Audi A3 8P CECM Login code
DjDvr
Romania
C?ID=267309
Hello everyone,
I am looking for the loging code for the MK5 style CECM 09 in order to be able to read the eeprom and edit the comfort time activation parameters like in the MK6 platforms.
Is anyone aware of the login code ?
Sunday,21,April,2019,17:04:31:23804
VCDS Version: 18.9.1.0  HEX-NET CB: 0.4436.4
VIN: WAUZZZ8P84A051357   License Plate: SB23XUS
Mileage: 280460km-174269mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 76 7D
VIN: WAUZZZ8P84A051357   Mileage: 280460km-174269miles
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 016 J    HW: 028 101 138 3
   Component: R4 1,9L EDC G000SG  5347
   Revision: 12345678    Serial number: AUX7Z0C6FNT06F
   Coding: 0000071
   Shop #: WSC 06435 000 00000
   VCID: 2A18FBE985A3D51AA3-807E
   Part No: 1K0 907 379 D
   Coding: 0053894
   VCID: 3326E68D526994D210-8066
   Part No SW: 8P0 820 043     HW: 8P0 820 043
   Component: KlimavollautomatH11 0130
   VCID: 699A44E540251E026A-803C
00483 - Control Module for Auxiliary Air Heater
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 174
                    Mileage: 280466 km
                    Date: 2019.04.21
                    Time: 16:57:29
00532 - Supply Voltage B+
                    Reset counter: 190
                    Mileage: 276696 km
                    Date: 2032.00.00
                    Time: 00:00:00
                    Voltage: 8.70 V
                    Reset counter: 214
                    Mileage: 280466 km
                    Date: 2019.04.21
                    Time: 13:35:14
Address 09: Cent. Elect.        Labels:. 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 P    HW: 8P0 907 279 P
   Component: Bordnetz-SG     H63 2904
   Revision: 00H63000    Serial number: 00000004681726
   Coding: A98857268294109E00000000000000000009FF1F0001020E008000000000
   Shop #: WSC 16070 123 104857
   VCID: 4AD89B6925E3F51A43-801E
   Subsystem 1 - Part No: 8P1 955 119   Labels: 1TX-955-119.CLB
   Component: Wischer WWS Audi350 0130
   Coding: 16711696
   Shop #: WSC 16070
Address 15: Airbags        Labels: 8P0-959-655-84.lbl
   Part No SW: 8P0 959 655 F    HW: 8P0 959 655 F
   Component: Airbag 8.4ED    H01 0130
   Coding: 0010602
   VCID: 45C2A8550CFD1A62AE-8010
   Part No SW: 8P0 953 549 G    HW: 8P0 953 549 G
   Component: Lenksäulenmodul H36 0070
   Coding: 0000042
   Shop #: WSC 73571 136 85310
   VCID: 42C8B3491DD32D5A8B-8016
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY7.lbl
   Part No SW: 8P0 920 930 F    HW: 8P0 920 930 F
   Component: KOMBIINSTR. VDO H25 0080
   Revision: D05         Serial number: 2246CD05000370
   Coding: 0004003
   Shop #: WSC 00001 001 00001
   VCID: 3522D8955C1D8AE23E-8060
   Part No SW: 1K0 907 530 B    HW: 1K0 907 951
   Component: Gateway         H08 0090
   Revision: 08          Serial number: 240010371891D2
   Coding: 3D0F0F42070100
   VCID: 26000FD991BBF17A87-8072
   Revision: D05         Serial number: AUX7Z0C6FNT06F
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 8P0 959 801 J    HW: 8P0 959 801 J
   Component: Tuer-SG         H03 0060
   Coding: 0004208
   Shop #: WSC 06314 000 00000
Address 44: Steering Assist        Labels: 1Kx-909-143-GEN1.clb
   Part No: 1K1 909 143 L
   Component: EPS_ZFLS Kl.6       0402
Address 46: Central Conv.        Labels: 8P0-959-433.lbl
   Part No: 8P0 959 433 B
   Component:    KSG          H02 0030
   Coding: 18A000587F008505488A016000
   Shop #: WSC 06435 123 12345
   VCID: 3B36CEAD7A395C92C8-806E
   Part No SW: 8P3 035 382     HW: 8P3 035 382
   Component: AB2 SUBWOOFERBOXH23 0100
   Revision: 00001       Serial number: 10000001038019
   VCID: 70AC298163FFEFCA2D-8024
Address 52: Door Elect, Pass.        Labels: 8P0-959-802-MAX2.lbl
   Part No: 8P0 959 802 G
   Component: Tuer-SG         020 0100
   Coding: 0000368
   VCID: 40CCB94113DF3F4A9D-8014
Address 56: Radio        Labels: 8P0-035-1xx-56.lbl
   Part No SW: 8P0 035 186     HW: 8P0 035 186
   Component: concert II EU   H52 0060
   Revision:      05S    Serial number: AUZ2Z3C1307412
   Coding: 0001001
   VCID: 6FAE2AFD7EC1F03234-803A
                    Reset counter: 213
                    Time Indication: 15
                    Bin. Bits:       10
                    Reset counter: 213
                    Time Indication: 15
00852 - Loudspeaker(s); Front
                    Fault Status: 00101011
                    Reset counter: 211
                    Mileage: 280353 km
                    Date: 2019.04.15
                    Time: 22:55:50
Address 76: Park Assist        Labels: 8P0-919-283.lbl
   Part No SW: 8P0 919 283     HW: 8P0 919 283
   Component: Parkhilfe 4-Kan H06 0020
   Coding: 0000003
   VCID: 78BC11A10B8FB78AE5-802C
01546 - Sensor for Parking Aid; Rear Mid-Left (G204)
                    Reset counter: 208
                    Mileage: 279715 km
                    Date: 2019.03.22
                    Time: 19:01:05
   Part No SW: 1K0 963 235 C    HW: 1K0 963 235 C
   Revision: 00600000    Serial number:
   VCID: 2B16FEED8A59CC1258-807E
            014 - Defective
End----------(Elapsed Time: 01:07, VBatt start/end: 12.1V/12.0V)-----------
Address 08: DTCs cleared
Address 56: DTCs cleared
Address 76: DTCs cleared
Address 7D: DTCs cleared
Dana
Western PA, USA
I'm not aware of a SA code for that type of 09 module but I can move this to the Tweaks sub-forum to see if anyone in that area may be able to assist.
hadez16
C?ID=289891
How do you think to read the EEPROM with VCDS?
DjDvr
Romania
C?ID=267309
:) not with VCDS. I want to try and see if I can read it with external software but I do not know the login in code. Testing it with VCDS should show me if I can access additional adaptation channels hidden without the code and if it works read it with another software. I
DjDvr
Romania
C?ID=267309
Thank you.
DjDvr
Romania
C?ID=267309
Did no one play with adapting lights etc over adaptations in these modules ?
