origal code was 1342401209220000C81202E5901F000823C000
When i try to enter it into the coding it comes up error 31 out or range.
anyone help with a code I can use. I have tried basic seetings before hand but just comes up error
Saturday,27,April,2019,12:28:57:42570
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUZZZ8P69A006716 License Plate: APO8VDO
Mileage: 228950km-142262mi Repair Order:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56
VIN: WAUZZZ8P69A006716 Mileage: 228950km-142262miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 BQ HW: 03L 906 022 BQ
Component: R4 2,0L EDC 0000SG 3066
Revision: --H01--- Serial number: AUX7Z0H5FNI012
Coding: 0000072
Shop #: WSC 84224 932 461222
VCID: 75B4E89959CB520FBD3-8020
008198 - Intake Manifold Flap; Bank 1
P2006 - 000 - Stuck Closed - Intermittent
Mileage: 228956 km
Date: 2019.04.26
Time: 21:19:45
RPM: 782 /min
Load: 0.0 %
Load: 4.7 %
Lambda: 16.6 %
Mass Air / Rev.: 330.0 mg/str
Temperature: 73.8°C
008196 - Intake Manifold Flap; Bank 1
P2004 - 000 - Stuck Open - Intermittent
Mileage: 228956 km
Date: 2019.04.26
Time: 21:19:46
RPM: 782 /min
Load: 0.0 %
Load: 4.7 %
Lambda: 91.5 %
Mass Air / Rev.: 335.0 mg/str
Temperature: 73.8°C
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - Intermittent
Mileage: 228956 km
Date: 2019.04.26
Time: 00:00:08
Voltage: 12.46 V
Load: 100.0 %
Load: 100.0 %
Mass Air / Rev.: 760.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Part No SW: 1K0 907 379 BD HW: 1K0 907 379 BD
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Shop #: WSC 06314 000 00000
VCID: 75B4E89955CB520FBD3-8020
Reset counter: 221
Date: 2019.04.26
Time: 00:26:36
Count: 3
Count: 20992
Count: 195
Count: 43008
Fault Status: 01100101
Reset counter: 221
Mileage: 228956 km
Date: 2019.04.26
Time: 00:24:06
Count: 3
Count: 4096
Count: 279
Count: 43264
Count: 1024
Reset counter: 221
Mileage: 228956 km
Date: 2019.04.26
Time: 00:24:06
Count: 3
Count: 4096
Count: 295
Count: 43264
Count: 1024
Reset counter: 221
Mileage: 228956 km
Date: 2019.04.26
Time: 00:24:06
Count: 3
Count: 4096
Count: 270
Count: 43264
Count: 1024
Part No SW: 8P0 820 043 BG HW: 8P0 820 043 BG
Component: KlimavollautomatH08 0100
Revision: 000264 Serial number: 8P0820043BG
VCID: 72BED38528A54537981-8026
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 221
Mileage: 228956 km
Date: 2019.04.26
Time: 00:16:36
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000008568940
Coding: F18A1F07A0141380EF00000A4F00000000084E0564060003002000000000
Shop #: WSC 06314 000 08192
VCID: 48CA516D7EB99FE7165-801C
Subsystem 1 - Part No: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Coding: 00150573
Shop #: WSC 06314
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003000000000
Coding: 303142413039303030384A55305238503053
ROD: EV_Airba10AURB4.rod
VCID: 49CC5469693366EF09B-801C
Serial number: 34928RB400003CCC184Y
Serial number: 35028RB400003D0E3A6N
Serial number: 35128RB400003CCC03DU
Serial number: 35228RB400003D0EAAC
Serial number: 35547RB400003CE961D
Serial number: 35647RB400003CE965C%
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0002012
VCID: 41DC4C495D83AEAFD1B-8014
Component: E0221 H02 0030
01304 - Radio
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H15 0820
Revision: D0H15004 Serial number: 2245H004001151
Coding: 0004428
Shop #: WSC 00128 067 57207
VCID: 392C24A93553F66F99B-806C
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K086050E43
Coding: E9811F061002020101
VCID: 35342899194B120F7D3-8060
Fault Status: 01101011
Fault Frequency: 193
Reset counter: 221
Mileage: 228605 km
Date: 2019.04.20
Time: 07:28:41
01304 - Radio
Reset counter: 218
Mileage: 228909 km
Date: 2019.04.25
Time: 08:00:06
Revision: D0H15004 Serial number: AUX7Z0H5FNI012
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 J HW: 8P0 959 801 J
Component: Tuer-SG H03 0060
Coding: 0000564
VCID: 42DE43455885B5B7C81-8016
01552 - Motor for Central Locking; Drivers Door (V56); Lock
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
VCID: 36362F95044D1917749-8062
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D2D8505489AC637
VCID: 43D04641479FBCBFC37-8016
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
01134 - Alarm Horn (H12)
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 D HW: 8P3 035 382 D
Component: AB2 SUBWOOFERBOXH30 0160
Revision: 00006 Serial number: 30659850185132
VCID: 3432159D12310B074AD-8060
Part No SW: 8P0 959 802 J HW: 8P0 959 802 J
Coding: 0000564
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 J
Component: Dynamische LWR H01 0020
Coding: 0000013
Address 56: Radio
End----(Elapsed Time: 01:02, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
