Hi guys having problems with electric parking brake scan attached
Sunday,10,March,2019,13:31:01:31334
VCDS Version: 18.9.0.2
VIN: WAUZZZ4F98N152645 License Plate: PE58 KDX
Mileage: 219300km-136266mi Repair Order:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 1E 37 42 46 47 4F 52 53
56 61 62 72 77
VIN: WAUZZZ4F98N152645 Mileage: 219300km-136266miles
Part No SW: 03G 906 016 MF HW: 03G 906 016 MF
Component: R4 2,0L EDC G000CG 1142
Revision: --H06--- Serial number:
Coding: 0000076
Shop #: WSC 66565 257 00032
VCID: 73E5A8D912CF4ED2D8-8026
006215 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Mileage: 219306 km
Date: 2007.06.11
Time: 11:56:29
Voltage: 11.32 V
Bin. Bits: 00101000
Torque: 0.0 Nm
Bin. Bits: 00000100
012547 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction - Intermittent
Voltage: 11.78 V
Bin. Bits: 00001010
Torque: 0.0 Nm
Torque: 300.1 Nm
Address 02: Auto Trans Labels: 01J-927-156.lbl
Part No SW: 4F9 910 155 B HW: 01J 927 156 JG
Component: V30 01J 2.0l PD RdW 0030
Revision: --H04--- Serial number: 00000000000366
Shop #: WSC 00561 210 181929
VCID: 2A5B75BD85854F1AAB-807E
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AC HW: 4F0 614 517 T
Component: ESP8 front H01 0070
Coding: 0020856
Shop #: WSC 02325 785 00200
VCID: 65C1C681AC1BA06246-8030
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 94
Mileage: 219306 km
Date: 2007.06.11
Time: 12:09:40
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x0035
Hex Value: 0x01AE
Hex Value: 0x00FF
Reset counter: 134
Mileage: 219306 km
Date: 2007.06.11
Time: 13:23:11
Hex Value: 0x0000
Hex Value: 0x0282
Hex Value: 0x0024
Hex Value: 0x0189
Hex Value: 0x00FF
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0240
Revision: 07020801 Serial number: 10601901093919
Coding: 0000147
Shop #: WSC 02323 785 00200
VCID: 63C5D899A22FDE52A8-8036
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H46 0080
Component: FBSAUDIC6 IDG H01 0040
Reset counter: 134
Mileage: 219306 km
Date: 2007.06.11
Time: 13:23:03
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 H HW: 4E0 035 729
Component: Interfacebox H43 5140
Revision: 00000000 Serial number: 350EX087882069
Coding: 0001002
Shop #: WSC 02335 785 00200
VCID: 285F8FB59B897D0ABD-807C
Subsystem 2 - Serial number: 00000001064094
Subsystem 3 - Serial number: 0128.04.080000000100010691ÿ
Subsystem 4 - Serial number: 010691ÿ
00003 - Control Module
Fault Status: 01100101
Reset counter: 94
Mileage: 219306 km
Date: 2007.06.11
Time: 12:06:22
Reset counter: 134
Mileage: 219306 km
Date: 2007.06.11
Time: 12:06:22
Bin. Bits: 00000000
Bin. Bits: 0010000
Bin. Bits: 000
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F2 820 043 P
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000000529749
Coding: 0001300
VCID: 1C37A365DFD1A1AA29-8048
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Coding: 0000101
VCID: 316962D1A8533CC26A-8064
Subsystem 1 - Part No: 4F2 910 113 B Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H06 0190
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02335
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 95
Mileage: 219304 km
Date: 2007.06.11
Time: 13:24:00
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H46 0390
Revision: 00046002 Serial number: AUZ5ZBH8420497
VCID: 1A3BA57DD5E5DF9A3B-804E
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 4E AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0Y6DKV
Coding: 0013381
VCID: 29598AB180834402A2-807C
Subsystem 1 - Serial number: 6332CSME33632857+
Subsystem 2 - Serial number: 6342CSME2C6449368
Subsystem 3 - Serial number: 6352QSME674C1F45V
Subsystem 4 - Serial number: 6362QSME64103A79I
Subsystem 5 - Serial number: 63734SME70682E375
Subsystem 6 - Serial number: 63834SME690C3B6FL
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055081290218
Coding: 0102142
VCID: 275D8C8996977272B4-8072
Component: E0221 H02 0030
Reset counter: 134
Mileage: 219306 km
Date: 2007.06.11
Time: 13:23:07
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 982 T
Component: KOMBIINSTR. M73 H23 0240
Revision: 00000000 Serial number: 72W33GC58
Coding: 3328458
Shop #: WSC 33299 067 57207
VCID: 23459899E2AF9E52E8-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B085158935
Coding: E5519E5770320600
VCID: 2D517EA1B46B58224E-8078
Reset counter: 94
Mileage: 219306 km
Date: 2007.06.11
Time: 13:25:29
Address 1E: Media Player 2 (R192) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 B HW: 4E0 035 785 B
Component: SG ext.Player H15 0700
Revision: 00000000
VCID: 275D8C8956977272B4-8072
Part No SW: 4E0 910 888 E HW: 4E0 919 887 M
Component: MNS ECE H51 1050
Revision: 00000000 Serial number: 364E.087787361
Shop #: WSC 00236 210 89910
VCID: 306F67D5A35935CA65-8064
Reset counter: 134
Mileage: 219306 km
Date: 2007.06.09
Time: 18:13:47
Hex Value: 0x466D
Hex Value: 0x4CBB
Hex Value: 0x0042
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: dPi
Coding: 0003610
Shop #: WSC 02327 785 00200
VCID: 2C5773A58F71512A59-8078
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H27 0220
Revision: 02200027 Serial number: 01112936120000
Coding: 0000763
02739 - Bulb for Tail/Brake Light; Right
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 238
Reset counter: 94
Mileage: 216855 km
Date: 2017.12.22
Time: 13:33:51
01134 - Alarm Horn (H12)
Reset counter: 134
Reset counter: 94
Mileage: 219306 km
Date: 2007.06.11
Time: 13:28:08
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 M HW: 4F0 035 223 N
Component: Amp.-ASK-RD H07 0270
Revision: S1400000
Coding: 010001
Shop #: WSC 02399 823 56573
VCID: 285F8FB55B897D0ABD-807C
6 Faults Found:
Fault Status: 00101011
Reset counter: 134
Mileage: 219306 km
Date: 2007.06.11
Time: 13:24:16
Voltage: 11.70 V
Temperature: 4.0°C
Bin. Bits: 00000111
00420 - Front Right DSP Midrange Speaker (R104)
Reset counter: 134
Mileage: 219306 km
Date: 2007.06.11
Time: 13:24:16
Voltage: 11.70 V
Temperature: 4.0°C
Bin. Bits: 00000111
Reset counter: 134
Mileage: 219306 km
Date: 2007.06.11
Time: 13:24:16
Voltage: 11.70 V
Temperature: 4.0°C
Bin. Bits: 00000111
00419 - Left Front DSP Midrange Speaker (R103)
Reset counter: 134
Mileage: 219306 km
Date: 2007.06.11
Time: 13:24:16
Voltage: 11.70 V
Temperature: 4.0°C
Bin. Bits: 00000111
02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
Reset counter: 134
Mileage: 219306 km
Date: 2007.06.11
Time: 13:24:16
Voltage: 11.70 V
Temperature: 5.0°C
Bin. Bits: 00000111
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
Reset counter: 134
Mileage: 219306 km
Date: 2007.06.11
Time: 13:24:16
Voltage: 11.70 V
Temperature: 5.0°C
Bin. Bits: 00000111
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000550983
Coding: 0001104
VCID: 5EB3E96D894DF3BA87-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: ƒTp
Coding: 0003610
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000131
Shop #: WSC 02145 785 00200
VCID: 204F9795F3B9854AF5-8074
Fault Status: 00101101
Reset counter: 134
Mileage: 219304 km
Date: 2007.06.11
Time: 13:36:19
Voltage: 13.15 V
Count: 236
02442 - Function Lamp in Control Head
Reset counter: 94
Mileage: 219304 km
Date: 2007.06.11
Time: 13:24:27
Voltage: 10.35 V
Count: 65
02443 - Control Head
012 - Electrical Fault in Circuit - MIL ON
Fault Status: 11101100
Reset counter: 94
Voltage: 10.97 V
Count: 40
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Revision: 00000000 Serial number: 394EV087901076
Shop #: WSC 02324 785 00200
VCID: 2E5379ADB96D233A77-807A
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000088718
VCID: 24479B85E7A1996A91-8070
Component: von VA0 2805202473
Coding: 344630393135313035442056413032383035323032343733
Shop #: WSC 00000 512 00290
02272 - Quiescent Current Stage 1
Date: 2007.06.11
Time: 12:07:21
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0003074
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0003074
Address 77: Telephone
End-------------------------(Elapsed Time: 03:27)--------------------------
