Since this comes up a lot, figured I'm make a forum post on the subject so future searches can find it....
The B7 Audi A4s with the 2.0T have a very common issue with the following DTC:
P310B/012555 - Low Pressure Fuel regulation: Fuel Pressure Outside Specification
Most of the time this is caused by a failing lift pump in the fuel tank. The lift pump is run via a duty cycle, in other words, it isn't "powered on" when the engine is running, but rather cycled on and off at a very fast rate, like a strobe light. With the engine at operating temp, the duty cycle of the lift pump should be around 50%. You can view this by the following:
Start VCDS
[Select]
[01-Engine]
[Meas Blocks - 08]
Group 106, field #2
I would want to see that reading below 55% at idle, the closer to 50%, the better. If the reading is greater than 60% at idle, then you have problems. The lift pump is working harder than it should. So if you then try to do burn outs in your neighbor's lawn, a lift pump that is overworked at idle is not able to keep up when heavy fuel demands are called for, the lift pump in the fuel tank just can't keep up.
First I would verify there are no kinks or damage with the fuel lines for the low side fuel pressure, from the fuel tank up to the engine bay. If a fuel line or hose is restricted, that will cause the lift pump to work harder.
If the fuel lines all check out, I would next see about replacing the fuel filter. If the filter is gummed up, again, that can make the lift pump work harder to overcome the restriction. To this end, there are different versions of the fuel filters because they have fuel pressure regulators integrated into the filter itself. We have had several cases of people getting the wrong fuel filter, every time, the filter was not purchased from the dealer. I would suggest getting the filter from the dealer. IMHO, if the fuel filter has 80,000 miles (130,000 km) on it, it has done its job, replace it anyway.
Last, and most likely, the lift pump in the fuel tank is bad. A common mistake we see people make when replacing the lift pump is not getting the part from the Audi dealer. I have seen many cases were the original factory installed lift pump had failed and the duty cycle was say 70% at idle, and then a non dealer supplied lift pump was put in and it would run at 85% duty cycle, worse than original. Be warned, there are places that will sell you "factory parts" that come in the "factory box", but they are not same quality as you will get from the Audi dealer parts department. Or we get a shop calling us up saying they've replaced the lift pump 6 months ago and it has failed again..... it isn't a dealer supplied lift pump. We get this example 2 or 3 times per week and that is really the whole point of this post... get the lift pump from the dealer.
Enjoy.
Start VCDS
[Select]
[01-Engine]
[Meas Blocks - 08]
Group 106, field #2
Enjoy.
