Results 1 to 7 of 7
Thread: CC 2016 PDC retrofit and ABS coding US -> EU
    Mar 2018
    Poland
    Hi!
    I retrofitted PDC with PLA to CC 2016. Everything works, but I can't code visualisation on Discover Media. In adaptation channel "Park Pilot" if I set to active, then rejects the coding with "Out of range" error. How can I turn on the visualisation of PDC on radio? Is the PDC module to old for this radio unit?
    Also I want to recode ABS module to EU. After changing Instruments to EU there is an error in ABS module:
    Control Module Incorrectly Coded and Control Module in Instrument Cluster (J285).
    Can You give me the right coding of ABS unit to change it to EU?
    Friday,17,May,2019,17:39:53:43668
    VCDS Version: 18.9.1.0  HEX-NET CB: 0.4436.4
    Dealer/Shop Name: VagLab
    Workshop Code: 444 12345 012345
    VIN: WVWBP7AN3GE513621   License Plate: CC
    Mileage: 30480km-18939mi   Repair Order:
    Chassis Type: AN-VW46 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4F 52 53 55 5F 62
              65 6C 72 75
    VIN: WVWBP7AN3GE513621   Mileage: 30480km-18939miles
    Address 01: Engine (CBF)       Labels: None
       Part No SW: 06J 906 027 JK    HW: 06J 907 309 B
       Component: MED17.5.2        06 1336
       Revision: PAH05---    Serial number: VWZCZ000000000
       Coding: 040401081C070160
       Shop #: WSC 05314 000 00001
       VCID: FDB28A61A45B7AA236-80A8
       Part No SW: 02E 300 062 C    HW: 02E 927 770 AL
       Component: GSG DSG AG6     531 4017
       Revision: 06253104    Serial number: 00001512041374
       Shop #: WSC 05311 000 00001
       VCID: 9562B2C1BC2B82E29E-80C0
       Part No SW: 3AA 614 109 BM    HW: 3AA 614 109 BM
       Component: J104   C2 450M VD9B 0040
       Revision: --H07---    Serial number: 00000009085259
       Coding: 0004495
       Shop #: WSC 12345 444 12345
       VCID: F9BA9E71B07346821A-80AC
                        Reset counter: 155
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 11.50 V
                        Bin. Bits: 00011111
                        Count: 215
                        Hex Value: 0x0000
                        Reset counter: 155
       Part No SW: 1K8 907 044 BM    HW: 1K8 907 044 BM
       Component: Climatronic   H07 0405
       Revision: 00001K04
       Coding: 0714019048
       Shop #: WSC 00015 115 00001
       VCID: FBB68479724F749208-80AE
       Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
       Component: BCM PQ47 H++  422 0477
       Revision: BD422001
       Coding: 00080000000000000088028194000D4C20550B0840200D20E484402400C0
       VCID: C9DA2EB160131602CA-809C
       Subsystem 1 - Part No SW: 3C8 955 119 H    HW: 3C8 955 119 H  Labels: 1KX-955-119.CLB
       Component: WWS464 281015  024 0644
       Serial number: 15102103080511
       Coding: 044D9D
       Component: RLHS  037 0059
       Serial number: S5Y16M01D24H23M02S58
       Coding: 0728DD
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0043
       Revision: --------    Serial number: 56231330903814
       Coding: 348307
       ASAM Dataset: EV_EPHVA2C000000000 002014
       ROD: EV_EPHVA2C000000000.rod
       VCID: CBD614B9626F0412F8-809E
       Part No SW: 5N0 959 655 AC    HW: 5N0 959 655 AC
       Component: J234__702 VW10 HI   5418
       Revision: 35022000    Serial number: 003MBP0VHH85
       Coding: 0012338
       VCID: FEB08D6DA95D61BA2F-80AA
       Subsystem 1 - Part No: 3C8 959 339 A
       Subsystem 2 - Serial number: 0000000000PYSH
       Subsystem 3 - Serial number: 0028.09.150000300000850015˙†63
       Subsystem 4 - Serial number: 850015˙†6332MTS604353055 ˙†63
       Subsystem 5 - Serial number: 53055 ˙†6342MTS601953055 ˙†63
       Subsystem 6 - Serial number: 53055 ˙†6351HTS6R7T85EKJ ˙†63
       Subsystem 7 - Serial number: 85EKJ ˙†6361HTS6PHS95EKJ ˙†63
       Subsystem 8 - Serial number: 95EKJ ˙†63727TS6B8JVSDKR ˙†63
       Subsystem 9 - Serial number: VSDKR ˙†63827TS6LN34EEKR ˙
       Subsystem 10 - Serial number: 4EEKR ˙
       Part No SW: 3C5 953 501 CN    HW: 5K0 953 569 AS
       Revision: FF010042    Serial number: 20160114100739
       Coding: 098A270001
       VCID: F3A6AC595A1F3CD250-80A6
       Component: E221__MFL-TK6  H07 0023
       Serial number: 70000000000000897817
       Coding: E20000
       Part No SW: 3C8 920 971 L    HW: 3C8 920 971 L
       Component: KOMBI         H05 1008
       Coding: 040F000000
       VCID: B620554D09ED69FAB7-80E2
       Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1663
       Revision:   H56       Serial number: 090116F1000903
       Coding: 469036
       VCID: F2A8A95D2D0535DA5B-80A6
       Part No SW: 3AA 959 799 G    HW: 3AA 959 799 G
       Component:    IMMO         091 0429
       Revision: 00091000    Serial number: VWZCZ000000000
       VCID: CCD417A5AF61032AF1-8098
       Part No SW: 3C8 959 701 A    HW: 3C0 959 793 J
       Component: TUER-SG FT    002 0603
       Revision: 12100010    Serial number: 0010331311
       Coding: 0004B7
       Shop #: WSC 05311 115 00001
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
       VCID: AE107D2DF1BD513AFF-80FA
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  006 0503
       Serial number: 00000004231285
       Coding: 010490
       Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
       Component: J500__APA-BS KL.302 1401
       Revision: 1BH04739    Serial number: 00153380058501
       Coding: 0000258
       VCID: C1CA36919823DE4212-8094
    Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
       Component:    KESSY PQ47   091 0414
       Coding: 1B910F8001860E521204143FF08A0F0E10780203043798
       Subsystem 4 - Part No: 3AA 962 243 D
       Component: GEB.F.Heckoef       0811
       Component: EZE_2         H56 1663
       Coding: 00000008
       VCID: EFAEA0293E371832B4-80BA
       Subsystem 1 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
       Component: Analoguhr  005 0004
       Part No SW: 3C8 959 702 A    HW: 3C0 959 792 J
       Component: TUER-SG BT    002 0603
       Revision: 14100010    Serial number: 0010325049
       Coding: 0004B6
       ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
       ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
       VCID: AF2E6029F6B75832F4-80FA
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  006 0503
       Serial number: 00000004224459
       Coding: 010490
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000001032465
       Coding: 0022156
       VCID: B83C5B75CBF99F8AA5-80EC
       Component: AFS-ECU       H05 0111
       Coding: 071200010B000400
       VCID: B73E58490EE790F2AC-80E2
       Subsystem 1 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H06 0007
       Coding: 350000
       Subsystem 2 - Part No SW: 1T0 941 329 A    HW: 1T0 941 329 A  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H06 0007
       Coding: 350000
       Part No SW: 5C0 035 684     HW: 5C0 035 684
       Component: MU-S-NS-US    H22 0245
       Serial number: VWZAZ2S0005265
       Coding: 02740402FF00000051220001001808001F0100C400200105C6
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: E288D91DF5E5A55A2B-80B6
              B11CF 53 [009] - Deactivated
                        Reset counter: 155
                        Mileage: 30481 km
                        Date: 2019.05.17
                        Time: 18:34:02
                        Voltage terminal 30: 11.8 V
                        SDARS_tuner_status_2-Antenna current: 0 mA
                        SDARS_tuner_status_2-Reception quality: No_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 00
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 00
    Address 62: Door, Rear Left
       Part No SW: 3AA 907 273 H    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0012
       Serial number: 30000000051443
       ROD: EV_RDKBERU30_006_VW36.rod
       VCID: B93A5E7138F386825A-80EC
    Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
       Part No SW: 7N0 907 441 B    HW: 7N0 907 441 B
       Component: VW428 RVC Mid H04 0040
       Coding: 016404016001000700
       Shop #: WSC 05311 000 00322
       ASAM Dataset: EV_CamSysRearPANAVW428 002002
       ROD: EV_CamSysRearPANAVW428.rod
       VCID: B02C6355EB8947CAED-80E4
    Address 72: Door, Rear Right
       Part No SW: 561 035 285 A    HW: 561 035 285 A
       Component: OCULowUSA     020 0158
       Serial number: 000003554140546
       Coding: 02640402C24212107F1606000000
       ASAM Dataset: EV_OCULow 002010
       ROD: EV_OCULow_002.rod
       VCID: 9464CFC57FD19BEAE9-80C0
    End----(Elapsed Time: 01:49, VBatt start/end: 11.6V/11.6V. VIgn 11.6V)-----
    Jul 2014
    Tallinn, Estonia
    You need to change PLA module to 1K8919475D. You should find these in abundance on Allegro. Do keep in mind this newer module has different connectors, so you would need a converter such as this -> https://www.aliexpress.com/store/pro...259d38dfdQ8IHc . You also might have to add some wires to this converter because it might only cover 8K PDC - PLA has more wires.
    Mar 2018
    Poland
    Thanks! I was suspecting that. Different connectors isn't a problem, I can rewire it.
    How about ABS module? What is the proper coding for EU model?
    Tartu, Estonia
    You still have US cluster, or why the P/N is 3C8 920 971 L, xxx xxx 9xx xx being MPH. You may wanna try out ABS coding 0004489, but no guarantees.
    The world is my oyster...
    Jul 2014
    Tallinn, Estonia
    Quote Originally Posted by cinek2004 View Post
    Sure, if the rather bad accessibility (even with the cluster removed) of the connectors does not pose a problem for you.
    I have two sets of new connectors on hand but am still using a converter because of this.
    Mar 2018
    Poland
    Yes, US cluster stays, I change only the faces. But with EU cluster coding there is an error in ABS. I'll check later the coding You gave me.
    I have the dash disassembled so changing connectors isn't a problem.
  7. #7
    Mar 2018
    Poland
    It solved the problem! Thank you!
  8. Likes Uwe liked this post
