Results 1 to 10 of 14
Thread: AUDI A6 4G Chassis transmission problem
    Jun 2016
    Botswana
    Hi there,this is my first post,and as such let me first say that after 10 years of using VCDS I am more than satisfied with it.I am conscious that, due to my age I am not able to use most of its functions,but so far I am trying and I can say I have also very satisfied customers and friends.When I mentioned customers,this is piece job.Nowadays is,if you do not run your own business you are just surviving.
    Anyway,my brother call me on 19.10.18.telling me that he had some messages on the display regarding transmission.I told him to pass by me at work.On he"s way to me he had a small accident where the grill and A/C line was affected,only.Gas went out.I did a scan and after that I told him I think its not much serious,go home and call our friend workshop to arrange to fix that while I am going to look for manual or diagram to attend first problem.Four days after,mechanic come to he"s home to take car to workshop,and they battled to put in reverse.After countless attempts they managed and he left.Few hours later mechanic told me that car is refusing to start.After work I went straight there tried to scan,but machine couldn't see trany"s ECU.I organized assistance from home country in Europe,for terminal arrangements and went under the car to disconnect trany"s connector.While turning the ring with short handle,and connector started sliding backwards from the socket few drops of yellowish fluid came out.I was wandering how is possible for the oil to come out on the car with 60K on the clock.Pulled completely out,than I realized that was water,not oil.Anyway,term 16 for B+ was rotten completely,I just tried to pull wire backwards and it came out w/out any force.It was rotten right on the point of crimping.
    Than broo came in and we found most possible scenario how the water came in.In 2017 he left car at local dealer where he bought it(it was still under motor plan)to sort out some issues I was not aware of them.Nothing major but inconvenient,he left car for about 2,5month(he went on holiday back home). When he collected car it was around October 2017 and they told him that they replaced main engine harness.On Christmas break he went with it in northern Botswana and he told me they wanted to see one of the pans.It was still soon after rain and he accidentally catch mud where he hardly manged to take car out of it.That is the moment,I guess water came in,since when disconnecting connector I didn't feel that click which is normal when connector is properly inserted in and locked.After that I thought also the pins are rotten and I told mechanic that I want to replace connector with inner harness,just to discover that connector is a part of ECU.Mechanic is the one who tried to remove it for me,but he didn't went far with it since he also found that arrangements is not like one we thought.After long battle to get new terminals and new connector(local dealer wanted to sell complete engine harness) from Germany,I cut all cables and replaced them with new ones already crimped with terminals and clean pins in the socket.Than I checked that particular one for B+,strength,tried to push bit left or right with small screw driver,it was still strong,it wasn't moving at all.Than I tried with only one terminal w/out connector, to see if the terminal is having good grip,it was almost no difference between other pins.Now I would like to mention conversation with Dana few days ago,where she said that it is already known that 4G chassis have problems with pulling coolant into the harness and so on.In my case,I do not think that could be the reason,because trany"s branch is coming from top of the gearbox and just next to the socket, it bent slightly upwards and that length of about few centimeter cables are visible,there is no sleeve coming straight to the connector.Not to mention that round connector(420973716) is not designed to accommodate end of corrugated sleeve.Actually,due to the heat,that branch in length of about 500-700mm is not in standard corrugated sleeve,it is special sleeve made of mineral whole and alum-foil to be heat resistant.Plus,the moment when I went under the car to test it first time.all cables were very dry,there was no single sign of water,moisture or something like that.
    Now mechanic put back everything,even oil,oil is maybe short for about one liter,he didn't have more at the moment.We started car yesterday and I made two scans first I wanted to clear some of the faults they were there due to dead battery.I replaced battery yesterday,new one.Message on the display says there is no reverse gear,but you can continue driving.We just run car for a while,up to operating temp with no other visible problems.Scans are according to dates,time when I made it.
    My question now is,where sensors 1 and 4 are located,and what can be wrong that they not producing signals.Another issue is time in the code description,it does not at all represent time when any activity was around car.And this is not problem with this car,many times up to now I can not rely on that time,simply it does not make much sense.Which unit or software is responsible in the car to keep it in order?
    My sincere apology for quite long story,it just my attempt to present it as much as possible in better way that you can understand.
    I am sorry,but it is refusing to paste scan.I will try to send scans separately.
    Jun 2016
    Botswana
    I am sorry,I can not identify problem why copy and paste system does not work to post scans,from folder Logs in my computer?Any assistance will be highly appreciated.
    Open the file with Notepad.
    Ctrl+A to select all.
    Ctrl+C to copy it.
    Ctrl+V to paste it here.
    Jun 2016
    Botswana
    FILE 1 ---
    Friday,19,October,2018,14:02:48:41997
    VCDS Version: 18.9.0.2 (x64)
    Dealer/Shop Name: M.Nikolic
    VIN: WAUZZZ4G9CN072019   License Plate: 19.10.18
    Mileage: 63492km-39452mi   Repair Order: Buraz
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 52 53 55 5F
              62 6C 72
    VIN: WAUZZZ4G9CN072019   Mileage: 63492km-39452miles
    Address 01: Engine (J623-CGWB)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 907 551     HW: 4H0 907 551
       Component: 3.0l V6 TFSI  H07 0007
       Revision: --H07---
       Coding: 0A250032052701020000
       Shop #: WSC 02311 785 00200
       ASAM Dataset: EV_ECM30TFS0214G0907551 002010
       ROD: EV_ECM30TFS0214G0907551_002.rod
       VCID: E680D30319C3407ACF-80B2
       Part No SW: 4G1 927 156 K    HW: 0B5 927 156 K
       Component: 0B5 30TFSIRdW H05 0008
       Revision: --H05---
       Coding: 000001
       Shop #: WSC 04940 001 00001
       ROD: EV_TCMDL501021.rod
       VCID: B522444F14E5FBE2B6-80E0
    23236 - Signal Line for Gear Display on Selector Lever
              P1893 00 [032] - Electrical Malfunction
                        Reset counter: 38
                        Mileage: 63474 km
                        Date: 2018.10.19
                        Time: 06:40:06
                        Engine speed: 1202 /min
                        Transmission input speed: 1202 /min
                        Transmission output speed: 136 /min
                        Engine torque: 128 Nm
                        Transmission fluid temperature: 93 ∞C
                        Accelerator position: 25.6 %
                        Clutch status: Beide Kupplungen kˆnnen Moment ¸bertragen
                        Unlearning counter according OBD: 38
                        Voltage terminal 30: 13.800 V
                        W006_Vwh_PrzWh_Whs1-Data: 39.90 %
                        W007_Vwh_PrzWh_Whs2-Data: 39.90 %
                        Selector lever maximum pulse width High-Data: 4.008 ms
                        Selector lever minimum pulse width High-Data: 3.993 ms
                        Selector lever maximum pulse width Low-Data: 51.106 ms
                        Selector lever minimum pulse width Low-Data: 35.242 ms
    23237 - Signal Line for Gear Display on Selector Lever
              P1894 00 [032] - Implausible Signal
                        Reset counter: 39
                        Mileage: 63473 km
                        Date: 2018.10.19
                        Time: 06:40:00
                        Engine speed: 1511 /min
                        Transmission input speed: 1511 /min
                        Transmission output speed: 361 /min
                        Engine torque: 12 Nm
                        Accelerator position: 0.0 %
                        Clutch status: Kupplung 2 kann Moment ¸bertragen
                        Selector lever maximum pulse width Low-Data: 47.176 ms
       Part No SW: 4G0 907 379 F    HW: 4G0 907 379 F
       Component: ESP PREMIUM   H09 0250
       Coding: 44A687012265E180DB00
       ASAM Dataset: EV_ESPPremiAU57X 004017
       VCID: B424794B1F9FE2EA81-80E0
       Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
       Coding: 01B83006000000000000
       VCID: F6A083434163B0FA7F-80A2
       Part No SW: 4G0 820 043 G    HW: 4G0 820 043 G
       Component: KLIMA 2 ZONEN H10 0062
       Serial number: 23101100040374
       Coding: 6621000828
       ASAM Dataset: EV_AirCondiBasisUDS 002037
       VCID: A3068A17AA71755268-80F6
    0378 - Coolant Circulation Pump
              B10D0 04 [008] - Internal System Fault
                        Fault Frequency: 22
                        Reset counter: 49
                        Mileage: 57947 km
                        Date: 2018.03.12
                        Time: 06:46:33
                        Voltage terminal 30: 14.48 V
                        Outside air temperature: 20.0 ∞C
                        Interior temperature: 26.20 ∞C
    0379 - Supply Voltage Terminal 30 for Coolant Pump
              B11D5 01 [009] - Electrical Failure
                        Fault Frequency: 20
                        Reset counter: 22
                        Mileage: 57868 km
                        Date: 2018.03.08
                        Time: 17:22:04
                        Voltage terminal 30: 14.27 V
                        Outside air temperature: 36.0 ∞C
                        Interior temperature: 30.45 ∞C
       Part No SW: 4H0 907 063 BE    HW: 4H0 907 063 E
       Component: BCM1 2.0      H12 0100
       Revision: 19012002    Serial number: 00000001251450
       Coding: 2600E01040349FE00181008480001D0CCF9DC30827090101800004602101
       VCID: EC94A12B0F2F7A2A99-80B8
       Component: WWS57X 110909  H35 0051
       Serial number:         110921235342
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 11729007
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 18 10 2011  00000190
       Subsystem 4 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA100730000000559513
       Coding: 020300
       Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Component: Humidity_Sens  H02 0002
       Serial number: D05803D5000000000001
       Part No SW: 4H0 919 475 L    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0043
       Revision: 11001001    Serial number: 55901128501136
       Coding: 280305
       ROD: EV_EPHVA18AU57X0000_002_AU57.rod
       VCID: BB36527732C12D9240-80EE
       Component: Airbag10.43   H40 0040
       Revision: --------    Serial number: 003JG004X30Z
       Coding: 30323436313330303538554A305234473053
       VCID: B620434309E3F0FABF-80E2
       Serial number: 3575HRB405B0SM2M78IU
       Serial number: 3585HRB40590SM2MG0V0
       Serial number: 3515JRB405V0Q8K46ORB
       Serial number: 3525JRB40670OPMM18U6
       Serial number: 3554VRB404V0P4N2DG81
       Serial number: 3564VRB404V0P4N2K0N8
       Revision: 00000000    Serial number: 20111019000514
       Coding: 000034
       VCID: B02C755BE387DECAE5-80E4
       Component: E221 - MFL  H08 0009
       Part No SW: 4G8 920 931 C    HW: 4G8 920 931 C
       Component: TBenRdw       H79 0375
       Revision: 26181120    Serial number: 658121011596012
       Coding: 33A608000B010008010000
       ASAM Dataset: EV_RBD4K 004040
       ROD: EV_RBD4K.rod
       VCID: AE106B23F1B3C83AF7-80FA
       Part No SW: 4G0 907 468 E    HW: 4G0 907 468 A
       Component: J533--Gateway H08 0213
       Revision: --------    Serial number: 00000000278855
       Coding: 00CD073000
       ROD: EV_GatewUDS_AU57.rod
       VCID: B2287F53E58BECDA93-80E6
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790820551
       Voltage stabilizer:
       Serial number: 11293002282011200181
    0264 - Powertrain Databus (VAG Wingle-Wire Mode) (SAE  L Shorted H)
              U0009 00 [008] - -
              [Datenbus Antrieb Eindraht]
                        Fault Frequency: 34
                        Reset counter: 70
                        Mileage: 63387 km
                        Date: 2018.10.17
                        Time: 12:22:57
                        Voltage terminal 30: 14.0 V
                        Voltage terminal 15: 14.1 V
                        Control Module temperature: 44 ∞C
                        System status: Terminal 15 on
                        Engine running: On
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
       Revision: AA000000    Serial number: 00000014865620
       VCID: F7BE8E474669C9F264-80A2
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0004
       Revision: --------    Serial number: EJ1BPA3200NHLH0
       ASAM Dataset: EV_SARA 006014
       ROD: EV_SARA_006.rod
       VCID: EB96A23702217D1290-80BE
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011F16204E01620002080002
       Shop #: WSC 02312 785 00200
       VCID: C2C82F935D2B5C5A03-8096
    Address 44: Steering Assist        Labels:
       VCID: D5EC6BD72C0B967F1D3-FFFE
    Address 46: Central Conv.
    FILE 2 ---
    Saturday,10,November,2018,15:02:24:41997
    VCDS Version: 18.9.0.2 (x64)  HEX-NET CB: 0.4436.4
    VIN: WAUZZZ4G9CN072019   License Plate: 10.11.18.
    Mileage: 63570km-39500mi   Repair Order: Buraz,Audi
              62 6C 72
    VIN: WAUZZZ4G9CN072019   Mileage: 63570km-39500miles
    02-Auto Trans -- Status: Cannot be reached 0100
       Revision: --H07---
    6088 - No Communication with Transmission Control Module
              U0101 00 [037] - -
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 13:45:57
                        Coolant temperature: 25 ∞C
                        Intake air temperature: 27 ∞C
                        Ambient air pressure: 860 mbar
                        Voltage terminal 30: 11.780 V
                        Engine speed: actual: 0 /min
                        T_AST_ENVD: 0.00 s
                        Gear: 0
                        Engine: operating status: ES
                        Battery voltage: 11.781250 V
                        Vehicle speed: actual: 0 km/h
    Readiness: 0110 0001
    0058 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_Getriebe_01_Timeout]
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 11:43:29
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BB
                        Uz: 98
    0060 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_Getriebe_03_Timeout]
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 11:43:29
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 20
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: BE
                        Uz: 98
    0061 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [ComScl_PDU_Getriebe_04_Timeout]
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 11:43:29
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 0F
                        Bit Info 3: 22
                        Bit Info 4: 1F
                        F-Path: 00
                        F-Type: C8
                        Uz: 98
    0486 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [Ldm_ApbFailureState]
                        Fault Frequency: 13
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 11:42:54
                        VzRef: 00
                        Bit Info 1: 00
                        Bit Info 2: 02
                        Bit Info 3: 20
                        Bit Info 4: 1F
                        F-Path: 02
                        F-Type: 01
                        Uz: 98
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 13:49:33
       Coding: 6621000828
    0267 - Sensor for Refrigerant Pressure and Temperature
              B10C2 21 [009] - Signal Amplitude Too Low
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 11:43:30
                        Compressor current: actual value: 0 mA
                        Outside air temperature: 28.5 ∞C
                        Temperature after evaporator: 20.31 ∞C
                        Engine speed: 0 /min
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 11:43:06
       Coding: 0045F7
       Coding: 02512B
       Coding: 020300
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 13:50:00
       Coding: 280305
    12648720 - Databus
              [Getriebesteuerger‰t - Getriebe_03 - kein Signal/keine Kommunikation]
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 11:41:50
       Coding: 000034
       ROD: EV_RBD4K.rod
       Coding: 00CD073000
       Voltage stabilizer:
    4226 - No Communication with Transmission Control Module
              U0101 00 [009] - -
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 11:41:53
                        Voltage terminal 30: 11.7 V
                        Voltage terminal 15: 11.8 V
                        Control Module temperature: 34 ∞C
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0006189161
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       Revision: 00002001    Serial number: 0161175198
       Coding: 011A062200B9040480300804000100000000000000000000000000000000
       Subsystem 3 - Part No SW: 7P5 959 591     HW: 4H0 959 591
       Component: J245 PS40.033  H07 0006
       Serial number:     WOO13776187
       Coding: 901E00
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 11:42:00
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: C1CA209F582D47421A-8094
       Revision: --------    Serial number: 00000000160077
       ROD: EV_ParkiBrake_VW51.rod
       VCID: AA186733CD5BA41A2B-80FE
    329728 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [FC_GETRIEBE_03_MESSAGE_TIMEOUT]
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 11:42:04
                        Voltage terminal 30: 11.9 V
                        Internal Fault ID: 94
                        Red operating lamp: OFF
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
    329984 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [FC_GETRIEBE_04_MESSAGE_TIMEOUT]
                        Reset counter: 35
                        Mileage: 63570 km
                        Date: 2018.11.07
                        Time: 11:42:04
                        Internal Fault ID: 95
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
       Serial number: 111017-0002-027
       Coding: 1121A6101000A300
       ROD: EV_HeadlRegulBasic.rod
       VCID: AC14612BC7AFBA2AD9-80F8
       Part No SW: 4G0 035 182 H    HW: 4G0 035 182 H
       Component: RMC Cnct Plus H51 0717
       Coding: 0101000001C1DF47002B060303010000000000
       VCID: A6009303D143807A0F-80F2
       Subsystem 1 - Part No SW: 4G0 919 603     HW: 4G0 919 603
       Component: DU6 Basic  H42 0084
       Serial number: 9464HP0B0064250
       Subsystem 2 - Part No SW: 4G2 919 610     HW: 4G2 919 610
       Component: E380 BDT C7  H08 0203
       Serial number: 90349KJD000J0
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F14204001620002080002
       VCID: C4C4298B473F526A31-8090
       Revision: --H04---    Serial number: 525 PA8J1XG03C
       Coding: 1080004
       VCID: A60093031143807A0F-80F2
       Component: TSG HR        H04 0212
    End----(Elapsed Time: 01:53, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    FILE 3 ----
    Saturday,18,May,2019,12:50:59:41997
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
    VIN: WAUZZZ4G9CN072019   License Plate: B791AVJ
    Mileage: 63568km-39499mi   Repair Order: Buraz, Audi
              62 6C 72
    VIN: WAUZZZ4G9CN072019   Mileage: 63568km-39499miles
       Revision: --H07---
       VCID: E680D30319C3407AC7-80B2
       Revision: --H05---
       Coding: 000001
       VCID: B522444F14E5FBE2BE-80E0
    17584 - Position Sensor 1 for Gear Selector
              P173A 00 [175] - Implausible Signal
                        Reset counter: 40
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 00:18:15
                        Transmission input speed: 0 /min
                        Transmission output speed: 0 /min
                        Engine torque: -28 Nm
                        Transmission fluid temperature: 26 ∞C
                        Clutch status: Beide Kupplungen offen
                        Voltage terminal 30: 12.100 V
                        Supply voltage of sensors for partial transmission 2-Param to DOP: 5.010 V
                        S005_Siw_Adc_Gs_Sensor[G2R_1]-Data: 0
    17585 - Position Sensor 4 for Gear Selector
              P173D 00 [175] - Implausible Signal
                        Reset counter: 40
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 00:18:15
                        S006_Siw_Adc_Gs_Sensor[G2R_2]-Data: 15
       VCID: B424794B1F9FE2EA89-80E0
       VCID: F6A083434163B0FA77-80A2
       Coding: 6621000828
       VCID: A3068A17AA71755260-80F6
                        Reset counter: 35
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 00:19:17
                        Outside air temperature: 26.0 ∞C
                        Temperature after evaporator: 21.89 ∞C
    0276 - Engine Off Timer Performance
              P150A 00 [008] - -
                        Reset counter: 75
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 00:19:17
                        Voltage terminal 30: 12.20 V
                        Reset counter: 35
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 00:19:17
                        Interior temperature: 26.07 ∞C
       VCID: EC94A12B0F2F7A2A91-80B8
       Coding: 0045F7
       Coding: 02512B
       Coding: 020300
       Coding: 280305
       VCID: BB36527732C12D9248-80EE
       VCID: B620434309E3F0FAB7-80E2
       Coding: 000034
       VCID: B02C755BE387DECAED-80E4
       ROD: EV_RBD4K.rod
       VCID: AE106B23F1B3C83AFF-80FA
       Coding: 00CD073000
       VCID: B2287F53E58BECDA9B-80E6
       Voltage stabilizer:
              U140B 00 [008] - -
              [Powermanagement active]
                        Reset counter: 75
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 12:47:23
                        Voltage terminal 30: 10.2 V
                        Voltage terminal 15: 0.0 V
                        Control Module temperature: 19 ∞C
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Terminal 15 status: OFF
                        Datenfeld: 3
       VCID: F7BE8E474669C9F26C-80A2
       VCID: EB96A23702217D1298-80BE
       VCID: C2C82F935D2B5C5A0B-8096
       Coding: 901E00
       VCID: C1CA209F582D474212-8094
       VCID: AA186733CD5BA41A23-80FE
       VCID: AC14612BC7AFBA2AD1-80F8
       VCID: A6009303D143807A07-80F2
       VCID: C4C4298B473F526A39-8090
       Coding: 1080004
       VCID: A60093031143807A07-80F2
    End----(Elapsed Time: 01:50, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
    FILE 4 ---
    Saturday,18,May,2019,13:02:08:41997
    VIN: WAUZZZ4G9CN072019   License Plate: B791AVJ/2
    Mileage: 63568km-39499mi   Repair Order: Buraz,Audi
              62 6C 72
       Revision: --H07---
       Revision: --H05---
       Coding: 000001
                        Reset counter: 40
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 00:18:15
                        Reset counter: 40
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 00:18:15
       Coding: 6621000828
                        Reset counter: 35
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 00:19:17
              P150A 00 [008] - -
                        Reset counter: 75
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 00:19:17
                        Reset counter: 35
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 00:19:17
       Coding: 0045F7
       Coding: 02512B
       Coding: 020300
       Coding: 280305
    1113107 - Front Parking Aid Sensor(s)
              B10FC 13 [009] - Open Circuit
                        Reset counter: 35
                        Mileage: 63568 km
                        Date: 2019.05.16
                        Time: 00:35:39
       Coding: 000034
       ROD: EV_RBD4K.rod
       Coding: 00CD073000
       Voltage stabilizer:
              U140B 00 [008] - -
                        Reset counter: 75
                        Mileage: 63568 km
                        Date: 2019.05.10
                        Time: 12:47:23
                        Engine running: OFF
                        IN ZAS_Te_X: OFF
                        Datenfeld: 3
       Coding: 901E00
       Coding: 1080004
    End----------(Elapsed Time: 01:54, VBatt start/end: 14.6V/14.6V)-----------
              62 6C 72
       Revision: --H07---
       Revision: --H05---
       Coding: 000001
              P173A 00 [167] - Implausible Signal
                        Reset counter: 40
                        Mileage: 63568 km
                        Date: 2019.05.16
                        Time: 00:48:56
                        Engine speed: 693 /min
                        Transmission input speed: 693 /min
                        Engine torque: 4 Nm
                        Transmission fluid temperature: 53 ∞C
                        Voltage terminal 30: 14.300 V
              P173D 00 [167] - Implausible Signal
                        Reset counter: 40
                        Mileage: 63568 km
                        Date: 2019.05.16
                        Time: 00:48:56
                        Engine torque: 4 Nm
       Coding: 6621000828
                        Reset counter: 35
                        Mileage: 63568 km
                        Date: 2019.05.16
                        Time: 00:48:54
                        Outside air temperature: 23.5 ∞C
                        Temperature after evaporator: 27.22 ∞C
                        Engine speed: 702 /min
                        Reset counter: 35
                        Mileage: 63568 km
                        Date: 2019.05.16
                        Time: 00:48:54
                        Voltage terminal 30: 14.61 V
                        Interior temperature: 23.82 ∞C
       Coding: 0045F7
       Coding: 02512B
       Coding: 020300
       Coding: 280305
                        Reset counter: 35
                        Mileage: 63568 km
                        Date: 2019.05.16
                        Time: 00:48:54
       Coding: 000034
       ROD: EV_RBD4K.rod
       Coding: 00CD073000
       Voltage stabilizer:
       Coding: 901E00
       Coding: 1080004
    End----------(Elapsed Time: 01:49, VBatt start/end: 14.6V/14.6V)-----------
  5. Likes Dana liked this post
    Jun 2016
    Botswana
    Thank you very much.
    Jun 2016
    Botswana
    Uwe,thank you very much for your assistance.
    Oct 2014
    Arandjelovac, Serbia
    Our user Nik need help about 2 faults. Any advice, please.
       Revision: --H05---
       Coding: 000001
                        Reset counter: 40
                        Mileage: 63568 km
                        Date: 2019.05.16
                        Time: 00:48:56
                        Engine torque: 4 Nm
                        Reset counter: 40
                        Mileage: 63568 km
                        Date: 2019.05.16
                        Time: 00:48:56
                        Engine torque: 4 Nm
  9. Likes Dana liked this post
  10. #8
    United States
    Hi Guys,
    Have you diagnosed the cause of the Coolant Circulation Pump and Supply Voltage Terminal 30 for Coolant Pump DTCs yet or unplugged the TCM and inspected the terminals on both ends yet?
    P.S. This 0B5 thread included a photo of the damage that occurs frequently: https://forums.ross-tech.com/showthr...-Communication
    I should find a home for a link to that thread on the Wiki. I might stick it on the 0B5 page.
  11. #9
    Has wiring been verified from end to end with load light and as Dana aforementioned?
  12. Likes Boki Ar, Dana, Nik liked this post
  13. #10
    Jun 2016
    Botswana
    Good day and thank you to all.I appreciate indeed your time and your effort.I already composed reply,but when I refresh the page to send it is gone.Please advice,if I keep bit longer typing time will elapse for me online,I have to refresh the page,correct?How I should save my reply so that is not lost like now?
    Many thanks for your assistance
