Good Morning,
Troubleshooting (or maybe just throwing hail marry parts in an attempt to "get lucky") 2006 Audi 2.0T
Started without VCDS and only OBDII-- showed cylinder 303/304 codes
Vac is a steady 15
>>Comp Test all were between 175/170
>>Smoke Test revealed no leaks, checked both sides of PCV.
>> Carbon cleaning and new intake manifold gasket
>>Replaced coils and plugs
>>Fuel PSI was good used old fashion gauge...- but replaced fuel filter.
>>N80 seems to allow about 0-5 sometimes 5-10hg through-- no vac when power removed
>> Put Fork in toaster still no luck.
>> replaced injectors, and o rings, with "bench cleaned" and check R 1.4 - no change in misfire
>>Vac is steady 15 @ idle
>>Battery replaced with H8, 900CCA
Purchased VCDS- "Hoping to find maybe another code like a P0171 would have been nice ..lol
Only Misfire codes-- "#3 at idle ~7-10 and cylinder 2 is always zero". Once I touch the throttle-- zero misfires display
At this point I suspect the wiring/the ECU because There are no other fault codes, or pulling the head to see whats inside... Car is "off the road" so plenty of time to play.
Vac is a steady 15
67 69 75 76 77
VIN: WAUDF78E16A295490 Mileage: 213180km-132463miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E0 910 115 M HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0070
Revision: --H13--- Serial number:
Coding: 0104010A190F0120
Shop #: WSC 03134 444 50336
VCID: 2B030660DF01EE2F1BF-807E
P0300 - 002 - - MIL ON
Fault Status: 11100010
Mileage: 213184 km
RPM: 665 /min
Load: 23.5 %
Temperature: 80.0°C
Temperature: 19.0°C
Absolute Pres.: 990.0 mbar
Voltage: 14.224 V
000771 - Cylinder 3
P0303 - 002 - Misfire Detected - MIL ON
Mileage: 213184 km
RPM: 650 /min
Load: 24.7 %
Temperature: 82.0°C
Temperature: 20.0°C
Voltage: 13.843 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - MIL ON
Fault Status: 11101000
Mileage: 213184 km
RPM: 650 /min
Load: 24.7 %
Temperature: 82.0°C
Temperature: 20.0°C
Voltage: 13.843 V
000769 - Cylinder 1
P0301 - 008 - Misfire Detected
Mileage: 213184 km
RPM: 1360 /min
Load: 17.6 %
Temperature: 57.0°C
Temperature: 21.0°C
Voltage: 14.224 V
Readiness: 0010 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 C HW: 09L 927 156 B
Component: AG6 09L 2.0TFSI USA 0040
Revision: --H01--- Serial number: 4161978
Shop #: WSC 06335 000 00000
VCID: 270BFA50C3E9CA4FFF7-8072
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Coding: 0004528
VCID: 2E050F74EC139B073C1-807A
Fault Frequency: 32
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x4202
Hex Value: 0x0024
Hex Value: 0x018D
Hex Value: 0x0001
18265 - Load Signal
P1857 - 000 - Error Message from ECU - Intermittent
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x6202
Hex Value: 0x0028
Hex Value: 0x018B
Hex Value: 0x0001
Fault Status: 00101101
Fault Frequency: 14
Reset counter: 40
Hex Value: 0x0000
Hex Value: 0x6202
Hex Value: 0x0025
Hex Value: 0x018B
Hex Value: 0x0001
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
VCID: 6D87C8782485201F45B-5160
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 00003
Shop #: WSC 06335
VCID: 3D2738383465709FB5B-4B00
01326 - Control Module for Multi-Function Steering Wheel (J453)
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N001U8ZK
Coding: 0032607
VCID: 3C21353C2A6F7997825-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 3BV02
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ63
Subsystem 4 - Serial number: 000000ÿ6332DRB40331CC12Hÿ63
Subsystem 5 - Serial number: 1CC12Hÿ6342DRB40336112FFÿ63
Subsystem 6 - Serial number: 6112FFÿ6352ARB401337E7CTÿ63
Subsystem 7 - Serial number: 37E7CTÿ6362ARB40133BDA8Wÿ63
Subsystem 8 - Serial number: 3BDA8Wÿ63729RB40132AEAE.ÿ63
Subsystem 9 - Serial number: 2AEAE.ÿ63829RB40132AEB2Rÿ
Subsystem 10 - Serial number: 2AEB2Rÿ
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 R
Component: Lenksáulenmodul 1102
Coding: 02021
Shop #: WSC 01312
VCID: 42DD4BC44D9B0F67C89-4B00
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 G HW: 8E0 920 951 G
Component: KOMBI+WFS 4 H14 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0023261
Shop #: WSC 01312 444 12149
VCID: 2E050F74EC039B073C1-5184
01176 - Key
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023261
01176 - Key
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4035
Coding: 11820
Shop #: WSC 06335
VCID: 78A9E92C5BC795B7A6D-4B00
Component: Tõrsteuer.FS BRM 0706
Component: Tõrsteuer.BF BRM 0706
01134 - Alarm Horn (H12)
29-10 - Short to Ground - Intermittent
49-00 - No Communications
00955 - Key 1
35-10 - - - Intermittent
00956 - Key 2
End----------(Elapsed Time: 05:55, VBatt start/end: 13.9V/13.9V)-----------
