2012 vw Jetta tdi check engine light/fault codes
Vwjoe29
Alberta Canada
C?ID=349077
Saturday,18,May,2019,16:01:00:61484
VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
VIN: 3VW3L7AJ0CM408842   License Plate:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 03 05 08 09 15 17 19 25 2B 2E 37 44 47 56
VIN: 3VW3L7AJ0CM408842   Mileage: 162960km-101258miles
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 906 019 EH    HW: 03L 907 309 AA
   Component: R4 2,0L EDC G000SG  3523
   Revision: 12H14---    Serial number:
   Coding: 0050072
   Shop #: WSC 83968 804 673350
   VCID: 75B7E21909CE346FBDB-8020
6 Faults Found:
001699 - Sensor Reference Voltage "D"
               P06A3 - 000 - Open Circuit - MIL ON
                    Fault Status: 11100000
                    Mileage: 162923 km
                    Date: 2019.05.17
                    Time: 22:46:09
                    Voltage: 12.39 V
                    Temperature: 95.4°C
                    (no units): 0.0
                    Torque: -150.0 Nm
               P0300 - 000 -
                    Mileage: 162925 km
                    Date: 2019.05.17
                    Time: 23:17:33
                    RPM: 3105 /min
                    Speed: 83.0 km/h
                    Load: 34.1 %
                    Voltage: 13.76 V
                    Voltage: 13.76 V
                    Voltage: 13.76 V
                    Voltage: 13.76 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected
                    Mileage: 162927 km
                    Date: 2019.05.17
                    Time: 23:19:34
                    RPM: 2162 /min
                    Speed: 36.0 km/h
                    Load: 38.8 %
                    Bin. Bits: 00100000
                    Torque: 3.0 Nm
                    Bin. Bits: 00000000
                    Ign. Timing: 18.4 °ATDC
000771 - Cylinder 3
               P0303 - 000 - Misfire Detected
                    Mileage: 162927 km
                    Date: 2019.05.17
                    Time: 23:19:34
                    RPM: 2162 /min
                    Speed: 36.0 km/h
                    Load: 38.8 %
                    Bin. Bits: 00100000
                    Torque: 3.0 Nm
                    Bin. Bits: 00000000
000772 - Cylinder 4
               P0304 - 000 - Misfire Detected
                    Mileage: 162927 km
                    Date: 2019.05.17
                    Time: 23:19:34
                    RPM: 2162 /min
                    Speed: 36.0 km/h
                    Load: 38.8 %
                    Bin. Bits: 00100000
                    Torque: 3.0 Nm
                    Bin. Bits: 00000000
000770 - Cylinder 2
               P0302 - 000 - Misfire Detected
                    Mileage: 162927 km
                    Date: 2019.05.17
                    Time: 23:19:34
                    RPM: 2162 /min
                    Speed: 36.0 km/h
                    Load: 38.8 %
                    Bin. Bits: 00100000
                    Torque: 3.0 Nm
                    Bin. Bits: 00000000
Readiness: 1 1 0 0 X
   Revision: 00H31001
   Coding: B14B400C492200028D1302E8921B0042251400
   Shop #: WSC 30799 001 104857
   VCID: 7DA7FA393DFE6C2FF5B-8028
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 84
                    Mileage: 162961 km
                    Date: 2019.05.18
                    Time: 08:43:01
                    Count: 2
                    Count: 4096
                    Count: 397
                    Count: 44288
                    Count: 63488
   Revision: 00085000    Serial number: 0167091423
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_A02_VW36.rod
   VCID: 34311F1D4EB46D674A5-8060
   Part No SW: 5C0 820 047 AQ    HW: 5C0 820 047 AQ
   Component: J301  Klimaanlage   0203
   Revision: 2001010S    Serial number: 00000000924153
   VCID: 6FBBD0716B920EBF777-803A
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0256
   Revision: B2066001    Serial number: 04371118121328
   Coding: 73994B9A08230F0008382000240884C50082502E6000000030A000000000
   VCID: 2F3B1071A7124EBF377-807A
   Subsystem 1 - Part No SW: 6R0 959 801 AF    HW: 6R0 959 801 AF  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  004 3464
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 AF    HW: 6R0 959 802 AF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  004 3464
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H09 0007
   Serial number:     WRH0004LQG.
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542 A    HW: 5K0 959 542 A
   Serial number: 0163787
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 H    HW: 6R0 959 811 H
   Component: J388__TSG_HL  004 3464
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 H    HW: 6R0 959 812 H
   Component: J389__TSG_HR  004 3464
   Coding: 800000
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   014 0808
   Serial number: 003GTM05NFWG
   Coding: 00003936
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
   ROD: EV_AirbaVW10SMEVW360.rod
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000DYLT0O
   Coding: 303042
   Serial number: 3572MSME7B2A236BZZZ2
   Serial number: 3582MSME084F656BZZZ6
   Serial number: 3516KSME011C0819ZZZL
   Serial number: 3526KSME4F0A0819ZZZ.
   Serial number: 3556LSME25196B17ZZZ-
   Serial number: 3566LSME06146B17ZZZV
   Part No SW: 5C6 920 951 AX    HW: 5C6 920 951 AX
   Component: KOMBI         H04 0604
   Coding: 270A01
   VCID: 015F86C9418608CF913-8054
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0256
   Revision: B2066001
   Coding: 102200
   VCID: 70B9D30D7AAC11476ED-8024
   Component: IMMO          H04 0604
   Coding: 000007
   Shop #: WSC 30799 001 1048576
   VCID: 6A8DC1655CF0EB97209-803E
   Part No SW: 5K0 905 861 A    HW: 5K0 905 861 A
   Component: ELV-PQ35      H20 0230
   Revision: 00000000    Serial number: 11000201982001
   Coding: 4100000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 2E050D75A09847B73C1-807A
   Revision: A1001003    Serial number: 7661467615
   Coding: 020000
   VCID: 290FFE6999F6208FE93-807C
   Part No SW: 1K0 035 274 B    HW: 1K0 035 274 B
   Component: RNS315-NAR    H35 0265
   Serial number: VWZAZ2M4215505
   Coding: 04090001010006000000100A
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_RNS315NARV2UDS A01004
   ROD: EV_RNS315NARV2UDS_VW32.rod
   VCID: 2313EC41FB5AFADFA3F-8076
   Component: NAR_V2  0002
          B11CF 53 [009] - Deactivated
                    Reset counter: 84
                    Mileage: 162961 km
                    Date: 2019.05.18
                    Time: 08:43:02
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 70     3305
   Revision: 00H22000
   VCID: 372B28115342867F6F7-8062
   Part No SW: 5C6 035 456     HW: 5C6 035 456
   Component: KonzernAmp10K H07 0468
   Revision: --------    Serial number: EAA083A0016615
   VCID: 6597B259B5EEC4EF0DB-8030
End----------(Elapsed Time: 01:25, VBatt start/end: 14.2V/14.4V)-----------
PetrolDave
Westbury, UK
C?ID=1423
We'll need to see the full Auto-Scan not just the edited fault code section.
Vwjoe29
Alberta Canada
C?ID=349077
just edited and pasted complete autoscan
thx
On the Engine, I would chase this down first:
You will need wiring diagrams.
As for the ABS fault, check/adjust tire pressures, then use the tire pressure SET switch. I'm not sure where it is on that car. It should be documented in the owner's manual.
Vwjoe29
Alberta Canada
C?ID=349077
What sensor reads cylinder misfire, because car is running very good, so that might be the sensor where the open circuit is???
When swapped wiring harness the loom was melted on the wires that go to the timing gear on rear main seal. The wires looked ok so I just replaced the loom. I should of checked the wires with a test light. So that’s a possibility. Just a PITA to get back in there to test and replace wire if needed. Always learning.
In most engines, misfires are detected based on small changes in crankshaft speed. However, in some TDIs, the cylinder pressure sensors built into the glow plugs may also play a role.
Vwjoe29
Alberta Canada
C?ID=349077
Would a specific code come up for glow plugs or crank sensor if either were not working and/or connected?
JPPSG!
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
Most likely a bad wire in the harness & from a chafe point!
FOD never sleeps!
Hint: Check wiper area for water ingress or damage and where harness rubs cylinder head!
Perform load light tests from end to end with ECU & sensors isolated.
Vwjoe29
Alberta Canada
C?ID=349077
More history on my VW Jetta tdi
I had my high pressure fuel pump seize the timing belt jumped and damaged the head.
So I did a complete engine swap and I did change wire harness because my tdi is a 6 speed manual and the engine I got was automatic. New timing belt, pulleys, CP3, new thermostat, and new clutch/flywheel.
Also the rear main seal was leaking and was replaced using the correct tool to get timing gear correctly positioned.
The code that will not clear is P06A3 the other ones will clear but come back up.
Thx
Thx
Recheck your work for induced FOD damage of harness & verify every sensor and part on engine are correct!
Vwjoe29
Alberta Canada
C?ID=349077
FOD ?
How to verify every sensor ?
Thx
