Results 1 to 6 of 6
Thread: Audi A3 8P CECM Login code
    May 2019
    Romania
    Hello everyone,
    I am looking for the loging code for the MK5 style CECM 09 in order to be able to read the eeprom and edit the comfort time activation parameters like in the MK6 platforms.
    Is anyone aware of the login code ?
    Sunday,21,April,2019,17:04:31:23804
    VCDS Version: 18.9.1.0  HEX-NET CB: 0.4436.4
    VIN: WAUZZZ8P84A051357   License Plate: SB23XUS
    Mileage: 280460km-174269mi   Repair Order:
    Chassis Type: 8P (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 76 7D
    VIN: WAUZZZ8P84A051357   Mileage: 280460km-174269miles
    Address 01: Engine        Labels: 03G-906-016-BKC.clb
       Part No SW: 03G 906 016 J    HW: 028 101 138 3
       Component: R4 1,9L EDC G000SG  5347
       Revision: 12345678    Serial number: AUX7Z0C6FNT06F
       Coding: 0000071
       Shop #: WSC 06435 000 00000
       VCID: 2A18FBE985A3D51AA3-807E
       Part No: 1K0 907 379 D
       Coding: 0053894
       VCID: 3326E68D526994D210-8066
       Part No SW: 8P0 820 043     HW: 8P0 820 043
       Component: KlimavollautomatH11 0130
       VCID: 699A44E540251E026A-803C
    00483 - Control Module for Auxiliary Air Heater
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 174
                        Mileage: 280466 km
                        Date: 2019.04.21
                        Time: 16:57:29
    00532 - Supply Voltage B+
                        Reset counter: 190
                        Mileage: 276696 km
                        Date: 2032.00.00
                        Time: 00:00:00
                        Voltage: 8.70 V
                        Reset counter: 214
                        Mileage: 280466 km
                        Date: 2019.04.21
                        Time: 13:35:14
    Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
       Part No SW: 8P0 907 279 P    HW: 8P0 907 279 P
       Component: Bordnetz-SG     H63 2904
       Revision: 00H63000    Serial number: 00000004681726
       Coding: A98857268294109E00000000000000000009FF1F0001020E008000000000
       Shop #: WSC 16070 123 104857
       VCID: 4AD89B6925E3F51A43-801E
       Subsystem 1 - Part No: 8P1 955 119   Labels: 1TX-955-119.CLB
       Component: Wischer WWS Audi350 0130
       Coding: 16711696
       Shop #: WSC 16070
    Address 15: Airbags        Labels: 8P0-959-655-84.lbl
       Part No SW: 8P0 959 655 F    HW: 8P0 959 655 F
       Component: Airbag 8.4ED    H01 0130
       Coding: 0010602
       VCID: 45C2A8550CFD1A62AE-8010
       Part No SW: 8P0 953 549 G    HW: 8P0 953 549 G
       Component: Lenksäulenmodul H36 0070
       Coding: 0000042
       Shop #: WSC 73571 136 85310
       VCID: 42C8B3491DD32D5A8B-8016
       Part No SW: 8P0 920 930 F    HW: 8P0 920 930 F
       Component: KOMBIINSTR. VDO H25 0080
       Revision: D05         Serial number: 2246CD05000370
       Coding: 0004003
       Shop #: WSC 00001 001 00001
       VCID: 3522D8955C1D8AE23E-8060
       Part No SW: 1K0 907 530 B    HW: 1K0 907 951
       Component: Gateway         H08 0090
       Revision: 08          Serial number: 240010371891D2
       Coding: 3D0F0F42070100
       VCID: 26000FD991BBF17A87-8072
       Revision: D05         Serial number: AUX7Z0C6FNT06F
    Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
       Part No SW: 8P0 959 801 J    HW: 8P0 959 801 J
       Component: Tuer-SG         H03 0060
       Coding: 0004208
       Shop #: WSC 06314 000 00000
    Address 44: Steering Assist        Labels: 1Kx-909-143-GEN1.clb
       Part No: 1K1 909 143 L
       Component: EPS_ZFLS Kl.6       0402
       Part No: 8P0 959 433 B
       Component:    KSG          H02 0030
       Coding: 18A000587F008505488A016000
       Shop #: WSC 06435 123 12345
       VCID: 3B36CEAD7A395C92C8-806E
       Part No SW: 8P3 035 382     HW: 8P3 035 382
       Component: AB2 SUBWOOFERBOXH23 0100
       Revision: 00001       Serial number: 10000001038019
       VCID: 70AC298163FFEFCA2D-8024
    Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX2.lbl
       Part No: 8P0 959 802 G
       Component: Tuer-SG         020 0100
       Coding: 0000368
       VCID: 40CCB94113DF3F4A9D-8014
    Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
       Part No SW: 8P0 035 186     HW: 8P0 035 186
       Component: concert II EU   H52 0060
       Revision:      05S    Serial number: AUZ2Z3C1307412
       Coding: 0001001
       VCID: 6FAE2AFD7EC1F03234-803A
                        Reset counter: 213
                        Time Indication: 15
                        Bin. Bits:       10
                        Reset counter: 213
                        Time Indication: 15
    00852 - Loudspeaker(s); Front
                        Fault Status: 00101011
                        Reset counter: 211
                        Mileage: 280353 km
                        Date: 2019.04.15
                        Time: 22:55:50
    Address 76: Park Assist        Labels: 8P0-919-283.lbl
       Part No SW: 8P0 919 283     HW: 8P0 919 283
       Component: Parkhilfe 4-Kan H06 0020
       Coding: 0000003
       VCID: 78BC11A10B8FB78AE5-802C
                        Reset counter: 208
                        Mileage: 279715 km
                        Date: 2019.03.22
                        Time: 19:01:05
       Part No SW: 1K0 963 235 C    HW: 1K0 963 235 C
       Revision: 00600000    Serial number:
       VCID: 2B16FEED8A59CC1258-807E
                014 - Defective
    End----------(Elapsed Time: 01:07, VBatt start/end: 12.1V/12.0V)-----------
    Address 08: DTCs cleared
    Address 56: DTCs cleared
    Address 76: DTCs cleared
    Address 7D: DTCs cleared
    United States
    I'm not aware of a SA code for that type of 09 module but I can move this to the Tweaks sub-forum to see if anyone in that area may be able to assist.
  3. Likes Uwe, DjDvr liked this post
    Jun 2017
    How do you think to read the EEPROM with VCDS?
    May 2019
    Romania
    not with VCDS. I want to try and see if I can read it with external software but I do not know the login in code. Testing it with VCDS should show me if I can access additional adaptation channels hidden without the code and if it works read it with another software. I
    May 2019
    Romania
    Thank you.
    May 2019
    Romania
    Did no one play with adapting lights etc over adaptations in these modules ?
