832	29,8	4,12	4,17
    	355,06	6,3	0	 	 	354,48	832	85,5	12,5	ON	354,77	832	29,8	4,12	4,14
    	355,95	7	0	 	 	355,37	832	85,5	15,2	ON	355,65	832	29,8	4,12	4,25
    	356,86	7	0	 	 	356,26	864	85,5	14,5	ON	356,55	864	29,8	4,12	4,21
    	357,77	7	0	 	 	357,17	832	85,5	11,7	ON	357,48	832	29,8	4,12	4,22
    	358,64	7	0	 	 	358,06	864	85,5	12,9	ON	358,36	864	29,8	4,12	4,17
    	359,57	7	0	 	 	358,95	864	85,5	15,6	ON	359,26	864	29,8	4,12	4,25
    	360,45	7	0	 	 	359,87	864	85,5	15,6	ON	360,15	864	29,8	4,12	4,16
    	361,36	7	0	 	 	360,74	864	85,5	13,3	ON	361,07	832	29,8	4,12	4,17
    	362,27	7	0	 	 	361,65	832	85,5	12,5	ON	361,97	832	29,8	4,12	4,23
    	363,12	7	0	 	 	362,56	832	85,5	15,2	ON	362,84	832	29,8	4,12	4,12
    	364,01	7	0	 	 	363,42	864	85,5	13,7	ON	363,71	864	29,8	4,12	4,11
    	364,89	7	0	 	 	364,29	864	85,5	10,9	ON	364,58	832	29,8	4,12	4,03
    	365,79	7	0	 	 	365,19	832	85,5	8,2	ON	365,5	832	29,8	4,12	4
    	366,63	7	0	 	 	366,07	832	85,5	6,3	ON	366,35	832	29,8	4,12	4,08
    	367,51	7	0	 	 	366,91	832	85,5	8,6	ON	367,2	832	29,8	4,12	4,02
    	368,41	7	0	 	 	367,81	864	85,5	11,7	ON	368,11	864	28,6	4,12	4,12
    	369,31	7	0	 	 	368,69	832	85,5	12,5	ON	369,01	864	29,8	4,12	3,96
    	370,19	7	0	 	 	369,59	832	85,5	9,8	ON	369,9	832	29,8	4,12	4,08
    	371,08	7	0	 	 	370,5	832	85,5	7,8	ON	370,78	832	29,8	4,12	4,08
    	372	7	0	 	 	371,38	864	85,5	10,2	ON	371,69	864	29,8	4,12	4,03
    	372,88	7	0	 	 	372,28	832	85,5	13,3	ON	372,59	832	29,8	4,12	4,11
    	373,75	7	0	 	 	373,17	832	85,5	10,9	ON	373,46	832	29,8	4,12	4,13
    	374,65	7	0	 	 	374,05	832	85,5	9,8	ON	374,36	832	29,8	4,12	4,08
    	375,51	7	0	 	 	374,93	864	85,5	12,5	ON	375,23	864	29,8	4,12	4,17
    	376,38	7	0	 	 	375,8	864	85,5	14,5	ON	376,1	864	28,6	4,12	4,01
    	377,29	7	0	 	 	376,67	832	85,5	12,1	ON	376,97	864	29,8	4,12	4,06
    	378,2	7	0	 	 	377,6	832	85,5	9	ON	377,89	832	29,8	4,12	4,08
    	379,1	7	0	 	 	378,51	864	85,5	12,1	ON	378,8	832	29,8	4,12	4,03
    	380	7	0	 	 	379,4	864	85,5	14,8	ON	379,69	864	28,6	4,12	4,03
    	380,87	7	0	 	 	380,3	864	85,5	13,3	ON	380,59	832	28,6	4,12	3,99
    	381,77	7	0	 	 	381,18	832	85,5	10,5	ON	381,47	832	29,8	4,12	4,11
    	382,63	7	0	 	 	382,05	832	85,5	10,2	ON	382,33	832	29,8	4,12	4,17
    	383,52	7	0	 	 	382,93	832	85,5	12,9	ON	383,22	864	29,8	4,12	4,11
    	384,43	7	0	 	 	383,82	864	85,5	15,6	ON	384,12	864	28,6	4,12	4,07
    	385,34	7	0	 	 	384,75	832	85,5	13,7	ON	385,04	864	28,6	4,12	3,99
    	386,18	7	0	 	 	385,61	864	85,5	10,9	ON	385,9	832	28,6	4,12	4
    	387,05	7	0	 	 	386,47	832	85,5	10,2	ON	386,76	832	29,8	4,12	4,13
    	387,92	7	0	 	 	387,35	832	85,5	12,9	ON	387,63	864	29,8	4,12	4,11
    	388,83	7	0	 	 	388,22	864	85,5	15,6	ON	388,53	864	28,6	4,12	4,14
    	389,68	7	0	 	 	389,11	864	85,5	14,1	ON	389,37	832	28,6	4,12	4
    	390,58	7	0	 	 	389,98	832	85,5	11,3	ON	390,3	832	28,6	4,12	3,99
    	391,41	7	0	 	 	390,85	832	85,5	11,7	ON	391,14	832	29,8	4,12	4,11
    	392,31	7	0	 	 	391,72	864	85,5	14,1	ON	392,02	864	28,6	4,12	4,05
    	393,2	7	0	 	 	392,61	864	85,5	14,8	ON	392,91	832	28,6	4,12	4,08
    	394,11	7	0	 	 	393,49	864	85,5	12,1	ON	393,8	832	28,6	4,12	4,05
    	394,98	7	0	 	 	394,41	832	85,5	10,2	ON	394,71	832	29,8	4,12	4,03
    	395,87	7	0	 	 	395,28	832	85,5	12,9	ON	395,58	864	28,6	4,12	3,98
    	396,74	7	0	 	 	396,16	864	85,5	15,6	ON	396,46	864	28,6	4,12	4,03
    	397,65	7	0	 	 	397,05	864	85,5	14,8	ON	397,36	832	28,6	4,12	4,08
    	398,55	7	0	 	 	397,95	832	85,5	12,1	ON	398,24	832	28,6	4,12	4,12
    	399,45	7	0	 	 	398,84	832	85,5	10,5	ON	399,16	832	29,8	4,12	4,03
    	400,34	7	0	 	 	399,76	832	85,5	13,3	ON	400,05	832	28,6	4,12	4,05
    	401,25	7	0	 	 	400,63	864	85,5	15,6	ON	400,94	864	28,6	4,12	4,05
    	402,13	7	0	 	 	401,53	864	85,5	12,9	ON	401,83	864	28,6	4,12	4,13
    	403,02	7	0	 	 	402,42	832	85,5	10,2	ON	402,73	832	28,6	4,12	4,08
    	403,91	7	0	 	 	403,31	832	85,5	12,5	ON	403,59	832	28,6	4,12	3,97
    	404,81	7	0	 	 	404,21	832	85,5	14,8	ON	404,51	864	28,6	4,12	3,99
    	405,67	7	0	 	 	405,11	864	85,5	14,8	ON	405,4	832	28,6	4,12	4,03
    	406,52	7	0	 	 	405,96	832	85,5	12,5	ON	406,21	832	28,6	4,12	3,98
    	407,42	7	0	 	 	406,82	832	85,5	10,5	ON	407,13	832	28,6	4,12	4,21
    	408,3	7	0	 	 	407,71	832	85,5	13,3	ON	408,01	832	28,6	4,12	4
    	409,17	7	0	 	 	408,58	864	85,5	16	ON	408,87	864	28,6	4,12	4,01
    	410,02	7	0	 	 	409,46	864	85,5	13,7	ON	409,73	832	28,6	4,12	4,11
    	410,88	7	0	 	 	410,31	832	85,5	11,3	ON	410,6	832	28,6	4,12	3,99
    	411,76	7	0	 	 	411,16	832	85,5	11,3	ON	411,45	832	29,8	4,12	3,94
    	412,65	7	0	 	 	412,06	832	85,5	14,1	ON	412,35	832	28,6	4,12	3,99
    	413,57	7	0	 	 	412,96	864	85,5	16	ON	413,27	832	28,6	4,12	4,02
    	414,45	7	0	 	 	413,85	832	85,5	13,3	ON	414,15	832	28,6	4,12	4
    	415,33	7	0	 	 	414,73	832	85,5	10,5	ON	415,03	832	29,8	4,12	4,11
    	416,23	7	0	 	 	415,62	832	85,5	12,9	ON	415,92	832	28,6	4,12	4,02
    	417,13	7	0	 	 	416,52	832	85,5	15,6	ON	416,82	864	28,6	4,12	3,97
    	418,02	7	0	 	 	417,44	864	85,5	15,2	ON	417,73	832	28,6	4,12	4,04
    	508,75	0	0	 	 	508,09	2240	85,5	18,4	ON	508,42	2240	40	6,18	14,25
    	509,77	0	0	 	 	509,09	2240	85,5	25	ON	509,43	2240	40	6,18	14,16
    	510,78	0	0	 	 	510,1	2240	85,5	19,5	ON	510,44	2240	40	6,18	14,29
    1	511,77	0	0	 	 	511,1	2208	85,5	18,8	ON	511,43	2208	44,3	6,18	15,96
    	512,77	0	0	 	 	512,1	2208	85,5	22,3	ON	512,44	2240	45,5	7,21	16,16
    	513,78	0	0	 	 	513,11	2240	85,5	19,5	ON	513,44	2208	50,2	8,24	17,97
    	514,77	0	0	 	 	514,11	2240	85,5	18,8	ON	514,44	2240	66,3	9,27	24,29
    	515,78	0	0	 	 	515,1	2272	85,5	17,6	ON	515,44	2272	65,1	9,27	23,71
    	516,79	0	0	 	 	516,12	2304	85,5	16,8	ON	516,45	2304	63,9	9,27	23,91
    	517,77	0	0	 	 	517,11	2304	85,5	20,3	ON	517,44	2336	67,5	10,3	25,45
    	518,91	0	0	 	 	518,29	2368	85,5	18	ON	518,57	2368	68,6	10,3	25,77
    	519,92	0	0	 	 	519,23	2400	85,5	14,8	ON	519,58	2400	68,6	9,27	26,55
    	520,94	0	0	 	 	520,25	2432	85,5	14,8	ON	520,59	2464	72,9	10,3	29,17
    	521,96	0	0	 	 	521,29	2464	85,5	13,3	ON	521,64	2496	72,9	10,3	28,77
    	523	0	0	 	 	522,3	2496	85,5	12,5	ON	522,67	2528	74,1	10,3	30,39
    	524	0	0	 	 	523,32	2560	85,5	12,1	ON	523,66	2560	74,1	10,3	30,12
    	524,98	0	0	 	 	524,33	2592	85,5	12,1	ON	524,66	2624	72,9	10,3	30,94
    	526	0	0	 	 	525,31	2624	85,5	12,1	ON	525,65	2656	71,8	10,3	30,25
    	527,02	0	0	 	 	526,35	2656	85,5	9,8	ON	526,67	2688	69,4	10,3	29,57
    	528,01	0	0	 	 	527,36	2688	85,5	7,4	ON	527,69	2688	63,9	9,27	27,24
    	529,01	0	0	 	 	528,34	2720	85,5	9,4	ON	528,68	2720	58	8,24	25,64
    	530,08	0	0	 	 	529,36	2720	85,5	10,5	ON	529,71	2720	56,1	8,24	24,36
    	531,1	0	0	 	 	530,43	2752	85,5	10,5	ON	530,78	2752	52,5	8,24	23,03
    	532,16	0	0	 	 	531,46	2752	85,5	7,4	ON	531,82	2752	47,8	7,21	21,71
    	533,18	0	0	 	 	532,49	2752	85,5	9,8	ON	532,85	2752	45,5	6,18	20,33
    	534,2	0	0	 	 	533,53	2752	85,5	12,5	ON	533,86	2752	46,7	7,21	20,93
    	535,18	0	0	 	 	534,52	2784	85,5	11,7	ON	534,84	2784	46,7	7,21	21,15
    	536,16	0	0	 	 	535,51	2784	85,5	11,7	ON	535,84	2784	46,7	7,21	21,34
    	537,22	0	0	 	 	536,52	2784	85,5	14,1	ON	536,87	2784	47,8	6,18	21,58
    	538,25	0	0	 	 	537,57	2816	85,5	15,6	ON	537,9	2816	46,7	6,18	21,22
    	539,26	0	0	 	 	538,61	2816	85,5	18,4	ON	538,96	2816	44,3	6,18	20,53
    	540,26	0	0	 	 	539,6	2848	85,5	18,8	ON	539,94	2848	47,8	7,21	22,18
    	541,31	0	0	 	 	540,62	2848	85,5	16,4	ON	540,95	2848	42,4	6,18	18,99
    	542,36	0	0	 	 	541,65	2848	85,5	15,6	ON	542	2880	40	6,18	18,4
    	543,39	0	0	 	 	542,7	2880	85,5	12,5	ON	543,04	2880	41,2	6,18	18,47
    	544,36	0	0	 	 	543,71	2880	85,5	15,2	ON	544,04	2880	41,2	6,18	18,88
    	545,31	0	0	 	 	544,66	2880	85,5	19,1	ON	544,99	2880	35,3	5,15	17,18
    	546,31	0	0	 	 	545,64	2880	85,5	20,7	ON	545,97	2880	35,3	5,15	16,64
    	547,24	0	0	 	 	546,61	2880	85,5	16	ON	546,92	2880	34,1	5,15	15,57
    	548,24	0	0	 	 	547,56	2880	85,5	16,8	ON	547,9	2880	35,3	5,15	15,96
    	549,26	0	0	 	 	548,56	2880	85,5	21,5	ON	548,9	2880	36,5	5,15	16,43
    	550,3	0	0	 	 	549,61	2880	85,5	16	ON	549,96	2880	36,5	5,15	16,73
    	551,35	0	0	 	 	550,64	2880	85,5	14,8	ON	551	2880	37,6	5,15	17,26
    	552,39	0	0	 	 	551,7	2912	85,5	17,6	ON	552,04	2880	37,6	5,15	17,53
    	553,45	0	0	 	 	552,75	2912	85,5	21,1	ON	553,1	2912	36,5	5,15	16,73
    	554,55	0	0	 	 	553,82	2912	85,5	19,5	ON	554,18	2912	36,5	5,15	17,18
    	555,62	0	0	 	 	554,93	2912	85,5	13,7	ON	555,29	2912	36,5	5,15	17,18
    	556,59	0	0	 	 	555,9	2912	85,5	16,8	ON	556,23	2912	34,1	5,15	15,87
    	557,68	0	0	 	 	556,94	2912	85,5	20,7	ON	557,31	2912	32,9	5,15	15,83
    	558,72	0	0	 	 	558,04	2912	85,5	18,8	ON	558,38	2880	31	4,12	14,78
    	559,73	0	0	 	 	559,06	2880	85,5	18,8	ON	559,41	2880	31,8	5,15	14,56
    	560,74	0	0	 	 	560,06	2880	85,5	16,4	ON	560,4	2880	29,8	4,12	13,8
    	561,76	0	0	 	 	561,07	2880	85,5	22,3	ON	561,42	2880	29,8	4,12	13,38
    	562,77	0	0	 	 	562,09	2848	85,5	17,6	ON	562,44	2848	29,8	4,12	13,92
    	563,78	0	0	 	 	563,12	2848	85,5	15,6	ON	563,43	2848	29,8	4,12	13,65
    	564,79	0	0	 	 	564,14	2816	85,5	21,5	ON	564,48	2816	29,8	4,12	13,36
    	565,82	0	0	 	 	565,12	2816	85,5	18	ON	565,47	2816	29,8	4,12	13,62
    	566,88	0	0	 	 	566,17	2816	85,5	13,3	ON	566,54	2816	29,8	4,12	13,51
    	567,92	0	0	 	 	567,22	2816	85,5	18	ON	567,56	2784	29,8	4,12	13,65
    	568,96	0	0	 	 	568,28	2784	85,5	21,1	ON	568,63	2784	29,8	4,12	13,2
    	569,96	0	0	 	 	569,29	2784	85,5	16,8	ON	569,63	2784	32,9	5,15	14,71
    	570,96	0	0	 	 	570,3	2784	85,5	15,6	ON	570,63	2784	35,3	5,15	15,83
    	571,96	0	0	 	 	571,28	2784	85,5	22,3	ON	571,62	2784	36,5	5,15	16,1
    	572,98	0	0	 	 	572,3	2784	85,5	16	ON	572,64	2784	36,5	5,15	15,9
    	574	0	0	 	 	573,32	2784	85,5	15,6	ON	573,66	2784	36,5	5,15	16,26
    	574,98	0	0	 	 	574,33	2784	85,5	16	ON	574,64	2784	37,6	5,15	16,84
    	575,98	0	0	 	 	575,3	2784	85,5	21,5	ON	575,64	2784	37,6	5,15	16,84
    	576,98	0	0	 	 	576,31	2784	85,5	20,7	ON	576,64	2784	37,6	6,18	16,84
    	578	0	0	 	 	577,34	2784	85,5	16,4	ON	577,68	2784	37,6	5,15	16,84
    	578,96	0	0	 	 	578,33	2784	85,5	14,1	ON	578,64	2784	36,5	5,15	16,16
    	579,91	0	0	 	 	579,27	2784	85,5	19,5	ON	579,59	2784	36,5	5,15	16,41
    	580,88	0	0	 	 	580,23	2784	85,5	19,9	ON	580,56	2784	36,5	5,15	16,5
    	581,88	0	0	 	 	581,22	2784	85,5	15,2	ON	581,55	2784	36,5	5,15	16,5
    	582,92	0	0	 	 	582,23	2784	85,5	16	ON	582,59	2816	35,3	5,15	16,13
    	583,91	0	0	 	 	583,26	2784	85,5	21,1	ON	583,58	2784	35,3	5,15	15,83
    	584,9	0	0	 	 	584,24	2784	85,5	20,3	ON	584,57	2816	35,3	5,15	15,51
    	585,87	0	0	 	 	585,22	2784	85,5	16	ON	585,55	2816	34,1	5,15	15,83
    	586,84	0	0	 	 	586,19	2784	85,5	15,6	ON	586,51	2784	34,1	4,12	15,02
    	587,84	0	0	 	 	587,16	2784	85,5	21,5	ON	587,5	2784	34,1	5,15	15,19
    	588,86	0	0	 	 	588,18	2784	85,5	18	ON	588,53	2784	35,3	5,15	15,53
    	589,89	0	0	 	 	589,2	2784	85,5	15,6	ON	589,54	2784	35,3	5,15	16,07
    	590,88	0	0	 	 	590,22	2784	85,5	19,9	ON	590,54	2784	35,3	5,15	15,74
    	591,87	0	0	 	 	591,22	2784	85,5	22,3	ON	591,55	2784	36,5	5,15	16,5
    	592,88	0	0	 	 	592,2	2784	85,5	12,9	ON	592,54	2784	36,5	5,15	16,16
    	593,87	0	0	 	 	593,21	2784	85,5	18,8	ON	593,54	2784	36,5	5,15	16,74
    	594,78	0	0	 	 	594,16	2784	85,5	19,9	ON	594,48	2784	36,5	5,15	16,5
    	595,71	0	0	 	 	595,09	2784	85,5	14,1	ON	595,39	2784	36,5	5,15	16,28
    	596,68	0	0	 	 	596,04	2784	85,5	21,5	ON	596,36	2784	36,5	5,15	16,5
    	597,63	0	0	 	 	596,99	2784	85,5	20,7	ON	597,3	2784	36,5	5,15	16,16
    	598,64	0	0	 	 	597,96	2784	85,5	17,6	ON	598,29	2784	36,5	5,15	15,87
    	599,61	0	0	 	 	598,97	2784	85,5	15,2	ON	599,29	2784	36,5	5,15	16,1
    	600,54	0	0	 	 	599,92	2784	85,5	19,5	ON	600,24	2784	36,5	5,15	16,16
    	601,55	0	0	 	 	600,88	2784	85,5	18,8	ON	601,21	2784	36,5	5,15	16,84
    	602,52	0	0	 	 	601,88	2784	85,5	12,9	ON	602,21	2784	37,6	5,15	16,5
    	603,52	0	0	 	 	602,84	2784	85,5	16	ON	603,18	2784	36,5	5,15	16,81
    	604,55	0	0	 	 	603,86	2784	85,5	21,1	ON	604,21	2784	36,5	5,15	16,16
    	605,56	0	0	 	 	604,89	2784	85,5	20,7	ON	605,24	2784	35,3	5,15	15,64
    	606,53	0	0	 	 	605,88	2784	84	18,4	ON	606,2	2784	35,3	5,15	15,51
    	607,57	0	0	 	 	606,87	2784	84	15,2	ON	607,23	2784	35,3	5,15	15,59
    	608,55	0	0	 	 	607,89	2784	85,5	15,6	ON	608,22	2784	34,1	5,15	15,02
    	609,51	0	0	 	 	608,87	2784	84	21,1	ON	609,19	2784	34,1	5,15	15,51
    	610,46	0	0	 	 	609,83	2784	84	19,5	ON	610,12	2784	34,1	5,15	15,59
    	611,46	0	0	 	 	610,8	2784	84	14,1	ON	611,13	2784	35,3	5,15	15,64
    	612,46	0	0	 	 	611,8	2784	84	19,5	ON	612,13	2784	35,3	5,15	15,83
    	613,47	0	0	 	 	612,8	2784	84	21,1	ON	613,14	2784	35,3	5,15	15,51
    	614,45	0	0	 	 	613,81	2784	84	18,8	ON	614,13	2784	35,3	5,15	15,83
    	615,42	0	0	 	 	614,76	2784	84	15,2	ON	615,08	2784	35,3	5,15	15,83
    	616,43	0	0	 	 	615,76	2784	84	21,5	ON	616,09	2784	35,3	5,15	16,16
    	617,39	0	0	 	 	616,74	2784	84	21,1	ON	617,06	2784	35,3	5,15	16,16
    	618,4	0	0	 	 	617,72	2784	84	19,5	ON	618,07	2784	35,3	5,15	16,16
    	619,4	0	0	 	 	618,73	2784	84	15,6	ON	619,06	2784	36,5	5,15	16,5
    	620,4	0	0	 	 	619,74	2784	84	17,2	ON	620,07	2784	36,5	5,15	16,38
    	621,34	0	0	 	 	620,71	2784	84	21,1	ON	621,03	2784	36,5	5,15	16,5
    	622,3	0	0	 	 	621,66	2784	84	18	ON	621,98	2784	36,5	5,15	16,56
    	623,3	0	0	 	 	622,64	2784	84	14,5	ON	622,96	2784	36,5	5,15	16,43
    	624,31	0	0	 	 	623,65	2784	84	16,8	ON	623,98	2784	36,5	5,15	16,5
    	625,26	0	0	 	 	624,62	2784	84	21,1	ON	624,94	2784	36,5	5,15	16,5
    	626,21	0	0	 	 	625,57	2784	84	20,3	ON	625,89	2816	35,3	5,15	15,83
    	627,17	0	0	 	 	626,53	2784	84	12,9	ON	626,85	2784	35,3	5,15	15,74
    	628,14	0	0	 	 	627,49	2784	84	18	ON	627,81	2784	34,1	5,15	14,87
    	629,13	0	0	 	 	628,46	2784	84	21,9	ON	628,79	2784	34,1	5,15	15,51
    	630,13	0	0	 	 	629,45	2784	84	17,6	ON	629,79	2784	34,1	5,15	15,83
    	631,14	0	0	 	 	630,47	2784	84	15,2	ON	630,81	2784	34,1	5,15	14,87
    	632,13	0	0	 	 	631,46	2784	84	16,8	ON	631,8	2784	32,9	5,15	15,42
    	633,16	0	0	 	 	632,47	2784	84	19,9	ON	632,82	2784	34,1	5,15	15,77
    	634,14	0	0	 	 	633,49	2784	84	21,9	ON	633,82	2784	34,1	5,15	14,87
    	635,13	0	0	 	 	634,48	2784	84	19,9	ON	634,8	2784	34,1	5,15	15,56
    	636,11	0	0	 	 	635,46	2784	84	16,4	ON	635,78	2784	34,1	5,15	15,51
    	637,14	0	0	 	 	636,45	2784	84	19,5	ON	636,8	2784	35,3	5,15	15,83
    	638,1	0	0	 	 	637,47	2784	84	21,9	ON	637,78	2784	36,5	5,15	16,36
    	639,12	0	0	 	 	638,45	2784	84	16,8	ON	638,79	2784	36,5	5,15	16,34
    	640,11	0	0	 	 	639,44	2752	84	15,2	ON	639,77	2784	17,3	2,06	7,22
    	641,05	0	0	 	 	640,42	2752	84	19,1	ON	640,74	2720	0	0	7,18
    	641,98	0	0	 	 	641,36	2688	84	0	OFF	641,66	2656	0	0	7,18
    	642,93	0	0	 	 	642,3	2624	84	0	OFF	642,62	2592	0	0	6,77
    	643,87	0	0	 	 	643,24	2560	84	0	OFF	643,56	2560	0	0	6,38
    	644,79	0	0	 	 	644,16	2528	84	0	OFF	644,48	2496	0	0	6,29
    	645,74	0	0	 	 	645,1	2464	84	0	OFF	645,42	2464	0	0	6,04
    	646,69	0	0	 	 	646,05	2400	84	0	ON	646,38	2400	27,5	4,12	12,11
    	647,69	0	0	 	 	647,03	2400	84	2,3	ON	647,36	2400	34,1	4,12	13,36
    	648,7	0	0	 	 	648,03	2400	84	2,3	ON	648,37	2400	35,3	4,12	13,49
    	649,72	0	0	 	 	649,04	2400	84	2,7	ON	649,38	2400	35,3	4,12	13,65
    	650,69	0	0	 	 	650,05	2432	84	14,8	ON	650,38	2432	35,3	5,15	13,38
    	651,67	0	0	 	 	651,01	2432	84	23	ON	651,34	2432	35,3	5,15	13,94
    	652,64	0	0	 	 	652,01	2432	84	15,2	ON	652,34	2432	35,3	5,15	13,65
    	653,67	0	0	 	 	652,99	2432	84	21,9	ON	653,32	2432	34,1	5,15	13
    	654,66	0	0	 	 	653,99	2432	84	17,6	ON	654,32	2432	34,1	5,15	13,36
    	655,69	0	0	 	 	654,99	2432	84	16,4	ON	655,34	2432	32,9	4,12	12,78
    	656,72	0	0	 	 	656,03	2432	84	19,9	ON	656,38	2432	32,9	4,12	12,95
    	657,72	0	0	 	 	657,06	2432	84	18	ON	657,4	2432	31,8	5,15	12,5
    	658,74	0	0	 	 	658,06	2432	84	15,2	ON	658,39	2432	31,8	4,12	12,06
    	659,76	0	0	 	 	659,07	2432	84	18,4	ON	659,4	2272	0	0	6,32
    	660,77	7	0	 	 	660,09	1632	84	0	ON	660,46	1504	16,1	3,09	3,81
    	661,64	7,8	0	 	 	661,06	1184	84	0	ON	661,35	1056	19,2	3,09	4,2
    	662,51	7	0	 	 	661,91	896	84	1,6	ON	662,22	832	25,1	4,12	4,2
    	663,38	7	0	 	 	662,79	896	84	2,3	ON	663,09	896	25,1	4,12	3,87
    	664,29	7	0	 	 	663,71	896	84	-0,4	ON	664	864	25,1	3,09	3,81
    	665,2	7	0	 	 	664,59	864	84	-3,1	ON	664,9	864	25,1	3,09	3,65
    	666,08	7,8	0	 	 	665,5	864	84	-5,9	ON	665,8	864	25,1	3,09	3,62
    	666,97	7,8	0	 	 	666,38	864	84	-8,6	ON	666,67	864	25,1	3,09	3,71
    	667,87	7,8	0	 	 	667,26	864	84	-11,3	ON	667,56	832	26,3	3,09	3,77
    	668,73	7,8	0	 	 	668,16	832	84	-9	ON	668,44	832	26,3	3,09	3,72
    	669,63	7,8	0	 	 	669,03	832	84	-6,6	ON	669,32	832	26,3	3,09	3,63
    	670,56	0	0	 	 	669,94	832	84	-3,9	ON	670,25	864	36,5	5,15	9,36
    	671,43	5,5	0	 	 	670,87	1248	84	-0,8	ON	671,16	928	29,8	3,09	5,41
    	672,3	6,3	0	 	 	671,7	992	84	1,2	ON	672	960	31,8	4,12	4,19
    	673,22	7	0	 	 	672,61	896	84	2,3	ON	672,91	896	27,5	3,09	4,22
    	674,12	7	0	 	 	673,53	864	84	3,9	ON	673,82	864	27,5	3,09	4,19
    	675	0	0	 	 	674,41	896	84	5,1	ON	674,7	864	26,3	3,09	3,71
    	675,94	0	0	 	 	675,31	1056	84	6,6	ON	675,63	1152	44,3	6,18	9,37
    	676,85	0	0	 	 	676,26	992	84	10,5	ON	676,54	864	41,2	6,18	6,78
    	677,83	0	0	 	 	677,16	1184	84	12,9	ON	677,51	1248	36,5	5,15	6,98
    	678,88	0	0	 	 	678,19	1472	84	18,8	ON	678,53	1632	36,5	5,15	4,73
    	679,85	0	0	 	 	679,24	1248	84	0,4	ON	679,53	960	44,3	7,21	10,07
    	680,75	0	0	 	 	680,13	1056	84	2,3	ON	680,44	1088	46,7	6,18	7,8
    	681,69	0	0	 	 	681,05	1184	84	2,3	ON	681,38	1248	47,8	6,18	9,74
    	682,69	0	0	 	 	682	1376	84	5,5	ON	682,32	1504	65,1	9,27	15,09
    	683,75	0	0	 	 	683,06	1824	84	17,6	ON	683,42	2016	68,6	10,3	22,72
    	684,77	0	0	 	 	684,07	2368	84	16	ON	684,43	2240	0	0	9,29
    	685,82	0	0	 	 	685,14	1504	84	0,8	ON	685,47	1632	69,4	9,27	18,63
    	686,89	0	0	 	 	686,18	1728	84	0,8	ON	686,53	1824	76,5	10,3	22,46
    	687,94	0	0	 	 	687,24	1952	84	0,4	ON	687,57	2016	77,6	10,3	25,02
    	688,97	0	0	 	 	688,27	2176	84	11,3	ON	688,61	2240	76,5	10,3	27,19
    	689,95	0	0	 	 	689,3	2400	84	10,9	ON	689,62	2464	76,5	10,3	29,53
    	691,02	0	0	 	 	690,28	2336	84	0	OFF	690,64	1824	34,1	5,15	15,12
    	692,06	0	0	 	 	691,38	1920	84	0,8	ON	691,72	1952	75,3	10,3	24,06
    	693,11	0	0	 	 	692,44	2016	84	0,4	ON	692,78	2048	77,6	10,3	25,63
    	694,12	0	0	 	 	693,45	2112	84	1,2	ON	693,78	2144	77,6	10,3	26,46
    	695,13	0	0	 	 	694,45	2240	84	11,3	ON	694,79	2272	76,5	10,3	27,24
    	696,13	0	0	 	 	695,46	2336	84	12,5	ON	695,8	2368	75,3	10,3	28,25
    	697,18	0	0	 	 	696,47	2400	84	0	OFF	696,83	2016	22,7	3,09	5,79
    	698,2	0	0	 	 	697,53	2048	84	1,6	ON	697,87	2080	69,4	9,27	22,72
    	699,2	0	0	 	 	698,52	2112	84	1,6	ON	698,87	2144	69,4	9,27	23,47
    	700,24	0	0	 	 	699,54	2176	84	1,6	ON	699,88	2208	68,6	9,27	23,91
    	701,26	0	0	 	 	700,57	2240	84	18,8	ON	700,91	2272	66,3	10,3	23,63
    	702,26	0	0	 	 	701,58	2304	84	10,9	ON	701,9	2336	56,9	7,21	18,88
    	703,22	0	0	 	 	702,57	2368	84	13,3	ON	702,9	2368	56,1	8,24	20,77
    	704,25	0	0	 	 	703,56	2400	84	16	ON	703,89	2400	50,2	7,21	18,99
    	705,27	0	0	 	 	704,58	2432	84	19,5	ON	704,92	2464	56,1	8,24	21,92
    	706,31	0	0	 	 	705,64	2496	84	14,5	ON	705,99	2496	54,9	8,24	21,68
    	707,32	0	0	 	 	706,62	2528	84	14,8	ON	706,97	2528	47,8	7,21	18,99
    	708,35	0	0	 	 	707,69	2560	84	16,4	ON	708	2560	41,2	6,18	16,05
    	709,41	0	0	 	 	708,7	2560	84	17,6	ON	709,05	2560	35,3	5,15	14,56
    	710,39	0	0	 	 	709,73	2560	84	18,8	ON	710,07	2560	29,8	4,12	11,92
    	711,42	0	0	 	 	710,74	2560	84	10,5	ON	711,08	2560	25,1	3,09	10,41
    	712,43	0	0	 	 	711,79	2528	84	15,6	ON	712,1	2528	22,7	3,09	9,21
    	713,45	0	0	 	 	712,79	2528	84	19,5	ON	713,13	2528	22,7	3,09	8,85
    	714,53	0	0	 	 	713,82	2496	84	15,6	ON	714,18	2496	21,6	3,09	8,69
    	715,51	0	0	 	 	714,86	2496	85,5	16,4	ON	715,18	2496	21,6	3,09	8,78
    	716,56	0	0	 	 	715,87	2496	84	21,5	ON	716,22	2496	22,7	3,09	9,13
    	717,62	0	0	 	 	716,91	2464	84	15,2	ON	717,27	2464	23,9	3,09	9,92
    	718,65	0	0	 	 	717,96	2464	84	20,3	ON	718,3	2464	25,1	3,09	10,16
    	719,68	0	0	 	 	718,98	2464	84	15,6	ON	719,34	2464	26,3	4,12	10,9
    	720,71	0	0	 	 	720,02	2464	85,5	16	ON	720,37	2464	27,5	4,12	11,01
    	721,73	0	0	 	 	721,06	2464	85,5	17,2	ON	721,4	2464	28,6	4,12	11,16
    	722,77	0	0	 	 	722,08	2464	85,5	11,3	ON	722,43	2464	28,6	4,12	11,68
    	723,8	0	0	 	 	723,11	2464	84	14,5	ON	723,47	2464	29,8	4,12	11,92
    	724,85	0	0	 	 	724,15	2464	85,5	19,9	ON	724,5	2464	31	4,12	11,82
    	725,93	0	0	 	 	725,19	2464	85,5	15,6	ON	725,58	2464	31	4,12	12,23
    	726,97	0	0	 	 	726,28	2464	84	14,1	ON	726,62	2464	29,8	4,12	11,91
    	728,01	0	0	 	 	727,31	2464	85,5	15,6	ON	727,66	2464	31	4,12	11,99
    	729,05	0	0	 	 	728,36	2464	85,5	19,1	ON	728,7	2464	31	4,12	12,23
    	730,07	0	0	 	 	729,4	2464	85,5	15,2	ON	729,72	2464	31	4,12	12,32
    	731,11	0	0	 	 	730,42	2464	84	12,9	ON	730,75	2464	31	4,12	12,23
    	732,15	0	0	 	 	731,45	2464	85,5	16,8	ON	731,8	2464	29,8	4,12	11,95
    	733,18	0	0	 	 	732,5	2464	84	19,5	ON	732,82	2464	29,8	4,12	11,95
    	734,19	0	0	 	 	733,52	2496	84	15,6	ON	733,87	2464	29,8	4,12	12,23
    	735,24	0	0	 	 	734,54	2464	85,5	16,4	ON	734,9	2464	29,8	4,12	11,79
    	736,3	0	0	 	 	735,6	2464	84	20,7	ON	735,96	2464	29,8	4,12	12,23
    	737,32	0	0	 	 	736,64	2496	84	16	ON	736,96	2496	29,8	4,12	11,95
    	738,37	0	0	 	 	737,67	2464	84	16	ON	738,03	2464	29,8	4,12	11,64
    	739,42	0	0	 	 	738,7	2464	84	20,3	ON	739,07	2464	29,8	4,12	11,95
    	740,45	0	0	 	 	739,75	2464	84	15,6	ON	740,09	2464	29,8	4,12	11,84
    	741,52	0	0	 	 	740,79	2464	84	15,6	ON	741,15	2464	29,8	4,12	11,71
    	742,57	0	0	 	 	741,87	2464	84	20,3	ON	742,22	2464	29,8	4,12	11,98
    	743,57	0	0	 	 	742,9	2464	84	18,8	ON	743,25	2464	29,8	4,12	12,23
    	744,6	0	0	 	 	743,93	2464	84	11,3	ON	744,28	2464	31	4,12	12,47
    	745,63	0	0	 	 	744,95	2464	84	15,2	ON	745,3	2464	31	4,12	12,5
    	746,64	0	0	 	 	745,96	2464	84	21,1	ON	746,3	2464	31,8	4,12	12,62
    	747,66	0	0	 	 	746,98	2464	84	14,8	ON	747,31	2464	31,8	4,12	12,62
    	748,7	0	0	 	 	748,01	2464	84	16,4	ON	748,35	2464	31,8	4,12	13,18
    	749,77	0	0	 	 	749,06	2464	84	21,1	ON	749,41	2496	31	4,12	12,5
    	750,84	0	0	 	 	750,12	2464	84	17,2	ON	750,51	2464	31	4,12	12,5
    	751,83	0	0	 	 	751,18	2464	84	13,3	ON	751,5	2464	31	4,12	12,23
    	752,88	0	0	 	 	752,18	2464	84	18,8	ON	752,53	2464	31,8	4,12	12,5
    	753,92	0	0	 	 	753,23	2464	84	16,4	ON	753,57	2464	31	4,12	12,62
    	754,93	0	0	 	 	754,26	2464	84	13,7	ON	754,59	2464	31,8	4,12	12,36
    	755,94	0	0	 	 	755,28	2464	84	19,9	ON	755,59	2464	31,8	4,12	12,23
    	756,97	0	0	 	 	756,29	2464	84	16,4	ON	756,64	2464	31,8	4,12	12,76
    	758,02	0	0	 	 	757,33	2464	84	11,3	ON	757,67	2464	31,8	4,12	12,29
    	759,01	0	0	 	 	758,35	2464	84	15,2	ON	758,67	2496	31	4,12	12,47
    	760,02	0	0	 	 	759,33	2496	84	18,8	ON	759,67	2496	29,8	4,12	11,95
    	761,06	0	0	 	 	760,37	2496	84	16	ON	760,71	2496	29,8	4,12	11,44
    	762,13	0	0	 	 	761,42	2496	84	10,9	ON	761,77	2496	28,6	4,12	11,55
    	763,13	0	0	 	 	762,44	2496	84	15,6	ON	762,79	2464	28,6	4,12	11,42
    	764,15	0	0	 	 	763,47	2464	84	15,6	ON	763,8	2464	29,8	4,12	11,07
    	765,17	0	0	 	 	764,48	2464	84	13,3	ON	764,82	2464	29,8	4,12	11,68
    	766,17	0	0	 	 	765,49	2464	84	15,2	ON	765,82	2464	29,8	4,12	11,68
    	767,15	0	0	 	 	766,5	2464	84	18	ON	766,84	2464	31	4,12	12,23
    	768,17	0	0	 	 	767,49	2464	84	10,5	ON	767,84	2464	31	4,12	12,23
    	769,23	0	0	 	 	768,53	2464	84	15,2	ON	768,89	2464	31	4,12	12,5
    	770,27	0	0	 	 	769,58	2464	84	19,1	ON	769,93	2464	31,8	4,12	12,5
    	771,27	0	0	 	 	770,6	2464	84	15,2	ON	770,95	2464	31,8	4,12	12,78
    	772,26	0	0	 	 	771,61	2464	84	14,1	ON	771,95	2464	31	4,12	12,47
    	773,32	0	0	 	 	772,62	2464	84	19,1	ON	772,95	2464	31	4,12	12,5
    	774,35	0	0	 	 	773,68	2464	84	16,8	ON	774,04	2496	31	4,12	11,98
    	775,4	0	0	 	 	774,71	2464	84	10,5	ON	775,07	2464	31	4,12	12,24
    	776,42	0	0	 	 	775,74	2496	84	16	ON	776,07	2496	29,8	4,12	11,71
    	777,43	0	0	 	 	776,76	2464	84	18,4	ON	777,1	2464	29,8	4,12	11,68
    	778,48	0	0	 	 	777,78	2464	84	12,9	ON	778,13	2464	29,8	4,12	11,64
    	779,48	0	0	 	 	778,82	2464	84	15,2	ON	779,13	2464	29,8	4,12	11,68
    	780,52	0	0	 	 	779,81	2464	84	19,1	ON	780,17	2464	29,8	4,12	11,95
    	781,56	0	0	 	 	780,87	2464	84	14,5	ON	781,21	2464	29,8	4,12	11,82
    	782,57	0	0	 	 	781,91	2464	84	12,1	ON	782,23	2464	31	4,12	12,13
    	783,61	0	0	 	 	782,93	2464	84	18,4	ON	783,27	2464	31	4,12	11,95
    	784,55	0	0	 	 	783,92	2464	84	14,8	ON	784,25	2464	29,8	4,12	11,95
    	785,54	0	0	 	 	784,89	2464	84	14,8	ON	785,2	2464	31	4,12	11,68
    	786,57	0	0	 	 	785,88	2464	84	17,6	ON	786,23	2464	31	4,12	12,32
    	787,62	0	0	 	 	786,91	2464	84	12,5	ON	787,25	2464	31	4,12	12,46
    	788,67	0	0	 	 	787,97	2464	84	14,5	ON	788,32	2464	31,8	4,12	12,24
    	789,72	0	0	 	 	789,02	2464	84	19,9	ON	789,36	2464	31,8	4,12	12,78
    	790,76	0	0	 	 	790,07	2464	84	14,5	ON	790,42	2464	31,8	4,12	12,5
    	791,78	0	0	 	 	791,12	2496	84	14,5	ON	791,44	2464	31	4,12	12,78
    	792,85	0	0	 	 	792,14	2496	84	19,5	ON	792,5	2496	31	4,12	12,13
    	793,8	0	0	 	 	793,17	2496	84	14,8	ON	793,47	2496	29,8	4,12	11,84
    	794,76	0	0	 	 	794,11	2496	84	15,2	ON	794,41	2496	28,6	4,12	11,42
    	795,78	0	0	 	 	795,12	2496	84	15,6	ON	795,44	2464	28,6	4,12	11,68
    	796,81	0	0	 	 	796,13	2464	84	11,7	ON	796,48	2464	28,6	4,12	11,42
    	797,82	0	0	 	 	797,13	2464	84	18	ON	797,49	2464	29,8	4,12	11,89
    	798,82	0	0	 	 	798,16	2464	84	15,2	ON	798,5	2464	29,8	4,12	12,23
    	799,86	0	0	 	 	799,16	2464	84	13,3	ON	799,5	2464	31	4,12	12,24
    	800,87	0	0	 	 	800,2	2464	84	18,8	ON	800,54	2464	31	4,12	12,5
    	801,88	0	0	 	 	801,22	2464	84	16	ON	801,55	2464	31	4,12	12,78
    	802,9	0	0	 	 	802,22	2464	84	12,1	ON	802,57	2464	31	4,12	12,64
    	803,89	0	0	 	 	803,25	2464	84	19,9	ON	803,58	2464	31	4,12	12,78
    	804,93	0	0	 	 	804,23	2464	84	15,2	ON	804,58	2464	31	4,12	12,5
    	805,98	0	0	 	 	805,28	2464	84	11,3	ON	805,63	2464	31	4,12	12,09
    	807,03	0	0	 	 	806,34	2464	84	18,8	ON	806,67	2464	31	4,12	12,24
    	808,06	0	0	 	 	807,38	2464	84	17,2	ON	807,72	2464	31,8	4,12	12,5
    	809,07	0	0	 	 	808,4	2464	84	11,7	ON	808,73	2464	31,8	4,12	12,89
    	810,1	0	0	 	 	809,41	2464	84	16	ON	809,75	2464	31,8	4,12	12,83
    	811,11	0	0	 	 	810,44	2464	84	19,1	ON	810,77	2464	32,9	5,15	12,99
    	812,14	0	0	 	 	811,47	2464	84	11,3	ON	811,82	2464	31,8	4,12	12,78
    	813,16	0	0	 	 	812,47	2464	84	16	ON	812,81	2464	31,8	4,12	12,5
    	814,17	0	0	 	 	813,49	2464	84	19,1	ON	813,82	2464	31,8	4,12	12,78
    	815,17	0	0	 	 	814,51	2464	84	13,7	ON	814,84	2464	31,8	4,12	12,86
    	816,19	0	0	 	 	815,5	2464	84	14,8	ON	815,85	2464	31,8	4,12	12,83
    	817,25	0	0	 	 	816,54	2464	84	19,9	ON	816,9	2464	34,1	5,15	13,51
    	818,28	0	0	 	 	817,61	2464	84	18,8	ON	817,95	2464	35,3	5,15	14
    	819,33	0	0	 	 	818,62	2464	84	13,7	ON	818,98	2464	35,3	5,15	13,94
    	820,33	0	0	 	 	819,68	2464	84	16	ON	819,99	2464	35,3	5,15	13,67
    	821,33	0	0	 	 	820,65	2464	84	21,1	ON	820,99	2464	35,3	5,15	13,94
    	822,31	0	0	 	 	821,64	2496	84	20,3	ON	821,97	2464	34,1	5,15	13,94
    	823,3	0	0	 	 	822,64	2464	84	14,5	ON	822,98	2496	32,9	5,15	13,48
    	824,29	0	0	 	 	823,63	2496	84	16	ON	823,94	2496	32,9	4,12	13,23
    	825,35	0	0	 	 	824,63	2496	84	20,3	ON	824,99	2496	31,8	4,12	12,5
    	826,42	0	0	 	 	825,71	2496	84	17,2	ON	826,07	2496	31	4,12	12,5
    	827,36	0	0	 	 	826,72	2496	84	11,3	ON	827,04	2496	31	4,12	12,23
    	828,33	0	0	 	 	827,68	2496	84	14,1	ON	828	2496	29,8	4,12	11,92
    	829,26	0	0	 	 	828,65	2496	84	18	ON	828,96	2496	29,8	4,12	11,57
    	830,21	0	0	 	 	829,59	2496	84	11,3	ON	829,9	2496	28,6	4,12	11,48
    	831,23	0	0	 	 	830,51	2496	84	14,5	ON	830,87	2464	27,5	4,12	11,16
    	832,18	0	0	 	 	831,56	2496	84	14,5	ON	831,87	2496	27,5	4,12	10,96
    	833,22	0	0	 	 	832,52	2496	84	10,2	ON	832,88	2496	27,5	4,12	10,84
    	834,2	0	0	 	 	833,57	2496	84	13,7	ON	833,88	2496	26,3	3,09	10,41
    	835,2	0	0	 	 	834,51	2496	84	16,8	ON	834,84	2496	25,1	3,09	10,28
    	836,16	0	0	 	 	835,52	2496	84	9,4	ON	835,84	2496	23,9	3,09	9,53
    	837,14	0	0	 	 	836,48	2496	84	16,4	ON	836,78	2496	22,7	3,09	8,93
    	838,13	0	0	 	 	837,48	2496	84	11,3	ON	837,81	2496	22,7	3,09	8,78
    	839,1	0	0	 	 	838,47	2496	84	14,5	ON	838,78	2496	21,6	3,09	8,55
    	840,08	0	0	 	 	839,42	2496	84	15,2	ON	839,76	2496	19,2	2,06	7,75
    	841,08	0	0	 	 	840,4	2496	84	10,2	ON	840,75	2496	18,4	2,06	7,2
    	842,07	0	0	 	 	841,4	2496	84	16,4	ON	841,73	2496	17,3	2,06	6,71
    	843,02	0	0	 	 	842,41	2496	84	10,2	ON	842,71	2496	16,1	2,06	6,44
    	844	0	0	 	 	843,37	2496	84	17,2	ON	843,68	2496	14,9	2,06	6,13
    	844,96	0	0	 	 	844,3	2496	84	9,8	ON	844,61	2496	14,9	2,06	6,29
    	846,01	0	0	 	 	845,32	2496	84	18,4	ON	845,68	2496	16,1	2,06	6,56
    	846,99	0	0	 	 	846,33	2464	84	10,5	ON	846,66	2464	16,1	2,06	6,47
    	847,98	0	0	 	 	847,32	2464	84	19,9	ON	847,64	2464	16,1	2,06	6,67
    	848,98	0	0	 	 	848,33	2464	84	15,2	ON	848,66	2464	17,3	2,06	6,99
    	850,02	0	0	 	 	849,33	2464	84	12,9	ON	849,67	2464	17,3	2,06	6,81
    	851,02	0	0	 	 	850,35	2464	84	17,6	ON	850,7	2464	17,3	2,06	6,99
    	852,05	0	0	 	 	851,36	2464	84	12,9	ON	851,69	2464	19,2	2,06	7,61
    	853,06	0	0	 	 	852,38	2464	84	18,4	ON	852,73	2464	18,4	2,06	7,38
    	854,06	0	0	 	 	853,39	2464	84	15,6	ON	853,73	2464	18,4	2,06	7,39
    	855,02	0	0	 	 	854,37	2464	84	16,8	ON	854,69	2464	18,4	2,06	7,18
    	856,05	0	0	 	 	855,35	2464	84	13,3	ON	855,7	2464	17,3	2,06	7,24
    	857,05	0	0	 	 	856,37	2464	84	15,6	ON	856,7	2464	17,3	2,06	6,83
    	858,08	0	0	 	 	857,42	2496	84	15,6	ON	857,76	2464	17,3	2,06	6,99
    	859,08	0	0	 	 	858,41	2496	84	13,7	ON	858,75	2464	17,3	2,06	7,24
    	860,12	0	0	 	 	859,42	2464	84	18,4	ON	859,76	2464	17,3	2,06	6,81
    	861,12	0	0	 	 	860,46	2464	82,5	11,7	ON	860,78	2464	18,4	2,06	7,38
    	862,16	0	0	 	 	861,48	2464	82,5	21,9	ON	861,83	2464	20,4	3,09	8,36
    	863,17	0	0	 	 	862,5	2432	82,5	15,6	ON	862,84	2464	21,6	3,09	8,78
    	864,2	0	0	 	 	863,51	2432	82,5	19,1	ON	863,87	2432	23,9	3,09	10,04
    	865,23	0	0	 	 	864,55	2432	82,5	15,2	ON	864,88	2432	26,3	4,12	10,38
    	866,22	0	0	 	 	865,55	2432	82,5	14,1	ON	865,9	2432	28,6	4,12	11,42
    	867,2	0	0	 	 	866,56	2432	82,5	19,5	ON	866,9	2208	0	0	7,93
    	868,17	7,8	0	 	 	867,55	1408	82,5	0	ON	867,86	1312	16,1	3,09	3,31
    	869,1	7	0	 	 	868,5	1056	82,5	0	ON	868,82	992	21,6	3,09	4,03
    	870,11	7	0	 	 	869,45	960	82,5	0,4	ON	869,81	992	23,9	3,09	3,89
    	871,02	7	0	 	 	870,42	960	82,5	0,4	ON	870,73	928	23,9	3,09	3,83
    	871,93	7	0	 	 	871,32	928	82,5	-2	ON	871,63	928	25,1	3,09	3,83
    	872,84	7	0	 	 	872,24	896	82,5	-4,7	ON	872,55	896	25,1	3,09	3,85
    	873,73	7	0	 	 	873,12	896	82,5	-7,4	ON	873,42	864	25,1	3,09	4
    	874,63	7,8	0	 	 	874,02	864	82,5	-10,2	ON	874,33	864	26,3	3,09	3,87
    	875,54	7,8	0	 	 	874,93	864	82,5	-9	ON	875,23	864	26,3	3,09	3,72
    	876,41	7	0	 	 	875,82	864	82,5	-6,3	ON	876,12	864	26,3	3,09	3,77
    	877,31	7,8	0	 	 	876,72	864	82,5	-3,5	ON	877,01	864	26,3	3,09	3,76
    	878,21	7	0	 	 	877,59	864	82,5	-0,8	ON	877,92	864	26,3	3,09	3,73
    	879,1	7	0	 	 	878,5	864	82,5	2	ON	878,8	864	26,3	3,09	3,69
    	879,97	7	0	 	 	879,38	896	82,5	4,7	ON	879,68	896	25,1	3,09	3,71
    	880,86	0	0	 	 	880,27	896	82,5	3,5	ON	880,55	864	25,1	3,09	3,76
    	881,91	0	0	 	 	881,22	1600	82,5	0,4	ON	881,56	1792	22,7	3,09	6,03
    	882,96	0	0	 	 	882,26	1792	82,5	5,1	ON	882,62	1760	32,9	4,12	10,12
    	883,92	6,3	0	 	 	883,29	1728	82,5	0	ON	883,61	1632	18,4	3,09	4,68
    	884,86	7	0	 	 	884,25	1248	82,5	0	ON	884,55	1216	20,4	3,09	3,27
    	885,76	7	0	 	 	885,15	1056	82,5	0,4	ON	885,45	960	22,7	3,09	4,22
    	886,55	7	0	 	 	886,02	960	82,5	0,4	ON	886,29	992	25,1	3,09	3,98
    	887,46	7,8	0	 	 	886,87	960	82,5	0,4	ON	887,16	896	23,9	3,09	4,11
    	888,38	7	0	 	 	887,77	896	82,5	-2,3	ON	888,08	896	25,1	3,09	3,83
    	889,26	7,8	0	 	 	888,66	864	84	-5,1	ON	888,95	864	26,3	3,09	3,96
    	890,17	7,8	0	 	 	889,59	832	82,5	-7,8	ON	889,88	864	26,3	3,09	3,73
    	891,05	0	0	 	 	890,47	864	82,5	-9,4	ON	890,77	832	26,3	3,09	3,94
    	892,09	0	0	 	 	891,43	1312	84	-6,6	ON	891,76	1280	43,5	5,15	9,47
    	892,95	0	0	 	 	892,41	1376	82,5	-0,4	ON	892,69	1440	41,2	5,15	9,43
    	893,97	0	0	 	 	893,3	1536	84	5,5	ON	893,63	1600	40	5,15	10,14
    	895,04	0	0	 	 	894,34	1728	84	14,1	ON	894,7	1856	58	9,27	17,26
    	896,07	0	0	 	 	895,38	2176	84	16	ON	895,73	2016	0	0	4,7
    	896,94	0	0	 	 	896,36	1440	84	0	ON	896,68	1408	65,1	9,27	14,63
    	898,01	0	0	 	 	897,3	1504	84	0,4	ON	897,64	1568	67,5	9,27	16,84
    	899,11	0	0	 	 	898,38	1664	82,5	0,4	ON	898,73	1696	67,5	9,27	18,4
    	900,15	0	0	 	 	899,45	1824	84	8,2	ON	899,8	1856	68,6	10,3	20,61
    	901,21	0	0	 	 	900,51	1984	84	21,1	ON	900,87	2016	56,9	8,24	15,68
    	902,23	0	0	 	 	901,56	2080	84	9	ON	901,91	2112	44,3	6,18	13,94
    	903,25	0	0	 	 	902,58	2144	84	12,9	ON	902,9	2144	36,5	5,15	12,17
    	904,28	0	0	 	 	903,59	2144	84	14,8	ON	903,94	2176	28,6	4,12	10,16
    	905,33	0	0	 	 	904,63	2144	84	14,1	ON	904,99	2144	28,6	4,12	9,57
    	906,33	0	0	 	 	905,67	2112	84	0	OFF	906	1728	18,4	3,09	5,08
    	907,29	7	0	 	 	906,65	1568	84	0	ON	906,95	1440	16,1	3,09	3,88
    	908,16	7,8	0	 	 	907,59	1152	84	0	ON	907,89	1056	19,2	3,09	4,06
    	909,1	7	0	 	 	908,46	960	84	0,4	ON	908,78	928	25,1	3,09	4,26
    	910,13	7	0	 	 	909,45	992	84	-1,2	ON	909,81	992	23,9	3,09	3,86
    	911,01	7,8	0	 	 	910,42	928	84	-4,3	ON	910,72	864	25,1	3,09	4,02
    	911,92	7,8	0	 	 	911,31	864	84	-6,6	ON	911,61	864	26,3	3,09	3,83
    	912,82	7,8	0	 	 	912,22	864	84	-5,1	ON	912,51	864	25,1	3,09	3,81
    	913,69	7,8	0	 	 	913,11	864	84	-6,3	ON	913,4	864	25,1	3,09	3,72
    	914,57	7,8	0	 	 	914	864	84	-7,8	ON	914,28	864	26,3	3,09	3,63
    	915,47	7,8	0	 	 	914,88	864	84	-5,1	ON	915,18	864	25,1	3,09	3,59
    	916,39	7,8	0	 	 	915,78	864	84	-2,3	ON	916,09	864	25,1	3,09	3,49
    	917,28	7,8	0	 	 	916,69	864	84	0,4	ON	916,98	832	25,1	3,09	3,58
    	918,17	7,8	0	 	 	917,59	864	84	-2	ON	917,88	864	25,1	3,09	3,61
    	919,06	7,8	0	 	 	918,47	864	84	-3,5	ON	918,78	864	25,1	3,09	3,56
    	919,96	7	0	 	 	919,37	864	84	-0,8	ON	919,66	864	25,1	3,09	3,71
    	920,83	7,8	0	 	 	920,27	896	84	0	ON	920,54	864	25,1	3,09	3,77
    	921,71	7,8	0	 	 	921,13	864	84	-2,3	ON	921,42	864	25,1	3,09	3,71
    	922,61	7,8	0	 	 	922,01	864	84	-5,1	ON	922,31	864	26,3	3,09	3,76
    	923,51	7,8	0	 	 	922,91	864	84	-3,5	ON	923,22	864	26,3	3,09	3,66
    	924,44	7,8	0	 	 	923,82	864	84	-0,8	ON	924,13	864	25,1	3,09	3,61
    	925,33	7,8	0	 	 	924,73	832	84	-2,7	ON	925,03	832	25,1	3,09	3,54
    	926,18	7,8	0	 	 	925,62	832	84	-5,5	ON	925,9	832	25,1	3,09	3,55
    	927,05	7,8	0	 	 	926,48	832	84	-3,9	ON	926,76	832	25,1	3,09	3,57
    	927,91	7,8	0	 	 	927,35	864	84	-1,2	ON	927,63	832	25,1	3,09	3,68
    	928,78	7,8	0	 	 	928,19	832	84	-0,8	ON	928,48	832	25,1	3,09	3,6
    	929,66	7,8	0	 	 	929,09	864	84	-3,5	ON	929,38	832	25,1	3,09	3,49
    	930,53	7,8	0	 	 	929,93	832	84	-5,5	ON	930,24	832	25,1	3,09	3,59
    	931,4	7,8	0	 	 	930,83	832	84	-2,7	ON	931,13	832	26,3	3,09	3,69
    	932,28	7,8	0	 	 	931,71	832	84	0	ON	932	832	25,1	3,09	3,57
    	933,15	7,8	0	 	 	932,56	832	84	-2,3	ON	932,86	864	26,3	3,09	3,61
    	934,03	7	0	 	 	933,44	864	84	-4,7	ON	933,74	832	26,3	3,09	3,83
    	934,9	7,8	0	 	 	934,31	832	84	-2,3	ON	934,59	864	26,3	3,09	3,63
    	935,79	7,8	0	 	 	935,2	832	84	0,4	ON	935,48	832	26,3	3,09	3,65
    	936,66	7,8	0	 	 	936,07	864	84	0	ON	936,36	832	26,3	3,09	3,63
    	937,57	7,8	0	 	 	936,97	832	84	-2,7	ON	937,26	832	26,3	3,09	3,69
    	938,45	7,8	0	 	 	937,86	832	84	-3,9	ON	938,15	832	26,3	3,09	3,63
    	939,33	7	0	 	 	938,73	832	84	-1,6	ON	939,03	832	26,3	3,09	3,71
    	940,22	7,8	0	 	 	939,62	864	84	1,2	ON	939,92	864	26,3	3,09	3,68
    	941,11	7	0	 	 	940,51	864	84	0,4	ON	940,82	832	26,3	3,09	3,73
    	941,95	7	0	 	 	941,39	832	84	-2,3	ON	941,66	832	27,5	3,09	3,8
    	942,83	7	0	 	 	942,25	832	84	-3,1	ON	942,54	832	27,5	3,09	3,98
    	943,69	7	0	 	 	943,1	832	84	-0,8	ON	943,4	864	27,5	3,09	3,77
    	944,58	7	0	 	 	943,98	864	84	2	ON	944,27	864	27,5	3,09	3,65
    	945,44	7	0	 	 	944,87	832	84	0	ON	945,15	832	26,3	3,09	3,84
    	946,34	7	0	 	 	945,75	832	84	-2,3	ON	946,04	832	27,5	3,09	3,82
    	947,22	7	0	 	 	946,62	832	84	-1,6	ON	946,91	832	27,5	3,09	3,77
    	948,09	7	0	 	 	947,51	832	84	1,2	ON	947,8	832	27,5	3,09	3,92
    	949,01	7	0	 	 	948,4	864	84	3,9	ON	948,71	864	27,5	3,09	3,87
    	949,88	7	0	 	 	949,31	832	84	3,5	ON	949,6	832	27,5	3,09	3,92
    	950,77	7	0	 	 	950,18	864	84	0,8	ON	950,48	832	27,5	3,09	3,87
    	951,68	7	0	 	 	951,06	832	84	1,6	ON	951,37	864	27,5	3,09	3,82
    	952,58	7	0	 	 	951,98	864	84	4,7	ON	952,27	832	27,5	3,09	3,77
    	953,44	7	0	 	 	952,86	864	84	2,7	ON	953,16	832	27,5	3,09	3,77
    	954,3	7	0	 	 	953,73	832	84	0,4	ON	954,02	832	27,5	3,09	3,91
    	955,21	7	0	 	 	954,61	832	84	0,4	ON	954,92	832	27,5	3,09	3,88
    	956,11	7	0	 	 	955,52	832	85,5	3,5	ON	955,81	864	27,5	3,09	3,73
    	957	7	0	 	 	956,41	864	85,5	5,1	ON	956,72	864	27,5	3,09	3,86
    	957,9	7	0	 	 	957,31	864	85,5	2,3	ON	957,62	864	27,5	3,09	3,89
    	958,79	7	0	 	 	958,19	832	85,5	0	ON	958,5	832	27,5	3,09	3,77
    	959,66	7	0	 	 	959,08	832	85,5	2,7	ON	959,38	864	27,5	3,09	3,8
    	960,53	7	0	 	 	959,95	832	85,5	5,5	ON	960,25	864	27,5	3,09	3,76
    	961,4	7	0	 	 	960,84	864	85,5	3,5	ON	961,12	832	27,5	3,09	3,85
    	962,25	7,8	0	 	 	961,69	832	85,5	0,8	ON	961,97	832	27,5	3,09	3,76
    	963,09	7	0	 	 	962,53	832	85,5	2	ON	962,8	832	27,5	3,09	3,87
    	963,96	7	0	 	 	963,38	832	85,5	4,3	ON	963,67	832	27,5	3,09	3,77
    	964,85	7	0	 	 	964,26	864	85,5	5,9	ON	964,57	864	26,3	3,09	3,73
    	965,76	7,8	0	 	 	965,16	832	85,5	3,1	ON	965,47	832	27,5	3,09	3,85
    	966,6	7	0	 	 	966,04	832	85,5	0,8	ON	966,31	832	27,5	3,09	3,89
    	967,45	7	0	 	 	966,88	832	85,5	3,1	ON	967,16	832	27,5	3,09	3,89
    	968,32	7	0	 	 	967,75	864	85,5	5,9	ON	968,04	832	27,5	3,09	3,76
    	969,19	7	0	 	 	968,62	832	85,5	4,3	ON	968,91	832	27,5	3,09	3,86
    	970,06	7	0	 	 	969,47	832	85,5	1,6	ON	969,76	832	27,5	3,09	3,75
    	970,94	7	0	 	 	970,37	832	85,5	2	ON	970,66	832	27,5	3,09	3,85
    	971,81	7	0	 	 	971,21	864	85,5	4,7	ON	971,51	864	27,5	3,09	3,93
    	972,73	7	0	 	 	972,1	864	85,5	6,3	ON	972,41	864	27,5	3,09	3,91
    	973,61	7	0	 	 	973,03	864	85,5	3,5	ON	973,32	832	27,5	3,09	3,81
    	974,51	7	0	 	 	973,91	832	85,5	1,6	ON	974,22	832	27,5	3,09	3,94
    	975,38	7	0	 	 	974,79	832	85,5	4,3	ON	975,09	864	27,5	3,09	3,78
    	976,28	7	0	 	 	975,67	832	85,5	5,9	ON	975,96	832	27,5	3,09	3,71
    	977,12	7	0	 	 	976,57	832	85,5	3,1	ON	976,85	832	27,5	3,09	3,82
    	978,02	7	0	 	 	977,42	832	85,5	1,6	ON	977,72	832	27,5	3,09	3,83
    	978,89	7	0	 	 	978,29	832	85,5	4,3	ON	978,59	832	27,5	3,09	3,77
    	979,81	7	0	 	 	979,2	864	85,5	7	ON	979,5	864	27,5	3,09	3,77
    	980,65	7	0	 	 	980,1	832	85,5	4,7	ON	980,38	832	27,5	3,09	3,83
    	981,54	7,8	0	 	 	980,93	832	85,5	2	ON	981,22	832	27,5	3,09	3,89
    	982,42	7	0	 	 	981,82	832	85,5	3,5	ON	982,13	832	27,5	3,09	3,83
    	983,33	7	0	 	 	982,73	864	85,5	6,3	ON	983,04	832	27,5	3,09	3,87
    	984,22	7	0	 	 	983,62	864	85,5	5,5	ON	983,92	832	27,5	3,09	3,87
    	985,11	7	0	 	 	984,52	832	85,5	2,7	ON	984,81	832	27,5	3,09	3,89
    	986,01	7	0	 	 	985,4	832	85,5	3,1	ON	985,72	832	27,5	3,09	3,82
    	986,91	7	0	 	 	986,31	864	85,5	5,9	ON	986,6	864	27,5	3,09	3,88
    	987,77	7	0	 	 	987,19	832	85,5	4,7	ON	987,47	832	27,5	3,09	3,86
    	988,65	7	0	 	 	988,06	832	85,5	2	ON	988,37	832	27,5	3,09	3,82
    	989,56	7	0	 	 	988,94	864	85,5	4,7	ON	989,25	864	27,5	3,09	3,81
    	990,45	7	0	 	 	989,84	832	85,5	5,1	ON	990,14	832	27,5	3,09	3,78
    	991,3	7	0	 	 	990,75	832	85,5	2,3	ON	991,03	832	27,5	3,09	3,94
    	992,21	7	0	 	 	991,59	832	85,5	3,5	ON	991,91	832	27,5	3,09	3,93
    	993,06	7	0	 	 	992,49	832	85,5	6,3	ON	992,76	864	27,5	3,09	3,87
    	993,97	7	0	 	 	993,37	832	85,5	5,1	ON	993,67	832	27,5	3,09	3,75
    	994,86	7	0	 	 	994,26	832	85,5	2,3	ON	994,56	832	27,5	3,09	3,96
    	995,76	7	0	 	 	995,16	832	85,5	2,7	ON	995,47	832	27,5	3,09	3,86
    	996,65	7	0	 	 	996,05	832	85,5	5,5	ON	996,35	864	27,5	3,09	3,74
    	997,54	7	0	 	 	996,96	864	85,5	5,5	ON	997,25	832	27,5	3,09	3,83
    	998,44	7	0	 	 	997,83	832	85,5	2,7	ON	998,13	832	27,5	3,09	3,92
    	999,33	7	0	 	 	998,75	832	85,5	2,7	ON	999,03	864	27,5	3,09	3,87
    	1000,23	7	0	 	 	999,62	864	85,5	5,5	ON	999,93	864	27,5	3,09	3,92
    	1001,12	7	0	 	 	1000,53	832	85,5	3,5	ON	1000,82	832	27,5	3,09	3,89
    	1002	7	0	 	 	1001,43	832	85,5	1,2	ON	1001,72	864	27,5	3,09	3,86
    	1002,89	7	0	 	 	1002,31	832	85,5	2	ON	1002,62	832	27,5	3,09	3,91
    	1003,78	7	0	 	 	1003,18	832	85,5	4,7	ON	1003,48	864	27,5	3,09	3,89
    	1004,67	7	0	 	 	1004,08	864	85,5	6,3	ON	1004,38	864	27,5	3,09	3,86
    	1005,58	7	0	 	 	1004,96	864	85,5	3,5	ON	1005,27	864	27,5	3,09	3,78
    	1006,49	7	0	 	 	1005,87	832	85,5	0,8	ON	1006,19	832	27,5	3,09	3,88
    	1007,39	7	0	 	 	1006,79	832	85,5	3,1	ON	1007,08	832	27,5	3,09	3,92
    	1008,29	7	0	 	 	1007,68	864	85,5	5,9	ON	1007,98	864	27,5	3,09	3,88
    	1009,2	7	0	 	 	1008,6	832	85,5	7	ON	1008,89	832	26,3	3,09	3,79
    	1010,07	7	0	 	 	1009,51	832	85,5	4,3	ON	1009,79	832	27,5	3,09	3,85
    	1010,91	7	0	 	 	1010,35	832	85,5	4,3	ON	1010,63	832	27,5	3,09	3,82
    	1011,79	7	0	 	 	1011,21	864	85,5	6,6	ON	1011,48	864	27,5	3,09	3,85
    	1012,68	7	0	 	 	1012,09	832	85,5	6,3	ON	1012,39	864	27,5	3,09	3,85
    	1013,59	7	0	 	 	1012,98	832	85,5	3,5	ON	1013,29	864	27,5	3,09	3,79
    	1014,47	7	0	 	 	1013,87	832	85,5	3,5	ON	1014,17	832	27,5	3,09	3,85
    	1015,38	7	0	 	 	1014,77	832	85,5	6,3	ON	1015,07	864	27,5	3,09	3,83
    	1016,29	7	0	 	 	1015,68	864	85,5	7	ON	1015,99	864	27,5	3,09	3,78
    	1017,15	7	0	 	 	1016,58	832	85,5	4,3	ON	1016,87	832	27,5	3,09	3,8
    	1018,04	7	0	 	 	1017,46	832	85,5	1,6	ON	1017,76	832	27,5	3,09	3,82
    	1018,89	7	0	 	 	1018,32	832	85,5	4,3	ON	1018,59	864	27,5	3,09	3,73
    	1019,81	7	0	 	 	1019,2	864	85,5	6,6	ON	1019,51	864	27,5	3,09	3,8
    	1020,68	7	0	 	 	1020,1	832	85,5	6,3	ON	1020,38	832	27,5	3,09	3,69
    	1021,52	7	0	 	 	1020,96	864	85,5	3,5	ON	1021,24	832	27,5	3,09	3,86
    	1022,39	7	0	 	 	1021,8	832	85,5	2,3	ON	1022,09	832	27,5	3,09	3,82
    	1023,3	7	0	 	 	1022,7	832	85,5	5,1	ON	1023	832	27,5	3,09	3,77
    	1024,16	7	0	 	 	1023,58	832	85,5	7,8	ON	1023,85	864	27,5	3,09	3,78
    	1025,05	7	0	 	 	1024,45	864	85,5	5,5	ON	1024,75	832	26,3	3,09	3,81
    	1025,94	7	0	 	 	1025,34	832	85,5	3,1	ON	1025,63	832	27,5	3,09	3,96
    	1026,82	7	0	 	 	1026,22	832	85,5	4,3	ON	1026,52	832	27,5	3,09	3,87
    	1027,7	7	0	 	 	1027,12	864	85,5	7	ON	1027,41	832	27,5	3,09	3,82
    	1028,58	7	0	 	 	1028	864	85,5	7,4	ON	1028,3	832	27,5	3,09	3,93
    	1029,47	7	0	 	 	1028,89	832	85,5	4,7	ON	1029,18	832	27,5	3,09	3,72
    	1030,31	7	0	 	 	1029,74	832	85,5	2	ON	1030,02	832	27,5	3,09	3,94
    	1031,23	7,8	0	 	 	1030,61	832	85,5	4,7	ON	1030,92	864	27,5	3,09	3,82
    	1032,29	7	0	 	 	1031,68	864	85,5	7,8	ON	1031,98	864	27,5	3,09	3,69
    	1033,16	7	0	 	 	1032,58	864	85,5	5,9	ON	1032,86	832	26,3	3,09	3,81
    	1034,06	7	0	 	 	1033,46	832	85,5	3,1	ON	1033,76	832	27,5	3,09	3,75
    	1034,91	7	0	 	 	1034,33	832	85,5	4,7	ON	1034,62	832	27,5	3,09	3,83
    	1035,78	7	0	 	 	1035,21	832	85,5	7,4	ON	1035,5	832	26,3	3,09	3,89
    	1036,65	7	0	 	 	1036,07	832	85,5	6,3	ON	1036,36	832	27,5	3,09	3,71
    	1037,54	7,8	0	 	 	1036,95	832	85,5	3,5	ON	1037,26	832	27,5	3,09	3,77
    	1038,45	7	0	 	 	1037,83	832	85,5	3,5	ON	1038,14	832	27,5	3,09	3,77
    	1039,33	7	0	 	 	1038,74	864	85,5	6,3	ON	1039,02	864	27,5	3,09	3,83
    	1040,2	7	0	 	 	1039,62	832	85,5	7,8	ON	1039,9	864	27,5	3,09	3,75
    	1041,07	7	0	 	 	1040,49	832	85,5	5,1	ON	1040,77	832	27,5	3,09	3,73
    	1041,93	7	0	 	 	1041,35	832	85,5	2,7	ON	1041,62	832	27,5	3,09	3,88
    	1042,8	7	0	 	 	1042,23	832	85,5	4,3	ON	1042,52	832	27,5	3,09	3,82
    MAF average 3.70g/s
    Friday	21	June	2019	13:16:38:00008-VCID:1E3368789AB7DDBF84-515A	VCDS Version: Release 19,6,0 (x64)	Data version: 20190529 DS308,0
    3B0 906 018 A		1,6l/2V SIMOS3 G00HS0009
    	Group A:	'032				Group B:	'099				Group C:	'002
    		Adaptation (Idle)	Adaptation (Partial)	 	 		Engine Speed	Coolant	Lambda Control	Lambda Control		Engine Speed	Engine Load	Injection Timing	Mass Air Flow
    	TIME	Bank 1 Sensor 1	Bank 1 Sensor 1			TIME	(G28)	Temperature (G62)		Status	TIME	(G28)			Sensor (G70)
    Marker	STAMP	 %	 %			STAMP	 /min	C	 %		STAMP	 /min	 %	 ms	 g/s
    	0,57	0	0	 	 	0,01	864	91,5	0	OFF	0,3	832	23,9	3,09	2,56
    	1,45	0	0	 	 	0,87	864	91,5	0	OFF	1,16	864	23,9	3,09	2,59
    	2,34	0	0	 	 	1,75	832	91,5	0	OFF	2,04	832	23,9	3,09	2,8
    	3,21	0	0	 	 	2,63	832	91,5	0	OFF	2,92	832	23,9	3,09	2,87
    	4,1	0	0	 	 	3,52	832	91,5	0	OFF	3,8	832	25,1	3,09	3,07
    	5	0	0	 	 	4,41	832	91,5	0	OFF	4,71	832	26,3	3,09	3,41
    	5,85	0	0	 	 	5,28	864	91,5	0	OFF	5,57	832	27,5	3,09	3,43
    	6,74	0	0	 	 	6,15	832	91,5	0	OFF	6,45	832	28,6	3,09	3,69
    	7,63	0	0	 	 	7,02	832	91,5	0	OFF	7,33	832	28,6	3,09	3,87
    	8,5	0	0	 	 	7,92	832	91,5	0	OFF	8,19	832	29,8	3,09	4,03
    	9,41	0	0	 	 	8,82	864	91,5	0	OFF	9,11	864	31	3,09	4,14
    	10,3	0	0	 	 	9,72	832	91,5	0	OFF	10,01	864	31	3,09	4,24
    	11,16	0	0	 	 	10,56	832	91,5	0	OFF	10,87	864	31,8	3,09	4,27
    	12,04	0	0	 	 	11,46	864	91,5	0	OFF	11,74	896	31,8	3,09	4,33
    	12,96	0	0	 	 	12,35	832	91,5	1,6	ON	12,64	864	31,8	3,09	4,12
    	13,85	0	0	 	 	13,27	864	91,5	4,3	ON	13,56	864	29,8	3,09	3,81
    	14,76	0	0	 	 	14,15	896	91,5	7	ON	14,47	896	27,5	3,09	3,61
    	15,66	0	0	 	 	15,06	896	91,5	9,8	ON	15,36	896	25,1	3,09	3,31
    	16,54	0	0	 	 	15,96	864	91,5	12,5	ON	16,24	896	22,7	3,09	2,98
    	17,43	0	0	 	 	16,83	864	91,5	15,2	ON	17,13	896	21,6	3,09	2,97
    	18,32	0	0	 	 	17,73	864	91,5	18	ON	18,02	864	20,4	3,09	2,8
    	19,19	0	0	 	 	18,6	864	91,5	20,7	ON	18,89	864	19,2	3,09	2,74
    	20,08	0	0	 	 	19,48	864	91,5	23,4	ON	19,77	864	19,2	3,09	2,58
    	20,98	0	0	 	 	20,38	864	91,5	26,2	ON	20,68	864	18,4	3,09	2,56
    	21,88	0	0	 	 	21,28	864	91,5	27,7	ON	21,59	864	18,4	3,09	2,55
    	22,75	0	0	 	 	22,17	864	91,5	27,7	ON	22,46	864	18,4	2,06	2,38
    	23,64	0	0	 	 	23,06	832	91,5	27,7	ON	23,35	832	18,4	2,06	2,5
    	24,51	0	0	 	 	23,92	832	91,5	27,7	ON	24,22	832	17,3	2,06	2,39
    	25,37	0	0	 	 	24,8	832	91,5	27,7	ON	25,06	832	18,4	3,09	2,59
    	26,21	0	0	 	 	25,66	864	91,5	27,7	ON	25,93	832	18,4	3,09	2,54
    	27,1	0	0	 	 	26,52	864	91,5	27,7	ON	26,81	864	18,4	3,09	2,58
    	28,01	0	0	 	 	27,4	864	91,5	27,7	ON	27,71	832	18,4	3,09	2,61
    	28,9	0	0	 	 	28,3	864	91,5	27,7	ON	28,61	864	18,4	3,09	2,58
    	29,79	0	0	 	 	29,17	832	91,5	27,7	ON	29,48	832	18,4	3,09	2,66
    	30,67	0	0	 	 	30,08	864	91,5	27,7	ON	30,39	832	18,4	3,09	2,69
    	31,53	0	0	 	 	30,97	832	91,5	27,7	ON	31,25	768	18,4	2,06	2,77
    	32,39	0	0	 	 	31,83	864	91,5	0	OFF	32,11	832	29,8	3,09	3,68
    	33,26	0	0	 	 	32,68	832	91,5	0	OFF	32,98	832	31	3,09	4,13
    	34,16	0	0	 	 	33,58	800	91,5	0	OFF	33,87	832	31,8	3,09	4,54
    	35,02	0	0	 	 	34,44	800	91,5	0	OFF	34,73	864	32,9	4,12	4,29
    	35,88	0	0	 	 	35,3	864	91,5	0	OFF	35,61	864	31,8	3,09	4,21
    	36,76	0	0	 	 	36,17	864	91,5	0	OFF	36,45	864	31,8	3,09	4,36
    	37,65	0	0	 	 	37,06	864	91,5	0	OFF	37,35	864	31	3,09	4,04
    	38,5	0	0	 	 	37,93	864	91,5	0	OFF	38,22	864	29,8	3,09	3,89
    	39,39	0	0	 	 	38,79	832	91,5	0	OFF	39,09	864	29,8	3,09	3,72
    	40,28	0	0	 	 	39,69	864	91,5	0	OFF	39,99	864	29,8	3,09	3,61
    	41,15	0	0	 	 	40,57	864	91,5	0	OFF	40,86	832	29,8	3,09	3,78
    	42,07	0	0	 	 	41,45	832	91,5	0	OFF	41,76	832	28,6	3,09	3,59
    	42,96	0	0	 	 	42,37	832	91,5	0	OFF	42,67	864	29,8	3,09	3,76
    	43,83	0	0	 	 	43,26	864	91,5	0	OFF	43,55	832	29,8	3,09	4,18
    	44,73	0	0	 	 	44,14	832	91,5	0	OFF	44,43	832	31	3,09	4,03
    	45,61	0	0	 	 	45,03	864	91,5	0	OFF	45,31	832	31	3,09	4,42
    	46,5	0	0	 	 	45,9	832	91,5	0	OFF	46,2	864	32,9	4,12	4,71
    	47,33	0	0	 	 	46,78	832	91,5	0	OFF	47,06	800	34,1	4,12	4,81
    	48,22	0	0	 	 	47,63	832	91,5	0	OFF	47,93	864	34,1	4,12	4,54
    	49,09	0	0	 	 	48,5	832	91,5	0	OFF	48,81	864	35,3	4,12	4,53
    	49,98	0	0	 	 	49,39	864	91,5	0	OFF	49,68	864	35,3	4,12	4,78
    	50,84	0	0	 	 	50,26	800	91,5	0	OFF	50,55	832	37,6	4,12	4,82
    	51,76	0	0	 	 	51,15	864	91,5	0	OFF	51,46	832	35,3	4,12	4,81
    	52,63	0	0	 	 	52,07	864	91,5	0	OFF	52,36	864	34,1	4,12	4,62
    	53,53	0	0	 	 	52,93	864	91,5	0	OFF	53,21	864	35,3	4,12	4,87
    	54,41	0	0	 	 	53,82	832	91,5	0	OFF	54,12	832	35,3	4,12	5,01
    	55,32	0	0	 	 	54,7	864	91,5	0	OFF	55,02	864	35,3	4,12	4,94
    	56,19	0	0	 	 	55,6	832	91,5	0	OFF	55,89	832	35,3	4,12	4,56
    	57,07	0	0	 	 	56,5	800	91,5	0	OFF	56,78	864	37,6	4,12	5,39
    	57,96	0	0	 	 	57,36	864	91,5	0	OFF	57,67	864	34,1	4,12	4,88
    	58,83	0	0	 	 	58,24	864	91,5	0	OFF	58,52	832	35,3	4,12	4,94
    MAF average 2.82g/s (before throttle again)
    Friday	21	June	2019	17:27:38:00008-VCID:1E3368789AB7DDBF84-5178	VCDS Version: Release 19,6,0 (x64)	Data version: 20190529 DS308,0
    	0,26	0	0	 	 	0,53	0	31,5	0	OFF	0,01	0	0	0	0
    	1,06	0	0	 	 	1,33	0	31,5	0	OFF	0,79	0	0	0	0
    	12,99	0	0	 	 	13,33	1088	33	0	OFF	13,64	1088	36,5	6,18	6,51
    	13,96	0	0	 	 	14,26	1088	33	0	OFF	14,57	1088	36,5	6,18	6,34
    	14,87	0	0	 	 	15,16	1088	33	0	OFF	15,47	1088	36,5	6,18	6,39
    	15,79	0	0	 	 	16,11	1088	33	0	OFF	16,43	1088	36,5	6,18	6,44
    	16,73	0	0	 	 	17,03	1088	33	0	OFF	17,34	1088	36,5	6,18	6,28
    	17,64	0	0	 	 	17,96	1088	33	0	OFF	18,28	1088	36,5	5,15	6,47
    	18,59	0	0	 	 	18,89	1088	33	0	OFF	19,19	1088	35,3	5,15	6,21
    	19,49	0	0	 	 	19,81	1088	33	0	OFF	20,15	1088	35,3	5,15	6,19
    	20,47	0	0	 	 	20,81	1088	33	0	OFF	21,13	1088	36,5	5,15	6,29
    	21,45	0	0	 	 	21,76	1088	33	0	OFF	22,08	1088	35,3	5,15	6,13
    	22,39	0	0	 	 	22,7	1088	33	0	OFF	23,02	1056	36,5	5,15	6,44
    	23,35	0	0	 	 	23,66	1088	33	0	OFF	23,96	1088	35,3	5,15	6,19
    	24,27	0	0	 	 	24,59	1056	33	0	OFF	24,92	1088	35,3	5,15	6,05
    	25,23	0	0	 	 	25,53	1056	33	0	OFF	25,84	1088	36,5	5,15	6,18
    	26,17	0	0	 	 	26,48	1088	34,5	0	OFF	26,79	1088	35,3	5,15	6,15
    	27,07	0	0	 	 	27,37	1088	34,5	0	OFF	27,69	1088	35,3	5,15	6,13
    	28,01	0	0	 	 	28,34	1056	34,5	0	OFF	28,67	1088	35,3	5,15	5,97
    	28,99	0	0	 	 	29,33	1088	34,5	0	OFF	29,65	1056	34,1	5,15	6,21
    	29,99	0	0	 	 	30,31	1056	34,5	0	OFF	30,64	1088	34,1	5,15	5,98
    	30,96	0	0	 	 	31,27	1088	34,5	0	OFF	31,61	1056	35,3	5,15	6,36
    	31,92	0	0	 	 	32,22	1056	34,5	0	OFF	32,53	1088	35,3	5,15	5,99
    	32,84	0	0	 	 	33,15	1088	34,5	0	OFF	33,49	1088	35,3	5,15	6,41
    	33,79	0	0	 	 	34,09	1056	34,5	0	OFF	34,39	1088	35,3	5,15	6,21
    	34,72	0	0	 	 	35,05	1088	34,5	0	OFF	35,38	1088	35,3	5,15	6,13
    	35,7	0	0	 	 	35,99	1088	34,5	0	OFF	36,3	1088	32,9	5,15	5,65
    	36,63	0	0	 	 	36,93	1088	34,5	0	OFF	37,23	1088	31,8	5,15	5,33
    	37,55	0	0	 	 	37,85	1088	36	0	OFF	38,14	1088	29,8	4,12	5,24
    	38,44	0	0	 	 	38,73	1088	36	0	OFF	39,02	1088	28,6	4,12	4,87
    	39,32	0	0	 	 	39,65	1088	36	-0,4	ON	39,94	1024	23,9	3,09	3,57
    	40,29	0	0	 	 	40,65	992	36	-3,5	ON	41,01	992	26,3	3,09	4,37
    	41,36	0	0	 	 	41,63	960	36	-6,6	ON	42	960	31	3,09	4,79
    	42,26	0	0	 	 	42,59	960	36	-9,4	ON	42,87	960	32,9	3,09	5,22
    	43,18	0	0	 	 	43,48	928	36	-12,1	ON	43,78	928	35,3	4,12	5,59
    	44,07	0	0	 	 	44,37	928	36	-14,8	ON	44,67	928	38,8	4,12	5,89
    	44,99	0	0	 	 	45,3	960	37,5	-17,6	ON	45,59	928	40	4,12	5,87
    	45,89	0	0	 	 	46,2	896	37,5	-20,3	ON	46,5	896	40	4,12	5,59
    	46,79	0	0	 	 	47,07	864	37,5	-23	ON	47,35	832	43,5	4,12	6,35
    	47,64	0	0	 	 	47,94	864	37,5	-25,4	ON	48,23	800	46,7	5,15	6,07
    	48,54	0	0	 	 	48,85	800	37,5	-28,1	ON	49,14	864	52,5	5,15	7,34
    	49,44	0	0	 	 	49,73	800	37,5	-28,1	ON	50,03	864	54,9	5,15	7,44
    	50,34	0	0	 	 	50,63	864	37,5	-28,1	ON	50,93	832	52,5	5,15	7,55
    	51,23	0	0	 	 	51,51	768	37,5	-28,1	ON	51,78	736	61,6	6,18	8,08
    	52,07	0	0	 	 	52,36	704	37,5	-26,6	ON	52,65	672	68,6	7,21	8,22
    	52,92	0	0	 	 	53,23	864	37,5	-24,2	ON	53,56	1344	60,4	1,03	3,36
    	53,89	0	0	 	 	54,21	960	37,5	-18,8	ON	54,51	896	31,8	2,06	4,32
    	54,8	0	0	 	 	55,11	864	39	-17,6	ON	55,42	864	31	3,09	4,43
    	55,73	0	0	 	 	56,03	864	39	-16	ON	56,34	864	31,8	3,09	4,57
    	56,63	0	0	 	 	56,91	864	39	-14,8	ON	57,21	864	32,9	3,09	4,51
    	57,5	0	0	 	 	57,81	896	39	-13,3	ON	58,11	864	32,9	3,09	4,74
    	58,44	0	0	 	 	58,74	896	39	-12,1	ON	59,04	864	31,8	3,09	4,57
    	59,37	0	0	 	 	59,66	896	39	-10,5	ON	59,94	896	31	3,09	4,51
    	60,25	0	0	 	 	60,55	896	39	-9,4	ON	60,85	896	29,8	3,09	4,34
    	61,15	0	0	 	 	61,43	896	39	-7,8	ON	61,73	864	28,6	3,09	4,09
    	62,04	0	0	 	 	62,33	896	39	-6,6	ON	62,62	896	28,6	3,09	4,12
    	62,91	0	0	 	 	63,22	864	39	-5,1	ON	63,5	864	28,6	3,09	4,03
    	63,8	0	0	 	 	64,1	896	39	-3,9	ON	64,4	896	28,6	3,09	4,19
    	64,7	0	0	 	 	65,01	896	39	-2,3	ON	65,29	896	27,5	3,09	3,94
    	65,59	0	0	 	 	65,88	896	40,5	-1,2	ON	66,2	896	25,1	3,09	3,77
    	66,53	0	0	 	 	66,82	864	40,5	0,4	ON	67,11	864	25,1	3,09	3,39
    	67,41	0	0	 	 	67,69	864	40,5	1,6	ON	68,02	864	25,1	3,09	3,46
    	68,31	0	0	 	 	68,6	896	40,5	3,1	ON	68,91	896	23,9	3,09	3,53
    	69,19	0	0	 	 	69,49	896	40,5	3,5	ON	69,81	896	23,9	3,09	3,34
    	70,09	0	0	 	 	70,42	896	40,5	2	ON	70,71	864	23,9	3,09	3,36
    	71,01	0	0	 	 	71,31	864	40,5	0,8	ON	71,59	864	23,9	3,09	3,57
    	71,9	0	0	 	 	72,2	864	40,5	-0,8	ON	72,5	864	23,9	3,09	3,57
    	72,76	0	0	 	 	73,07	864	40,5	-2	ON	73,37	864	23,9	3,09	3,53
    	73,67	0	0	 	 	73,95	864	40,5	-3,1	ON	74,25	864	25,1	3,09	3,65
    	74,55	0	0	 	 	74,84	864	40,5	-0,4	ON	75,15	864	23,9	3,09	3,53
    	75,44	0	0	 	 	75,74	864	40,5	2,3	ON	76,04	864	25,1	3,09	3,51
    	76,34	0	0	 	 	76,61	864	42	5,1	ON	76,89	864	23,9	3,09	3,43
    	77,17	0	0	 	 	77,48	896	42	7,4	ON	77,79	896	23,9	3,09	3,56
    	78,08	0	0	 	 	78,39	864	42	5,9	ON	78,69	864	22,7	3,09	3,32
    	78,99	0	0	 	 	79,27	864	42	3,1	ON	79,58	864	23,9	3,09	3,38
    	79,88	0	0	 	 	80,19	864	42	0,4	ON	80,5	864	23,9	3,09	3,53
    	80,8	0	0	 	 	81,09	864	42	2	ON	81,4	832	23,9	3,09	3,57
    	81,69	0	0	 	 	81,98	864	42	4,7	ON	82,28	896	23,9	3,09	3,51
    	82,6	0	0	 	 	82,91	896	42	7,4	ON	83,21	896	23,9	3,09	3,48
    	83,51	0	0	 	 	83,79	896	42	7	ON	84,11	896	22,7	3,09	3,24
    	84,4	0	0	 	 	84,7	864	42	4,3	ON	85	864	22,7	3,09	3,33
    	85,29	0	0	 	 	85,58	864	42	1,6	ON	85,87	864	23,9	3,09	3,33
    	86,18	0	0	 	 	86,46	832	42	-0,4	ON	86,74	832	23,9	3,09	3,61
    	87,02	0	0	 	 	87,31	864	42	2,3	ON	87,61	864	25,1	3,09	3,46
    	87,89	0	0	 	 	88,18	896	42	5,1	ON	88,49	896	23,9	3,09	3,51
    	88,79	0	0	 	 	89,1	896	43,5	7,8	ON	89,4	896	23,9	3,09	3,57
    	89,68	0	0	 	 	89,96	864	43,5	9	ON	90,25	896	22,7	3,09	3,38
    	90,54	0	0	 	 	90,82	864	43,5	6,3	ON	91,11	864	22,7	3,09	3,33
    	91,41	0	0	 	 	91,7	864	43,5	3,5	ON	92	864	23,9	3,09	3,25
    	92,31	0	0	 	 	92,6	864	43,5	0,8	ON	92,9	832	23,9	3,09	3,61
    	93,21	0	0	 	 	93,53	864	43,5	1,6	ON	93,82	864	23,9	3,09	3,51
    	94,14	0	0	 	 	94,42	864	43,5	4,3	ON	94,71	896	23,9	3,09	3,51
    	95,01	0	0	 	 	95,33	864	43,5	7	ON	95,63	896	23,9	3,09	3,33
    	95,94	0	0	 	 	96,24	864	43,5	9,4	ON	96,52	896	22,7	3,09	3,37
    	96,82	0	0	 	 	97,11	864	43,5	6,6	ON	97,41	864	22,7	3,09	3,4
    	97,7	0	0	 	 	97,99	864	43,5	3,9	ON	98,3	864	23,9	3,09	3,37
    	98,61	0	0	 	 	98,92	832	43,5	1,2	ON	99,2	864	23,9	3,09	3,21
    	99,49	0	0	 	 	99,78	864	43,5	2	ON	100,07	864	23,9	3,09	3,57
    	100,34	0	0	 	 	100,63	864	43,5	4,7	ON	100,91	864	23,9	3,09	3,34
    	101,19	0	0	 	 	101,5	864	43,5	7	ON	101,8	896	23,9	3,09	3,31
    	102,1	0	0	 	 	102,4	864	45	9,8	ON	102,69	864	22,7	3,09	3,29
    	102,98	0	0	 	 	103,26	864	45	7,8	ON	103,56	864	22,7	3,09	3,54
    	103,84	0	0	 	 	104,13	864	45	5,1	ON	104,44	864	22,7	3,09	3,33
    	104,74	0	0	 	 	105,04	864	45	2,3	ON	105,33	832	22,7	3,09	3,39
    	105,63	0	0	 	 	105,93	864	45	1,2	ON	106,23	864	25,1	3,09	3,58
    	106,52	0	0	 	 	106,82	864	45	3,9	ON	107,1	896	25,1	3,09	3,65
    	107,41	0	0	 	 	107,71	896	45	6,6	ON	108,03	896	23,9	3,09	3,44
    	108,33	0	0	 	 	108,61	896	45	9,4	ON	108,9	896	22,7	3,09	3,2
    	109,18	0	0	 	 	109,47	896	45	7	ON	109,75	864	22,7	3,09	3,29
    	110,04	0	0	 	 	110,33	864	45	4,3	ON	110,62	864	22,7	3,09	3,32
    	110,94	0	0	 	 	111,24	864	45	1,6	ON	111,54	864	23,9	3,09	3,37
    	111,85	0	0	 	 	112,15	864	45	2,3	ON	112,45	864	23,9	3,09	3,39
    	112,75	0	0	 	 	113,05	864	45	5,5	ON	113,36	864	23,9	3,09	3,46
    	113,66	0	0	 	 	113,97	896	45	8,2	ON	114,25	896	23,9	3,09	3,42
    	114,54	0	0	 	 	114,83	896	45	9	ON	115,12	896	22,7	3,09	3,34
    	115,42	0	0	 	 	115,7	864	45	6,3	ON	116	864	22,7	3,09	3,31
    	116,28	0	0	 	 	116,57	864	46,5	3,5	ON	116,87	864	22,7	3,09	3,28
    	117,18	0	0	 	 	117,47	832	46,5	0,8	ON	117,77	832	23,9	3,09	3,57
    	118,06	0	0	 	 	118,35	864	46,5	2	ON	118,64	864	23,9	3,09	3,38
    	118,95	0	0	 	 	119,27	864	46,5	4,7	ON	119,57	896	22,7	3,09	3,46
    	119,88	0	0	 	 	120,16	896	46,5	7,4	ON	120,43	864	22,7	3,09	3,35
    	120,72	0	0	 	 	121,03	864	46,5	9,8	ON	121,34	864	22,7	3,09	3,43
    	121,63	0	0	 	 	121,94	864	46,5	7,4	ON	122,23	864	22,7	3,09	3,34
    	122,54	0	0	 	 	122,83	864	46,5	4,7	ON	123,31	864	22,7	3,09	3,26
    	123,59	0	0	 	 	123,88	864	46,5	2	ON	124,19	864	23,9	3,09	3,38
    	124,48	0	0	 	 	124,96	864	46,5	4,7	ON	125,42	864	23,9	3,09	3,36
    	125,69	0	0	 	 	125,99	896	46,5	8,2	ON	126,28	896	22,7	3,09	3,42
    	126,6	0	0	 	 	126,87	864	46,5	8,6	ON	127,15	896	22,7	3,09	3,38
    	127,45	0	0	 	 	127,89	864	46,5	5,5	ON	128,21	864	22,7	3,09	3,11
    	128,49	0	0	 	 	128,8	864	46,5	2,7	ON	129,29	832	22,7	3,09	3,33
    	129,55	0	0	 	 	129,84	864	46,5	2,3	ON	130,14	832	23,9	3,09	3,62
    	130,63	0	0	 	 	130,86	864	46,5	5,5	ON	131,16	896	23,9	3,09	3,51
    	131,45	0	0	 	 	131,76	896	48	8,2	ON	132,26	896	22,7	3,09	3,49
    	132,55	0	0	 	 	132,84	864	48	7,4	ON	133,15	864	22,7	3,09	3,31
    	133,44	0	0	 	 	133,73	864	48	4,7	ON	134,04	832	22,7	3,09	3,4
    	134,33	0	0	 	 	134,63	864	48	2	ON	134,94	864	22,7	3,09	3,32
    	135,23	0	0	 	 	135,51	832	48	0,8	ON	135,8	864	23,9	3,09	3,55
    	136,09	0	0	 	 	136,38	864	48	3,5	ON	136,67	864	23,9	3,09	3,61
    	136,98	0	0	 	 	137,28	896	48	6,3	ON	137,56	896	23,9	3,09	3,63
    	137,83	0	0	 	 	138,14	896	48	9	ON	138,45	896	22,7	3,09	3,06
    	138,76	0	0	 	 	139,07	896	48	9,4	ON	139,38	896	22,7	3,09	3,23
    	139,69	0	0	 	 	139,99	864	48	6,6	ON	140,28	864	22,7	3,09	3,24
    	140,58	0	0	 	 	140,88	864	48	3,9	ON	141,16	864	22,7	3,09	3,22
    	141,44	0	0	 	 	141,71	832	48	1,2	ON	142,02	832	22,7	3,09	3,49
    	142,32	0	0	 	 	142,58	832	48	-0,8	ON	142,86	832	25,1	3,09	3,69
    	143,17	0	0	 	 	143,47	864	48	2	ON	143,75	864	25,1	3,09	3,69
    	144,02	0	0	 	 	144,32	896	48	4,3	ON	144,61	896	25,1	3,09	3,57
    	144,91	0	0	 	 	145,21	896	48	7	ON	145,51	896	23,9	3,09	3,38
    	145,83	0	0	 	 	146,13	896	48	10,2	ON	146,45	896	22,7	3,09	3,06
    	146,76	0	0	 	 	147,04	864	49,5	7,8	ON	147,33	864	22,7	3,09	3,21
    	147,62	0	0	 	 	147,91	864	49,5	5,1	ON	148,2	864	22,7	3,09	3,14
    	148,5	0	0	 	 	148,8	832	49,5	2,3	ON	149,09	832	22,7	3,09	3,33
    	149,37	0	0	 	 	149,66	864	49,5	0,4	ON	149,97	864	23,9	3,09	3,56
    	150,28	0	0	 	 	150,58	864	49,5	3,5	ON	150,89	896	23,9	3,09	3,52
    	151,16	0	0	 	 	151,44	864	49,5	5,9	ON	151,73	896	22,7	3,09	3,27
    	152,03	0	0	 	 	152,33	864	49,5	8,6	ON	152,62	864	23,9	3,09	3,38
    	152,93	0	0	 	 	153,25	896	49,5	9,4	ON	153,54	864	22,7	3,09	3,31
    	153,83	0	0	 	 	154,12	864	49,5	6,6	ON	154,45	864	22,7	3,09	3,12
    	154,75	0	0	 	 	155,06	864	49,5	3,9	ON	155,36	832	22,7	3,09	3,51
    	155,65	0	0	 	 	155,94	864	49,5	1,2	ON	156,27	832	22,7	3,09	3,17
    	156,56	0	0	 	 	156,82	832	49,5	2,3	ON	157,12	864	23,9	3,09	3,46
    	157,41	0	0	 	 	157,71	864	51	5,1	ON	158	896	23,9	3,09	3,53
    	158,29	0	0	 	 	158,58	896	51	7,8	ON	158,88	896	23,9	3,09	3,43
    	159,18	0	0	 	 	159,48	896	51	9,8	ON	159,78	896	22,7	3,09	3,27
    	160,08	0	0	 	 	160,38	864	51	7	ON	160,68	864	22,7	3,09	3,23
    	160,98	0	0	 	 	161,28	864	51	4,3	ON	161,59	864	22,7	3,09	3,31
    	161,91	0	0	 	 	162,21	832	51	1,6	ON	162,49	864	22,7	3,09	3,4
    	163	0	0	 	 	163,23	832	51	0,4	ON	163,53	832	23,9	3,09	3,44
    	163,81	0	0	 	 	164,1	864	51	3,1	ON	164,39	864	23,9	3,09	3,45
    	164,66	0	0	 	 	164,98	896	51	5,9	ON	165,29	896	23,9	3,09	3,4
    	165,59	0	0	 	 	165,88	864	51	8,6	ON	166,18	896	22,7	3,09	3,36
    	166,47	0	0	 	 	166,8	896	51	9	ON	167,11	864	22,7	3,09	3,19
    	167,42	0	0	 	 	167,72	864	51	5,9	ON	168,02	864	21,6	3,09	3,13
    	168,31	0	0	 	 	168,61	864	51	3,1	ON	168,9	864	22,7	3,09	3,07
    	169,2	0	0	 	 	169,51	864	52,5	0,4	ON	169,78	832	22,7	3,09	3,32
    	170,08	0	0	 	 	170,38	864	52,5	2	ON	170,68	864	22,7	3,09	3,38
    	170,96	0	0	 	 	171,23	864	52,5	4,7	ON	171,53	864	22,7	3,09	3,47
    	171,81	0	0	 	 	172,1	864	52,5	7,4	ON	172,38	864	22,7	3,09	3,37
    	172,67	0	0	 	 	172,99	864	52,5	10,2	ON	173,27	896	22,7	3,09	3,39
    	173,57	0	0	 	 	173,86	864	52,5	8,2	ON	174,16	864	21,6	3,09	3,36
    	174,45	0	0	 	 	174,76	864	52,5	5,5	ON	175,05	864	22,7	3,09	3,34
    	175,38	0	0	 	 	175,67	864	52,5	2,7	ON	175,97	864	21,6	3,09	3,15
    	176,26	0	0	 	 	176,55	832	52,5	2	ON	176,85	864	23,9	3,09	3,53
    	177,13	0	0	 	 	177,42	864	52,5	4,3	ON	177,72	864	22,7	3,09	3,48
    	178,02	0	0	 	 	178,33	896	52,5	7	ON	178,63	896	22,7	3,09	3,4
    	178,93	0	0	 	 	179,22	896	52,5	9,8	ON	179,52	896	22,7	3,09	3,15
    	179,83	0	0	 	 	180,13	864	52,5	9	ON	180,44	864	21,6	3,09	3,14
    	180,74	0	0	 	 	181,03	864	52,5	5,9	ON	181,33	864	21,6	3,09	2,99
    	181,61	0	0	 	 	181,9	832	54	3,5	ON	182,22	832	21,6	3,09	3,09
    	182,52	0	0	 	 	182,81	864	54	0,8	ON	183,11	864	22,7	3,09	3,43
    	183,4	0	0	 	 	183,7	864	54	3,1	ON	184,01	864	23,9	3,09	3,46
    	184,31	0	0	 	 	184,59	864	54	5,9	ON	184,89	864	23,9	3,09	3,38
    	185,17	0	0	 	 	185,46	864	54	8,6	ON	185,76	896	22,7	3,09	3,39
    	186,05	0	0	 	 	186,36	864	54	11,3	ON	186,67	896	21,6	3,09	3,32
    	186,98	0	0	 	 	187,27	864	54	9	ON	187,57	864	21,6	3,09	3,39
    	187,88	0	0	 	 	188,18	864	54	6,3	ON	188,47	864	22,7	3,09	3,31
    	188,78	0	0	 	 	189,11	864	54	3,1	ON	189,41	832	22,7	3,09	3,24
    	189,72	0	0	 	 	190,01	864	54	2	ON	190,31	864	22,7	3,09	3,38
    	190,61	0	0	 	 	190,91	864	54	4,7	ON	191,22	864	22,7	3,09	3,42
    	191,54	0	0	 	 	191,84	864	54	7,4	ON	192,14	864	22,7	3,09	3,48
    	192,47	0	0	 	 	192,76	896	54	10,5	ON	193,06	896	22,7	3,09	3,36
    	193,36	0	0	 	 	193,67	864	54	10,2	ON	193,97	864	21,6	3,09	3,25
    	194,26	0	0	 	 	194,56	864	54	7	ON	194,86	864	21,6	3,09	3,14
    	195,15	0	0	 	 	195,44	832	55,5	4,7	ON	195,75	864	21,6	3,09	3,01
    	196,02	0	0	 	 	196,33	832	55,5	2	ON	196,63	832	22,7	3,09	3,37
    	196,94	0	0	 	 	197,24	864	55,5	3,5	ON	197,53	864	23,9	3,09	3,51
    	197,83	0	0	 	 	198,12	896	55,5	6,3	ON	198,43	896	22,7	3,09	3,31
    	198,73	0	0	 	 	199,06	896	55,5	9	ON	199,37	896	21,6	3,09	3,31
    	199,66	0	0	 	 	199,96	864	55,5	10,5	ON	200,25	864	21,6	3,09	3,17
    	200,56	0	0	 	 	200,86	864	55,5	7,8	ON	201,17	864	21,6	3,09	3,06
    	201,47	0	0	 	 	201,78	832	55,5	5,1	ON	202,07	832	21,6	3,09	3,14
    	202,36	0	0	 	 	202,64	832	55,5	2,3	ON	202,94	832	22,7	3,09	3,49
    	203,24	0	0	 	 	203,54	864	55,5	4,7	ON	203,85	864	23,9	3,09	3,51
    	204,15	0	0	 	 	204,47	896	55,5	7,4	ON	204,77	896	22,7	3,09	3,49
    	205,08	0	0	 	 	205,37	896	55,5	10,2	ON	205,69	896	22,7	3,09	3,31
    	205,98	0	0	 	 	206,27	864	55,5	10,2	ON	206,56	864	21,6	3,09	2,97
    	206,86	0	0	 	 	207,18	864	55,5	7,4	ON	207,48	864	21,6	3,09	3,12
    	207,78	0	0	 	 	208,09	832	55,5	4,7	ON	208,39	832	21,6	3,09	3,16
    	208,69	0	0	 	 	208,98	832	55,5	2	ON	209,26	832	22,7	3,09	3,35
    	209,57	0	0	 	 	209,85	832	55,5	4,3	ON	210,14	864	22,7	3,09	3,47
    	210,44	0	0	 	 	210,74	864	57	7	ON	211,04	896	22,7	3,09	3,28
    	211,34	0	0	 	 	211,64	896	57	9,8	ON	211,92	864	21,6	3,09	3,15
    	212,21	0	0	 	 	212,49	864	57	10,5	ON	212,78	864	21,6	3,09	3,12
    	213,08	0	0	 	 	213,36	864	57	7,8	ON	213,67	864	21,6	3,09	3,17
    	213,96	0	0	 	 	214,27	832	57	5,1	ON	214,56	832	21,6	3,09	3,15
    	214,85	0	0	 	 	215,15	832	57	2,3	ON	215,45	864	22,7	3,09	3,49
    	215,75	0	0	 	 	216,03	832	57	4,3	ON	216,32	864	22,7	3,09	3,26
    	216,62	0	0	 	 	216,91	896	57	7	ON	217,2	896	22,7	3,09	3,31
    	217,51	0	0	 	 	217,79	864	57	9,8	ON	218,1	896	21,6	3,09	3,14
    	218,4	0	0	 	 	218,69	864	57	10,5	ON	219	864	21,6	3,09	3,15
    	219,31	0	0	 	 	219,62	864	57	7,8	ON	219,93	864	21,6	3,09	2,78
    	220,24	0	0	 	 	220,53	832	57	5,1	ON	220,83	864	22,7	3,09	3,23
    	221,13	0	0	 	 	221,42	832	57	4,7	ON	221,69	832	22,7	3,09	3,26
    	221,98	0	0	 	 	222,28	864	57	7,4	ON	222,59	864	22,7	3,09	3,39
    	222,9	0	0	 	 	223,19	864	57	10,2	ON	223,47	896	21,6	3,09	3,33
    	223,75	0	0	 	 	224,03	864	57	12,9	ON	224,32	896	21,6	3,09	2,95
    	224,62	0	0	 	 	224,93	864	57	10,5	ON	225,23	864	21,6	3,09	3,14
    	225,53	0	0	 	 	225,8	864	58,5	7,8	ON	226,1	832	20,4	2,06	2,83
    	226,4	0	0	 	 	226,68	832	58,5	5,5	ON	226,99	832	23,9	3,09	3,42
    	227,27	0	0	 	 	227,57	864	58,5	5,9	ON	227,87	896	22,7	3,09	3,42
    	228,17	0	0	 	 	228,5	864	58,5	8,6	ON	228,79	864	22,7	3,09	3,31
    	229,09	0	0	 	 	229,41	864	58,5	11,7	ON	229,73	864	22,7	3,09	3,18
    	230,05	0	0	 	 	230,35	896	58,5	13,7	ON	230,63	864	21,6	3,09	3,04
    	230,92	0	0	 	 	231,23	864	58,5	10,9	ON	231,53	864	20,4	3,09	2,89
    	231,83	0	0	 	 	232,12	832	58,5	8,2	ON	232,41	832	20,4	2,06	2,88
    	232,69	0	0	 	 	232,99	832	58,5	5,5	ON	233,3	864	21,6	3,09	3,23
    	233,59	0	0	 	 	233,88	864	58,5	7,4	ON	234,19	864	22,7	3,09	3,51
    	234,49	0	0	 	 	234,8	864	58,5	10,2	ON	235,09	896	22,7	3,09	3,28
    	235,39	0	0	 	 	235,68	864	58,5	12,9	ON	235,98	864	22,7	3,09	3,28
    	236,26	0	0	 	 	236,56	896	58,5	14,1	ON	236,88	896	20,4	3,09	3,03
    	237,17	0	0	 	 	237,46	864	58,5	11,3	ON	237,76	832	21,6	3,09	3,17
    	238,05	0	0	 	 	238,34	864	58,5	8,6	ON	238,63	864	21,6	2,06	2,92
    	238,93	0	0	 	 	239,22	832	58,5	5,9	ON	239,53	832	22,7	3,09	3,43
    	239,84	0	0	 	 	240,13	864	58,5	7,4	ON	240,44	864	22,7	3,09	3,39
    	240,73	0	0	 	 	241,07	896	58,5	10,2	ON	241,38	896	22,7	3,09	3,32
    	241,67	0	0	 	 	241,96	896	58,5	12,9	ON	242,24	864	21,6	3,09	3,23
    	242,53	0	0	 	 	242,84	864	60	14,1	ON	243,13	864	21,6	3,09	2,93
    	243,41	0	0	 	 	243,7	864	60	11,3	ON	243,98	864	21,6	3,09	3,03
    	244,27	0	0	 	 	244,58	832	60	8,6	ON	244,86	864	21,6	3,09	3,09
    	245,14	0	0	 	 	245,42	832	60	7	ON	245,71	864	21,6	3,09	3,21
    	246,01	0	0	 	 	246,31	864	60	9,8	ON	246,6	864	22,7	3,09	3,25
    	246,9	0	0	 	 	247,2	864	60	12,5	ON	247,48	864	21,6	3,09	3,25
    	247,79	0	0	 	 	248,08	896	60	14,5	ON	248,37	896	21,6	3,09	3,03
    	248,66	0	0	 	 	248,95	864	60	12,1	ON	249,28	864	21,6	3,09	3,12
    	249,59	0	0	 	 	249,89	864	60	9	ON	250,19	832	20,4	2,06	2,8
    	250,49	0	0	 	 	250,78	832	60	7,4	ON	251,07	832	22,7	3,09	3,51
    	251,36	0	0	 	 	251,66	864	60	10,2	ON	251,97	864	22,7	3,09	3,6
    	252,26	0	0	 	 	252,57	864	60	12,9	ON	252,88	896	22,7	3,09	3,37
    	253,2	0	0	 	 	253,51	864	60	15,6	ON	253,8	896	21,6	3,09	3,01
    	254,11	0	0	 	 	254,39	896	60	14,1	ON	254,69	864	20,4	2,06	2,8
    	255	0	0	 	 	255,29	864	60	11,7	ON	255,6	832	20,4	2,06	2,77
    	255,89	0	0	 	 	256,19	864	60	8,6	ON	256,49	832	20,4	2,06	2,98
    	256,8	0	0	 	 	257,08	832	60	7,4	ON	257,38	832	22,7	3,09	3,43
    	257,69	0	0	 	 	258	864	60	10,2	ON	258,29	864	22,7	3,09	3,38
    	258,6	0	0	 	 	258,91	896	61,5	13,3	ON	259,21	864	21,6	3,09	3,09
    	259,48	0	0	 	 	259,8	864	61,5	15,2	ON	260,1	864	21,6	3,09	2,96
    	260,41	0	0	 	 	260,7	864	61,5	12,5	ON	261,01	864	20,4	2,06	2,86
    	261,31	0	0	 	 	261,6	832	61,5	9,8	ON	261,91	832	21,6	3,09	3,37
    	262,19	0	0	 	 	262,47	832	61,5	7,8	ON	262,77	864	22,7	3,09	3,2
    	263,08	0	0	 	 	263,38	864	61,5	10,5	ON	263,68	864	22,7	3,09	3,38
    	263,99	0	0	 	 	264,29	864	61,5	13,3	ON	264,59	864	22,7	3,09	3,29
    	264,89	0	0	 	 	265,19	864	61,5	16	ON	265,5	896	21,6	3,09	3
    	265,8	0	0	 	 	266,11	864	61,5	14,1	ON	266,42	864	21,6	3,09	2,95
    	266,71	0	0	 	 	267,02	864	61,5	11,3	ON	267,33	864	20,4	2,06	2,97
    	267,62	0	0	 	 	267,9	832	61,5	8,6	ON	268,18	832	21,6	3,09	3,17
    	268,49	0	0	 	 	268,79	864	61,5	8,2	ON	269,08	864	21,6	3,09	3,19
    	269,39	0	0	 	 	269,7	864	61,5	10,9	ON	270	864	21,6	3,09	3,16
    	270,29	0	0	 	 	270,6	864	61,5	13,7	ON	270,9	864	21,6	3,09	3,32
    	271,21	0	0	 	 	271,53	896	61,5	14,5	ON	271,82	896	21,6	3,09	2,89
    	272,12	0	0	 	 	272,43	864	63	11,7	ON	272,72	832	20,4	3,09	2,86
    	273,01	0	0	 	 	273,32	832	63	9	ON	273,61	832	21,6	2,06	3,13
    	273,91	0	0	 	 	274,19	832	63	8,6	ON	274,49	832	22,7	3,09	3,42
    	274,8	0	0	 	 	275,1	864	63	11,3	ON	275,41	864	22,7	3,09	3,23
    	275,72	0	0	 	 	276,01	864	63	14,1	ON	276,3	864	21,6	3,09	3,22
    	276,61	0	0	 	 	276,92	896	63	16,8	ON	277,2	864	21,6	3,09	3,14
    	277,49	0	0	 	 	277,79	864	63	14,1	ON	278,1	864	20,4	3,09	2,99
    	278,38	0	0	 	 	278,68	864	63	11,3	ON	278,95	864	20,4	2,06	2,78
    	279,24	0	0	 	 	279,52	832	63	9	ON	279,79	864	20,4	2,06	2,83
    	280,08	0	0	 	 	280,36	832	63	8,2	ON	280,65	832	22,7	3,09	3,49
    	280,95	0	0	 	 	281,27	864	63	11,3	ON	281,58	896	22,7	3,09	3,32
    	281,86	0	0	 	 	282,17	896	63	13,7	ON	282,46	896	21,6	3,09	3,11
    	282,77	0	0	 	 	283,06	864	63	15,6	ON	283,36	864	21,6	3,09	3,26
    	283,64	0	0	 	 	283,92	864	63	12,9	ON	284,19	864	20,4	2,06	2,87
    	284,49	0	0	 	 	284,79	832	63	10,5	ON	285,1	832	20,4	2,06	3,04
    	285,41	0	0	 	 	285,71	864	63	8,2	ON	286	864	21,6	3,09	3,32
    	286,31	0	0	 	 	286,6	864	63	10,9	ON	286,9	864	22,7	3,09	3,23
    	287,2	0	0	 	 	287,48	896	63	13,3	ON	287,78	864	21,6	3,09	3,22
    	288,08	0	0	 	 	288,36	864	63	15,6	ON	288,66	864	21,6	3,09	3,18
    	288,97	0	0	 	 	289,27	864	64,5	12,9	ON	289,57	864	20,4	2,06	2,8
    	289,85	0	0	 	 	290,14	832	64,5	10,5	ON	290,42	832	20,4	2,06	2,89
    	290,73	0	0	 	 	291,04	832	64,5	7,8	ON	291,34	832	21,6	3,09	3,23
    	291,64	0	0	 	 	291,94	864	64,5	10,5	ON	292,24	864	22,7	3,09	3,16
    	292,54	0	0	 	 	292,83	864	64,5	13,3	ON	293,13	864	21,6	3,09	3,14
    	293,44	0	0	 	 	293,72	864	64,5	16	ON	294,02	896	20,4	3,09	2,54
    	294,31	0	0	 	 	294,6	864	64,5	15,2	ON	294,92	864	20,4	3,09	2,95
    	295,22	0	0	 	 	295,51	832	64,5	12,5	ON	295,8	832	20,4	2,06	2,78
    	296,08	0	0	 	 	296,38	832	64,5	9,8	ON	296,68	832	20,4	2,06	3,02
    	296,97	0	0	 	 	297,26	832	64,5	10,5	ON	297,56	864	21,6	3,09	3,09
    	297,87	0	0	 	 	298,17	864	64,5	13,3	ON	298,48	864	21,6	3,09	3,23
    	298,76	0	0	 	 	299,04	864	64,5	16	ON	299,33	864	21,6	3,09	3,07
    	299,6	0	0	 	 	299,89	864	64,5	17,6	ON	300,18	864	20,4	3,09	2,83
    	300,47	0	0	 	 	300,77	864	64,5	14,8	ON	301,06	864	20,4	2,06	2,82
    	301,36	0	0	 	 	301,66	832	64,5	12,1	ON	301,96	832	20,4	2,06	3,06
    	302,27	0	0	 	 	302,56	832	64,5	9,8	ON	302,86	832	20,4	3,09	3,04
    	303,15	0	0	 	 	303,45	864	64,5	12,5	ON	303,76	864	21,6	3,09	3,14
    	304,04	0	0	 	 	304,34	864	64,5	15,2	ON	304,63	864	21,6	3,09	3,08
    	304,93	0	0	 	 	305,22	864	66	18	ON	305,5	864	20,4	3,09	2,95
    	305,82	0	0	 	 	306,11	864	66	15,2	ON	306,41	864	20,4	2,06	3,03
    	306,72	0	0	 	 	307,01	832	66	12,5	ON	307,3	832	20,4	2,06	2,78
    	307,62	0	0	 	 	307,92	832	66	11,3	ON	308,23	832	20,4	3,09	3,17
    	308,54	0	0	 	 	308,83	864	66	14,1	ON	309,12	864	20,4	3,09	3,09
    	309,44	0	0	 	 	309,73	864	66	16,8	ON	310,03	864	21,6	3,09	3,15
    	310,33	0	0	 	 	310,63	864	66	18,4	ON	310,91	864	19,2	2,06	2,74
    	311,2	0	0	 	 	311,5	864	66	15,6	ON	311,79	832	20,4	2,06	2,87
    	312,1	0	0	 	 	312,4	832	66	12,9	ON	312,71	832	20,4	2,06	2,95
    	313,02	0	0	 	 	313,33	832	66	10,9	ON	313,63	864	20,4	3,09	3,03
    	313,92	0	0	 	 	314,22	864	66	13,7	ON	314,51	864	20,4	3,09	3,01
    	314,8	0	0	 	 	315,11	864	66	16,4	ON	315,43	864	20,4	3,09	3,15
    	315,72	0	0	 	 	316,02	864	66	19,1	ON	316,34	896	20,4	3,09	2,83
    	316,64	0	0	 	 	316,94	864	66	17,2	ON	317,24	864	20,4	3,09	2,87
    	317,52	0	0	 	 	317,83	832	66	14,5	ON	318,12	832	20,4	2,06	2,74
    	318,4	0	0	 	 	318,68	832	66	11,7	ON	318,95	832	20,4	2,06	2,89
    	319,27	0	0	 	 	319,56	832	66	11,7	ON	319,85	832	20,4	3,09	2,91
    	320,12	0	0	 	 	320,42	864	66	14,5	ON	320,72	864	21,6	3,09	3,09
    	321,01	0	0	 	 	321,32	864	67,5	17,2	ON	321,61	864	20,4	3,09	3,06
    	321,91	0	0	 	 	322,18	864	67,5	17,6	ON	322,48	864	19,2	2,06	2,92
    	322,77	0	0	 	 	323,06	864	67,5	14,8	ON	323,37	864	19,2	2,06	2,66
    	323,65	0	0	 	 	323,96	832	67,5	12,5	ON	324,26	832	20,4	2,06	3,17
    	324,57	0	0	 	 	324,87	864	67,5	12,9	ON	325,16	864	20,4	3,09	2,89
    	325,46	0	0	 	 	325,76	864	67,5	15,6	ON	326,04	864	20,4	3,09	3,11
    	326,34	0	0	 	 	326,63	864	67,5	18,4	ON	326,91	864	20,4	3,09	3,02
    	327,21	0	0	 	 	327,51	864	67,5	18,8	ON	327,81	864	19,2	3,09	2,69
    	328,11	0	0	 	 	328,41	832	67,5	16	ON	328,71	864	19,2	2,06	2,75
    	328,97	0	0	 	 	329,27	832	67,5	13,7	ON	329,54	832	19,2	2,06	2,81
    	329,83	0	0	 	 	330,12	832	67,5	14,5	ON	330,41	864	20,4	3,09	3,01
    	330,73	0	0	 	 	331,02	864	67,5	17,2	ON	331,32	864	20,4	3,09	3,27
    	331,6	0	0	 	 	331,91	896	67,5	19,9	ON	332,2	864	19,2	3,09	2,86
    	332,48	0	0	 	 	332,78	864	67,5	18,8	ON	333,08	864	19,2	2,06	2,79
    	333,35	0	0	 	 	333,64	832	67,5	16	ON	333,95	832	19,2	2,06	2,74
    	334,21	0	0	 	 	334,51	832	67,5	14,1	ON	334,79	832	20,4	2,06	2,98
    	335,1	0	0	 	 	335,41	864	67,5	16,8	ON	335,7	864	20,4	3,09	2,92
    	336	0	0	 	 	336,28	864	67,5	19,5	ON	336,59	864	20,4	3,09	2,88
    	336,87	0	0	 	 	337,16	864	67,5	20,3	ON	337,47	864	19,2	2,06	2,92
    	337,77	0	0	 	 	338,06	864	67,5	17,6	ON	338,37	832	19,2	2,06	2,83
    	338,65	0	0	 	 	338,93	832	67,5	14,8	ON	339,21	832	19,2	2,06	2,8
    	339,5	0	0	 	 	339,78	832	67,5	12,1	ON	340,07	832	20,4	2,06	3,03
    	340,38	0	0	 	 	340,66	864	67,5	14,1	ON	340,96	864	21,6	3,09	3,22
    	341,24	0	0	 	 	341,53	896	67,5	16,8	ON	341,82	896	20,4	3,09	3,01
    	342,12	0	0	 	 	342,39	864	67,5	19,1	ON	342,7	864	19,2	3,09	2,77
    	342,99	0	0	 	 	343,28	864	69	16,4	ON	343,58	832	19,2	2,06	2,89
    	343,86	0	0	 	 	344,13	832	69	13,7	ON	344,42	832	19,2	2,06	2,72
    	344,72	0	0	 	 	345,04	832	69	14,1	ON	345,33	864	20,4	3,09	2,76
    	345,64	0	0	 	 	345,95	832	69	16,8	ON	346,21	864	20,4	3,09	2,92
    	346,53	0	0	 	 	346,83	864	69	19,5	ON	347,12	864	20,4	3,09	2,86
    	347,41	0	0	 	 	347,71	864	69	19,5	ON	348,02	864	20,4	3,09	2,83
    	348,31	0	0	 	 	348,61	864	69	16,8	ON	348,91	864	19,2	2,06	2,76
    	349,19	0	0	 	 	349,5	832	69	14,1	ON	349,8	832	20,4	2,06	3,03
    	350,11	0	0	 	 	350,4	832	69	13,7	ON	350,7	864	20,4	3,09	2,92
    	350,98	0	0	 	 	351,29	864	69	16,4	ON	351,58	864	20,4	3,09	2,96
    	351,88	0	0	 	 	352,18	864	69	19,1	ON	352,46	864	20,4	3,09	3,17
    	352,73	0	0	 	 	353,05	864	69	18,4	ON	353,36	864	19,2	2,06	2,78
    	353,64	0	0	 	 	353,95	864	69	15,6	ON	354,25	864	19,2	2,06	2,92
    	354,54	0	0	 	 	354,84	832	69	12,9	ON	355,14	832	19,2	2,06	2,78
    	355,43	0	0	 	 	355,73	832	69	14,1	ON	356,03	864	20,4	3,09	3,04
    	356,34	0	0	 	 	356,62	864	69	16,8	ON	356,92	864	20,4	3,09	3,08
    	357,19	0	0	 	 	357,48	896	69	19,5	ON	357,77	864	19,2	2,06	2,74
    	358,07	0	0	 	 	358,34	832	69	16,8	ON	358,63	864	19,2	2,06	2,86
    	358,92	0	0	 	 	359,19	832	69	14,5	ON	359,49	832	19,2	2,06	2,79
    	359,78	0	0	 	 	360,06	832	69	11,7	ON	360,37	832	20,4	2,06	2,89
    	360,67	0	0	 	 	360,96	864	69	13,7	ON	361,23	864	20,4	3,09	2,93
    	361,52	0	0	 	 	361,81	864	69	16	ON	362,12	864	20,4	3,09	2,97
    	362,42	0	0	 	 	362,71	896	69	18,8	ON	363,01	864	20,4	3,09	2,86
    	363,32	0	0	 	 	363,61	864	70,5	17,6	ON	363,91	864	19,2	2,06	2,58
    	364,19	0	0	 	 	364,48	832	70,5	14,8	ON	364,77	832	19,2	2,06	2,67
    	365,07	0	0	 	 	365,38	832	70,5	12,1	ON	365,66	832	19,2	2,06	2,92
    	365,95	0	0	 	 	366,26	832	70,5	13,7	ON	366,58	864	21,6	3,09	3,17
    	366,89	0	0	 	 	367,18	864	70,5	16,4	ON	367,47	896	20,4	3,09	3,11
    	367,78	0	0	 	 	368,08	896	70,5	18,4	ON	368,39	864	19,2	2,06	2,72
    	368,69	0	0	 	 	368,99	864	70,5	15,6	ON	369,28	832	19,2	2,06	2,74
    	369,56	0	0	 	 	369,86	832	70,5	12,9	ON	370,17	832	19,2	2,06	2,92
    	370,47	0	0	 	 	370,77	832	70,5	12,1	ON	371,08	864	20,4	2,06	2,98
    	371,39	0	0	 	 	371,67	832	70,5	14,8	ON	371,96	864	20,4	3,09	3,16
    	372,27	0	0	 	 	372,56	864	70,5	17,6	ON	372,86	864	20,4	3,09	2,93
    	373,17	0	0	 	 	373,47	864	70,5	18,4	ON	373,75	864	20,4	3,09	2,86
    	374,05	0	0	 	 	374,34	864	70,5	15,6	ON	374,65	864	19,2	2,06	2,91
    	374,94	0	0	 	 	375,24	832	70,5	12,9	ON	375,54	832	19,2	2,06	2,56
    	375,82	0	0	 	 	376,12	832	70,5	13,7	ON	376,42	832	19,2	2,06	2,84
    	376,71	0	0	 	 	377,02	864	70,5	16,4	ON	377,33	864	20,4	3,09	2,75
    	377,61	0	0	 	 	377,9	864	70,5	19,1	ON	378,19	864	20,4	3,09	2,82
    	378,51	0	0	 	 	378,8	864	70,5	16,8	ON	379,09	864	19,2	2,06	2,59
    	379,36	0	0	 	 	379,66	832	70,5	14,1	ON	379,97	832	19,2	2,06	2,84
    	380,26	0	0	 	 	380,56	832	70,5	12,9	ON	380,85	832	20,4	3,09	3,24
    	381,16	0	0	 	 	381,46	864	70,5	15,6	ON	381,75	864	20,4	3,09	2,98
    	382,05	0	0	 	 	382,36	864	70,5	18,4	ON	382,66	864	20,4	3,09	2,96
    	382,97	0	0	 	 	383,27	864	70,5	16,4	ON	383,56	832	19,2	2,06	2,76
    	383,85	0	0	 	 	384,13	832	70,5	13,7	ON	384,42	832	19,2	2,06	2,8
    	384,72	0	0	 	 	385	832	72	12,1	ON	385,3	832	20,4	2,06	2,87
    	385,6	0	0	 	 	385,9	832	72	14,8	ON	386,17	832	19,2	2,06	2,8
    	386,47	0	0	 	 	386,75	832	72	17,6	ON	387,05	864	19,2	3,09	2,78
    	387,35	0	0	 	 	387,65	864	72	20,3	ON	387,95	864	19,2	3,09	3,03
    	388,26	0	0	 	 	388,56	864	72	17,6	ON	388,86	864	19,2	2,06	3,03
    	389,16	0	0	 	 	389,44	864	72	14,8	ON	389,75	832	19,2	2,06	2,83
    	390,04	0	0	 	 	390,33	832	72	16	ON	390,63	864	19,2	2,06	2,62
    	390,94	0	0	 	 	391,21	864	72	18,8	ON	391,51	832	19,2	2,06	2,72
    	391,78	0	0	 	 	392,08	864	72	19,1	ON	392,38	864	19,2	2,06	2,74
    	392,68	0	0	 	 	392,98	864	72	16,4	ON	393,29	832	19,2	2,06	2,8
    	393,58	0	0	 	 	393,87	864	72	13,7	ON	394,18	864	19,2	2,06	2,83
    	394,48	0	0	 	 	394,77	832	72	16	ON	395,06	864	19,2	2,06	2,77
    	395,35	0	0	 	 	395,66	864	72	18,8	ON	395,97	864	19,2	3,09	2,93
    	396,25	0	0	 	 	396,55	864	72	19,5	ON	396,84	864	19,2	2,06	2,97
    	397,13	0	0	 	 	397,43	864	72	16,8	ON	397,71	864	19,2	2,06	2,5
    	398,01	0	0	 	 	398,3	832	72	14,1	ON	398,61	832	19,2	2,06	2,63
    	398,9	0	0	 	 	399,19	832	72	11,3	ON	399,49	832	19,2	2,06	2,93
    	399,78	0	0	 	 	400,07	832	72	13,7	ON	400,38	864	19,2	2,06	2,86
    	400,67	0	0	 	 	400,97	864	72	16,4	ON	401,28	864	19,2	3,09	2,89
    	401,58	0	0	 	 	401,87	864	72	19,1	ON	402,16	864	19,2	3,09	2,95
    	402,45	0	0	 	 	402,75	864	72	20,7	ON	403,04	864	19,2	2,06	2,73
    	403,33	0	0	 	 	403,62	864	72	18	ON	403,92	864	18,4	2,06	2,4
    	404,2	0	0	 	 	404,51	832	73,5	15,6	ON	404,8	832	18,4	2,06	2,52
    	405,09	0	0	 	 	405,4	832	73,5	12,9	ON	405,71	832	18,4	2,06	2,48
    	406	0	0	 	 	406,3	832	73,5	10,2	ON	406,59	832	19,2	2,06	2,89
    	406,88	0	0	 	 	407,19	832	73,5	10,5	ON	407,49	864	21,6	3,09	3,03
    	407,78	0	0	 	 	408,07	864	73,5	13,3	ON	408,36	864	20,4	3,09	3,16
    	408,66	0	0	 	 	408,96	864	73,5	16	ON	409,25	896	19,2	2,06	2,61
    	409,55	0	0	 	 	409,86	864	73,5	18,8	ON	410,16	864	19,2	2,06	2,8
    	410,46	0	0	 	 	410,75	864	73,5	19,5	ON	411,06	864	18,4	2,06	2,61
    	411,35	0	0	 	 	411,64	832	73,5	16,8	ON	411,94	832	19,2	2,06	2,55
    	412,24	0	0	 	 	412,53	864	73,5	14,1	ON	412,83	832	19,2	2,06	2,73
    	413,12	0	0	 	 	413,44	832	73,5	11,3	ON	413,75	832	20,4	2,06	3,09
    	414,04	0	0	 	 	414,34	832	73,5	12,5	ON	414,64	864	20,4	2,06	2,96
    	414,92	0	0	 	 	415,21	864	73,5	15,2	ON	415,52	864	20,4	2,06	2,88
    	415,79	0	0	 	 	416,1	864	73,5	17,6	ON	416,39	896	20,4	3,09	2,92
    	416,69	0	0	 	 	416,97	864	73,5	20,3	ON	417,24	864	19,2	2,06	2,77
    	417,54	0	0	 	 	417,85	832	73,5	18,8	ON	418,15	864	18,4	2,06	2,41
    	418,44	0	0	 	 	418,73	832	73,5	16	ON	419	832	18,4	2,06	2,51
    	419,32	0	0	 	 	419,61	832	73,5	13,3	ON	419,93	832	18,4	2,06	2,76
    	420,24	0	0	 	 	420,54	832	73,5	10,5	ON	420,82	832	19,2	2,06	2,83
    	421,1	0	0	 	 	421,37	864	73,5	12,5	ON	421,67	864	19,2	2,06	2,99
    	421,97	0	0	 	 	422,27	864	73,5	15,2	ON	422,54	864	19,2	2,06	2,89
    	422,84	0	0	 	 	423,12	864	73,5	18	ON	423,43	832	19,2	2,06	2,8
    	423,74	0	0	 	 	424,03	864	73,5	20,7	ON	424,32	864	19,2	3,09	2,71
    	424,62	0	0	 	 	424,92	864	73,5	19,1	ON	425,22	864	19,2	2,06	2,64
    	425,51	0	0	 	 	425,8	864	75	16,4	ON	426,1	864	18,4	2,06	2,71
    	426,39	0	0	 	 	426,68	832	75	14,1	ON	426,98	832	18,4	2,06	2,52
    	427,28	0	0	 	 	427,56	832	75	12,9	ON	427,83	832	19,2	2,06	2,69
    	428,14	0	0	 	 	428,44	832	75	15,6	ON	428,75	832	20,4	3,09	3,02
    	429,05	0	0	 	 	429,36	864	75	18,4	ON	429,66	864	19,2	3,09	2,94
    	429,96	0	0	 	 	430,25	864	75	19,9	ON	430,56	864	19,2	2,06	2,72
    	430,86	0	0	 	 	431,16	864	75	17,2	ON	431,47	832	18,4	2,06	2,59
    	431,77	0	0	 	 	432,06	832	75	14,5	ON	432,38	832	18,4	2,06	2,43
    	432,67	0	0	 	 	432,96	832	75	12,1	ON	433,25	832	19,2	2,06	3,09
    	433,54	0	0	 	 	433,82	832	75	14,5	ON	434,11	832	19,2	2,06	2,84
    	434,39	0	0	 	 	434,69	832	75	17,2	ON	434,99	864	19,2	3,09	2,69
    	435,29	0	0	 	 	435,59	864	75	19,9	ON	435,89	864	19,2	2,06	2,78
    	436,17	0	0	 	 	436,46	864	75	20,7	ON	436,75	864	18,4	2,06	2,64
    	437,04	0	0	 	 	437,33	832	75	18	ON	437,63	832	18,4	2,06	2,46
    	437,94	0	0	 	 	438,24	832	75	15,2	ON	438,54	832	18,4	2,06	2,66
    	438,82	0	0	 	 	439,13	832	75	12,5	ON	439,43	832	18,4	2,06	2,8
    	439,72	0	0	 	 	440,02	832	75	12,5	ON	440,32	832	20,4	2,06	3,11
    	440,61	0	0	 	 	440,9	864	75	14,8	ON	441,2	864	20,4	2,06	3,03
    	441,51	0	0	 	 	441,81	864	75	17,6	ON	442,12	864	19,2	2,06	2,8
    	442,42	0	0	 	 	442,74	864	75	20,7	ON	443,05	864	18,4	2,06	2,71
    	443,34	0	0	 	 	443,64	864	75	19,1	ON	443,94	832	18,4	2,06	2,57
    	444,22	0	0	 	 	444,51	832	75	16,4	ON	444,81	832	18,4	2,06	2,56
    	445,09	0	0	 	 	445,39	832	75	13,7	ON	445,69	832	19,2	2,06	3,09
    	445,99	0	0	 	 	446,29	864	75	12,9	ON	446,56	864	19,2	2,06	2,92
    	446,86	0	0	 	 	447,16	864	75	15,6	ON	447,46	864	20,4	2,06	3,15
    	447,76	0	0	 	 	448,04	864	75	18	ON	448,32	864	19,2	2,06	2,89
    	448,62	0	0	 	 	448,92	864	76,5	20,7	ON	449,22	864	19,2	2,06	2,61
    	449,52	0	0	 	 	449,83	864	76,5	19,5	ON	450,13	864	18,4	2,06	2,52
    	450,43	0	0	 	 	450,73	832	76,5	16,8	ON	450,99	832	18,4	2,06	2,43
    	451,29	0	0	 	 	451,58	832	76,5	14,5	ON	451,87	832	19,2	2,06	3,39
    	452,18	0	0	 	 	452,48	864	76,5	13,3	ON	452,79	864	19,2	2,06	2,91
    	453,09	0	0	 	 	453,39	864	76,5	16	ON	453,69	864	19,2	2,06	3,06
    	453,98	0	0	 	 	454,28	864	76,5	18,8	ON	454,58	864	19,2	2,06	2,95
    	454,87	0	0	 	 	455,16	864	76,5	21,5	ON	455,45	864	18,4	2,06	2,61
    	455,74	0	0	 	 	456,03	864	76,5	20,7	ON	456,32	864	18,4	2,06	2,36
    	456,63	0	0	 	 	456,94	864	76,5	18	ON	457,24	832	18,4	2,06	2,35
    	457,54	0	0	 	 	457,83	832	76,5	15,2	ON	458,11	832	18,4	2,06	2,63
    	458,41	0	0	 	 	458,72	832	76,5	12,9	ON	459	832	19,2	2,06	2,58
    	459,3	0	0	 	 	459,61	864	76,5	14,5	ON	459,91	832	19,2	2,06	2,83
    	460,21	0	0	 	 	460,51	832	76,5	17,2	ON	460,8	864	19,2	2,06	2,83
    	461,11	0	0	 	 	461,42	864	76,5	19,9	ON	461,73	864	18,4	2,06	2,83
    	462,05	0	0	 	 	462,36	864	76,5	22,7	ON	462,66	864	18,4	2,06	3,01
    	462,95	0	0	 	 	463,26	864	76,5	21,9	ON	463,55	864	18,4	2,06	2,4
    	463,85	0	0	 	 	464,16	864	76,5	19,1	ON	464,44	832	18,4	2,06	2,57
    	464,73	0	0	 	 	465,04	832	76,5	16,4	ON	465,34	832	18,4	2,06	2,68
    	465,64	0	0	 	 	465,94	832	76,5	13,7	ON	466,24	832	18,4	2,06	2,63
    	466,54	0	0	 	 	466,84	832	76,5	14,1	ON	467,15	832	19,2	2,06	2,81
    	467,45	0	0	 	 	467,75	832	76,5	16,8	ON	468,04	864	19,2	2,06	2,77
    	468,33	0	0	 	 	468,62	864	76,5	19,5	ON	468,92	864	19,2	2,06	2,69
    	469,21	0	0	 	 	469,5	864	76,5	21,5	ON	469,79	864	18,4	2,06	2,56
    	470,08	0	0	 	 	470,38	864	76,5	18,8	ON	470,67	832	18,4	2,06	2,62
    	470,99	0	0	 	 	471,29	832	76,5	16	ON	471,56	832	18,4	2,06	2,69
    	471,87	0	0	 	 	472,17	832	76,5	13,3	ON	472,45	832	18,4	2,06	2,81
    	472,75	0	0	 	 	473,04	832	76,5	15,6	ON	473,34	864	19,2	2,06	2,83
    	473,66	0	0	 	 	473,96	864	76,5	18,4	ON	474,27	864	19,2	3,09	3,17
    	474,56	0	0	 	 	474,86	864	78	21,5	ON	475,16	864	19,2	3,09	2,77
    	475,44	0	0	 	 	475,73	864	76,5	22,3	ON	476,03	864	18,4	2,06	2,58
    	476,33	0	0	 	 	476,63	832	78	19,5	ON	476,92	864	18,4	2,06	2,39
    	477,22	0	0	 	 	477,51	832	78	16,8	ON	477,8	832	18,4	2,06	2,53
    	478,11	0	0	 	 	478,41	832	78	14,1	ON	478,71	832	19,2	2,06	2,61
    	479,01	0	0	 	 	479,29	832	78	14,1	ON	479,58	832	19,2	2,06	2,97
    	479,88	0	0	 	 	480,16	864	78	16,8	ON	480,45	864	19,2	2,06	2,93
    	480,74	0	0	 	 	481,05	864	78	19,5	ON	481,35	864	19,2	2,06	2,81
    	481,66	0	0	 	 	481,94	864	78	22,3	ON	482,25	864	18,4	2,06	2,5
    	482,56	0	0	 	 	482,86	864	78	21,5	ON	483,15	864	18,4	2,06	2,55
    	483,44	0	0	 	 	483,74	864	78	18,8	ON	484,04	832	17,3	2,06	2,42
    	484,34	0	0	 	 	484,64	800	78	16	ON	484,93	832	18,4	2,06	2,69
    	485,24	0	0	 	 	485,52	832	78	13,3	ON	485,84	832	19,2	2,06	2,74
    	486,13	0	0	 	 	486,44	864	78	15,6	ON	486,76	832	19,2	2,06	2,78
    	487,06	0	0	 	 	487,36	864	78	18,4	ON	487,65	864	19,2	2,06	2,81
    	487,94	0	0	 	 	488,24	864	78	21,1	ON	488,53	864	18,4	2,06	2,79
    	488,83	0	0	 	 	489,13	864	78	22,3	ON	489,43	864	18,4	2,06	2,5
    	489,71	0	0	 	 	490	864	78	19,5	ON	490,3	864	18,4	2,06	2,58
    	490,61	0	0	 	 	490,9	832	78	16,8	ON	491,2	832	17,3	2,06	2,53
    	491,5	0	0	 	 	491,8	832	78	14,1	ON	492,09	832	18,4	2,06	2,86
    	492,4	0	0	 	 	492,7	864	78	14,1	ON	493,01	864	19,2	2,06	2,72
    	493,31	0	0	 	 	493,61	864	78	16,8	ON	493,9	864	19,2	2,06	2,76
    	494,2	0	0	 	 	494,51	864	78	19,5	ON	494,8	864	19,2	2,06	2,76
    	495,09	0	0	 	 	495,38	864	78	21,5	ON	495,67	864	18,4	2,06	2,6
    	495,98	0	0	 	 	496,27	864	78	18,8	ON	496,57	864	18,4	2,06	2,41
    	496,87	0	0	 	 	497,17	832	78	16	ON	497,47	832	18,4	2,06	2,66
    	497,78	0	0	 	 	498,06	832	78	13,3	ON	498,36	832	18,4	2,06	2,96
    	498,64	0	0	 	 	498,94	832	78	13,7	ON	499,24	832	19,2	2,06	2,88
    	499,54	0	0	 	 	499,84	864	78	16,4	ON	500,13	864	19,2	2,06	3,06
    	500,41	0	0	 	 	500,7	864	78	19,1	ON	501,01	864	19,2	2,06	2,76
    	501,31	0	0	 	 	501,6	864	78	21,9	ON	501,9	864	18,4	2,06	2,69
    	502,2	0	0	 	 	502,5	864	78	20,7	ON	502,81	864	18,4	2,06	2,53
    	503,11	0	0	 	 	503,39	832	78	18	ON	503,68	832	18,4	2,06	2,51
    	503,98	0	0	 	 	504,28	832	78	15,2	ON	504,57	832	18,4	2,06	2,63
    	504,88	0	0	 	 	505,19	832	78	12,5	ON	505,47	832	19,2	2,06	2,92
    	505,76	0	0	 	 	506,06	864	78	13,7	ON	506,36	864	19,2	2,06	3,03
    	506,64	0	0	 	 	506,93	864	78	16	ON	507,23	864	20,4	3,09	3,09
    	507,53	0	0	 	 	507,82	896	78	18,8	ON	508,12	896	18,4	2,06	2,72
    	508,39	0	0	 	 	508,68	864	78	21,5	ON	508,97	864	18,4	2,06	2,55
    	509,27	0	0	 	 	509,57	864	78	21,1	ON	509,87	832	17,3	2,06	2,56
    	510,17	0	0	 	 	510,47	832	78	18,4	ON	510,76	832	17,3	2,06	2,36
    	511,04	0	0	 	 	511,36	832	78	15,6	ON	511,64	832	18,4	2,06	2,52
    	511,95	0	0	 	 	512,24	832	78	12,9	ON	512,53	832	18,4	2,06	2,76
    	512,82	0	0	 	 	513,1	864	78	15,2	ON	513,4	832	19,2	2,06	2,83
    	513,72	0	0	 	 	514,01	864	78	18	ON	514,3	864	19,2	2,06	2,8
    	514,59	0	0	 	 	514,88	864	78	20,7	ON	515,17	864	18,4	2,06	2,67
    	515,45	0	0	 	 	515,77	864	78	23	ON	516,06	864	18,4	2,06	2,61
    	516,34	0	0	 	 	516,65	864	78	20,7	ON	516,95	864	18,4	2,06	2,51
    	517,26	0	0	 	 	517,55	832	78	18	ON	517,84	832	17,3	2,06	2,46
    	518,13	0	0	 	 	518,42	832	78	15,2	ON	518,7	832	18,4	2,06	2,71
    	518,99	0	0	 	 	519,28	832	79,5	14,5	ON	519,58	864	19,2	2,06	2,74
    	519,89	0	0	 	 	520,2	864	79,5	17,2	ON	520,49	864	19,2	2,06	2,79
    	520,81	0	0	 	 	521,1	864	78	20,3	ON	521,37	864	19,2	2,06	2,76
    	521,69	0	0	 	 	522	864	78	22,3	ON	522,3	864	18,4	2,06	2,55
    	522,61	0	0	 	 	522,91	864	79,5	19,5	ON	523,21	832	17,3	2,06	2,27
    	523,5	0	0	 	 	523,78	800	79,5	16,8	ON	524,08	832	18,4	2,06	2,69
    	524,36	0	0	 	 	524,65	832	79,5	14,1	ON	524,94	832	19,2	2,06	2,77
    	525,22	0	0	 	 	525,52	864	79,5	14,8	ON	525,81	832	19,2	2,06	2,74
    	526,11	0	0	 	 	526,39	864	79,5	17,6	ON	526,7	832	18,4	2,06	2,86
    	527,01	0	0	 	 	527,32	864	79,5	20,3	ON	527,63	864	19,2	2,06	2,69
    	527,93	0	0	 	 	528,23	864	79,5	23	ON	528,53	864	18,4	2,06	2,68
    	528,82	0	0	 	 	529,12	864	79,5	20,7	ON	529,41	864	18,4	2,06	2,35
    	529,7	0	0	 	 	529,97	832	79,5	18	ON	530,28	832	18,4	2,06	2,47
    	530,56	0	0	 	 	530,87	832	79,5	15,2	ON	531,16	832	17,3	2,06	2,44
    	531,44	0	0	 	 	531,71	832	79,5	12,9	ON	532	832	18,4	2,06	2,66
    	532,29	0	0	 	 	532,61	832	79,5	15,6	ON	532,9	864	19,2	2,06	2,8
    	533,2	0	0	 	 	533,48	864	79,5	18,4	ON	533,79	864	19,2	2,06	2,93
    	534,08	0	0	 	 	534,37	864	79,5	21,1	ON	534,67	864	18,4	2,06	2,66
    	534,97	0	0	 	 	535,26	864	79,5	21,1	ON	535,55	864	18,4	2,06	2,38
    	535,85	0	0	 	 	536,16	832	79,5	18,4	ON	536,47	832	18,4	2,06	2,61
    	536,76	0	0	 	 	537,07	832	79,5	15,6	ON	537,37	832	18,4	2,06	2,74
    	537,65	0	0	 	 	537,96	832	79,5	14,1	ON	538,25	832	18,4	2,06	2,66
    	538,55	0	0	 	 	538,84	832	79,5	16,8	ON	539,13	864	18,4	2,06	2,54
    	539,44	0	0	 	 	539,74	864	79,5	19,5	ON	540,04	864	18,4	2,06	2,63
    	540,33	0	0	 	 	540,63	864	79,5	22,3	ON	540,92	864	18,4	2,06	2,61
    	541,23	0	0	 	 	541,54	864	79,5	21,9	ON	541,85	864	18,4	2,06	2,38
    	542,14	0	0	 	 	542,45	832	79,5	19,1	ON	542,73	832	17,3	2,06	2,46
    	543	0	0	 	 	543,28	832	79,5	16,8	ON	543,58	832	18,4	2,06	2,49
    	543,87	0	0	 	 	544,16	832	79,5	14,1	ON	544,44	832	18,4	2,06	2,54
    	544,74	0	0	 	 	545,03	832	79,5	16,8	ON	545,33	864	18,4	2,06	2,62
    	545,62	0	0	 	 	545,91	864	79,5	19,5	ON	546,21	864	18,4	2,06	2,66
    	546,5	0	0	 	 	546,79	864	79,5	22,3	ON	547,08	864	18,4	2,06	2,72
    	547,37	0	0	 	 	547,67	864	79,5	21,9	ON	547,96	864	18,4	2,06	2,48
    	548,26	0	0	 	 	548,54	864	79,5	19,1	ON	548,83	832	17,3	2,06	2,41
    	549,13	0	0	 	 	549,42	832	79,5	16,8	ON	549,72	832	17,3	2,06	2,37
    	550,02	0	0	 	 	550,31	832	79,5	14,5	ON	550,6	864	18,4	2,06	2,78
    	550,9	0	0	 	 	551,18	832	79,5	17,2	ON	551,48	864	18,4	2,06	2,8
    	551,8	0	0	 	 	552,1	864	79,5	19,9	ON	552,39	864	18,4	2,06	2,75
    	552,7	0	0	 	 	552,99	864	79,5	22,7	ON	553,27	864	18,4	2,06	2,52
    	553,56	0	0	 	 	553,86	864	79,5	21,9	ON	554,17	864	17,3	2,06	2,52
    	554,46	0	0	 	 	554,76	832	79,5	18,8	ON	555,06	832	16,1	2,06	2,24
    	555,36	0	0	 	 	555,65	832	79,5	16,4	ON	555,95	832	18,4	2,06	2,83
    	556,24	0	0	 	 	556,53	832	79,5	14,8	ON	556,82	864	18,4	2,06	2,52
    	557,11	0	0	 	 	557,39	864	79,5	17,6	ON	557,69	832	18,4	2,06	2,73
    	557,98	0	0	 	 	558,27	864	79,5	20,3	ON	558,58	864	18,4	2,06	2,8
    	558,86	0	0	 	 	559,17	864	79,5	23	ON	559,48	864	18,4	2,06	2,63
    	559,77	0	0	 	 	560,07	864	79,5	21,5	ON	560,36	832	17,3	2,06	2,38
    	560,65	0	0	 	 	560,95	832	79,5	18,8	ON	561,24	832	17,3	2,06	2,34
    	561,53	0	0	 	 	561,81	800	79,5	16	ON	562,11	832	18,4	2,06	2,75
    	562,41	0	0	 	 	562,71	864	79,5	17,2	ON	563,01	832	18,4	2,06	2,76
    	563,31	0	0	 	 	563,61	864	79,5	19,9	ON	563,91	864	18,4	2,06	2,49
    	564,2	0	0	 	 	564,48	864	79,5	22,7	ON	564,77	864	18,4	2,06	2,56
    	565,07	0	0	 	 	565,37	864	79,5	21,9	ON	565,67	832	17,3	2,06	2,48
    	565,97	0	0	 	 	566,26	832	79,5	19,1	ON	566,57	800	17,3	2,06	2,54
    	566,87	0	0	 	 	567,17	832	79,5	16,4	ON	567,44	800	17,3	2,06	2,46
    	567,74	0	0	 	 	568,04	864	79,5	18,8	ON	568,34	864	18,4	2,06	2,79
    	568,63	0	0	 	 	568,92	864	79,5	21,5	ON	569,23	864	18,4	2,06	2,61
    	569,52	0	0	 	 	569,81	864	79,5	24,2	ON	570,1	864	18,4	2,06	2,56
    	570,39	0	0	 	 	570,68	864	81	23	ON	570,96	864	17,3	2,06	2,69
    	571,23	0	0	 	 	571,53	832	79,5	20,7	ON	571,83	832	17,3	2,06	2,24
    	572,14	0	0	 	 	572,45	832	81	18	ON	572,74	800	17,3	2,06	2,89
    	573,01	0	0	 	 	573,32	832	81	15,6	ON	573,63	864	18,4	2,06	2,56
    	573,92	0	0	 	 	574,22	864	81	18,4	ON	574,5	864	18,4	2,06	2,71
    	574,81	0	0	 	 	575,11	864	81	21,1	ON	575,38	864	18,4	2,06	2,75
    	575,71	0	0	 	 	576,01	864	81	22,7	ON	576,29	864	17,3	2,06	2,75
    	576,59	0	0	 	 	576,87	864	81	19,9	ON	577,16	832	17,3	2,06	2,43
    	577,45	0	0	 	 	577,74	832	81	17,2	ON	578,02	832	17,3	2,06	2,53
    	578,33	0	0	 	 	578,63	832	81	16	ON	578,91	832	18,4	2,06	2,61
    	579,2	0	0	 	 	579,51	832	81	18,8	ON	579,79	864	18,4	2,06	2,62
    	580,09	0	0	 	 	580,41	864	81	21,5	ON	580,71	864	18,4	2,06	2,57
    	581	0	0	 	 	581,3	864	81	23,4	ON	581,59	864	18,4	2,06	2,61
    	581,87	0	0	 	 	582,17	864	81	20,7	ON	582,47	832	17,3	2,06	2,52
    	582,78	0	0	 	 	583,07	832	81	18	ON	583,38	832	17,3	2,06	2,39
    	583,68	0	0	 	 	583,99	800	81	15,6	ON	584,3	832	18,4	2,06	3,06
    	584,59	0	0	 	 	584,87	832	81	18,4	ON	585,18	864	18,4	2,06	2,54
    	585,49	0	0	 	 	585,8	864	81	21,1	ON	586,11	864	18,4	2,06	2,69
    	586,4	0	0	 	 	586,68	864	81	22,7	ON	587	864	17,3	2,06	2,38
    	587,29	0	0	 	 	587,59	864	81	19,9	ON	587,87	832	17,3	2,06	2,46
    	588,16	0	0	 	 	588,46	800	81	17,2	ON	588,75	832	17,3	2,06	2,51
    	589,04	0	0	 	 	589,34	832	81	18	ON	589,62	832	18,4	2,06	2,64
    	589,9	0	0	 	 	590,16	864	81	20,7	ON	590,47	864	18,4	2,06	2,64
    	590,77	0	0	 	 	591,07	864	81	23,4	ON	591,38	864	17,3	2,06	2,69
    	591,68	0	0	 	 	591,97	864	81	21,5	ON	592,26	864	17,3	2,06	2,64
    	592,55	0	0	 	 	592,86	864	81	18,8	ON	593,14	864	17,3	2,06	2,31
    	593,41	0	0	 	 	593,7	832	81	16	ON	594	832	17,3	2,06	2,72
    	594,27	0	0	 	 	594,58	832	81	15,6	ON	594,89	832	18,4	2,06	2,6
    	595,18	0	0	 	 	595,49	864	81	18,4	ON	595,77	864	18,4	2,06	2,8
    	596,08	0	0	 	 	596,39	864	81	21,5	ON	596,68	864	18,4	2,06	2,62
    	596,98	0	0	 	 	597,29	864	81	21,5	ON	597,62	864	18,4	2,06	2,83
    	597,91	0	0	 	 	598,21	832	81	18,4	ON	598,5	832	17,3	2,06	2,53
    	598,78	0	0	 	 	599,06	832	81	15,6	ON	599,35	832	17,3	2,06	2,44
    	599,65	0	0	 	 	599,94	832	81	16,8	ON	600,23	832	18,4	2,06	2,55
    	600,54	0	0	 	 	600,83	864	81	19,5	ON	601,13	832	18,4	2,06	2,58
    	601,43	0	0	 	 	601,72	864	81	22,3	ON	602	864	18,4	2,06	2,64
    	602,32	0	0	 	 	602,63	864	81	21,9	ON	602,92	864	18,4	2,06	2,6
    	603,23	0	0	 	 	603,51	832	81	19,1	ON	603,8	832	17,3	2,06	2,36
    	604,08	0	0	 	 	604,38	832	81	16,8	ON	604,68	832	17,3	2,06	2,59
    	604,97	0	0	 	 	605,26	832	81	16	ON	605,58	832	18,4	2,06	2,54
    	605,87	0	0	 	 	606,16	832	81	18,8	ON	606,45	832	18,4	2,06	2,81
    	606,76	0	0	 	 	607,06	864	81	21,5	ON	607,35	864	18,4	2,06	2,75
    	607,65	0	0	 	 	607,93	864	81	20,7	ON	608,23	864	18,4	2,06	2,53
    	608,52	0	0	 	 	608,83	832	81	18,4	ON	609,12	832	18,4	2,06	2,53
    	609,41	0	0	 	 	609,7	832	81	15,6	ON	610,01	832	17,3	2,06	2,37
    	610,31	0	0	 	 	610,61	832	81	15,6	ON	610,9	832	18,4	2,06	2,69
    	611,17	0	0	 	 	611,48	864	81	18	ON	611,78	864	18,4	2,06	2,61
    	612,1	0	0	 	 	612,38	864	81	21,1	ON	612,69	864	18,4	2,06	2,46
    	612,98	0	0	 	 	613,28	864	81	19,5	ON	613,56	864	17,3	2,06	2,42
    	613,84	0	0	 	 	614,15	832	81	16,8	ON	614,44	800	17,3	2,06	2,51
    	614,75	0	0	 	 	615,03	832	81	14,8	ON	615,33	832	19,2	2,06	2,75
    	615,61	0	0	 	 	615,91	864	81	17,6	ON	616,22	864	18,4	2,06	2,79
    	616,51	0	0	 	 	616,81	864	81	19,9	ON	617,11	864	18,4	2,06	2,57
    	617,4	0	0	 	 	617,68	864	81	21,9	ON	617,99	864	17,3	2,06	2,59
    	618,28	0	0	 	 	618,58	864	81	19,1	ON	618,86	832	17,3	2,06	2,32
    	619,16	0	0	 	 	619,46	832	81	16,4	ON	619,77	832	17,3	2,06	2,41
    	620,06	0	0	 	 	620,35	832	81	13,7	ON	620,64	864	18,4	2,06	2,67
    	620,94	0	0	 	 	621,24	832	81	15,6	ON	621,52	832	19,2	2,06	2,88
    	621,81	0	0	 	 	622,1	864	81	18,4	ON	622,39	864	18,4	2,06	2,73
    	622,69	0	0	 	 	623	864	81	21,1	ON	623,31	864	18,4	2,06	2,58
    	623,6	0	0	 	 	623,87	864	81	19,9	ON	624,2	864	17,3	2,06	2,41
    	624,48	0	0	 	 	624,78	832	81	16,8	ON	625,07	832	17,3	2,06	2,61
    	625,36	0	0	 	 	625,63	832	81	15,2	ON	625,92	832	18,4	2,06	2,61
    	626,23	0	0	 	 	626,53	864	81	18	ON	626,82	864	18,4	2,06	2,55
    	627,14	0	0	 	 	627,44	864	81	20,7	ON	627,73	864	18,4	2,06	2,61
    	628,04	0	0	 	 	628,35	864	81	20,3	ON	628,64	864	18,4	2,06	2,66
    	628,93	0	0	 	 	629,24	864	82,5	17,6	ON	629,54	864	18,4	2,06	2,66
    	629,8	0	0	 	 	630,1	832	82,5	14,8	ON	630,39	832	17,3	2,06	2,49
    	630,7	0	0	 	 	630,99	832	81	15,2	ON	631,3	832	19,2	2,06	2,64
    	631,6	0	0	 	 	631,89	864	81	18	ON	632,22	864	18,4	2,06	2,58
    	632,52	0	0	 	 	632,81	864	82,5	21,1	ON	633,13	864	18,4	2,06	2,74
    	633,43	0	0	 	 	633,71	864	81	19,9	ON	634,01	864	17,3	2,06	2,53
    	634,31	0	0	 	 	634,6	832	82,5	17,2	ON	634,91	832	17,3	2,06	2,52
    	635,23	0	0	 	 	635,52	832	82,5	14,8	ON	635,81	832	17,3	2,06	2,44
    	636,13	0	0	 	 	636,42	832	82,5	17,6	ON	636,72	864	18,4	2,06	2,66
    	637,02	0	0	 	 	637,3	864	82,5	20,3	ON	637,58	864	18,4	2,06	2,58
    	637,87	0	0	 	 	638,15	864	82,5	21,9	ON	638,46	864	18,4	2,06	2,75
    	638,77	0	0	 	 	639,08	864	82,5	18,8	ON	639,38	832	17,3	2,06	2,27
    	639,67	0	0	 	 	639,97	832	82,5	16	ON	640,28	832	17,3	2,06	2,66
    	640,57	0	0	 	 	640,84	832	82,5	16,8	ON	641,13	832	18,4	2,06	2,71
    	641,43	0	0	 	 	641,72	832	82,5	19,5	ON	642,01	832	18,4	2,06	2,39
    	642,3	0	0	 	 	642,59	864	82,5	22,3	ON	642,87	864	18,4	2,06	2,58
    	643,16	0	0	 	 	643,45	832	82,5	20,7	ON	643,76	832	18,4	2,06	2,42
    	644,06	0	0	 	 	644,36	864	82,5	18	ON	644,65	832	17,3	2,06	2,54
    	644,97	0	0	 	 	645,28	832	82,5	15,2	ON	645,58	832	18,4	2,06	2,69
    	645,88	0	0	 	 	646,17	832	82,5	16,8	ON	646,47	864	18,4	2,06	2,61
    	646,75	0	0	 	 	647,05	864	82,5	19,1	ON	647,32	832	18,4	2,06	2,57
    	647,62	0	0	 	 	647,92	864	82,5	21,9	ON	648,22	864	18,4	2,06	2,62
    	648,51	0	0	 	 	648,79	864	82,5	19,5	ON	649,1	864	18,4	2,06	2,53
    	649,41	0	0	 	 	649,71	832	82,5	16,8	ON	650,01	832	17,3	2,06	2,42
    	650,29	0	0	 	 	650,58	832	82,5	14,1	ON	650,89	832	18,4	2,06	2,67
    	651,2	0	0	 	 	651,5	832	82,5	16,8	ON	651,81	864	18,4	2,06	2,72
    	652,09	0	0	 	 	652,38	864	82,5	19,5	ON	652,67	864	18,4	2,06	2,8
    	652,97	0	0	 	 	653,27	864	82,5	20,3	ON	653,57	864	18,4	2,06	2,73
    	653,86	0	0	 	 	654,16	864	82,5	18	ON	654,45	832	18,4	2,06	2,69
    	654,74	0	0	 	 	655,02	832	82,5	15,2	ON	655,28	832	17,3	2,06	2,3
    	655,59	0	0	 	 	655,88	832	82,5	16,4	ON	656,17	832	17,3	2,06	2,59
    	656,46	0	0	 	 	656,78	832	82,5	19,1	ON	657,06	832	18,4	2,06	2,62
    	657,36	0	0	 	 	657,65	864	82,5	21,9	ON	657,96	864	18,4	2,06	2,89
    	658,26	0	0	 	 	658,56	864	82,5	21,1	ON	658,86	864	18,4	2,06	2,57
    	659,16	0	0	 	 	659,46	832	82,5	18,4	ON	659,74	832	17,3	2,06	2,53
    	660,05	0	0	 	 	660,35	832	82,5	15,6	ON	660,65	832	17,3	2,06	2,59
    	660,95	0	0	 	 	661,23	832	82,5	15,6	ON	661,5	832	18,4	2,06	2,56
    	661,82	0	0	 	 	662,12	864	82,5	18,4	ON	662,43	864	18,4	2,06	2,86
    	662,73	0	0	 	 	663,02	864	82,5	21,1	ON	663,31	864	18,4	2,06	2,75
    	663,6	0	0	 	 	663,88	864	82,5	20,7	ON	664,19	864	17,3	2,06	2,54
    	664,46	0	0	 	 	664,75	864	82,5	18	ON	665,04	832	17,3	2,06	2,24
    	665,31	0	0	 	 	665,6	832	82,5	15,2	ON	665,88	832	18,4	2,06	2,57
    	666,17	0	0	 	 	666,44	832	82,5	15,6	ON	666,72	832	18,4	2,06	2,64
    	667	0	0	 	 	667,29	864	82,5	18,4	ON	667,57	864	18,4	2,06	2,72
    	667,88	0	0	 	 	668,16	864	82,5	21,1	ON	668,47	864	18,4	2,06	2,69
    	668,77	0	0	 	 	669,06	864	82,5	20,3	ON	669,36	864	17,3	2,06	2,47
    	669,64	0	0	 	 	669,92	832	82,5	17,6	ON	670,22	832	17,3	2,06	2,47
    	670,52	0	0	 	 	670,81	832	82,5	15,2	ON	671,09	832	17,3	2,06	2,49
    	671,38	0	0	 	 	671,67	832	82,5	18	ON	671,99	864	18,4	2,06	2,75
    	672,3	0	0	 	 	672,6	864	82,5	20,7	ON	672,89	864	18,4	2,06	2,76
    	673,2	0	0	 	 	673,5	864	82,5	20,7	ON	673,8	864	17,3	2,06	2,33
    	674,07	0	0	 	 	674,36	832	82,5	18,4	ON	674,65	832	17,3	2,06	2,43
    	674,95	0	0	 	 	675,25	832	82,5	15,6	ON	675,53	800	17,3	2,06	2,64
    	675,83	0	0	 	 	676,12	832	82,5	15,6	ON	676,42	832	18,4	2,06	2,48
    	676,71	0	0	 	 	677,01	864	82,5	18	ON	677,3	864	18,4	2,06	2,75
    	677,59	0	0	 	 	677,88	864	82,5	20,7	ON	678,19	864	18,4	2,06	2,66
    	678,47	0	0	 	 	678,76	864	82,5	23,4	ON	679,05	864	18,4	2,06	2,6
    	679,36	0	0	 	 	679,65	864	82,5	20,7	ON	679,95	864	17,3	2,06	2,49
    	680,24	0	0	 	 	680,53	832	82,5	18	ON	680,82	832	17,3	2,06	2,54
    	681,12	0	0	 	 	681,42	832	82,5	15,2	ON	681,7	832	17,3	2,06	2,56
    	682	0	0	 	 	682,28	832	82,5	16,8	ON	682,58	832	18,4	2,06	2,72
    	682,88	0	0	 	 	683,18	864	82,5	19,5	ON	683,49	864	18,4	2,06	2,59
    	683,78	0	0	 	 	684,08	864	82,5	20,3	ON	684,38	864	18,4	2,06	2,52
    	684,68	0	0	 	 	684,97	832	82,5	17,6	ON	685,25	832	17,3	2,06	2,32
    	685,55	0	0	 	 	685,84	832	82,5	14,8	ON	686,14	832	17,3	2,06	2,5
    	686,42	0	0	 	 	686,72	832	82,5	16	ON	687,01	832	19,2	2,06	3,13
    	687,32	0	0	 	 	687,61	864	82,5	18,4	ON	687,91	864	19,2	2,06	2,81
    	688,2	0	0	 	 	688,49	864	82,5	21,1	ON	688,78	896	18,4	2,06	2,46
    	689,07	0	0	 	 	689,36	864	82,5	22,3	ON	689,65	864	18,4	2,06	2,64
    	689,94	0	0	 	 	690,23	864	82,5	19,9	ON	690,52	864	17,3	2,06	2,42
    	690,82	0	0	 	 	691,1	832	82,5	17,2	ON	691,4	800	17,3	2,06	2,47
    	691,67	0	0	 	 	691,97	832	82,5	15,2	ON	692,26	832	18,4	2,06	2,6
    	692,55	0	0	 	 	692,85	864	82,5	18	ON	693,14	864	18,4	2,06	2,89
    	693,43	0	0	 	 	693,73	864	82,5	20,3	ON	694,04	864	18,4	2,06	2,75
    	694,35	0	0	 	 	694,64	864	82,5	22,3	ON	694,94	864	18,4	2,06	2,72
    	695,26	0	0	 	 	695,55	864	82,5	19,5	ON	695,84	864	18,4	2,06	2,73
    	696,15	0	0	 	 	696,45	832	82,5	16,8	ON	696,72	832	17,3	2,06	2,35
    	697,01	0	0	 	 	697,32	832	82,5	15,6	ON	697,63	832	18,4	2,06	2,72
    	697,93	0	0	 	 	698,24	832	82,5	18,4	ON	698,53	864	18,4	2,06	2,8
    	698,83	0	0	 	 	699,13	864	82,5	21,1	ON	699,43	864	18,4	2,06	2,69
    	699,73	0	0	 	 	700,03	864	82,5	21,5	ON	700,32	864	17,3	2,06	2,42
    	700,62	0	0	 	 	700,89	832	82,5	18,8	ON	701,19	832	17,3	2,06	2,43
    	701,47	0	0	 	 	701,76	832	82,5	16,4	ON	702,06	800	17,3	2,06	2,55
    	702,34	0	0	 	 	702,64	832	82,5	15,6	ON	702,93	832	18,4	2,06	2,81
    	703,22	0	0	 	 	703,52	864	82,5	18	ON	703,81	864	18,4	2,06	2,83
    	704,11	0	0	 	 	704,41	864	82,5	20,7	ON	704,7	864	18,4	2,06	2,72
    	705	0	0	 	 	705,28	864	82,5	22,7	ON	705,58	864	18,4	2,06	2,42
    	705,86	0	0	 	 	706,17	864	82,5	20,3	ON	706,46	832	17,3	2,06	2,33
    	706,74	0	0	 	 	707,05	832	82,5	17,6	ON	707,31	832	17,3	2,06	2,44
    	707,6	0	0	 	 	707,89	832	82,5	15,2	ON	708,18	800	18,4	2,06	2,56
    	708,45	0	0	 	 	708,74	832	82,5	18	ON	709,03	864	18,4	2,06	2,67
    	709,31	0	0	 	 	709,62	864	82,5	20,7	ON	709,93	864	18,4	2,06	2,96
    	710,24	0	0	 	 	710,54	896	82,5	23,4	ON	710,83	864	17,3	2,06	2,44
    	711,13	0	0	 	 	711,44	864	82,5	23,4	ON	711,74	864	18,4	2,06	2,38
    	712,03	0	0	 	 	712,33	832	82,5	20,7	ON	712,63	832	17,3	2,06	2,39
    	712,91	0	0	 	 	713,2	832	82,5	18	ON	713,49	832	17,3	2,06	2,41
    	713,76	0	0	 	 	714,06	832	82,5	15,2	ON	714,36	800	18,4	2,06	2,98
    	714,67	0	0	 	 	714,96	864	82,5	16,8	ON	715,26	864	18,4	2,06	2,8
    	715,56	0	0	 	 	715,86	832	82,5	19,5	ON	716,16	864	19,2	2,06	2,86
    	716,44	0	0	 	 	716,72	864	82,5	21,9	ON	717,01	864	18,4	2,06	2,69
    	717,31	0	0	 	 	717,61	864	82,5	23	ON	717,9	864	17,3	2,06	2,35
    	718,19	0	0	 	 	718,49	832	84	20,3	ON	718,79	832	17,3	2,06	2,29
    	719,09	0	0	 	 	719,37	832	84	17,6	ON	719,66	800	17,3	2,06	2,55
    	719,96	0	0	 	 	720,26	832	82,5	15,6	ON	720,55	832	18,4	2,06	2,56
    	720,85	0	0	 	 	721,16	832	82,5	18,4	ON	721,45	832	17,3	2,06	2,51
    	721,73	0	0	 	 	722,04	832	82,5	21,1	ON	722,32	864	18,4	2,06	2,49
    	722,59	0	0	 	 	722,89	864	82,5	23	ON	723,18	864	17,3	2,06	2,52
    	723,47	0	0	 	 	723,77	832	84	20,3	ON	724,06	832	17,3	2,06	2,58
    	724,38	0	0	 	 	724,68	832	82,5	19,1	ON	724,97	864	17,3	2,06	2,36
    	725,25	0	0	 	 	725,54	832	84	21,9	ON	725,82	832	17,3	2,06	2,44
    	726,13	0	0	 	 	726,43	832	84	24,6	ON	726,73	864	17,3	2,06	2,6
    	727,01	0	0	 	 	727,32	864	82,5	25	ON	727,62	864	17,3	2,06	2,66
    	727,91	0	0	 	 	728,2	864	82,5	22,3	ON	728,5	864	17,3	2,06	2,24
    	728,78	0	0	 	 	729,05	832	82,5	19,5	ON	729,36	832	17,3	2,06	2,4
    	729,66	0	0	 	 	729,95	832	84	18,4	ON	730,22	832	17,3	2,06	2,29
    	730,51	0	0	 	 	730,81	832	84	21,1	ON	731,11	832	17,3	2,06	2,31
    	731,4	0	0	 	 	731,68	832	82,5	23,8	ON	731,99	832	17,3	2,06	2,27
    	732,27	0	0	 	 	732,56	864	84	23,8	ON	732,86	864	17,3	2,06	2,47
    	733,17	0	0	 	 	733,46	864	84	20,7	ON	733,73	832	17,3	2,06	2,47
    	734,02	0	0	 	 	734,3	832	84	20,3	ON	734,6	832	17,3	2,06	2,52
    	734,9	0	0	 	 	735,19	832	84	23	ON	735,46	832	17,3	2,06	2,32
    	735,74	0	0	 	 	736,05	864	84	25,8	ON	736,34	864	17,3	2,06	2,61
    	736,64	0	0	 	 	736,92	864	84	27,3	ON	737,22	864	17,3	2,06	2,53
    	737,51	0	0	 	 	737,82	832	84	25	ON	738,12	832	17,3	2,06	2,47
    	738,41	0	0	 	 	738,73	832	84	21,9	ON	739,01	832	17,3	2,06	2,43
    	739,31	0	0	 	 	739,6	832	84	19,5	ON	739,88	832	17,3	2,06	2,58
    	740,17	0	0	 	 	740,45	832	84	20,3	ON	740,76	864	18,4	2,06	2,69
    	741,03	0	0	 	 	741,34	864	84	23	ON	741,63	864	17,3	2,06	2,6
    	741,93	0	0	 	 	742,22	864	84	25	ON	742,52	864	17,3	2,06	2,64
    	742,8	0	0	 	 	743,09	864	84	22,3	ON	743,36	832	17,3	2,06	2,36
    	743,66	0	0	 	 	743,94	832	84	19,5	ON	744,24	832	17,3	2,06	2,38
    	744,53	0	0	 	 	744,8	832	84	20,7	ON	745,08	832	17,3	2,06	2,44
    	745,37	0	0	 	 	745,68	864	84	23,4	ON	745,97	864	17,3	2,06	2,56
    	746,26	0	0	 	 	746,55	864	84	25,4	ON	746,85	864	17,3	2,06	2,4
    	747,15	0	0	 	 	747,45	864	84	22,7	ON	747,74	832	17,3	2,06	2,42
    	748,05	0	0	 	 	748,35	832	84	19,9	ON	748,65	800	16,1	2,06	2,26
    	748,94	0	0	 	 	749,23	832	84	17,2	ON	749,52	832	18,4	2,06	2,8
    	749,81	0	0	 	 	750,09	864	84	19,5	ON	750,38	864	18,4	2,06	2,72
    	750,69	0	0	 	 	750,99	864	84	22,3	ON	751,29	864	18,4	2,06	2,74
    	751,58	0	0	 	 	751,87	864	84	25	ON	752,16	864	17,3	2,06	2,59
    	752,45	0	0	 	 	752,75	864	84	22,7	ON	753,04	864	17,3	2,06	2,51
    	753,32	0	0	 	 	753,6	832	84	19,9	ON	753,87	832	17,3	2,06	2,26
    	754,18	0	0	 	 	754,47	832	84	17,6	ON	754,75	832	17,3	2,06	2,58
    	755,06	0	0	 	 	755,35	832	84	18,8	ON	755,64	832	18,4	2,06	2,61
    	755,93	0	0	 	 	756,23	832	84	21,5	ON	756,52	832	18,4	2,06	2,62
    	756,8	0	0	 	 	757,09	864	84	23,8	ON	757,38	864	17,3	2,06	2,36
    	757,69	0	0	 	 	757,99	864	84	22,7	ON	758,29	864	17,3	2,06	2,36
    	758,58	0	0	 	 	758,88	832	84	19,9	ON	759,16	832	17,3	2,06	2,33
    	759,45	0	0	 	 	759,75	832	84	17,2	ON	760,02	832	17,3	2,06	2,41
    	760,33	0	0	 	 	760,61	864	84	18,8	ON	760,92	864	18,4	2,06	2,66
    	761,23	0	0	 	 	761,51	864	84	21,1	ON	761,79	864	18,4	2,06	2,72
    	762,09	0	0	 	 	762,38	864	84	23,8	ON	762,67	864	17,3	2,06	2,56
    	762,97	0	0	 	 	763,27	864	84	21,5	ON	763,57	832	17,3	2,06	2,46
    	763,85	0	0	 	 	764,15	832	84	19,1	ON	764,45	832	17,3	2,06	2,59
    	764,73	0	0	 	 	765,04	832	84	18,4	ON	765,33	832	17,3	2,06	2,54
    	765,62	0	0	 	 	765,92	864	84	21,1	ON	766,23	864	17,3	2,06	2,39
    	766,54	0	0	 	 	766,85	864	84	23	ON	767,12	864	17,3	2,06	2,41
    	767,42	0	0	 	 	767,72	832	84	20,3	ON	768	832	17,3	2,06	2,44
    	768,27	0	0	 	 	768,58	832	84	18,4	ON	768,86	832	17,3	2,06	2,43
    	769,17	0	0	 	 	769,45	832	84	21,1	ON	769,74	864	17,3	2,06	2,63
    	770,03	0	0	 	 	770,33	864	84	23,8	ON	770,61	864	17,3	2,06	2,59
    	770,91	0	0	 	 	771,21	864	84	24,6	ON	771,51	864	17,3	2,06	2,46
    	771,79	0	0	 	 	772,09	864	84	22,3	ON	772,37	832	17,3	2,06	2,5
    	772,67	0	0	 	 	772,98	832	84	19,5	ON	773,26	832	17,3	2,06	2,51
    	773,58	0	0	 	 	773,88	832	84	17,2	ON	774,17	832	18,4	2,06	2,51
    	774,46	0	0	 	 	774,74	832	84	19,9	ON	775,04	864	18,4	2,06	2,53
    	775,34	0	0	 	 	775,65	864	84	22,7	ON	775,96	864	17,3	2,06	2,6
    	776,24	0	0	 	 	776,54	864	84	25,4	ON	776,82	864	17,3	2,06	2,32
    	777,11	0	0	 	 	777,4	864	84	23,4	ON	777,69	864	17,3	2,06	2,51
    	777,97	0	0	 	 	778,26	832	84	21,1	ON	778,56	832	17,3	2,06	2,46
    	778,85	0	0	 	 	779,15	832	84	18,4	ON	779,45	832	17,3	2,06	2,64
    	779,73	0	0	 	 	780,02	832	84	21,1	ON	780,3	832	17,3	2,06	2,44
    	780,6	0	0	 	 	780,89	864	84	23,4	ON	781,18	864	18,4	2,06	2,46
    	781,48	0	0	 	 	781,76	864	84	25,4	ON	782,05	864	17,3	2,06	2,53
    	782,34	0	0	 	 	782,63	864	84	22,7	ON	782,93	864	17,3	2,06	2,52
    	783,19	0	0	 	 	783,49	832	84	19,9	ON	783,79	832	17,3	2,06	2,58
    	784,08	0	0	 	 	784,38	832	84	19,5	ON	784,65	832	17,3	2,06	2,38
    	784,96	0	0	 	 	785,27	832	84	22,3	ON	785,53	864	17,3	2,06	2,55
    	785,84	0	0	 	 	786,14	864	84	25	ON	786,44	864	17,3	2,06	2,43
    	786,73	0	0	 	 	787,04	864	84	23,8	ON	787,35	864	17,3	2,06	2,68
    	787,65	0	0	 	 	787,96	832	84	21,1	ON	788,26	832	17,3	2,06	2,51
    	788,54	0	0	 	 	788,83	832	84	19,5	ON	789,14	832	17,3	2,06	2,34
    	789,41	0	0	 	 	789,69	832	84	22,3	ON	789,98	832	17,3	2,06	2,61
    	790,26	0	0	 	 	790,55	864	84	25	ON	790,85	864	17,3	2,06	2,32
    	791,12	0	0	 	 	791,4	864	84	26,2	ON	791,68	832	17,3	2,06	2,56
    	791,95	0	0	 	 	792,26	864	84	23,4	ON	792,57	832	17,3	2,06	2,53
    	792,85	0	0	 	 	793,14	864	84	20,7	ON	793,45	832	17,3	2,06	2,61
    	793,75	0	0	 	 	794,05	832	84	19,1	ON	794,34	832	17,3	2,06	2,53
    	794,62	0	0	 	 	794,91	832	84	21,9	ON	795,19	864	18,4	2,06	2,53
    	795,48	0	0	 	 	795,77	864	84	24,6	ON	796,09	864	17,3	2,06	2,53
    	796,38	0	0	 	 	796,69	864	84	23,4	ON	796,97	832	17,3	2,06	2,62
    	797,25	0	0	 	 	797,55	832	84	20,7	ON	797,85	832	17,3	2,06	2,5
    	798,16	0	0	 	 	798,45	832	84	21,1	ON	798,73	832	17,3	2,06	2,53
    	799	0	0	 	 	799,31	864	84	23,8	ON	799,59	832	17,3	2,06	2,61
    	799,9	0	0	 	 	800,19	864	84	26,6	ON	800,49	832	17,3	2,06	2,57
    	800,79	0	0	 	 	801,09	864	84	25	ON	801,39	832	17,3	2,06	2,6
    	801,7	0	0	 	 	802,01	832	84	21,9	ON	802,31	832	17,3	2,06	2,32
    	802,61	0	0	 	 	802,89	832	84	19,1	ON	803,2	832	17,3	2,06	2,32
    	803,51	0	0	 	 	803,78	832	84	20,7	ON	804,07	832	18,4	2,06	2,61
    	804,35	0	0	 	 	804,63	832	84	23	ON	804,92	864	18,4	2,06	2,52
    	805,21	0	0	 	 	805,52	864	84	25,8	ON	805,81	864	17,3	2,06	2,64
    	806,1	0	0	 	 	806,39	864	84	24,2	ON	806,69	864	17,3	2,06	2,34
    	806,97	0	0	 	 	807,26	832	84	21,5	ON	807,57	832	17,3	2,06	2,5
    	807,86	0	0	 	 	808,15	832	84	18,8	ON	808,43	832	17,3	2,06	2,52
    	808,73	0	0	 	 	809,01	864	84	20,7	ON	809,31	832	17,3	2,06	2,43
    	809,58	0	0	 	 	809,89	864	84	23,4	ON	810,21	864	17,3	2,06	2,43
    	810,51	0	0	 	 	810,8	864	84	24,6	ON	811,1	864	17,3	2,06	2,3
    	811,36	0	0	 	 	811,66	832	84	21,9	ON	811,96	832	17,3	2,06	2,49
    	812,24	0	0	 	 	812,52	832	84	19,1	ON	812,83	832	17,3	2,06	2,36
    	813,12	0	0	 	 	813,41	832	84	21,9	ON	813,71	832	17,3	2,06	2,44
    	814,01	0	0	 	 	814,31	832	84	24,6	ON	814,6	832	17,3	2,06	2,38
    	814,88	0	0	 	 	815,17	832	84	22,7	ON	815,45	832	17,3	2,06	2,4
    	815,76	0	0	 	 	816,06	832	84	19,9	ON	816,36	832	17,3	2,06	2,52
    	816,66	0	0	 	 	816,95	832	84	20,7	ON	817,25	864	18,4	2,06	2,62
    	817,52	0	0	 	 	817,82	864	84	23,4	ON	818,12	864	17,3	2,06	2,39
    	818,42	0	0	 	 	818,69	864	84	25,8	ON	818,99	864	17,3	2,06	2,61
    	819,29	0	0	 	 	819,59	864	84	23	ON	819,87	832	17,3	2,06	2,54
    	820,15	0	0	 	 	820,43	832	84	20,3	ON	820,73	832	17,3	2,06	2,66
    	821,03	0	0	 	 	821,34	832	84	19,1	ON	821,63	832	17,3	2,06	2,47
    	821,91	0	0	 	 	822,19	864	84	21,9	ON	822,49	864	17,3	2,06	2,38
    	822,79	0	0	 	 	823,07	864	84	24,6	ON	823,36	864	17,3	2,06	2,56
    	823,65	0	0	 	 	823,94	864	84	23,8	ON	824,24	864	17,3	2,06	2,53
    	824,53	0	0	 	 	824,84	832	84	21,1	ON	825,13	832	17,3	2,06	2,2
    	825,4	0	0	 	 	825,71	832	84	18,4	ON	826,01	832	17,3	2,06	2,32
    	826,31	0	0	 	 	826,61	832	84	16,4	ON	826,91	832	18,4	2,06	2,59
    	827,21	0	0	 	 	827,51	864	84	19,1	ON	827,82	832	18,4	2,06	2,71
    	828,12	0	0	 	 	828,41	864	84	21,9	ON	828,71	864	17,3	2,06	2,39
    	829,01	0	0	 	 	829,3	832	84	22,7	ON	829,59	832	17,3	2,06	2,61
    	829,88	0	0	 	 	830,17	864	84	19,9	ON	830,49	832	17,3	2,06	2,35
    	830,78	0	0	 	 	831,09	832	84	17,2	ON	831,37	832	17,3	2,06	2,58
    	831,66	0	0	 	 	831,97	832	84	19,5	ON	832,26	832	17,3	2,06	2,61
    	832,54	0	0	 	 	832,81	864	84	22,3	ON	833,11	864	17,3	2,06	2,32
    	833,41	0	0	 	 	833,71	864	84	25	ON	834	864	17,3	2,06	2,55
    	834,31	0	0	 	 	834,61	864	84	22,7	ON	834,91	864	17,3	2,06	2,36
    	835,2	0	0	 	 	835,49	832	84	19,9	ON	835,79	832	17,3	2,06	2,47
    	836,07	0	0	 	 	836,38	832	84	19,1	ON	836,67	832	17,3	2,06	2,38
    	836,95	0	0	 	 	837,23	832	84	21,9	ON	837,54	864	17,3	2,06	2,55
    	837,85	0	0	 	 	838,14	832	84	24,6	ON	838,43	864	17,3	2,06	2,38
    	838,73	0	0	 	 	839,02	864	84	26,6	ON	839,31	864	17,3	2,06	2,42
    	839,6	0	0	 	 	839,89	864	84	23,8	ON	840,19	832	17,3	2,06	2,33
    	840,5	0	0	 	 	840,8	832	84	21,1	ON	841,1	832	17,3	2,06	2,32
    	841,39	0	0	 	 	841,7	832	84	20,3	ON	842,02	832	18,4	2,06	2,69
    	842,31	0	0	 	 	842,61	832	84	23	ON	842,89	864	17,3	2,06	2,61
    	843,2	0	0	 	 	843,51	864	84	25,8	ON	843,8	864	18,4	2,06	2,43
    	844,1	0	0	 	 	844,38	864	84	23	ON	844,68	864	17,3	2,06	2,34
    	844,98	0	0	 	 	845,28	864	84	20,7	ON	845,56	832	16,1	2,06	2,33
    	845,85	0	0	 	 	846,14	832	84	18	ON	846,45	832	17,3	2,06	2,24
    	846,75	0	0	 	 	847,05	832	84	19,1	ON	847,35	832	18,4	2,06	2,74
    	847,64	0	0	 	 	847,92	864	84	21,9	ON	848,21	864	18,4	2,06	2,61
    	848,51	0	0	 	 	848,8	864	84	24,6	ON	849,09	864	18,4	2,06	2,57
    	849,38	0	0	 	 	849,67	864	84	26,2	ON	849,97	864	18,4	2,06	2,53
    	850,28	0	0	 	 	850,56	832	84	23,4	ON	850,88	832	17,3	2,06	2,41
    	851,17	0	0	 	 	851,48	832	84	20,7	ON	851,77	832	17,3	2,06	2,39
    	852,04	0	0	 	 	852,33	832	84	18	ON	852,61	800	16,1	2,06	2,28
    	852,91	0	0	 	 	853,19	832	84	19,5	ON	853,5	832	18,4	2,06	2,63
    	853,79	0	0	 	 	854,1	864	84	22,3	ON	854,4	864	18,4	2,06	2,6
    	854,87	0	0	 	 	855,09	864	84	25,4	ON	855,4	864	17,3	2,06	2,51
    	855,7	0	0	 	 	856,01	864	84	27	ON	856,29	864	17,3	2,06	2,6
    	856,59	0	0	 	 	856,88	864	84	24,2	ON	857,18	864	17,3	2,06	2,32
    	857,47	0	0	 	 	857,75	832	84	21,5	ON	858,04	832	16,1	2,06	2,32
    	858,34	0	0	 	 	858,63	832	84	20,3	ON	858,93	832	17,3	2,06	2,58
    	859,22	0	0	 	 	859,52	864	84	23	ON	859,82	864	17,3	2,06	2,38
    	860,11	0	0	 	 	860,41	864	84	25,8	ON	860,71	864	17,3	2,06	2,59
    	861	0	0	 	 	861,29	864	84	26,6	ON	861,59	864	17,3	2,06	2,39
    	861,9	0	0	 	 	862,2	864	84	23,8	ON	862,49	832	16,1	2,06	2,23
    	862,77	0	0	 	 	863,05	832	84	21,1	ON	863,36	832	16,1	2,06	2,32
    	863,66	0	0	 	 	863,94	832	84	19,9	ON	864,23	832	17,3	2,06	2,81
    	864,52	0	0	 	 	864,79	864	84	22,7	ON	865,1	832	18,4	2,06	2,6
    	865,39	0	0	 	 	865,67	832	84	25,4	ON	865,96	864	18,4	2,06	2,73
    	866,25	0	0	 	 	866,54	864	84	27,7	ON	866,84	864	18,4	2,06	2,5
    	867,14	0	0	 	 	867,43	864	84	25,8	ON	867,72	864	17,3	2,06	2,31
    	868	0	0	 	 	868,28	864	84	23,4	ON	868,56	832	16,1	2,06	2,44
    	868,84	0	0	 	 	869,11	832	84	20,7	ON	869,41	832	16,1	2,06	2,23
    	869,71	0	0	 	 	870,01	800	84	18,4	ON	870,3	832	18,4	2,06	2,64
    	870,6	0	0	 	 	870,91	864	84	21,1	ON	871,21	864	18,4	2,06	2,66
    	871,51	0	0	 	 	871,84	864	84	23,8	ON	872,13	864	18,4	2,06	2,61
    	872,41	0	0	 	 	872,72	864	84	26,6	ON	873,01	864	17,3	2,06	1,98
    	873,32	0	0	 	 	873,6	864	84	25,8	ON	873,89	832	16,1	2,06	2,21
    	874,17	0	0	 	 	874,47	832	84	23	ON	874,76	832	16,1	2,06	2,36
    	875,06	0	0	 	 	875,36	832	85,5	20,7	ON	875,65	832	17,3	2,06	2,78
    	875,95	0	0	 	 	876,26	864	84	23,4	ON	876,57	864	17,3	2,06	2,57
    	876,85	0	0	 	 	877,16	864	84	26,2	ON	877,46	864	17,3	2,06	2,58
    	877,76	0	0	 	 	878,06	864	84	26,6	ON	878,33	864	17,3	2,06	2,4
    	878,65	0	0	 	 	878,94	832	84	23,8	ON	879,25	832	16,1	2,06	2,35
    	879,55	0	0	 	 	879,85	832	85,5	21,1	ON	880,14	832	17,3	2,06	2,54
    	880,43	0	0	 	 	880,74	832	84	21,9	ON	881,02	832	17,3	2,06	2,33
    	881,31	0	0	 	 	881,61	864	85,5	24,6	ON	881,89	864	17,3	2,06	2,5
    	882,19	0	0	 	 	882,48	864	84	27,3	ON	882,79	864	17,3	2,06	2,44
    	883,08	0	0	 	 	883,39	864	85,5	24,6	ON	883,69	832	17,3	2,06	2,38
    	883,99	0	0	 	 	884,29	832	84	21,5	ON	884,58	832	16,1	2,06	2,38
    	884,87	0	0	 	 	885,15	832	84	20,7	ON	885,45	832	18,4	2,06	2,8
    	885,76	0	0	 	 	886,07	864	84	23,4	ON	886,38	864	18,4	2,06	2,53
    	886,7	0	0	 	 	886,99	864	84	26,2	ON	887,27	864	17,3	2,06	2,53
    	887,58	0	0	 	 	887,89	864	85,5	24,6	ON	888,19	864	17,3	2,06	2,35
    	888,48	0	0	 	 	888,78	832	84	21,9	ON	889,09	832	16,1	2,06	2,31
    	889,38	0	0	 	 	889,67	832	85,5	19,9	ON	889,98	832	17,3	2,06	2,37
    	890,26	0	0	 	 	890,54	864	85,5	22,3	ON	890,83	864	17,3	2,06	2,58
    	891,13	0	0	 	 	891,43	864	85,5	25	ON	891,69	864	17,3	2,06	2,39
    	891,99	0	0	 	 	892,3	864	85,5	27,7	ON	892,57	864	17,3	2,06	2,27
    	892,86	0	0	 	 	893,15	864	85,5	26,6	ON	893,44	864	16,1	2,06	2,39
    	893,72	0	0	 	 	894,03	832	85,5	23,8	ON	894,32	832	17,3	2,06	2,41
    	894,61	0	0	 	 	894,91	832	85,5	24,6	ON	895,2	832	17,3	2,06	2,27
    	895,5	0	0	 	 	895,78	864	85,5	27,3	ON	896,08	832	17,3	2,06	2,33
    	896,4	0	0	 	 	896,7	832	85,5	27,3	ON	896,99	832	17,3	2,06	2,4
    	897,27	0	0	 	 	897,56	832	85,5	24,6	ON	897,84	832	17,3	2,06	2,4
    	898,13	0	0	 	 	898,44	832	85,5	24,2	ON	898,73	832	17,3	2,06	2,41
    	899,01	0	0	 	 	899,3	864	85,5	27	ON	899,59	832	17,3	2,06	2,4
    	899,87	0	0	 	 	900,15	864	85,5	27,7	ON	900,44	864	17,3	2,06	2,31
    	900,73	0	0	 	 	901,04	832	85,5	27	ON	901,32	864	17,3	2,06	2,44
    	901,62	0	0	 	 	901,92	832	85,5	24,2	ON	902,21	832	17,3	2,06	2,41
    	902,49	0	0	 	 	902,8	864	85,5	25,4	ON	903,09	832	17,3	2,06	2,35
    	903,37	0	0	 	 	903,66	832	85,5	27,7	ON	903,94	864	17,3	2,06	2,48
    	904,25	0	0	 	 	904,54	864	85,5	27,7	ON	904,83	832	16,1	2,06	2,42
    	905,12	0	0	 	 	905,41	832	85,5	25	ON	905,7	832	17,3	2,06	2,34
    	905,99	0	0	 	 	906,27	832	85,5	25,8	ON	906,54	832	16,1	2,06	2,23
    	906,85	0	0	 	 	907,14	832	85,5	27,7	ON	907,45	864	16,1	2,06	2,34
    	907,73	0	0	 	 	908,03	832	85,5	26,6	ON	908,34	832	16,1	2,06	2,31
    	908,62	0	0	 	 	908,9	832	85,5	23,8	ON	909,18	832	17,3	2,06	2,52
    	909,48	0	0	 	 	909,77	832	85,5	23	ON	910,07	832	17,3	2,06	2,64
    	910,38	0	0	 	 	910,67	832	85,5	25,8	ON	910,97	864	17,3	2,06	2,41
    	911,25	0	0	 	 	911,54	864	85,5	27,7	ON	911,84	864	17,3	2,06	2,54
    	912,14	0	0	 	 	912,44	864	85,5	26,2	ON	912,75	832	17,3	2,06	2,43
    	913,04	0	0	 	 	913,33	832	85,5	23,4	ON	913,62	864	17,3	2,06	2,35
    	913,89	0	0	 	 	914,2	832	85,5	23,4	ON	914,5	832	17,3	2,06	2,29
    	914,77	0	0	 	 	915,04	832	85,5	26,2	ON	915,31	832	17,3	2,06	2,29
    	915,62	0	0	 	 	915,93	832	85,5	27,7	ON	916,22	864	17,3	2,06	2,38
    	916,52	0	0	 	 	916,83	832	85,5	25,8	ON	917,12	864	17,3	2,06	2,43
    	917,42	0	0	 	 	917,7	832	85,5	23	ON	918	832	17,3	2,06	2,46
    	918,3	0	0	 	 	918,6	832	85,5	23,4	ON	918,89	864	17,3	2,06	2,44
    	919,19	0	0	 	 	919,47	832	85,5	26,2	ON	919,76	864	17,3	2,06	2,35
    	920,05	0	0	 	 	920,35	864	85,5	27,7	ON	920,65	864	16,1	2,06	2,44
    	920,92	0	0	 	 	921,2	832	85,5	25	ON	921,48	832	17,3	2,06	2,34
    	921,77	0	0	 	 	922,05	832	85,5	23,4	ON	922,35	864	17,3	2,06	2,38
    	922,66	0	0	 	 	922,96	864	85,5	26,2	ON	923,27	832	16,1	2,06	2,35
    	923,55	0	0	 	 	923,85	832	85,5	27	ON	924,14	864	16,1	2,06	2,54
    	924,43	0	0	 	 	924,72	832	85,5	24,6	ON	925,03	832	16,1	2,06	2,44
    	925,31	0	0	 	 	925,59	832	85,5	25	ON	925,89	832	17,3	2,06	2,59
    	926,18	0	0	 	 	926,47	864	85,5	27,3	ON	926,77	864	17,3	2,06	2,54
    	927,06	0	0	 	 	927,36	864	85,5	27,7	ON	927,67	864	17,3	2,06	2,39
    	927,98	0	0	 	 	928,27	864	85,5	27	ON	928,57	832	16,1	2,06	2,41
    	928,86	0	0	 	 	929,14	832	85,5	24,2	ON	929,42	832	16,1	2,06	2,11
    	929,7	0	0	 	 	929,98	832	85,5	25,4	ON	930,27	832	16,1	2,06	2,52
    	930,54	0	0	 	 	930,85	864	85,5	27,7	ON	931,14	832	16,1	2,06	2,48
    	931,42	0	0	 	 	931,72	864	85,5	27,7	ON	932,03	832	16,1	2,06	2,3
    	932,32	0	0	 	 	932,58	864	85,5	27,7	ON	932,89	832	16,1	2,06	2,46
    	933,19	0	0	 	 	933,48	832	85,5	27	ON	933,77	832	16,1	2,06	2,32
    	934,07	0	0	 	 	934,37	832	85,5	24,6	ON	934,65	832	17,3	2,06	2,34
    	934,93	0	0	 	 	935,23	832	85,5	25,4	ON	935,52	832	17,3	2,06	2,53
    	935,82	0	0	 	 	936,13	864	85,5	27,7	ON	936,43	864	16,1	2,06	2,5
    	936,73	0	0	 	 	937,03	864	85,5	26,2	ON	937,32	864	16,1	2,06	2,32
    	937,61	0	0	 	 	937,91	832	85,5	25,8	ON	938,19	864	16,1	2,06	2,32
    	938,46	0	0	 	 	938,77	832	85,5	27,7	ON	939,06	832	16,1	2,06	2,4
    	939,35	0	0	 	 	939,66	832	85,5	27	ON	939,93	832	16,1	2,06	2,29
    	940,24	0	0	 	 	940,52	832	85,5	24,2	ON	940,82	832	16,1	2,06	2,43
    	941,09	0	0	 	 	941,37	832	85,5	21,9	ON	941,66	832	16,1	2,06	2,27
    	941,96	0	0	 	 	942,27	832	85,5	24,6	ON	942,56	832	17,3	2,06	2,57
    	942,82	0	0	 	 	943,11	832	85,5	27,3	ON	943,41	864	17,3	2,06	2,37
    	943,7	0	0	 	 	944,02	864	85,5	27,3	ON	944,31	864	17,3	2,06	2,53
    	944,6	0	0	 	 	944,9	864	85,5	25	ON	945,2	832	17,3	2,06	2,55
    	945,48	0	0	 	 	945,77	864	85,5	27	ON	946,07	864	17,3	2,06	2,32
    	946,37	0	0	 	 	946,66	832	85,5	27,7	ON	946,96	864	17,3	2,06	2,27
    	947,26	0	0	 	 	947,55	832	85,5	25	ON	947,82	832	17,3	2,06	2,55
    	948,13	0	0	 	 	948,41	832	85,5	23,8	ON	948,7	832	17,3	2,06	2,43
    	948,98	0	0	 	 	949,28	864	85,5	26,6	ON	949,58	864	17,3	2,06	2,4
    	949,86	0	0	 	 	950,14	864	85,5	27,7	ON	950,43	864	17,3	2,06	2,61
    	950,73	0	0	 	 	951,02	864	85,5	25,8	ON	951,3	832	17,3	2,06	2,46
    	951,59	0	0	 	 	951,87	832	85,5	23	ON	952,16	864	17,3	2,06	2,51
    	952,46	0	0	 	 	952,73	832	85,5	25,8	ON	953,01	832	17,3	2,06	2,31
    	953,3	0	0	 	 	953,59	832	85,5	27,7	ON	953,89	832	17,3	2,06	2,33
    	954,17	0	0	 	 	954,48	864	85,5	27,7	ON	954,77	864	17,3	2,06	2,38
    	955,04	0	0	 	 	955,34	864	85,5	27,7	ON	955,65	832	17,3	2,06	2,55
    	955,95	0	0	 	 	956,25	832	85,5	27,7	ON	956,54	832	17,3	2,06	2,44
    	956,86	0	0	 	 	957,16	864	85,5	27,7	ON	957,43	832	17,3	2,06	2,38
    	957,73	0	0	 	 	958,04	832	85,5	27,7	ON	958,34	832	17,3	2,06	2,3
    	958,63	0	0	 	 	958,91	864	85,5	27,7	ON	959,2	864	16,1	2,06	2,35
    	959,49	0	0	 	 	959,79	832	85,5	27,7	ON	960,1	832	16,1	2,06	2,41
    	960,39	0	0	 	 	960,67	832	85,5	25	ON	960,94	832	17,3	2,06	2,61
    	961,23	0	0	 	 	961,51	832	85,5	27,7	ON	961,8	832	16,1	2,06	2,29
    	962,09	0	0	 	 	962,38	832	85,5	27,7	ON	962,69	832	16,1	2,06	2,47
    	962,98	0	0	 	 	963,26	864	85,5	27,7	ON	963,56	864	17,3	2,06	2,29
    	963,85	0	0	 	 	964,15	864	85,5	27,7	ON	964,42	864	17,3	2,06	2,54
    	964,72	0	0	 	 	965,01	864	85,5	25	ON	965,28	864	16,1	2,06	2,24
    	965,59	0	0	 	 	965,89	864	85,5	25,4	ON	966,18	832	17,3	2,06	2,4
    	966,46	0	0	 	 	966,75	832	85,5	27,7	ON	967,05	864	16,1	2,06	2,38
    	967,33	0	0	 	 	967,62	832	85,5	27,7	ON	967,93	864	17,3	2,06	2,44
    	968,23	0	0	 	 	968,53	832	85,5	25,4	ON	968,79	864	17,3	2,06	2,24
    	969,08	0	0	 	 	969,35	832	85,5	25,8	ON	969,62	832	17,3	2,06	2,46
    	969,92	0	0	 	 	970,22	832	85,5	27,7	ON	970,5	864	17,3	2,06	2,32
    	970,78	0	0	 	 	971,07	864	85,5	27,7	ON	971,34	832	16,1	2,06	2,4
    	971,61	0	0	 	 	971,91	832	85,5	27,7	ON	972,22	832	17,3	2,06	2,38
    	972,52	0	0	 	 	972,81	864	85,5	27,7	ON	973,11	864	16,1	2,06	2,33
    	973,4	0	0	 	 	973,69	864	85,5	27,7	ON	973,99	832	16,1	2,06	2,41
    	974,29	0	0	 	 	974,58	864	85,5	27,7	ON	974,89	864	16,1	2,06	2,47
    	975,18	0	0	 	 	975,45	864	85,5	27,7	ON	975,74	832	16,1	2,06	2,46
    	976,03	0	0	 	 	976,33	832	85,5	27,7	ON	976,61	832	16,1	2,06	2,53
    	976,92	0	0	 	 	977,23	832	85,5	27,7	ON	977,52	864	17,3	2,06	2,43
    	977,81	0	0	 	 	978,1	832	85,5	27,7	ON	978,38	864	17,3	2,06	2,3
    	978,7	0	0	 	 	979	864	85,5	27,7	ON	979,29	832	17,3	2,06	2,52
    	979,58	0	0	 	 	979,87	864	85,5	27,7	ON	980,17	864	16,1	2,06	2,19
    	980,46	0	0	 	 	980,75	832	85,5	27,7	ON	981,03	832	17,3	2,06	2,46
    	981,31	0	0	 	 	981,59	832	85,5	27,7	ON	981,87	832	16,1	2,06	2,32
    	982,15	0	0	 	 	982,43	832	85,5	27,7	ON	982,72	832	16,1	2,06	2,33
    	983,01	0	0	 	 	983,29	832	85,5	27,7	ON	983,58	832	16,1	2,06	2,33
    	983,88	0	0	 	 	984,2	864	85,5	27,7	ON	984,49	832	16,1	2,06	2,44
    	984,79	0	0	 	 	985,07	864	85,5	27,7	ON	985,37	864	16,1	2,06	2,32
    	985,67	0	0	 	 	985,97	864	85,5	27,7	ON	986,28	864	16,1	2,06	2,4
    	986,57	0	0	 	 	986,86	864	85,5	27,7	ON	987,15	832	16,1	2,06	2,38
    	987,44	0	0	 	 	987,73	832	85,5	27,7	ON	988,04	864	16,1	2,06	2,32
    	988,34	0	0	 	 	988,63	832	85,5	27,7	ON	988,93	832	16,1	2,06	2,35
    	989,24	0	0	 	 	989,52	864	85,5	27,7	ON	989,81	864	16,1	2,06	2,26
    	990,07	0	0	 	 	990,38	832	85,5	27,7	ON	990,68	832	17,3	2,06	2,66
    	990,98	0	0	 	 	991,27	864	85,5	27,7	ON	991,56	832	16,1	2,06	2,34
    	991,85	0	0	 	 	992,14	864	85,5	27,7	ON	992,44	832	16,1	2,06	2,33
    	992,72	0	0	 	 	993,03	832	85,5	27,7	ON	993,32	832	17,3	2,06	2,38
    	993,61	0	0	 	 	993,9	832	85,5	27,7	ON	994,19	864	17,3	2,06	2,32
    	994,5	0	0	 	 	994,8	864	85,5	27,7	ON	995,11	832	16,1	2,06	2,34
    	995,41	0	0	 	 	995,69	832	85,5	27,7	ON	995,97	832	17,3	2,06	2,4
    	996,27	0	0	 	 	996,55	864	85,5	27,7	ON	996,83	864	16,1	2,06	2,38
    	997,11	0	0	 	 	997,41	832	85,5	27,7	ON	997,7	832	16,1	2,06	2,35
    	997,99	0	0	 	 	998,29	832	85,5	27,7	ON	998,58	832	16,1	2,06	2,33
    	998,85	0	0	 	 	999,14	832	85,5	27,7	ON	999,41	832	16,1	2,06	2,5
    	999,72	0	0	 	 	1000,01	832	85,5	27,7	ON	1000,29	832	16,1	2,06	2,38
    	1000,58	0	0	 	 	1000,87	832	85,5	27,7	ON	1001,16	832	16,1	2,06	2,34
    	1001,45	0	0	 	 	1001,74	864	85,5	27,7	ON	1002,03	864	16,1	2,06	2,33
    	1002,3	0	0	 	 	1002,61	864	85,5	27,7	ON	1002,9	832	16,1	2,06	2,32
    	1003,2	0	0	 	 	1003,51	864	85,5	27,7	ON	1003,8	864	16,1	2,06	2,39
    	1004,1	0	0	 	 	1004,38	832	85,5	27,7	ON	1004,67	864	17,3	2,06	2,44
    	1004,96	0	0	 	 	1005,24	832	85,5	27,7	ON	1005,52	864	16,1	2,06	2,37
    	1005,8	0	0	 	 	1006,1	832	85,5	27,7	ON	1006,37	832	16,1	2,06	2,58
    	1006,66	0	0	 	 	1006,95	832	85,5	27,7	ON	1007,25	864	16,1	2,06	2,32
    	1007,53	0	0	 	 	1007,82	832	85,5	27,7	ON	1008,12	864	16,1	2,06	2,34
    	1008,41	0	0	 	 	1008,69	832	85,5	27,7	ON	1008,97	832	16,1	2,06	2,31
    	1009,25	0	0	 	 	1009,53	832	85,5	27,7	ON	1009,81	832	16,1	2,06	2,47
    	1010,09	0	0	 	 	1010,38	832	85,5	27,7	ON	1010,67	832	17,3	2,06	2,52
    	1010,96	0	0	 	 	1011,25	864	85,5	27,7	ON	1011,55	832	17,3	2,06	2,39
    	1011,85	0	0	 	 	1012,14	864	85,5	27,7	ON	1012,43	864	17,3	2,06	2,53
    	1012,72	0	0	 	 	1013,03	832	85,5	27,7	ON	1013,32	832	17,3	2,06	2,48
    	1013,6	0	0	 	 	1013,89	864	85,5	27,7	ON	1014,18	864	17,3	2,06	2,36
    	1014,47	0	0	 	 	1014,77	864	85,5	27,7	ON	1015,06	864	16,1	2,06	2,42
    	1015,36	0	0	 	 	1015,66	832	85,5	27,7	ON	1015,94	832	17,3	2,06	2,72
    	1016,23	0	0	 	 	1016,51	832	85,5	27,7	ON	1016,79	864	17,3	2,06	2,44
    	1017,1	0	0	 	 	1017,4	832	85,5	27,7	ON	1017,69	864	17,3	2,06	2,35
    	1017,99	0	0	 	 	1018,29	832	85,5	27,7	ON	1018,59	864	17,3	2,06	2,51
    	1018,89	0	0	 	 	1019,17	864	85,5	27,7	ON	1019,46	864	16,1	2,06	2,42
    	1019,76	0	0	 	 	1020,06	864	85,5	27,7	ON	1020,34	832	16,1	2,06	2,42
    	1020,64	0	0	 	 	1020,92	832	85,5	27,7	ON	1021,21	864	16,1	2,06	2,2
    	1021,51	0	0	 	 	1021,79	832	85,5	27,7	ON	1022,06	832	16,1	2,06	2,53
    	1022,34	0	0	 	 	1022,61	832	85,5	27,7	ON	1022,91	832	16,1	2,06	2,55
    	1023,2	0	0	 	 	1023,5	832	85,5	27,7	ON	1023,79	832	16,1	2,06	2,24
    	1024,07	0	0	 	 	1024,36	832	85,5	27,7	ON	1024,66	832	16,1	2,06	2,44
    	1024,94	0	0	 	 	1025,22	832	85,5	27,7	ON	1025,51	832	16,1	2,06	2,46
    	1025,81	0	0	 	 	1026,1	832	85,5	27,7	ON	1026,37	832	16,1	2,06	2,2
    	1026,65	0	0	 	 	1026,95	832	85,5	27,7	ON	1027,23	832	16,1	2,06	2,36
    	1027,54	0	0	 	 	1027,84	832	85,5	27,7	ON	1028,15	864	16,1	2,06	2,35
    	1028,44	0	0	 	 	1028,7	832	85,5	27,7	ON	1029	832	16,1	2,06	2,31
    	1029,28	0	0	 	 	1029,56	832	85,5	27,7	ON	1029,86	864	17,3	2,06	2,35
    	1030,14	0	0	 	 	1030,41	832	85,5	27,7	ON	1030,72	864	17,3	2,06	2,48
    	1031,03	0	0	 	 	1031,33	864	85,5	27,7	ON	1031,63	832	16,1	2,06	2,51
    	1031,92	0	0	 	 	1032,22	832	85,5	27,7	ON	1032,51	864	17,3	2,06	2,68
    	1032,8	0	0	 	 	1033,11	832	85,5	27,7	ON	1033,39	864	16,1	2,06	2,11
    	1033,7	0	0	 	 	1034	832	85,5	27,7	ON	1034,3	864	16,1	2,06	2,21
    	1034,59	0	0	 	 	1034,91	832	85,5	27,7	ON	1035,21	832	16,1	2,06	2,38
    	1035,48	0	0	 	 	1035,79	832	85,5	27,7	ON	1036,09	864	16,1	2,06	2,15
    	1036,39	0	0	 	 	1036,68	832	85,5	27,7	ON	1036,98	832	16,1	2,06	2,46
    	1037,26	0	0	 	 	1037,56	832	85,5	27,7	ON	1037,86	832	16,1	2,06	2,36
    	1038,15	0	0	 	 	1038,44	832	85,5	27,7	ON	1038,73	832	16,1	2,06	2,37
    	1039,03	0	0	 	 	1039,32	832	85,5	27,7	ON	1039,62	864	16,1	2,06	2,39
    	1039,93	0	0	 	 	1040,23	832	85,5	27,7	ON	1040,51	832	16,1	2,06	2,42
    	1040,8	0	0	 	 	1041,1	832	85,5	27,7	ON	1041,39	832	16,1	2,06	2,32
    	1041,67	0	0	 	 	1041,97	832	85,5	27,7	ON	1042,28	832	16,1	2,06	2,38
    	1042,57	0	0	 	 	1042,86	832	85,5	27,7	ON	1043,16	832	16,1	2,06	2,47
    	1043,45	0	0	 	 	1043,75	864	85,5	27,7	ON	1044,06	832	16,1	2,06	2,43
    	1044,35	0	0	 	 	1044,63	832	85,5	27,7	ON	1044,91	832	17,3	2,06	2,44
    	1045,2	0	0	 	 	1045,5	832	85,5	27,7	ON	1045,79	864	16,1	2,06	2,42
    	1046,08	0	0	 	 	1046,37	864	85,5	27,7	ON	1046,67	864	16,1	2,06	2,12
    	1046,94	0	0	 	 	1047,23	832	85,5	27,7	ON	1047,52	832	17,3	2,06	2,53
    	1047,79	0	0	 	 	1048,1	864	85,5	27,7	ON	1048,39	832	17,3	2,06	2,36
    	1048,67	0	0	 	 	1048,96	864	85,5	27,7	ON	1049,25	864	16,1	2,06	2,24
    	1049,55	0	0	 	 	1049,85	832	85,5	27,7	ON	1050,14	832	17,3	2,06	2,38
    	1050,44	0	0	 	 	1050,73	864	85,5	27,7	ON	1050,99	832	17,3	2,06	2,35
    	1051,31	0	0	 	 	1051,59	832	85,5	27,7	ON	1051,87	832	17,3	2,06	2,39
    	1052,15	0	0	 	 	1052,43	832	85,5	27,7	ON	1052,71	832	17,3	2,06	2,41
    	1052,99	0	0	 	 	1053,29	832	85,5	27,7	ON	1053,58	832	16,1	2,06	2,42
    	1053,87	0	0	 	 	1054,17	832	85,5	27,7	ON	1054,46	832	17,3	2,06	2,53
    	1054,74	0	0	 	 	1055,03	864	85,5	27,7	ON	1055,32	864	17,3	2,06	2,43
    	1055,61	0	0	 	 	1055,9	864	85,5	27,7	ON	1056,21	832	16,1	2,06	2,52
    	1056,49	0	0	 	 	1056,79	864	85,5	27,7	ON	1057,08	864	17,3	2,06	2,35
    	1057,37	0	0	 	 	1057,67	864	85,5	27,7	ON	1057,98	832	16,1	2,06	2,44
    	1058,27	0	0	 	 	1058,58	832	85,5	27,7	ON	1058,85	864	16,1	2,06	2,44
    	1059,16	0	0	 	 	1059,44	864	85,5	27,7	ON	1059,72	832	16,1	2,06	2,32
    	1060,02	0	0	 	 	1060,32	832	85,5	27,7	ON	1060,61	864	16,1	2,06	2,38
    	1060,89	0	0	 	 	1061,19	864	85,5	27,7	ON	1061,5	864	16,1	2,06	2,3
    	1061,79	0	0	 	 	1062,07	864	85,5	27,7	ON	1062,34	832	16,1	2,06	2,35
    	1062,64	0	0	 	 	1062,94	864	85,5	27,7	ON	1063,23	832	16,1	2,06	2,31
    	1063,52	0	0	 	 	1063,8	864	85,5	27,7	ON	1064,09	832	16,1	2,06	2,37
    	1064,38	0	0	 	 	1064,66	832	85,5	27,7	ON	1064,96	832	17,3	2,06	2,38
    	1065,24	0	0	 	 	1065,52	864	85,5	27,7	ON	1065,82	864	16,1	2,06	2,22
    	1066,1	0	0	 	 	1066,4	864	85,5	27,7	ON	1066,71	864	16,1	2,06	2,39
    	1067	0	0	 	 	1067,3	864	85,5	27,7	ON	1067,59	832	16,1	2,06	2,42
    	1067,9	0	0	 	 	1068,19	832	85,5	27,7	ON	1068,47	832	16,1	2,06	2,38
    	1068,75	0	0	 	 	1069,03	832	85,5	27,7	ON	1069,31	864	16,1	2,06	2,26
    	1069,6	0	0	 	 	1069,91	832	85,5	27,7	ON	1070,21	832	16,1	2,06	2,14
    	1070,52	0	0	 	 	1070,81	832	85,5	27,7	ON	1071,09	832	16,1	2,06	2,48
    	1071,37	0	0	 	 	1071,67	832	85,5	27,7	ON	1071,96	832	17,3	2,06	2,44
    	1072,27	0	0	 	 	1072,56	832	85,5	27,7	ON	1072,87	832	17,3	2,06	2,32
    	1073,15	0	0	 	 	1073,45	832	85,5	27,7	ON	1073,76	864	17,3	2,06	2,42
    	1074,06	0	0	 	 	1074,35	832	85,5	27,7	ON	1074,65	832	17,3	2,06	2,44
    	1074,95	0	0	 	 	1075,24	864	85,5	27,7	ON	1075,51	864	17,3	2,06	2,34
    	1075,82	0	0	 	 	1076,11	864	85,5	27,7	ON	1076,37	832	17,3	2,06	2,48
    	1076,66	0	0	 	 	1076,96	832	85,5	27,7	ON	1077,27	864	16,1	2,06	2,4
    	1077,56	0	0	 	 	1077,85	832	85,5	27,7	ON	1078,14	832	16,1	2,06	2,44
    	1078,43	0	0	 	 	1078,72	832	85,5	27,7	ON	1079	832	17,3	2,06	2,47
    	1079,28	0	0	 	 	1079,58	832	85,5	27,7	ON	1079,88	864	16,1	2,06	2,32
    	1080,18	0	0	 	 	1080,46	832	85,5	27,7	ON	1080,75	864	17,3	2,06	2,41
    	1081,05	0	0	 	 	1081,35	832	85,5	27,7	ON	1081,66	864	17,3	2,06	2,4
    	1081,95	0	0	 	 	1082,22	832	85,5	27,7	ON	1082,53	864	17,3	2,06	2,36
    	1082,84	0	0	 	 	1083,14	832	85,5	27,7	ON	1083,43	832	16,1	2,06	2,51
    	1083,7	0	0	 	 	1083,99	832	85,5	27,7	ON	1084,27	864	17,3	2,06	2,37
    	1084,57	0	0	 	 	1084,86	864	85,5	27,7	ON	1085,17	864	16,1	2,06	2,37
    	1085,47	0	0	 	 	1085,78	832	85,5	27,7	ON	1086,07	832	17,3	2,06	2,3
    	1086,36	0	0	 	 	1086,64	832	85,5	27,7	ON	1086,94	832	17,3	2,06	2,35
    	1087,23	0	0	 	 	1087,53	864	85,5	27,7	ON	1087,82	832	16,1	2,06	2,31
    	1088,12	0	0	 	 	1088,42	864	85,5	27,7	ON	1088,73	864	17,3	2,06	2,37
    	1089,03	0	0	 	 	1089,31	832	85,5	27,7	ON	1089,6	864	16,1	2,06	2,31
    	1089,9	0	0	 	 	1090,2	864	85,5	27,7	ON	1090,49	864	16,1	2,06	2,29
    	1090,79	0	0	 	 	1091,07	864	85,5	27,7	ON	1091,37	864	16,1	2,06	2,32
    	1091,65	0	0	 	 	1091,94	832	85,5	27,7	ON	1092,24	832	16,1	2,06	2,3
    	1092,54	0	0	 	 	1092,83	832	85,5	27,7	ON	1093,13	832	14,9	2,06	2,33
    	1093,43	0	0	 	 	1093,73	832	85,5	27,7	ON	1094,02	832	16,1	2,06	2,37
    	1094,31	0	0	 	 	1094,6	832	85,5	27,7	ON	1094,88	832	16,1	2,06	2,41
    	1095,14	0	0	 	 	1095,45	864	85,5	27,7	ON	1095,74	864	17,3	2,06	2,38
    	1096,04	0	0	 	 	1096,33	864	85,5	27,7	ON	1096,61	864	16,1	2,06	2,43
    	1096,91	0	0	 	 	1097,18	832	85,5	27,7	ON	1097,49	832	16,1	2,06	2,19
    	1097,78	0	0	 	 	1098,07	864	85,5	27,7	ON	1098,37	832	16,1	2,06	2,29
    	1098,68	0	0	 	 	1098,96	832	85,5	27,7	ON	1099,27	832	16,1	2,06	2,54
    	1099,57	0	0	 	 	1099,87	864	85,5	27,7	ON	1100,18	864	16,1	2,06	2,35
    	1100,49	0	0	 	 	1100,8	864	85,5	27,7	ON	1101,09	832	16,1	2,06	2,46
    	1101,37	0	0	 	 	1101,66	864	85,5	27,7	ON	1101,95	864	16,1	2,06	2,24
    	1102,25	0	0	 	 	1102,52	832	85,5	27,7	ON	1102,81	832	16,1	2,06	2,53
    	1103,1	0	0	 	 	1103,38	864	85,5	27,7	ON	1103,69	832	16,1	2,06	2,09
    	1103,97	0	0	 	 	1104,28	832	85,5	27,7	ON	1104,58	864	16,1	2,06	2,17
    	1104,89	0	0	 	 	1105,18	832	85,5	27,7	ON	1105,5	832	16,1	2,06	2,31
    	1105,79	0	0	 	 	1106,08	832	85,5	27,7	ON	1106,36	832	16,1	2,06	2,55
    	1106,64	0	0	 	 	1106,93	864	85,5	27,7	ON	1107,23	864	16,1	2,06	2,44
    	1107,52	0	0	 	 	1107,82	832	85,5	27,7	ON	1108,12	864	17,3	2,06	2,26
    	1108,42	0	0	 	 	1108,7	832	85,5	27,7	ON	1108,98	832	16,1	2,06	2,12
    	1109,28	0	0	 	 	1109,56	832	85,5	27,7	ON	1109,83	864	16,1	2,06	2,42
    	1110,14	0	0	 	 	1110,43	832	85,5	27,7	ON	1110,72	832	16,1	2,06	2,21
    	1111,01	0	0	 	 	1111,29	864	85,5	27,7	ON	1111,57	832	16,1	2,06	1,98
    	1111,86	0	0	 	 	1112,15	832	85,5	27,7	ON	1112,42	832	16,1	2,06	2,44
    	1112,73	0	0	 	 	1113,04	864	85,5	27,7	ON	1113,32	832	16,1	2,06	2,14
    	1113,6	0	0	 	 	1113,88	832	85,5	27,7	ON	1114,16	832	16,1	2,06	2,56
    	1114,42	0	0	 	 	1114,73	832	85,5	27,7	ON	1115,03	832	16,1	2,06	2,53
    	1115,31	0	0	 	 	1115,62	832	85,5	27,7	ON	1115,92	864	17,3	2,06	2,33
    	1116,22	0	0	 	 	1116,51	832	85,5	27,7	ON	1116,81	832	17,3	2,06	2,6
    	1117,12	0	0	 	 	1117,4	864	85,5	27,7	ON	1117,7	864	17,3	2,06	2,37
    	1117,99	0	0	 	 	1118,3	864	85,5	27,7	ON	1118,59	832	16,1	2,06	2,31
    	1118,87	0	0	 	 	1119,16	832	85,5	27,7	ON	1119,46	832	17,3	2,06	2,48
    	1119,75	0	0	 	 	1120,03	832	85,5	27,7	ON	1120,31	832	17,3	2,06	2,38
    	1120,61	0	0	 	 	1120,91	864	85,5	27,7	ON	1121,22	832	16,1	2,06	2,43
    	1121,5	0	0	 	 	1121,8	864	85,5	27,7	ON	1122,1	864	16,1	2,06	2,13
    	1122,38	0	0	 	 	1122,67	832	85,5	27,7	ON	1122,97	832	16,1	2,06	2,47
    	1123,27	0	0	 	 	1123,57	864	85,5	27,7	ON	1123,85	864	16,1	2,06	2
    	1124,15	0	0	 	 	1124,46	832	85,5	27,7	ON	1124,76	832	16,1	2,06	2,68
    	1125,06	0	0	 	 	1125,35	864	85,5	27,7	ON	1125,62	832	16,1	2,06	2,24
    	1125,91	0	0	 	 	1126,19	832	85,5	27,7	ON	1126,46	832	16,1	2,06	2,32
    	1126,75	0	0	 	 	1127,05	832	85,5	27,7	ON	1127,34	864	16,1	2,06	2,31
    	1127,64	0	0	 	 	1127,92	864	85,5	27,7	ON	1128,21	864	16,1	2,06	2,29
    	1128,51	0	0	 	 	1128,79	832	85,5	27,7	ON	1129,1	864	16,1	2,06	2,27
    	1129,39	0	0	 	 	1129,67	832	85,5	27,7	ON	1129,95	832	16,1	2,06	2,46
    	1130,23	0	0	 	 	1130,51	832	85,5	27,7	ON	1130,8	864	16,1	2,06	2,33
    	1131,1	0	0	 	 	1131,38	832	85,5	27,7	ON	1131,69	832	16,1	2,06	2,34
    	1131,98	0	0	 	 	1132,29	832	85,5	27,7	ON	1132,56	832	17,3	2,06	2,43
    	1132,87	0	0	 	 	1133,16	864	85,5	27,7	ON	1133,45	864	17,3	2,06	2,33
    	1133,75	0	0	 	 	1134,06	832	85,5	27,7	ON	1134,34	864	16,1	2,06	2,52
    	1134,65	0	0	 	 	1134,94	832	85,5	27,7	ON	1135,21	832	16,1	2,06	2,43
    	1135,51	0	0	 	 	1135,8	864	85,5	27,7	ON	1136,09	864	16,1	2,06	2,43
    	1136,39	0	0	 	 	1136,67	832	85,5	27,7	ON	1136,97	832	17,3	2,06	2,54
    	1137,27	0	0	 	 	1137,56	832	85,5	27,7	ON	1137,86	832	16,1	2,06	2,28
    	1138,16	0	0	 	 	1138,45	864	85,5	27,7	ON	1138,74	864	16,1	2,06	2,28
    	1139,04	0	0	 	 	1139,34	832	85,5	27,7	ON	1139,62	832	17,3	2,06	2,55
    	1139,9	0	0	 	 	1140,2	864	85,5	27,7	ON	1140,51	864	16,1	2,06	2,43
    	1140,78	0	0	 	 	1141,08	864	85,5	27,7	ON	1141,39	864	16,1	2,06	2,39
    	1141,68	0	0	 	 	1141,97	832	85,5	27,7	ON	1142,28	864	17,3	2,06	2,53
    	1142,56	0	0	 	 	1142,87	864	85,5	27,7	ON	1143,17	864	17,3	2,06	2,47
    	1143,46	0	0	 	 	1143,75	864	85,5	27,7	ON	1144,05	864	16,1	2,06	2,33
    	1144,34	0	0	 	 	1144,64	864	85,5	27,7	ON	1144,95	832	16,1	2,06	2,31
    	1145,24	0	0	 	 	1145,52	832	85,5	27,7	ON	1145,79	832	16,1	2,06	2,44
    	1146,08	0	0	 	 	1146,35	832	85,5	27,7	ON	1146,65	864	17,3	2,06	2,44
    	1146,95	0	0	 	 	1147,25	832	85,5	27,7	ON	1147,55	864	17,3	2,06	2,5
    	1147,84	0	0	 	 	1148,15	864	85,5	27,7	ON	1148,45	864	16,1	2,06	2,34
    	1148,72	0	0	 	 	1148,99	832	85,5	27,7	ON	1149,28	832	17,3	2,06	2,26
    	1149,58	0	0	 	 	1149,86	832	85,5	27,7	ON	1150,15	832	16,1	2,06	2,24
    	1150,43	0	0	 	 	1150,72	832	85,5	27,7	ON	1151,01	832	16,1	2,06	2,37
    	1151,31	0	0	 	 	1151,6	832	85,5	27,7	ON	1151,89	832	16,1	2,06	2,38
    	1152,19	0	0	 	 	1152,5	832	85,5	27,7	ON	1152,8	864	16,1	2,06	2,31
    	1153,09	0	0	 	 	1153,39	864	85,5	27,7	ON	1153,7	832	16,1	2,06	2,33
    	1154	0	0	 	 	1154,29	832	85,5	27,7	ON	1154,6	832	17,3	2,06	2,41
    	1154,88	0	0	 	 	1155,16	832	85,5	27,7	ON	1155,45	832	17,3	2,06	2,38
    	1155,75	0	0	 	 	1156,05	832	85,5	27,7	ON	1156,34	832	17,3	2,06	2,57
    	1156,65	0	0	 	 	1156,92	864	85,5	27,7	ON	1157,21	832	17,3	2,06	2,47
    	1157,5	0	0	 	 	1157,78	864	85,5	27,7	ON	1158,07	864	16,1	2,06	2,35
    	1158,37	0	0	 	 	1158,67	864	85,5	27,7	ON	1158,97	864	16,1	2,06	2,43
    	1159,28	0	0	 	 	1159,56	864	85,5	27,7	ON	1159,85	832	16,1	2,06	2,37
    	1160,14	0	0	 	 	1160,46	832	85,5	27,7	ON	1160,74	832	16,1	2,06	2,19
    	1161,03	0	0	 	 	1161,31	832	85,5	27,7	ON	1161,59	832	16,1	2,06	2,36
    	1161,87	0	0	 	 	1162,15	832	85,5	27,7	ON	1162,42	864	16,1	2,06	2,42
    	1162,72	0	0	 	 	1163,03	864	85,5	27,7	ON	1163,33	832	16,1	2,06	2,3
    	1163,61	0	0	 	 	1163,9	832	85,5	27,7	ON	1164,2	832	16,1	2,06	2,33
    	1164,51	0	0	 	 	1164,79	832	85,5	27,7	ON	1165,09	832	17,3	2,06	2,39
    	1165,39	0	0	 	 	1165,7	864	85,5	27,7	ON	1166	864	16,1	2,06	2,38
    	1166,29	0	0	 	 	1166,58	832	85,5	27,7	ON	1166,88	832	17,3	2,06	2,5
    	1167,19	0	0	 	 	1167,47	864	85,5	27,7	ON	1167,76	864	16,1	2,06	2,24
    	1168,04	0	0	 	 	1168,34	832	85,5	27,7	ON	1168,64	864	16,1	2,06	2,37
    	1168,95	0	0	 	 	1169,21	832	85,5	27,7	ON	1169,52	832	16,1	2,06	2,33
    	1169,81	0	0	 	 	1170,08	832	85,5	27,7	ON	1170,39	864	16,1	2,06	2,1
    	1170,68	0	0	 	 	1170,97	832	85,5	27,7	ON	1171,27	832	16,1	2,06	2,33
    	1171,56	0	0	 	 	1171,87	832	85,5	27,7	ON	1172,18	832	16,1	2,06	2,29
    	1172,46	0	0	 	 	1172,76	864	85,5	27,7	ON	1173,05	832	16,1	2,06	2,54
    	1173,34	0	0	 	 	1173,64	864	85,5	27,7	ON	1173,93	864	16,1	2,06	2,35
    	1174,22	0	0	 	 	1174,52	864	85,5	27,7	ON	1174,81	832	16,1	2,06	2,29
    	1175,09	0	0	 	 	1175,37	832	85,5	27,7	ON	1175,67	832	16,1	2,06	2,03
    	1175,96	0	0	 	 	1176,27	832	85,5	27,7	ON	1176,54	832	17,3	2,06	2,51
    	1176,82	0	0	 	 	1177,12	832	85,5	27,7	ON	1177,4	864	17,3	2,06	2,48
    	1177,7	0	0	 	 	1177,99	864	85,5	27,7	ON	1178,29	864	16,1	2,06	2,59
    	1178,6	0	0	 	 	1178,91	832	85,5	27,7	ON	1179,19	864	17,3	2,06	2,44
    	1179,49	0	0	 	 	1179,79	864	85,5	27,7	ON	1180,1	864	16,1	2,06	2,3
    	1180,4	0	0	 	 	1180,68	864	85,5	27,7	ON	1180,97	832	16,1	2,06	2,52
    	1181,26	0	0	 	 	1181,54	832	85,5	27,7	ON	1181,84	864	16,1	2,06	2,28
    	1182,15	0	0	 	 	1182,43	864	85,5	27,7	ON	1182,71	832	16,1	2,06	2,6
    	1182,97	0	0	 	 	1183,3	832	85,5	27,7	ON	1183,58	864	16,1	2,06	2,4
    	1183,89	0	0	 	 	1184,16	832	85,5	27,7	ON	1184,48	832	17,3	2,06	2,49
    	1184,77	0	0	 	 	1185,05	864	85,5	27,7	ON	1185,36	864	16,1	2,06	2,52
    	1185,64	0	0	 	 	1185,95	832	87	27,7	ON	1186,23	832	17,3	2,06	2,42
    	1186,54	0	0	 	 	1186,85	832	85,5	27,7	ON	1187,15	832	16,1	2,06	2,34
    	1187,44	0	0	 	 	1187,72	832	85,5	27,7	ON	1188,02	832	16,1	2,06	2,44
    	1188,33	0	0	 	 	1188,63	832	85,5	27,7	ON	1188,92	864	17,3	2,06	2,47
    	1189,2	0	0	 	 	1189,47	832	85,5	27,7	ON	1189,78	864	16,1	2,06	2,23
    	1190,09	0	0	 	 	1190,36	864	85,5	27,7	ON	1190,66	864	16,1	2,06	2,32
    	1190,98	0	0	 	 	1191,26	864	85,5	27,7	ON	1191,56	832	16,1	2,06	2,24
    	1191,83	0	0	 	 	1192,16	832	85,5	27,7	ON	1192,45	832	16,1	2,06	2,34
    	1192,73	0	0	 	 	1193,01	864	85,5	27,7	ON	1193,31	832	16,1	2,06	2,37
    	1193,6	0	0	 	 	1193,91	864	87	27,7	ON	1194,2	864	16,1	2,06	2,24
    	1194,49	0	0	 	 	1194,75	832	85,5	27,7	ON	1195,06	832	16,1	2,06	2,39
    	1195,34	0	0	 	 	1195,65	832	85,5	27,7	ON	1195,91	832	16,1	2,06	2,47
    	1196,21	0	0	 	 	1196,49	832	85,5	27,7	ON	1196,78	864	16,1	2,06	2,3
    	1197,09	0	0	 	 	1197,37	864	85,5	27,7	ON	1197,67	832	16,1	2,06	2,38
    	1197,95	0	0	 	 	1198,24	832	85,5	27,7	ON	1198,52	832	16,1	2,06	2,35
    	1198,83	0	0	 	 	1199,17	1792	85,5	0	OFF	1199,53	1536	0	0	3,09
    	1199,85	0	0	 	 	1200,13	1312	85,5	0	ON	1200,45	1184	13,7	2,06	2,19
    	1200,77	0	0	 	 	1201,1	1024	85,5	0	ON	1201,39	960	17,3	2,06	3,21
    	1201,67	0	0	 	 	1201,99	960	85,5	0	ON	1202,25	992	19,2	3,09	3,14
    	1202,51	0	0	 	 	1202,85	960	87	-1,2	ON	1203,16	928	18,4	2,06	2,78
    	1203,46	0	0	 	 	1203,75	864	85,5	-3,9	ON	1204,06	864	19,2	2,06	2,4
    	1204,35	0	0	 	 	1204,66	832	85,5	-2,3	ON	1204,97	832	19,2	2,06	2,58
    	1205,26	0	0	 	 	1205,55	832	85,5	0,4	ON	1205,85	832	19,2	2,06	2,64
    	1206,14	0	0	 	 	1206,44	832	85,5	2,7	ON	1206,71	832	19,2	2,06	2,74
    	1206,98	0	0	 	 	1207,3	832	85,5	5,5	ON	1207,6	832	19,2	2,06	2,93
    	1207,9	0	0	 	 	1208,22	800	85,5	8,2	ON	1208,49	832	21,6	3,09	3,2
    	1208,78	0	0	 	 	1209,08	864	85,5	10,9	ON	1209,36	864	21,6	3,09	3,06
    	1209,63	0	0	 	 	1209,92	864	85,5	13,7	ON	1210,21	864	20,4	2,06	3,01
    	1210,51	0	0	 	 	1210,81	864	85,5	16,4	ON	1211,1	864	19,2	2,06	2,82
    	1211,41	0	0	 	 	1211,68	864	85,5	19,1	ON	1211,97	896	18,4	2,06	2,58
    	1212,24	0	0	 	 	1212,56	864	85,5	21,5	ON	1212,84	864	18,4	2,06	2,35
    	1213,14	0	0	 	 	1213,42	864	85,5	24,2	ON	1213,71	864	17,3	2,06	2,04
    	1214	0	0	 	 	1214,3	832	85,5	27	ON	1214,6	832	16,1	2,06	2,04
    	1214,87	0	0	 	 	1215,17	832	85,5	27,7	ON	1215,48	832	16,1	2,06	2,24
    	1215,78	0	0	 	 	1216,06	832	85,5	27,7	ON	1216,36	832	16,1	2,06	2,07
    	1216,65	0	0	 	 	1216,93	832	85,5	27,7	ON	1217,21	832	17,3	2,06	2,46
    	1217,5	0	0	 	 	1217,8	864	85,5	27,7	ON	1218,08	832	16,1	2,06	2,3
    	1218,38	0	0	 	 	1218,68	832	85,5	27,7	ON	1218,98	864	17,3	2,06	2,23
    	1219,33	0	0	 	 	1219,69	1536	85,5	24,2	ON	1220,06	1568	37,6	5,15	5,99
    	1220,35	0	0	 	 	1220,65	1280	85,5	18	ON	1220,96	1344	17,3	2,06	2,32
    	1221,27	0	0	 	 	1221,58	864	85,5	14,5	ON	1221,87	832	31,8	4,12	4,94
    	1222,16	0	0	 	 	1222,47	1056	85,5	15,2	ON	1222,78	1152	23,9	3,09	3,32
    	1223,09	0	0	 	 	1223,39	1248	85,5	15,6	ON	1223,71	1088	13,7	2,06	2,52
    	1224	0	0	 	 	1224,3	1056	85,5	12,9	ON	1224,6	992	16,1	2,06	2,68
    	1224,9	0	0	 	 	1225,21	960	85,5	12,5	ON	1225,51	1024	23,9	3,09	4,33
    	1225,83	0	0	 	 	1226,13	1088	85,5	14,5	ON	1226,46	1152	22,7	3,09	4,03
    	1226,77	0	0	 	 	1227,09	1216	85,5	17,2	ON	1227,39	1248	19,2	2,06	3,63
    	1227,72	0	0	 	 	1228,01	1248	85,5	21,1	ON	1228,34	1216	20,4	3,09	4,44
    	1228,65	0	0	 	 	1228,96	1280	85,5	25	ON	1229,28	1312	19,2	3,09	4,05
    	1229,61	0	0	 	 	1229,92	1344	85,5	27,7	ON	1230,24	1376	16,1	2,06	3,45
    	1230,59	0	0	 	 	1230,92	1376	85,5	21,9	ON	1231,26	1408	16,1	2,06	3,64
    	1231,58	0	0	 	 	1231,92	1376	85,5	19,9	ON	1232,24	1376	16,1	2,06	3,83
    	1232,56	0	0	 	 	1232,89	1376	85,5	24,2	ON	1233,23	1376	17,3	2,06	3,94
    	1233,56	0	0	 	 	1233,88	1376	85,5	26,2	ON	1234,23	1376	16,1	2,06	3,51
    	1234,54	0	0	 	 	1234,85	1344	85,5	21,9	ON	1235,16	1312	14,9	2,06	2,86
    	1235,46	0	0	 	 	1235,77	1312	85,5	20,7	ON	1236,08	1280	14,9	2,06	2,92
    	1236,38	0	0	 	 	1236,71	1280	85,5	25	ON	1237,03	1248	10,2	1,03	2,04
    	1237,36	0	0	 	 	1237,71	1280	85,5	24,6	ON	1238,03	1248	12,5	2,06	2,57
    	1238,33	0	0	 	 	1238,64	1280	85,5	27,7	ON	1238,97	1248	13,7	2,06	3,03
    	1239,27	0	0	 	 	1239,57	1216	85,5	27,7	ON	1239,9	1152	16,1	2,06	3,26
    	1240,22	0	0	 	 	1240,53	1184	85,5	27,7	ON	1240,82	1120	17,3	2,06	3,72
    	1241,15	0	0	 	 	1241,5	1184	85,5	27,7	ON	1241,81	1152	19,2	3,09	3,97
    	1242,13	0	0	 	 	1242,45	1280	85,5	27,7	ON	1242,77	1408	31	5,15	6,75
    	1243,05	0	0	 	 	1243,42	1600	85,5	27,7	ON	1243,76	1696	25,1	4,12	7,24
    	1244,08	0	0	 	 	1244,41	1376	85,5	0	ON	1244,75	1184	40	6,18	11,68
    	1245,1	0	0	 	 	1245,39	1184	85,5	0	ON	1245,72	1280	56,9	7,21	11,07
    	1246,02	0	0	 	 	1246,33	1504	85,5	0	ON	1246,66	1600	53,7	7,21	12,67
    	1247	0	0	 	 	1247,39	1824	85,5	2	ON	1247,73	1920	49	6,18	14,56
    	1248,08	0	0	 	 	1248,41	2144	85,5	15,2	ON	1248,73	2016	0	0	5,72
    	1249,06	0	0	 	 	1249,37	1280	85,5	0	ON	1249,67	1344	53,7	7,21	12,23
    	1249,99	0	0	 	 	1250,36	1408	85,5	0	ON	1250,71	1440	60,4	8,24	13,63
    	1250,98	0	0	 	 	1251,33	1504	85,5	0	ON	1251,69	1568	58	7,21	13,97
    	1252,05	0	0	 	 	1252,41	1632	85,5	4,3	ON	1252,76	1664	56,1	7,21	15,33
    	1253,1	0	0	 	 	1253,46	1760	85,5	17,6	ON	1253,81	1792	43,5	6,18	12,23
    	1254,17	0	0	 	 	1254,52	1824	85,5	20,7	ON	1254,88	1856	32,9	5,15	9,78
    	1255,24	0	0	 	 	1255,57	1856	85,5	20,7	ON	1255,9	1856	31,8	5,15	10,04
    	1256,26	0	0	 	 	1256,63	1888	85,5	25,8	ON	1256,99	1888	40	6,18	13,03
    	1257,35	0	0	 	 	1257,7	1952	85,5	15,6	ON	1258,05	1952	43,5	6,18	12,82
    	1258,4	0	0	 	 	1258,77	1984	85,5	18	ON	1259,11	1984	42,4	6,18	13,11
    	1259,47	0	0	 	 	1259,81	2016	85,5	23,4	ON	1260,15	2016	42,4	6,18	13,44
    	1260,5	0	0	 	 	1260,84	2048	85,5	24,2	ON	1261,17	2048	41,2	6,18	13,48
    	1261,52	0	0	 	 	1261,86	2080	85,5	23	ON	1262,2	2112	37,6	6,18	12,48
    	1262,54	0	0	 	 	1262,87	2112	85,5	22,7	ON	1263,22	2112	28,6	4,12	9,13
    	1263,58	0	0	 	 	1263,92	2080	85,5	21,5	ON	1264,27	2048	23,9	3,09	7,76
    	1264,63	0	0	 	 	1265	2016	85,5	23	ON	1265,36	1984	17,3	2,06	5,42
    	1265,73	0	0	 	 	1266,07	1920	85,5	14,8	ON	1266,43	1888	14,9	2,06	3,83
    	1266,79	0	0	 	 	1267,13	1824	85,5	14,8	ON	1267,46	1792	17,3	2,06	5,61
    	1267,8	0	0	 	 	1268,13	1760	85,5	22,7	ON	1268,46	1728	20,4	3,09	5,73
    	1268,82	0	0	 	 	1269,16	1664	85,5	27,7	ON	1269,5	1664	20,4	3,09	5,39
    	1269,81	0	0	 	 	1270,13	1632	85,5	27,7	ON	1270,48	1600	20,4	3,09	5,33
    	1270,83	0	0	 	 	1271,16	1600	85,5	25,4	ON	1271,52	1568	19,2	3,09	4,94
    	1271,87	0	0	 	 	1272,2	1568	85,5	23,8	ON	1272,51	1504	19,2	3,09	4,83
    	1272,83	0	0	 	 	1273,21	1536	85,5	27	ON	1273,48	1504	18,4	3,09	2,87
    	1273,77	0	0	 	 	1274,07	1248	85,5	24,6	ON	1274,37	1024	19,2	3,09	4,67
    	1274,65	0	0	 	 	1274,94	800	85,5	23,4	ON	1275,27	896	29,8	4,12	4,32
    	1275,59	0	0	 	 	1275,89	896	85,5	25	ON	1276,17	896	28,6	4,12	4,23
    	1276,48	0	0	 	 	1276,78	864	85,5	26,2	ON	1277,08	864	27,5	4,12	3,88
    	1277,38	0	0	 	 	1277,68	832	85,5	27,7	ON	1277,97	832	27,5	4,12	3,84
    	1278,25	0	0	 	 	1278,55	832	85,5	27,7	ON	1278,87	864	29,8	4,12	4,56
    	1279,19	0	0	 	 	1279,48	992	85,5	27,7	ON	1279,78	992	47,8	7,21	7,09
    	1280,09	0	0	 	 	1280,39	1024	85,5	24,6	ON	1280,7	1024	32,9	5,15	4,46
    	1280,99	0	0	 	 	1281,3	1024	85,5	21,5	ON	1281,59	1024	29,8	4,12	4,99
    	1281,92	0	0	 	 	1282,21	1024	85,5	20,7	ON	1282,54	992	29,8	4,12	4,78
    	1282,85	0	0	 	 	1283,16	1056	85,5	23,4	ON	1283,47	1024	31,8	4,12	5,31
    	1283,78	0	0	 	 	1284,09	1056	85,5	26,2	ON	1284,4	1056	27,5	4,12	4,14
    	1284,71	0	0	 	 	1285,02	1056	85,5	23,8	ON	1285,33	1088	21,6	3,09	3,57
    	1285,64	0	0	 	 	1285,96	1056	85,5	21,1	ON	1286,27	1056	21,6	3,09	3,54
    	1286,61	0	0	 	 	1286,91	960	85,5	19,1	ON	1287,2	992	22,7	3,09	3,86
    	1287,49	0	0	 	 	1287,8	864	85,5	20,7	ON	1288,08	832	27,5	4,12	4,23
    	1288,36	0	0	 	 	1288,64	832	85,5	21,9	ON	1288,94	864	28,6	4,12	3,91
    	1289,24	0	0	 	 	1289,55	864	85,5	23,4	ON	1289,85	864	27,5	4,12	3,79
    	1290,15	0	0	 	 	1290,46	864	85,5	24,6	ON	1290,75	864	31	4,12	5,79
    	1291,03	0	0	 	 	1291,33	896	85,5	25,8	ON	1291,64	832	31	4,12	3,96
    	1291,93	0	0	 	 	1292,24	896	85,5	26,6	ON	1292,54	864	26,3	4,12	3,83
    	1292,85	0	0	 	 	1293,16	864	85,5	25	ON	1293,45	864	25,1	4,12	3,61
    	1293,72	0	0	 	 	1294,03	832	85,5	23,8	ON	1294,33	832	25,1	3,09	3,58
    	1294,63	0	0	 	 	1294,93	832	85,5	22,3	ON	1295,22	832	25,1	3,09	3,74
    	1295,52	0	0	 	 	1295,82	832	85,5	21,1	ON	1296,12	832	26,3	4,12	3,65
    	1296,42	0	0	 	 	1296,72	832	85,5	19,5	ON	1297,02	896	28,6	4,12	3,63
    	1297,3	0	0	 	 	1297,61	832	85,5	21,1	ON	1297,92	832	27,5	4,12	3,75
    	1298,21	0	0	 	 	1298,52	832	85,5	22,3	ON	1298,81	832	28,6	4,12	3,63
    	1299,1	0	0	 	 	1299,41	832	85,5	23,8	ON	1299,69	832	28,6	4,12	3,91
    	1299,97	0	0	 	 	1300,27	832	85,5	25	ON	1300,58	864	28,6	4,12	3,91
    	1300,88	0	0	 	 	1301,2	864	85,5	26,2	ON	1301,5	864	27,5	4,12	3,89
    	1301,79	0	0	 	 	1302,09	864	85,5	25	ON	1302,39	896	27,5	4,12	3,85
    	1302,67	0	0	 	 	1302,97	864	85,5	23,4	ON	1303,27	864	26,3	4,12	3,79
    	1303,58	0	0	 	 	1303,89	864	85,5	22,3	ON	1304,2	864	25,1	3,09	3,62
    	1304,48	0	0	 	 	1304,79	864	85,5	20,7	ON	1305,1	928	27,5	4,12	4,13
    	1305,39	0	0	 	 	1305,68	896	85,5	20,7	ON	1305,96	928	27,5	4,12	3,83
    	1306,25	0	0	 	 	1306,59	960	85,5	22,3	ON	1306,89	960	23,9	3,09	3,48
    	1307,18	0	0	 	 	1307,5	992	85,5	21,1	ON	1307,82	1024	22,7	3,09	3,71
    	1308,12	0	0	 	 	1308,43	1024	85,5	19,5	ON	1308,75	1056	21,6	3,09	3,56
    	1309,06	0	0	 	 	1309,37	1056	85,5	20,7	ON	1309,67	1056	20,4	3,09	3,49
    	1309,97	0	0	 	 	1310,27	1088	85,5	23	ON	1310,58	1056	20,4	3,09	3,29
    	1310,88	0	0	 	 	1311,21	1056	85,5	26,2	ON	1311,54	1088	19,2	3,09	3,4
    	1311,86	0	0	 	 	1312,16	1088	85,5	27	ON	1312,46	1088	19,2	3,09	3,38
    	1312,77	0	0	 	 	1313,11	1120	85,5	24,2	ON	1313,44	1088	19,2	3,09	3,45
    	1313,75	0	0	 	 	1314,07	1120	85,5	22,7	ON	1314,4	1120	19,2	3,09	3,38
    	1314,7	0	0	 	 	1315,01	1120	85,5	25,4	ON	1315,32	1056	20,4	3,09	3,67
    	1315,63	0	0	 	 	1315,93	1120	85,5	27,7	ON	1316,23	1120	22,7	3,09	4,29
    	1316,52	0	0	 	 	1316,84	1120	85,5	27,7	ON	1317,12	1152	22,7	3,09	4,22
    	1317,42	0	0	 	 	1317,75	1120	85,5	27,7	ON	1318,06	1152	21,6	3,09	4
    	1318,38	0	0	 	 	1318,69	1152	87	27	ON	1318,97	1152	18,4	3,09	3,39
    	1319,3	0	0	 	 	1319,61	1152	87	24,2	ON	1319,92	1152	19,2	3,09	3,89
    	1320,23	0	0	 	 	1320,53	1120	85,5	26,6	ON	1320,84	1120	20,4	3,09	4,45
    	1321,17	0	0	 	 	1321,48	1120	85,5	27,7	ON	1321,79	1152	21,6	3,09	4,23
    	1322,12	0	0	 	 	1322,41	1152	87	27,7	ON	1322,72	1152	21,6	3,09	4,14
    	1323,04	0	0	 	 	1323,36	1152	85,5	27,7	ON	1323,66	1184	20,4	3,09	3,89
    	1324,01	0	0	 	 	1324,32	1216	87	27,7	ON	1324,64	1216	19,2	3,09	3,64
    	1324,95	0	0	 	 	1325,28	1216	85,5	25,8	ON	1325,62	1248	18,4	2,06	3,38
    	1325,95	0	0	 	 	1326,25	1216	85,5	22,7	ON	1326,56	1216	17,3	2,06	3,28
    	1326,87	0	0	 	 	1327,19	1248	85,5	23,8	ON	1327,52	1216	17,3	2,06	3,43
    	1327,84	0	0	 	 	1328,14	1216	85,5	27	ON	1328,47	1216	17,3	2,06	3,43
    	1328,77	0	0	 	 	1329,1	1216	85,5	25,8	ON	1329,43	1216	17,3	2,06	3,51
    	1329,75	0	0	 	 	1330,04	1216	87	24,6	ON	1330,34	1184	18,4	3,09	3,55
    	1330,64	0	0	 	 	1330,95	1152	87	27,3	ON	1331,26	1184	20,4	3,09	4,46
    	1331,55	0	0	 	 	1331,85	1152	85,5	27,7	ON	1332,17	1184	23,9	3,09	4,93
    	1332,47	0	0	 	 	1332,78	1152	87	27,7	ON	1333,1	1152	23,9	3,09	4,72
    	1333,42	0	0	 	 	1333,74	1184	85,5	27,7	ON	1334,04	1152	22,7	3,09	4,54
    	1334,35	0	0	 	 	1334,67	1152	85,5	27,7	ON	1334,99	1152	22,7	3,09	4,21
    	1335,31	0	0	 	 	1335,64	1184	85,5	27,7	ON	1335,95	1184	21,6	3,09	4,22
    	1336,26	0	0	 	 	1336,58	1152	85,5	27,7	ON	1336,88	1184	21,6	3,09	3,99
    	1337,17	0	0	 	 	1337,48	1184	85,5	27,7	ON	1337,8	1184	20,4	3,09	4,06
    	1338,12	0	0	 	 	1338,43	1184	85,5	27,7	ON	1338,76	1152	20,4	3,09	4,13
    	1339,08	0	0	 	 	1339,37	1152	85,5	27,7	ON	1339,67	1184	20,4	3,09	4,02
    	1339,97	0	0	 	 	1340,27	1152	85,5	27,7	ON	1340,59	1152	20,4	3,09	4,03
    	1340,88	0	0	 	 	1341,21	1152	85,5	27,7	ON	1341,53	1184	20,4	3,09	4,28
    	1341,83	0	0	 	 	1342,14	1152	85,5	27,7	ON	1342,47	1088	18,4	3,09	3,6
    	1342,77	0	0	 	 	1343,06	832	85,5	27,7	ON	1343,36	896	27,5	4,12	4,14
    	1343,65	0	0	 	 	1343,94	896	85,5	27,7	ON	1344,23	896	26,3	4,12	3,87
    	1344,54	0	0	 	 	1344,84	832	85,5	27,7	ON	1345,15	864	26,3	4,12	3,83
    	1345,46	0	0	 	 	1345,75	864	85,5	27,7	ON	1346,05	832	25,1	4,12	3,79
    	1346,34	0	0	 	 	1346,63	864	85,5	27,7	ON	1346,94	864	25,1	4,12	3,54
    	1347,24	0	0	 	 	1347,52	832	85,5	27,7	ON	1347,81	800	25,1	4,12	3,79
    	1348,09	0	0	 	 	1348,4	864	85,5	27,7	ON	1348,69	864	27,5	4,12	3,97
    	1348,98	0	0	 	 	1349,29	832	85,5	27,7	ON	1349,57	864	27,5	4,12	3,73
    	1349,87	0	0	 	 	1350,15	864	85,5	27,7	ON	1350,47	1344	49	7,21	3,14
    	1350,79	0	0	 	 	1351,14	1632	85,5	21,1	ON	1351,55	1472	17,3	2,06	3,67
    	1351,9	0	0	 	 	1352,21	1376	85,5	12,9	ON	1352,52	896	32,9	4,12	5,98
    	1352,84	0	0	 	 	1353,16	1216	85,5	13,3	ON	1353,49	1152	19,2	2,06	5,54
    	1353,8	0	0	 	 	1354,11	800	85,5	15,6	ON	1354,41	864	31,8	4,12	4,2
    	1354,69	0	0	 	 	1354,99	896	85,5	16,8	ON	1355,27	896	29,8	4,12	4,16
    	1355,56	0	0	 	 	1355,86	832	85,5	18,4	ON	1356,16	864	27,5	4,12	3,48
    	1356,45	0	0	 	 	1356,76	832	85,5	19,5	ON	1357,06	832	25,1	3,09	3,43
    	1357,35	0	0	 	 	1357,66	832	85,5	21,1	ON	1357,95	832	26,3	4,12	3,53
    	1358,26	0	0	 	 	1358,55	832	85,5	22,3	ON	1358,81	832	26,3	4,12	3,61
    	1359,09	0	0	 	 	1359,39	832	85,5	21,5	ON	1359,82	864	26,3	4,12	3,63
    	1360,11	0	0	 	 	1360,6	864	85,5	18,4	ON	1360,84	864	26,3	3,09	3,63
    	1361,14	0	0	 	 	1361,44	832	85,5	15,2	ON	1361,73	832	26,3	3,09	3,59
    	1362,02	0	0	 	 	1362,32	832	85,5	17,6	ON	1362,61	864	26,3	3,09	3,69
    	1362,91	0	0	 	 	1363,2	864	85,5	20,3	ON	1363,5	832	26,3	4,12	3,64
    MAF average 3.62g/s
    Friday	21	June	2019	17:50:52:00008-VCID:1E3368789AB7DDBF84-515A	VCDS Version: Release 19,6,0 (x64)	Data version: 20190529 DS308,0
    3B0 906 018 A		1,6l/2V SIMOS3 G00HS0009
    	Group A:	'032				Group B:	'099				Group C:	'002
    		Adaptation (Idle)	Adaptation (Partial)	 	 		Engine Speed	Coolant	Lambda Control	Lambda Control		Engine Speed	Engine Load	Injection Timing	Mass Air Flow
    	TIME	Bank 1 Sensor 1	Bank 1 Sensor 1			TIME	(G28)	Temperature (G62)		Status	TIME	(G28)			Sensor (G70)
    Marker	STAMP	 %	 %			STAMP	 /min	C	 %		STAMP	 /min	 %	 ms	 g/s
    	0,48	0	0	 	 	0,75	0	87	0	OFF	0,22	0	0	2,06	0
    	1,29	0	0	 	 	1,62	832	87	0	OFF	1,01	0	0	2,06	0
    	2,26	0	0	 	 	2,54	960	87	0	OFF	1,93	1280	35,3	6,18	3,12
    	3,14	0	0	 	 	3,44	864	87	0	OFF	2,84	896	22,7	3,09	3,55
    	4,07	0	0	 	 	4,36	864	87	0	OFF	3,75	896	25,1	3,09	3,45
    	4,96	0	0	 	 	5,25	864	87	0	OFF	4,68	896	23,9	3,09	3,27
    	5,82	0	0	 	 	6,11	864	87	0	OFF	5,53	864	22,7	3,09	2,94
    	6,7	0	0	 	 	7,01	864	87	0	OFF	6,42	832	21,6	3,09	2,78
    	7,6	0	0	 	 	7,89	864	87	0	OFF	7,29	864	21,6	2,06	2,51
    	8,48	0	0	 	 	8,79	832	87	0	OFF	8,18	832	21,6	2,06	2,66
    	9,39	0	0	 	 	9,69	832	87	0	OFF	9,09	832	21,6	2,06	2,58
    	10,28	0	0	 	 	10,56	832	87	0	OFF	9,99	832	21,6	2,06	2,44
    	11,12	0	0	 	 	11,38	832	87	0	OFF	10,83	832	21,6	2,06	2,69
    	11,97	0	0	 	 	12,26	832	87	0	OFF	11,69	832	21,6	2,06	2,82
    	12,83	0	0	 	 	13,14	832	87	0	OFF	12,55	832	21,6	2,06	2,92
    	13,75	0	0	 	 	14,05	832	87	0	OFF	13,44	864	32,9	4,12	4,82
    	14,65	0	0	 	 	14,94	864	87	0	OFF	14,35	832	36,5	4,12	4,88
    	15,55	0	0	 	 	15,84	832	87	0	OFF	15,25	864	35,3	4,12	4,38
    	16,43	0	0	 	 	16,72	800	87	0	OFF	16,14	832	32,9	4,12	4,11
    	17,32	0	0	 	 	17,63	832	87	0	OFF	17,01	800	32,9	4,12	4,47
    	18,18	0	0	 	 	18,49	832	87	0	OFF	17,91	832	35,3	4,12	4,62
    	19,07	0	0	 	 	19,38	832	87	0	OFF	18,79	832	36,5	4,12	4,65
    	19,97	0	0	 	 	20,27	832	87	0	OFF	19,66	832	36,5	4,12	5
    	20,85	0	0	 	 	21,16	832	87	0	OFF	20,55	832	36,5	4,12	5,07
    	21,77	0	0	 	 	22,08	864	87	0	OFF	21,46	832	37,6	4,12	5,23
    	22,67	0	0	 	 	22,97	832	87	0	OFF	22,37	832	37,6	4,12	5,29
    	23,55	0	0	 	 	23,83	864	87	2,3	ON	23,26	832	37,6	4,12	5,39
    	24,45	0	0	 	 	24,76	864	87	5,1	ON	24,14	864	37,6	4,12	5,14
    	25,36	0	0	 	 	25,66	864	87	7,8	ON	25,05	896	36,5	4,12	5,09
    	26,27	0	0	 	 	26,55	896	87	10,5	ON	25,97	896	35,3	4,12	4,8
    	27,16	0	0	 	 	27,47	864	87	13,3	ON	26,87	896	31,8	4,12	4,62
    	28,05	0	0	 	 	28,33	896	87	16	ON	27,75	896	31	4,12	4,22
    	28,9	0	0	 	 	29,19	864	87	18,8	ON	28,61	896	28,6	4,12	4,19
    	29,76	0	0	 	 	30,05	864	87	21,1	ON	29,46	864	27,5	4,12	3,81
    	30,63	0	0	 	 	30,93	864	87	23,8	ON	30,34	864	26,3	4,12	3,49
    	31,54	0	0	 	 	31,83	864	87	25,4	ON	31,25	864	26,3	4,12	3,52
    	32,43	0	0	 	 	32,74	832	87	22,7	ON	32,14	864	25,1	3,09	3,37
    	33,32	0	0	 	 	33,62	832	87	19,9	ON	33,03	832	25,1	3,09	3,32
    	34,21	0	0	 	 	34,52	832	87	17,2	ON	33,92	832	25,1	3,09	3,37
    	35,12	0	0	 	 	35,39	832	87	14,5	ON	34,82	832	25,1	3,09	3,4
    	35,98	0	0	 	 	36,28	832	87	11,7	ON	35,69	832	26,3	3,09	3,28
    	36,87	0	0	 	 	37,19	832	87	9	ON	36,57	832	26,3	3,09	3,43
    	37,77	0	0	 	 	38,05	832	87	10,2	ON	37,48	832	27,5	3,09	3,57
    	38,62	0	0	 	 	38,93	864	87	12,9	ON	38,33	832	27,5	3,09	3,63
    	39,56	0	0	 	 	39,86	864	87	15,6	ON	39,24	864	27,5	3,09	3,69
    	40,46	0	0	 	 	40,78	864	87	18,4	ON	40,16	864	27,5	3,09	3,69
    	41,38	0	0	 	 	41,68	864	87	21,1	ON	41,08	864	26,3	3,09	3,68
    	42,28	0	0	 	 	42,58	864	87	19,1	ON	41,97	864	26,3	3,09	3,51
    	43,19	0	0	 	 	43,5	832	87	16,4	ON	42,89	864	25,1	3,09	3,57
    	44,08	0	0	 	 	44,37	832	87	16,4	ON	43,79	832	25,1	3,09	3,43
    	44,93	0	0	 	 	45,23	832	87	19,1	ON	44,65	832	25,1	3,09	3,39
    	45,82	0	0	 	 	46,13	864	87	21,5	ON	45,52	832	25,1	3,09	3,49
    	46,71	0	0	 	 	47,01	864	87	18,8	ON	46,41	832	25,1	3,09	3,57
    	47,62	0	0	 	 	47,92	832	87	16,4	ON	47,31	832	25,1	3,09	3,44
    	48,51	0	0	 	 	48,8	832	87	19,1	ON	48,2	832	25,1	3,09	3,54
    	49,36	0	0	 	 	49,66	864	87	21,9	ON	49,08	832	25,1	3,09	3,42
    	50,26	0	0	 	 	50,56	864	87	21,5	ON	49,96	832	25,1	3,09	3,45
    	51,14	0	0	 	 	51,42	832	87	18,8	ON	50,85	864	25,1	3,09	3,37
    	51,98	0	0	 	 	52,26	832	87	19,5	ON	51,7	832	25,1	3,09	3,58
    	52,85	0	0	 	 	53,15	864	87	22,3	ON	52,56	832	25,1	3,09	3,46
    	53,74	0	0	 	 	54,02	832	87	24,2	ON	53,44	864	25,1	3,09	3,53
    	54,61	0	0	 	 	54,9	832	87	21,5	ON	54,32	864	25,1	3,09	3,46
    	55,48	0	0	 	 	55,77	832	87	20,3	ON	55,19	864	25,1	3,09	3,44
    	56,35	0	0	 	 	56,65	832	87	22,7	ON	56,05	832	25,1	3,09	3,49
    	57,25	0	0	 	 	57,55	864	87	25,4	ON	56,95	832	25,1	3,09	3,51
    	58,16	0	0	 	 	58,45	864	87	24,6	ON	57,85	864	25,1	4,12	3,48
    	59,07	0	0	 	 	59,37	864	87	21,9	ON	58,74	864	25,1	3,09	3,43
    	59,97	0	0	 	 	60,27	832	87	22,3	ON	59,67	832	23,9	3,09	3,55
    	60,88	0	0	 	 	61,17	864	87	25	ON	60,57	832	25,1	3,09	3,58
    	61,79	0	0	 	 	62,08	864	87	24,6	ON	61,48	864	25,1	4,12	3,57
    	62,71	0	0	 	 	63,01	832	87	21,9	ON	62,39	864	25,1	3,09	3,46
    	63,61	0	0	 	 	63,9	832	87	22,3	ON	63,3	832	25,1	3,09	3,51
    	64,49	0	0	 	 	64,78	832	87	25	ON	64,19	864	25,1	3,09	3,48
    	65,41	0	0	 	 	65,72	864	87	27	ON	65,08	864	25,1	4,12	3,49
    	66,31	0	0	 	 	66,61	864	87	24,2	ON	66,02	864	25,1	3,09	3,47
    	67,2	0	0	 	 	67,48	832	87	21,5	ON	66,9	864	25,1	3,09	3,63
    	68,09	0	0	 	 	68,39	832	87	21,9	ON	67,79	832	25,1	3,09	3,55
    	69,01	0	0	 	 	69,32	832	87	25	ON	68,7	864	25,1	3,09	3,58
    	69,93	0	0	 	 	70,22	864	87	25,8	ON	69,62	864	25,1	4,12	3,48
    	70,83	0	0	 	 	71,13	832	87	23	ON	70,52	864	25,1	3,09	3,57
    	71,76	0	0	 	 	72,04	832	87	20,7	ON	71,44	832	25,1	3,09	3,58
    	72,61	0	0	 	 	72,91	832	87	23	ON	72,32	832	25,1	3,09	3,57
    	73,5	0	0	 	 	73,81	832	87	25,8	ON	73,21	864	25,1	3,09	3,56
    	74,42	0	0	 	 	74,72	864	87	24,6	ON	74,11	832	25,1	4,12	3,51
    	75,32	0	0	 	 	75,6	832	87	21,9	ON	75,03	864	23,9	3,09	3,49
    	76,16	0	0	 	 	76,44	832	87	23,4	ON	75,88	832	23,9	3,09	3,45
    	77,02	0	0	 	 	77,31	864	87	26,2	ON	76,74	864	25,1	3,09	3,49
    	77,91	0	0	 	 	78,19	832	87	26,2	ON	77,6	864	23,9	3,09	3,47
    	78,79	0	0	 	 	79,08	832	87	23,4	ON	78,5	832	23,9	3,09	3,44
    	79,64	0	0	 	 	79,92	832	87	23,4	ON	79,36	832	23,9	3,09	3,42
    	80,48	0	0	 	 	80,76	832	87	25,8	ON	80,2	832	23,9	3,09	3,49
    	81,37	0	0	 	 	81,67	864	87	26,2	ON	81,07	864	23,9	3,09	3,36
    	82,25	0	0	 	 	82,54	832	87	23,4	ON	81,96	832	23,9	3,09	3,45
    	83,13	0	0	 	 	83,43	832	87	22,7	ON	82,82	832	23,9	3,09	3,51
    	84	0	0	 	 	84,3	864	87	25,4	ON	83,71	832	23,9	3,09	3,45
    	84,89	0	0	 	 	85,18	832	87	25,8	ON	84,59	864	23,9	3,09	3,44
    	85,76	0	0	 	 	86,06	832	87	23	ON	85,46	832	23,9	3,09	3,37
    	86,65	0	0	 	 	86,95	832	87	21,9	ON	86,36	832	23,9	3,09	3,36
    	87,52	0	0	 	 	87,8	832	87	24,6	ON	87,24	832	23,9	3,09	3,38
    	88,36	0	0	 	 	88,66	832	87	27,3	ON	88,08	832	23,9	3,09	3,57
    	89,22	0	0	 	 	89,52	864	87	26,2	ON	88,94	864	23,9	3,09	3,42
    	90,12	0	0	 	 	90,44	864	87	23	ON	89,83	864	23,9	3,09	3,47
    	91,03	0	0	 	 	91,33	832	87	21,5	ON	90,74	832	25,1	3,09	3,61
    	91,91	0	0	 	 	92,2	832	87	24,2	ON	91,62	832	25,1	3,09	3,41
    	92,8	0	0	 	 	93,11	864	87	27	ON	92,49	864	25,1	3,09	3,39
    	93,72	0	0	 	 	94,02	864	87	25,4	ON	93,41	832	23,9	3,09	3,54
    	94,62	0	0	 	 	94,89	832	87	22,7	ON	94,31	864	23,9	3,09	3,46
    	95,68	0	0	 	 	95,96	832	87	24,2	ON	95,2	832	25,1	3,09	3,54
    	96,66	0	0	 	 	96,96	864	87	27,3	ON	96,43	832	23,9	3,09	3,4
    	97,55	0	0	 	 	97,84	864	87	27	ON	97,25	864	23,9	3,09	3,55
    	98,42	0	0	 	 	98,73	832	87	24,2	ON	98,14	832	23,9	3,09	3,47
    	99,33	0	0	 	 	99,61	832	87	22,7	ON	99,02	832	25,1	3,09	3,47
    	100,18	0	0	 	 	100,47	864	87	25	ON	99,89	864	25,1	3,09	3,38
    I will isolate brake booster from intake, unplug N80 and N156, block SAI port one by one, repeat logs and check IAT reading before and after current log session but it should be normal. (4th measuring group will degrade sample rate under 1.0x).
    Sorry for misaligned column headers and actual data.
    Can't understand why fuel trims are not consistent in every log. There are some variable/-s I don't know of
    Can bad MAF act different because of hot vs cold air temperature in engine bay itself?
  6. Likes Uwe, Jack@European_Parts liked this post
  7. #15
    What about PCV.....this can run interference with n80 & LDP if supported + brake booster.
    "Any" multiplicative air leaks can cause this shit!
    The OXS could indeed be contaminated or faulty!
    Additionally bad fuel injectors or faulty ECU.
    Be sure ECT and IAT reflect proper readings during all transitions.
  8. Likes _Val liked this post
  9. #16
    Nov 2017
    Latvia
    What can I do about PCV system?
    Unplugging N80 didn't change anything in fuel trims. Rechecked vacuum holding today. Perfect from engine side. "Normal" from atmosphere side (dropping a little).
    No LDP in this car.
    My first guess was leaking brake booster.
    Disconnecting it (some vacuum "escaped" from the pipe) and plugging intake side shut just made car not having brakes. All trims were still misterious.
    Yes, I tried driving it on closed road to see actual trims at partial throttle.
    This exact car has no one-way valve in vacuum pipe but I found option that had it. I might just buy it as it's a better part than mine.
    http://trshop.audi.de/konakart/Selec...IPE&model=0001
    Next part in question which could potentially make a big leak is Kombi valve for a SAI system.
    Took it off, checked vacuum membrane (ok), how it opens/closed (visually ok). Anyway put a metallic gasket under it and bolted it back, removed SAI fuse did some logging again
    I guess it can stuck open at higher temperature and still be ok with cold engine.
    STFT is still high, but it's first time in long time LTFT started to change.
    In the first seconds STFT gets negative... I suppose it's because of blocked SAI as engine is waiting for extra air but it's not getting "in".
    Tuesday	25	June	2019	19:46:05:00008-VCID:1E3368789AB7DDBF84-5178	VCDS Version: Release 19,6,0 (x64)	Data version: 20190529 DS308,0
    	0,52	0	0	 	 	0,79	0	45	0	OFF	0,25	0	0	0	0
    	1,33	0	0	 	 	1,59	0	45	0	OFF	1,06	0	0	0	0
    	2,18	0	0	 	 	2,51	1344	45	0	OFF	1,87	192	68,6	28,84	3,48
    	3,11	0	0	 	 	3,47	960	45	0	OFF	2,82	928	32,9	9,27	5,16
    	4,1	0	0	 	 	4,46	960	45	0	OFF	3,83	992	31,8	4,12	4,96
    	5,02	0	0	 	 	5,31	960	45	0	OFF	4,73	960	28,6	4,12	4,63
    	5,9	0	0	 	 	6,2	928	45	0	OFF	5,61	928	27,5	4,12	4,36
    	6,79	0	0	 	 	7,09	896	45	0	OFF	6,5	928	25,1	3,09	3,89
    	7,69	0	0	 	 	7,98	864	45	0	OFF	7,39	896	23,9	3,09	3
    	8,58	0	0	 	 	8,88	864	45	0	OFF	8,28	864	23,9	3,09	2,84
    	9,47	0	0	 	 	9,76	864	45	0	OFF	9,17	864	23,9	3,09	3,26
    	10,36	0	0	 	 	10,65	864	45	0	OFF	10,06	864	23,9	3,09	3,18
    	11,26	0	0	 	 	11,55	864	45	0	OFF	10,95	864	23,9	3,09	3,28
    	12,13	0	0	 	 	12,44	864	45	0	OFF	11,84	864	23,9	3,09	3,26
    	13,06	0	0	 	 	13,34	864	45	0	OFF	12,74	864	23,9	3,09	3,46
    	13,92	0	0	 	 	14,22	864	45	0	OFF	13,62	864	23,9	3,09	3,46
    	14,84	0	0	 	 	15,14	864	45	0	OFF	14,54	896	22,7	3,09	3,23
    	15,75	0	0	 	 	16,06	864	45	0	OFF	15,46	864	23,9	3,09	3,14
    	16,65	0	0	 	 	16,92	864	45	0	OFF	16,36	864	23,9	3,09	3,42
    	17,51	0	0	 	 	17,8	864	45	0	OFF	17,22	864	23,9	3,09	3,31
    	18,39	0	0	 	 	18,71	864	45	0	OFF	18,09	864	22,7	3,09	3,41
    	19,28	0	0	 	 	19,6	864	45	0	OFF	18,99	864	22,7	3,09	3,4
    	20,21	0	0	 	 	20,51	864	45	0	OFF	19,9	864	23,9	3,09	3,49
    	21,11	0	0	 	 	21,4	864	45	0	OFF	20,81	896	22,7	3,09	3,31
    	22	0	0	 	 	22,29	864	45	0	OFF	21,71	864	22,7	3,09	3,32
    	22,88	0	0	 	 	23,19	864	45	0	OFF	22,59	896	23,9	3,09	3,26
    	23,8	0	0	 	 	24,09	864	45	0	OFF	23,5	864	22,7	3,09	3,51
    	24,69	0	0	 	 	24,98	864	45	0	OFF	24,38	864	23,9	3,09	3,33
    	25,56	0	0	 	 	25,85	864	45	0	OFF	25,27	864	22,7	3,09	3,04
    	26,44	0	0	 	 	26,73	864	45	0	OFF	26,15	864	22,7	3,09	3,28
    	27,33	0	0	 	 	27,64	864	45	0	OFF	27,03	864	22,7	3,09	3,32
    	28,24	0	0	 	 	28,51	864	45	0	OFF	27,93	864	23,9	3,09	3,51
    	29,13	0	0	 	 	29,42	864	45	0	OFF	28,81	864	22,7	3,09	3,36
    	30,02	0	0	 	 	30,3	864	45	0	OFF	29,73	864	23,9	3,09	3,57
    	30,9	0	0	 	 	31,2	864	46,5	0	OFF	30,61	864	23,9	3,09	3,42
    	31,79	0	0	 	 	32,09	864	46,5	0	OFF	31,5	864	22,7	3,09	3,33
    	32,68	0	0	 	 	32,98	864	46,5	0	OFF	32,39	864	22,7	3,09	3,33
    	33,57	0	0	 	 	33,87	864	46,5	0	OFF	33,28	864	23,9	3,09	3,48
    	34,46	0	0	 	 	34,76	864	46,5	0	OFF	34,16	864	23,9	3,09	3,59
    	35,36	0	0	 	 	35,68	864	46,5	0	OFF	35,05	864	23,9	3,09	3,44
    	36,26	0	0	 	 	36,56	864	46,5	0	OFF	35,98	864	23,9	3,09	3,35
    	37,17	0	0	 	 	37,46	864	46,5	0	OFF	36,87	864	23,9	3,09	3,49
    	38,04	0	0	 	 	38,33	864	46,5	0	OFF	37,75	864	22,7	3,09	3,58
    	38,93	0	0	 	 	39,25	864	46,5	0	OFF	38,63	864	23,9	3,09	3,51
    	39,84	0	0	 	 	40,15	864	46,5	0	OFF	39,55	864	23,9	3,09	3,28
    	40,73	0	0	 	 	41,02	864	46,5	0	OFF	40,44	864	23,9	3,09	3,69
    	41,61	0	0	 	 	41,89	864	46,5	0	OFF	41,31	864	23,9	3,09	3,59
    	42,47	0	0	 	 	42,76	864	46,5	0	OFF	42,18	864	23,9	3,09	3,47
    	43,37	0	0	 	 	43,66	864	46,5	-2,7	ON	43,07	864	23,9	3,09	3,54
    	44,26	0	0	 	 	44,57	864	46,5	-5,5	ON	43,96	832	23,9	3,09	3,86
    	45,16	0	0	 	 	45,47	832	46,5	-8,2	ON	44,86	864	25,1	3,09	3,63
    	46,06	0	0	 	 	46,37	832	46,5	-10,9	ON	45,76	832	26,3	3,09	4,08
    	46,98	0	0	 	 	47,29	800	46,5	-13,7	ON	46,68	864	28,6	3,09	4,12
    	47,89	0	0	 	 	48,2	864	46,5	-16,8	ON	47,59	832	31,8	3,09	4,49
    	48,76	0	0	 	 	49,08	832	46,5	-19,1	ON	48,48	832	32,9	3,09	4,83
    	49,64	0	0	 	 	49,93	832	46,5	-21,9	ON	49,35	832	35,3	3,09	5,12
    	50,53	0	0	 	 	50,81	864	46,5	-24,6	ON	50,23	832	38,8	3,09	5,64
    	51,39	0	0	 	 	51,68	896	46,5	-27,3	ON	51,1	832	42,4	4,12	6,04
    	52,26	0	0	 	 	52,56	896	48	-28,1	ON	51,97	832	41,2	3,09	6,13
    	53,14	0	0	 	 	53,42	832	48	-28,1	ON	52,85	896	45,5	4,12	6,39
    	54,01	0	0	 	 	54,28	864	48	-28,1	ON	53,72	832	46,7	4,12	6,32
    	54,88	0	0	 	 	55,18	832	48	-28,1	ON	54,59	864	46,7	4,12	6,12
    	55,74	0	0	 	 	56,04	768	48	-28,1	ON	55,47	800	53,7	5,15	8,81
    	56,62	0	0	 	 	56,91	864	48	-28,1	ON	56,34	800	56,9	5,15	7,89
    	57,51	0	0	 	 	57,82	896	48	-28,1	ON	57,2	896	51,4	5,15	7,26
    	58,39	0	0	 	 	58,69	864	48	-28,1	ON	58,1	896	50,2	4,12	7,38
    	59,26	0	0	 	 	59,56	864	48	-28,1	ON	58,98	896	51,4	5,15	7,11
    	60,15	0	0	 	 	60,44	800	48	-28,1	ON	59,88	832	54,9	5,15	7,87
    	61,03	0	0	 	 	61,35	928	48	-28,1	ON	60,73	928	58	5,15	7,87
    	61,96	0	0	 	 	62,27	864	48	-28,1	ON	61,65	896	56,1	5,15	8,37
    	62,84	0	0	 	 	63,14	896	48	-28,1	ON	62,56	896	54,9	5,15	7,66
    	63,76	0	0	 	 	64,05	864	48	-28,1	ON	63,44	896	53,7	5,15	7,43
    	64,66	0	0	 	 	64,95	928	48	-28,1	ON	64,35	928	52,5	5,15	7,49
    	65,58	0	0	 	 	65,89	864	48	-28,1	ON	65,26	896	50,2	4,12	7,38
    	66,5	0	0	 	 	66,8	928	48	-28,1	ON	66,19	896	51,4	5,15	7,51
    	67,4	0	0	 	 	67,69	896	48	-28,1	ON	67,09	928	49	4,12	7,06
    	68,29	0	0	 	 	68,59	896	48	-28,1	ON	68	864	46,7	4,12	6,47
    	69,18	0	0	 	 	69,5	864	49,5	-25,4	ON	68,88	864	47,8	4,12	7,22
    	70,08	0	0	 	 	70,39	928	49,5	-22,7	ON	69,8	928	45,5	4,12	6,38
    	70,97	0	0	 	 	71,29	896	49,5	-19,9	ON	70,69	928	42,4	4,12	6,11
    	71,88	0	0	 	 	72,19	960	49,5	-17,2	ON	71,58	928	41,2	4,12	5,95
    	72,78	0	0	 	 	73,08	896	49,5	-14,5	ON	72,48	960	37,6	4,12	5,59
    	73,7	0	0	 	 	74,01	928	49,5	-11,7	ON	73,41	896	36,5	4,12	5,22
    	74,6	0	0	 	 	74,91	928	49,5	-9	ON	74,32	960	32,9	3,09	4,94
    	75,5	0	0	 	 	75,8	928	49,5	-6,3	ON	75,21	928	29,8	3,09	4,33
    	76,38	0	0	 	 	76,69	896	49,5	-3,5	ON	76,1	896	28,6	3,09	4,32
    	77,3	0	0	 	 	77,6	896	49,5	-0,8	ON	77	928	27,5	3,09	3,94
    	78,19	0	0	 	 	78,52	896	49,5	2	ON	77,88	896	25,1	3,09	3,65
    	79,12	0	0	 	 	79,41	896	49,5	3,9	ON	78,83	896	23,9	3,09	3,17
    	80,02	0	0	 	 	80,32	864	49,5	1,2	ON	79,71	896	22,7	3,09	2,83
    	80,93	0	0	 	 	81,23	864	49,5	-2	ON	80,63	864	22,7	3,09	2,97
    	81,83	0	0	 	 	82,1	864	51	-4,3	ON	81,53	864	22,7	3,09	3,13
    	82,7	0	0	 	 	82,98	832	51	-5,9	ON	82,41	864	23,9	3,09	3,56
    	83,56	0	0	 	 	83,85	864	51	-3,1	ON	83,26	832	23,9	3,09	3,6
    	84,46	0	0	 	 	84,74	896	51	-0,4	ON	84,16	864	25,1	3,09	3,78
    	85,35	0	0	 	 	85,63	896	51	2,3	ON	85,06	896	23,9	3,09	3,65
    	86,21	0	0	 	 	86,53	896	51	4,7	ON	85,92	864	23,9	3,09	3,43
    	87,1	0	0	 	 	87,41	896	51	6,3	ON	86,81	864	22,7	3,09	3,25
    	88,03	0	0	 	 	88,34	864	51	3,5	ON	87,72	896	22,7	3,09	2,97
    	88,94	0	0	 	 	89,24	864	51	0,8	ON	88,64	864	22,7	3,09	3,36
    	89,83	0	0	 	 	90,11	832	51	-2	ON	89,53	864	22,7	3,09	3,23
    	90,7	0	0	 	 	91	864	51	-2	ON	90,4	832	22,7	2,06	3,29
    	91,6	0	0	 	 	91,9	864	51	0,8	ON	91,3	832	23,9	3,09	3,4
    	92,48	0	0	 	 	92,79	864	51	3,5	ON	92,2	896	23,9	3,09	3,42
    	93,37	0	0	 	 	93,65	896	51	6,3	ON	93,08	864	22,7	3,09	3,17
    	94,24	0	0	 	 	94,53	864	52,5	7,8	ON	93,96	896	22,7	3,09	3,06
    	95,14	0	0	 	 	95,43	864	52,5	5,1	ON	94,84	896	21,6	3,09	2,89
    	96,05	0	0	 	 	96,36	832	52,5	2	ON	95,75	864	21,6	3,09	2,99
    	96,96	0	0	 	 	97,24	832	52,5	-0,8	ON	96,67	832	21,6	2,06	2,98
    	97,83	0	0	 	 	98,13	864	52,5	1,2	ON	97,52	864	22,7	2,06	3,28
    	98,73	0	0	 	 	99,06	864	52,5	3,9	ON	98,43	864	22,7	3,09	3,48
    	99,65	0	0	 	 	99,94	896	52,5	6,6	ON	99,36	864	22,7	3,09	3,44
    	100,56	0	0	 	 	100,86	864	52,5	7,4	ON	100,26	864	21,6	3,09	3,04
    	101,47	0	0	 	 	101,76	864	52,5	4,3	ON	101,16	864	21,6	3,09	2,87
    	102,36	0	0	 	 	102,65	832	52,5	2	ON	102,06	864	21,6	3,09	3,06
    	103,24	0	0	 	 	103,52	832	52,5	1,2	ON	102,94	864	21,6	2,06	2,86
    	104,11	0	0	 	 	104,4	896	52,5	3,9	ON	103,82	864	23,9	3,09	3,66
    	104,98	0	0	 	 	105,28	896	52,5	6,6	ON	104,68	896	22,7	3,09	3,51
    	105,88	0	0	 	 	106,17	896	54	9,4	ON	105,6	864	21,6	3,09	3,39
    	106,77	0	0	 	 	107,06	896	54	10,2	ON	106,47	864	21,6	3,09	3,09
    	107,65	0	0	 	 	107,94	864	54	7,4	ON	107,36	864	21,6	3,09	3
    	108,56	0	0	 	 	108,85	832	54	4,7	ON	108,25	864	20,4	2,06	3,02
    	109,42	0	0	 	 	109,73	864	54	2	ON	109,13	832	21,6	3,09	3,27
    	110,36	0	0	 	 	110,65	864	54	4,7	ON	110,04	864	22,7	3,09	3,48
    	111,28	0	0	 	 	111,56	864	54	7,4	ON	110,98	896	21,6	3,09	2,71
    	112,13	0	0	 	 	112,43	864	54	10,2	ON	111,84	896	21,6	3,09	3,04
    	113,04	0	0	 	 	113,34	864	54	9,4	ON	112,74	864	21,6	3,09	3,02
    	113,91	0	0	 	 	114,22	832	54	6,6	ON	113,62	864	20,4	3,09	2,99
    	114,84	0	0	 	 	115,15	832	54	4,3	ON	114,53	864	20,4	2,06	2,91
    	115,71	0	0	 	 	116	864	54	7	ON	115,43	864	21,6	3,09	3,35
    	116,62	0	0	 	 	116,95	864	54	9,8	ON	116,31	864	21,6	3,09	3,22
    	117,51	0	0	 	 	117,81	864	54	12,5	ON	117,23	864	21,6	3,09	3,17
    	118,43	0	0	 	 	118,74	864	54	10,2	ON	118,11	864	20,4	3,09	3
    	119,34	0	0	 	 	119,65	832	55,5	7,4	ON	119,04	864	20,4	3,09	3,11
    	120,26	0	0	 	 	120,57	832	55,5	4,7	ON	119,96	832	20,4	2,06	2,71
    	121,19	0	0	 	 	121,5	864	55,5	6,3	ON	120,88	832	21,6	3,09	3,06
    	122,09	0	0	 	 	122,36	864	55,5	9	ON	121,79	864	21,6	3,09	3,38
    	122,97	0	0	 	 	123,29	896	55,5	11,7	ON	122,66	864	21,6	3,09	3,04
    	123,89	0	0	 	 	124,19	864	55,5	12,1	ON	123,59	896	21,6	3,09	3,03
    	124,79	0	0	 	 	125,09	864	55,5	9,4	ON	124,49	864	20,4	2,06	3,03
    	125,68	0	0	 	 	125,96	864	55,5	6,6	ON	125,39	832	20,4	2,06	2,88
    	126,57	0	0	 	 	126,86	864	55,5	7,4	ON	126,27	864	20,4	2,06	2,81
    	127,49	0	0	 	 	127,8	864	55,5	10,2	ON	127,16	864	21,6	3,09	3,17
    	128,39	0	0	 	 	128,68	864	55,5	12,9	ON	128,09	896	21,6	3,09	3,16
    	129,27	0	0	 	 	129,58	864	55,5	10,2	ON	128,96	864	20,4	3,09	3,04
    	130,19	0	0	 	 	130,49	864	55,5	7,4	ON	129,89	864	20,4	2,06	2,86
    	131,09	0	0	 	 	131,38	864	55,5	7	ON	130,79	832	20,4	2,06	2,98
    	131,97	0	0	 	 	132,28	864	57	9,8	ON	131,68	864	20,4	3,09	2,97
    	132,87	0	0	 	 	133,18	896	57	12,5	ON	132,57	864	20,4	3,09	2,97
    	133,79	0	0	 	 	134,08	864	57	13,3	ON	133,49	864	20,4	3,09	3,06
    	134,69	0	0	 	 	134,99	864	57	10,5	ON	134,38	864	20,4	3,09	2,75
    	135,62	0	0	 	 	135,91	864	57	7,8	ON	135,31	864	20,4	2,06	2,93
    	136,52	0	0	 	 	136,81	832	57	8,2	ON	136,22	864	20,4	2,06	2,78
    	137,39	0	0	 	 	137,7	864	57	10,9	ON	137,09	864	20,4	3,09	2,98
    	138,28	0	0	 	 	138,59	864	57	13,7	ON	137,99	864	20,4	3,09	2,97
    	139,16	0	0	 	 	139,44	864	57	14,1	ON	138,87	864	21,6	3,09	3,06
    	140,03	0	0	 	 	140,32	864	57	9,4	ON	139,73	864	20,4	3,09	3,08
    	140,94	0	0	 	 	141,24	832	57	7,8	ON	140,63	832	20,4	2,06	2,91
    	141,83	0	0	 	 	142,13	864	57	10,5	ON	141,53	832	20,4	3,09	3,21
    	142,68	0	0	 	 	142,99	896	57	13,3	ON	142,42	864	21,6	3,09	3,2
    	143,55	0	0	 	 	143,83	896	57	14,5	ON	143,27	896	20,4	3,09	2,91
    	144,41	0	0	 	 	144,69	864	57	11,7	ON	144,12	864	20,4	2,06	2,95
    	145,33	0	0	 	 	145,63	832	57	9	ON	145,01	864	20,4	2,06	2,66
    	146,23	0	0	 	 	146,53	832	58,5	7,8	ON	145,91	832	20,4	2,06	3,03
    	147,09	0	0	 	 	147,38	864	58,5	10,5	ON	146,82	864	20,4	2,06	3,03
    	147,98	0	0	 	 	148,26	896	58,5	13,3	ON	147,67	864	21,6	3,09	3,03
    	148,86	0	0	 	 	149,15	864	58,5	16	ON	148,56	896	21,6	3,09	3,02
    	149,73	0	0	 	 	150,02	864	58,5	16,8	ON	149,43	896	20,4	3,09	2,95
    	150,6	0	0	 	 	150,89	864	58,5	14,1	ON	150,33	864	20,4	3,09	3,04
    	151,45	0	0	 	 	151,75	832	58,5	11,3	ON	151,16	864	19,2	2,06	2,56
    	152,34	0	0	 	 	152,63	864	58,5	12,5	ON	152,04	832	20,4	2,06	2,92
    	153,24	0	0	 	 	153,53	864	58,5	15,2	ON	152,93	864	20,4	3,09	3,22
    	154,13	0	0	 	 	154,45	896	58,5	18	ON	153,83	864	20,4	3,09	3
    	155,06	0	0	 	 	155,36	864	58,5	20,7	ON	154,75	896	19,2	3,09	2,67
    	155,93	0	0	 	 	156,2	864	58,5	21,5	ON	155,64	864	19,2	3,09	2,42
    	156,82	0	0	 	 	157,1	864	58,5	22,3	ON	156,5	864	18,4	2,06	2,67
    	157,69	0	0	 	 	157,97	864	58,5	23	ON	157,41	864	18,4	2,06	2,83
    	158,58	0	0	 	 	158,88	832	58,5	24,6	ON	158,28	864	18,4	3,09	2,81
    	159,47	0	0	 	 	159,76	864	58,5	23,8	ON	159,16	864	18,4	3,09	2,47
    	160,4	0	0	 	 	160,72	864	58,5	21,1	ON	160,09	864	18,4	2,06	2,67
    	161,3	0	0	 	 	161,6	832	58,5	19,5	ON	161,01	864	19,2	2,06	2,78
    	162,2	0	0	 	 	162,48	864	60	18	ON	161,9	832	19,2	2,06	2,78
    	163,05	0	0	 	 	163,34	832	60	15,6	ON	162,75	832	19,2	2,06	2,67
    	163,95	0	0	 	 	164,25	832	60	15,2	ON	163,65	832	19,2	2,06	2,78
    	164,85	0	0	 	 	165,17	864	60	18	ON	164,54	864	20,4	3,09	2,99
    	165,79	0	0	 	 	166,09	896	60	21,1	ON	165,49	864	20,4	3,09	3,06
    	166,68	0	0	 	 	166,97	864	60	23,4	ON	166,39	896	19,2	3,09	2,83
    	167,54	0	0	 	 	167,8	864	60	22,3	ON	167,26	864	19,2	3,09	2,93
    	168,41	0	0	 	 	168,71	864	60	19,5	ON	168,1	864	19,2	3,09	2,87
    	169,32	0	0	 	 	169,63	864	60	16,8	ON	169,02	864	19,2	2,06	2,55
    	170,2	0	0	 	 	170,49	832	60	14,1	ON	169,92	832	18,4	2,06	2,78
    	171,08	0	0	 	 	171,38	864	60	14,8	ON	170,79	832	19,2	2,06	2,83
    	172	0	0	 	 	172,29	896	60	17,6	ON	171,68	896	20,4	3,09	3,03
    	172,87	0	0	 	 	173,16	896	60	20,3	ON	172,58	864	20,4	3,09	2,95
    	173,78	0	0	 	 	174,09	864	60	21,9	ON	173,47	864	19,2	3,09	3,04
    	174,7	0	0	 	 	175,01	864	60	19,1	ON	174,39	864	19,2	3,09	2,72
    	175,61	0	0	 	 	175,9	864	61,5	16,4	ON	175,31	864	19,2	2,06	2,59
    	176,49	0	0	 	 	176,78	832	61,5	13,7	ON	176,2	832	18,4	2,06	2,68
    	177,33	0	0	 	 	177,64	864	61,5	14,1	ON	177,06	832	20,4	2,06	3,28
    	178,25	0	0	 	 	178,55	896	61,5	17,2	ON	177,94	864	20,4	3,09	3,36
    	179,13	0	0	 	 	179,42	864	61,5	19,5	ON	178,85	896	20,4	3,09	2,96
    	180,04	0	0	 	 	180,33	864	61,5	22,7	ON	179,73	864	20,4	3,09	2,91
    	180,94	0	0	 	 	181,25	864	61,5	19,9	ON	180,63	864	19,2	3,09	2,83
    	181,87	0	0	 	 	182,18	832	61,5	17,2	ON	181,56	864	19,2	2,06	2,62
    	182,74	0	0	 	 	183,06	832	61,5	14,5	ON	182,46	832	19,2	2,06	2,66
    	183,64	0	0	 	 	183,94	832	61,5	13,3	ON	183,37	832	19,2	2,06	2,84
    	184,52	0	0	 	 	184,82	896	61,5	16	ON	184,23	864	21,6	3,09	3,35
    	185,46	0	0	 	 	185,76	864	61,5	18,8	ON	185,13	864	20,4	3,09	3,27
    	186,36	0	0	 	 	186,65	864	61,5	21,1	ON	186,06	864	20,4	3,09	3,11
    	187,25	0	0	 	 	187,55	864	61,5	18,4	ON	186,95	864	19,2	3,09	2,83
    	188,13	0	0	 	 	188,43	864	61,5	16	ON	187,84	864	19,2	2,06	2,61
    	188,99	0	0	 	 	189,29	832	63	13,3	ON	188,72	832	19,2	2,06	2,69
    	189,91	0	0	 	 	190,22	832	63	13,7	ON	189,6	832	19,2	2,06	2,72
    	190,82	0	0	 	 	191,12	864	63	16,4	ON	190,51	864	20,4	3,09	2,92
    	191,71	0	0	 	 	191,99	864	63	19,1	ON	191,43	864	20,4	3,09	3,21
    	192,59	0	0	 	 	192,89	896	63	21,9	ON	192,3	864	20,4	3,09	2,97
    	193,49	0	0	 	 	193,79	864	63	21,1	ON	193,19	864	19,2	3,09	2,78
    	194,42	0	0	 	 	194,71	864	63	18	ON	194,11	864	18,4	2,06	2,54
    	195,29	0	0	 	 	195,56	832	63	15,6	ON	195	832	19,2	2,06	2,66
    	196,15	0	0	 	 	196,44	832	63	12,9	ON	195,87	832	19,2	2,06	2,86
    	197,04	0	0	 	 	197,34	864	63	15,6	ON	196,74	832	20,4	2,06	3,02
    	197,94	0	0	 	 	198,23	896	63	18,4	ON	197,63	864	20,4	3,09	3,06
    	198,83	0	0	 	 	199,11	864	63	21,1	ON	198,53	864	20,4	3,09	3,06
    	199,71	0	0	 	 	199,99	864	63	20,7	ON	199,42	864	19,2	3,09	2,82
    	200,59	0	0	 	 	200,9	864	63	18	ON	200,29	864	19,2	2,06	2,62
    	201,51	0	0	 	 	201,8	832	63	15,2	ON	201,21	864	18,4	2,06	2,76
    	202,4	0	0	 	 	202,7	864	63	12,5	ON	202,1	832	19,2	2,06	2,67
    	203,31	0	0	 	 	203,59	864	63	15,2	ON	203,01	832	19,2	2,06	2,97
    	204,19	0	0	 	 	204,51	864	63	18	ON	203,9	864	20,4	3,09	2,95
    	205,11	0	0	 	 	205,42	896	63	20,7	ON	204,82	864	20,4	3,09	2,87
    	205,99	0	0	 	 	206,3	864	64,5	21,5	ON	205,71	864	19,2	3,09	2,81
    	206,9	0	0	 	 	207,2	864	64,5	18,8	ON	206,58	864	18,4	2,06	2,56
    	207,77	0	0	 	 	208,05	832	64,5	16	ON	207,48	832	18,4	2,06	2,64
    	208,65	0	0	 	 	208,95	832	64,5	13,3	ON	208,36	832	19,2	2,06	2,47
    	209,55	0	0	 	 	209,85	832	64,5	14,1	ON	209,25	832	19,2	2,06	2,98
    	210,42	0	0	 	 	210,72	864	64,5	16,8	ON	210,14	832	19,2	2,06	2,94
    	211,32	0	0	 	 	211,61	896	64,5	19,5	ON	211,01	864	20,4	3,09	2,87
    	212,23	0	0	 	 	212,54	864	64,5	21,5	ON	211,95	896	19,2	3,09	2,62
    	213,15	0	0	 	 	213,47	864	64,5	18,8	ON	212,85	864	18,4	2,06	2,74
    	214,07	0	0	 	 	214,36	832	64,5	16	ON	213,77	864	18,4	2,06	2,46
    	214,98	0	0	 	 	215,27	832	64,5	13,3	ON	214,66	832	18,4	2,06	2,48
    	215,86	0	0	 	 	216,16	864	64,5	15,6	ON	215,57	864	19,2	2,06	2,97
    	216,76	0	0	 	 	217,06	864	64,5	18,4	ON	216,46	832	19,2	2,06	2,87
    	217,65	0	0	 	 	217,93	864	64,5	21,1	ON	217,35	864	19,2	3,09	2,94
    	218,54	0	0	 	 	218,84	864	64,5	23	ON	218,23	864	19,2	3,09	3,06
    	219,43	0	0	 	 	219,72	864	64,5	20,3	ON	219,15	864	19,2	3,09	2,86
    	220,3	0	0	 	 	220,58	832	64,5	18	ON	220,02	832	19,2	2,06	2,71
    	221,18	0	0	 	 	221,47	832	66	15,2	ON	220,88	832	18,4	2,06	2,69
    	222,05	0	0	 	 	222,33	832	66	15,2	ON	221,77	864	19,2	2,06	2,89
    	222,93	0	0	 	 	223,21	864	66	18	ON	222,62	832	19,2	2,06	2,98
    	223,77	0	0	 	 	224,08	864	66	20,3	ON	223,5	864	19,2	3,09	3,08
    	224,67	0	0	 	 	224,96	896	66	23	ON	224,35	864	19,2	3,09	2,97
    	225,55	0	0	 	 	225,87	864	66	21,9	ON	225,27	864	19,2	3,09	2,49
    	226,44	0	0	 	 	226,76	832	66	19,5	ON	226,14	864	18,4	2,06	2,58
    	227,34	0	0	 	 	227,64	864	66	16,8	ON	227,04	864	18,4	2,06	2,48
    	228,18	0	0	 	 	228,47	832	66	14,1	ON	227,9	832	18,4	2,06	2,74
    	229,06	0	0	 	 	229,38	832	66	14,5	ON	228,77	832	19,2	2,06	2,76
    	229,97	0	0	 	 	230,27	864	66	17,2	ON	229,67	864	20,4	2,06	2,96
    	230,85	0	0	 	 	231,15	896	66	19,9	ON	230,57	864	20,4	3,09	3,07
    	231,73	0	0	 	 	232,05	896	66	22,7	ON	231,44	864	19,2	3,09	2,95
    	232,64	0	0	 	 	232,96	864	66	21,1	ON	232,35	864	18,4	2,06	2,61
    	233,56	0	0	 	 	233,86	832	66	18,4	ON	233,26	864	18,4	2,06	2,44
    	234,42	0	0	 	 	234,71	832	66	15,6	ON	234,14	832	18,4	2,06	2,56
    	235,3	0	0	 	 	235,6	832	66	12,9	ON	235,01	864	19,2	2,06	2,69
    	236,2	0	0	 	 	236,49	832	66	14,1	ON	235,9	832	19,2	2,06	3,07
    	237,06	0	0	 	 	237,33	864	66	16,8	ON	236,78	864	20,4	3,09	3,15
    	237,92	0	0	 	 	238,24	896	67,5	19,5	ON	237,62	896	20,4	3,09	3,23
    	238,82	0	0	 	 	239,12	864	67,5	20,3	ON	238,53	864	19,2	2,06	2,86
    	239,71	0	0	 	 	239,99	832	67,5	17,6	ON	239,43	864	18,4	2,06	2,43
    	240,57	0	0	 	 	240,87	864	67,5	14,8	ON	240,29	832	18,4	2,06	2,62
    	241,45	0	0	 	 	241,75	864	67,5	14,5	ON	241,15	832	19,2	2,06	2,94
    	242,34	0	0	 	 	242,64	864	67,5	17,2	ON	242,05	864	19,2	2,06	2,89
    	243,23	0	0	 	 	243,53	864	67,5	19,9	ON	242,93	864	19,2	3,09	2,83
    	244,15	0	0	 	 	244,44	864	67,5	22,7	ON	243,84	864	19,2	3,09	2,88
    	245	0	0	 	 	245,29	864	67,5	21,5	ON	244,71	864	19,2	3,09	2,83
    	245,88	0	0	 	 	246,18	832	67,5	18,8	ON	245,58	864	18,4	2,06	2,75
    	246,73	0	0	 	 	247,01	832	67,5	16	ON	246,46	832	18,4	2,06	2,52
    	247,61	0	0	 	 	247,91	832	67,5	13,3	ON	247,31	832	18,4	2,06	2,59
    	248,47	0	0	 	 	248,76	864	67,5	14,5	ON	248,18	832	20,4	3,09	3,46
    	249,36	0	0	 	 	249,66	896	67,5	17,2	ON	249,06	864	20,4	3,09	3,31
    	250,25	0	0	 	 	250,56	864	67,5	19,9	ON	249,97	864	20,4	3,09	2,96
    	251,14	0	0	 	 	251,44	864	67,5	22,7	ON	250,85	864	19,2	3,09	2,66
    	252,02	0	0	 	 	252,29	864	67,5	20,3	ON	251,74	864	19,2	3,09	2,64
    	252,87	0	0	 	 	253,18	864	67,5	17,6	ON	252,6	864	18,4	2,06	2,73
    	253,78	0	0	 	 	254,07	832	67,5	14,8	ON	253,48	832	18,4	2,06	2,76
    	254,68	0	0	 	 	254,97	864	67,5	14,8	ON	254,39	832	20,4	2,06	3,29
    	255,59	0	0	 	 	255,87	864	67,5	17,6	ON	255,28	864	20,4	3,09	2,94
    	256,46	0	0	 	 	256,76	864	67,5	20,3	ON	256,16	864	20,4	3,09	2,78
    	257,34	0	0	 	 	257,64	864	69	21,5	ON	257,04	864	19,2	3,09	2,87
    	258,24	0	0	 	 	258,55	864	69	18,8	ON	257,93	864	18,4	2,06	2,59
    	259,11	0	0	 	 	259,4	864	69	16	ON	258,82	832	18,4	2,06	2,67
    	259,98	0	0	 	 	260,29	832	69	13,7	ON	259,69	832	18,4	2,06	2,46
    	260,87	0	0	 	 	261,18	864	69	13,7	ON	260,57	832	19,2	2,06	2,79
    	261,76	0	0	 	 	262,06	864	69	16,4	ON	261,47	832	20,4	2,06	3,12
    	262,66	0	0	 	 	262,95	864	69	19,1	ON	262,37	864	19,2	2,06	3,03
    	263,56	0	0	 	 	263,85	864	69	21,9	ON	263,24	864	20,4	3,09	2,8
    	264,44	0	0	 	 	264,72	864	69	22,3	ON	264,14	864	19,2	3,09	2,79
    	265,32	0	0	 	 	265,62	864	69	19,5	ON	265,03	864	19,2	2,06	2,86
    	266,21	0	0	 	 	266,5	864	69	16,8	ON	265,92	864	18,4	2,06	2,64
    	267,1	0	0	 	 	267,4	832	69	14,1	ON	266,8	832	18,4	2,06	2,48
    	268	0	0	 	 	268,29	832	69	14,1	ON	267,69	832	19,2	2,06	2,98
    	268,86	0	0	 	 	269,16	864	69	16,8	ON	268,58	832	20,4	2,06	2,93
    	269,76	0	0	 	 	270,07	864	69	19,5	ON	269,45	864	19,2	3,09	3,06
    	270,66	0	0	 	 	270,94	864	69	22,3	ON	270,36	896	19,2	3,09	2,81
    	271,53	0	0	 	 	271,83	864	69	20,7	ON	271,23	864	19,2	3,09	2,86
    	272,43	0	0	 	 	272,73	832	69	18	ON	272,1	864	18,4	2,06	2,62
    	273,32	0	0	 	 	273,63	832	69	15,2	ON	273,02	832	18,4	2,06	2,6
    	274,23	0	0	 	 	274,52	832	69	12,5	ON	273,92	832	19,2	2,06	2,55
    	275,13	0	0	 	 	275,42	832	69	15,2	ON	274,83	832	19,2	2,06	3
    	276,02	0	0	 	 	276,32	864	69	18	ON	275,72	864	19,2	2,06	2,76
    	276,92	0	0	 	 	277,22	864	70,5	20,7	ON	276,62	864	19,2	2,06	2,98
    	277,83	0	0	 	 	278,12	864	70,5	23	ON	277,53	864	19,2	3,09	2,88
    	278,72	0	0	 	 	279,03	864	70,5	20,3	ON	278,41	864	18,4	2,06	2,52
    	279,62	0	0	 	 	279,92	832	70,5	17,6	ON	279,33	832	18,4	2,06	2,61
    	280,49	0	0	 	 	280,77	832	70,5	14,8	ON	280,21	832	18,4	2,06	2,52
    	281,33	0	0	 	 	281,62	832	70,5	14,8	ON	281,05	832	19,2	2,06	2,53
    	282,2	0	0	 	 	282,5	864	70,5	17,6	ON	281,92	832	19,2	2,06	2,94
    	283,12	0	0	 	 	283,43	864	70,5	20,3	ON	282,81	864	19,2	2,06	2,93
    	284,01	0	0	 	 	284,32	864	70,5	23	ON	283,73	864	18,4	2,06	2,72
    	284,9	0	0	 	 	285,19	864	70,5	21,1	ON	284,61	864	19,2	2,06	2,81
    	285,79	0	0	 	 	286,09	832	70,5	18,4	ON	285,49	864	18,4	2,06	2,58
    	286,66	0	0	 	 	286,95	832	70,5	15,6	ON	286,38	864	18,4	2,06	2,53
    	287,52	0	0	 	 	287,81	832	70,5	14,1	ON	287,23	832	18,4	2,06	2,57
    	288,43	0	0	 	 	288,74	864	70,5	17,2	ON	288,12	832	19,2	2,06	2,77
    	289,36	0	0	 	 	289,66	832	70,5	19,9	ON	289,05	864	18,4	2,06	2,77
    	290,26	0	0	 	 	290,55	864	70,5	22,7	ON	289,97	864	18,4	2,06	2,28
    	291,15	0	0	 	 	291,46	864	70,5	22,3	ON	290,84	864	18,4	2,06	2,5
    	292,06	0	0	 	 	292,35	864	70,5	19,5	ON	291,76	864	18,4	2,06	2,74
    	292,95	0	0	 	 	293,26	832	70,5	16,4	ON	292,65	864	18,4	2,06	2,78
    	293,83	0	0	 	 	294,14	832	70,5	15,2	ON	293,55	832	18,4	2,06	2,69
    	294,72	0	0	 	 	295	864	70,5	18	ON	294,43	800	18,4	2,06	2,64
    	295,59	0	0	 	 	295,87	864	70,5	20,3	ON	295,29	864	19,2	2,06	2,61
    	296,47	0	0	 	 	296,78	896	70,5	22,7	ON	296,17	864	19,2	3,09	3
    	297,38	0	0	 	 	297,67	864	72	22,7	ON	297,09	864	18,4	2,06	2,75
    	298,29	0	0	 	 	298,59	832	72	19,5	ON	297,98	864	18,4	2,06	2,42
    	299,2	0	0	 	 	299,49	832	72	16,8	ON	298,89	832	18,4	2,06	2,38
    	300,09	0	0	 	 	300,4	832	72	14,1	ON	299,79	832	18,4	2,06	2,81
    	300,97	0	0	 	 	301,26	864	72	16,8	ON	300,69	832	19,2	2,06	2,74
    	301,85	0	0	 	 	302,16	864	72	19,5	ON	301,56	864	19,2	2,06	2,96
    	302,75	0	0	 	 	303,04	864	72	22,3	ON	302,45	864	19,2	2,06	3,01
    	303,65	0	0	 	 	303,96	864	72	23	ON	303,35	864	18,4	2,06	2,92
    	304,57	0	0	 	 	304,87	864	72	20,3	ON	304,27	864	18,4	2,06	2,43
    	305,45	0	0	 	 	305,75	832	72	17,6	ON	305,15	832	18,4	2,06	2,58
    	306,35	0	0	 	 	306,64	832	72	14,8	ON	306,07	832	18,4	2,06	2,67
    	307,23	0	0	 	 	307,5	832	72	14,8	ON	306,94	832	18,4	2,06	2,68
    	308,11	0	0	 	 	308,4	864	72	17,6	ON	307,81	832	18,4	2,06	2,67
    	309,01	0	0	 	 	309,29	864	72	20,3	ON	308,7	864	18,4	2,06	2,69
    	309,88	0	0	 	 	310,18	864	72	23	ON	309,58	864	18,4	2,06	2,69
    	310,79	0	0	 	 	311,1	864	72	21,5	ON	310,49	864	18,4	2,06	2,72
    	311,71	0	0	 	 	312,02	832	72	18,8	ON	311,41	832	18,4	2,06	2,67
    	312,62	0	0	 	 	312,92	832	72	16	ON	312,32	832	18,4	2,06	2,37
    	313,49	0	0	 	 	313,81	832	72	15,6	ON	313,2	832	18,4	2,06	2,55
    	314,37	0	0	 	 	314,67	864	72	18	ON	314,09	832	18,4	2,06	2,68
    	315,25	0	0	 	 	315,54	864	72	20,7	ON	314,96	832	18,4	2,06	2,72
    	316,14	0	0	 	 	316,43	864	72	23,4	ON	315,84	864	18,4	2,06	2,8
    	317,03	0,8	0	 	 	317,34	864	72	20,3	ON	316,73	864	18,4	2,06	2,75
    	317,96	0,8	0	 	 	318,27	864	73,5	17,6	ON	317,64	864	18,4	2,06	2,66
    	318,87	0,8	0	 	 	319,16	832	73,5	14,8	ON	318,56	832	18,4	2,06	2,52
    	319,77	0,8	0	 	 	320,08	832	73,5	15,6	ON	319,47	832	18,4	2,06	2,52
    	320,67	0,8	0	 	 	320,97	864	73,5	18,4	ON	320,36	832	19,2	2,06	2,75
    	321,55	0,8	0	 	 	321,86	864	73,5	21,1	ON	321,27	864	19,2	2,06	2,55
    	322,44	0,8	0	 	 	322,74	864	73,5	20,3	ON	322,15	864	19,2	3,09	2,81
    	323,36	0,8	0	 	 	323,64	864	73,5	17,2	ON	323,05	864	18,4	2,06	2,61
    	324,25	0,8	0	 	 	324,54	832	73,5	14,8	ON	323,94	864	18,4	2,06	2,4
    	325,14	0,8	0	 	 	325,42	832	73,5	13,7	ON	324,84	832	18,4	2,06	2,67
    	325,98	0,8	0	 	 	326,26	864	73,5	16,4	ON	325,7	832	18,4	2,06	2,62
    	326,87	0,8	0	 	 	327,15	832	73,5	19,1	ON	326,56	864	19,2	2,06	2,52
    	327,74	0,8	0	 	 	328,03	864	73,5	21,9	ON	327,44	864	19,2	3,09	2,83
    	328,63	2,3	0	 	 	328,92	864	73,5	19,9	ON	328,32	864	19,2	3,09	2,81
    	329,51	2,3	0	 	 	329,82	864	73,5	17,2	ON	329,21	864	18,4	2,06	2,42
    	330,42	2,3	0	 	 	330,73	832	73,5	14,5	ON	330,12	832	18,4	2,06	2,47
    	331,31	2,3	0	 	 	331,6	832	73,5	11,7	ON	331,01	832	18,4	2,06	2,57
    	332,23	2,3	0	 	 	332,52	864	73,5	13,3	ON	331,92	832	19,2	2,06	2,84
    	333,13	2,3	0	 	 	333,41	832	73,5	16	ON	332,83	864	19,2	2,06	2,87
    	334,02	2,3	0	 	 	334,31	864	73,5	18,8	ON	333,73	864	19,2	2,06	2,78
    	334,9	2,3	0	 	 	335,19	864	73,5	19,5	ON	334,6	864	18,4	2,06	2,94
    	335,83	2,3	0	 	 	336,13	832	73,5	16,4	ON	335,52	864	18,4	2,06	2,62
    	336,75	2,3	0	 	 	337,04	832	73,5	13,7	ON	336,44	864	18,4	2,06	2,46
    	337,63	2,3	0	 	 	337,9	832	73,5	11,3	ON	337,31	832	18,4	2,06	2,77
    	338,46	2,3	0	 	 	338,74	864	73,5	13,3	ON	338,18	832	18,4	2,06	2,69
    	339,35	2,3	0	 	 	339,66	832	75	16,4	ON	339,04	864	19,2	2,06	2,78
    	340,26	2,3	0	 	 	340,57	864	75	19,1	ON	339,95	864	19,2	2,06	2,67
    	341,16	3,9	0	 	 	341,45	864	75	18,4	ON	340,86	864	18,4	2,06	2,69
    	342,05	3,9	0	 	 	342,34	864	75	15,6	ON	341,74	864	18,4	2,06	2,73
    	342,93	3,9	0	 	 	343,23	832	75	12,9	ON	342,64	864	18,4	2,06	2,54
    	343,8	3,9	0	 	 	344,11	800	75	10,2	ON	343,52	832	18,4	2,06	2,82
    	344,69	3,1	0	 	 	345	864	75	12,9	ON	344,39	832	20,4	2,06	3,03
    	345,6	3,1	0	 	 	345,91	864	75	15,6	ON	345,3	864	19,2	2,06	3
    	346,52	3,1	0	 	 	346,81	864	75	18,4	ON	346,21	864	20,4	3,09	2,95
    	347,41	3,1	0	 	 	347,7	864	75	17,2	ON	347,1	864	19,2	3,09	2,74
    	348,3	3,9	0	 	 	348,61	832	75	14,5	ON	348	832	18,4	2,06	2,72
    	349,2	3,9	0	 	 	349,5	832	75	11,7	ON	348,91	864	18,4	2,06	2,33
    	350,11	3,9	0	 	 	350,41	832	75	9,8	ON	349,81	832	18,4	2,06	2,84
    	351	3,1	0	 	 	351,31	864	75	12,5	ON	350,71	864	19,2	2,06	2,91
    	351,93	3,1	0	 	 	352,23	864	75	15,2	ON	351,62	832	19,2	2,06	3,03
    	352,81	3,9	0	 	 	353,09	864	75	18	ON	352,52	864	19,2	2,06	2,99
    	353,68	3,1	0	 	 	353,98	864	75	16,8	ON	353,4	864	18,4	2,06	2,42
    	354,58	3,9	0	 	 	354,89	864	75	14,1	ON	354,27	832	18,4	2,06	2,86
    	355,48	3,9	0	 	 	355,78	832	75	11,3	ON	355,18	832	18,4	2,06	2,86
    	356,39	3,9	0	 	 	356,71	832	75	12,9	ON	356,09	864	19,2	2,06	2,74
    	357,3	3,9	0	 	 	357,59	864	75	15,6	ON	357	832	19,2	2,06	2,78
    	358,21	3,9	0	 	 	358,49	864	75	18,4	ON	357,91	864	19,2	3,09	3,17
    	359,1	3,1	0	 	 	359,39	864	75	18,8	ON	358,8	864	19,2	3,09	2,63
    	359,99	3,9	0	 	 	360,28	832	75	16	ON	359,69	864	18,4	2,06	2,58
    	360,88	3,9	0	 	 	361,16	832	75	13,3	ON	360,59	832	18,4	2,06	2,51
    	361,73	3,9	0	 	 	362,02	832	76,5	10,5	ON	361,45	832	18,4	2,06	2,57
    	362,6	3,9	0	 	 	362,92	832	75	8,6	ON	362,3	832	18,4	2,06	2,72
    	363,52	3,1	0	 	 	363,8	832	75	11,3	ON	363,21	832	19,2	2,06	2,83
    	364,4	3,1	0	 	 	364,7	864	76,5	14,1	ON	364,11	832	19,2	2,06	2,97
    	365,3	3,9	0	 	 	365,58	864	76,5	16,8	ON	364,99	864	19,2	2,06	2,92
    	366,19	3,9	0	 	 	366,49	864	76,5	18	ON	365,88	864	18,4	2,06	2,46
    	367,09	3,9	0	 	 	367,4	864	76,5	15,2	ON	366,79	864	18,4	2,06	2,46
    	367,96	3,9	0	 	 	368,25	832	76,5	12,5	ON	367,68	832	17,3	2,06	2,46
    	368,83	3,9	0	 	 	369,13	832	76,5	9,8	ON	368,53	832	18,4	2,06	2,61
    	369,73	3,1	0	 	 	370,02	864	76,5	12,5	ON	369,42	832	19,2	2,06	3
    	370,61	3,9	0	 	 	370,91	864	76,5	15,2	ON	370,31	864	19,2	2,06	2,89
    	371,5	3,1	0	 	 	371,79	864	76,5	18	ON	371,21	864	19,2	2,06	2,91
    	372,4	3,9	0	 	 	372,69	864	76,5	18	ON	372,1	864	18,4	2,06	2,52
    	373,26	3,9	0	 	 	373,56	832	76,5	15,2	ON	372,98	864	18,4	2,06	2,34
    	374,12	3,9	0	 	 	374,43	832	76,5	12,5	ON	373,83	832	18,4	2,06	2,8
    	375,03	3,9	0	 	 	375,32	832	76,5	9,8	ON	374,74	832	18,4	2,06	2,58
    	375,92	3,9	0	 	 	376,23	832	76,5	12,1	ON	375,63	832	18,4	2,06	2,66
    	376,83	3,9	0	 	 	377,14	864	76,5	14,8	ON	376,52	832	18,4	2,06	2,79
    	377,76	3,9	0	 	 	378,05	864	76,5	17,6	ON	377,45	864	18,4	2,06	2,64
    	378,64	3,9	0	 	 	378,94	864	76,5	19,1	ON	378,35	864	18,4	2,06	2,33
    	379,54	3,9	0	 	 	379,83	864	76,5	16,8	ON	379,25	864	18,4	2,06	2,46
    	380,44	3,9	0	 	 	380,72	832	76,5	14,1	ON	380,13	864	18,4	2,06	2,48
    	381,31	3,9	0	 	 	381,6	832	76,5	11,3	ON	381	832	18,4	2,06	2,66
    	382,23	3,9	0	 	 	382,54	832	76,5	11,3	ON	381,92	832	18,4	2,06	2,52
    	383,14	3,9	0	 	 	383,44	864	76,5	14,1	ON	382,84	832	19,2	2,06	2,81
    	384,02	3,9	0	 	 	384,34	864	76,5	16,8	ON	383,73	864	19,2	2,06	2,97
    	384,93	3,1	0	 	 	385,24	864	76,5	17,6	ON	384,64	864	18,4	2,06	2,74
    	385,85	3,9	0	 	 	386,14	832	76,5	14,8	ON	385,55	864	17,3	2,06	2,55
    	386,73	3,9	0	 	 	387,03	832	76,5	12,1	ON	386,44	832	17,3	2,06	2,49
    	387,64	3,9	0	 	 	387,95	832	76,5	10,2	ON	387,33	832	18,4	2,06	2,64
    	388,55	3,9	0	 	 	388,83	864	76,5	12,9	ON	388,25	832	19,2	2,06	2,81
    	389,41	3,9	0	 	 	389,71	864	76,5	15,6	ON	389,13	864	19,2	2,06	2,92
    	390,32	3,9	0	 	 	390,6	864	76,5	18,4	ON	390,01	896	18,4	2,06	2,62
    	391,21	3,9	0	 	 	391,52	864	76,5	16,8	ON	390,91	864	18,4	2,06	2,46
    	392,12	3,9	0	 	 	392,4	832	78	14,1	ON	391,83	832	17,3	2,06	2,42
    	393	3,9	0	 	 	393,3	832	78	11,3	ON	392,7	832	17,3	2,06	2,67
    	393,9	3,9	0	 	 	394,2	832	78	12,9	ON	393,6	832	18,4	2,06	2,68
    	394,8	3,9	0	 	 	395,1	832	78	15,6	ON	394,49	864	18,4	2,06	2,62
    	395,68	3,9	0	 	 	395,96	864	78	18,4	ON	395,38	864	18,4	2,06	2,57
    	396,56	3,9	0	 	 	396,85	864	78	17,6	ON	396,28	864	18,4	2,06	2,24
    	397,46	3,9	0	 	 	397,75	832	78	14,8	ON	397,15	864	18,4	2,06	2,49
    	398,34	3,9	0	 	 	398,63	832	78	12,1	ON	398,05	832	17,3	2,06	2,42
    	399,18	3,9	0	 	 	399,47	832	78	9,8	ON	398,9	832	17,3	2,06	2,41
    	400,04	3,9	0	 	 	400,34	864	78	10,9	ON	399,75	800	18,4	2,06	2,84
    	400,94	3,9	0	 	 	401,24	864	78	13,7	ON	400,64	864	18,4	2,06	2,8
    	401,83	3,1	0	 	 	402,1	864	78	16,4	ON	401,55	864	18,4	2,06	2,69
    	402,73	3,9	0	 	 	403,02	864	78	19,1	ON	402,41	864	18,4	2,06	2,57
    	403,64	3,9	0	 	 	403,94	864	78	17,6	ON	403,34	864	18,4	2,06	2,62
    	404,53	3,9	0	 	 	404,81	832	78	14,8	ON	404,23	832	17,3	2,06	2,28
    	405,4	3,9	0	 	 	405,7	832	78	12,1	ON	405,1	832	17,3	2,06	2,51
    	406,27	3,9	0	 	 	406,55	832	78	9,8	ON	405,97	832	18,4	2,06	2,51
    	407,12	3,9	0	 	 	407,4	864	78	12,1	ON	406,83	832	18,4	2,06	2,67
    	407,99	3,9	0	 	 	408,29	864	78	14,8	ON	407,68	864	18,4	2,06	2,73
    	408,88	3,9	0	 	 	409,15	832	78	17,6	ON	408,58	864	18,4	2,06	2,75
    	409,76	3,9	0	 	 	410,05	864	78	16	ON	409,45	864	18,4	2,06	2,72
    	410,68	3,9	0	 	 	410,97	832	78	13,3	ON	410,37	864	18,4	2,06	2,62
    	411,56	3,9	0	 	 	411,86	832	78	10,9	ON	411,26	864	18,4	2,06	2,5
    	412,45	3,9	0	 	 	412,75	832	78	13,7	ON	412,16	832	18,4	2,06	2,37
    	413,33	3,9	0	 	 	413,63	832	78	16,4	ON	413,04	832	18,4	2,06	2,52
    	414,24	3,9	0	 	 	414,55	864	78	19,1	ON	413,94	864	18,4	2,06	2,82
    	415,15	3,9	0	 	 	415,43	864	78	17,6	ON	414,85	864	18,4	2,06	2,46
    	416,03	3,9	0	 	 	416,32	832	78	14,8	ON	415,74	832	18,4	2,06	2,68
    	416,9	3,9	0	 	 	417,2	832	78	12,1	ON	416,62	832	18,4	2,06	2,6
    	417,78	3,9	0	 	 	418,09	832	78	9,8	ON	417,49	832	18,4	2,06	2,59
    	418,69	3,9	0	 	 	418,99	832	78	12,5	ON	418,41	832	18,4	2,06	2,61
    	419,59	3,9	0	 	 	419,89	864	78	15,2	ON	419,3	832	18,4	2,06	2,69
    	420,48	3,9	0	 	 	420,75	864	78	18	ON	420,19	864	18,4	2,06	2,69
    	421,36	3,9	0	 	 	421,66	864	78	15,6	ON	421,05	864	18,4	2,06	2,4
    	422,21	3,9	0	 	 	422,5	864	78	13,3	ON	421,93	864	18,4	2,06	2,61
    	423,07	3,9	0	 	 	423,36	832	78	10,9	ON	422,78	832	18,4	2,06	2,64
    	423,95	3,9	0	 	 	424,24	864	78	13,3	ON	423,66	832	18,4	2,06	2,72
    	424,8	3,9	0	 	 	425,07	832	78	16	ON	424,52	832	18,4	2,06	2,59
    	425,66	3,9	0	 	 	425,95	864	78	18,8	ON	425,38	864	18,4	2,06	2,58
    	426,55	3,9	0	 	 	426,83	864	78	16,4	ON	426,25	864	18,4	2,06	2,64
    	427,44	3,9	0	 	 	427,72	864	78	13,7	ON	427,13	864	18,4	2,06	2,74
    	428,33	3,9	0	 	 	428,63	832	78	10,9	ON	428,03	832	18,4	2,06	2,6
    	429,21	3,9	0	 	 	429,51	832	78	13,3	ON	428,91	832	18,4	2,06	2,46
    	430,1	3,9	0	 	 	430,41	832	78	16	ON	429,81	864	18,4	2,06	2,54
    	430,99	3,9	0	 	 	431,28	864	78	18,8	ON	430,68	832	18,4	2,06	2,68
    	431,89	3,9	0	 	 	432,18	864	78	17,2	ON	431,59	832	18,4	2,06	2,58
    	432,79	3,9	0	 	 	433,09	832	78	14,1	ON	432,48	864	17,3	2,06	2,53
    	433,68	3,9	0	 	 	434	832	78	12,5	ON	433,38	832	18,4	2,06	2,72
    	434,55	3,9	0	 	 	434,84	832	78	15,2	ON	434,28	832	18,4	2,06	2,83
    	435,43	3,9	0	 	 	435,73	864	78	17,6	ON	435,14	832	18,4	2,06	2,6
    	436,31	3,9	0	 	 	436,61	864	79,5	18	ON	436,02	864	18,4	2,06	2,66
    	437,19	3,9	0	 	 	437,47	832	79,5	15,2	ON	436,9	832	17,3	2,06	2,6
    	438,08	3,9	0	 	 	438,36	832	79,5	12,5	ON	437,78	832	17,3	2,06	2,36
    	438,92	3,9	0	 	 	439,22	832	78	9,8	ON	438,66	832	17,3	2,06	2,48
    	439,83	3,9	0	 	 	440,13	864	79,5	12,1	ON	439,53	832	18,4	2,06	2,67
    	440,74	3,9	0	 	 	441,04	864	79,5	14,8	ON	440,43	864	18,4	2,06	2,86
    	441,65	3,9	0	 	 	441,93	832	79,5	17,6	ON	441,34	864	18,4	2,06	2,58
    	442,5	3,9	0	 	 	442,81	864	79,5	20,3	ON	442,22	832	18,4	2,06	2,68
    	443,41	3,9	0	 	 	443,7	864	79,5	18,4	ON	443,11	864	18,4	2,06	2,66
    	444,29	3,9	0	 	 	444,57	832	79,5	15,6	ON	444	864	17,3	2,06	2,51
    	445,18	3,9	0	 	 	445,48	832	79,5	12,9	ON	444,88	832	17,3	2,06	2,66
    	446,06	3,9	0	 	 	446,36	832	79,5	10,2	ON	445,76	832	17,3	2,06	2,47
    	446,97	3,9	0	 	 	447,26	832	79,5	11,7	ON	446,66	832	18,4	2,06	2,76
    	447,83	3,9	0	 	 	448,14	864	79,5	14,5	ON	447,56	864	18,4	2,06	2,78
    	448,75	3,9	0	 	 	449,03	864	79,5	17,2	ON	448,46	864	19,2	2,06	2,75
    	449,61	3,9	0	 	 	449,91	864	79,5	19,9	ON	449,32	864	18,4	2,06	2,77
    	450,49	3,9	0	 	 	450,79	864	79,5	18	ON	450,17	864	18,4	2,06	2,46
    	451,35	3,9	0	 	 	451,63	832	79,5	15,2	ON	451,08	864	17,3	2,06	2,44
    	452,22	3,9	0	 	 	452,49	832	79,5	12,5	ON	451,92	832	17,3	2,06	2,19
    	453,09	3,9	0	 	 	453,37	832	79,5	10,2	ON	452,78	800	17,3	2,06	2,39
    	453,97	3,9	0	 	 	454,28	832	79,5	12,9	ON	453,65	832	18,4	2,06	2,55
    	454,83	3,9	0	 	 	455,13	864	79,5	15,6	ON	454,53	864	18,4	2,06	2,53
    	455,71	3,9	0	 	 	456,02	864	79,5	18	ON	455,43	864	18,4	2,06	2,72
    	456,6	3,9	0	 	 	456,89	864	79,5	17,6	ON	456,3	864	18,4	2,06	2,61
    	457,49	3,9	0	 	 	457,78	864	79,5	14,8	ON	457,19	864	18,4	2,06	2,83
    	458,41	3,9	0	 	 	458,71	864	79,5	12,1	ON	458,09	832	18,4	2,06	2,5
    	459,3	3,9	0	 	 	459,59	832	79,5	9,8	ON	459,01	832	18,4	2,06	2,55
    	460,18	3,9	0	 	 	460,45	832	79,5	12,5	ON	459,89	832	18,4	2,06	2,73
    	461,06	3,9	0	 	 	461,34	864	79,5	15,2	ON	460,77	832	18,4	2,06	2,58
    	461,95	3,9	0	 	 	462,23	864	79,5	18	ON	461,65	864	18,4	2,06	2,49
    	462,84	3,9	0	 	 	463,13	864	79,5	19,1	ON	462,53	864	18,4	2,06	2,47
    	463,72	3,9	0	 	 	464,01	832	79,5	16,4	ON	463,44	864	17,3	2,06	2,48
    	464,58	3,9	0	 	 	464,88	832	79,5	13,7	ON	464,3	832	17,3	2,06	2,6
    	465,49	3,9	0	 	 	465,79	832	79,5	10,9	ON	465,19	800	17,3	2,06	2,52
    	466,38	3,9	0	 	 	466,69	832	79,5	10,9	ON	466,08	832	18,4	2,06	2,63
    	467,29	3,9	0	 	 	467,6	864	79,5	13,7	ON	466,98	864	18,4	2,06	2,69
    	468,18	3,9	0	 	 	468,48	864	79,5	16,4	ON	467,89	864	18,4	2,06	2,8
    	469,07	3,9	0	 	 	469,38	864	79,5	19,1	ON	468,78	864	18,4	2,06	2,74
    	469,96	3,9	0	 	 	470,26	864	79,5	17,2	ON	469,68	864	18,4	2,06	2,24
    	470,84	3,9	0	 	 	471,14	832	79,5	14,5	ON	470,54	832	17,3	2,06	2,48
    	471,73	3,9	0	 	 	472,04	832	79,5	11,7	ON	471,42	832	17,3	2,06	2,33
    	472,62	3,9	0	 	 	472,92	832	79,5	9	ON	472,32	832	17,3	2,06	2,41
    	473,52	3,9	0	 	 	473,83	832	79,5	10,9	ON	473,21	832	18,4	2,06	2,72
    	474,41	3,9	0	 	 	474,69	864	79,5	13,7	ON	474,12	832	18,4	2,06	2,62
    	475,28	3,9	0	 	 	475,59	864	79,5	16	ON	475	864	18,4	2,06	2,72
    	476,21	3,9	0	 	 	476,51	864	79,5	19,1	ON	475,9	864	18,4	2,06	2,8
    	477,1	3,9	0	 	 	477,4	864	79,5	16,4	ON	476,79	864	18,4	2,06	2,57
    	477,98	3,9	0	 	 	478,26	864	79,5	13,7	ON	477,7	864	17,3	2,06	2,58
    	478,85	3,9	0	 	 	479,14	832	79,5	10,9	ON	478,55	832	17,3	2,06	2,32
    	479,73	3,9	0	 	 	480,02	832	79,5	10,2	ON	479,44	832	17,3	2,06	2,43
    	480,61	3,9	0	 	 	480,92	832	79,5	12,9	ON	480,3	832	18,4	2,06	2,44
    	481,49	3,9	0	 	 	481,79	864	79,5	15,2	ON	481,22	832	18,4	2,06	2,64
    	482,38	3,9	0	 	 	482,66	864	79,5	18	ON	482,09	832	18,4	2,06	2,46
    	483,24	3,9	0	 	 	483,53	864	81	16,4	ON	482,96	864	17,3	2,06	2,53
    	484,1	3,9	0	 	 	484,41	832	81	13,7	ON	483,81	864	17,3	2,06	2,55
    	484,97	3,9	0	 	 	485,25	832	81	12,9	ON	484,69	832	17,3	2,06	2,55
    	485,85	3,9	0	 	 	486,14	832	81	15,6	ON	485,55	832	17,3	2,06	2,55
    	486,74	3,9	0	 	 	487,02	864	81	18,4	ON	486,43	832	17,3	2,06	2,62
    	487,61	3,9	0	 	 	487,92	864	81	18,8	ON	487,32	864	17,3	2,06	2,33
    	488,53	3,9	0	 	 	488,83	864	81	16	ON	488,23	864	17,3	2,06	2,42
    	489,43	3,9	0	 	 	489,74	832	81	13,3	ON	489,13	832	17,3	2,06	2,41
    	490,33	3,9	0	 	 	490,64	832	81	12,1	ON	490,04	832	17,3	2,06	2,6
    	491,24	3,9	0	 	 	491,53	832	81	14,8	ON	490,94	832	18,4	2,06	2,64
    	492,14	3,9	0	 	 	492,44	864	81	17,6	ON	491,83	864	18,4	2,06	2,63
    	493,04	3,9	0	 	 	493,35	864	81	18,8	ON	492,74	864	18,4	2,06	2,56
    	493,94	3,9	0	 	 	494,24	832	81	16	ON	493,64	864	17,3	2,06	2,55
    	494,79	3,9	0	 	 	495,1	832	81	13,3	ON	494,52	832	17,3	2,06	2,72
    	495,7	3,9	0	 	 	496	832	81	11,7	ON	495,4	832	17,3	2,06	2,27
    	496,61	3,9	0	 	 	496,89	832	81	14,5	ON	496,29	832	18,4	2,06	2,52
    	497,47	3,9	0	 	 	497,76	832	81	17,2	ON	497,17	832	18,4	2,06	2,69
    	498,35	3,9	0	 	 	498,66	864	81	18,8	ON	498,05	864	18,4	2,06	2,73
    	499,27	3,9	0	 	 	499,55	864	81	16	ON	498,96	864	17,3	2,06	2,4
    	500,17	3,9	0	 	 	500,45	832	81	13,3	ON	499,86	832	17,3	2,06	2,38
    	501,08	3,9	0	 	 	501,38	832	81	11,7	ON	500,77	832	17,3	2,06	2,34
    	501,98	3,9	0	 	 	502,29	832	81	14,5	ON	501,68	832	18,4	2,06	2,6
    	502,88	3,9	0	 	 	503,19	864	81	17,2	ON	502,58	864	18,4	2,06	2,67
    	503,77	3,9	0	 	 	504,06	864	81	17,6	ON	503,48	864	17,3	2,06	2,54
    	504,66	3,9	0	 	 	504,94	832	81	14,8	ON	504,35	864	17,3	2,06	2,46
    	505,55	3,9	0	 	 	505,84	832	81	12,1	ON	505,24	832	17,3	2,06	2,28
    	506,42	3,9	0	 	 	506,7	800	81	12,5	ON	506,13	832	17,3	2,06	2,54
    	507,29	3,9	0	 	 	507,59	864	81	15,2	ON	507	832	18,4	2,06	2,57
    	508,17	3,9	0	 	 	508,45	864	81	18	ON	507,89	864	18,4	2,06	2,83
    	509,03	3,9	0	 	 	509,34	864	81	17,6	ON	508,73	864	18,4	2,06	2,32
    	509,94	3,9	0	 	 	510,22	832	81	14,8	ON	509,63	864	17,3	2,06	2,28
    	510,8	3,9	0	 	 	511,08	832	81	12,1	ON	510,51	832	17,3	2,06	2,39
    	511,68	3,9	0	 	 	511,97	832	81	11,3	ON	511,37	832	17,3	2,06	2,48
    	512,57	3,9	0	 	 	512,87	864	81	14,1	ON	512,28	832	17,3	2,06	2,54
    	513,47	3,9	0	 	 	513,76	864	81	16,8	ON	513,17	832	17,3	2,06	2,63
    	514,38	3,9	0	 	 	514,67	864	81	17,6	ON	514,07	864	17,3	2,06	2,39
    	515,25	3,9	0	 	 	515,55	832	81	14,8	ON	514,96	864	17,3	2,06	2,41
    	516,15	3,9	0	 	 	516,46	832	81	12,1	ON	515,85	832	17,3	2,06	2,53
    	517,04	3,9	0	 	 	517,35	832	81	13,7	ON	516,76	832	17,3	2,06	2,3
    	517,91	3,9	0	 	 	518,22	864	81	16,4	ON	517,64	864	17,3	2,06	2,54
    	518,79	3,9	0	 	 	519,08	864	81	19,1	ON	518,49	832	17,3	2,06	2,37
    	519,69	3,9	0	 	 	519,99	864	81	16,4	ON	519,38	864	17,3	2,06	2,54
    	520,58	3,9	0	 	 	520,88	832	81	13,7	ON	520,29	864	17,3	2,06	2,26
    	521,47	3,9	0	 	 	521,78	832	81	11,7	ON	521,18	832	17,3	2,06	2,48
    	522,41	3,9	0	 	 	522,69	832	81	14,5	ON	522,1	832	17,3	2,06	2,61
    	523,29	3,9	0	 	 	523,59	864	81	17,2	ON	522,99	832	17,3	2,06	2,44
    	524,19	3,9	0	 	 	524,48	864	81	17,6	ON	523,9	864	17,3	2,06	2,59
    	525,09	3,9	0	 	 	525,4	832	81	14,8	ON	524,79	864	17,3	2,06	2,46
    	525,97	3,9	0	 	 	526,28	832	81	12,5	ON	525,68	832	17,3	2,06	2,48
    	526,86	3,9	0	 	 	527,15	864	81	15,2	ON	526,56	832	17,3	2,06	2,51
    	527,74	3,9	0	 	 	528,02	864	81	18	ON	527,45	864	17,3	2,06	2,4
    	528,6	3,9	0	 	 	528,91	864	81	17,6	ON	528,31	864	17,3	2,06	2,52
    	529,5	3,9	0	 	 	529,81	832	81	14,8	ON	529,21	864	17,3	2,06	2,43
    	530,4	3,9	0	 	 	530,7	832	81	12,1	ON	530,12	832	17,3	2,06	2,38
    	531,29	3,9	0	 	 	531,57	864	81	14,1	ON	531	832	17,3	2,06	2,29
    	532,18	3,9	0	 	 	532,46	832	81	16,8	ON	531,87	864	17,3	2,06	2,44
    	533,04	3,9	0	 	 	533,32	864	81	19,5	ON	532,73	864	17,3	2,06	2,18
    	533,96	3,9	0	 	 	534,27	864	81	16,4	ON	533,65	864	17,3	2,06	2,27
    	534,86	3,9	0	 	 	535,15	832	81	13,7	ON	534,56	864	17,3	2,06	2,44
    	535,72	3,9	0	 	 	536,03	832	81	13,7	ON	535,43	832	17,3	2,06	2,52
    	536,62	3,9	0	 	 	536,92	832	81	16,4	ON	536,33	832	17,3	2,06	2,51
    	537,52	3,9	0	 	 	537,8	864	81	19,1	ON	537,22	832	17,3	2,06	2,59
    	538,4	3,9	0	 	 	538,7	864	81	18	ON	538,1	864	17,3	2,06	2,42
    	539,28	3,9	0	 	 	539,57	832	81	15,2	ON	538,98	864	17,3	2,06	2,38
    	540,16	3,9	0	 	 	540,47	832	81	12,5	ON	539,86	832	17,3	2,06	2,37
    	541,04	3,9	0	 	 	541,33	832	81	15,2	ON	540,76	832	17,3	2,06	2,3
    	541,92	3,9	0	 	 	542,19	832	81	17,6	ON	541,62	832	17,3	2,06	2,32
    	542,79	3,9	0	 	 	543,08	832	81	19,5	ON	542,5	832	17,3	2,06	2,41
    	543,67	3,9	0	 	 	543,97	832	81	16,8	ON	543,38	864	17,3	2,06	2,56
    	544,56	3,9	0	 	 	544,85	832	81	14,5	ON	544,26	832	17,3	2,06	2,6
    	545,44	3,9	0	 	 	545,72	832	81	12,9	ON	545,16	864	17,3	2,06	2,54
    	546,28	3,9	0	 	 	546,56	832	81	15,2	ON	546	832	17,3	2,06	2,31
    	547,13	3,9	0	 	 	547,42	832	81	18	ON	546,84	864	17,3	2,06	2,38
    	548	3,9	0	 	 	548,31	864	81	18	ON	547,71	832	17,3	2,06	2,62
    	548,92	3,9	0	 	 	549,23	832	81	14,8	ON	548,62	864	17,3	2,06	2,37
    	549,81	3,9	0	 	 	550,13	832	81	12,1	ON	549,52	832	17,3	2,06	2,64
    	550,71	3,9	0	 	 	551	832	81	12,1	ON	550,41	832	17,3	2,06	2,63
    	551,62	3,9	0	 	 	551,94	864	81	14,8	ON	551,31	832	18,4	2,06	2,69
    	552,53	3,9	0	 	 	552,82	864	81	17,6	ON	552,23	832	18,4	2,06	2,63
    	553,43	3,9	0	 	 	553,72	864	81	18	ON	553,13	864	18,4	2,06	2,61
    	554,33	3,9	0	 	 	554,63	864	81	15,2	ON	554,02	864	18,4	2,06	2,69
    	555,22	3,9	0	 	 	555,51	832	81	12,5	ON	554,92	864	17,3	2,06	2,55
    	556,1	3,9	0	 	 	556,41	832	81	10,2	ON	555,79	832	17,3	2,06	2,46
    	557,02	3,9	0	 	 	557,32	832	82,5	13,3	ON	556,72	832	18,4	2,06	2,66
    	557,93	3,9	0	 	 	558,22	864	82,5	16	ON	557,63	864	18,4	2,06	2,53
    	558,81	3,9	0	 	 	559,13	864	81	18,8	ON	558,52	864	18,4	2,06	2,55
    	559,73	3,9	0	 	 	560,01	864	81	16,8	ON	559,43	864	17,3	2,06	2,62
    	560,63	3,9	0	 	 	560,93	832	81	14,1	ON	560,33	832	17,3	2,06	2,44
    	561,49	3,9	0	 	 	561,76	832	81	11,3	ON	561,23	832	17,3	2,06	2,38
    	562,36	3,9	0	 	 	562,67	832	82,5	12,9	ON	562,07	832	17,3	2,06	2,51
    	563,27	3,9	0	 	 	563,56	832	82,5	15,6	ON	562,96	832	18,4	2,06	2,33
    	564,18	3,9	0	 	 	564,49	864	82,5	18,4	ON	563,87	864	18,4	2,06	2,54
    	565,09	3,9	0	 	 	565,38	864	82,5	17,6	ON	564,8	864	18,4	2,06	2,61
    	565,98	3,9	0	 	 	566,29	864	82,5	14,8	ON	565,69	864	17,3	2,06	2,58
    	566,89	3,9	0	 	 	567,19	832	82,5	11,7	ON	566,58	832	17,3	2,06	2,46
    	567,78	3,9	0	 	 	568,07	832	82,5	11,7	ON	567,49	832	17,3	2,06	2,38
    	568,65	3,9	0	 	 	568,94	832	82,5	14,5	ON	568,37	832	17,3	2,06	2,52
    	569,53	3,9	0	 	 	569,84	864	82,5	16,8	ON	569,24	864	18,4	2,06	2,72
    	570,42	3,9	0	 	 	570,71	864	82,5	17,2	ON	570,13	832	17,3	2,06	2,53
    	571,29	3,9	0	 	 	571,58	864	82,5	14,5	ON	571	864	17,3	2,06	2,61
    	572,16	3,9	0	 	 	572,43	832	82,5	12,1	ON	571,88	832	17,3	2,06	2,58
    	573,03	3,9	0	 	 	573,32	832	82,5	11,3	ON	572,74	832	17,3	2,06	2,43
    	573,92	3,9	0	 	 	574,2	832	82,5	14,1	ON	573,62	832	17,3	2,06	2,66
    	574,8	3,9	0	 	 	575,1	864	82,5	16,8	ON	574,49	832	17,3	2,06	2,71
    	575,71	3,9	0	 	 	576,01	864	82,5	18,8	ON	575,41	864	17,3	2,06	2,58
    	576,62	3,9	0	 	 	576,91	864	82,5	15,6	ON	576,32	864	17,3	2,06	2,46
    	577,51	3,9	0	 	 	577,79	832	82,5	12,9	ON	577,22	832	17,3	2,06	2,63
    	578,37	3,9	0	 	 	578,67	832	82,5	10,9	ON	578,07	832	17,3	2,06	2,56
    	579,24	3,9	0	 	 	579,53	832	82,5	13,3	ON	578,96	832	18,4	2,06	2,66
    	580,12	3,9	0	 	 	580,4	832	82,5	16	ON	579,83	864	17,3	2,06	2,42
    	580,99	3,9	0	 	 	581,29	864	82,5	18,8	ON	580,69	832	17,3	2,06	2,76
    	581,88	3,9	0	 	 	582,18	864	82,5	17,6	ON	581,57	864	17,3	2,06	2,6
    	582,78	3,9	0	 	 	583,07	832	82,5	14,5	ON	582,47	832	17,3	2,06	2,53
    	583,67	3,9	0	 	 	583,96	832	82,5	11,7	ON	583,38	832	17,3	2,06	2,32
    	584,59	4,7	0	 	 	584,9	832	82,5	14,1	ON	584,27	832	17,3	2,06	2,46
    	585,48	3,9	0	 	 	585,78	832	82,5	16,8	ON	585,19	832	17,3	2,06	2,28
    	586,37	3,9	0	 	 	586,69	864	82,5	19,5	ON	586,07	832	18,4	2,06	2,69
    	587,28	3,9	0	 	 	587,55	864	82,5	17,2	ON	586,98	864	17,3	2,06	2,58
    	588,15	3,9	0	 	 	588,42	832	82,5	14,8	ON	587,86	832	16,1	2,06	2,48
    	589,03	3,9	0	 	 	589,34	832	82,5	12,1	ON	588,74	832	16,1	2,06	2,4
    	589,92	3,9	0	 	 	590,23	832	82,5	13,7	ON	589,63	800	17,3	2,06	2,47
    	590,83	3,9	0	 	 	591,12	864	82,5	16,4	ON	590,53	832	17,3	2,06	2,4
    	591,7	3,9	0	 	 	592	864	82,5	17,6	ON	591,41	864	17,3	2,06	2,66
    	592,59	3,9	0	 	 	592,89	864	82,5	14,8	ON	592,3	864	17,3	2,06	2,62
    	593,48	3,9	0	 	 	593,77	832	82,5	12,1	ON	593,19	864	17,3	2,06	2,59
    	594,35	3,9	0	 	 	594,66	832	82,5	11,7	ON	594,04	832	17,3	2,06	2,43
    	595,25	3,9	0	 	 	595,53	832	82,5	14,1	ON	594,95	832	17,3	2,06	2,42
    	596,12	3,9	0	 	 	596,41	864	82,5	16,8	ON	595,82	832	17,3	2,06	2,71
    	597,01	3,9	0	 	 	597,3	864	82,5	17,6	ON	596,71	864	17,3	2,06	2,36
    	597,89	3,9	0	 	 	598,18	832	82,5	14,8	ON	597,6	864	17,3	2,06	2,57
    	598,79	3,9	0	 	 	599,09	832	82,5	12,1	ON	598,48	832	16,1	2,06	2,33
    	599,68	3,9	0	 	 	599,98	864	82,5	14,8	ON	599,39	832	17,3	2,06	2,38
    	600,58	3,9	0	 	 	600,88	864	82,5	17,6	ON	600,27	864	17,3	2,06	2,47
    	601,46	3,9	0	 	 	601,75	864	82,5	16,4	ON	601,17	864	17,3	2,06	2,44
    	602,34	3,9	0	 	 	602,64	832	82,5	13,7	ON	602,04	864	17,3	2,06	2,34
    	603,26	3,9	0	 	 	603,55	832	82,5	11,7	ON	602,95	832	17,3	2,06	2,36
    	604,13	3,9	0	 	 	604,41	832	82,5	14,5	ON	603,84	832	16,1	2,06	2,4
    	605	3,9	0	 	 	605,28	864	82,5	17,2	ON	604,7	832	17,3	2,06	2,49
    	605,85	3,9	0	 	 	606,15	864	82,5	18	ON	605,57	832	17,3	2,06	2,39
    	606,74	3,9	0	 	 	607,04	864	82,5	15,2	ON	606,45	832	17,3	2,06	2,38
    	607,63	3,9	0	 	 	607,93	832	82,5	12,5	ON	607,33	864	17,3	2,06	2,33
    	608,51	3,9	0	 	 	608,8	832	82,5	13,3	ON	608,23	832	17,3	2,06	2,59
    	609,41	3,9	0	 	 	609,69	832	82,5	16	ON	609,1	832	17,3	2,06	2,59
    	610,28	3,9	0	 	 	610,59	864	82,5	18,8	ON	609,98	864	17,3	2,06	2,37
    	611,19	3,9	0	 	 	611,49	864	82,5	17,2	ON	610,9	864	17,3	2,06	2,46
    	612,08	3,9	0	 	 	612,36	832	82,5	14,5	ON	611,78	864	16,1	2,06	2,3
    	612,95	3,9	0	 	 	613,25	832	82,5	12,1	ON	612,65	832	16,1	2,06	2,27
    	613,83	3,9	0	 	 	614,12	832	82,5	14,5	ON	613,54	832	16,1	2,06	2,4
    	614,72	3,9	0	 	 	615	864	82,5	17,2	ON	614,42	832	17,3	2,06	2,68
    	615,59	3,9	0	 	 	615,89	864	82,5	17,6	ON	615,29	864	17,3	2,06	2,62
    	616,45	3,9	0	 	 	616,73	864	82,5	15,2	ON	616,17	864	16,1	2,06	2,41
    	617,32	3,9	0	 	 	617,61	832	82,5	12,5	ON	617,02	832	16,1	2,06	2,43
    	618,19	4,7	0	 	 	618,5	832	82,5	14,1	ON	617,9	832	16,1	2,06	2,44
    	619,11	3,9	0	 	 	619,4	864	82,5	16,8	ON	618,81	832	16,1	2,06	2,39
    	619,99	3,9	0	 	 	620,29	864	82,5	19,5	ON	619,7	832	17,3	2,06	2,34
    	620,85	3,9	0	 	 	621,13	864	82,5	17,6	ON	620,57	864	16,1	2,06	2,21
    	621,71	3,9	0	 	 	622	832	82,5	14,8	ON	621,42	864	16,1	2,06	2,43
    	622,61	3,9	0	 	 	622,89	832	82,5	12,1	ON	622,3	864	17,3	2,06	2,26
    	623,49	3,9	0	 	 	623,79	864	82,5	14,1	ON	623,19	832	17,3	2,06	2,4
    	624,38	3,9	0	 	 	624,67	832	82,5	16,8	ON	624,09	864	17,3	2,06	2,36
    	625,25	3,9	0	 	 	625,52	864	82,5	19,5	ON	624,95	864	17,3	2,06	2,23
    	626,13	3,9	0	 	 	626,44	864	82,5	16,8	ON	625,82	864	16,1	2,06	2,4
    	627,03	3,9	0	 	 	627,35	832	82,5	14,1	ON	626,74	832	16,1	2,06	2,31
    	627,93	3,9	0	 	 	628,21	832	82,5	11,7	ON	627,65	832	17,3	2,06	2,38
    	628,8	3,9	0	 	 	629,1	832	82,5	14,1	ON	628,5	832	17,3	2,06	2,52
    	629,67	3,9	0	 	 	629,99	832	82,5	16,8	ON	629,37	832	17,3	2,06	2,58
    	630,57	3,9	0	 	 	630,86	864	82,5	19,5	ON	630,28	864	17,3	2,06	2,44
    	631,45	3,9	0	 	 	631,74	832	82,5	17,2	ON	631,15	864	17,3	2,06	2,38
    	632,3	3,9	0	 	 	632,58	832	82,5	14,8	ON	632,02	832	17,3	2,06	2,37
    	633,16	3,9	0	 	 	633,47	832	82,5	12,1	ON	632,86	832	17,3	2,06	2,52
    	634,03	3,9	0	 	 	634,34	832	82,5	14,8	ON	633,76	864	16,1	2,06	2,31
    	634,91	3,9	0	 	 	635,21	832	82,5	17,2	ON	634,63	832	17,3	2,06	2,4
    	635,81	3,9	0	 	 	636,09	864	82,5	18,8	ON	635,51	864	17,3	2,06	2,41
    	636,68	3,9	0	 	 	636,98	832	82,5	16,4	ON	636,39	864	17,3	2,06	2,44
    	637,54	3,9	0	 	 	637,82	832	82,5	13,7	ON	637,28	832	17,3	2,06	2,41
    	638,4	3,9	0	 	 	638,69	832	82,5	13,7	ON	638,1	832	17,3	2,06	2,44
    	639,26	3,9	0	 	 	639,55	864	82,5	16	ON	638,98	832	17,3	2,06	2,43
    	640,14	3,9	0	 	 	640,43	864	82,5	18,8	ON	639,84	832	17,3	2,06	2,5
    	641,03	3,9	0	 	 	641,34	864	82,5	19,1	ON	640,73	864	17,3	2,06	2,75
    	641,95	3,9	0	 	 	642,25	864	82,5	16,4	ON	641,65	864	17,3	2,06	2,38
    	642,85	3,9	0	 	 	643,13	832	82,5	13,7	ON	642,56	864	17,3	2,06	2,49
    	643,71	3,9	0	 	 	644,01	864	82,5	11,3	ON	643,41	832	17,3	2,06	2,47
    	644,61	3,9	0	 	 	644,89	832	82,5	14,1	ON	644,31	832	17,3	2,06	2,72
    	645,48	3,9	0	 	 	645,77	864	82,5	16,8	ON	645,18	832	17,3	2,06	2,51
    	646,35	3,9	0	 	 	646,65	864	82,5	18,4	ON	646,06	864	17,3	2,06	2,58
    	647,24	3,9	0	 	 	647,56	864	82,5	15,6	ON	646,95	832	17,3	2,06	2,52
    	648,15	3,9	0	 	 	648,45	832	82,5	12,9	ON	647,86	864	17,3	2,06	2,42
    	649,05	3,9	0	 	 	649,33	832	82,5	11,7	ON	648,76	832	17,3	2,06	2,39
    	649,92	3,9	0	 	 	650,22	832	82,5	14,5	ON	649,61	832	17,3	2,06	2,53
    	650,81	3,9	0	 	 	651,11	864	82,5	17,2	ON	650,52	832	17,3	2,06	2,64
    	651,71	3,9	0	 	 	652,01	864	82,5	19,1	ON	651,4	864	17,3	2,06	2,6
    	652,62	3,9	0	 	 	652,93	864	82,5	16,4	ON	652,31	864	16,1	2,06	2,44
    	653,52	3,9	0	 	 	653,84	832	82,5	13,7	ON	653,24	864	16,1	2,06	2,35
    	654,44	3,9	0	 	 	654,73	832	82,5	12,5	ON	654,15	832	16,1	2,06	2,32
    	655,29	3,9	0	 	 	655,58	832	82,5	15,2	ON	655	832	17,3	2,06	2,46
    	656,16	3,9	0	 	 	656,46	864	82,5	18	ON	655,87	864	17,3	2,06	2,59
    	657,04	3,9	0	 	 	657,34	864	82,5	18	ON	656,75	864	17,3	2,06	2,41
    	657,9	3,9	0	 	 	658,21	864	82,5	15,2	ON	657,63	864	17,3	2,06	2,26
    	658,79	3,9	0	 	 	659,09	832	82,5	12,5	ON	658,5	832	17,3	2,06	2,58
    	659,66	3,9	0	 	 	659,95	832	82,5	13,3	ON	659,37	832	16,1	2,06	2,38
    	660,52	3,9	0	 	 	660,82	864	82,5	15,6	ON	660,24	832	18,4	2,06	2,64
    	661,41	3,9	0	 	 	661,69	864	82,5	18,4	ON	661,11	864	18,4	2,06	2,75
    	662,29	3,9	0	 	 	662,6	864	82,5	17,2	ON	661,98	864	17,3	2,06	2,72
    	663,21	3,9	0	 	 	663,52	832	82,5	14,5	ON	662,9	864	16,1	2,06	2,34
    	664,11	4,7	0	 	 	664,39	832	82,5	11,7	ON	663,82	832	16,1	2,06	2,35
    	664,98	3,9	0	 	 	665,27	832	82,5	14,1	ON	664,68	800	17,3	2,06	2,57
    	665,86	3,9	0	 	 	666,16	864	82,5	16,8	ON	665,57	864	18,4	2,06	2,43
    	666,77	3,9	0	 	 	667,07	864	82,5	18,8	ON	666,46	864	18,4	2,06	2,69
    	667,65	3,9	0	 	 	667,95	864	82,5	16	ON	667,36	896	18,4	2,06	2,33
    	668,55	3,9	0	 	 	668,84	832	82,5	13,3	ON	668,24	832	17,3	2,06	2,38
    	669,43	3,9	0	 	 	669,74	832	82,5	10,5	ON	669,15	832	16,1	2,06	2,38
    	670,32	3,9	0	 	 	670,6	864	82,5	13,3	ON	670,02	832	17,3	2,06	2,31
    	671,17	3,9	0	 	 	671,45	864	82,5	16	ON	670,88	864	17,3	2,06	2,55
    	672,05	3,9	0	 	 	672,33	864	82,5	18,4	ON	671,76	832	17,3	2,06	2,63
    	672,93	3,9	0	 	 	673,23	864	82,5	16	ON	672,62	864	17,3	2,06	2,33
    	673,8	3,9	0	 	 	674,09	832	82,5	13,3	ON	673,51	864	17,3	2,06	2,53
    	674,67	3,9	0	 	 	674,98	832	82,5	12,5	ON	674,39	832	16,1	2,06	2,41
    	675,58	3,9	0	 	 	675,89	832	82,5	15,2	ON	675,27	832	17,3	2,06	2,44
    	676,46	3,9	0	 	 	676,76	864	82,5	18	ON	676,17	832	17,3	2,06	2,51
    	677,34	3,9	0	 	 	677,63	864	82,5	16,8	ON	677,04	864	17,3	2,06	2,44
    	678,25	3,9	0	 	 	678,55	864	82,5	14,1	ON	677,94	864	17,3	2,06	2,43
    	679,15	3,9	0	 	 	679,44	832	82,5	11,3	ON	678,85	832	17,3	2,06	2,44
    	680,02	3,9	0	 	 	680,32	832	82,5	13,7	ON	679,72	832	17,3	2,06	2,6
    	680,89	3,9	0	 	 	681,2	864	82,5	16,4	ON	680,6	864	17,3	2,06	2,5
    	681,82	3,9	0	 	 	682,11	864	82,5	18	ON	681,51	864	17,3	2,06	2,54
    	682,71	3,9	0	 	 	683	864	82,5	15,2	ON	682,41	864	17,3	2,06	2,51
    	683,59	3,9	0	 	 	683,89	832	82,5	12,5	ON	683,29	864	16,1	2,06	2,35
    	684,5	3,9	0	 	 	684,8	832	82,5	11,3	ON	684,18	832	16,1	2,06	2,47
    	685,4	3,9	0	 	 	685,69	832	82,5	14,1	ON	685,11	832	17,3	2,06	2,42
    	686,29	3,9	0	 	 	686,58	832	82,5	16,8	ON	685,99	832	17,3	2,06	2,5
    	687,13	3,9	0	 	 	687,44	864	82,5	18	ON	686,87	864	17,3	2,06	2,4
    	688,05	3,9	0	 	 	688,35	864	82,5	15,2	ON	687,75	864	17,3	2,06	2,53
    	688,93	3,9	0	 	 	689,21	832	82,5	12,5	ON	688,64	832	16,1	2,06	2,46
    	689,8	3,9	0	 	 	690,08	832	82,5	12,1	ON	689,49	832	17,3	2,06	2,46
    	690,69	3,9	0	 	 	690,98	832	82,5	14,8	ON	690,39	832	17,3	2,06	2,52
    	691,6	3,9	0	 	 	691,92	864	82,5	17,6	ON	691,29	864	17,3	2,06	2,44
    	692,49	3,9	0	 	 	692,78	864	82,5	16	ON	692,21	864	17,3	2,06	2,42
    	693,36	3,9	0	 	 	693,64	832	82,5	13,3	ON	693,08	864	17,3	2,06	2,43
    	694,23	3,9	0	 	 	694,54	832	82,5	11,3	ON	693,93	832	17,3	2,06	2,4
    	695,14	3,9	0	 	 	695,42	832	82,5	14,1	ON	694,85	832	17,3	2,06	2,42
    	695,98	3,9	0	 	 	696,27	832	82,5	16,8	ON	695,7	832	17,3	2,06	2,52
    	696,86	3,9	0	 	 	697,16	864	82,5	18,4	ON	696,57	864	17,3	2,06	2,27
    	697,77	3,9	0	 	 	698,07	864	82,5	15,6	ON	697,47	864	17,3	2,06	2,39
    	698,67	4,7	0	 	 	698,97	832	82,5	12,9	ON	698,37	864	17,3	2,06	2,3
    	699,56	3,9	0	 	 	699,87	832	82,5	12,9	ON	699,28	832	16,1	2,06	2,36
    	700,48	3,9	0	 	 	700,79	832	82,5	15,6	ON	700,16	832	17,3	2,06	2,41
    	701,41	3,9	0	 	 	701,69	864	82,5	18,4	ON	701,11	864	17,3	2,06	2,49
    	702,28	3,9	0	 	 	702,57	832	82,5	16,8	ON	701,97	864	17,3	2,06	2,4
    	703,18	3,9	0	 	 	703,46	832	82,5	14,1	ON	702,87	832	17,3	2,06	2,4
    	704,08	3,9	0	 	 	704,37	864	82,5	11,3	ON	703,77	864	17,3	2,06	2,24
    	704,97	3,9	0	 	 	705,28	832	82,5	13,7	ON	704,68	832	17,3	2,06	2,43
    	705,87	3,9	0	 	 	706,17	864	82,5	16,4	ON	705,57	832	17,3	2,06	2,55
    	706,77	3,9	0	 	 	707,06	864	82,5	18,8	ON	706,45	864	17,3	2,06	2,44
    	707,63	3,9	0	 	 	707,92	864	82,5	16	ON	707,33	864	17,3	2,06	2,21
    	708,51	3,9	0	 	 	708,78	832	82,5	13,3	ON	708,22	864	17,3	2,06	2,52
    	709,34	3,9	0	 	 	709,6	832	82,5	12,9	ON	709,07	864	17,3	2,06	2,39
    	710,22	3,9	0	 	 	710,51	832	82,5	15,6	ON	709,91	832	17,3	2,06	2,38
    	711,13	3,9	0	 	 	711,44	832	82,5	17,6	ON	710,83	864	17,3	2,06	2,33
    	712,03	3,9	0	 	 	712,31	864	84	14,8	ON	711,73	832	17,3	2,06	2,16
    	712,91	3,9	0	 	 	713,19	832	84	12,1	ON	712,62	864	16,1	2,06	2,41
    	713,79	3,9	0	 	 	714,08	832	84	13,3	ON	713,5	832	17,3	2,06	2,41
    	714,63	3,9	0	 	 	714,94	864	84	15,6	ON	714,35	832	17,3	2,06	2,38
    	715,54	3,9	0	 	 	715,83	864	84	18,4	ON	715,25	864	17,3	2,06	2,41
    	716,41	3,9	0	 	 	716,71	864	82,5	19,1	ON	716,11	864	17,3	2,06	2,49
    	717,31	3,9	0	 	 	717,62	864	84	16	ON	717	864	17,3	2,06	2,44
    	718,22	3,9	0	 	 	718,52	832	82,5	13,3	ON	717,92	864	16,1	2,06	2,49
    	719,12	4,7	0	 	 	719,43	832	84	10,5	ON	718,81	832	16,1	2,06	2,44
    	720,02	3,9	0	 	 	720,31	832	82,5	12,9	ON	719,72	832	17,3	2,06	2,52
    	720,89	3,9	0	 	 	721,2	832	84	15,6	ON	720,59	832	17,3	2,06	2,64
    	721,78	3,9	0	 	 	722,07	864	84	18,4	ON	721,48	864	17,3	2,06	2,58
    	722,69	3,9	0	 	 	722,98	864	84	17,2	ON	722,37	864	17,3	2,06	2,53
    	723,6	3,9	0	 	 	723,91	864	84	14,5	ON	723,29	864	17,3	2,06	2,42
    	724,5	3,9	0	 	 	724,79	832	84	11,7	ON	724,2	864	16,1	2,06	2,54
    	725,37	3,9	0	 	 	725,68	832	82,5	11,7	ON	725,09	832	16,1	2,06	2,46
    	726,3	3,9	0	 	 	726,61	864	84	14,5	ON	725,98	832	17,3	2,06	2,64
    	727,21	3,9	0	 	 	727,5	864	84	17,2	ON	726,91	864	17,3	2,06	2,54
    	728,08	3,9	0	 	 	728,37	864	84	19,5	ON	727,79	864	17,3	2,06	2,46
    	728,96	3,9	0	 	 	729,24	864	84	16,8	ON	728,68	864	17,3	2,06	2,4
    	729,83	3,9	0	 	 	730,15	832	84	14,1	ON	729,53	864	16,1	2,06	2,38
    	730,74	3,9	0	 	 	731,02	832	84	11,3	ON	730,46	864	16,1	2,06	2,24
    	731,59	3,9	0	 	 	731,88	832	84	10,9	ON	731,31	832	16,1	2,06	2,37
    	732,48	3,9	0	 	 	732,77	864	84	13,7	ON	732,18	864	18,4	2,06	2,57
    	733,37	3,9	0	 	 	733,66	864	84	16,4	ON	733,08	864	18,4	2,06	2,57
    	734,27	3,9	0	 	 	734,57	864	84	16	ON	733,98	864	17,3	2,06	2,27
    	735,18	3,9	0	 	 	735,46	832	84	13,3	ON	734,87	832	16,1	2,06	2,33
    	736,05	3,9	0	 	 	736,35	832	84	10,5	ON	735,77	832	16,1	2,06	2,22
    	736,94	4,7	0	 	 	737,23	832	84	12,5	ON	736,66	832	16,1	2,06	2,21
    	737,83	3,9	0	 	 	738,1	832	84	15,2	ON	737,54	832	17,3	2,06	2,55
    	738,7	3,9	0	 	 	739	864	84	18	ON	738,4	864	17,3	2,06	2,35
    	739,58	3,9	0	 	 	739,88	864	84	16,8	ON	739,28	864	17,3	2,06	2,48
    	740,45	3,9	0	 	 	740,75	832	84	14,1	ON	740,18	864	17,3	2,06	2,43
    	741,35	4,7	0	 	 	741,64	832	84	11,3	ON	741,06	832	16,1	2,06	2,49
    	742,23	3,9	0	 	 	742,53	832	84	12,9	ON	741,94	832	16,1	2,06	2,43
    	743,1	3,9	0	 	 	743,39	832	84	15,6	ON	742,81	832	17,3	2,06	2,46
    	743,98	3,9	0	 	 	744,27	864	84	18,4	ON	743,69	832	17,3	2,06	2,62
    	744,86	3,9	0	 	 	745,15	864	84	19,5	ON	744,56	864	17,3	2,06	2,47
    	745,78	3,9	0	 	 	746,07	864	84	16,8	ON	745,47	864	17,3	2,06	2,57
    	746,68	0	0	 	 	746,99	864	84	14,5	ON	746,4	864	16,1	2,06	2,44
    	747,59	0	0	 	 	747,92	1568	84	11,7	ON	747,33	1152	22,7	3,09	3,91
    	748,62	0	0	 	 	748,91	1504	84	3,9	ON	748,25	1632	11,4	1,03	2,81
    	749,53	0	0	 	 	749,83	1056	84	6,6	ON	749,21	1344	14,9	2,06	3,39
    	750,43	0	0	 	 	750,74	1184	84	9	ON	750,15	1024	18,4	2,06	3,71
    	751,34	0	0	 	 	751,66	1408	84	10,9	ON	751,03	1312	17,3	2,06	2,69
    	752,29	0	0	 	 	752,59	1280	84	7	ON	751,96	1408	11,4	1,03	2,58
    	753,25	0	0	 	 	753,55	1248	84	8,2	ON	752,92	1248	12,5	1,03	2,8
    	754,16	0	0	 	 	754,48	1344	84	12,5	ON	753,84	1312	13,7	2,06	2,92
    	755,14	0	0	 	 	755,47	1376	84	16,8	ON	754,81	1344	12,5	2,06	2,82
    	756,12	0	0	 	 	756,43	1376	84	17,2	ON	755,81	1376	12,5	2,06	2,84
    	757,08	0	0	 	 	757,39	1376	84	12,9	ON	756,77	1376	12,5	2,06	2,76
    	758,04	0	0	 	 	758,36	1344	84	18	ON	757,71	1344	12,5	2,06	2,87
    	758,99	0	0	 	 	759,3	1376	84	22,3	ON	758,66	1344	12,5	2,06	2,83
    	759,93	0	0	 	 	760,24	1408	84	17,6	ON	759,62	1376	12,5	2,06	2,96
    	760,88	0	0	 	 	761,2	1344	84	13,3	ON	760,55	1376	12,5	2,06	2,82
    	761,84	0	0	 	 	762,15	1344	84	16,8	ON	761,52	1344	12,5	2,06	2,87
    	762,79	0	0	 	 	763,11	1376	84	21,1	ON	762,46	1344	12,5	2,06	2,8
    	763,77	0	0	 	 	764,1	1408	82,5	18,8	ON	763,45	1408	12,5	2,06	2,76
    	764,72	0	0	 	 	765,03	1376	82,5	14,1	ON	764,41	1408	11,4	1,03	2,94
    	765,65	0	0	 	 	765,97	1344	84	14,5	ON	765,34	1376	12,5	1,03	2,83
    	766,6	0	0	 	 	766,9	1344	82,5	18,4	ON	766,29	1312	12,5	2,06	2,84
    	767,57	0	0	 	 	767,9	1440	82,5	19,9	ON	767,22	1376	12,5	2,06	2,97
    	768,51	0	0	 	 	768,83	1440	82,5	14,1	ON	768,19	1440	11,4	2,06	2,86
    	769,5	0	0	 	 	769,81	1376	82,5	13,3	ON	769,16	1408	12,5	1,03	2,95
    	770,51	0	0	 	 	770,84	1376	82,5	18	ON	770,16	1344	12,5	2,06	2,77
    	771,43	0	0	 	 	771,74	1376	82,5	18,4	ON	771,13	1376	12,5	2,06	2,83
    	772,38	0	0	 	 	772,71	1376	82,5	14,1	ON	772,05	1408	12,5	2,06	2,86
    	773,4	0	0	 	 	773,73	1312	82,5	13,7	ON	773,04	1376	11,4	1,03	2,79
    	774,37	0	0	 	 	774,7	1376	82,5	18	ON	774,06	1344	12,5	2,06	2,78
    	775,35	0	0	 	 	775,66	1408	82,5	20,7	ON	775,04	1344	12,5	2,06	2,83
    	776,29	0	0	 	 	776,62	1408	82,5	16,4	ON	775,97	1408	11,4	2,06	2,82
    	777,29	0	0	 	 	777,62	1344	82,5	14,1	ON	776,96	1376	11,4	1,03	2,69
    	778,24	0	0	 	 	778,55	1344	82,5	18,4	ON	777,92	1312	12,5	2,06	2,8
    	779,19	0	0	 	 	779,51	1408	82,5	22,7	ON	778,85	1344	12,5	2,06	2,78
    	780,13	0	0	 	 	780,45	1408	82,5	16	ON	779,81	1440	11,4	2,06	2,84
    	781,08	0	0	 	 	781,41	1312	82,5	14,8	ON	780,77	1376	12,5	1,03	2,83
    	782,06	0	0	 	 	782,4	1376	82,5	19,1	ON	781,74	1344	12,5	2,06	2,81
    	783,08	0	0	 	 	783,41	1408	82,5	19,5	ON	782,74	1376	12,5	2,06	2,78
    	784,11	0	0	 	 	784,45	1344	82,5	14,8	ON	783,76	1376	11,4	2,06	2,75
    	785,11	0	0	 	 	785,38	1344	82,5	15,6	ON	784,78	1344	12,5	2,06	2,72
    	786,03	0	0	 	 	786,33	1344	82,5	19,9	ON	785,7	1312	12,5	2,06	2,92
    	787,02	0	0	 	 	787,36	1408	82,5	24,6	ON	786,67	1344	12,5	2,06	2,86
    	787,98	0	0	 	 	788,25	1440	82,5	18,4	ON	787,67	1440	11,4	2,06	2,86
    	788,88	0	0	 	 	789,2	1376	82,5	13,3	ON	788,56	1440	11,4	1,03	2,95
    	789,82	0	0	 	 	790,13	1344	82,5	18	ON	789,5	1344	12,5	1,03	2,91
    	790,8	0	0	 	 	791,11	1376	82,5	22,7	ON	790,48	1344	12,5	2,06	2,76
    	791,78	0	0	 	 	792,09	1408	82,5	18,8	ON	791,46	1408	12,5	2,06	2,71
    	792,78	0	0	 	 	793,11	1344	82,5	14,1	ON	792,43	1408	11,4	1,03	2,75
    	793,75	0	0	 	 	794,05	1312	82,5	17,6	ON	793,4	1312	12,5	2,06	2,72
    	794,66	0	0	 	 	794,95	1376	82,5	21,9	ON	794,36	1344	12,5	2,06	2,78
    	795,6	0	0	 	 	795,93	1408	82,5	20,7	ON	795,25	1376	12,5	2,06	2,8
    	796,6	0	0	 	 	796,93	1376	82,5	16,4	ON	796,26	1408	11,4	2,06	2,78
    	797,59	0	0	 	 	797,92	1312	82,5	16,8	ON	797,26	1344	11,4	1,03	2,75
    	798,51	0	0	 	 	798,83	1344	82,5	20,7	ON	798,2	1312	12,5	2,06	2,8
    	799,45	0	0	 	 	799,77	1408	82,5	25,4	ON	799,14	1376	12,5	2,06	2,84
    	800,4	0	0	 	 	800,77	1440	82,5	19,1	ON	800,08	1440	11,4	2,06	2,83
    	801,43	0	0	 	 	801,75	1376	82,5	16,4	ON	801,09	1440	11,4	1,03	2,89
    	802,4	0	0	 	 	802,7	1376	82,5	20,7	ON	802,08	1376	12,5	2,06	2,81
    	803,38	0	0	 	 	803,71	1376	82,5	21,1	ON	803,03	1376	12,5	2,06	2,83
    	804,36	0	0	 	 	804,68	1344	82,5	16,4	ON	804,03	1376	12,5	2,06	2,89
    	805,31	0	0	 	 	805,63	1344	82,5	16,4	ON	805	1344	12,5	2,06	2,82
    	806,24	0	0	 	 	806,55	1376	82,5	20,7	ON	805,93	1376	12,5	2,06	2,84
    	807,22	0	0	 	 	807,55	1376	82,5	18,8	ON	806,88	1408	12,5	2,06	2,79
    	808,2	0	0	 	 	808,52	1344	82,5	14,1	ON	807,88	1376	11,4	1,03	2,78
    	809,16	0	0	 	 	809,49	1344	82,5	19,1	ON	808,85	1312	12,5	2,06	2,76
    	810,17	0	0	 	 	810,49	1376	82,5	23,8	ON	809,82	1344	12,5	2,06	2,8
    	811,11	0	0	 	 	811,45	1408	82,5	21,5	ON	810,8	1376	12,5	2,06	2,86
    	812,12	0	0	 	 	812,44	1408	82,5	16,8	ON	811,8	1408	11,4	2,06	2,97
    	813,07	0	0	 	 	813,39	1312	82,5	14,5	ON	812,76	1376	11,4	1,03	2,77
    	814,02	0	0	 	 	814,34	1344	82,5	19,1	ON	813,7	1312	12,5	2,06	2,84
    	815,03	0	0	 	 	815,35	1408	82,5	23,4	ON	814,69	1344	12,5	2,06	2,84
    	816,02	0	0	 	 	816,36	1440	82,5	19,1	ON	815,7	1408	11,4	2,06	2,89
    	817	0	0	 	 	817,32	1344	82,5	14,5	ON	816,69	1408	11,4	1,03	2,86
    	817,95	0	0	 	 	818,3	1376	82,5	19,1	ON	817,64	1344	12,5	2,06	2,73
    	818,93	0	0	 	 	819,23	1376	82,5	21,1	ON	818,62	1376	12,5	2,06	2,78
    	819,83	0	0	 	 	820,15	1376	82,5	16,8	ON	819,53	1376	12,5	2,06	2,78
    	820,77	0	0	 	 	821,07	1344	82,5	15,2	ON	820,46	1344	12,5	1,03	2,76
    	821,7	0	0	 	 	822,03	1344	82,5	19,5	ON	821,4	1344	12,5	2,06	2,71
    	822,68	0	0	 	 	823	1376	82,5	23,8	ON	822,37	1344	12,5	2,06	2,83
    	823,64	0	0	 	 	823,95	1408	82,5	18,4	ON	823,34	1408	12,5	2,06	2,83
    	824,59	0	0	 	 	824,91	1312	82,5	13,7	ON	824,28	1376	11,4	2,06	2,81
    	825,56	0	0	 	 	825,86	1312	82,5	18	ON	825,23	1312	12,5	2,06	2,72
    	826,53	0	0	 	 	826,86	1376	82,5	22,7	ON	826,18	1344	12,5	2,06	2,81
    	827,52	0	0	 	 	827,84	1408	82,5	20,7	ON	827,2	1408	12,5	2,06	2,89
    	828,45	0	0	 	 	828,76	1376	82,5	16,4	ON	828,15	1408	11,4	2,06	2,84
    	829,4	0	0	 	 	829,71	1344	82,5	16	ON	829,08	1376	11,4	1,03	2,77
    	830,32	0	0	 	 	830,62	1344	82,5	19,9	ON	830,01	1312	12,5	2,06	2,8
    	831,27	0	0	 	 	831,61	1408	82,5	24,2	ON	830,95	1344	12,5	2,06	2,86
    	832,27	0	0	 	 	832,59	1440	82,5	19,9	ON	831,93	1440	11,4	2,06	2,83
    	833,24	0	0	 	 	833,55	1376	82,5	15,2	ON	832,92	1408	11,4	2,06	2,86
    	834,19	0	0	 	 	834,48	1344	82,5	19,1	ON	833,88	1344	12,5	2,06	2,76
    	835,11	0	0	 	 	835,42	1408	82,5	23,4	ON	834,78	1344	12,5	2,06	2,8
    	836,05	0	0	 	 	836,38	1408	82,5	19,5	ON	835,75	1408	12,5	2,06	2,78
    	837	0	0	 	 	837,31	1344	82,5	15,2	ON	836,71	1376	11,4	2,06	2,82
    	837,94	0	0	 	 	838,26	1312	82,5	17,2	ON	837,62	1312	12,5	2,06	2,78
    	838,93	0	0	 	 	839,26	1376	82,5	21,9	ON	838,6	1344	12,5	2,06	2,72
    	839,87	0	0	 	 	840,19	1408	82,5	20,3	ON	839,57	1376	12,5	2,06	2,86
    	840,84	0	0	 	 	841,16	1376	82,5	16	ON	840,52	1408	12,5	2,06	2,82
    	841,82	0	0	 	 	842,15	1344	82,5	17,6	ON	841,49	1344	12,5	2,06	2,83
    	842,78	0	0	 	 	843,1	1376	82,5	21,9	ON	842,46	1344	12,5	2,06	2,75
    	843,76	0	0	 	 	844,1	1408	82,5	19,1	ON	843,42	1376	12,5	2,06	2,86
    	844,72	0	0	 	 	845,04	1376	82,5	14,8	ON	844,39	1408	11,4	2,06	2,81
    	845,66	0	0	 	 	845,98	1312	82,5	15,2	ON	845,34	1344	12,5	2,06	2,74
    	846,59	0	0	 	 	846,91	1344	82,5	19,5	ON	846,29	1312	12,5	2,06	2,86
    	847,55	0	0	 	 	847,87	1408	82,5	23,8	ON	847,24	1376	12,5	2,06	2,86
    	848,51	0	0	 	 	848,84	1408	82,5	20,3	ON	848,18	1408	11,4	2,06	2,83
    	849,46	0	0	 	 	849,78	1344	82,5	15,6	ON	849,15	1376	11,4	2,06	2,77
    	850,41	0	0	 	 	850,74	1344	82,5	19,5	ON	850,1	1344	12,5	2,06	2,86
    	851,37	0	0	 	 	851,7	1408	82,5	23,8	ON	851,05	1344	12,5	2,06	2,83
    	852,32	0	0	 	 	852,64	1440	82,5	18,8	ON	852,02	1440	12,5	2,06	2,77
    	853,33	0	0	 	 	853,66	1376	82,5	18	ON	852,99	1408	11,4	1,03	2,89
    	854,31	0	0	 	 	854,64	1376	82,5	22,7	ON	853,98	1376	12,5	2,06	2,83
    	855,31	0	0	 	 	855,62	1376	82,5	19,9	ON	854,96	1376	12,5	2,06	2,73
    	856,26	0	0	 	 	856,61	1344	82,5	15,2	ON	855,94	1376	11,4	2,06	2,73
    	857,26	0	0	 	 	857,56	1344	82,5	17,2	ON	856,94	1344	12,5	2,06	2,78
    	858,18	0	0	 	 	858,5	1376	82,5	21,5	ON	857,88	1344	12,5	2,06	2,78
    	859,13	0	0	 	 	859,49	1408	82,5	21,9	ON	858,82	1408	12,5	2,06	2,97
    	860,14	0	0	 	 	860,48	1376	82,5	17,2	ON	859,81	1408	11,4	2,06	2,82
    	861,09	0	0	 	 	861,4	1344	82,5	17,2	ON	860,78	1344	12,5	1,03	2,72
    	862,01	0	0	 	 	862,36	1376	82,5	21,5	ON	861,7	1344	12,5	2,06	2,89
    	863,04	0	0	 	 	863,35	1408	82,5	23	ON	862,69	1376	12,5	2,06	2,89
    	864	0	0	 	 	864,34	1408	82,5	18,4	ON	863,69	1408	11,4	2,06	2,99
    	864,99	0	0	 	 	865,32	1344	82,5	15,6	ON	864,67	1376	11,4	2,06	2,8
    	865,97	0	0	 	 	866,28	1376	82,5	20,3	ON	865,64	1376	12,5	2,06	2,76
    	866,92	0	0	 	 	867,24	1376	82,5	20,7	ON	866,6	1376	12,5	2,06	2,92
    	867,88	0	0	 	 	868,22	1376	82,5	16,4	ON	867,55	1408	12,5	2,06	2,78
    	868,92	0	0	 	 	869,24	1344	82,5	16,8	ON	868,57	1376	12,5	2,06	2,75
    	869,91	0	0	 	 	870,23	1376	82,5	21,1	ON	869,59	1344	12,5	2,06	2,74
    	870,87	0	0	 	 	871,2	1408	82,5	20,7	ON	870,56	1376	12,5	2,06	2,86
    	871,83	0	0	 	 	872,14	1376	82,5	16,4	ON	871,5	1408	12,5	2,06	2,95
    	872,78	0	0	 	 	873,09	1344	82,5	17,6	ON	872,47	1344	12,5	1,03	2,78
    	873,73	0	0	 	 	874,05	1344	82,5	21,9	ON	873,41	1344	12,5	2,06	2,86
    	874,7	0	0	 	 	875,01	1408	82,5	23,4	ON	874,36	1376	12,5	2,06	2,81
    	875,67	0	0	 	 	876,01	1408	82,5	18,4	ON	875,36	1408	11,4	2,06	2,84
    	876,65	0	0	 	 	876,97	1376	82,5	19,1	ON	876,34	1376	11,4	2,06	2,74
    	877,61	0	0	 	 	877,93	1376	82,5	23,4	ON	877,29	1376	12,5	2,06	2,81
    	878,59	0	0	 	 	878,92	1408	82,5	21,9	ON	878,27	1408	12,5	2,06	2,76
    	879,54	0	0	 	 	879,86	1408	82,5	17,2	ON	879,22	1408	11,4	2,06	2,89
    	880,51	0	0	 	 	880,81	1344	82,5	16,8	ON	880,2	1376	11,4	2,06	2,89
    	881,46	0	0	 	 	881,76	1344	82,5	21,1	ON	881,13	1344	12,5	2,06	2,74
    	882,37	0	0	 	 	882,7	1344	82,5	25,4	ON	882,07	1344	12,5	2,06	2,75
    	883,36	0	0	 	 	883,7	1376	82,5	21,5	ON	883,03	1376	12,5	2,06	2,63
    	884,35	0	0	 	 	884,67	1344	82,5	16,8	ON	884,02	1376	11,4	2,06	2,59
    	885,31	0	0	 	 	885,63	1312	82,5	21,1	ON	884,99	1312	11,4	2,06	2,63
    	886,26	0	0	 	 	886,57	1344	82,5	25,4	ON	885,95	1312	12,5	2,06	2,79
    	887,18	0	0	 	 	887,48	1376	82,5	28,1	ON	886,88	1344	12,5	2,06	2,76
    	888,11	0	0	 	 	888,44	1408	82,5	23,4	ON	887,78	1408	11,4	2,06	2,77
    	889,08	0	0	 	 	889,41	1344	82,5	19,1	ON	888,76	1376	11,4	2,06	2,69
    	890,06	0	0	 	 	890,4	1312	82,5	20,3	ON	889,74	1344	11,4	2,06	2,64
    	891,03	0	0	 	 	891,36	1344	82,5	24,6	ON	890,71	1312	11,4	2,06	2,89
    	892,01	0	0	 	 	892,32	1376	82,5	28,1	ON	891,68	1344	11,4	2,06	2,64
    	893,01	0	0	 	 	893,32	1408	82,5	23,4	ON	892,68	1408	11,4	2,06	2,68
    	893,94	0	0	 	 	894,24	1344	82,5	19,1	ON	893,63	1376	11,4	2,06	2,61
    	894,86	0	0	 	 	895,18	1280	82,5	19,1	ON	894,54	1312	11,4	1,03	2,61
    	895,82	0	0	 	 	896,14	1344	82,5	23,4	ON	895,49	1280	12,5	2,06	2,77
    	896,78	0	0	 	 	897,09	1376	82,5	28,1	ON	896,44	1344	12,5	2,06	2,72
    	897,74	0	0	 	 	898,08	1376	82,5	23,8	ON	897,4	1376	11,4	2,06	2,69
    	898,69	0	0	 	 	899	1312	82,5	19,5	ON	898,38	1344	11,4	1,03	2,67
    	899,6	0	0	 	 	899,9	1312	82,5	24,6	ON	899,3	1280	11,4	2,06	2,52
    	900,51	0	0	 	 	900,83	1376	82,5	28,1	ON	900,19	1312	12,5	2,06	2,63
    	901,46	3,1	0	 	 	901,75	1088	82,5	25	ON	901,15	1376	12,5	2,06	3,23
    	902,4	3,1	0	 	 	902,68	960	82,5	27	ON	902,08	992	17,3	3,09	4,06
    	903,31	2,3	0	 	 	903,61	1184	82,5	27,7	ON	903,02	1024	20,4	3,09	3,98
    	904,19	3,1	0	 	 	904,49	992	82,5	24,6	ON	903,91	1152	13,7	2,06	2,44
    	905,05	3,9	0	 	 	905,32	864	82,5	22,3	ON	904,77	928	16,1	2,06	3,19
    	905,9	3,9	0	 	 	906,17	832	82,5	19,5	ON	905,61	864	16,1	2,06	2,24
    	906,77	4,7	0	 	 	907,07	832	82,5	17,2	ON	906,46	800	14,9	2,06	2,14
    	907,69	0	0	 	 	907,99	1408	82,5	19,5	ON	907,39	992	21,6	3,09	4,08
    	908,62	0	0	 	 	908,93	1344	82,5	14,1	ON	908,32	1440	11,4	2,06	2,41
    	909,53	0	0	 	 	909,85	1216	82,5	9,8	ON	909,24	1312	11,4	1,03	2,24
    	910,46	0	0	 	 	910,76	1248	82,5	10,9	ON	910,15	1216	13,7	2,06	2,92
    	911,37	0	0	 	 	911,68	1344	82,5	14,8	ON	911,06	1312	13,7	2,06	2,69
    	912,3	0	0	 	 	912,6	1344	82,5	19,1	ON	911,99	1344	12,5	2,06	2,52
    	913,25	0	0	 	 	913,57	1280	82,5	16,8	ON	912,91	1312	11,4	2,06	2,56
    	914,17	0	0	 	 	914,49	1312	82,5	21,1	ON	913,88	1280	12,5	2,06	2,83
    	915,15	0	0	 	 	915,49	1376	82,5	25,4	ON	914,83	1344	12,5	2,06	3,02
    	916,14	0	0	 	 	916,46	1408	82,5	23,8	ON	915,81	1408	12,5	2,06	2,83
    	917,1	0	0	 	 	917,43	1376	82,5	19,1	ON	916,78	1408	11,4	2,06	2,78
    	918,11	0	0	 	 	918,44	1376	82,5	21,9	ON	917,79	1344	12,5	2,06	2,66
    	919,06	3,1	0	 	 	919,36	1120	82,5	25,8	ON	918,75	1376	12,5	2,06	2,75
    	919,96	3,1	0	 	 	920,27	1056	82,5	27,7	ON	919,64	1024	17,3	2,06	3,91
    	920,92	3,1	0	 	 	921,24	1120	82,5	26,6	ON	920,59	1088	19,2	3,09	3,38
    	921,82	3,9	0	 	 	922,09	896	82,5	25	ON	921,53	1024	14,9	2,06	2,59
    	922,66	3,9	0	 	 	922,96	864	82,5	23,4	ON	922,38	864	17,3	2,06	3,04
    	923,55	3,9	0	 	 	923,84	864	82,5	22,3	ON	923,25	864	16,1	2,06	2,24
    	924,45	4,7	0	 	 	924,74	832	82,5	20,7	ON	924,13	864	14,9	2,06	2,31
    	925,33	4,7	0	 	 	925,61	800	82,5	19,5	ON	925,04	832	14,9	2,06	2,3
    	926,18	3,9	0	 	 	926,48	864	82,5	21,1	ON	925,89	832	17,3	2,06	2,61
    	927,07	3,9	0	 	 	927,36	864	82,5	22,3	ON	926,76	864	17,3	2,06	2,33
    	927,94	3,9	0	 	 	928,24	832	82,5	19,5	ON	927,65	864	17,3	2,06	2,43
    	928,83	3,9	0	 	 	929,12	864	82,5	16,8	ON	928,53	832	17,3	2,06	2,41
    	929,72	4,7	0	 	 	930,02	832	82,5	14,1	ON	929,42	832	16,1	2,06	2,3
    	930,6	3,9	0	 	 	930,9	832	82,5	14,1	ON	930,32	832	17,3	2,06	2,26
    	931,5	3,9	0	 	 	931,79	832	82,5	17,2	ON	931,2	832	17,3	2,06	2,53
    	932,39	3,9	0	 	 	932,67	864	82,5	19,5	ON	932,09	832	17,3	2,06	2,63
    	933,26	3,9	0	 	 	933,56	864	82,5	21,9	ON	932,96	864	17,3	2,06	2,49
    	934,15	3,9	0	 	 	934,45	864	82,5	19,1	ON	933,86	864	16,1	2,06	2,46
    	935,03	3,9	0	 	 	935,33	832	82,5	16,4	ON	934,74	864	16,1	2,06	2,33
    	935,89	3,9	0	 	 	936,19	832	82,5	14,1	ON	935,6	832	16,1	2,06	2,35
    	936,8	3,9	0	 	 	937,09	832	82,5	16	ON	936,51	832	17,3	2,06	2,58
    	937,67	3,9	0	 	 	937,96	864	82,5	18,8	ON	937,38	864	17,3	2,06	2,51
    	938,54	3,9	0	 	 	938,84	864	82,5	21,1	ON	938,24	864	17,3	2,06	2,57
    	939,44	3,9	0	 	 	939,73	864	82,5	19,5	ON	939,14	896	17,3	2,06	2,24
    	940,28	3,9	0	 	 	940,59	832	82,5	16,8	ON	940,01	864	16,1	2,06	2,43
    	941,17	4,7	0	 	 	941,48	832	82,5	14,1	ON	940,89	832	16,1	2,06	2,37
    	942,07	3,9	0	 	 	942,37	832	82,5	16,4	ON	941,79	832	16,1	2,06	2,52
    	942,98	3,9	0	 	 	943,28	864	82,5	19,1	ON	942,68	832	17,3	2,06	2,42
    	943,87	3,9	0	 	 	944,18	864	84	21,5	ON	943,58	864	17,3	2,06	2,29
    	944,75	3,9	0	 	 	945,04	832	82,5	18,8	ON	944,47	864	16,1	2,06	2,36
    	945,63	3,9	0	 	 	945,95	832	84	16	ON	945,34	832	16,1	2,06	2,27
    	946,52	3,9	0	 	 	946,82	832	84	13,3	ON	946,25	832	17,3	2,06	2,26
    	947,44	3,9	0	 	 	947,74	832	82,5	15,6	ON	947,14	832	17,3	2,06	2,46
    	948,33	3,9	0	 	 	948,63	832	84	18,4	ON	948,03	832	17,3	2,06	2,32
    	949,22	3,9	0	 	 	949,53	864	84	21,1	ON	948,93	864	17,3	2,06	2,34
    	950,14	3,9	0	 	 	950,44	864	84	21,9	ON	949,85	864	17,3	2,06	2,59
    ok, try #2. I see that LTFT (idle) is back just after engine is started again, that's good sign
    Let's try driving and get LTFT (partial) out of 0%... Didn't happened though. Next day car will get ~200km and I will check how it's changed.
    Tuesday	25	June	2019	20:03:30:00008-VCID:1E3368789AB7DDBF84-5178	VCDS Version: Release 19,6,0 (x64)	Data version: 20190529 DS308,0
    3B0 906 018 A		1,6l/2V SIMOS3 G00HS0009
    	Group A:	'032				Group B:	'099				Group C:	'002
    		Adaptation (Idle)	Adaptation (Partial)	 	 		Engine Speed	Coolant	Lambda Control	Lambda Control		Engine Speed	Engine Load	Injection Timing	Mass Air Flow
    	TIME	Bank 1 Sensor 1	Bank 1 Sensor 1			TIME	(G28)	Temperature (G62)		Status	TIME	(G28)			Sensor (G70)
    Marker	STAMP	 %	 %			STAMP	 /min	C	 %		STAMP	 /min	 %	 ms	 g/s
    	0,01	0	0	 	 	0,26	0	85,5	0	OFF	0,53	0	0	2,06	0
    	0,8	0	0	 	 	1,06	0	85,5	0	OFF	1,33	0	0	2,06	0
    	1,6	0	0	 	 	1,92	1088	85,5	0	OFF	2,22	1312	32,9	4,12	4,04
    	2,53	1,6	0	 	 	2,84	992	85,5	0	OFF	3,15	928	23,9	3,09	4,22
    	3,44	2,3	0	 	 	3,74	928	85,5	0	OFF	4,03	928	26,3	3,09	4,25
    	4,32	2,3	0	 	 	4,6	928	85,5	0	OFF	4,91	928	23,9	3,09	3,79
    	5,21	2,3	0	 	 	5,52	896	85,5	0	OFF	5,82	896	22,7	3,09	2,77
    	6,14	3,1	0	 	 	6,43	896	85,5	0	OFF	6,72	896	20,4	2,06	2,62
    	7,02	3,1	0	 	 	7,31	864	85,5	0	OFF	7,61	864	20,4	2,06	2,68
    	7,91	3,1	0	 	 	8,2	832	85,5	0	OFF	8,51	832	19,2	2,06	2,38
    	8,81	3,9	0	 	 	9,08	832	85,5	0	OFF	9,38	832	20,4	2,06	2,44
    	9,66	3,9	0	 	 	9,95	832	85,5	0	OFF	10,25	832	20,4	2,06	2,39
    	10,55	3,1	0	 	 	10,83	832	85,5	0	OFF	11,12	832	20,4	2,06	2,91
    	11,42	3,1	0	 	 	11,72	864	85,5	0	OFF	12,01	864	21,6	2,06	2,78
    	12,3	3,1	0	 	 	12,59	864	85,5	0	OFF	12,89	864	21,6	2,06	2,94
    	13,19	3,1	0	 	 	13,48	832	85,5	0	OFF	13,78	832	20,4	2,06	2,82
    	14,06	3,1	0	 	 	14,36	832	85,5	0	OFF	14,67	832	20,4	2,06	2,95
    	14,99	3,1	0	 	 	15,28	864	85,5	0	OFF	15,56	864	20,4	2,06	2,66
    	15,85	3,1	0	 	 	16,16	832	85,5	0	OFF	16,46	832	21,6	2,06	2,96
    	16,75	3,1	0	 	 	17,05	864	85,5	0	OFF	17,35	832	21,6	2,06	3,06
    	17,65	3,1	0	 	 	17,94	832	85,5	0	OFF	18,24	832	21,6	2,06	3,26
    	18,54	3,1	0	 	 	18,83	864	85,5	0	OFF	19,12	864	20,4	2,06	2,91
    	19,41	3,1	0	 	 	19,71	832	85,5	0	OFF	20,01	832	21,6	2,06	3,26
    	20,31	3,1	0	 	 	20,59	832	85,5	0	OFF	20,89	864	20,4	2,06	3,01
    	21,2	3,1	0	 	 	21,5	832	85,5	0	OFF	21,78	832	20,4	2,06	3,17
    	22,06	3,1	0	 	 	22,35	832	85,5	0	OFF	22,63	864	20,4	2,06	2,89
    	22,93	3,1	0	 	 	23,22	832	85,5	0,8	ON	23,52	864	21,6	2,06	3,21
    	23,81	3,1	0	 	 	24,1	864	85,5	3,5	ON	24,39	864	20,4	2,06	2,95
    	24,69	3,1	0	 	 	24,98	864	85,5	6,3	ON	25,27	864	19,2	2,06	2,71
    	25,57	3,1	0	 	 	25,87	864	85,5	9	ON	26,14	864	19,2	2,06	2,55
    	26,44	3,9	0	 	 	26,74	864	85,5	11,7	ON	27,04	864	18,4	2,06	2,52
    	27,31	3,9	0	 	 	27,62	864	85,5	14,1	ON	27,93	864	18,4	2,06	2,53
    	28,22	3,9	0	 	 	28,52	864	85,5	16,8	ON	28,81	864	18,4	2,06	2,36
    	29,12	3,9	0	 	 	29,43	864	85,5	15,6	ON	29,74	864	18,4	2,06	2,52
    	30,03	3,9	0	 	 	30,32	832	85,5	12,9	ON	30,61	864	17,3	2,06	2,24
    	30,92	3,9	0	 	 	31,21	832	85,5	10,2	ON	31,5	832	17,3	2,06	2,44
    	31,76	3,9	0	 	 	32,04	832	85,5	9,4	ON	32,34	832	18,4	2,06	2,43
    	32,61	3,9	0	 	 	32,9	832	85,5	12,1	ON	33,19	864	18,4	2,06	2,46
    	33,51	3,9	0	 	 	33,8	864	85,5	14,8	ON	34,1	864	18,4	2,06	2,47
    	34,38	3,9	0	 	 	34,69	864	85,5	17,6	ON	35,01	864	17,3	2,06	2,26
    	35,3	3,9	0	 	 	35,59	864	85,5	18,8	ON	35,88	864	17,3	2,06	2,24
    	36,18	3,9	0	 	 	36,47	832	85,5	16	ON	36,77	832	17,3	2,06	2,38
    	37,05	3,9	0	 	 	37,36	832	85,5	13,3	ON	37,64	832	16,1	2,06	2,3
    	37,92	3,9	0	 	 	38,23	832	85,5	16	ON	38,52	832	17,3	2,06	2,34
    	38,79	3,9	0	 	 	39,08	832	85,5	18,4	ON	39,36	832	16,1	2,06	2,34
    	39,65	3,9	0	 	 	39,95	864	85,5	21,1	ON	40,24	864	16,1	2,06	2,54
    	40,54	3,9	0	 	 	40,85	864	85,5	21,5	ON	41,14	864	16,1	2,06	2,21
    	41,43	3,9	0	 	 	41,73	864	85,5	18,8	ON	42,02	832	16,1	2,06	2,2
    	42,32	4,7	0	 	 	42,59	832	85,5	16	ON	42,87	832	16,1	2,06	2,28
    	43,17	3,9	0	 	 	43,46	832	85,5	16	ON	43,74	832	16,1	2,06	2,28
    	44,05	3,9	0	 	 	44,34	832	85,5	18,4	ON	44,62	832	16,1	2,06	2,32
    	44,88	3,9	0	 	 	45,19	864	85,5	21,1	ON	45,48	832	16,1	2,06	2,39
    	45,79	3,9	0	 	 	46,08	864	85,5	23,8	ON	46,37	864	16,1	2,06	2,31
    	46,66	3,9	0	 	 	46,97	864	85,5	25	ON	47,27	864	16,1	2,06	2,09
    	47,56	3,9	0	 	 	47,86	864	85,5	22,3	ON	48,15	832	14,9	2,06	2,18
    	48,44	4,7	0	 	 	48,72	832	85,5	19,5	ON	49,01	832	14,9	2,06	2,18
    	49,32	4,7	0	 	 	49,63	832	85,5	17,6	ON	49,92	832	16,1	2,06	2,77
    	50,21	3,9	0	 	 	50,52	864	85,5	19,9	ON	50,83	864	17,3	2,06	2,32
    	51,14	3,9	0	 	 	51,44	864	85,5	23	ON	51,72	896	17,3	2,06	2,24
    	52	3,9	0	 	 	52,28	864	85,5	24,6	ON	52,57	864	16,1	2,06	2,16
    	52,88	3,9	0	 	 	53,19	864	85,5	21,9	ON	53,48	832	14,9	2,06	2,18
    	53,76	4,7	0	 	 	54,06	832	85,5	19,1	ON	54,35	832	16,1	2,06	2,4
    	54,64	3,9	0	 	 	54,95	832	85,5	18,4	ON	55,23	832	17,3	2,06	2,46
    	55,52	3,9	0	 	 	55,8	864	85,5	21,1	ON	56,09	864	17,3	2,06	2,52
    	56,39	3,9	0	 	 	56,68	864	85,5	23,8	ON	56,97	896	17,3	2,06	2,11
    	57,27	3,9	0	 	 	57,54	864	85,5	24,2	ON	57,83	864	16,1	2,06	2,31
    	58,13	4,7	0	 	 	58,41	832	85,5	21,5	ON	58,71	832	14,9	2,06	2,06
    	59,03	4,7	0	 	 	59,34	832	85,5	18,8	ON	59,63	832	14,9	2,06	2,07
    	59,92	4,7	0	 	 	60,22	832	85,5	16	ON	60,52	832	16,1	2,06	2,18
    	60,81	4,7	0	 	 	61,11	832	85,5	17,6	ON	61,39	832	18,4	2,06	2,78
    	61,69	3,9	0	 	 	61,99	864	85,5	19,9	ON	62,29	864	17,3	2,06	2,64
    	62,59	3,9	0	 	 	62,89	864	85,5	22,7	ON	63,19	864	17,3	2,06	2,69
    	63,47	3,9	0	 	 	63,76	864	85,5	25,4	ON	64,04	864	16,1	2,06	2,24
    	64,33	3,9	0	 	 	64,61	864	85,5	24,6	ON	64,92	832	16,1	2,06	2,3
    	65,22	3,9	0	 	 	65,54	832	85,5	21,9	ON	65,83	832	14,9	2,06	2,07
    	66,11	4,7	0	 	 	66,41	832	85,5	19,1	ON	66,7	832	16,1	2,06	2,26
    	66,98	3,9	0	 	 	67,29	832	85,5	16,4	ON	67,58	832	17,3	2,06	2,64
    	67,87	3,9	0	 	 	68,16	864	85,5	18	ON	68,47	864	18,4	2,06	2,64
    	68,78	3,9	0	 	 	69,07	864	85,5	20,7	ON	69,36	864	17,3	2,06	2,52
    	69,67	3,9	0	 	 	69,97	864	85,5	23,4	ON	70,28	832	17,3	2,06	2,36
    	70,56	3,9	0	 	 	70,86	864	85,5	23,8	ON	71,15	864	16,1	2,06	2,11
    	71,45	3,9	0	 	 	71,75	864	85,5	21,1	ON	72,03	864	16,1	2,06	2,24
    	72,33	3,9	0	 	 	72,63	832	85,5	18,4	ON	72,9	832	16,1	2,06	2,24
    	73,21	3,9	0	 	 	73,5	832	85,5	15,6	ON	73,82	832	17,3	2,06	2,44
    	74,12	3,9	0	 	 	74,4	832	85,5	18	ON	74,68	832	17,3	2,06	2,6
    	74,97	3,9	0	 	 	75,28	864	85,5	20,7	ON	75,58	864	17,3	2,06	2,62
    	75,87	3,9	0	 	 	76,18	864	85,5	23,4	ON	76,47	864	17,3	2,06	2,3
    	76,77	3,9	0	 	 	77,05	864	85,5	25	ON	77,35	864	16,1	2,06	2,19
    	77,64	3,9	0	 	 	77,91	864	85,5	22,7	ON	78,19	832	16,1	2,06	2,41
    	78,48	3,9	0	 	 	78,77	832	85,5	19,9	ON	79,04	832	16,1	2,06	2,26
    	79,35	3,9	0	 	 	79,63	832	85,5	18	ON	79,91	832	16,1	2,06	2,33
    	80,21	3,9	0	 	 	80,5	832	85,5	20,3	ON	80,78	832	16,1	2,06	2,36
    	81,07	3,9	0	 	 	81,37	832	85,5	22,7	ON	81,68	832	16,1	2,06	2,33
    	81,99	3,9	0	 	 	82,27	864	85,5	24,2	ON	82,58	864	16,1	2,06	2,34
    	82,88	3,9	0	 	 	83,18	832	85,5	21,5	ON	83,47	864	16,1	2,06	2,34
    	83,79	3,9	0	 	 	84,07	832	85,5	18,8	ON	84,36	832	16,1	2,06	2,23
    	84,66	3,9	0	 	 	84,95	832	85,5	21,1	ON	85,24	864	16,1	2,06	2,41
    	85,52	3,9	0	 	 	85,83	832	85,5	23,8	ON	86,12	832	16,1	2,06	2,38
    	86,4	3,9	0	 	 	86,7	864	85,5	24,2	ON	86,99	832	16,1	2,06	2,15
    	87,26	3,9	0	 	 	87,57	832	85,5	21,5	ON	87,86	832	16,1	2,06	2,23
    	88,16	3,9	0	 	 	88,45	832	85,5	20,3	ON	88,75	832	16,1	2,06	2,27
    	89,04	3,9	0	 	 	89,35	832	85,5	23	ON	89,63	864	16,1	2,06	2,24
    	89,94	3,9	0	 	 	90,23	864	85,5	25,8	ON	90,53	864	16,1	2,06	2,31
    	90,84	3,9	0	 	 	91,14	864	85,5	25,4	ON	91,44	864	16,1	2,06	2,34
    	91,74	3,9	0	 	 	92,03	864	85,5	22,7	ON	92,32	832	16,1	2,06	2,3
    	92,61	4,7	0	 	 	92,91	832	85,5	25	ON	93,2	832	16,1	2,06	2,12
    	93,48	4,7	0	 	 	93,78	832	85,5	27,3	ON	94,07	832	16,1	2,06	2,26
    	94,34	3,9	0	 	 	94,64	832	85,5	30,1	ON	94,92	864	16,1	2,06	2,12
    	95,23	4,7	0	 	 	95,51	864	85,5	31,6	ON	95,8	864	16,1	2,06	2,24
    	96,08	3,9	0	 	 	96,38	864	85,5	31,6	ON	96,68	864	14,9	2,06	2,34
    	96,97	4,7	0	 	 	97,27	864	85,5	29,3	ON	97,57	832	14,9	2,06	2,02
    	97,86	4,7	0	 	 	98,18	832	85,5	27,7	ON	98,49	832	14,9	2,06	2,18
    	98,77	4,7	0	 	 	99,06	832	85,5	27,7	ON	99,36	832	14,9	2,06	2,06
    	99,64	4,7	0	 	 	99,92	832	85,5	27,7	ON	100,22	832	16,1	2,06	2,41
    	100,51	4,7	0	 	 	100,81	832	85,5	25,4	ON	101,12	832	16,1	2,06	2,33
    	101,41	3,9	0	 	 	101,72	864	85,5	23	ON	101,99	832	16,1	2,06	2,17
    	102,3	4,7	0	 	 	102,59	832	85,5	20,3	ON	102,88	832	16,1	2,06	2,18
    	103,17	3,9	0	 	 	103,46	864	85,5	22,3	ON	103,77	864	16,1	2,06	2,28
    	104,05	3,9	0	 	 	104,36	864	85,5	25	ON	104,67	864	16,1	2,06	2,34
    	104,95	4,7	0	 	 	105,24	864	85,5	27,7	ON	105,55	832	16,1	2,06	2,33
    	105,83	4,7	0	 	 	106,13	832	85,5	25,4	ON	106,42	832	17,3	2,06	2,74
    	106,71	3,9	0	 	 	106,98	864	85,5	24,6	ON	107,28	864	16,1	2,06	2,38
    	107,56	3,9	0	 	 	107,86	864	85,5	27,3	ON	108,16	864	16,1	2,06	2,38
    	108,44	3,9	0	 	 	108,72	864	85,5	25	ON	109	832	16,1	2,06	2,26
    	109,3	0	0	 	 	109,7	1376	85,5	22,7	ON	110,01	1440	19,2	3,09	2,28
    	110,32	2,3	0	 	 	110,63	1120	85,5	17,6	ON	110,92	992	23,9	3,09	6,13
    	111,26	0	0	 	 	111,58	1088	85,5	17,2	ON	111,91	1216	40	6,18	7,04
    	112,23	0	0	 	 	112,54	1152	85,5	17,6	ON	112,84	1120	19,2	2,06	2,88
    	113,19	0	0	 	 	113,49	1024	85,5	15,2	ON	113,81	1152	25,1	3,09	3,47
    	114,11	2,3	0	 	 	114,42	1184	85,5	18	ON	114,72	1120	16,1	2,06	2,93
    	115,03	3,1	0	 	 	115,33	864	85,5	15,2	ON	115,64	800	42,4	8,24	11,75
    	115,93	0	0	 	 	116,26	1568	85,5	12,9	ON	116,6	1472	27,5	3,09	6,48
    	116,92	0	0	 	 	117,21	960	85,5	10,2	ON	117,5	832	29,8	4,12	6,21
    	117,81	2,3	0	 	 	118,11	896	85,5	11,7	ON	118,41	928	21,6	3,09	2,6
    	118,72	3,1	0	 	 	119,02	896	85,5	12,1	ON	119,3	864	19,2	2,06	2,62
    	119,57	3,1	0	 	 	119,89	864	85,5	10,9	ON	120,19	864	19,2	2,06	2,5
    	120,51	3,1	0	 	 	120,8	864	85,5	13,3	ON	121,08	896	18,4	2,06	2,49
    	121,39	3,9	0	 	 	121,69	864	85,5	13,3	ON	121,99	864	19,2	2,06	2,67
    	122,29	3,9	0	 	 	122,6	864	85,5	12,1	ON	122,9	864	19,2	2,06	2,83
    	123,18	3,1	0	 	 	123,48	864	85,5	14,8	ON	123,76	864	18,4	2,06	2,54
    	124,08	0	0	 	 	124,39	1056	85,5	17,2	ON	124,68	1376	38,8	6,18	17,44
    	125	0	0	 	 	125,33	1376	85,5	16,8	ON	125,64	992	25,1	3,09	5,58
    	125,96	0	0	 	 	126,26	1120	85,5	15,2	ON	126,6	1184	19,2	3,09	3,17
    	126,9	0	0	 	 	127,21	1248	85,5	16,8	ON	127,51	1280	14,9	2,06	2,49
    	127,83	0	0	 	 	128,15	1248	85,5	12,5	ON	128,47	1216	13,7	2,06	2,6
    	128,81	0	0	 	 	129,13	1184	85,5	11,7	ON	129,43	1152	16,1	2,06	3,49
    	129,74	0	0	 	 	130,05	1184	85,5	14,5	ON	130,37	1120	19,2	2,06	3,89
    	130,68	0	0	 	 	130,98	1216	85,5	17,2	ON	131,29	1248	18,4	2,06	3,72
    	131,61	0	0	 	 	131,93	1280	85,5	21,1	ON	132,25	1312	16,1	2,06	3,11
    	132,56	0	0	 	 	132,88	1312	85,5	22,3	ON	133,21	1312	14,9	2,06	3,35
    	133,51	0	0	 	 	133,81	1312	85,5	19,9	ON	134,12	1280	14,9	2,06	3,23
    	134,43	0	0	 	 	134,73	1280	85,5	23,8	ON	135,02	1280	14,9	2,06	3,42
    	135,36	0	0	 	 	135,71	1280	85,5	28,1	ON	136,03	1280	17,3	3,09	3,89
    	136,36	0	0	 	 	136,7	1312	85,5	26,6	ON	137,02	1312	14,9	2,06	3,22
    	137,32	0	0	 	 	137,64	1280	85,5	22,3	ON	137,96	1280	12,5	2,06	2,32
    	138,27	0	0	 	 	138,56	1280	85,5	18	ON	138,87	1280	12,5	2,06	2,6
    	139,18	0	0	 	 	139,5	1280	85,5	18,4	ON	139,83	1312	12,5	2,06	2,44
    	140,16	0	0	 	 	140,49	1312	85,5	22,7	ON	140,82	1376	14,9	2,06	3,6
    	141,12	0	0	 	 	141,44	1376	85,5	27	ON	141,77	1376	14,9	2,06	3,17
    	142,1	0	0	 	 	142,45	1408	85,5	25,8	ON	142,74	1440	12,5	2,06	3,09
    	143,18	0	0	 	 	143,57	1504	85,5	21,9	ON	143,89	1600	22,7	4,12	9,09
    	144,26	0	0	 	 	144,64	1888	85,5	25,4	ON	144,98	1792	0	0	4,63
    	145,28	0	0	 	 	145,64	1472	85,5	0	ON	146	1472	51,4	7,21	11,01
    	146,36	0	0	 	 	146,71	1760	85,5	0,4	ON	147,05	1888	40	5,15	11,55
    	147,41	0	0	 	 	147,74	2080	85,5	0,8	ON	148,06	2144	51,4	7,21	20,94
    	148,39	0	0	 	 	148,72	2496	85,5	7	ON	149,03	2688	72,9	10,3	31,51
    	149,33	0	0	 	 	149,68	3040	85,5	7,4	ON	150	3200	46,7	4,12	11,53
    	150,31	0	0	 	 	150,62	2496	85,5	0	ON	150,96	2016	75,3	10,3	23,79
    	151,31	0	0	 	 	151,63	2240	85,5	0	ON	151,94	2304	74,1	9,27	27
    	152,27	0	0	 	 	152,62	2432	85,5	0	ON	152,97	2528	74,1	9,27	29,62
    	153,3	0	0	 	 	153,61	2656	85,5	6,3	ON	153,93	2720	75,3	10,3	32,67
    	154,31	0	0	 	 	154,66	2752	85,5	0	OFF	154,98	2432	0	0	5,47
    	155,33	0	0	 	 	155,66	1760	85,5	0	OFF	156,01	1472	0	0	3,2
    	156,34	3,1	0	 	 	156,64	1216	85,5	0	ON	156,97	1184	16,1	2,06	3,04
    	157,3	3,1	0	 	 	157,61	1152	85,5	0	ON	157,95	1120	14,9	2,06	2,67
    	158,26	3,1	0	 	 	158,54	1024	85,5	0,4	ON	158,9	992	17,3	2,06	3,06
    	159,19	3,1	0	 	 	159,47	992	85,5	-1,2	ON	159,82	992	18,4	2,06	3,03
    	160,16	3,1	0	 	 	160,5	928	85,5	-3,9	ON	160,79	864	18,4	2,06	3,04
    	161,08	3,1	0	 	 	161,39	864	85,5	-3,1	ON	161,67	864	19,2	2,06	2,55
    	161,96	3,9	0	 	 	162,27	864	85,5	-0,4	ON	162,55	864	19,2	2,06	2,79
    	162,85	3,1	0	 	 	163,15	864	85,5	2,3	ON	163,45	864	19,2	2,06	2,59
    	163,75	3,9	0	 	 	164,05	864	85,5	5,1	ON	164,33	864	19,2	2,06	2,72
    	164,62	3,1	0	 	 	164,93	864	85,5	7,8	ON	165,2	832	18,4	2,06	2,89
    	165,5	3,9	0	 	 	165,79	832	85,5	10,2	ON	166,07	832	18,4	2,06	2,49
    	166,36	3,9	0	 	 	166,67	864	85,5	12,9	ON	166,97	864	18,4	2,06	2,41
    	167,26	3,9	0	 	 	167,54	864	85,5	15,6	ON	167,84	864	18,4	2,06	2,61
    	168,13	3,1	0	 	 	168,4	896	85,5	18,4	ON	168,69	864	22,7	4,12	3,83
    	169	0	0	 	 	169,33	1664	85,5	21,9	ON	169,64	1728	36,5	5,15	11,42
    	169,98	0	0	 	 	170,28	1216	85,5	28,5	ON	170,62	1504	44,3	7,21	10,41
    	170,96	0	0	 	 	171,28	1568	85,5	0	OFF	171,61	1280	27,5	4,12	11,78
    	171,92	0	0	 	 	172,23	1344	85,5	0,4	ON	172,62	1504	54,9	7,21	12,24
    	172,98	0	0	 	 	173,31	1760	85,5	0,4	ON	173,66	1920	58	7,21	17,98
    	174	0	0	 	 	174,32	2272	85,5	0,4	ON	174,64	2272	0	0	6,99
    	175	0	0	 	 	175,35	1536	85,5	0	ON	175,7	1600	65,1	9,27	17,07
    	176,03	0	0	 	 	176,35	1760	85,5	0,4	ON	176,73	1856	66,3	9,27	20,36
    	177,09	0	0	 	 	177,43	2016	85,5	0,4	ON	177,77	2080	68,6	9,27	22,44
    	178,1	0	0	 	 	178,44	2272	85,5	10,5	ON	178,76	2336	56,9	6,18	21,07
    	179,11	0	0	 	 	179,47	1760	85,5	0	ON	179,83	1760	61,6	8,24	17
    	180,21	0	0	 	 	180,58	1824	85,5	0,4	ON	180,96	1856	45,5	6,18	13,47
    	181,3	0	0	 	 	181,66	1920	85,5	0,8	ON	181,99	1952	34,1	4,12	10,42
    	182,34	0	0	 	 	182,7	1984	85,5	5,5	ON	183,06	2016	22,7	3,09	7,16
    	183,42	0	0	 	 	183,77	2016	85,5	14,8	ON	184,13	2016	20,4	3,09	6,51
    	184,49	0	0	 	 	184,84	2048	85,5	25	ON	185,2	2080	20,4	3,09	6,67
    	185,53	0	0	 	 	185,87	2080	85,5	28,5	ON	186,2	2112	28,6	4,12	10,41
    	186,55	0	0	 	 	186,88	2144	85,5	25	ON	187,23	2144	31,8	4,12	11,21
    	187,57	0	0	 	 	187,92	2144	85,5	0	OFF	188,27	1824	16,1	2,06	4,43
    	188,62	0	0	 	 	188,99	1856	85,5	0,4	ON	189,34	1856	32,9	4,12	10
    	189,69	0	0	 	 	190,04	1888	85,5	0,4	ON	190,41	1888	25,1	3,09	7,29
    	190,78	0	0	 	 	191,14	1888	85,5	0,4	ON	191,5	1920	23,9	3,09	7,07
    	191,85	0	0	 	 	192,22	1920	85,5	8,6	ON	192,58	1920	23,9	3,09	7,73
    	192,94	0	0	 	 	193,29	1920	85,5	18,4	ON	193,66	1920	26,3	4,12	8,26
    	194	0	0	 	 	194,35	1952	85,5	28,1	ON	194,72	1952	26,3	4,12	8,49
    	195,07	0	0	 	 	195,43	1952	85,5	23,8	ON	195,79	1952	26,3	4,12	8,17
    	196,14	0	0	 	 	196,49	1984	85,5	27,3	ON	196,85	1984	25,1	4,12	8,52
    	197,21	0	0	 	 	197,57	1984	85,5	22,7	ON	197,91	1984	25,1	4,12	8,22
    	198,27	0	0	 	 	198,63	1984	85,5	24,2	ON	198,97	2016	26,3	4,12	8,64
    	199,33	0	0	 	 	199,68	2016	85,5	27,3	ON	200,04	2016	28,6	4,12	9,68
    	200,39	0	0	 	 	200,75	2016	85,5	20,3	ON	201,1	2016	29,8	4,12	9,97
    	201,44	0	0	 	 	201,78	2016	85,5	24,2	ON	202,14	2016	34,1	5,15	11,78
    	202,48	0	0	 	 	202,83	2048	85,5	27,3	ON	203,19	2048	40	6,18	12,5
    	203,54	0	0	 	 	203,86	2048	85,5	18,4	ON	204,21	2048	41,2	6,18	13,86
    	204,57	0	0	 	 	204,93	2080	85,5	18,8	ON	205,27	2080	46,7	6,18	15,07
    	205,64	0	0	 	 	205,98	2112	85,5	22,7	ON	206,32	2112	45,5	7,21	15,72
    	206,66	0	0	 	 	206,99	2112	85,5	24,2	ON	207,32	2144	45,5	7,21	16,09
    	207,65	0	0	 	 	207,97	2144	85,5	23,4	ON	208,32	2144	45,5	7,21	16,16
    	208,66	0	0	 	 	208,99	2144	85,5	18	ON	209,31	2176	45,5	7,21	16,16
    	209,66	0	0	 	 	209,98	2176	85,5	22,7	ON	210,31	2176	46,7	7,21	16,16
    	210,65	0	0	 	 	210,99	2176	85,5	25	ON	211,32	2176	45,5	7,21	16,5
    	211,67	0	0	 	 	212	2208	85,5	19,5	ON	212,34	2208	46,7	7,21	16,5
    	212,68	0	0	 	 	213,03	2208	85,5	17,6	ON	213,38	2208	46,7	7,21	16,09
    	213,73	0	0	 	 	214,08	2208	85,5	18	ON	214,41	2208	45,5	7,21	16,5
    	214,76	0	0	 	 	215,1	2240	85,5	21,9	ON	215,44	2240	45,5	7,21	16,24
    	215,76	0	0	 	 	216,08	2240	85,5	24,2	ON	216,4	2240	46,7	7,21	17,09
    	216,72	0	0	 	 	217,06	2240	85,5	19,1	ON	217,39	2240	46,7	7,21	17,16
    	217,74	0	0	 	 	218,07	2240	85,5	17,2	ON	218,4	2272	45,5	7,21	16,63
    	218,73	0	0	 	 	219,07	2272	85,5	21,9	ON	219,39	2272	43,5	6,18	15,81
    	219,73	0	0	 	 	220,07	2272	85,5	21,1	ON	220,38	2272	40	6,18	14,8
    	220,71	0	0	 	 	221,04	2272	85,5	20,3	ON	221,38	2272	41,2	6,18	15,19
    	221,71	0	0	 	 	222,06	2272	85,5	21,5	ON	222,4	2272	41,2	6,18	15,19
    	222,74	0	0	 	 	223,08	2272	85,5	25,8	ON	223,39	2272	41,2	6,18	15,51
    	223,71	0	0	 	 	224,03	2272	85,5	21,5	ON	224,35	2272	41,2	6,18	14,89
    	224,7	0	0	 	 	225,02	2272	85,5	19,9	ON	225,35	2272	41,2	6,18	15,02
    	225,69	0	0	 	 	226,03	2272	85,5	25,8	ON	226,36	2272	41,2	6,18	14,56
    	226,69	0	0	 	 	227,02	2272	85,5	22,3	ON	227,33	2272	41,2	6,18	15,26
    	227,66	0	0	 	 	228	2272	85,5	18	ON	228,34	2272	42,4	6,18	15,51
    	228,66	0	0	 	 	228,99	2272	85,5	22,3	ON	229,32	2304	43,5	6,18	15,83
    	229,64	0	0	 	 	229,98	2304	85,5	22,3	ON	230,32	2304	43,5	6,18	15,86
    	230,65	0	0	 	 	230,98	2304	85,5	18,8	ON	231,3	2304	42,4	6,18	15,83
    	231,63	0	0	 	 	231,95	2304	85,5	18	ON	232,26	2304	42,4	6,18	15,36
    	232,59	0	0	 	 	232,93	2304	85,5	23,8	ON	233,25	2304	42,4	6,18	15,86
    	233,58	0	0	 	 	233,9	2304	85,5	21,5	ON	234,23	2304	41,2	6,18	15,51
    	234,56	0	0	 	 	234,88	2336	85,5	18	ON	235,22	2336	42,4	6,18	15,83
    	235,55	0	0	 	 	235,88	2336	85,5	19,5	ON	236,21	2336	41,2	6,18	15,19
    	236,53	0	0	 	 	236,86	2336	85,5	24,2	ON	237,19	2336	35,3	5,15	13,89
    	237,52	0	0	 	 	237,83	2336	85,5	19,5	ON	238,16	2336	35,3	5,15	12,92
    	238,49	0	0	 	 	238,82	2336	85,5	17,2	ON	239,14	2336	35,3	5,15	13,13
    	239,47	0	0	 	 	239,8	2336	85,5	20,7	ON	240,14	2336	36,5	5,15	13,65
    	240,49	0	0	 	 	240,8	2368	85,5	22,7	ON	241,14	2368	36,5	5,15	13,94
    	241,45	0	0	 	 	241,79	2368	85,5	21,5	ON	242,12	2368	36,5	5,15	13,65
    	242,46	0	0	 	 	242,79	2368	85,5	18,4	ON	243,11	2400	36,5	5,15	14,14
    	243,43	0	0	 	 	243,75	2400	85,5	22,3	ON	244,09	2400	36,5	5,15	13,74
    	244,42	0	0	 	 	244,74	2400	85,5	23,8	ON	245,06	2400	32,9	5,15	13,16
    	245,39	0	0	 	 	245,73	2400	85,5	18,4	ON	246,05	2400	32,9	5,15	13,02
    	246,39	0	0	 	 	246,73	2432	85,5	18	ON	247,05	2432	32,9	4,12	12,97
    	247,38	0	0	 	 	247,71	2432	85,5	23,4	ON	248,03	2432	31	4,12	12,11
    	248,36	0	0	 	 	248,68	2432	85,5	14,8	ON	249	2432	29,8	4,12	11,68
    	249,33	0	0	 	 	249,68	2432	85,5	18,4	ON	250,01	2432	28,6	4,12	11,51
    	250,38	0	0	 	 	250,7	2432	85,5	21,1	ON	251,03	2432	26,3	4,12	10,65
    	251,36	0	0	 	 	251,68	2432	85,5	16,4	ON	252,01	2432	27,5	4,12	10,41
    	252,35	0	0	 	 	252,7	2400	85,5	18	ON	253,02	2400	27,5	3,09	10,75
    	253,36	0	0	 	 	253,68	2400	85,5	20,7	ON	254	2400	27,5	4,12	10,65
    	254,34	0	0	 	 	254,67	2400	85,5	15,6	ON	254,99	2400	27,5	4,12	10,63
    	255,33	0	0	 	 	255,67	2400	85,5	22,7	ON	255,98	2400	28,6	4,12	11,13
    	256,29	0	0	 	 	256,63	2400	85,5	13,7	ON	256,97	2400	28,6	4,12	10,94
    	257,32	0	0	 	 	257,68	2400	85,5	22,3	ON	258	2400	28,6	4,12	10,96
    	258,34	0	0	 	 	258,69	2400	85,5	16,8	ON	259,01	2400	28,6	4,12	11,25
    	259,36	0	0	 	 	259,72	2400	85,5	18,8	ON	260,04	2400	29,8	4,12	11,32
    	260,36	0	0	 	 	260,69	2400	85,5	19,1	ON	261	2400	29,8	4,12	11,68
    	261,33	0	0	 	 	261,64	2400	85,5	19,9	ON	261,97	2400	29,8	4,12	11,68
    	262,29	0	0	 	 	262,61	2400	85,5	19,9	ON	262,94	2400	31	4,12	12,11
    	263,26	0	0	 	 	263,58	2400	85,5	18	ON	263,92	2400	31	4,12	12,23
    	264,23	0	0	 	 	264,57	2400	85,5	22,3	ON	264,91	2400	31,8	5,15	11,95
    	265,24	0	0	 	 	265,57	2400	85,5	16	ON	265,91	2400	31	4,12	12,39
    	266,24	0	0	 	 	266,58	2400	85,5	20,7	ON	266,91	2400	31,8	4,12	12,23
    	267,25	0	0	 	 	267,6	2432	85,5	19,9	ON	267,93	2432	31	4,12	12,18
    	268,25	0	0	 	 	268,6	2432	85,5	17,2	ON	268,92	2432	31,8	4,12	12,23
    	269,27	0	0	 	 	269,61	2432	85,5	21,1	ON	269,94	2432	31,8	4,12	12,44
    	270,27	0	0	 	 	270,58	2432	85,5	19,5	ON	270,92	2432	31,8	5,15	12,5
    	271,25	0	0	 	 	271,58	2432	85,5	16	ON	271,92	2432	31,8	4,12	12,23
    	272,24	0	0	 	 	272,57	2432	85,5	20,3	ON	272,9	2432	31,8	4,12	12,78
    	273,24	0	0	 	 	273,55	2432	85,5	21,1	ON	273,88	2432	31,8	4,12	12,41
    	274,23	0	0	 	 	274,57	2432	85,5	16,4	ON	274,91	2432	31	4,12	12,23
    	275,24	0	0	 	 	275,57	2432	85,5	16	ON	275,91	2432	29,8	4,12	11,68
    	276,27	0	0	 	 	276,58	2432	84	19,5	ON	276,91	2432	29,8	4,12	11,68
    	277,24	0	0	 	 	277,56	2432	85,5	19,1	ON	277,9	2432	27,5	4,12	11,16
    	278,22	0	0	 	 	278,58	2432	84	16	ON	278,91	2432	28,6	4,12	11,16
    	279,23	0	0	 	 	279,57	2432	84	16,8	ON	279,89	2432	28,6	4,12	11,12
    	280,22	0	0	 	 	280,56	2432	85,5	20,3	ON	280,91	2432	28,6	4,12	11,42
    	281,25	0	0	 	 	281,57	2400	84	12,9	ON	281,91	2400	28,6	4,12	11,36
    	282,25	0	0	 	 	282,58	2400	84	16,8	ON	282,91	2400	29,8	4,12	11,38
    	283,25	0	0	 	 	283,57	2400	84	21,9	ON	283,89	2400	29,8	4,12	11,68
    	284,23	0	0	 	 	284,54	2400	84	19,1	ON	284,87	2400	31	4,12	11,68
    	285,2	0	0	 	 	285,52	2400	84	15,6	ON	285,85	2400	31,8	4,12	12,41
    	286,19	0	0	 	 	286,52	2400	84	16,4	ON	286,86	2400	32,9	5,15	12,5
    	287,19	0	0	 	 	287,51	2400	84	18	ON	287,83	2400	32,9	4,12	12,95
    	288,16	0	0	 	 	288,5	2432	84	19,9	ON	288,83	2432	34,1	5,15	13,36
    	289,17	0	0	 	 	289,49	2432	84	20,3	ON	289,8	2432	32,9	5,15	12,78
    	290,13	0	0	 	 	290,46	2432	84	21,1	ON	290,82	2432	31	4,12	12,5
    	291,15	0	0	 	 	291,48	2432	84	14,5	ON	291,82	2432	31	4,12	12,12
    	292,16	0	0	 	 	292,49	2432	84	17,2	ON	292,86	2432	31,8	4,12	12,26
    	293,19	0	0	 	 	293,51	2432	84	19,5	ON	293,84	2432	31	4,12	12,23
    	294,18	0	0	 	 	294,52	2432	84	11,7	ON	294,85	2432	31	4,12	11,66
    	295,18	0	0	 	 	295,52	2432	84	14,8	ON	295,86	2432	31	4,12	11,95
    	296,2	0	0	 	 	296,52	2432	84	18,8	ON	296,84	2432	31,8	4,12	12,23
    	297,18	0	0	 	 	297,51	2432	84	16	ON	297,86	2432	32,9	4,12	12,78
    	298,2	0	0	 	 	298,54	2432	84	13,7	ON	298,86	2432	31,8	4,12	12,5
    	299,2	0	0	 	 	299,54	2432	84	17,2	ON	299,87	2432	34,1	5,15	13,36
    	300,19	0	0	 	 	300,52	2432	84	19,1	ON	300,84	2432	34,1	5,15	12,99
    	301,16	0	0	 	 	301,49	2432	84	16,4	ON	301,81	2432	34,1	5,15	13,36
    	302,12	0	0	 	 	302,46	2432	84	15,2	ON	302,79	2432	34,1	5,15	13,43
    	303,11	0	0	 	 	303,44	2432	84	19,5	ON	303,77	2432	36,5	5,15	13,94
    	304,11	0	0	 	 	304,44	2432	84	19,5	ON	304,79	2432	36,5	5,15	14,25
    	305,11	0	0	 	 	305,45	2464	84	18,4	ON	305,79	2464	37,6	5,15	14,25
    	306,12	0	0	 	 	306,46	2464	84	13,7	ON	306,78	2464	36,5	5,15	14,56
    	307,14	0	0	 	 	307,48	2464	84	13,3	ON	307,8	2464	36,5	5,15	14,25
    	308,16	0	0	 	 	308,48	2464	84	15,2	ON	308,8	2464	36,5	5,15	14,87
    	309,12	0	0	 	 	309,46	2496	84	16,4	ON	309,8	2496	35,3	5,15	14,17
    	310,12	0	0	 	 	310,45	2496	84	19,9	ON	310,75	2496	36,5	5,15	14,46
    	311,06	0	0	 	 	311,4	2496	84	18,4	ON	311,73	2496	36,5	5,15	14,41
    	312,08	0	0	 	 	312,41	2496	84	15,2	ON	312,73	2528	35,3	5,15	14,38
    	313,06	0	0	 	 	313,37	2528	84	14,1	ON	313,7	2528	36,5	5,15	14,38
    	314,04	0	0	 	 	314,38	2528	84	14,1	ON	314,72	2528	35,3	5,15	14,56
    	315,03	0	0	 	 	315,36	2528	84	17,2	ON	315,71	2528	35,3	5,15	14,79
    	316,05	0	0	 	 	316,39	2528	84	21,1	ON	316,74	2528	34,1	5,15	14,25
    	317,07	0	0	 	 	317,39	2528	84	16,8	ON	317,74	2528	32,9	5,15	13,63
    	318,09	0	0	 	 	318,42	2528	84	15,6	ON	318,76	2560	31	4,12	12,5
    	319,09	0	0	 	 	319,43	2528	84	12,1	ON	319,78	2528	31	4,12	12,62
    	320,12	0	0	 	 	320,47	2528	84	14,1	ON	320,81	2528	31	4,12	12,5
    	321,14	0	0	 	 	321,45	2528	84	16,8	ON	321,78	2528	31	4,12	12,78
    	322,11	0	0	 	 	322,46	2528	84	16,8	ON	322,81	2528	31	4,12	12,5
    	323,15	0	0	 	 	323,48	2528	84	13,7	ON	323,85	2528	31	4,12	12,5
    	324,18	0	0	 	 	324,51	2528	84	10,9	ON	324,84	2528	31	4,12	12,78
    	325,16	0	0	 	 	325,5	2528	84	15,2	ON	325,84	2528	31	4,12	12,71
    	326,17	0	0	 	 	326,5	2528	84	18,4	ON	326,84	2528	31	4,12	12,5
    	327,19	0	0	 	 	327,53	2496	84	16,8	ON	327,87	2496	31,8	4,12	13,07
    	328,2	0	0	 	 	328,54	2496	84	16	ON	328,86	2496	34,1	5,15	13,55
    	329,2	0	0	 	 	329,53	2496	84	13,7	ON	329,84	2496	32,9	4,12	13,43
    	330,17	0	0	 	 	330,5	2528	84	17,2	ON	330,82	2528	32,9	4,12	13,65
    	331,17	0	0	 	 	331,5	2528	84	20,7	ON	331,82	2528	32,9	4,12	13,53
    	332,15	0	0	 	 	332,49	2528	84	18,4	ON	332,83	2528	32,9	5,15	13,65
    	333,17	0	0	 	 	333,5	2528	84	15,2	ON	333,82	2528	34,1	5,15	14,03
    	334,16	0	0	 	 	334,49	2528	84	15,6	ON	334,85	2528	35,3	5,15	14,28
    	335,16	0	0	 	 	335,49	2528	84	13,3	ON	335,84	2528	36,5	5,15	14,87
    	336,17	0	0	 	 	336,51	2528	84	15,6	ON	336,83	2528	36,5	5,15	15,19
    	337,18	0	0	 	 	337,51	2560	84	17,6	ON	337,83	2560	41,2	5,15	16,67
    	338,17	0	0	 	 	338,5	2560	84	15,2	ON	338,84	2560	42,4	6,18	17,18
    	339,19	0	0	 	 	339,5	2560	84	15,6	ON	339,85	2592	41,2	6,18	17,07
    	340,16	0	0	 	 	340,47	2592	84	14,1	ON	340,8	2592	41,2	6,18	16,87
    	341,14	0	0	 	 	341,45	2592	84	14,1	ON	341,77	2592	41,2	6,18	17,18
    	342,09	0	0	 	 	342,41	2624	84	12,1	ON	342,73	2624	41,2	6,18	17,44
    	343,06	0	0	 	 	343,4	2624	84	14,1	ON	343,75	2624	41,2	6,18	17,18
    	344,08	0	0	 	 	344,41	2656	84	13,3	ON	344,76	2656	41,2	6,18	17,18
    	345,1	0	0	 	 	345,43	2656	84	12,9	ON	345,75	2656	40	5,15	17,15
    	346,09	0	0	 	 	346,42	2656	84	16	ON	346,75	2656	40	5,15	16,75
    	347,08	0	0	 	 	347,43	2656	84	15,6	ON	347,74	2688	37,6	5,15	16,16
    	348,07	0	0	 	 	348,39	2688	84	16,8	ON	348,71	2688	37,6	5,15	16,38
    	349,02	0	0	 	 	349,35	2688	84	19,5	ON	349,67	2688	37,6	5,15	16,01
    	350	0	0	 	 	350,32	2688	84	16,4	ON	350,65	2688	32,9	5,15	14,2
    	351	0	0	 	 	351,31	2688	84	15,6	ON	351,62	2688	32,9	4,12	14,25
    	351,93	0	0	 	 	352,27	2688	84	17,6	ON	352,61	2688	32,9	4,12	13,94
    	352,94	0	0	 	 	353,28	2688	84	20,3	ON	353,6	2688	32,9	4,12	14,25
    	353,91	0	0	 	 	354,24	2688	84	22,3	ON	354,6	2688	32,9	5,15	14,25
    	354,94	0	0	 	 	355,27	2688	84	19,1	ON	355,6	2688	31,8	5,15	13,94
    	355,92	0	0	 	 	356,26	2688	84	15,6	ON	356,56	2688	31,8	4,12	13,92
    	356,88	0	0	 	 	357,22	2688	84	18	ON	357,56	2688	31,8	4,12	14,25
    	357,91	0	0	 	 	358,22	2688	84	18,8	ON	358,55	2688	31,8	4,12	13,94
    	358,88	0	0	 	 	359,2	2688	84	19,9	ON	359,51	2688	29,8	4,12	12,47
    	359,87	0	0	 	 	360,19	2688	84	18	ON	360,5	2656	28,6	4,12	12,5
    	360,84	0	0	 	 	361,18	2656	84	14,8	ON	361,52	2656	29,8	4,12	12,76
    	361,86	0	0	 	 	362,2	2656	84	19,1	ON	362,53	2656	29,8	4,12	12,78
    	362,85	0	0	 	 	363,19	2656	84	19,5	ON	363,52	2656	29,8	4,12	12,78
    	363,86	0	0	 	 	364,19	2656	84	17,2	ON	364,53	2656	29,8	4,12	12,78
    	364,86	0	0	 	 	365,19	2656	84	14,5	ON	365,52	2656	29,8	4,12	13,07
    	365,85	0	0	 	 	366,18	2656	84	18,4	ON	366,5	2656	31	4,12	13,07
    	366,83	0	0	 	 	367,17	2656	84	19,9	ON	367,53	2656	29,8	4,12	12,78
    	367,88	0	0	 	 	368,22	2656	84	17,6	ON	368,55	2656	29,8	4,12	12,38
    	368,87	0	0	 	 	369,22	2624	84	14,5	ON	369,56	2656	29,8	4,12	12,73
    	369,9	0	0	 	 	370,26	2624	84	17,6	ON	370,62	2624	29,8	4,12	13,07
    	370,96	0	0	 	 	371,3	2624	84	19,5	ON	371,65	2624	31	4,12	13,65
    	371,99	0	0	 	 	372,32	2624	84	21,9	ON	372,66	2624	32,9	5,15	13,89
    	373,01	0	0	 	 	373,34	2656	84	20,3	ON	373,67	2656	32,9	5,15	13,65
    	374	0	0	 	 	374,34	2656	84	15,6	ON	374,69	2656	31,8	4,12	13,49
    	375,02	0	0	 	 	375,35	2656	84	18,8	ON	375,69	2656	31,8	4,12	13,62
    	376,03	0	0	 	 	376,37	2656	84	20,3	ON	376,68	2656	31,8	4,12	13,94
    	377	0	0	 	 	377,34	2656	84	21,9	ON	377,68	2656	31,8	4,12	13,65
    	377,98	0	0	 	 	378,3	2656	84	17,2	ON	378,62	2656	31	4,12	13,36
    	378,95	0	0	 	 	379,28	2656	84	15,2	ON	379,61	2656	29,8	4,12	12,78
    	379,94	0	0	 	 	380,28	2656	84	18,4	ON	380,62	2656	28,6	4,12	12,5
    	380,98	0	0	 	 	381,31	2656	84	17,6	ON	381,63	2656	29,8	4,12	13,07
    	381,96	0	0	 	 	382,29	2656	84	13,7	ON	382,61	2656	31	4,12	13,65
    	382,95	0	0	 	 	383,26	2656	84	17,6	ON	383,6	2656	31,8	4,12	13,53
    	383,92	0	0	 	 	384,22	2656	84	22,7	ON	384,56	2656	31	4,12	13,33
    	384,87	0	0	 	 	385,2	2656	84	17,2	ON	385,53	2656	28,6	4,12	12,78
    	385,86	0	0	 	 	386,21	2656	84	14,5	ON	386,53	2656	28,6	4,12	12,35
    	386,85	0	0	 	 	387,16	2656	84	15,6	ON	387,48	2656	29,8	4,12	12,71
    	387,8	0	0	 	 	388,13	2656	84	21,5	ON	388,45	2688	31	4,12	13,09
    	388,76	0	0	 	 	389,11	2656	84	18	ON	389,43	2688	31	4,12	13,36
    	389,76	0	0	 	 	390,09	2656	84	15,6	ON	390,4	2688	31	4,12	13,63
    	390,73	0	0	 	 	391,07	2688	84	15,6	ON	391,38	2688	31	4,12	13,36
    	391,72	0	0	 	 	392,05	2688	84	18	ON	392,36	2688	28,6	4,12	11,98
    	392,68	0	0	 	 	393,02	2688	84	17,2	ON	393,34	2688	27,5	4,12	11,73
    	393,67	0	0	 	 	394	2688	84	14,1	ON	394,31	2688	27,5	3,09	12
    	394,62	0	0	 	 	394,96	2656	84	19,9	ON	395,27	2688	27,5	4,12	11,95
    	395,6	0	0	 	 	395,92	2656	84	17,2	ON	396,24	2656	27,5	4,12	11,68
    	396,58	0	0	 	 	396,9	2656	84	12,5	ON	397,24	2656	28,6	4,12	12,52
    	397,57	0	0	 	 	397,89	2656	84	16,8	ON	398,21	2656	28,6	4,12	12,5
    	398,53	0	0	 	 	398,84	2656	84	19,5	ON	399,16	2656	28,6	4,12	11,78
    	399,49	0	0	 	 	399,79	2656	84	13,7	ON	400,13	2656	27,5	4,12	11,95
    	400,46	0	0	 	 	400,81	2656	84	12,5	ON	401,13	2656	27,5	4,12	11,75
    	401,47	0	0	 	 	401,81	2656	84	16,8	ON	402,13	2656	28,6	4,12	12,18
    	402,46	0	0	 	 	402,8	2656	84	19,1	ON	403,14	2656	28,6	4,12	12,2
    	403,46	0	0	 	 	403,8	2656	84	14,8	ON	404,14	2656	27,5	4,12	11,83
    	404,47	0	0	 	 	404,8	2656	84	13,7	ON	405,14	2656	35,3	5,15	15,51
    	405,48	0	0	 	 	405,8	2656	84	16	ON	406,12	2656	36,5	5,15	15,59
    	406,45	0	0	 	 	406,78	2656	84	19,5	ON	407,12	2656	34,1	5,15	14,76
    	407,43	0	0	 	 	407,74	2688	84	20,3	ON	408,06	2688	31	4,12	13,33
    	408,39	0	0	 	 	408,72	2688	84	20,3	ON	409,05	2688	28,6	4,12	12,3
    	409,37	0	0	 	 	409,68	2688	84	14,8	ON	410,02	2688	26,3	3,09	11,16
    	410,35	0	0	 	 	410,66	2688	84	13,3	ON	410,99	2688	25,1	3,09	10,61
    	411,32	0	0	 	 	411,65	2656	84	14,5	ON	411,98	2656	25,1	3,09	10,65
    	412,3	0	0	 	 	412,65	2656	84	20,7	ON	412,98	2656	25,1	3,09	11,11
    	413,31	0	0	 	 	413,65	2656	84	15,6	ON	413,99	2656	26,3	3,09	11,39
    	414,31	0	0	 	 	414,64	2656	84	13,7	ON	414,98	2656	26,3	3,09	11,44
    	415,31	0	0	 	 	415,62	2656	82,5	18	ON	415,96	2656	27,5	4,12	11,88
    	416,29	0	0	 	 	416,61	2624	82,5	17,2	ON	416,94	2624	27,5	4,12	12,04
    	417,27	0	0	 	 	417,6	2624	82,5	14,5	ON	417,93	2624	28,6	4,12	12,2
    	418,27	0	0	 	 	418,59	2624	82,5	13,7	ON	418,92	2624	28,6	4,12	12,5
    	419,24	0	0	 	 	419,58	2624	82,5	18	ON	419,92	2624	29,8	4,12	12,71
    	420,27	0	0	 	 	420,61	2624	82,5	18,4	ON	420,94	2624	29,8	4,12	12,5
    	421,26	0	0	 	 	421,58	2624	82,5	15,6	ON	421,9	2624	29,8	4,12	13,07
    	422,25	0	0	 	 	422,6	2624	82,5	14,8	ON	422,95	2656	31	4,12	13,07
    	423,28	0	0	 	 	423,6	2624	82,5	15,2	ON	423,93	2656	31	4,12	13,23
    	424,26	0	0	 	 	424,59	2656	82,5	18,8	ON	424,91	2656	31	4,12	13,29
    	425,24	0	0	 	 	425,58	2656	82,5	18,8	ON	425,91	2656	29,8	4,12	13,02
    	426,24	0	0	 	 	426,57	2656	82,5	15,2	ON	426,9	2656	29,8	4,12	12,78
    	427,26	0	0	 	 	427,59	2656	82,5	13,7	ON	427,93	2656	31	4,12	12,81
    	428,24	0	0	 	 	428,56	2656	82,5	16	ON	428,89	2656	29,8	4,12	12,78
    	429,22	0	0	 	 	429,54	2656	82,5	19,5	ON	429,87	2656	28,6	4,12	12,42
    	430,19	0	0	 	 	430,51	2656	82,5	18	ON	430,83	2656	28,6	4,12	12,23
    	431,15	0	0	 	 	431,47	2656	82,5	10,5	ON	431,79	2656	28,6	4,12	12,27
    	432,12	0	0	 	 	432,45	2656	82,5	13,7	ON	432,78	2656	29,8	4,12	12,5
    	433,1	0	0	 	 	433,43	2656	82,5	17,2	ON	433,76	2656	29,8	4,12	12,5
    	434,08	0	0	 	 	434,41	2656	82,5	17,6	ON	434,75	2656	29,8	4,12	12,47
    	435,08	0	0	 	 	435,41	2656	82,5	15,2	ON	435,75	2656	29,8	4,12	12,78
    	436,08	0	0	 	 	436,42	2656	82,5	12,1	ON	436,75	2656	29,8	4,12	12,3
    	437,08	0	0	 	 	437,41	2656	82,5	14,5	ON	437,74	2656	29,8	4,12	12,68
    	438,06	0	0	 	 	438,39	2656	82,5	16,8	ON	438,71	2656	28,6	4,12	11,95
    	439,02	0	0	 	 	439,34	2656	82,5	16,8	ON	439,66	2656	28,6	4,12	11,95
    	440	0	0	 	 	440,32	2624	82,5	13,7	ON	440,65	2656	28,6	4,12	12,32
    	440,97	0	0	 	 	441,3	2624	82,5	13,7	ON	441,64	2624	29,8	4,12	12,86
    	441,97	0	0	 	 	442,33	2624	82,5	18	ON	442,66	2624	31	4,12	12,8
    	443,01	0	0	 	 	443,35	2624	82,5	18,4	ON	443,7	2624	31,8	4,12	13,14
    	444,03	0	0	 	 	444,38	2624	82,5	15,6	ON	444,72	2624	31,8	4,12	13,65
    	445,07	0	0	 	 	445,41	2624	82,5	14,1	ON	445,76	2624	31,8	4,12	13,81
    	446,09	0	0	 	 	446,42	2656	82,5	16,8	ON	446,74	2656	31,8	4,12	13,41
    	447,06	0	0	 	 	447,41	2624	82,5	17,2	ON	447,74	2624	32,9	4,12	13,94
    	448,06	0	0	 	 	448,39	2624	82,5	17,6	ON	448,72	2624	32,9	4,12	14,25
    	449,05	0	0	 	 	449,39	2624	82,5	19,1	ON	449,73	2624	32,9	5,15	14,25
    	450,08	0	0	 	 	450,41	2624	82,5	18	ON	450,75	2624	34,1	5,15	14,54
    	451,06	0	0	 	 	451,38	2624	82,5	14,5	ON	451,71	2624	34,1	5,15	15,08
    	452,05	0	0	 	 	452,4	2624	82,5	14,1	ON	452,73	2624	34,1	5,15	14,56
    	453,04	0	0	 	 	453,37	2624	82,5	15,2	ON	453,7	2656	35,3	5,15	15,02
    	454,03	0	0	 	 	454,35	2656	82,5	17,2	ON	454,67	2656	35,3	5,15	14,63
    	455	0	0	 	 	455,33	2656	82,5	17,6	ON	455,65	2656	34,1	5,15	14,56
    	455,98	0	0	 	 	456,31	2656	82,5	20,3	ON	456,65	2656	34,1	5,15	14,25
    	456,96	0	0	 	 	457,28	2656	82,5	19,9	ON	457,62	2656	31,8	4,12	13,65
    	457,95	0	0	 	 	458,28	2656	82,5	17,2	ON	458,62	2656	31	4,12	13,07
    	458,96	0	0	 	 	459,3	2656	82,5	12,9	ON	459,62	2656	31	4,12	13,28
    	459,96	0	0	 	 	460,3	2656	82,5	11,7	ON	460,62	2656	31,8	4,12	13,54
    	460,96	0	0	 	 	461,31	2656	82,5	16,8	ON	461,64	2624	31,8	4,12	13,65
    	461,96	0	0	 	 	462,29	2624	82,5	21,5	ON	462,62	2624	32,9	5,15	14,11
    	462,94	0	0	 	 	463,3	2624	82,5	16,4	ON	463,62	2624	34,1	5,15	14,25
    	463,96	0	0	 	 	464,3	2624	82,5	15,2	ON	464,65	2624	34,1	5,15	14,56
    	464,98	0	0	 	 	465,33	2624	82,5	12,9	ON	465,67	2624	35,3	5,15	14,87
    	466	0	0	 	 	466,33	2624	82,5	15,2	ON	466,66	2624	36,5	5,15	15,51
    	467	0	0	 	 	467,34	2624	82,5	18,4	ON	467,7	2624	37,6	5,15	15,88
    	468,03	0	0	 	 	468,37	2656	82,5	19,1	ON	468,7	2656	37,6	5,15	15,83
    	469,02	0	0	 	 	469,36	2656	82,5	17,2	ON	469,68	2656	36,5	5,15	15,51
    	470,01	0	0	 	 	470,34	2656	82,5	15,6	ON	470,68	2656	35,3	5,15	15,22
    	471,01	0	0	 	 	471,34	2656	82,5	14,8	ON	471,66	2656	35,3	5,15	14,59
    	471,98	0	0	 	 	472,33	2656	82,5	14,5	ON	472,66	2656	34,1	5,15	14,59
    	473	0	0	 	 	473,32	2656	82,5	16,4	ON	473,66	2656	32,9	4,12	13,94
    	473,99	0	0	 	 	474,33	2656	82,5	19,5	ON	474,66	2656	31,8	4,12	13,65
    	474,99	0	0	 	 	475,31	2656	82,5	20,3	ON	475,64	2656	31,8	4,12	13,38
    	475,97	0	0	 	 	476,29	2656	82,5	15,2	ON	476,63	2656	31,8	4,12	13,57
    	476,98	0	0	 	 	477,33	2656	82,5	13,3	ON	477,66	2656	31,8	4,12	13,36
    	477,99	0	0	 	 	478,32	2656	82,5	14,8	ON	478,66	2656	32,9	4,12	13,94
    	479	0	0	 	 	479,32	2656	82,5	14,1	ON	479,64	2656	32,9	4,12	13,94
    	479,98	0	0	 	 	480,3	2656	82,5	15,6	ON	480,64	2656	32,9	4,12	13,94
    	480,98	0	0	 	 	481,32	2656	82,5	20,3	ON	481,67	2656	32,9	4,12	13,67
    	481,99	0	0	 	 	482,32	2656	82,5	16,8	ON	482,65	2656	32,9	5,15	14
    	482,99	0	0	 	 	483,31	2656	82,5	12,9	ON	483,64	2656	32,9	4,12	13,94
    	483,98	0	0	 	 	484,29	2656	82,5	15,2	ON	484,62	2656	32,9	4,12	13,65
    	484,96	0	0	 	 	485,3	2656	82,5	18	ON	485,65	2624	32,9	4,12	14,06
    	486,01	0	0	 	 	486,36	2656	82,5	18,4	ON	486,71	2656	32,9	4,12	13,94
    	487,06	0	0	 	 	487,4	2624	82,5	17,6	ON	487,75	2624	32,9	5,15	13,94
    	488,08	0	0	 	 	488,4	2624	82,5	17,2	ON	488,72	2624	34,1	5,15	14,87
    	489,05	0	0	 	 	489,38	2624	82,5	14,5	ON	489,72	2624	34,1	5,15	14,87
    	490,03	0	0	 	 	490,36	2624	82,5	14,8	ON	490,7	2656	35,3	5,15	14,64
    	491,05	0	0	 	 	491,39	2656	82,5	15,2	ON	491,71	2656	34,1	5,15	14,87
    	492,04	0	0	 	 	492,37	2656	82,5	16,8	ON	492,69	2656	34,1	5,15	14,36
    	493,02	0	0	 	 	493,38	2656	82,5	19,5	ON	493,72	2656	32,9	4,12	14,22
    	494,04	0	0	 	 	494,36	2656	82,5	16	ON	494,69	2656	31,8	4,12	14
    	495,02	0	0	 	 	495,34	2656	82,5	12,9	ON	495,68	2656	31,8	4,12	13,62
    	496,01	0	0	 	 	496,35	2656	82,5	14,8	ON	496,67	2656	31,8	4,12	13,36
    	497	0	0	 	 	497,33	2656	82,5	17,2	ON	497,65	2656	31,8	4,12	13,65
    	497,97	0	0	 	 	498,3	2656	82,5	19,5	ON	498,62	2624	32,9	4,12	13,65
    	498,94	0	0	 	 	499,27	2656	82,5	18,8	ON	499,61	2624	32,9	5,15	13,94
    	499,93	0	0	 	 	500,25	2624	82,5	14,8	ON	500,58	2656	32,9	5,15	13,94
    	500,93	0	0	 	 	501,27	2656	82,5	13,7	ON	501,59	2656	32,9	4,12	13,94
    	501,92	0	0	 	 	502,26	2656	82,5	16	ON	502,57	2656	32,9	4,12	14,12
    	502,9	0	0	 	 	503,24	2656	82,5	17,2	ON	503,56	2656	31,8	4,12	13,38
    	503,89	0	0	 	 	504,22	2656	82,5	18,8	ON	504,55	2656	31	4,12	13,15
    	504,88	0	0	 	 	505,21	2656	82,5	14,5	ON	505,53	2656	31	4,12	13,36
    	505,85	0	0	 	 	506,18	2656	82,5	11,3	ON	506,52	2656	31	4,12	13,07
    	506,85	0	0	 	 	507,16	2656	82,5	13,3	ON	507,49	2656	31	4,12	13,36
    	507,82	0	0	 	 	508,16	2656	82,5	16,4	ON	508,47	2656	31,8	4,12	13,38
    	508,81	0	0	 	 	509,15	2656	82,5	19,5	ON	509,47	2656	31,8	4,12	13,36
    	509,81	0	0	 	 	510,13	2656	82,5	16	ON	510,47	2624	31	4,12	13,26
    	510,81	0	0	 	 	511,14	2656	82,5	12,9	ON	511,47	2624	31,8	4,12	13,09
    	511,8	0	0	 	 	512,13	2624	82,5	14,5	ON	512,46	2656	31,8	4,12	13,65
    	512,81	0	0	 	 	513,14	2624	82,5	16,4	ON	513,5	2624	32,9	4,12	13,87
    	513,84	0	0	 	 	514,18	2624	82,5	17,6	ON	514,51	2624	32,9	4,12	14,56
    	514,85	0	0	 	 	515,17	2624	82,5	20,3	ON	515,49	2624	34,1	5,15	14,53
    	515,82	0	0	 	 	516,14	2624	82,5	17,6	ON	516,48	2624	34,1	5,15	14,42
    	516,81	0	0	 	 	517,13	2624	82,5	15,6	ON	517,45	2624	34,1	5,15	14,48
    	517,78	0	0	 	 	518,14	2624	82,5	12,9	ON	518,47	2656	34,1	5,15	14,87
    	518,82	0	0	 	 	519,15	2656	82,5	14,8	ON	519,48	2656	34,1	5,15	14,93
    	519,82	0	0	 	 	520,15	2656	82,5	16,4	ON	520,48	2656	34,1	5,15	14,84
    	520,81	0	0	 	 	521,15	2656	82,5	18	ON	521,48	2656	34,1	5,15	14,31
    	521,82	0	0	 	 	522,14	2656	82,5	17,6	ON	522,48	2656	34,1	5,15	14,2
    	522,82	0	0	 	 	523,17	2656	82,5	18,4	ON	523,5	2656	32,9	4,12	13,94
    	523,83	0	0	 	 	524,17	2656	82,5	16	ON	524,5	2656	31,8	5,15	13,65
    	524,82	0	0	 	 	525,15	2656	82,5	12,5	ON	525,49	2656	31	4,12	13,15
    	525,84	0	0	 	 	526,17	2656	82,5	14,5	ON	526,49	2688	29,8	4,12	12,41
    	526,82	0	0	 	 	527,13	2688	82,5	15,6	ON	527,45	2688	27,5	3,09	11,47
    	527,78	0	0	 	 	528,09	2688	82,5	12,5	ON	528,41	2688	26,3	3,09	11,21
    	528,75	0	0	 	 	529,07	2688	82,5	10,5	ON	529,4	2656	23,9	3,09	10,49
    	529,72	0	0	 	 	530,03	2656	82,5	14,5	ON	530,36	2656	23,9	3,09	10,3
    	530,7	0	0	 	 	531,05	2656	82,5	14,8	ON	531,38	2656	22,7	3,09	10,25
    	531,7	0	0	 	 	532,03	2656	82,5	9,8	ON	532,37	2656	23,9	3,09	10,18
    	532,68	0	0	 	 	533,01	2656	82,5	15,6	ON	533,35	2656	23,9	3,09	10,05
    	533,67	0	0	 	 	533,99	2656	82,5	14,8	ON	534,33	2656	23,9	3,09	10,29
    	534,65	0	0	 	 	534,98	2656	82,5	9	ON	535,31	2656	23,9	3,09	10,62
    	535,65	0	0	 	 	535,99	2656	82,5	14,8	ON	536,34	2656	25,1	3,09	10,65
    	536,67	0	0	 	 	536,99	2656	82,5	17,2	ON	537,31	2656	25,1	3,09	10,69
    	537,65	0	0	 	 	537,98	2624	82,5	11,3	ON	538,3	2656	25,1	3,09	10,41
    	538,63	0	0	 	 	538,96	2656	82,5	15,2	ON	539,29	2656	25,1	3,09	11,04
    	539,62	0	0	 	 	539,95	2656	82,5	16,8	ON	540,29	2656	25,1	3,09	10,94
    	540,62	0	0	 	 	540,97	2624	82,5	14,1	ON	541,3	2656	25,1	3,09	10,9
    	541,63	0	0	 	 	541,96	2656	82,5	11,7	ON	542,29	2624	26,3	3,09	11,11
    	542,62	0	0	 	 	542,95	2624	82,5	15,6	ON	543,27	2656	27,5	3,09	11,44
    	543,59	0	0	 	 	543,93	2624	82,5	14,5	ON	544,27	2624	27,5	4,12	11,42
    	544,61	0	0	 	 	544,94	2624	82,5	12,1	ON	545,29	2624	29,8	4,12	12,44
    	545,61	0	0	 	 	545,96	2624	82,5	14,1	ON	546,29	2624	29,8	4,12	12,78
    	546,63	0	0	 	 	546,95	2624	82,5	16,4	ON	547,28	2624	31,8	4,12	13,41
    	547,62	0	0	 	 	547,94	2624	82,5	19,9	ON	548,27	2624	34,1	5,15	14,31
    	548,6	0	0	 	 	548,93	2624	82,5	18,4	ON	549,26	2624	35,3	5,15	14,84
    	549,59	0	0	 	 	549,92	2624	82,5	15,2	ON	550,24	2624	36,5	5,15	15,28
    	550,58	0	0	 	 	550,92	2624	82,5	12,5	ON	551,27	2624	36,5	5,15	15,19
    	551,6	0	0	 	 	551,93	2656	82,5	13,7	ON	552,28	2624	36,5	5,15	15,51
    	552,61	0	0	 	 	552,93	2656	82,5	14,5	ON	553,27	2656	35,3	5,15	14,87
    	553,6	0	0	 	 	553,93	2656	82,5	14,8	ON	554,27	2656	34,1	5,15	14,28
    	554,61	0	0	 	 	554,94	2656	82,5	14,8	ON	555,27	2656	31,8	4,12	13,65
    	555,61	0	0	 	 	555,92	2656	82,5	17,6	ON	556,24	2656	31	4,12	13,36
    	556,57	0	0	 	 	556,9	2656	82,5	14,8	ON	557,22	2656	31	4,12	13,09
    	557,56	0	0	 	 	557,9	2656	82,5	9,4	ON	558,22	2656	29,8	4,12	12,78
    	558,56	0	0	 	 	558,89	2656	82,5	13,7	ON	559,21	2656	29,8	4,12	12,78
    	559,55	0	0	 	 	559,87	2624	82,5	18,8	ON	560,2	2624	31	4,12	13,31
    	560,53	0	0	 	 	560,88	2656	82,5	15,6	ON	561,23	2656	31	4,12	13,36
    	561,55	0	0	 	 	561,87	2656	82,5	13,7	ON	562,21	2656	31,8	4,12	13,94
    	562,53	0	0	 	 	562,87	2656	82,5	12,9	ON	563,21	2656	32,9	5,15	14,22
    	563,55	0	0	 	 	563,86	2656	82,5	12,9	ON	564,18	2656	31,8	4,12	13,89
    	564,51	0	0	 	 	564,84	2656	82,5	14,5	ON	565,18	2656	31,8	4,12	13,36
    	565,49	0	0	 	 	565,82	2656	82,5	19,1	ON	566,14	2656	31,8	4,12	13,51
    	566,48	0	0	 	 	566,8	2656	82,5	17,2	ON	567,13	2656	31	4,12	13,02
    	567,46	0	0	 	 	567,77	2656	82,5	12,5	ON	568,11	2656	29,8	4,12	12,63
    	568,44	0	0	 	 	568,77	2656	82,5	10,9	ON	569,1	2656	29,8	4,12	12,64
    	569,42	0	0	 	 	569,75	2656	82,5	12,1	ON	570,09	2656	29,8	4,12	12,89
    	570,42	0	0	 	 	570,74	2656	82,5	14,5	ON	571,07	2656	31	4,12	12,78
    	571,42	0	0	 	 	571,75	2656	82,5	18	ON	572,08	2656	31	4,12	13,36
    	572,4	0	0	 	 	572,74	2624	82,5	15,2	ON	573,09	2624	31,8	4,12	13,51
    	573,42	0	0	 	 	573,74	2624	82,5	11,7	ON	574,09	2624	32,9	4,12	13,87
    	574,44	0	0	 	 	574,77	2624	82,5	13,7	ON	575,11	2624	34,1	5,15	14,7
    	575,45	0	0	 	 	575,78	2624	82,5	16	ON	576,12	2624	35,3	5,15	15,1
    	576,45	0	0	 	 	576,79	2624	82,5	16,8	ON	577,13	2624	36,5	5,15	15,04
    	577,45	0	0	 	 	577,82	2624	82,5	17,2	ON	578,15	2624	36,5	5,15	15,39
    	578,48	0	0	 	 	578,82	2624	82,5	19,1	ON	579,16	2624	37,6	5,15	16,01
    	579,5	0	0	 	 	579,83	2624	82,5	14,8	ON	580,17	2624	38,8	5,15	15,66
    	580,49	0	0	 	 	580,82	2176	82,5	0	OFF	581,15	1856	0	0	4,67
    	581,5	0	0	 	 	581,83	1376	82,5	0	ON	582,13	1248	12,5	2,06	2,52
    	582,42	3,9	0	 	 	582,68	992	82,5	-0,4	ON	582,99	928	14,9	2,06	2,69
    	583,29	3,9	0	 	 	583,58	864	82,5	-0,8	ON	583,88	896	19,2	3,09	2,74
    	584,17	3,1	0	 	 	584,46	896	82,5	-0,8	ON	584,77	896	18,4	2,06	2,43
    	585,08	3,9	0	 	 	585,37	864	82,5	-3,5	ON	585,67	864	18,4	2,06	2,63
    	585,95	3,9	0	 	 	586,24	864	82,5	-6,3	ON	586,55	864	18,4	2,06	2,42
    	586,85	3,9	0	 	 	587,16	864	82,5	-9	ON	587,46	832	18,4	2,06	2,32
    	587,75	3,9	0	 	 	588,04	832	82,5	-11,7	ON	588,33	832	18,4	2,06	2,44
    	588,59	3,9	0	 	 	588,87	800	82,5	-10,2	ON	589,16	800	19,2	2,06	3,08
    	589,46	3,9	0	 	 	589,73	832	82,5	-7,4	ON	590,03	832	20,4	2,06	2,84
    	590,32	3,1	0	 	 	590,63	832	82,5	-4,7	ON	590,92	832	20,4	2,06	3,06
    	591,2	3,1	0	 	 	591,49	832	82,5	-2	ON	591,77	864	21,6	2,06	3,08
    	592,05	3,1	0	 	 	592,34	864	82,5	0,4	ON	592,62	864	21,6	2,06	3,13
    	592,92	3,1	0	 	 	593,24	864	82,5	3,1	ON	593,53	864	20,4	2,06	2,96
    	593,81	3,1	0	 	 	594,12	864	82,5	5,9	ON	594,44	864	19,2	2,06	2,55
    	594,74	3,1	0	 	 	595,04	864	82,5	8,6	ON	595,32	864	19,2	2,06	2,39
    	595,63	3,9	0	 	 	595,92	832	82,5	11,3	ON	596,23	864	19,2	2,06	2,57
    	596,52	3,9	0	 	 	596,82	864	82,5	14,1	ON	597,11	864	18,4	2,06	2,4
    	597,41	3,9	0	 	 	597,72	864	82,5	16,8	ON	598,02	1088	29,8	4,12	2,2
    	598,31	0	0	 	 	598,65	1120	82,5	17,6	ON	598,94	1248	38,8	5,15	6,53
    	599,25	0	0	 	 	599,6	1376	82,5	16,4	ON	599,92	1280	17,3	2,06	2,24
    	600,23	0	0	 	 	600,54	800	82,5	12,9	ON	600,82	864	51,4	7,21	7,91
    	601,11	0	0	 	 	601,4	1056	82,5	13,3	ON	601,71	1152	47,8	7,21	8,22
    	602,02	0	0	 	 	602,33	1312	82,5	15,6	ON	602,66	1408	47,8	7,21	12,36
    	602,92	0	0	 	 	603,27	1600	82,5	16,4	ON	603,6	1760	66,3	9,27	19,73
    	603,96	0	0	 	 	604,32	2176	82,5	16	ON	604,64	2336	68,6	9,27	25,53
    	604,98	0	0	 	 	605,29	2592	82,5	0	OFF	605,63	2304	0	0	5,44
    	605,97	0	0	 	 	606,31	1728	84	-0,8	ON	606,68	1824	70,6	9,27	19,76
    	607,03	0	0	 	 	607,38	1952	84	-0,4	ON	607,72	2048	78,8	10,3	26,15
    	608,07	0	0	 	 	608,39	2208	82,5	-0,4	ON	608,73	2304	76,5	10,3	27,24
    	609,07	0	0	 	 	609,38	2464	82,5	15,2	ON	609,71	2528	77,6	11,33	31,21
    	610,04	0	0	 	 	610,37	2688	84	9,8	ON	610,69	2784	80	10,3	35,09
    	611,03	0	0	 	 	611,35	2720	82,5	0	OFF	611,69	2432	17,3	2,06	6,08
    	612,03	0	0	 	 	612,38	2144	84	-0,8	ON	612,71	2176	71,8	9,27	24,97
    	613,04	0	0	 	 	613,37	2272	84	-0,8	ON	613,71	2304	72,9	9,27	27,38
    	614,04	0	0	 	 	614,39	2368	82,5	-0,8	ON	614,71	2400	74,1	9,27	28,21
    	615,06	0	0	 	 	615,39	2496	82,5	17,6	ON	615,71	2528	74,1	11,33	29,94
    	616,04	0	0	 	 	616,36	2496	82,5	0	OFF	616,7	2272	20,4	2,06	7,12
    	617,04	0	0	 	 	617,38	2208	82,5	-1,2	ON	617,71	2208	60,4	8,24	21,17
    	618,03	0	0	 	 	618,35	2240	82,5	-1,2	ON	618,68	2240	43,5	5,15	14,87
    	619,01	0	0	 	 	619,34	2272	82,5	-1,2	ON	619,68	2272	42,4	5,15	15,19
    	620	0	0	 	 	620,33	2304	82,5	8,6	ON	620,66	2304	41,2	5,15	14,87
    	621	0	0	 	 	621,33	2336	82,5	20,7	ON	621,65	2336	41,2	6,18	15,51
    	621,99	0	0	 	 	622,32	2368	84	11,7	ON	622,65	2368	40	5,15	14,94
    	622,98	0	0	 	 	623,31	2368	84	12,5	ON	623,62	2400	40	5,15	15,19
    	623,95	0	0	 	 	624,28	2400	82,5	14,5	ON	624,59	2400	45,5	6,18	18,13
    	624,92	0	0	 	 	625,24	2432	82,5	14,1	ON	625,57	2432	45,5	6,18	17,34
    	625,9	0	0	 	 	626,24	2464	82,5	15,6	ON	626,58	2464	44,3	6,18	17,18
    	626,94	0	0	 	 	627,3	2464	84	13,3	ON	627,62	2496	40	5,15	15,39
    	627,95	0	0	 	 	628,28	2496	84	19,5	ON	628,61	2496	40	5,15	15,99
    	628,96	0	0	 	 	629,29	2528	84	17,2	ON	629,62	2528	40	5,15	16,33
    	629,96	0	0	 	 	630,28	2528	84	16,4	ON	630,62	2528	41,2	6,18	16,5
    	630,97	0	0	 	 	631,3	2560	84	13,7	ON	631,63	2560	37,6	5,15	15,19
    	631,96	0	0	 	 	632,29	2560	84	11,7	ON	632,64	2560	34,1	5,15	14,25
    	632,98	0	0	 	 	633,32	2560	84	10,5	ON	633,65	2560	31,8	4,12	12,83
    	633,98	0	0	 	 	634,33	2560	84	12,9	ON	634,68	2560	29,8	4,12	12,23
    	635,03	0	0	 	 	635,36	2560	84	15,6	ON	635,71	2560	28,6	4,12	11,95
    	636,05	0	0	 	 	636,41	2528	84	12,1	ON	636,75	2528	28,6	4,12	11,68
    	637,09	0	0	 	 	637,43	2528	84	8,2	ON	637,75	2528	28,6	4,12	11,84
    	638,07	0	0	 	 	638,4	2528	84	11,7	ON	638,71	2528	28,6	4,12	11,95
    	639,04	0	0	 	 	639,38	2528	84	16,4	ON	639,7	2528	29,8	4,12	12,23
    	640,02	0	0	 	 	640,35	2528	84	15,6	ON	640,66	2528	29,8	4,12	12,23
    	640,99	0	0	 	 	641,32	2528	84	13,3	ON	641,65	2528	29,8	4,12	12,23
    	641,96	0	0	 	 	642,3	2528	84	10,2	ON	642,62	2528	29,8	4,12	12,23
    	642,95	0	0	 	 	643,27	2528	84	14,1	ON	643,61	2528	29,8	4,12	12,23
    	643,91	0	0	 	 	644,25	2528	84	16	ON	644,58	2528	29,8	4,12	12,29
    	644,92	0	0	 	 	645,24	2528	84	12,9	ON	645,59	2528	31,8	4,12	12,76
    	645,91	0	0	 	 	646,25	2528	84	10,2	ON	646,58	2528	31,8	4,12	12,92
    	646,92	0	0	 	 	647,25	2528	84	14,5	ON	647,59	2528	31,8	4,12	13,07
    	647,9	0	0	 	 	648,22	2528	84	18	ON	648,52	2528	31,8	4,12	13,07
    	648,85	0	0	 	 	649,17	2528	84	16,4	ON	649,51	2528	32,9	4,12	13,36
    	649,84	0	0	 	 	650,18	2528	84	14,8	ON	650,53	2528	31,8	4,12	12,78
    	650,88	0	0	 	 	651,2	2528	84	10,2	ON	651,53	2528	31	4,12	12,5
    	651,86	0	0	 	 	652,18	2528	84	10,9	ON	652,52	2528	29,8	4,12	12,23
    	652,87	0	0	 	 	653,19	2528	84	14,5	ON	653,51	2528	28,6	4,12	11,57
    	653,85	0	0	 	 	654,18	2528	82,5	13,7	ON	654,51	2528	27,5	4,12	11,16
    	654,83	0	0	 	 	655,16	2528	82,5	10,5	ON	655,49	2528	28,6	4,12	11,84
    	655,82	0	0	 	 	656,16	2528	82,5	12,1	ON	656,5	2528	28,6	3,09	11,68
    	656,86	0	0	 	 	657,19	2528	82,5	13,3	ON	657,52	2528	29,8	4,12	12,23
    	657,85	0	0	 	 	658,18	2528	84	15,2	ON	658,51	2496	31	4,12	12,73
    	658,82	0	0	 	 	659,16	2496	82,5	13,7	ON	659,47	2496	32,9	5,15	13,57
    	659,8	0	0	 	 	660,11	2496	82,5	12,9	ON	660,44	2496	34,1	5,15	14
    	660,77	0	0	 	 	661,11	2496	82,5	17,2	ON	661,43	2496	36,5	5,15	14,97
    	661,74	0	0	 	 	662,1	2496	82,5	18,4	ON	662,43	2496	37,6	5,15	15,19
    	662,78	0	0	 	 	663,09	2496	82,5	17,6	ON	663,4	2496	40	5,15	15,83
    	663,72	0	0	 	 	664,05	2496	82,5	15,2	ON	664,38	2496	41,2	6,18	16,5
    	664,71	0	0	 	 	665,05	2496	82,5	15,2	ON	665,38	2496	41,2	6,18	17,18
    	665,7	0	0	 	 	666	2496	82,5	16	ON	666,35	2528	41,2	6,18	16,75
    	666,67	0	0	 	 	667,01	2528	82,5	15,2	ON	667,37	2528	41,2	6,18	16,5
    	667,71	0	0	 	 	668,04	2528	82,5	15,2	ON	668,35	2528	40	5,15	16,05
    	668,68	0	0	 	 	669,01	2528	82,5	13,3	ON	669,33	2528	40	5,15	16,19
    	669,66	0	0	 	 	669,97	2528	82,5	10,2	ON	670,31	2528	38,8	5,15	15,51
    	670,63	0	0	 	 	670,95	2528	82,5	11,7	ON	671,28	2528	37,6	5,15	15,51
    	671,62	0	0	 	 	671,94	2528	82,5	14,8	ON	672,26	2528	36,5	5,15	14,56
    	672,61	0	0	 	 	672,93	2528	82,5	16	ON	673,27	2528	35,3	5,15	14,28
    	673,63	0	0	 	 	673,97	2528	82,5	14,5	ON	674,28	2528	34,1	5,15	13,94
    	674,62	0	0	 	 	674,95	2528	82,5	9,4	ON	675,29	2528	34,1	5,15	13,94
    	675,64	0	0	 	 	675,97	2528	82,5	12,1	ON	676,28	2528	34,1	5,15	14,22
    	676,61	0	0	 	 	676,93	2528	82,5	14,8	ON	677,26	2528	34,1	4,12	13,87
    	677,59	0	0	 	 	677,95	2528	82,5	16,8	ON	678,29	2528	32,9	4,12	13,89
    	678,62	0	0	 	 	678,96	2528	82,5	17,2	ON	679,31	2528	32,9	4,12	13,36
    	679,63	0	0	 	 	679,97	2560	82,5	13,7	ON	680,31	2528	31,8	4,12	13,07
    	680,65	0	0	 	 	680,99	2528	82,5	10,2	ON	681,33	2560	31	4,12	12,5
    	681,65	0	0	 	 	682,01	2560	82,5	12,5	ON	682,34	2560	28,6	4,12	11,92
    	682,68	0	0	 	 	683,01	2560	82,5	16,4	ON	683,35	2528	27,5	3,09	11,25
    	683,68	0	0	 	 	684,02	2560	82,5	11,7	ON	684,37	2528	26,3	3,09	10,54
    	684,71	0	0	 	 	685,05	2528	82,5	11,3	ON	685,4	2528	26,3	3,09	10,65
    	685,71	0	0	 	 	686,05	2528	82,5	17,6	ON	686,38	2528	27,5	3,09	11,29
    	686,71	0	0	 	 	687,02	2528	82,5	10,2	ON	687,36	2528	27,5	4,12	11,29
    	687,7	0	0	 	 	688,02	2528	82,5	10,5	ON	688,35	2528	28,6	4,12	11,68
    	688,67	0	0	 	 	689	2528	82,5	14,1	ON	689,34	2528	29,8	4,12	11,95
    	689,69	0	0	 	 	690,02	2528	82,5	15,2	ON	690,36	2528	29,8	4,12	11,99
    	690,69	0	0	 	 	691,01	2528	82,5	9,8	ON	691,35	2528	29,8	4,12	12,13
    	691,68	0	0	 	 	692,01	2528	82,5	12,9	ON	692,33	2528	29,8	4,12	12,16
    	692,66	0	0	 	 	693,02	2528	82,5	16,4	ON	693,35	2528	29,8	4,12	11,91
    	693,7	0	0	 	 	694,04	2528	82,5	14,5	ON	694,37	2528	29,8	4,12	12,23
    	694,72	0	0	 	 	695,06	2528	82,5	8,2	ON	695,38	2528	29,8	4,12	12,54
    	695,71	0	0	 	 	696,07	2528	82,5	13,7	ON	696,4	2528	29,8	4,12	12,23
    	696,73	0	0	 	 	697,05	2528	82,5	15,2	ON	697,39	2528	29,8	4,12	12,04
    	697,72	0	0	 	 	698,05	2528	82,5	11,7	ON	698,37	2528	29,8	4,12	12,23
    	698,73	0	0	 	 	699,08	2528	82,5	9,8	ON	699,4	2528	29,8	4,12	12,23
    	699,73	0	0	 	 	700,06	2528	82,5	12,9	ON	700,42	2528	29,8	4,12	11,95
    	700,77	0	0	 	 	701,09	2528	82,5	15,2	ON	701,42	2528	31	4,12	12,5
    	701,74	0	0	 	 	702,08	2528	82,5	9	ON	702,42	2528	31	4,12	12,83
    	702,73	0	0	 	 	703,07	2528	82,5	12,1	ON	703,41	2528	31,8	4,12	12,97
    	703,78	0	0	 	 	704,1	2528	82,5	14,8	ON	704,45	2528	31,8	4,12	12,66
    	704,75	0	0	 	 	705,08	2528	82,5	14,8	ON	705,43	2528	31,8	4,12	12,8
    	705,76	0	0	 	 	706,08	2528	82,5	12,1	ON	706,42	2528	31	4,12	12,78
    	706,75	0	0	 	 	707,11	2528	82,5	10,2	ON	707,44	2528	31	4,12	12,66
    	707,76	0	0	 	 	708,08	2528	82,5	12,1	ON	708,41	2528	31,8	4,12	13,07
    	708,75	0	0	 	 	709,09	2528	82,5	14,8	ON	709,42	2528	32,9	4,12	13,36
    	709,73	0	0	 	 	710,05	2528	82,5	17,6	ON	710,39	2528	32,9	4,12	13,65
    	710,72	0	0	 	 	711,05	2528	82,5	16	ON	711,4	2528	32,9	5,15	13,65
    	711,75	0	0	 	 	712,07	2528	82,5	14,8	ON	712,39	2528	34,1	5,15	13,75
    	712,73	0	0	 	 	713,07	2528	82,5	14,1	ON	713,41	2528	32,9	5,15	13,65
    	713,74	0	0	 	 	714,08	2528	82,5	12,5	ON	714,42	2528	32,9	4,12	13,53
    	714,75	0	0	 	 	715,1	2528	82,5	14,5	ON	715,45	2528	32,9	4,12	13,36
    	715,79	0	0	 	 	716,14	2528	82,5	17,2	ON	716,47	2528	31	4,12	12,69
    	716,81	0	0	 	 	717,15	2528	82,5	13,3	ON	717,49	2528	29,8	4,12	12,5
    	717,8	0	0	 	 	718,12	2528	82,5	9,4	ON	718,48	2528	28,6	4,12	11,95
    	718,83	0	0	 	 	719,17	2528	82,5	12,5	ON	719,51	2528	28,6	3,09	11,79
    	719,84	0	0	 	 	720,18	2528	82,5	15,6	ON	720,52	2528	28,6	4,12	11,84
    	720,84	0	0	 	 	721,17	2528	82,5	12,1	ON	721,53	2528	28,6	4,12	11,95
    	721,86	0	0	 	 	722,19	2528	82,5	8,2	ON	722,53	2528	28,6	4,12	12,07
    	722,87	0	0	 	 	723,19	2528	82,5	13,3	ON	723,53	2528	29,8	4,12	11,95
    	723,85	0	0	 	 	724,19	2528	82,5	16	ON	724,53	2528	29,8	4,12	12,06
    	724,87	0	0	 	 	725,19	2528	82,5	13,3	ON	725,52	2528	31	4,12	12,5
    	725,86	0	0	 	 	726,18	2528	82,5	10,2	ON	726,51	2528	31	4,12	12,5
    	726,83	0	0	 	 	727,17	2528	82,5	15,2	ON	727,5	2528	31,8	4,12	12,78
    	727,85	0	0	 	 	728,18	2528	82,5	16,4	ON	728,5	2528	31	4,12	12,78
    	728,85	0	0	 	 	729,21	2528	82,5	12,1	ON	729,55	2528	31	4,12	12,29
    	729,88	0	0	 	 	730,2	2528	82,5	10,2	ON	730,54	2528	31	4,12	12,5
    	730,88	0	0	 	 	731,21	2528	82,5	12,9	ON	731,57	2528	31	4,12	12,43
    	731,9	0	0	 	 	732,24	2528	82,5	17,2	ON	732,57	2528	31	4,12	12,32
    	732,91	0	0	 	 	733,27	2528	82,5	13,7	ON	733,62	2528	31	4,12	12,5
    	733,93	0	0	 	 	734,26	2528	82,5	9	ON	734,6	2528	28,6	4,12	11,95
    	734,93	0	0	 	 	735,27	2528	82,5	11,3	ON	735,61	2528	28,6	4,12	11,68
    	735,94	0	0	 	 	736,26	2528	82,5	14,1	ON	736,59	2528	28,6	4,12	11,71
    	736,93	0	0	 	 	737,26	2528	82,5	13,3	ON	737,59	2528	28,6	4,12	11,68
    	737,93	0	0	 	 	738,25	2528	82,5	10,9	ON	738,61	2528	28,6	4,12	11,68
    	738,94	0	0	 	 	739,27	2528	82,5	10,9	ON	739,61	2528	28,6	4,12	12,06
    	739,95	0	0	 	 	740,3	2528	82,5	16,4	ON	740,62	2528	28,6	4,12	11,79
    	740,95	0	0	 	 	741,28	2528	82,5	12,5	ON	741,62	2528	28,6	4,12	11,95
    	741,95	0	0	 	 	742,27	2528	82,5	10,5	ON	742,61	2528	28,6	4,12	11,68
    	742,96	0	0	 	 	743,29	2528	82,5	10,5	ON	743,62	2528	27,5	3,09	11,44
    	743,95	0	0	 	 	744,27	2528	82,5	14,5	ON	744,62	2528	27,5	3,09	11,59
    	744,95	0	0	 	 	745,27	2528	82,5	14,8	ON	745,6	2528	28,6	4,12	11,68
    	745,93	0	0	 	 	746,25	2528	82,5	10,5	ON	746,59	2528	28,6	4,12	11,42
    	746,92	0	0	 	 	747,27	2528	82,5	10,5	ON	747,61	2528	29,8	4,12	11,98
    	747,93	0	0	 	 	748,26	2496	82,5	17,2	ON	748,58	2496	31	4,12	12,64
    	748,93	0	0	 	 	749,25	2496	82,5	14,5	ON	749,57	2496	31,8	4,12	13,33
    	749,9	0	0	 	 	750,24	2496	82,5	12,5	ON	750,57	2496	34,1	5,15	13,65
    	750,93	0	0	 	 	751,27	2496	82,5	11,3	ON	751,59	2528	34,1	5,15	13,67
    	751,91	0	0	 	 	752,22	2528	82,5	14,5	ON	752,54	2528	32,9	4,12	13,65
    	752,85	0	0	 	 	753,2	2528	82,5	15,6	ON	753,51	2528	31,8	4,12	13,36
    	753,87	0	0	 	 	754,21	2528	82,5	17,6	ON	754,55	2528	31,8	4,12	12,92
    	754,9	0	0	 	 	755,23	2528	82,5	14,1	ON	755,56	2528	31	4,12	12,23
    	755,88	0	0	 	 	756,21	2528	82,5	10,5	ON	756,51	2528	29,8	4,12	12,27
    	756,85	0	0	 	 	757,2	2528	82,5	12,9	ON	757,54	2528	29,8	4,12	12,02
    	757,88	0	0	 	 	758,2	2528	82,5	16	ON	758,53	2528	29,8	4,12	11,84
    	758,87	0	0	 	 	759,22	2528	82,5	12,1	ON	759,56	2528	28,6	4,12	11,68
    	759,89	0	0	 	 	760,21	2528	82,5	9,4	ON	760,53	2528	28,6	4,12	11,75
    	760,86	0	0	 	 	761,2	2528	82,5	12,5	ON	761,52	2528	29,8	4,12	12,23
    	761,89	0	0	 	 	762,21	2528	82,5	16	ON	762,55	2528	31	4,12	12,5
    	762,87	0	0	 	 	763,19	2496	82,5	11,7	ON	763,52	2528	31,8	4,12	13,07
    	763,87	0	0	 	 	764,19	2528	82,5	10,5	ON	764,53	2528	31,8	4,12	13,21
    	764,85	0	0	 	 	765,18	2528	82,5	15,2	ON	765,49	2496	34,1	4,12	13,65
    	765,85	0	0	 	 	766,19	2528	82,5	18,4	ON	766,52	2496	32,9	4,12	13,36
    	766,84	0	0	 	 	767,2	2528	82,5	17,2	ON	767,54	2528	32,9	4,12	13,48
    	767,86	0	0	 	 	768,2	2528	82,5	16	ON	768,54	2528	34,1	5,15	13,48
    	768,87	0	0	 	 	769,21	2528	82,5	14,8	ON	769,52	2528	35,3	5,15	14,25
    	769,84	0	0	 	 	770,17	2528	82,5	11,7	ON	770,5	2528	36,5	5,15	14,61
    	770,84	0	0	 	 	771,17	2528	82,5	12,9	ON	771,49	2528	35,3	5,15	14,66
    	771,82	0	0	 	 	772,14	2528	82,5	16	ON	772,49	2528	35,3	5,15	14,56
    	772,83	0	0	 	 	773,17	2528	82,5	18,8	ON	773,5	2528	35,3	5,15	14,43
    	773,8	0	0	 	 	774,17	2528	82,5	16	ON	774,49	2528	35,3	5,15	14,25
    	774,81	0	0	 	 	775,12	2528	82,5	16	ON	775,47	2528	35,3	5,15	13,94
    	775,8	0	0	 	 	776,13	2528	82,5	12,9	ON	776,47	2528	35,3	5,15	14,25
    	776,79	0	0	 	 	777,12	2528	82,5	12,1	ON	777,45	2528	35,3	5,15	14,41
    	777,77	0	0	 	 	778,1	2528	82,5	14,5	ON	778,4	2528	34,1	5,15	14,25
    	778,76	0	0	 	 	779,1	2528	82,5	16,8	ON	779,43	2528	34,1	4,12	13,85
    	779,76	0	0	 	 	780,11	2528	82,5	17,6	ON	780,46	2528	32,9	4,12	13,48
    	780,81	0	0	 	 	781,14	2528	82,5	14,5	ON	781,47	2528	32,9	5,15	13,36
    	781,8	0	0	 	 	782,14	2528	82,5	10,2	ON	782,48	2528	32,9	4,12	13,65
    	782,8	0	0	 	 	783,12	2528	82,5	14,8	ON	783,46	2528	32,9	4,12	13,43
    	783,79	0	0	 	 	784,08	2528	82,5	18,4	ON	784,4	2528	32,9	4,12	13,65
    	784,76	0	0	 	 	785,07	2528	82,5	16,8	ON	785,4	2528	32,9	5,15	13,65
    	785,75	0	0	 	 	786,09	2528	82,5	14,1	ON	786,42	2528	32,9	5,15	13,72
    	786,74	0	0	 	 	787,08	2528	82,5	11,3	ON	787,41	2528	34,1	5,15	13,65
    	787,77	0	0	 	 	788,11	2528	82,5	12,9	ON	788,45	2528	34,1	5,15	13,8
    	788,77	0	0	 	 	789,1	2528	82,5	14,1	ON	789,44	2528	34,1	4,12	13,51
    	789,76	0	0	 	 	790,09	2528	82,5	14,8	ON	790,41	2528	32,9	4,12	13,41
    	790,76	0	0	 	 	791,09	2528	82,5	16,8	ON	791,42	2528	32,9	4,12	13,65
    	791,74	0	0	 	 	792,09	2528	82,5	17,6	ON	792,41	2528	32,9	4,12	13,65
    	792,76	0	0	 	 	793,1	2528	82,5	16,4	ON	793,43	2528	34,1	5,15	13,65
    	793,77	0	0	 	 	794,1	2528	82,5	13,7	ON	794,45	2528	35,3	5,15	14,14
    	794,78	0	0	 	 	795,1	2528	82,5	12,5	ON	795,43	2528	35,3	5,15	14,51
    	795,78	0	0	 	 	796,1	2528	82,5	12,9	ON	796,41	2528	35,3	5,15	14,56
    	796,73	0	0	 	 	797,05	2528	82,5	14,1	ON	797,4	2528	34,1	5,15	13,94
    	797,73	0	0	 	 	798,06	2528	82,5	16	ON	798,38	2528	34,1	5,15	14,25
    	798,7	0	0	 	 	799,03	2528	82,5	19,9	ON	799,36	2528	34,1	5,15	14
    	799,7	0	0	 	 	800,01	2528	82,5	18	ON	800,35	2528	34,1	5,15	13,94
    	800,67	0	0	 	 	801	2528	82,5	16	ON	801,33	2528	34,1	5,15	13,94
    	801,66	0	0	 	 	802,01	2528	82,5	14,5	ON	802,35	2528	34,1	5,15	14
    	802,67	0	0	 	 	802,98	2528	82,5	12,9	ON	803,3	2528	34,1	5,15	14,25
    	803,63	0	0	 	 	803,95	2528	82,5	12,1	ON	804,29	2528	32,9	4,12	13,65
    	804,63	0	0	 	 	804,97	2528	82,5	14,5	ON	805,31	2528	32,9	4,12	13,36
    	805,64	0	0	 	 	805,97	2528	82,5	16,8	ON	806,3	2528	32,9	4,12	13,36
    	806,62	0	0	 	 	806,96	2528	82,5	18	ON	807,29	2528	31,8	4,12	13,36
    	807,61	0	0	 	 	807,94	2528	82,5	12,5	ON	808,27	2528	32,9	4,12	13,36
    	808,6	0	0	 	 	808,91	2528	82,5	10,5	ON	809,22	2528	32,9	4,12	13,65
    	809,54	0	0	 	 	809,86	2528	82,5	13,7	ON	810,19	2528	32,9	4,12	13,65
    	810,51	0	0	 	 	810,85	2528	82,5	19,1	ON	811,18	2528	34,1	4,12	13,94
    	811,5	0	0	 	 	811,83	2528	82,5	16,8	ON	812,17	2528	34,1	5,15	13,94
    	812,49	0	0	 	 	812,83	2528	82,5	16	ON	813,16	2528	35,3	5,15	13,92
    	813,5	0	0	 	 	813,83	2528	82,5	12,1	ON	814,15	2528	35,3	5,15	14,38
    	814,47	0	0	 	 	814,8	2528	82,5	14,5	ON	815,13	2528	35,3	5,15	14,87
    	815,46	0	0	 	 	815,79	2528	82,5	14,8	ON	816,1	2528	36,5	5,15	14,56
    	816,42	0	0	 	 	816,76	2528	82,5	18,4	ON	817,12	2528	36,5	5,15	14,87
    	817,45	0	0	 	 	817,78	2528	82,5	18	ON	818,1	2528	36,5	5,15	14,7
    	818,43	0	0	 	 	818,75	2528	82,5	16,8	ON	819,06	2528	35,3	5,15	14,25
    	819,38	0	0	 	 	819,73	2528	82,5	14,8	ON	820,06	2528	35,3	5,15	14,25
    	820,4	0	0	 	 	820,73	2528	82,5	10,5	ON	821,06	2528	35,3	5,15	14,41
    	821,4	0	0	 	 	821,72	2528	82,5	11,7	ON	822,02	2528	34,1	4,12	13,94
    	822,35	0	0	 	 	822,67	2528	82,5	14,1	ON	823,02	2528	34,1	4,12	13,94
    	823,34	0	0	 	 	823,69	2528	82,5	15,6	ON	824,02	2528	34,1	4,12	14,12
    	824,33	0	0	 	 	824,66	2528	82,5	18,8	ON	825	2528	34,1	5,15	14,25
    	825,33	0	0	 	 	825,66	2528	82,5	16,8	ON	826	2528	34,1	5,15	14,25
    	826,32	0	0	 	 	826,66	2528	82,5	15,2	ON	827	2528	34,1	5,15	13,83
    	827,34	0	0	 	 	827,67	2528	82,5	13,7	ON	828,03	2528	34,1	5,15	14,25
    	828,35	0	0	 	 	828,68	2528	82,5	11,7	ON	829,01	2528	34,1	5,15	14,25
    	829,34	0	0	 	 	829,65	2528	82,5	12,1	ON	829,98	2528	34,1	5,15	14,25
    	830,3	0	0	 	 	830,63	2528	82,5	14,5	ON	830,97	2528	34,1	4,12	13,94
    	831,3	0	0	 	 	831,63	2528	82,5	16	ON	831,95	2528	34,1	5,15	14,25
    	832,27	0	0	 	 	832,6	2528	82,5	18	ON	832,93	2528	35,3	5,15	14,17
    	833,25	0	0	 	 	833,56	2528	82,5	14,1	ON	833,88	2528	34,1	5,15	14,25
    	834,23	0	0	 	 	834,58	2528	82,5	12,5	ON	834,91	2528	34,1	5,15	14,25
    	835,21	0	0	 	 	835,54	2528	82,5	11,3	ON	835,87	2528	34,1	5,15	13,94
    	836,19	0	0	 	 	836,52	2528	82,5	11,3	ON	836,89	2528	32,9	4,12	13,6
    	837,23	0	0	 	 	837,57	2528	82,5	11,3	ON	837,9	2528	32,9	4,12	13,36
    	838,24	0	0	 	 	838,58	2528	82,5	13,7	ON	838,92	2528	31,8	4,12	13,36
    	839,29	0	0	 	 	839,63	2528	82,5	14,1	ON	839,97	2528	31,8	4,12	13,07
    	840,31	0	0	 	 	840,69	2528	82,5	15,6	ON	841,03	2528	31,8	4,12	13,07
    	841,36	0	0	 	 	841,7	2528	82,5	15,6	ON	842,04	2528	31	4,12	12,66
    	842,37	0	0	 	 	842,68	2528	82,5	11,7	ON	843,02	2528	31	4,12	12,78
    	843,34	0	0	 	 	843,68	2528	82,5	9	ON	844,01	2528	31	4,12	12,8
    	844,32	0	0	 	 	844,66	2528	82,5	11,3	ON	845,01	2528	31	4,12	12,52
    	845,33	0	0	 	 	845,67	2528	82,5	14,1	ON	845,98	2528	31,8	4,12	12,78
    	846,32	0	0	 	 	846,64	2528	82,5	16,4	ON	846,96	2528	31,8	4,12	13,15
    	847,29	0	0	 	 	847,62	2528	82,5	15,6	ON	847,96	2528	32,9	4,12	13,55
    	848,31	0	0	 	 	848,64	2528	82,5	11,7	ON	848,96	2528	32,9	4,12	13,36
    	849,28	0	0	 	 	849,62	2528	82,5	12,5	ON	849,96	2528	32,9	4,12	13,33
    	850,28	0	0	 	 	850,64	2528	82,5	14,1	ON	850,97	2528	31,8	4,12	13,6
    	851,29	0	0	 	 	851,63	2528	82,5	18,4	ON	851,97	2528	31,8	4,12	12,92
    	852,3	0	0	 	 	852,61	2528	82,5	14,8	ON	852,92	2528	31,8	4,12	13,17
    	853,24	0	0	 	 	853,61	2528	82,5	9	ON	853,94	2528	31	4,12	12,69
    	854,28	0	0	 	 	854,6	2528	82,5	10,2	ON	854,95	2528	31	4,12	12,23
    	855,27	0	0	 	 	855,61	2528	82,5	11,7	ON	855,95	2528	31	4,12	12,32
    	856,26	0	0	 	 	856,57	2528	82,5	16,4	ON	856,92	2528	29,8	4,12	12,09
    	857,26	0	0	 	 	857,57	2528	82,5	12,5	ON	857,91	2528	29,8	4,12	12,23
    	858,22	0	0	 	 	858,57	2528	82,5	8,2	ON	858,89	2528	28,6	4,12	12,2
    	859,22	0	0	 	 	859,55	2528	82,5	10,5	ON	859,89	2528	28,6	4,12	11,68
    	860,22	0	0	 	 	860,56	2528	82,5	12,9	ON	860,89	2528	28,6	3,09	11,68
    	861,22	0	0	 	 	861,55	2528	82,5	13,7	ON	861,89	2528	27,5	4,12	11,64
    	862,21	0	0	 	 	862,54	2528	82,5	8,2	ON	862,88	2528	27,5	3,09	11,42
    	863,21	0	0	 	 	863,54	2528	82,5	11,7	ON	863,87	2528	28,6	3,09	11,68
    	864,21	0	0	 	 	864,56	2528	82,5	14,8	ON	864,89	2528	28,6	4,12	11,71
    	865,21	0	0	 	 	865,54	2528	82,5	11,3	ON	865,87	2528	29,8	4,12	12,23
    	866,19	0	0	 	 	866,54	2528	82,5	12,1	ON	866,85	2528	29,8	4,12	12,23
    	867,17	0	0	 	 	867,5	2528	82,5	14,1	ON	867,85	2528	31	4,12	12,24
    	868,17	0	0	 	 	868,51	2528	82,5	15,6	ON	868,84	2528	31	4,12	12,24
    	869,16	0	0	 	 	869,52	2528	82,5	13,3	ON	869,85	2528	31	4,12	12,57
    	870,18	0	0	 	 	870,51	2528	82,5	9	ON	870,86	2528	31,8	4,12	12,81
    	871,18	0	0	 	 	871,5	2528	82,5	11,3	ON	871,82	2528	31,8	4,12	13,07
    	872,15	0	0	 	 	872,47	2528	82,5	14,5	ON	872,81	2528	31	4,12	13,07
    	873,14	0	0	 	 	873,47	2528	82,5	16	ON	873,82	2528	31	4,12	12,62
    	874,17	0	0	 	 	874,49	2528	82,5	13,3	ON	874,81	2528	31	4,12	12,71
    	875,13	0	0	 	 	875,44	2528	82,5	7,8	ON	875,78	2528	29,8	4,12	12,23
    	876,15	0	0	 	 	876,49	2528	82,5	10,9	ON	876,83	2528	28,6	4,12	11,95
    	877,17	0	0	 	 	877,49	2528	82,5	14,8	ON	877,82	2528	28,6	4,12	11,68
    	878,16	0	0	 	 	878,5	2528	82,5	12,1	ON	878,84	2528	28,6	4,12	11,44
    	879,18	0	0	 	 	879,51	2528	82,5	9,4	ON	879,85	2528	29,8	4,12	11,66
    	880,17	0	0	 	 	880,51	2528	82,5	9	ON	880,83	2528	29,8	4,12	11,81
    	881,18	0	0	 	 	881,5	2528	82,5	12,5	ON	881,83	2528	29,8	4,12	11,68
    	882,18	0	0	 	 	882,52	2528	82,5	14,5	ON	882,86	2528	29,8	4,12	11,95
    	883,17	0	0	 	 	883,51	2528	82,5	10,9	ON	883,84	2528	29,8	4,12	11,95
    	884,17	0	0	 	 	884,5	2528	82,5	7,4	ON	884,83	2528	29,8	4,12	12,04
    	885,19	0	0	 	 	885,53	2528	82,5	10,2	ON	885,84	2528	29,8	4,12	11,95
    	886,18	0	0	 	 	886,51	2528	82,5	13,7	ON	886,85	2528	29,8	4,12	11,95
    	887,16	0	0	 	 	887,52	2528	82,5	13,3	ON	887,84	2528	29,8	4,12	11,91
    	888,17	0	0	 	 	888,48	2528	82,5	10,5	ON	888,83	2528	29,8	4,12	11,92
    	889,15	0	0	 	 	889,48	2528	82,5	9	ON	889,83	2528	29,8	4,12	12,2
    	890,16	0	0	 	 	890,48	2528	82,5	12,1	ON	890,84	2528	29,8	4,12	11,82
    	891,18	0	0	 	 	891,49	2528	82,5	14,1	ON	891,81	2528	31	4,12	12,5
    	892,16	0	0	 	 	892,48	2528	82,5	14,5	ON	892,81	2528	31	4,12	12,78
    	893,14	0	0	 	 	893,47	2528	82,5	10,9	ON	893,79	2528	31	4,12	12,78
    	894,12	0	0	 	 	894,45	2528	81	10,9	ON	894,79	2528	31	4,12	13,07
    	895,13	0	0	 	 	895,45	2528	81	13,3	ON	895,78	2528	31	4,12	12,78
    	896,1	0	0	 	 	896,43	2528	82,5	17,2	ON	896,76	2528	31,8	4,12	12,8
    	897,08	0	0	 	 	897,42	2528	82,5	13,3	ON	897,75	2528	31,8	4,12	12,78
    	898,08	0	0	 	 	898,43	2528	82,5	9,4	ON	898,76	2528	31	4,12	12,76
    	899,07	0	0	 	 	899,42	2528	81	12,5	ON	899,76	2528	31	4,12	12,73
    	900,09	0	0	 	 	900,44	2528	81	16	ON	900,8	2528	31	4,12	12,8
    	901,15	0	0	 	 	901,5	2528	81	15,2	ON	901,81	2528	29,8	4,12	12,12
    	902,14	0	0	 	 	902,46	2528	81	9,8	ON	902,79	2528	29,8	4,12	11,92
    	903,13	0	0	 	 	903,47	2528	82,5	10,9	ON	903,79	2528	29,8	4,12	12,23
    	904,13	0	0	 	 	904,47	2528	81	16,8	ON	904,79	2528	29,8	4,12	12,23
    	905,16	0	0	 	 	905,49	2528	81	11,7	ON	905,81	2528	29,8	4,12	12,2
    	906,14	0	0	 	 	906,46	2528	81	10,2	ON	906,79	2528	29,8	4,12	12,23
    	907,11	0	0	 	 	907,45	2528	82,5	13,7	ON	907,81	2528	29,8	4,12	12,47
    	908,16	0	0	 	 	908,5	2528	81	14,8	ON	908,84	2528	31	4,12	12,04
    	909,18	0	0	 	 	909,52	2528	81	12,9	ON	909,85	2528	31	4,12	12,23
    	910,18	0	0	 	 	910,51	2528	81	10,2	ON	910,84	2528	29,8	4,12	12,02
    	911,17	0	0	 	 	911,52	2528	82,5	10,9	ON	911,86	2528	29,8	4,12	12,44
    	912,2	0	0	 	 	912,53	2528	81	14,5	ON	912,86	2528	29,8	4,12	12,5
    	913,18	0	0	 	 	913,5	2528	81	13,7	ON	913,84	2528	29,8	4,12	12,34
    	914,17	0	0	 	 	914,5	2528	81	9	ON	914,81	2528	29,8	4,12	12,5
    	915,15	0	0	 	 	915,49	2528	81	12,1	ON	915,84	2528	31	4,12	12,23
    	916,17	0	0	 	 	916,49	2528	81	16	ON	916,83	2528	31	4,12	12,59
    	917,15	0	0	 	 	917,49	2528	81	12,5	ON	917,82	2528	31	4,12	13,02
    	918,16	0	0	 	 	918,48	2528	81	12,1	ON	918,81	2528	31,8	4,12	12,78
    	919,15	0	0	 	 	919,5	2528	81	10,9	ON	919,84	2528	31,8	4,12	12,73
    	920,17	0	0	 	 	920,52	2528	81	10,5	ON	920,84	2528	31,8	4,12	12,83
    	921,18	0	0	 	 	921,52	2528	81	11,7	ON	921,85	2528	31	4,12	12,78
    	922,19	0	0	 	 	922,52	2528	81	12,9	ON	922,83	2528	31,8	4,12	12,5
    	923,18	0	0	 	 	923,52	2528	81	14,8	ON	923,86	2528	31	4,12	12,5
    	924,17	0	0	 	 	924,51	2528	81	14,1	ON	924,85	2528	31,8	4,12	12,83
    	925,19	0	0	 	 	925,52	2528	81	10,2	ON	925,85	2528	31,8	4,12	12,86
    	926,19	0	0	 	 	926,53	2528	81	9	ON	926,87	2528	31	4,12	13,02
    	927,21	0	0	 	 	927,55	2528	81	10,5	ON	927,88	2528	31,8	4,12	13,07
    	928,21	0	0	 	 	928,53	2528	81	14,1	ON	928,87	2528	32,9	4,12	13,38
    	929,19	0	0	 	 	929,55	2528	81	16	ON	929,89	2528	32,9	4,12	13,36
    	930,22	0	0	 	 	930,55	2528	81	12,9	ON	930,87	2528	31,8	4,12	13,09
    	931,17	0	0	 	 	931,5	2528	81	9,8	ON	931,84	2528	31,8	4,12	13,09
    	932,19	0	0	 	 	932,52	2528	81	12,1	ON	932,85	2528	31,8	4,12	12,78
    	933,2	0	0	 	 	933,54	2528	81	15,6	ON	933,87	2528	31,8	4,12	12,78
    	934,23	0	0	 	 	934,56	2528	81	13,3	ON	934,9	2528	31,8	4,12	13,07
    	935,21	0	0	 	 	935,54	2528	81	7,8	ON	935,87	2528	31,8	4,12	12,95
    	936,19	0	0	 	 	936,56	2528	81	9,4	ON	936,91	2528	31,8	4,12	13,07
    	937,23	0	0	 	 	937,56	2528	81	12,1	ON	937,88	2528	31,8	4,12	13,07
    	938,2	0	0	 	 	938,54	2528	81	16,8	ON	938,87	2528	31,8	4,12	13,07
    	939,18	0	0	 	 	939,49	2528	81	13,7	ON	939,83	2528	31,8	4,12	12,8
    	940,16	0	0	 	 	940,49	2528	81	8,2	ON	940,84	2528	31,8	4,12	13,09
    	941,18	0	0	 	 	941,51	2528	81	10,5	ON	941,84	2528	32,9	4,12	13,07
    	942,16	0	0	 	 	942,48	2528	81	14,8	ON	942,82	2528	34,1	4,12	13,65
    	943,18	0	0	 	 	943,51	2528	81	17,2	ON	943,85	2528	32,9	4,12	13,65
    	944,17	0	0	 	 	944,5	2528	81	16,4	ON	944,82	2528	34,1	5,15	13,92
    	945,15	0	0	 	 	945,52	2528	81	14,1	ON	945,84	2528	34,1	5,15	13,55
    	946,16	0	0	 	 	946,49	2528	81	14,1	ON	946,83	2528	32,9	5,15	13,65
    	947,17	0	0	 	 	947,5	2528	81	9,8	ON	947,86	2528	32,9	4,12	13,07
    	948,19	0	0	 	 	948,53	2528	81	11,7	ON	948,86	2528	32,9	4,12	13,48
    	949,18	0	0	 	 	949,51	2528	81	14,5	ON	949,86	2528	32,9	4,12	13,36
    	950,2	0	0	 	 	950,52	2528	81	16,4	ON	950,86	2528	32,9	4,12	13,36
    	951,2	0	0	 	 	951,54	2528	81	14,5	ON	951,87	2528	32,9	4,12	13,65
    	952,23	0	0	 	 	952,56	2528	81	13,7	ON	952,91	2528	32,9	5,15	13,53
    	953,25	0	0	 	 	953,58	2528	81	10,9	ON	953,91	2528	32,9	4,12	13,65
    	954,26	0	0	 	 	954,6	2528	81	9,8	ON	954,93	2528	32,9	4,12	13,41
    	955,26	0	0	 	 	955,58	2528	81	10,5	ON	955,92	2528	32,9	4,12	13,65
    	956,25	0	0	 	 	956,61	2528	81	12,5	ON	956,93	2528	34,1	4,12	13,65
    	957,27	0	0	 	 	957,6	2528	81	14,5	ON	957,94	2528	34,1	4,12	13,6
    	958,26	0	0	 	 	958,58	2528	81	16	ON	958,93	2528	32,9	4,12	13,65
    	959,26	0	0	 	 	959,62	2528	81	15,2	ON	959,95	2528	32,9	4,12	13,36
    	960,29	0	0	 	 	960,63	2528	81	13,3	ON	960,96	2528	32,9	5,15	13,67
    	961,33	0	0	 	 	961,64	2528	81	9,4	ON	961,99	2528	32,9	5,15	13,94
    	962,33	0	0	 	 	962,65	2528	81	10,5	ON	963	2528	32,9	4,12	13,65
    	963,31	0	0	 	 	963,64	2528	81	12,9	ON	963,96	2528	32,9	4,12	13,62
    	964,29	0	0	 	 	964,62	2528	81	14,5	ON	964,96	2528	32,9	4,12	13,41
    	965,31	0	0	 	 	965,66	2528	81	16,4	ON	966	2528	32,9	4,12	13,48
    	966,33	0	0	 	 	966,66	2528	81	13,3	ON	966,99	2528	31,8	4,12	13,23
    	967,32	0	0	 	 	967,64	2528	81	9,4	ON	967,97	2528	31,8	4,12	13,07
    	968,31	0	0	 	 	968,64	2528	81	12,1	ON	968,97	2528	31	4,12	12,55
    	969,31	0	0	 	 	969,63	2528	81	12,1	ON	969,96	2528	28,6	4,12	11,72
    	970,31	0	0	 	 	970,65	2560	81	14,1	ON	971	2528	28,6	3,09	11,42
    	971,33	0	0	 	 	971,67	2528	81	12,9	ON	972,01	2528	27,5	3,09	11,27
    	972,35	0	0	 	 	972,68	2560	81	8,2	ON	973	2560	26,3	3,09	10,65
    	973,33	0	0	 	 	973,67	2560	81	10,9	ON	973,99	2560	25,1	3,09	10,41
    	974,34	0	0	 	 	974,66	2560	81	16	ON	975,02	2560	23,9	3,09	9,36
    	975,35	0	0	 	 	975,69	2560	81	10,5	ON	976,02	2560	21,6	3,09	8,48
    	976,35	0	0	 	 	976,7	2560	81	12,5	ON	977,03	2560	18,4	2,06	7,36
    	977,38	0	0	 	 	977,72	2560	81	14,1	ON	978,04	2560	17,3	2,06	6,99
    	978,36	0	0	 	 	978,71	2560	81	8,2	ON	979,04	2560	16,1	2,06	6,7
    	979,33	0	0	 	 	979,67	2560	81	17,2	ON	980,01	2560	16,1	2,06	6,64
    	980,34	0	0	 	 	980,68	2528	81	10,9	ON	981,03	2560	14,9	2,06	6,25
    	981,37	0	0	 	 	981,7	2528	81	15,2	ON	982,03	2528	14,9	2,06	6,02
    	982,35	0	0	 	 	982,69	2528	81	17,6	ON	983,01	2528	14,9	2,06	6,29
    	983,32	0	0	 	 	983,66	2528	81	11,7	ON	983,95	2528	16,1	2,06	6,78
    	984,27	0	0	 	 	984,6	2528	81	19,9	ON	984,94	2528	16,1	2,06	6,84
    	985,25	0	0	 	 	985,57	2528	81	12,9	ON	985,91	2528	18,4	2,06	7,18
    	986,23	0	0	 	 	986,53	2528	81	13,7	ON	986,85	2528	18,4	2,06	7,38
    	987,17	0	0	 	 	987,51	2496	81	14,8	ON	987,84	2496	18,4	2,06	7,49
    	988,18	0	0	 	 	988,49	2528	81	12,1	ON	988,82	2528	19,2	2,06	8,22
    	989,14	0	0	 	 	989,47	2528	81	15,6	ON	989,82	2528	20,4	2,06	8,57
    	990,14	0	0	 	 	990,47	2528	81	14,8	ON	990,78	2528	19,2	3,09	8,15
    	991,1	0	0	 	 	991,42	2528	81	10,9	ON	991,75	2528	18,4	2,06	7,49
    	992,09	0	0	 	 	992,42	2528	81	17,2	ON	992,74	2528	18,4	2,06	7,52
    	993,07	0	0	 	 	993,41	2528	81	10,5	ON	993,75	2528	17,3	2,06	6,92
    	994,07	0	0	 	 	994,41	2528	81	14,5	ON	994,74	2528	17,3	2,06	6,64
    	995,06	0	0	 	 	995,38	2528	81	16,4	ON	995,7	2528	16,1	2,06	6,92
    	996,01	0	0	 	 	996,35	2528	81	10,5	ON	996,66	2528	16,1	2,06	6,99
    	997	0	0	 	 	997,33	2528	81	16,4	ON	997,67	2528	17,3	2,06	7,51
    	997,99	0	0	 	 	998,33	2528	81	12,9	ON	998,65	2496	19,2	2,06	8,2
    	998,96	0	0	 	 	999,29	2496	81	13,3	ON	999,62	2496	21,6	3,09	9,22
    	999,99	0	0	 	 	1000,3	2496	81	19,9	ON	1000,65	2496	22,7	3,09	9,61
    	1000,96	0	0	 	 	1001,28	2496	81	12,5	ON	1001,59	2496	27,5	4,12	11,42
    	1001,91	0	0	 	 	1002,24	2464	81	13,3	ON	1002,56	2464	13,7	2,06	5,34
    	1002,87	0	0	 	 	1003,2	2400	81	0	OFF	1003,52	2400	0	0	5,34
    	1003,84	0	0	 	 	1004,16	2368	81	0	OFF	1004,49	2336	0	0	5,64
    	1004,83	0	0	 	 	1005,16	2304	81	0	OFF	1005,49	2272	0	0	5,33
    	1005,83	0	0	 	 	1006,15	2240	81	0	OFF	1006,49	2240	0	0	5,31
    	1006,84	0	0	 	 	1007,18	2176	81	0	OFF	1007,51	2144	0	0	5,47
    	1007,82	0	0	 	 	1008,16	2112	81	0	OFF	1008,5	2080	0	0	5,12
    	1008,84	0	0	 	 	1009,19	2048	81	0	OFF	1009,54	2048	12,5	2,06	4,13
    	1009,9	0	0	 	 	1010,25	2016	81	-1,2	ON	1010,56	2016	37,6	5,15	13,12
    	1010,92	0	0	 	 	1011,28	2016	81	-3,1	ON	1011,62	2016	43,5	5,15	13,94
    	1011,98	0	0	 	 	1012,34	1984	81	-3,9	ON	1012,69	2016	49	6,18	15,83
    	1013,04	0	0	 	 	1013,41	2016	81	9,4	ON	1013,76	2016	50,2	7,21	15,96
    	1014,11	0	0	 	 	1014,45	2016	81	21,9	ON	1014,79	2016	44,3	6,18	14,56
    	1015,14	0	0	 	 	1015,5	2016	81	13,3	ON	1015,86	1984	20,4	2,06	6,03
    	1016,22	0	0	 	 	1016,55	1952	81	6,3	ON	1016,92	1952	19,2	2,06	6,29
    	1017,27	0	0	 	 	1017,63	1920	81	15,2	ON	1017,98	1920	29,8	4,12	9,54
    	1018,34	0	0	 	 	1018,7	1888	81	11,7	ON	1019,08	1888	28,6	4,12	8,81
    	1019,44	0	0	 	 	1019,76	1856	81	14,8	ON	1020,13	1856	28,6	4,12	8,56
    	1020,46	0	0	 	 	1020,83	1632	81	0	OFF	1021,15	1376	13,7	2,06	2,37
    	1021,46	3,1	0	 	 	1021,76	1088	81	-0,4	ON	1022,07	960	14,9	2,06	2,58
    	1022,36	3,9	0	 	 	1022,67	864	81	-1,2	ON	1022,98	896	20,4	3,09	2,93
    	1023,28	3,1	0	 	 	1023,58	896	81	-1,6	ON	1023,89	896	19,2	3,09	2,69
    	1024,18	3,9	0	 	 	1024,49	864	81	-3,9	ON	1024,77	864	18,4	2,06	2,43
    	1025,06	3,9	0	 	 	1025,35	864	81	-7	ON	1025,64	832	18,4	2,06	2,52
    	1025,94	3,9	0	 	 	1026,23	800	81	-10,2	ON	1026,52	800	19,2	2,06	3,06
    	1026,81	0	0	 	 	1027,12	1088	81	-12,1	ON	1027,42	1216	32,9	4,12	7,32
    	1027,72	0	0	 	 	1028,04	1312	81	-6,3	ON	1028,36	1312	63,9	8,24	14,02
    	1028,69	0	0	 	 	1029	1408	81	3,1	ON	1029,46	1472	65,1	8,24	14,47
    	1029,77	0	0	 	 	1030,12	1600	81	14,5	ON	1030,47	1664	65,1	9,27	18,03
    	1030,84	0	0	 	 	1031,2	1824	81	16,4	ON	1031,55	1856	63,9	9,27	18,62
    	1031,92	0	0	 	 	1032,26	1984	81	13,3	ON	1032,61	2016	61,6	8,24	19,73
    	1032,94	0	0	 	 	1033,28	2112	81	14,1	ON	1033,6	2144	68,6	10,3	25,62
    	1033,93	0	0	 	 	1034,26	2272	81	12,5	ON	1034,59	2336	82	11,33	31,73
    	1034,92	0	0	 	 	1035,27	2464	81	3,5	ON	1035,61	2528	80	11,33	33,26
    	1035,94	0	0	 	 	1036,27	2688	81	3,9	ON	1036,59	2720	80	11,33	35,09
    	1036,89	0	0	 	 	1037,22	2240	81	0	OFF	1037,54	1920	0	0	4,57
    	1037,91	0	0	 	 	1038,21	1344	81	0	ON	1038,53	1216	14,9	2,06	3,14
    	1038,86	3,1	0	 	 	1039,17	1088	81	-0,8	ON	1039,48	1056	17,3	2,06	3,03
    	1039,79	3,1	0	 	 	1040,08	992	81	-1,2	ON	1040,4	960	17,3	2,06	2,78
    	1040,71	3,1	0	 	 	1041,03	928	81	-2	ON	1041,34	928	18,4	2,06	3,03
    	1041,64	3,1	0	 	 	1041,92	928	81	-4,7	ON	1042,2	896	19,2	2,06	3,13
    	1042,48	3,1	0	 	 	1042,78	864	81	-7,8	ON	1043,09	832	20,4	2,06	3,12
    	1043,4	3,1	0	 	 	1043,69	832	81	-10,2	ON	1044	832	20,4	2,06	3,24
    	1044,3	3,1	0	 	 	1044,6	864	81	-7,4	ON	1044,9	864	20,4	2,06	2,94
    	1045,19	3,1	0	 	 	1045,5	832	81	-4,7	ON	1045,78	832	20,4	2,06	3,03
    	1046,1	3,1	0	 	 	1046,39	832	81	-2	ON	1046,7	864	20,4	2,06	2,84
    	1047	3,1	0	 	 	1047,31	832	81	0,8	ON	1047,61	832	20,4	2,06	3,04
    	1047,91	3,1	0	 	 	1048,21	832	82,5	3,5	ON	1048,5	832	21,6	2,06	3,07
    	1048,8	3,1	0	 	 	1049,07	864	81	6,3	ON	1049,34	864	20,4	2,06	2,98
    	1049,63	3,1	0	 	 	1049,93	864	82,5	9	ON	1050,22	864	19,2	2,06	2,92
    	1050,52	0	0	 	 	1050,83	1120	82,5	11,3	ON	1051,14	1312	54,9	7,21	11,74
    	1051,46	0	0	 	 	1051,76	1024	82,5	13,3	ON	1052,06	1120	43,5	6,18	7,2
    	1052,38	0	0	 	 	1052,7	1248	82,5	12,9	ON	1053,05	1280	32,9	4,12	6,27
    	1053,35	1,6	0	 	 	1053,67	1216	82,5	9	ON	1053,97	1120	14,9	2,06	2,42
    	1054,28	3,9	0	 	 	1054,58	800	82,5	5,9	ON	1054,89	864	22,7	3,09	3,98
    	1055,17	3,1	0	 	 	1055,48	896	82,5	5,9	ON	1055,77	896	21,6	3,09	3,12
    	1056,05	3,1	0	 	 	1056,35	896	82,5	7	ON	1056,64	864	20,4	2,06	2,98
    	1056,92	3,1	0	 	 	1057,2	864	82,5	7,8	ON	1057,5	864	19,2	2,06	2,72
    	1057,81	3,1	0	 	 	1058,1	832	82,5	5,1	ON	1058,4	832	19,2	2,06	2,61
    	1058,69	3,9	0	 	 	1058,99	832	82,5	4,7	ON	1059,27	832	19,2	2,06	2,76
    	1059,56	3,1	0	 	 	1059,85	832	82,5	7,4	ON	1060,13	864	19,2	2,06	2,86
    	1060,43	3,1	0	 	 	1060,73	864	82,5	10,2	ON	1061,04	864	19,2	2,06	2,77
    	1061,33	3,1	0	 	 	1061,61	864	82,5	12,9	ON	1061,88	864	19,2	2,06	2,77
    	1062,17	3,1	0	 	 	1062,46	864	82,5	10,2	ON	1062,77	864	19,2	2,06	2,68
    	1063,07	0	0	 	 	1063,36	992	82,5	8,2	ON	1063,68	1248	29,8	4,12	5,54
    	1064	0	0	 	 	1064,32	1216	82,5	12,1	ON	1064,63	1184	26,3	3,09	5,74
    	1064,94	0	0	 	 	1065,27	1312	82,5	13,3	ON	1065,57	1376	26,3	3,09	5,38
    	1065,88	0	0	 	 	1066,2	1376	82,5	16	ON	1066,49	1216	13,7	2,06	2,52
    	1066,77	3,9	0	 	 	1067,07	864	82,5	12,9	ON	1067,37	800	21,6	3,09	4,4
    	1067,66	3,1	0	 	 	1067,96	896	82,5	11,7	ON	1068,25	896	21,6	3,09	3,17
    	1068,55	3,1	0	 	 	1068,83	896	82,5	10,9	ON	1069,12	896	19,2	2,06	2,86
    	1069,4	3,1	0	 	 	1069,71	864	82,5	7,8	ON	1069,99	832	19,2	2,06	2,89
    	1070,29	3,9	0	 	 	1070,61	832	82,5	4,7	ON	1070,91	864	21,6	3,09	3,06
    	1071,2	3,1	0	 	 	1071,5	864	82,5	7	ON	1071,79	864	20,4	2,06	3,13
    	1072,09	3,1	0	 	 	1072,41	832	82,5	9,8	ON	1072,7	864	20,4	2,06	2,56
    	1072,99	0	0	 	 	1073,35	1664	82,5	7,4	ON	1073,69	1696	0	0	4,53
    	1074,03	0	0	 	 	1074,34	1408	82,5	0	ON	1074,64	1216	13,7	2,06	2,43
    	1074,91	3,1	0	 	 	1075,21	960	82,5	-0,8	ON	1075,49	896	16,1	2,06	3,08
    	1075,79	3,9	0	 	 	1076,08	896	82,5	-1,2	ON	1076,38	896	19,2	3,09	2,41
    	1076,68	3,1	0	 	 	1076,97	896	82,5	-1,6	ON	1077,27	864	18,4	2,06	2,64
    	1077,57	3,9	0	 	 	1077,85	864	82,5	-4,7	ON	1078,15	864	18,4	2,06	2,51
    	1078,43	3,9	0	 	 	1078,71	832	84	-7,8	ON	1079,01	832	18,4	2,06	2,48
    	1079,31	3,9	0	 	 	1079,6	800	84	-10,9	ON	1079,89	800	19,2	2,06	3,2
    	1080,18	3,1	0	 	 	1080,48	832	82,5	-12,1	ON	1080,77	832	21,6	2,06	3,35
    	1081,05	3,1	0	 	 	1081,33	832	84	-9,4	ON	1081,63	832	21,6	2,06	3,25
    	1081,93	3,1	0	 	 	1082,22	864	84	-7	ON	1082,51	864	21,6	2,06	3,23
    	1082,8	3,1	0	 	 	1083,09	864	84	-4,3	ON	1083,38	864	21,6	2,06	3,32
    	1083,68	3,1	0	 	 	1083,99	864	84	-1,6	ON	1084,28	864	21,6	2,06	3,23
    	1084,55	3,1	0	 	 	1084,85	864	84	1,2	ON	1085,15	864	20,4	2,06	2,86
    	1085,45	3,1	0	 	 	1085,74	864	84	3,9	ON	1086,03	864	20,4	2,06	2,89
    	1086,34	3,1	0	 	 	1086,64	832	84	6,6	ON	1086,93	864	20,4	2,06	2,63
    	1087,22	3,1	0	 	 	1087,51	864	84	9,4	ON	1087,78	864	19,2	2,06	2,52
    	1088,09	3,9	0	 	 	1088,4	864	84	12,1	ON	1088,71	864	19,2	2,06	2,64
    	1088,98	3,9	0	 	 	1089,29	864	84	12,5	ON	1089,59	832	18,4	2,06	2,66
    	1089,89	3,9	0	 	 	1090,18	864	84	9,4	ON	1090,48	832	18,4	2,06	2,51
    	1090,78	3,9	0	 	 	1091,08	832	84	7	ON	1091,35	832	18,4	2,06	2,72
    	1091,66	3,9	0	 	 	1091,96	832	84	5,9	ON	1092,25	832	19,2	2,06	2,76
    	1092,52	3,1	0	 	 	1092,84	864	84	8,6	ON	1093,14	864	19,2	2,06	2,77
    	1093,42	3,9	0	 	 	1093,69	864	84	11,3	ON	1093,99	832	19,2	2,06	2,83
    1	1094,3	3,9	0	 	 	1094,6	864	84	13,3	ON	1094,91	864	19,2	2,06	2,73
    	1095,2	3,9	0	 	 	1095,48	864	84	10,5	ON	1095,76	832	18,4	2,06	2,58
    	1096,03	3,9	0	 	 	1096,35	832	84	9	ON	1096,64	832	19,2	2,06	2,55
    	1096,92	3,9	0	 	 	1097,21	800	84	11,7	ON	1097,49	800	20,4	3,09	3,38
    	1097,8	3,1	0	 	 	1098,1	864	84	14,1	ON	1098,38	896	22,7	3,09	3,03
    	1098,68	3,1	0	 	 	1098,97	896	84	16,8	ON	1099,26	864	20,4	3,09	3,29
    	1099,58	3,1	0	 	 	1099,86	864	84	19,5	ON	1100,16	864	19,2	3,09	2,49
    	1100,45	3,9	0	 	 	1100,76	832	84	22,3	ON	1101,06	832	19,2	3,09	2,62
    	1101,37	3,1	0	 	 	1101,66	864	84	25	ON	1101,94	864	19,2	3,09	2,86
    	1102,22	3,1	0	 	 	1102,51	896	84	25	ON	1102,81	896	19,2	3,09	2,66
    	1103,11	3,9	0	 	 	1103,4	896	84	25	ON	1103,69	864	17,3	2,06	2,58
    	1103,98	3,9	0	 	 	1104,28	864	84	25	ON	1104,56	864	16,1	2,06	2,41
    	1104,84	3,9	0	 	 	1105,1	864	84	25	ON	1105,41	864	16,1	2,06	2,23
    	1105,69	3,9	0	 	 	1105,98	832	84	25	ON	1106,26	832	16,1	2,06	2,38
    	1106,54	4,7	0	 	 	1106,8	832	84	22,7	ON	1107,1	832	16,1	2,06	2,32
    	1107,39	3,9	0	 	 	1107,7	832	84	19,9	ON	1107,98	832	16,1	2,06	2,4
    	1108,27	4,7	0	 	 	1108,56	832	84	17,6	ON	1108,86	832	17,3	2,06	2,41
    	1109,16	3,9	0	 	 	1109,45	832	84	14,8	ON	1109,76	832	18,4	2,06	2,62
    	1110,04	3,9	0	 	 	1110,35	832	84	12,1	ON	1110,64	832	18,4	2,06	2,59
    	1110,93	3,9	0	 	 	1111,23	832	84	12,5	ON	1111,53	864	18,4	2,06	2,6
    	1111,82	3,9	0	 	 	1112,12	864	84	14,1	ON	1112,41	864	18,4	2,06	2,38
    	1112,72	3,9	0	 	 	1113,02	832	84	11,3	ON	1113,33	832	18,4	2,06	2,56
    	1113,63	3,9	0	 	 	1113,92	832	84	8,6	ON	1114,22	832	18,4	2,06	2,47
    	1114,52	3,9	0	 	 	1114,82	832	84	5,9	ON	1115,13	832	18,4	2,06	2,51
    	1115,42	3,9	0	 	 	1115,71	832	84	8,2	ON	1115,99	832	18,4	2,06	2,58
    	1116,28	3,9	0	 	 	1116,58	832	84	10,9	ON	1116,88	864	18,4	2,06	2,61
    	1117,15	3,9	0	 	 	1117,45	832	84	13,3	ON	1117,76	864	18,4	2,06	2,49
    	1118,05	3,9	0	 	 	1118,36	864	84	11,3	ON	1118,67	832	18,4	2,06	2,72
    	1118,96	3,9	0	 	 	1119,25	832	84	8,2	ON	1119,55	832	18,4	2,06	2,58
    	1119,83	3,9	0	 	 	1120,11	832	84	7,8	ON	1120,4	832	19,2	2,06	2,76
    	1120,71	3,9	0	 	 	1121	832	84	10,5	ON	1121,27	832	18,4	2,06	2,63
    	1121,57	3,9	0	 	 	1121,87	832	84	13,3	ON	1122,19	864	18,4	2,06	2,59
    	1122,49	3,9	0	 	 	1122,79	864	84	12,5	ON	1123,09	864	18,4	2,06	2,58
    	1123,39	3,9	0	 	 	1123,71	864	84	9,8	ON	1124	832	18,4	2,06	2,69
    	1124,29	3,9	0	 	 	1124,57	832	84	9,4	ON	1124,86	832	18,4	2,06	2,67
    	1125,15	3,9	0	 	 	1125,44	832	84	12,1	ON	1125,74	832	18,4	2,06	2,55
    	1126,03	3,9	0	 	 	1126,33	864	84	12,5	ON	1126,62	864	18,4	2,06	2,47
    	1126,93	3,9	0	 	 	1127,21	864	84	10,2	ON	1127,49	832	18,4	2,06	2,76
    	1127,77	3,9	0	 	 	1128,07	832	84	7,4	ON	1128,37	832	18,4	2,06	2,66
    Lastly tried with Kombi valve port blocked and booster disconnected. But it didn't change LTFT (idle).
    Log needed? Didn't post to keep it shorter.
    Additionally bad fuel injectors or faulty ECU.
    Haven't done individual volume tests yet. If one/some of them were bad then shouldn't I get knocking cylinders or unstable idle?
    Keeping ECU change as dessert for later as there are some progress. Don't think that deleting EGR (+SAI probably) would be easy.
    Be sure ECT and IAT reflect proper readings during all transitions.
    Not a problem. IAT stays between outside temperature 25C to ~40...45C with hot engine idling.
  10. #17
    Nov 2017
    Latvia
    Just I thought, I need to extract engine ECU pin code out of 93C76 but plugging in and out another ECU did the trick with intermittent issues (I hope). Now it's actually adjusting both fuel trims.
    Still got some minor issues but this already is a huge leap for mankind
    16804 - Catalyst System; Bank 1
                P0420 - 35-00 - Efficiency Below Threshold
    17831 - Secondary Air Injection System; Bank 1
                P1423 - 35-00 - Insufficient Flow
    Friday	28	June	2019	06:25:10
    3B0 906 018 A		1,6l/2V SIMOS3 G00HS0009
    	Group A:	'031				Group B:	'032				Group C:	'099
    		Lambda Control	Lambda Control	 	 		Adaptation (Idle)	Adaptation (Partial)	 	 		Engine Speed	Coolant	Lambda Control	Lambda Control
    	TIME	Bank 1 (actual)	Bank 1 (specified)			TIME	Bank 1 Sensor 1	Bank 1 Sensor 1			TIME	(G28)	Temperature (G62)		Status
    Marker	STAMP	 V	 V			STAMP	 %	 %			STAMP	 /min	C	 %
    	0,01	0,44	0,43	 	 	0,26	0	0	 	 	0,53	0	16,5	0	OFF
    	0,8	0,44	0,39	 	 	1,07	0	0	 	 	1,34	0	16,5	0	OFF
    	1,6	0,44	0,39	 	 	1,87	0	0	 	 	2,14	160	16,5	0	OFF
    	11,78	0,44	0,43	 	 	11,19	2,3	0	 	 	11,48	896	16,5	0	OFF
    	12,67	0,44	0,39	 	 	12,08	2,3	0	 	 	12,37	896	16,5	0	OFF
    	13,56	0,44	0,39	 	 	12,98	2,3	0	 	 	13,27	896	16,5	0	OFF
    	14,46	0,44	0,43	 	 	13,86	2,3	0	 	 	14,16	864	16,5	0	OFF
    	15,34	0,44	0,39	 	 	14,76	2,3	0	 	 	15,06	896	16,5	0	OFF
    	16,2	0,44	0,39	 	 	15,61	2,3	0	 	 	15,9	864	16,5	0	OFF
    	17,14	0,44	0,43	 	 	16,54	2,3	0	 	 	16,84	896	16,5	0	OFF
    	18,04	0,44	0,39	 	 	17,44	2,3	0	 	 	17,73	896	16,5	0	OFF
    	18,93	0,44	0,39	 	 	18,34	2,3	0	 	 	18,64	864	16,5	0	OFF
    	19,84	0,44	0,39	 	 	19,23	2,3	0	 	 	19,54	896	16,5	0	OFF
    	20,73	0,44	0,39	 	 	20,14	2,3	0	 	 	20,44	896	16,5	0	OFF
    	21,61	0,44	0,39	 	 	21,05	2,3	0	 	 	21,33	896	16,5	0	OFF
    	22,48	0,44	0,43	 	 	21,9	2,3	0	 	 	22,2	896	16,5	0	OFF
    	23,37	0,44	0,39	 	 	22,77	2,3	0	 	 	23,06	896	16,5	0	OFF
    	24,3	0,44	0,39	 	 	23,69	2,3	0	 	 	24,01	896	16,5	0	OFF
    	25,19	0,44	0,39	 	 	24,6	2,3	0	 	 	24,9	896	16,5	0	OFF
    	26,08	0,44	0,39	 	 	25,49	2,3	0	 	 	25,78	896	16,5	0	OFF
    	27	0,44	0,39	 	 	26,4	2,3	0	 	 	26,71	896	16,5	0	OFF
    	27,94	0,44	0,39	 	 	27,31	2,3	0	 	 	27,64	896	16,5	0	OFF
    	28,86	0,44	0,43	 	 	28,24	2,3	0	 	 	28,54	896	16,5	0	OFF
    	29,73	0,44	0,39	 	 	29,16	2,3	0	 	 	29,44	896	16,5	0	OFF
    	30,64	0,44	0,39	 	 	30,03	2,3	0	 	 	30,34	864	18	0	OFF
    	31,51	0,44	0,43	 	 	30,93	2,3	0	 	 	31,21	864	18	0	OFF
    	32,42	0,44	0,43	 	 	31,8	2,3	0	 	 	32,1	896	18	0	OFF
    	33,32	0,44	0,43	 	 	32,72	2,3	0	 	 	33,03	896	18	0	OFF
    	34,22	0,44	0,39	 	 	33,62	2,3	0	 	 	33,91	896	18	0	OFF
    	35,12	0,44	0,43	 	 	34,52	2,3	0	 	 	34,81	896	18	0	OFF
    	36,06	0,44	0,39	 	 	35,42	2,3	0	 	 	35,74	896	18	0	OFF
    	36,96	0,44	0,39	 	 	36,37	2,3	0	 	 	36,68	864	18	0	OFF
    	37,86	0,42	0,39	 	 	37,24	2,3	0	 	 	37,56	896	18	0	OFF
    	38,81	0,42	0,39	 	 	38,18	2,3	0	 	 	38,49	896	18	0	OFF
    	39,73	0,42	0,39	 	 	39,13	2,3	0	 	 	39,44	896	18	0	OFF
    	40,65	0,42	0,43	 	 	40,04	2,3	0	 	 	40,35	896	18	0	OFF
    	41,56	0,52	0,39	 	 	40,96	3,1	0	 	 	41,26	832	18	0	OFF
    	42,46	0,52	0,39	 	 	41,87	2,3	0	 	 	42,16	864	18	0	OFF
    	43,38	0,52	0,43	 	 	42,77	2,3	0	 	 	43,07	896	19,5	0	OFF
    	44,27	0,52	0,39	 	 	43,69	2,3	0	 	 	43,97	864	19,5	0	OFF
    	45,14	0,52	0,39	 	 	44,57	2,3	0	 	 	44,85	896	19,5	0	OFF
    	46,02	0,52	0,39	 	 	45,44	2,3	0	 	 	45,74	896	19,5	0	OFF
    	46,92	0,54	0,43	 	 	46,33	2,3	0	 	 	46,63	896	19,5	0	OFF
    	47,8	0,54	0,43	 	 	47,21	2,3	0	 	 	47,49	896	19,5	0	OFF
    	48,68	0,54	0,39	 	 	48,1	2,3	0	 	 	48,39	896	19,5	0	OFF
    	49,56	0,54	0,39	 	 	48,98	2,3	0	 	 	49,27	896	19,5	0	OFF
    	50,5	0,54	0,43	 	 	49,88	2,3	0	 	 	50,2	896	19,5	0	OFF
    	51,42	0,56	0,43	 	 	50,82	2,3	0	 	 	51,12	896	19,5	0	OFF
    	52,31	0,56	0,39	 	 	51,72	2,3	0	 	 	52,01	896	19,5	0	OFF
    	53,21	0,56	0,39	 	 	52,6	2,3	0	 	 	52,91	896	19,5	0	OFF
    	54,12	0,56	0,39	 	 	53,53	3,1	0	 	 	53,83	896	21	0	OFF
    	55	0,56	0,39	 	 	54,41	3,1	0	 	 	54,7	864	21	-1,2	ON
    	55,96	0,54	0,39	 	 	55,31	3,1	0	 	 	55,64	896	21	-3,9	ON
    	56,84	0,54	0,39	 	 	56,27	3,1	0	 	 	56,55	896	21	-6,6	ON
    	57,75	0,54	0,43	 	 	57,16	3,1	0	 	 	57,47	896	21	-9,4	ON
    	58,59	0,54	0,39	 	 	58,02	3,1	0	 	 	58,29	864	21	-12,1	ON
    	59,53	0,52	0,43	 	 	58,9	2,3	0	 	 	59,22	864	21	-14,8	ON
    	60,44	0,52	0,43	 	 	59,83	3,1	0	 	 	60,12	864	21	-17,6	ON
    	61,31	0,38	0,39	 	 	60,73	2,3	0	 	 	61,01	864	21	-20,3	ON
    	62,16	0,32	0,39	 	 	61,58	2,3	0	 	 	61,87	864	21	-21,1	ON
    	63,04	0,34	0,39	 	 	62,45	2,3	0	 	 	62,75	864	21	-18,4	ON
    	63,94	0,34	0,43	 	 	63,36	2,3	0	 	 	63,65	896	21	-15,6	ON
    	64,83	0,36	0,39	 	 	64,24	2,3	0	 	 	64,54	896	21	-12,9	ON
    	65,75	0,64	0,43	 	 	65,13	2,3	0	 	 	65,44	896	21	-10,2	ON
    	66,65	0,6	0,43	 	 	66,07	2,3	0	 	 	66,37	896	22,5	-11,7	ON
    	67,56	0,56	0,43	 	 	66,96	2,3	0	 	 	67,25	896	22,5	-14,5	ON
    	68,45	0,46	0,39	 	 	67,85	3,1	0	 	 	68,13	864	22,5	-17,2	ON
    	69,36	0,36	0,43	 	 	68,74	2,3	0	 	 	69,06	864	22,5	-19,9	ON
    	70,23	0,32	0,43	 	 	69,64	2,3	0	 	 	69,94	864	22,5	-19,1	ON
    	71,1	0,32	0,39	 	 	70,53	2,3	0	 	 	70,81	896	22,5	-16,4	ON
    	72,02	0,34	0,39	 	 	71,4	2,3	0	 	 	71,72	896	22,5	-13,7	ON
    	72,93	0,34	0,39	 	 	72,32	2,3	0	 	 	72,61	896	22,5	-10,9	ON
    	73,83	0,68	0,43	 	 	73,24	2,3	0	 	 	73,55	896	22,5	-9,4	ON
    	74,73	0,62	0,39	 	 	74,14	2,3	0	 	 	74,44	896	22,5	-12,1	ON
    	75,64	0,56	0,39	 	 	75,04	2,3	0	 	 	75,34	864	22,5	-14,8	ON
    	76,56	0,38	0,39	 	 	75,95	2,3	0	 	 	76,26	864	22,5	-17,6	ON
    	77,45	0,28	0,39	 	 	76,85	2,3	0	 	 	77,12	864	24	-18	ON
    	78,33	0,3	0,39	 	 	77,74	2,3	0	 	 	78,02	896	24	-15,2	ON
    	79,25	0,32	0,39	 	 	78,66	2,3	0	 	 	78,95	896	24	-12,5	ON
    	80,16	0,6	0,39	 	 	79,55	2,3	0	 	 	79,85	864	24	-9,8	ON
    	81,04	0,68	0,39	 	 	80,44	2,3	0	 	 	80,74	896	24	-10,2	ON
    	81,9	0,6	0,39	 	 	81,34	2,3	0	 	 	81,62	896	24	-12,9	ON
    	82,76	0,5	0,43	 	 	82,2	3,1	0	 	 	82,47	864	24	-15,6	ON
    	83,67	0,36	0,43	 	 	83,06	3,1	0	 	 	83,36	864	24	-18,4	ON
    	84,56	0,28	0,39	 	 	83,98	2,3	0	 	 	84,27	864	24	-17,2	ON
    	85,45	0,28	0,43	 	 	84,86	2,3	0	 	 	85,15	864	24	-14,5	ON
    	86,36	0,3	0,39	 	 	85,75	2,3	0	 	 	86,05	896	24	-11,7	ON
    	87,24	0,72	0,43	 	 	86,66	2,3	0	 	 	86,95	896	24	-9	ON
    	88,14	0,66	0,43	 	 	87,54	2,3	0	 	 	87,85	896	24	-11,3	ON
    	89,01	0,58	0,43	 	 	88,43	2,3	0	 	 	88,74	896	24	-14,1	ON
    	89,9	0,4	0,43	 	 	89,31	3,1	0	 	 	89,6	864	25,5	-16,8	ON
    	90,78	0,26	0,39	 	 	90,2	3,1	0	 	 	90,5	864	25,5	-17,2	ON
    	91,7	0,28	0,39	 	 	91,11	2,3	0	 	 	91,4	896	25,5	-14,5	ON
    	92,58	0,28	0,39	 	 	92	2,3	0	 	 	92,28	864	25,5	-11,7	ON
    	93,47	0,52	0,39	 	 	92,87	2,3	0	 	 	93,16	896	25,5	-9	ON
    	94,37	0,74	0,43	 	 	93,76	2,3	0	 	 	94,06	896	25,5	-9,4	ON
    	95,31	0,66	0,43	 	 	94,69	3,1	0	 	 	94,99	896	25,5	-12,1	ON
    	96,16	0,54	0,43	 	 	95,6	3,1	0	 	 	95,86	864	25,5	-14,8	ON
    	97,05	0,3	0,43	 	 	96,46	3,1	0	 	 	96,76	864	25,5	-17,6	ON
    	97,91	0,24	0,39	 	 	97,34	2,3	0	 	 	97,61	896	25,5	-15,6	ON
    	98,78	0,28	0,39	 	 	98,2	2,3	0	 	 	98,48	896	25,5	-12,9	ON
    	99,68	0,6	0,39	 	 	99,1	2,3	0	 	 	99,37	896	27	-10,2	ON
    	100,58	0,7	0,43	 	 	99,98	2,3	0	 	 	100,29	896	27	-11,3	ON
    	101,48	0,62	0,43	 	 	100,88	2,3	0	 	 	101,18	896	27	-14,1	ON
    	102,39	0,36	0,43	 	 	101,79	3,1	0	 	 	102,09	864	27	-16,8	ON
    	103,26	0,24	0,39	 	 	102,69	3,1	0	 	 	102,97	864	27	-16	ON
    	104,2	0,26	0,39	 	 	103,58	2,3	0	 	 	103,87	896	27	-13,3	ON
    	105,12	0,28	0,39	 	 	104,5	2,3	0	 	 	104,8	896	27	-10,5	ON
    	106	0,76	0,43	 	 	105,41	2,3	0	 	 	105,72	896	27	-8,6	ON
    	106,88	0,7	0,51	 	 	106,29	2,3	0	 	 	106,57	896	27	-10,9	ON
    	107,76	0,6	0,47	 	 	107,17	3,1	0	 	 	107,47	896	27	-13,7	ON
    	108,68	0,4	0,43	 	 	108,07	3,1	0	 	 	108,37	864	27	-16,4	ON
    	109,57	0,22	0,35	 	 	108,97	3,1	0	 	 	109,27	864	27	-16	ON
    	110,51	0,24	0,35	 	 	109,88	2,3	0	 	 	110,2	864	27	-13,3	ON
    	111,4	0,26	0,35	 	 	110,79	2,3	0	 	 	111,09	896	28,5	-10,5	ON
    	112,28	0,8	0,55	 	 	111,68	2,3	0	 	 	111,99	896	28,5	-9,4	ON
    	113,19	0,68	0,55	 	 	112,6	3,1	0	 	 	112,89	864	28,5	-12,1	ON
    	114,09	0,64	0,51	 	 	113,48	3,1	0	 	 	113,78	864	28,5	-14,8	ON
    	115	0,32	0,43	 	 	114,4	3,1	0	 	 	114,69	864	28,5	-17,6	ON
    	115,86	0,22	0,31	 	 	115,27	3,1	0	 	 	115,58	864	28,5	-16	ON
    	116,7	0,24	0,31	 	 	116,15	2,3	0	 	 	116,42	864	28,5	-13,3	ON
    	117,61	0,26	0,31	 	 	117	2,3	0	 	 	117,3	896	28,5	-10,5	ON
    	118,51	0,8	0,59	 	 	117,9	2,3	0	 	 	118,22	896	28,5	-8,6	ON
    	119,41	0,72	0,59	 	 	118,8	3,1	0	 	 	119,12	896	28,5	-11,3	ON
    	120,29	0,64	0,59	 	 	119,71	3,1	0	 	 	120	864	28,5	-14,1	ON
    	121,18	0,48	0,51	 	 	120,6	3,1	0	 	 	120,88	864	28,5	-16,8	ON
    	122,07	0,18	0,23	 	 	121,48	3,1	0	 	 	121,78	864	28,5	-18	ON
    	123,01	0,22	0,27	 	 	122,4	3,1	0	 	 	122,7	864	28,5	-14,8	ON
    	123,89	0,24	0,27	 	 	123,32	2,3	0	 	 	123,59	864	30	-12,1	ON
    	124,81	0,34	0,27	 	 	124,19	2,3	0	 	 	124,5	896	30	-9,4	ON
    	125,68	0,82	0,66	 	 	125,09	3,1	0	 	 	125,39	896	30	-8,6	ON
    	126,58	0,74	0,66	 	 	125,99	3,1	0	 	 	126,27	896	30	-11,3	ON
    	127,48	0,64	0,63	 	 	126,88	3,1	0	 	 	127,2	864	30	-14,1	ON
    	128,36	0,52	0,55	 	 	127,76	3,1	0	 	 	128,06	864	30	-16,8	ON
    	129,31	0,18	0,2	 	 	128,67	3,1	0	 	 	128,98	832	30	-18,8	ON
    	130,2	0,2	0,2	 	 	129,61	3,1	0	 	 	129,9	864	30	-15,6	ON
    	131,1	0,22	0,23	 	 	130,5	2,3	0	 	 	130,8	896	30	-13,3	ON
    	131,99	0,24	0,23	 	 	131,38	2,3	0	 	 	131,68	896	30	-10,5	ON
    	132,92	0,74	0,39	 	 	132,3	3,1	0	 	 	132,63	864	30	-7,4	ON
    	133,83	0,8	0,7	 	 	133,22	3,1	0	 	 	133,52	896	31,5	-9,8	ON
    	134,71	0,7	0,66	 	 	134,13	3,1	0	 	 	134,42	864	31,5	-12,5	ON
    	135,59	0,6	0,63	 	 	135,01	3,1	0	 	 	135,29	864	31,5	-15,2	ON
    	136,47	0,46	0,51	 	 	135,88	3,1	0	 	 	136,18	864	31,5	-18	ON
    	137,37	0,18	0,16	 	 	136,77	3,1	0	 	 	137,07	864	31,5	-17,2	ON
    	138,23	0,2	0,16	 	 	137,66	2,3	0	 	 	137,96	896	31,5	-14,5	ON
    	139,13	0,22	0,2	 	 	138,54	2,3	0	 	 	138,84	896	31,5	-11,7	ON
    	140,03	0,28	0,23	 	 	139,43	2,3	0	 	 	139,72	896	31,5	-9	ON
    	140,91	0,84	0,7	 	 	140,35	3,1	0	 	 	140,63	896	31,5	-8,2	ON
    	141,77	0,78	0,74	 	 	141,21	3,1	0	 	 	141,49	896	31,5	-10,9	ON
    	142,63	0,68	0,7	 	 	142,05	3,1	0	 	 	142,34	896	31,5	-13,3	ON
    	143,48	0,58	0,66	 	 	142,91	3,1	0	 	 	143,2	864	33	-16	ON
    	144,41	0,18	0,23	 	 	143,79	3,1	0	 	 	144,1	832	33	-18	ON
    	145,35	0,18	0,16	 	 	144,72	3,1	0	 	 	145,02	864	33	-15,2	ON
    	146,23	0,2	0,16	 	 	145,63	2,3	0	 	 	145,94	864	33	-12,5	ON
    	147,14	0,24	0,2	 	 	146,54	2,3	0	 	 	146,84	896	33	-9,8	ON
    	148,04	0,86	0,66	 	 	147,44	3,1	0	 	 	147,74	896	33	-8,2	ON
    	148,91	0,74	0,74	 	 	148,32	3,1	0	 	 	148,61	864	33	-10,9	ON
    	149,82	0,66	0,7	 	 	149,2	3,1	0	 	 	149,51	864	33	-13,7	ON
    	150,71	0,38	0,47	 	 	150,12	3,1	0	 	 	150,41	864	33	-16,4	ON
    	151,61	0,18	0,16	 	 	151,01	3,1	0	 	 	151,3	864	33	-14,8	ON
    	152,51	0,2	0,16	 	 	151,92	3,1	0	 	 	152,22	864	33	-12,1	ON
    	153,46	0,44	0,2	 	 	152,84	3,1	0	 	 	153,16	896	34,5	-9,4	ON
    	154,33	0,82	0,78	 	 	153,76	3,1	0	 	 	154,04	864	34,5	-9,4	ON
    	155,2	0,72	0,78	 	 	154,62	3,1	0	 	 	154,91	896	34,5	-12,1	ON
    	156,11	0,46	0,66	 	 	155,51	3,1	0	 	 	155,82	864	34,5	-14,8	ON
    	157,09	0,24	0,16	 	 	156,45	0	5,1	 	 	156,76	1184	34,5	-14,1	ON
    	158,03	0,76	0,7	 	 	157,4	0	5,1	 	 	157,71	1152	34,5	-14,8	ON
    	158,93	0,18	0,51	 	 	158,36	0	5,1	 	 	158,66	1024	34,5	-17,6	ON
    	159,89	0,18	0,12	 	 	159,26	0	5,1	 	 	159,56	1024	34,5	-16	ON
    	160,84	0,2	0,16	 	 	160,21	0	5,1	 	 	160,52	1216	34,5	-12,9	ON
    	161,75	0,22	0,16	 	 	161,16	0	5,1	 	 	161,45	1152	34,5	-10,2	ON
    	162,68	0,22	0,16	 	 	162,08	0	5,1	 	 	162,38	1152	34,5	-7,4	ON
    	163,62	0,32	0,2	 	 	163	0	5,1	 	 	163,31	1216	34,5	-4,7	ON
    	164,58	0,84	0,47	 	 	163,93	0	5,1	 	 	164,27	1216	34,5	-4,7	ON
    	165,48	0,4	0,59	 	 	164,89	0	5,1	 	 	165,18	1184	36	-7,4	ON
    	166,42	0,2	0,16	 	 	165,8	0	5,1	 	 	166,11	1184	36	-5,9	ON
    	167,37	0,36	0,2	 	 	166,74	0	5,1	 	 	167,06	1248	36	-2,7	ON
    	168,34	0,88	0,59	 	 	167,7	0	5,1	 	 	168,01	1248	36	-3,5	ON
    	169,26	0,62	0,74	 	 	168,65	0	5,1	 	 	168,95	1216	36	-7,8	ON
    	170,17	0,2	0,2	 	 	169,57	0	5,1	 	 	169,88	1216	36	-7	ON
    	171,12	0,22	0,16	 	 	170,48	0	5,1	 	 	170,81	1248	36	-3,9	ON
    	172,1	0,76	0,2	 	 	171,45	0	5,1	 	 	171,79	1280	36	0,4	ON
    	173,1	0,86	0,78	 	 	172,44	0	5,1	 	 	172,75	1280	36	-2,7	ON
    	174,05	0,48	0,78	 	 	173,44	0	5,1	 	 	173,74	1248	36	-7	ON
    	174,98	0,2	0,16	 	 	174,35	0	5,1	 	 	174,69	1216	36	-5,9	ON
    	175,94	0,22	0,16	 	 	175,31	0	5,1	 	 	175,63	1280	36	-2,3	ON
    	176,9	0,9	0,51	 	 	176,26	0	5,1	 	 	176,58	1312	36	-1,2	ON
    	177,83	0,72	0,82	 	 	177,2	0	5,1	 	 	177,51	1280	37,5	-5,5	ON
    	178,78	0,18	0,35	 	 	178,15	0	5,1	 	 	178,46	1216	37,5	-7	ON
    	179,75	0,2	0,16	 	 	179,1	0	5,1	 	 	179,42	1248	37,5	-3,5	ON
    	180,72	0,88	0,39	 	 	180,06	0	5,1	 	 	180,41	1280	37,5	-1,6	ON
    	181,67	0,54	0,78	 	 	181,03	0	5,1	 	 	181,34	1248	37,5	-6,3	ON
    	182,63	0,2	0,2	 	 	181,98	0	5,1	 	 	182,3	1248	37,5	-5,5	ON
    	183,61	0,62	0,16	 	 	182,94	0	5,1	 	 	183,26	1280	37,5	-0,8	ON
    	184,57	0,78	0,78	 	 	183,92	0	5,1	 	 	184,27	1280	37,5	-3,5	ON
    	185,49	0,22	0,7	 	 	184,85	0	5,1	 	 	185,18	1248	37,5	-7,8	ON
    	186,37	0,18	0,12	 	 	185,81	3,1	0	 	 	186,1	1088	37,5	-5,1	ON
    	187,26	0,2	0,12	 	 	186,65	3,1	0	 	 	186,96	896	37,5	-3,5	ON
    	188,16	0,2	0,16	 	 	187,56	3,1	0	 	 	187,85	896	39	-2,3	ON
    	189,05	0,66	0,2	 	 	188,46	3,1	0	 	 	188,75	896	39	-0,8	ON
    	189,99	0,92	0,86	 	 	189,37	3,1	0	 	 	189,68	896	39	-1,6	ON
    	190,87	0,84	0,82	 	 	190,28	3,1	0	 	 	190,58	864	39	-2,7	ON
    	191,74	0,78	0,82	 	 	191,19	3,1	0	 	 	191,46	864	39	-4,3	ON
    	192,63	0,72	0,82	 	 	192,03	3,1	0	 	 	192,33	864	39	-5,5	ON
    	193,55	0,66	0,78	 	 	192,92	3,1	0	 	 	193,24	864	39	-7	ON
    	194,42	0,58	0,7	 	 	193,84	3,1	0	 	 	194,14	864	39	-8,2	ON
    	195,31	0,56	0,66	 	 	194,71	3,1	0	 	 	195	864	39	-9,8	ON
    	196,18	0,44	0,43	 	 	195,6	3,1	0	 	 	195,9	864	39	-10,9	ON
    	197,08	0,22	0,2	 	 	196,49	3,1	0	 	 	196,76	864	39	-12,1	ON
    	197,95	0,14	0,12	 	 	197,38	3,1	0	 	 	197,66	864	39	-9,4	ON
    	198,83	0,64	0,16	 	 	198,25	3,1	0	 	 	198,54	864	39	-6,6	ON
    	199,72	0,72	0,74	 	 	199,13	3,1	0	 	 	199,42	864	39	-7,8	ON
    	200,62	0,66	0,74	 	 	200	3,1	0	 	 	200,31	864	39	-10,5	ON
    	201,5	0,6	0,7	 	 	200,91	3,1	0	 	 	201,21	864	39	-13,3	ON
    	202,39	0,1	0,16	 	 	201,78	3,1	0	 	 	202,09	864	40,5	-15,6	ON
    	203,28	0,14	0,08	 	 	202,69	3,1	0	 	 	202,98	864	40,5	-12,9	ON
    	204,17	0,18	0,12	 	 	203,59	3,1	0	 	 	203,88	896	40,5	-10,2	ON
    	205,06	0,48	0,16	 	 	204,46	3,1	0	 	 	204,76	864	40,5	-7,4	ON
    	205,93	0,84	0,66	 	 	205,36	3,1	0	 	 	205,64	896	40,5	-7,8	ON
    	206,82	0,74	0,78	 	 	206,23	3,1	0	 	 	206,52	864	40,5	-10,5	ON
    The OXS could indeed be contaminated or faulty!
    Logged B1S1 lambda voltage for Jack.
    I will get the car back on sunday for more testing. Thanks all for help that keeped this car going.
  11. Likes Uwe liked this post
