Results 1 to 10 of 17
Thread: Audi A4 B5 2000 1.6 MAF issues
    Nov 2017
    Latvia
    Hello, own this car for 5 years. This is 1.6 8v gasoline 74kW engine with DBW throttle body, FWD manual 5spd trans, equipped with SAI, variable intake manifold, no EGR that is found on similar B6 engines.
    Car is NOT iso/obd-2 compatible when opening Generic OBD2 mode. Stupid Simos ECU
    --- FOD status: ---
    Equipped with A6 C5 concert 2 radio and A6 C5 facelift clocks with new LCD screen from China. It has disconnected front passenger airbag for child safety in rare case with child seat in front (B5 can only retrofit passenger airbag OFF switch in glove box, VAG didn't equip B5 with it).
    BTW successful readiness for this engine 1010 0000 as written in Elsa.
    VIN: WAUZZZ8DZYA184xxx
    Address 01: Engine       Labels: User\06B-906-018-ALZ.lbl
    Control Module Part Number: 3B0 906 018 A
    Component and/or Version: 1,6l/2V SIMOS3 G00HS0009
    Software Coding: 08001
    Will try to cover a little background from last year...
    OEM MAF 1 day started to show 90g/s at idle. Car was drivable with disconnected MAF. So I found a 10eur used OEM MAF that showed about normal readings. Last summer inspected every vacuum line and valve I could find with mechanical vacuum pump as checking with mouth isn't enough. Verified fuel pressure with and without vacuum line from intake, that also holds within specs after engine is OFF. Catalyst could be "dead" as it can't really set Readiness.
    Later exchanged that used OEM MAF with new 50eur Delphi unit which I regret of buying.
    --- Shiny parts: ---
    5W-40 engine oil [insert model here], OEM oil filter, new Hengst E206L air filter (previously Mahle LX622), new Bosch N80, new OEM suction jet pump (that makes venture effect for brake booster), Bosch spark plugs [can't get exact part number from taken photo], new aftermarket crankcase ventilation tubing 3 ago as old OEM was shot and badly repaired by previous owner.
    New timing belt kit. New Bosch B1S1 lambda. Later bought another and fitted as B1S2.
    Now onto bad things:
    Engine is now acting like sh** so I checked it with VCDS. Car is daily driven but not by me.
    Sunday,19,May,2019,19:17:02:44445
    VCDS Version: 19.4.0.0 (x64)  HEX-V2 CB: 0.4504.4
    Data version: 20190411 DS307.0
                Work Shop Code: WSC 12345
                          VCID: 1E65DCFAA9AD0C27AD7-5160
    17931 - Crash Signal from Airbag Controller
                P1523 - 35-10 - Implausible Signal - Intermittent
    16556 - Fuel Trim; Bank 1
                P0172 - 35-00 - System Too Rich
    16518 - Oxygen (Lambda) Sensor B1 S1
                P0134 - 35-00 - No Activity
    16825 - EVAP Emission Control Sys
                P0441 - 35-10 - Incorrect Flow - Intermittent
    16514 - Oxygen (Lambda) Sensor B1 S1
                P0130 - 35-10 - Malfunction in Circuit - Intermittent
    17978 - Engine Start Blocked by Immobilizer
                P1570 - 35-10 -  - Intermittent
    Readiness: 1000 1001
    Readiness Status: 1000 1001
    Exhaust Gas Recirculation: Failed or Incomplete
    Oxygen Sensor Heating: Passed
    Oxygen Sensor(s): Passed
    Air Conditioning: Passed
    Secondary Air Injection: Failed or Incomplete
    Evaporative Emissions: Passed
    Catalyst Heating: Passed
    Catalytic Converter(s): Failed or Incomplete
    Address 01: DTCs cleared
    Address 01,3B0 906 018 A,channel 0,adapted from,---,to,000,
    Fuel trims @032 group are 0.0%. The same before clearing faults and adaptations.
    They must be way too off that Siemens doesn't save it.
    Stupid Siemens ECU.
    IMHO it can hold limited amount of faults. Right now this should show that engine is knocking.
    Can't tell how old these faults are, so I cleared them.
                    Address 01: Engine       Labels: USER\06B-906-018-ALZ.LBL
                          VCID: 1E65DCFAA9AD0C27AD7-5184
                P1523 - 35-00 - Implausible Signal
    16555 - Fuel Trim; Bank 1
                P0171 - 35-00 - System Too Lean
    16685 - Cylinder 1
                P0301 - 35-10 - Misfire Detected - Intermittent
    16687 - Cylinder 3
                P0303 - 35-10 - Misfire Detected - Intermittent
    16686 - Cylinder 2
                P0302 - 35-10 - Misfire Detected - Intermittent
                P0300 - 35-10 -  - Intermittent
    Readiness: 1010 1101
    Boom, here are the misfire faults. Previously these could only be seen when checking Measuring blocks.
                    Address 01: Engine  (3B0 906 018 A)
    19:41:29 Group 015: Ignition (Misfire Recognition Cylinder 1-3)
      11  Misfire Counter Cylinder 1
      3  Misfire Counter Cylinder 2
      3  Misfire Counter Cylinder 3
      Enabled  Misfire Recognition
    19:41:29 Group 016: Ignition (Misfire Recognition Cylinder 4)
      3  Misfire Counter Cylinder 4
    --- Log file below. ---
    Columns are misaligned with wrong spaces/tabs. Maybe screenshot could be better.
    When lambda status @099.4 turns from OFF to ON, Lambda control @099.3 jumps up to max 27.7%, stays here a bit and resets to 0.0% and lambda status turns OFF. MAF reading looks "a bit" too much. Don't have a reference point. Elsa says it must be 2-5g/s at idle if I remember correct but that's enormous interval.
    Couple times restarted engine while logging for lambda status "restart".
    	Group A:	'032				Group B:	'099				Group C:	'002
    		Adaptation (Idle)	Adaptation (Partial)	 	 		Engine Speed	Coolant	Lambda Control	Lambda Control		Engine Speed	Engine Load	Injection Timing	Mass Air Flow
    	TIME	Bank 1 Sensor 1	Bank 1 Sensor 1			TIME	(G28)	Temperature (G62)		Status	TIME	(G28)			Sensor (G70)
    Marker	STAMP	 %	 %			STAMP	 /min	C	 %		STAMP	 /min	 %	 ms	 g/s
    	0.60	0.0	0.0	 	 	0.01	0	73.5	0.0	OFF	0.29	0	0.0	0.00	0.00
    	1.53	0.0	0.0	 	 	0.91	0	73.5	0.0	OFF	1.22	0	0.0	0.00	0.00
    	11.22	0.0	0.0	 	 	11.56	832	73.5	0.0	OFF	10.87	864	28.6	3.09	3.61
    	12.19	0.0	0.0	 	 	12.52	832	73.5	0.0	OFF	11.87	832	28.6	3.09	3.63
    	13.20	0.0	0.0	 	 	13.53	832	73.5	0.0	OFF	12.86	832	29.8	3.09	3.94
    	14.21	0.0	0.0	 	 	14.55	800	72.0	0.0	OFF	13.88	864	29.8	3.09	4.14
    	15.20	0.0	0.0	 	 	15.55	864	72.0	0.0	OFF	14.87	832	31.8	4.12	4.24
    	16.23	0.0	0.0	 	 	16.57	864	72.0	0.0	OFF	15.89	864	31.8	3.09	4.36
    	17.23	0.0	0.0	 	 	17.57	864	72.0	0.0	OFF	16.89	864	31.0	3.09	4.16
    	18.26	0.0	0.0	 	 	18.60	864	72.0	0.0	OFF	17.91	864	29.8	3.09	3.98
    	19.27	0.0	0.0	 	 	19.62	832	72.0	0.0	OFF	18.94	864	29.8	3.09	3.97
    	20.30	0.0	0.0	 	 	20.64	864	72.0	0.0	OFF	19.97	832	31.0	3.09	4.16
    	21.31	0.0	0.0	 	 	21.64	832	72.0	0.0	OFF	20.97	832	31.0	3.09	4.22
    	22.31	0.0	0.0	 	 	22.65	896	72.0	0.0	OFF	21.97	832	31.8	3.09	4.34
    	23.34	0.0	0.0	 	 	23.68	832	72.0	0.0	OFF	22.99	864	31.0	3.09	4.34
    	24.35	0.0	0.0	 	 	24.69	832	72.0	0.0	OFF	24.01	864	31.0	3.09	4.32
    	25.38	0.0	0.0	 	 	25.73	832	72.0	0.0	OFF	25.03	864	31.0	3.09	4.28
    	26.40	0.0	0.0	 	 	26.75	832	72.0	0.0	OFF	26.06	832	29.8	3.09	4.28
    	27.44	0.0	0.0	 	 	27.77	864	72.0	0.0	OFF	27.10	832	31.0	3.09	4.32
    	28.44	0.0	0.0	 	 	28.79	832	72.0	0.0	OFF	28.11	832	31.0	3.09	4.32
    	29.47	0.0	0.0	 	 	29.81	864	72.0	0.0	OFF	29.13	864	31.0	3.09	4.26
    	30.48	0.0	0.0	 	 	30.82	864	72.0	0.0	OFF	30.14	864	31.0	3.09	4.34
    	31.49	0.0	0.0	 	 	31.84	864	72.0	0.0	OFF	31.16	864	31.0	3.09	4.43
    	32.52	0.0	0.0	 	 	32.86	864	72.0	0.0	OFF	32.19	864	31.0	3.09	4.49
    	33.54	0.0	0.0	 	 	33.88	864	72.0	0.0	OFF	33.20	864	31.0	3.09	4.38
    	34.57	0.0	0.0	 	 	34.90	864	72.0	0.0	OFF	34.23	864	31.0	3.09	4.25
    	35.57	0.0	0.0	 	 	35.91	864	72.0	0.0	OFF	35.25	864	31.0	3.09	4.43
    	36.58	0.0	0.0	 	 	36.93	864	72.0	0.0	OFF	36.24	864	31.0	3.09	4.42
    	37.61	0.0	0.0	 	 	37.94	864	72.0	0.0	OFF	37.26	864	31.0	3.09	4.37
    	38.62	0.0	0.0	 	 	38.96	864	72.0	0.0	OFF	38.27	832	31.8	3.09	4.42
    	39.65	0.0	0.0	 	 	39.99	864	72.0	0.0	OFF	39.29	864	31.8	3.09	4.43
    	40.66	0.0	0.0	 	 	40.99	864	72.0	0.0	OFF	40.32	864	31.0	3.09	4.24
    	41.68	0.0	0.0	 	 	42.01	864	72.0	0.0	OFF	41.33	832	31.0	3.09	4.33
    	42.70	0.0	0.0	 	 	43.04	832	72.0	0.0	ON	42.35	864	31.0	3.09	4.40
    	43.71	0.0	0.0	 	 	44.04	864	72.0	-0.4	ON	43.37	832	31.0	3.09	4.16
    	44.71	0.0	0.0	 	 	45.06	832	72.0	0.0	ON	44.38	832	29.8	3.09	4.26
    	45.73	0.0	0.0	 	 	46.06	832	72.0	0.0	ON	45.40	864	29.8	3.09	4.11
    	46.74	0.0	0.0	 	 	47.09	832	72.0	0.0	ON	46.40	832	29.8	3.09	4.27
    	47.79	0.0	0.0	 	 	48.13	864	72.0	0.0	ON	47.43	864	29.8	3.09	4.14
    	48.80	0.0	0.0	 	 	49.12	864	72.0	-0.4	ON	48.46	864	29.8	3.09	4.22
    	49.81	0.0	0.0	 	 	50.14	864	72.0	0.0	ON	49.47	832	29.8	3.09	4.29
    	50.80	0.0	0.0	 	 	51.13	864	72.0	0.0	ON	50.46	832	29.8	3.09	4.01
    	51.80	0.0	0.0	 	 	52.14	864	73.5	0.0	ON	51.46	832	29.8	3.09	4.13
    	52.83	0.0	0.0	 	 	53.18	864	73.5	0.0	ON	52.49	864	29.8	3.09	4.17
    	53.88	0.0	0.0	 	 	54.22	864	73.5	0.0	ON	53.53	864	29.8	3.09	4.14
    	54.90	0.0	0.0	 	 	55.25	832	73.5	0.0	ON	54.57	864	29.8	3.09	4.12
    	55.94	0.0	0.0	 	 	56.27	832	73.5	0.0	ON	55.58	864	29.8	3.09	3.83
    	56.97	0.0	0.0	 	 	57.31	832	73.5	0.0	ON	56.62	864	29.8	3.09	4.16
    	57.99	0.0	0.0	 	 	58.34	864	73.5	0.0	ON	57.65	832	29.8	3.09	4.05
    	59.02	0.0	0.0	 	 	59.36	864	73.5	0.0	ON	58.67	832	29.8	3.09	4.19
    	60.06	0.0	0.0	 	 	60.39	864	73.5	0.0	ON	59.71	832	29.8	3.09	4.03
    	61.06	0.0	0.0	 	 	61.41	864	73.5	0.0	ON	60.73	832	29.8	3.09	4.23
    	62.10	0.0	0.0	 	 	62.45	864	73.5	0.0	ON	61.76	864	29.8	3.09	4.22
    	63.13	0.0	0.0	 	 	63.48	864	73.5	0.0	ON	62.78	864	29.8	3.09	4.07
    	64.16	0.0	0.0	 	 	64.50	864	73.5	0.0	ON	63.81	832	29.8	3.09	4.03
    	65.16	0.0	0.0	 	 	65.52	864	73.5	0.0	ON	64.83	864	29.8	3.09	4.44
    	66.20	0.0	0.0	 	 	66.54	864	73.5	0.0	ON	65.86	896	29.8	3.09	4.27
    	67.21	0.0	0.0	 	 	67.56	832	73.5	0.0	ON	66.88	864	29.8	3.09	4.25
    	68.24	0.0	0.0	 	 	68.59	832	73.5	0.0	ON	67.89	864	29.8	3.09	4.22
    	69.27	0.0	0.0	 	 	69.61	864	73.5	0.0	ON	68.92	832	31.0	3.09	4.18
    	70.27	0.0	0.0	 	 	70.60	864	73.5	0.0	ON	69.93	864	29.8	3.09	4.20
    	71.29	0.0	0.0	 	 	71.64	864	73.5	0.0	ON	70.94	864	29.8	3.09	4.06
    	72.31	0.0	0.0	 	 	72.64	832	73.5	0.0	ON	71.97	832	29.8	3.09	4.29
    	73.30	0.0	0.0	 	 	73.65	864	73.5	0.0	ON	72.97	832	28.6	3.09	4.22
    	74.31	0.0	0.0	 	 	74.66	864	75.0	0.0	ON	73.97	864	29.8	3.09	4.21
    	75.33	0.0	0.0	 	 	75.66	832	75.0	0.0	ON	74.99	864	29.8	3.09	4.24
    	76.34	0.0	0.0	 	 	76.68	864	75.0	0.0	ON	75.99	864	29.8	3.09	4.06
    	77.38	0.0	0.0	 	 	77.71	864	75.0	0.0	ON	77.03	864	28.6	3.09	3.97
    	78.39	0.0	0.0	 	 	78.71	864	75.0	0.0	ON	78.04	832	29.8	3.09	4.21
    	79.39	0.0	0.0	 	 	79.72	864	75.0	0.0	ON	79.04	864	28.6	3.09	4.13
    	80.41	0.0	0.0	 	 	80.76	864	75.0	0.0	ON	80.06	864	28.6	3.09	3.97
    	81.44	0.0	0.0	 	 	81.78	864	75.0	0.0	ON	81.09	832	29.8	3.09	4.08
    	82.47	0.0	0.0	 	 	82.81	864	75.0	0.0	ON	82.13	864	29.8	3.09	4.17
    	83.50	0.0	0.0	 	 	83.85	864	75.0	0.0	ON	83.15	864	28.6	3.09	4.16
    	84.54	0.0	0.0	 	 	84.90	864	75.0	0.0	ON	84.19	896	28.6	3.09	3.89
    	85.59	0.0	0.0	 	 	85.92	864	75.0	0.0	ON	85.24	864	28.6	3.09	4.17
    	86.60	0.0	0.0	 	 	86.94	864	75.0	0.0	ON	86.25	864	28.6	3.09	4.06
    	87.59	0.0	0.0	 	 	87.94	832	75.0	0.0	ON	87.27	832	28.6	3.09	4.01
    	88.63	0.0	0.0	 	 	88.96	832	75.0	0.0	ON	88.29	864	28.6	3.09	4.00
    	89.64	0.0	0.0	 	 	89.97	864	75.0	0.0	ON	89.31	832	28.6	3.09	4.11
    	90.66	0.0	0.0	 	 	91.01	832	75.0	0.0	ON	90.32	864	28.6	3.09	3.98
    	91.68	0.0	0.0	 	 	92.02	832	75.0	0.0	ON	91.35	864	28.6	3.09	4.03
    	92.70	0.0	0.0	 	 	93.04	832	75.0	0.0	ON	92.36	864	28.6	3.09	4.04
    	93.74	0.0	0.0	 	 	94.07	864	76.5	0.0	ON	93.39	864	28.6	3.09	4.03
    	94.74	0.0	0.0	 	 	95.08	864	76.5	0.0	ON	94.40	864	28.6	3.09	3.94
    	95.78	0.0	0.0	 	 	96.11	832	76.5	0.0	ON	95.43	864	27.5	3.09	3.85
    	96.80	0.0	0.0	 	 	97.13	864	76.5	0.0	ON	96.46	832	27.5	3.09	3.78
    	97.80	0.0	0.0	 	 	98.14	864	76.5	0.0	ON	97.47	864	27.5	3.09	3.80
    	98.83	0.0	0.0	 	 	99.18	864	76.5	0.0	ON	98.48	832	26.3	3.09	3.73
    	99.87	0.0	0.0	 	 	100.21	864	76.5	0.0	ON	99.52	864	26.3	3.09	3.63
    	100.89	0.0	0.0	 	 	101.24	832	76.5	0.0	ON	100.56	832	26.3	3.09	3.51
    	101.92	0.0	0.0	 	 	102.27	896	76.5	0.0	ON	101.58	864	26.3	3.09	3.43
    	102.94	0.0	0.0	 	 	103.29	832	76.5	0.0	ON	102.61	864	23.9	3.09	3.32
    	103.99	0.0	0.0	 	 	104.34	864	76.5	0.0	ON	103.64	832	23.9	3.09	3.18
    	105.04	0.0	0.0	 	 	105.37	832	76.5	0.0	ON	104.69	832	23.9	3.09	3.39
    	106.04	0.0	0.0	 	 	106.37	832	76.5	0.0	ON	105.71	832	25.1	3.09	3.39
    	107.04	0.0	0.0	 	 	107.38	864	76.5	0.0	ON	106.71	864	25.1	3.09	3.42
    	108.05	0.0	0.0	 	 	108.38	832	76.5	0.0	ON	107.72	864	25.1	3.09	3.61
    	109.03	0.0	0.0	 	 	109.37	864	76.5	0.0	ON	108.70	832	26.3	3.09	3.52
    	110.05	0.0	0.0	 	 	110.39	864	76.5	0.0	ON	109.71	832	26.3	3.09	3.55
    	111.05	0.0	0.0	 	 	111.38	832	76.5	0.0	ON	110.72	832	26.3	3.09	3.51
    	112.08	0.0	0.0	 	 	112.42	832	76.5	0.0	ON	111.73	864	26.3	3.09	3.62
    	113.10	0.0	0.0	 	 	113.43	864	76.5	0.0	ON	112.76	832	26.3	3.09	3.67
    	114.11	0.0	0.0	 	 	114.44	864	76.5	0.0	ON	113.77	832	26.3	3.09	3.71
    	115.10	0.0	0.0	 	 	115.43	832	76.5	0.0	ON	114.77	832	26.3	3.09	3.67
    	116.09	0.0	0.0	 	 	116.41	864	76.5	0.0	ON	115.76	832	26.3	3.09	3.75
    	117.10	0.0	0.0	 	 	117.43	832	78.0	0.0	ON	116.77	864	26.3	3.09	3.61
    	118.12	0.0	0.0	 	 	118.46	864	78.0	0.0	ON	117.77	832	27.5	3.09	3.89
    	119.14	0.0	0.0	 	 	119.47	832	78.0	0.0	ON	118.80	864	27.5	3.09	3.77
    	120.14	0.0	0.0	 	 	120.49	832	78.0	0.0	ON	119.81	864	27.5	3.09	3.83
    	121.16	0.0	0.0	 	 	121.50	864	78.0	0.0	ON	120.82	864	27.5	3.09	3.81
    	122.17	0.0	0.0	 	 	122.51	864	78.0	0.0	ON	121.84	832	27.5	3.09	3.85
    	123.19	0.0	0.0	 	 	123.54	864	78.0	0.0	ON	122.86	832	27.5	3.09	3.79
    	124.20	0.0	0.0	 	 	124.55	864	78.0	0.0	ON	123.86	864	26.3	3.09	3.74
    	125.20	0.0	0.0	 	 	125.55	864	78.0	0.0	ON	124.87	864	26.3	3.09	3.83
    	126.24	0.0	0.0	 	 	126.60	864	78.0	0.0	ON	125.90	832	26.3	3.09	3.85
    	127.28	0.0	0.0	 	 	127.62	832	78.0	0.0	ON	126.94	864	26.3	3.09	3.71
    	128.29	0.0	0.0	 	 	128.63	864	78.0	0.0	ON	127.95	832	27.5	3.09	4.03
    	129.30	0.0	0.0	 	 	129.63	864	78.0	0.0	ON	128.97	832	27.5	3.09	3.97
    	130.27	0.0	0.0	 	 	130.59	544	78.0	0.0	OFF	129.96	864	27.5	3.09	3.86
    	140.68	0.0	0.0	 	 	140.07	0	78.0	0.0	OFF	140.38	0	0.0	2.06	0.00
    	141.61	0.0	0.0	 	 	140.99	0	78.0	0.0	OFF	141.30	0	0.0	2.06	0.00
    	142.54	0.0	0.0	 	 	141.93	0	78.0	0.0	OFF	142.23	0	0.0	2.06	0.00
    	143.48	0.0	0.0	 	 	142.86	0	78.0	0.0	OFF	143.17	0	0.0	2.06	0.00
    	144.41	0.0	0.0	 	 	143.79	0	78.0	0.0	OFF	144.09	0	0.0	2.06	0.00
    	145.36	0.0	0.0	 	 	144.72	0	78.0	0.0	OFF	145.04	160	61.6	11.33	2.82
    	146.44	0.0	0.0	 	 	145.74	1344	78.0	0.0	OFF	146.10	1248	25.1	3.09	3.78
    	147.45	0.0	0.0	 	 	146.78	864	78.0	0.0	OFF	147.12	864	28.6	3.09	4.28
    	148.48	0.0	0.0	 	 	147.81	896	78.0	0.0	OFF	148.14	896	27.5	3.09	3.97
    	149.50	0.0	0.0	 	 	148.82	896	78.0	0.0	OFF	149.15	896	23.9	3.09	3.41
    	150.53	0.0	0.0	 	 	149.83	896	78.0	0.0	OFF	150.19	864	22.7	3.09	3.13
    	151.52	0.0	0.0	 	 	150.85	832	79.5	0.0	OFF	151.17	832	22.7	3.09	2.81
    	152.52	0.0	0.0	 	 	151.84	832	78.0	0.0	OFF	152.17	832	22.7	3.09	3.06
    	153.52	0.0	0.0	 	 	152.84	800	78.0	0.0	OFF	153.19	832	22.7	3.09	3.00
    	154.50	0.0	0.0	 	 	153.84	864	79.5	0.0	OFF	154.17	864	22.7	2.06	2.89
    	155.51	0.0	0.0	 	 	154.85	832	79.5	0.0	OFF	155.18	832	22.7	2.06	3.11
    	156.55	0.0	0.0	 	 	155.85	832	79.5	0.0	OFF	156.20	832	23.9	3.09	3.34
    	157.57	0.0	0.0	 	 	156.90	832	79.5	0.0	OFF	157.24	832	23.9	3.09	3.16
    	158.59	0.0	0.0	 	 	157.91	864	79.5	0.0	OFF	158.26	832	23.9	3.09	3.38
    	159.61	0.0	0.0	 	 	158.94	832	79.5	0.0	OFF	159.28	832	23.9	3.09	3.37
    	160.62	0.0	0.0	 	 	159.95	832	79.5	0.0	OFF	160.29	864	25.1	3.09	3.66
    	161.62	0.0	0.0	 	 	160.95	864	79.5	0.0	OFF	161.27	864	25.1	3.09	3.19
    	162.67	0.0	0.0	 	 	161.98	832	79.5	0.0	OFF	162.32	864	25.1	3.09	3.39
    	163.69	0.0	0.0	 	 	163.00	864	79.5	0.0	OFF	163.34	832	25.1	3.09	3.58
    	164.67	0.0	0.0	 	 	164.01	832	79.5	0.0	OFF	164.32	832	25.1	3.09	3.47
    	165.66	0.0	0.0	 	 	165.00	864	79.5	0.0	OFF	165.33	832	25.1	3.09	3.31
    	166.66	0.0	0.0	 	 	165.99	832	79.5	0.0	OFF	166.31	832	25.1	3.09	3.60
    	167.68	0.0	0.0	 	 	167.01	832	79.5	0.0	OFF	167.32	832	25.1	3.09	3.62
    	168.70	0.0	0.0	 	 	168.00	864	79.5	0.0	OFF	168.34	864	25.1	3.09	3.57
    	169.72	0.0	0.0	 	 	169.04	832	79.5	0.0	OFF	169.39	832	26.3	3.09	3.56
    	170.71	0.0	0.0	 	 	170.03	864	79.5	0.0	OFF	170.36	864	25.1	3.09	3.51
    	171.72	0.0	0.0	 	 	171.04	864	79.5	0.0	OFF	171.37	832	25.1	3.09	3.54
    	172.73	0.0	0.0	 	 	172.05	864	79.5	0.0	OFF	172.39	832	26.3	3.09	3.47
    	173.75	0.0	0.0	 	 	173.06	832	79.5	0.0	OFF	173.42	832	25.1	3.09	3.71
    	174.78	0.0	0.0	 	 	174.08	864	79.5	0.0	OFF	174.43	864	25.1	3.09	3.52
    	175.76	0.0	0.0	 	 	175.08	832	79.5	0.0	OFF	175.42	832	25.1	3.09	3.45
    	176.80	0.0	0.0	 	 	176.11	832	79.5	0.0	OFF	176.46	864	23.9	3.09	3.41
    	177.83	0.0	0.0	 	 	177.14	832	79.5	0.0	OFF	177.49	832	23.9	3.09	3.43
    	178.84	0.0	0.0	 	 	178.17	864	79.5	0.0	OFF	178.51	864	25.1	3.09	3.51
    	179.85	0.0	0.0	 	 	179.18	832	79.5	0.0	OFF	179.52	832	25.1	3.09	3.43
    	180.88	0.0	0.0	 	 	180.20	864	79.5	0.0	OFF	180.56	832	23.9	3.09	3.51
    	181.87	0.0	0.0	 	 	181.21	864	79.5	0.0	OFF	181.54	864	25.1	3.09	3.63
    	182.87	0.0	0.0	 	 	182.22	832	79.5	0.0	OFF	182.55	864	25.1	3.09	3.49
    	183.88	0.0	0.0	 	 	183.20	832	81.0	0.0	OFF	183.55	864	25.1	3.09	3.42
    	184.87	0.0	0.0	 	 	184.22	864	81.0	0.8	ON	184.55	864	25.1	3.09	3.53
    	185.90	0.0	0.0	 	 	185.22	864	81.0	3.9	ON	185.56	896	23.9	3.09	3.39
    	186.94	0.0	0.0	 	 	186.25	896	81.0	7.0	ON	186.61	864	22.7	3.09	3.18
    	187.96	0.0	0.0	 	 	187.28	896	81.0	10.2	ON	187.62	864	20.4	2.06	3.07
    	188.95	0.0	0.0	 	 	188.28	864	81.0	13.3	ON	188.61	864	19.2	2.06	2.82
    	189.96	0.0	0.0	 	 	189.27	864	81.0	16.4	ON	189.61	864	19.2	2.06	2.66
    	190.95	0.0	0.0	 	 	190.27	864	81.0	19.5	ON	190.62	864	18.4	2.06	2.09
    	191.94	0.0	0.0	 	 	191.27	864	81.0	22.7	ON	191.61	864	17.3	2.06	2.11
    	192.95	0.0	0.0	 	 	192.27	864	81.0	25.4	ON	192.62	832	16.1	2.06	1.96
    	193.97	0.0	0.0	 	 	193.29	832	81.0	27.7	ON	193.64	864	16.1	2.06	2.12
    	194.95	0.0	0.0	 	 	194.29	864	81.0	27.7	ON	194.62	864	16.1	2.06	2.10
    	195.98	0.0	0.0	 	 	195.30	864	81.0	27.7	ON	195.65	832	16.1	2.06	2.21
    	196.96	0.0	0.0	 	 	196.30	864	81.0	27.7	ON	196.63	832	16.1	2.06	2.01
    	197.97	0.0	0.0	 	 	197.29	832	81.0	27.7	ON	197.63	832	16.1	2.06	2.23
    	198.96	0.0	0.0	 	 	198.30	864	81.0	27.7	ON	198.61	832	16.1	2.06	2.11
    	199.96	0.0	0.0	 	 	199.30	832	81.0	27.7	ON	199.64	832	16.1	2.06	2.32
    	200.99	0.0	0.0	 	 	200.31	832	81.0	27.7	ON	200.67	832	16.1	2.06	2.26
    	202.00	0.0	0.0	 	 	201.34	864	81.0	27.7	ON	201.69	864	16.1	2.06	2.27
    	203.03	0.0	0.0	 	 	202.33	832	81.0	27.7	ON	202.68	832	16.1	2.06	2.21
    	204.05	0.0	0.0	 	 	203.38	832	81.0	27.7	ON	203.72	864	16.1	2.06	2.26
    	205.07	0.0	0.0	 	 	204.40	864	81.0	27.7	ON	204.75	832	16.1	2.06	2.44
    	206.06	0.0	0.0	 	 	205.39	864	81.0	27.7	ON	205.72	864	16.1	2.06	2.24
    	207.06	0.0	0.0	 	 	206.39	832	81.0	27.7	ON	206.73	832	16.1	2.06	2.32
    	208.07	0.0	0.0	 	 	207.40	832	81.0	27.7	ON	207.74	832	16.1	2.06	2.49
    	209.06	0.0	0.0	 	 	208.41	832	81.0	27.7	ON	208.73	832	17.3	2.06	2.52
    	210.07	0.0	0.0	 	 	209.41	864	81.0	27.7	ON	209.74	832	17.3	2.06	2.53
    	211.08	0.0	0.0	 	 	210.39	832	81.0	27.7	ON	210.74	832	17.3	2.06	2.54
    	212.10	0.0	0.0	 	 	211.44	864	82.5	27.7	ON	211.78	864	17.3	2.06	2.46
    	213.09	0.0	0.0	 	 	212.43	832	82.5	27.7	ON	212.76	832	17.3	2.06	2.60
    	214.12	0.0	0.0	 	 	213.42	864	82.5	27.7	ON	213.77	832	17.3	2.06	2.52
    	215.13	0.0	0.0	 	 	214.48	864	82.5	27.7	ON	214.80	864	17.3	2.06	2.37
    	216.15	0.0	0.0	 	 	215.46	832	82.5	27.7	ON	215.80	864	17.3	2.06	2.24
    	217.17	0.0	0.0	 	 	216.49	832	82.5	27.7	ON	216.82	864	17.3	2.06	2.38
    	218.19	0.0	0.0	 	 	217.53	832	82.5	27.7	ON	217.86	832	17.3	2.06	2.59
    	219.20	0.0	0.0	 	 	218.54	832	82.5	27.7	ON	218.86	832	17.3	2.06	2.59
    	220.23	0.0	0.0	 	 	219.56	832	82.5	0.0	OFF	219.89	864	25.1	3.09	3.36
    	221.23	0.0	0.0	 	 	220.57	800	82.5	0.0	OFF	220.90	864	26.3	3.09	3.94
    	222.22	0.0	0.0	 	 	221.55	832	82.5	0.0	OFF	221.88	832	27.5	3.09	4.04
    	223.23	0.0	0.0	 	 	222.56	864	82.5	0.0	OFF	222.89	864	27.5	3.09	3.97
    	224.27	0.0	0.0	 	 	223.58	864	82.5	0.0	OFF	223.92	864	27.5	3.09	3.91
    	225.28	0.0	0.0	 	 	224.62	864	82.5	0.0	OFF	224.95	864	26.3	3.09	3.94
    	226.30	0.0	0.0	 	 	225.63	864	82.5	0.0	OFF	225.96	864	26.3	3.09	3.83
    	227.30	0.0	0.0	 	 	226.63	864	82.5	0.0	OFF	226.98	864	26.3	3.09	3.80
    	228.33	0.0	0.0	 	 	227.65	864	82.5	0.0	OFF	227.99	864	25.1	3.09	3.69
    	229.37	0.0	0.0	 	 	228.68	864	82.5	0.0	OFF	229.04	864	25.1	3.09	3.51
    	230.41	0.0	0.0	 	 	229.73	864	82.5	0.0	OFF	230.07	864	23.9	3.09	3.48
    	231.42	0.0	0.0	 	 	230.74	864	82.5	0.0	OFF	231.09	864	25.1	3.09	3.46
    	232.45	0.0	0.0	 	 	231.77	832	82.5	0.0	OFF	232.12	864	23.9	3.09	3.44
    	233.43	0.0	0.0	 	 	232.79	832	82.5	0.0	OFF	233.11	832	25.1	3.09	3.49
    	234.44	0.0	0.0	 	 	233.76	832	82.5	0.0	OFF	234.09	864	23.9	3.09	3.49
    	235.44	0.0	0.0	 	 	234.77	864	82.5	0.0	OFF	235.10	864	23.9	3.09	3.47
    	236.46	0.0	0.0	 	 	235.78	864	82.5	0.0	OFF	236.12	864	23.9	3.09	3.34
    	237.52	0.0	0.0	 	 	236.82	832	82.5	0.0	OFF	237.17	864	23.9	3.09	3.43
    	238.54	0.0	0.0	 	 	237.87	832	82.5	0.0	OFF	238.22	864	23.9	3.09	3.37
    	239.57	0.0	0.0	 	 	238.87	832	82.5	0.0	OFF	239.22	864	23.9	3.09	3.43
    	240.59	0.0	0.0	 	 	239.91	832	82.5	0.0	OFF	240.25	832	25.1	3.09	3.61
    	241.60	0.0	0.0	 	 	240.92	864	82.5	0.0	OFF	241.26	832	25.1	3.09	3.68
    	242.61	0.0	0.0	 	 	241.93	832	82.5	0.0	OFF	242.28	832	23.9	3.09	3.53
    	243.62	0.0	0.0	 	 	242.96	864	82.5	0.0	OFF	243.29	864	23.9	3.09	3.37
    	244.65	0.0	0.0	 	 	243.96	832	82.5	0.0	OFF	244.30	832	23.9	3.09	3.51
    	245.70	0.0	0.0	 	 	245.00	832	82.5	0.0	OFF	245.35	864	23.9	3.09	3.63
    	246.73	0.0	0.0	 	 	246.04	832	82.5	0.0	OFF	246.38	864	25.1	3.09	3.57
    	247.75	0.0	0.0	 	 	247.06	864	82.5	0.0	OFF	247.40	832	25.1	3.09	3.54
    	248.73	0.0	0.0	 	 	248.08	864	82.5	0.0	OFF	248.40	864	25.1	3.09	3.47
    	249.76	0.0	0.0	 	 	249.08	864	82.5	0.0	OFF	249.43	864	23.9	3.09	3.53
    	250.77	0.0	0.0	 	 	250.10	864	82.5	0.0	OFF	250.44	832	23.9	3.09	3.59
    	251.80	0.0	0.0	 	 	251.10	832	82.5	0.0	OFF	251.45	832	23.9	3.09	3.36
    	252.81	0.0	0.0	 	 	252.13	864	82.5	0.0	OFF	252.47	864	23.9	3.09	3.43
    	253.84	0.0	0.0	 	 	253.16	864	84.0	0.0	OFF	253.49	832	23.9	3.09	3.48
    	254.85	0.0	0.0	 	 	254.17	864	84.0	0.0	OFF	254.50	864	23.9	3.09	3.42
    	255.85	0.0	0.0	 	 	255.18	864	84.0	0.0	OFF	255.52	864	23.9	3.09	3.38
    	256.79	0.0	0.0	 	 	256.17	832	84.0	0.0	OFF	256.48	608	20.4	2.06	0.00
    	266.17	0.0	0.0	 	 	266.48	0	84.0	0.0	OFF	266.79	0	0.0	2.06	0.00
    	267.10	0.0	0.0	 	 	267.41	0	84.0	0.0	OFF	267.72	0	0.0	2.06	0.00
    	268.03	0.0	0.0	 	 	268.34	0	84.0	0.0	OFF	268.65	0	0.0	2.06	0.00
    	268.96	0.0	0.0	 	 	269.27	0	84.0	0.0	OFF	269.59	0	0.0	2.06	0.00
    	269.91	0.0	0.0	 	 	270.27	1216	84.0	0.0	OFF	270.62	1312	27.5	4.12	3.62
    	270.94	0.0	0.0	 	 	271.27	896	84.0	0.0	OFF	271.62	864	26.3	3.09	4.31
    	271.96	0.0	0.0	 	 	272.31	896	84.0	0.0	OFF	272.67	896	27.5	3.09	4.08
    	273.01	0.0	0.0	 	 	273.35	928	84.0	0.0	OFF	273.68	896	23.9	3.09	3.29
    	274.02	0.0	0.0	 	 	274.35	864	84.0	0.0	OFF	274.70	864	22.7	3.09	3.15
    	275.05	0.0	0.0	 	 	275.39	864	84.0	0.0	OFF	275.73	864	21.6	2.06	2.92
    	276.07	0.0	0.0	 	 	276.40	832	84.0	0.0	OFF	276.74	832	21.6	2.06	2.76
    	277.09	0.0	0.0	 	 	277.43	832	84.0	0.0	OFF	277.76	832	20.4	2.06	2.58
    	278.10	0.0	0.0	 	 	278.43	832	84.0	0.0	OFF	278.77	832	20.4	2.06	2.71
    	279.10	0.0	0.0	 	 	279.44	832	84.0	0.0	OFF	279.77	832	22.7	2.06	2.95
    	280.10	0.0	0.0	 	 	280.44	864	84.0	0.0	OFF	280.79	832	22.7	2.06	2.92
    	281.13	0.0	0.0	 	 	281.48	800	84.0	0.0	OFF	281.82	864	23.9	3.09	3.09
    	282.17	0.0	0.0	 	 	282.51	864	84.0	0.0	OFF	282.85	832	22.7	2.06	3.27
    	283.18	0.0	0.0	 	 	283.53	832	84.0	0.0	OFF	283.87	832	22.7	2.06	3.26
    	284.21	0.0	0.0	 	 	284.55	832	84.0	0.0	OFF	284.90	832	23.9	3.09	3.14
    	285.23	0.0	0.0	 	 	285.58	832	84.0	0.0	OFF	285.92	832	23.9	3.09	3.33
    	286.24	0.0	0.0	 	 	286.60	832	84.0	0.0	OFF	286.92	864	23.9	3.09	3.33
    	287.27	0.0	0.0	 	 	287.60	864	84.0	0.0	OFF	287.93	864	23.9	3.09	3.41
    	288.27	0.0	0.0	 	 	288.59	832	84.0	0.0	OFF	288.90	832	23.9	3.09	3.29
    	289.25	0.0	0.0	 	 	289.59	832	84.0	0.0	OFF	289.94	864	23.9	3.09	3.35
    	290.29	0.0	0.0	 	 	290.64	832	84.0	0.0	OFF	290.97	832	23.9	3.09	3.27
    	291.30	0.0	0.0	 	 	291.63	832	84.0	0.0	ON	291.97	864	23.9	3.09	3.37
    	292.30	0.0	0.0	 	 	292.65	864	84.0	0.0	ON	292.98	864	23.9	3.09	3.38
    	293.33	0.0	0.0	 	 	293.67	864	84.0	0.0	ON	294.00	864	23.9	3.09	3.41
    	294.33	0.0	0.0	 	 	294.66	832	84.0	0.0	ON	294.99	864	23.9	3.09	3.37
    	295.32	0.0	0.0	 	 	295.67	832	84.0	0.0	ON	296.00	864	23.9	3.09	3.32
    	296.34	0.0	0.0	 	 	296.67	832	84.0	0.0	ON	297.02	832	22.7	2.06	3.31
    	297.37	0.0	0.0	 	 	297.72	864	84.0	0.0	ON	298.06	864	23.9	3.09	3.38
    	298.41	0.0	0.0	 	 	298.76	864	84.0	0.0	ON	299.09	864	22.7	2.06	3.27
    	299.43	0.0	0.0	 	 	299.78	864	84.0	0.0	ON	300.11	864	22.7	3.09	3.14
    	300.46	0.0	0.0	 	 	300.81	864	84.0	0.0	ON	301.16	832	22.7	2.06	3.44
    	301.50	0.0	0.0	 	 	301.85	864	84.0	0.0	ON	302.18	832	23.9	3.09	3.41
    	302.52	0.0	0.0	 	 	302.84	864	84.0	0.0	ON	303.18	832	22.7	2.06	3.44
    	303.52	0.0	0.0	 	 	303.86	864	84.0	0.0	ON	304.19	864	22.7	2.06	3.22
    	304.52	0.0	0.0	 	 	304.87	864	84.0	0.0	ON	305.20	832	23.9	3.09	3.29
    	305.54	0.0	0.0	 	 	305.86	864	84.0	0.0	ON	306.19	864	22.7	2.06	3.23
    	306.53	0.0	0.0	 	 	306.87	864	84.0	0.0	ON	307.21	864	22.7	2.06	3.26
    	307.56	0.0	0.0	 	 	307.89	832	84.0	0.0	ON	308.22	832	22.7	2.06	3.17
    	308.55	0.0	0.0	 	 	308.89	832	84.0	0.0	ON	309.22	832	22.7	2.06	3.23
    	309.55	0.0	0.0	 	 	309.90	832	84.0	0.0	ON	310.23	832	23.9	3.09	3.43
    	310.58	0.0	0.0	 	 	310.92	864	84.0	0.0	ON	311.25	832	22.7	2.06	3.37
    	311.58	0.0	0.0	 	 	311.90	832	84.0	0.0	ON	312.24	832	23.9	3.09	3.40
    	312.58	0.0	0.0	 	 	312.92	832	84.0	0.0	ON	313.25	832	23.9	3.09	3.43
    	313.60	0.0	0.0	 	 	313.93	864	84.0	0.0	ON	314.24	864	23.9	3.09	3.46
    	314.57	0.0	0.0	 	 	314.91	864	84.0	0.0	ON	315.26	832	23.9	3.09	3.46
    	315.61	0.0	0.0	 	 	315.95	864	84.0	0.0	ON	316.29	864	22.7	2.06	3.23
    	316.63	0.0	0.0	 	 	316.96	832	84.0	0.0	ON	317.31	832	22.7	2.06	3.29
    	317.64	0.0	0.0	 	 	317.98	864	84.0	0.0	ON	318.32	832	22.7	2.06	3.14
    	318.65	0.0	0.0	 	 	318.99	832	84.0	0.0	ON	319.34	864	22.7	2.06	3.15
    	319.69	0.0	0.0	 	 	320.04	832	84.0	0.0	ON	320.36	864	22.7	2.06	3.20
    	320.70	0.0	0.0	 	 	321.05	864	84.0	0.0	ON	321.38	864	22.7	2.06	3.17
    	321.71	0.0	0.0	 	 	322.04	832	84.0	0.0	ON	322.37	864	22.7	2.06	3.28
    	322.70	0.0	0.0	 	 	323.03	832	84.0	0.0	ON	323.36	832	22.7	2.06	3.32
    	323.69	0.0	0.0	 	 	324.01	832	84.0	0.0	ON	324.34	864	22.7	2.06	3.29
    	324.68	0.0	0.0	 	 	325.03	864	84.0	0.0	ON	325.36	832	22.7	2.06	3.17
    	325.69	0.0	0.0	 	 	326.03	832	84.0	0.0	ON	326.36	864	22.7	2.06	3.31
    	326.70	0.0	0.0	 	 	327.06	832	84.0	0.0	ON	327.39	864	22.7	2.06	3.19
    	327.73	0.0	0.0	 	 	328.06	864	84.0	0.0	ON	328.42	864	22.7	2.06	3.35
    	328.74	0.0	0.0	 	 	329.10	832	84.0	0.0	ON	329.45	832	22.7	2.06	3.37
    	329.76	0.0	0.0	 	 	330.10	832	84.0	0.0	ON	330.44	832	22.7	2.06	3.41
    	330.76	0.0	0.0	 	 	331.11	832	84.0	0.0	ON	331.46	832	22.7	2.06	3.42
    	331.81	0.0	0.0	 	 	332.15	832	84.0	0.0	ON	332.48	864	23.9	3.09	3.22
    	332.82	0.0	0.0	 	 	333.18	832	84.0	0.0	ON	333.51	864	22.7	2.06	3.27
    	333.85	0.0	0.0	 	 	334.18	832	84.0	0.0	ON	334.51	864	22.7	2.06	3.31
    	334.84	0.0	0.0	 	 	335.18	864	84.0	0.0	ON	335.51	864	22.7	2.06	3.43
    	335.86	0.0	0.0	 	 	336.18	832	84.0	0.0	ON	336.51	864	23.9	3.09	3.37
    	336.86	0.0	0.0	 	 	337.21	864	84.0	0.0	ON	337.55	832	22.7	3.09	3.49
    	337.89	0.0	0.0	 	 	338.22	832	85.5	0.0	ON	338.57	864	23.9	3.09	3.49
    	338.89	0.0	0.0	 	 	339.24	864	85.5	0.0	ON	339.59	864	22.7	2.06	3.03
    	339.92	0.0	0.0	 	 	340.26	864	84.0	0.0	ON	340.61	864	22.7	2.06	3.21
    	340.93	0.0	0.0	 	 	341.27	1120	84.0	0.0	ON	341.62	1280	19.2	2.06	2.83
    	342.01	0.0	0.0	 	 	342.36	1312	85.5	0.0	ON	342.72	1216	13.7	1.03	2.64
    	343.07	0.0	0.0	 	 	343.39	1088	84.0	0.0	ON	343.74	1024	20.4	2.06	4.00
    	344.09	0.0	0.0	 	 	344.45	1152	85.5	0.0	ON	344.83	1248	20.4	2.06	3.89
    	345.19	0.0	0.0	 	 	345.56	1312	84.0	0.0	ON	345.94	1312	16.1	2.06	3.12
    	346.29	0.0	0.0	 	 	346.66	1280	85.5	0.0	ON	347.01	1248	17.3	2.06	3.93
    	347.36	0.0	0.0	 	 	347.72	1248	85.5	0.0	ON	348.08	1280	18.4	2.06	4.11
    	348.44	0.0	0.0	 	 	348.80	1312	85.5	0.0	ON	349.14	1344	17.3	2.06	3.89
    	349.50	0.0	0.0	 	 	349.85	1312	84.0	0.0	ON	350.22	1312	17.3	2.06	3.82
    	350.58	0.0	0.0	 	 	350.96	1312	84.0	0.0	ON	351.31	1312	17.3	2.06	3.73
    	351.67	0.0	0.0	 	 	352.05	1312	84.0	0.0	ON	352.39	1312	18.4	2.06	3.97
    	352.78	0.0	0.0	 	 	353.15	1344	85.5	0.0	ON	353.50	1344	17.3	2.06	3.91
    	353.89	0.0	0.0	 	 	354.26	1376	84.0	0.0	ON	354.64	1376	17.3	2.06	3.84
    	355.01	0.0	0.0	 	 	355.36	1344	84.0	0.0	ON	355.72	1376	17.3	2.06	3.99
    	356.08	0.0	0.0	 	 	356.44	1344	84.0	0.0	ON	356.81	1376	18.4	2.06	3.83
    	357.16	0.0	0.0	 	 	357.52	1376	84.0	0.0	ON	357.87	1376	18.4	2.06	4.27
    	358.25	0.0	0.0	 	 	358.61	1376	84.0	0.0	ON	358.96	1408	18.4	2.06	4.09
    	359.32	0.0	0.0	 	 	359.71	1440	84.0	0.0	ON	360.07	1408	17.3	2.06	4.03
    	360.43	0.0	0.0	 	 	360.81	1376	84.0	0.0	ON	361.18	1280	14.9	2.06	2.89
    	361.49	0.0	0.0	 	 	361.84	832	84.0	0.0	ON	362.16	864	26.3	3.09	5.19
    	362.50	0.0	0.0	 	 	362.85	864	84.0	0.0	ON	363.19	896	27.5	3.09	3.98
    	363.51	0.0	0.0	 	 	363.86	896	84.0	0.0	ON	364.20	864	25.1	3.09	3.69
    	364.55	0.0	0.0	 	 	364.87	896	84.0	0.0	ON	365.20	864	22.7	2.06	3.49
    	365.53	0.0	0.0	 	 	365.86	832	84.0	0.0	ON	366.19	832	22.7	2.06	3.23
    	366.52	0.0	0.0	 	 	366.85	864	84.0	0.0	ON	367.17	832	22.7	2.06	3.09
    Sunday	19	May	2019	19:25:23:44445-VCID:1E65DCFAA9AD0C27AD7-5184	VCDS Version: Beta 19.4.0 (x64)	Data version: 20190411 DS307.0
    3B0 906 018 A		1.6l/2V SIMOS3 G00HS0009
    --- What next. ---
    Unplugged MAF and engine is not misfiring anymore.
    Perfect idle. Could be underpowered but still runs and drives better than previous.
    IAT is integrated into MAF casing if someone may ask why I have IAT fault now.
    19:48:00 Group 015: Ignition (Misfire Recognition Cylinder 1-3)
      0  Misfire Counter Cylinder 1
      0  Misfire Counter Cylinder 2
      0  Misfire Counter Cylinder 3
    19:48:00 Group 016: Ignition (Misfire Recognition Cylinder 4)
      0  Misfire Counter Cylinder 4
    19:48:00 Group 099: Lambda Control Shut-Off
      832 /min  Engine Speed (G28)
      87.0C  Coolant Temperature (G62)
      5.1 %  Lambda Control
      ON  Lambda Control Status
    16486 - Mass Air Flow Sensor (G70)
                P0102 - 35-00 - Signal too Low
    16497 - Intake Air Temp. Sensor (G42)
                P0113 - 35-00 - Signal too High
    --- TODO: ---
    Check leaks with "smokemachine"
    Get new OEM MAF by exchanging old one.
    Check engine compression
    Check injector flowrate (visually looking good)
    --- Main question. ---
    Should I buy new OEM MAF?
  2. Likes Uwe liked this post
  3. #2
    MY 2000 was not yet required to do generic OBD-II in Europe; I think the requirements were MY 2001 for gasoline and MY 2003 for diesel.
    What kind of MAF readings are you seeing at full throttle (under load, try 2nd or 3rd gear) between 5000 and 6000 rpm?
    Nov 2017
    Latvia
    Good question, don't have real data from yesterday.
    Got only limited time to check what's wrong. Actually writing first post took more than that. I will do it tomorrow.
    Did it some months ago, was about right. ~75g/s at 6000rpm.
    Got similar engine ECU from A4 B6 needing EGR-OFF. Then I could switch to that ECU as a last resort for testing is this issue related to ECU itself.
    Will bench test it again to see is it iso/obd-2 compatible.
    Nov 2017
    Latvia
    Update, 72g/s @6000rpm with attached MAF connector; 77g/s @6000rpm with disconnected MAF (value calculated by ECU itself based on other input data).
  6. Likes Dana, Uwe liked this post
    United States
    I would expect 80g/s but do see the note regarding higher altitudes at the bottom of this page.
    On a personal note, as long as the wiring to that MAF is OK I would invest in a new OEM MAF.
  8. Likes Uwe, Jack@European_Parts liked this post
  9. #6
    Any restrictions in exhaust or intake pre MAF or plugged filter?
    Are fuel volume and PSI tests within specification?
    Did you bifurcate the N80 with crimp tests?
  10. Likes Dana liked this post
  11. #7
    Nov 2017
    Latvia
    Can't really tell without removing CAT. Other than that exhaust looks normal, flow can go through, no weird noises coming out of it.
    When I was testing SAI, put a plastic bag onto tail pipe and SAI pump could blow into it.
    Air filter is new, air box cleaned, air guide from airbox to front grille is OK.
    DIY smoke machine from glow plug and glycerine maybe will tell more. Should have made it 15 years ago
    I did fuel volume test unknown time ago and it was ok.
    PSI tests were within specs.
    ^^ But can't find picture evidence for those above tests.
    I will have to repeat them together with measuring volume coming out of injectors.
    Nope, but I'm sure N80 is new and isn't leaking.
    https://forums.ross-tech.com/showthread.php?14361-EVAPORATION-(EVAP)-LEAK-DETECTION-PUMPS-(LDP)-Prepare-for-BIFURCATION!-TEST-S!
    I hope I understand that "bifurcate" word...
  12. Likes Dana liked this post
  13. #8
    Yeah..........nice picture!
    Did you switch to check release and from both directions?
  14. #9
    Nov 2017
    Latvia
    It was also tested using engine output tests, but can't remember if I tried vacuum test from the other side. I think no, it was summer 2018, can't remember.
    I can repeat it in weekend, no problem.
  15. #10
    Well.........we are waiting!
