Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Which measuring block to monitor VNT actuator position, 2006 Jetta TDI?
    Apr 2017
    It is not MBV, you need to go in Basic settings 011 and when test starts look difference between lower and higher numbers , It can not be more then 120. Best is around 90-100.
    I usually record this with Phone then look very careful numbers.
    Once you do this , post it here and I will tell you what is your problem in second post .
    It goes from about 960 to 1050. Question about the N75 valve. Is this a solenoid, i.e. on or off? Because when I do this test with a vacuum gage in the hose to the VNT actuator it reads either 0 or 25 in. so that's expected. But outside the test, at idle, it shows 17 in. Is this normal? Shouldn't it be 0 at idle so the vanes are closed?
  2. #12
    Apr 2017
    I don't suppose you have a scan of this car from when it had stock software in it?
    Just got the car like this from the original owner. It's bone stock except for an EGR cooler delete. I wonder if it was tuned to keep the CEL off.
  3. #13
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by atikovi View Post
    That is normal , When is on Idle it has to have full Vacuum to close Vanes, When Vanes are open , there is no vacuum. So when you do Basic setting test it is normal to have full vacuum and no vacuum.
    Did you check actuator is it holding vacuum?
    Also can you check actuator at what PSI starts moving and when it stops moving what is PSI?
    Most likely tune car if no CEL.
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  4. #14
    Apr 2017
    Holds for over 5 minutes at full vacuum.
    Starts moving at 6 psi.
    Stops at 19 psi.
  5. #15
    Apr 2017
    My first attempt at making and posting logs. Anything useful? MAP and MAF sensors OK?
    Two charge pressure tests:
    Thursday	16	May	2019	14:04:44:53717-VCID:63CF59B0A2846D52A0-8036	VCDS Version: Release 18.9.1 (x64)	Data version: 20190114 DS296.0
    03G 906 016 AB		RC s01f EDC G000SG  7550
    	Group A:	'011				Group B:	 Not Running				Group C:	 Not Running
    		Engine Speed	Boost Pressure	Boost Pressure	Charge Pressure
    	TIME	(G28)	(specified)	(actual)	Control Duty Cycle	TIME					TIME
    Marker	STAMP	 /min	 mbar	 mbar	 %	STAMP					STAMP
    	0.1	0	1183.2	979.2	0
    	0.25	0	1183.2	979.2	0
    	0.42	0	1183.2	979.2	0
    	0.61	0	1183.2	979.2	0
    	0.78	0	1183.2	979.2	0
    	0.95	0	1183.2	979.2	0
    	1.14	0	1183.2	979.2	0
    	1.3	0	1183.2	979.2	0
    	1.46	0	1183.2	979.2	0
    	1.63	0	1183.2	979.2	0
    	1.8	0	1183.2	979.2	0
    	1.97	0	1183.2	979.2	0
    	2.14	0	1183.2	979.2	0
    	2.3	0	1183.2	979.2	0
    	2.48	0	1183.2	979.2	0
    	2.66	0	1183.2	979.2	0
    	2.83	0	1183.2	979.2	0
    	2.98	0	1183.2	979.2	0
    	3.16	0	1183.2	979.2	0
    	3.33	0	1183.2	979.2	0
    	3.5	0	1183.2	979.2	0
    	3.67	0	1183.2	979.2	0
    	3.83	0	1183.2	979.2	0
    	4	0	1183.2	979.2	0
    	4.19	0	1183.2	979.2	0
    	4.36	0	1183.2	979.2	0
    	4.53	0	1183.2	979.2	0
    	4.71	0	1183.2	979.2	0
    	4.87	0	1183.2	979.2	0
    	5.03	0	1183.2	979.2	0
    	5.18	0	1183.2	979.2	0
    	5.36	0	1183.2	979.2	0
    	5.53	0	1183.2	979.2	0
    	5.7	0	1183.2	979.2	0
    	5.87	0	1183.2	979.2	0
    	6.03	0	1183.2	979.2	0
    	6.2	0	1183.2	979.2	0
    	6.39	0	1183.2	979.2	0
    	6.56	0	1183.2	979.2	0
    	6.72	0	1183.2	979.2	0
    	6.9	0	1183.2	979.2	0
    	7.06	0	1183.2	979.2	0
    	7.23	0	1183.2	979.2	0
    Thursday	16	May	2019	18:38:18:53717-VCID:63CF59B0A2846D52A0-8036	VCDS Version: Release 18.9.1 (x64)	Data version: 20190114 DS296.0
    		Engine Speed	Charge Pressure	Boost Pressure	Charge Pressure
    	TIME	(G28)	Control Status	(actual)	Control Duty Cycle	TIME					TIME
    Marker	STAMP	 /min	 mg/str	 mbar	 %	STAMP					STAMP
    	0	819	3.3	979.2	67.9
    	0.18	840	3	979.2	67.9
    	0.33	819	3.6	979.2	67.9
    	0.48	819	3.3	979.2	67.9
    	0.63	840	3	979.2	67.9
    	0.8	819	3.6	979.2	67.9
    	0.95	840	3	979.2	67.9
    	1.11	819	3.6	979.2	67.9
    	1.27	840	3	979.2	67.9
    	1.44	819	3.6	979.2	67.9
    	1.59	819	3.3	979.2	67.9
    	1.75	840	3	979.2	67.9
    	1.9	819	3.6	979.2	67.9
    	2.06	840	3	979.2	67.9
    	2.22	819	3.3	979.2	67.9
    	2.37	819	3.6	979.2	67.9
    	2.53	819	3.3	979.2	67.9
    	2.7	840	3	979.2	67.9
    	2.86	819	3.6	979.2	67.9
    	3.15	819	3.3	979.2	67.9
    	3.3	819	3.6	979.2	67.9
    	3.47	819	3.3	979.2	67.9
    	3.62	819	3.6	979.2	67.9
    	3.78	840	3	979.2	67.9
    	3.96	819	3.6	979.2	67.9
    	4.11	840	3	979.2	67.9
    	4.26	819	3.6	979.2	67.9
    	4.41	840	3	979.2	67.9
    	4.58	840	3.3	979.2	67.9
    	4.74	819	3.3	979.2	67.9
    	4.89	819	3.3	979.2	67.9
    	5.05	819	3.6	979.2	67.9
    	5.22	840	3	979.2	67.9
    	5.39	819	3.6	979.2	67.9
    	5.53	819	3.3	979.2	67.9
    	5.69	819	3.6	979.2	67.9
    	5.86	840	3	979.2	67.9
    	6.02	819	3.3	979.2	67.9
    	6.17	840	3.3	979.2	67.9
    	6.33	819	3.3	979.2	67.9
    	6.5	819	3.6	979.2	67.9
    	6.66	819	3.6	979.2	67.9
    	6.81	819	3.3	979.2	67.9
    	6.97	819	3.3	979.2	67.9
    	7.14	819	3.3	979.2	67.9
    	7.3	840	3	979.2	67.9
    	7.45	819	3.6	979.2	67.9
    	7.61	819	3.3	979.2	67.9
    	7.78	840	3	979.2	67.9
    	7.94	819	3.3	979.2	67.9
    	8.09	840	3	979.2	67.9
    	8.25	819	3.3	979.2	67.9
    	8.42	819	3.3	979.2	67.9
    	8.58	819	3.6	979.2	67.9
    	8.73	840	3.3	979.2	67.9
    	8.89	819	3.3	979.2	67.9
    	9.07	819	3.3	979.2	67.9
    	9.22	819	3.3	979.2	67.9
    	9.37	840	3.3	979.2	67.9
    	9.53	840	3	979.2	67.9
    	9.7	819	3.3	979.2	67.9
    	9.86	819	3.3	979.2	67.9
    	10.01	819	3.3	979.2	67.9
    	10.17	819	3.3	979.2	67.9
    	10.34	819	3.6	979.2	67.9
    	10.5	840	3	979.2	67.9
    Thursday	16	May	2019	18:38:41:53717-VCID:63CF59B0A2846D52A0-8036	VCDS Version: Release 18.9.1 (x64)	Data version: 20190114 DS296.0
    Marker	STAMP	 /min		 mbar	 %	STAMP					STAMP
    	0	1113	ON	989.4	90.3
    	0.16	1134	ON	989.4	90.3
    	0.31	1155	ON	989.4	90.3
    	0.47	1155	ON	999.6	90.3
    	0.64	1176	ON	989.4	90.3
    	0.8	1176	ON	999.6	90.3
    	0.95	1176	ON	999.6	90.3
    	1.09	1197	ON	999.6	90.3
    	1.25	1197	ON	999.6	90.3
    	1.41	1197	ON	999.6	90.3
    	1.56	1239	ON	999.6	90.3
    	1.72	1239	ON	999.6	90.3
    	1.9	1239	ON	999.6	90.3
    	2.05	1260	ON	999.6	90.3
    	2.2	1260	ON	1009.8	90.3
    	2.36	1281	ON	999.6	90.3
    	2.53	1281	ON	1009.8	90.3
    	2.69	1302	ON	1009.8	90.3
    	2.84	1302	ON	1009.8	90.3
    	3	1302	ON	1009.8	90.3
    	3.17	1302	ON	1009.8	90.3
    	3.33	1323	ON	1009.8	90.3
    	3.48	1344	ON	1009.8	90.3
    	3.64	1344	ON	1009.8	90.3
    	3.81	1344	ON	1009.8	90.3
    	3.97	1365	ON	1009.8	90.3
    	4.12	1386	ON	1009.8	90.3
    	4.28	1386	ON	1009.8	90.3
    	4.45	1386	ON	1020	90.3
    	4.61	1407	ON	1020	90.3
    	4.76	1407	ON	1020	90.3
    	4.92	1386	ON	1020	90.3
    	5.09	1386	ON	1020	90.3
    	5.25	1386	ON	1020	90.3
    	5.4	1407	ON	1020	90.3
    	5.56	1428	OFF	1020	9.9
    	5.73	1407	OFF	1009.8	9.9
    	5.89	1407	OFF	989.4	9.9
    	6.03	1407	OFF	979.2	9.9
    	6.19	1407	OFF	969	9.9
    	6.36	1407	OFF	969	9.9
    	6.52	1407	OFF	958.8	9.9
    	6.68	1386	OFF	958.8	9.9
    	6.84	1407	OFF	958.8	9.9
    	7.02	1428	OFF	958.8	9.9
    	7.16	1407	OFF	958.8	9.9
    	7.31	1407	OFF	958.8	9.9
    	7.47	1407	OFF	958.8	9.9
    	7.64	1407	OFF	958.8	9.9
    	7.8	1407	OFF	958.8	9.9
    	7.96	1407	OFF	958.8	9.9
    	8.12	1407	OFF	958.8	9.9
    	8.28	1386	OFF	958.8	9.9
    	8.44	1407	OFF	958.8	9.9
    	8.59	1407	OFF	958.8	9.9
    	8.75	1386	OFF	958.8	9.9
    	8.92	1386	OFF	958.8	9.9
    	9.08	1407	OFF	958.8	9.9
    	9.23	1407	OFF	958.8	9.9
    	9.39	1407	OFF	958.8	9.9
    	9.56	1407	OFF	958.8	9.9
    	9.72	1407	OFF	958.8	9.9
    	9.87	1407	OFF	958.8	9.9
    	10.03	1386	OFF	958.8	9.9
    	10.2	1386	OFF	958.8	9.9
    	10.36	1386	OFF	958.8	9.9
    	10.51	1407	OFF	958.8	9.9
    	10.67	1407	OFF	958.8	9.9
    	10.84	1407	OFF	958.8	9.9
    	11	1407	OFF	958.8	9.9
    	11.15	1407	OFF	958.8	9.9
    	11.31	1407	OFF	958.8	9.9
    	11.48	1407	OFF	958.8	9.9
    	11.64	1386	OFF	958.8	9.9
    	11.79	1407	OFF	958.8	9.9
    	11.95	1407	OFF	958.8	9.9
    	12.13	1407	OFF	958.8	9.9
    	12.28	1386	OFF	958.8	9.9
    	12.43	1386	OFF	958.8	9.9
    	12.57	1407	OFF	958.8	9.9
    	12.73	1407	OFF	958.8	9.9
    	12.89	1407	OFF	958.8	9.9
    	13.04	1386	OFF	958.8	9.9
    	13.2	1407	OFF	958.8	9.9
    	13.37	1407	OFF	958.8	9.9
    	13.53	1407	OFF	958.8	9.9
    	13.68	1386	OFF	958.8	9.9
    	13.84	1407	OFF	958.8	9.9
    	14.01	1407	OFF	958.8	9.9
    	14.17	1407	OFF	958.8	9.9
    	14.32	1386	OFF	958.8	9.9
    	14.48	1386	OFF	958.8	9.9
    	14.65	1407	OFF	958.8	9.9
    	14.81	1407	OFF	958.8	9.9
    	14.96	1407	OFF	958.8	9.9
    	15.12	1407	OFF	958.8	9.9
    	15.29	1407	OFF	958.8	9.9
    	15.44	1407	ON	958.8	90.3
    	15.59	1407	ON	958.8	90.3
    	15.74	1386	ON	958.8	90.3
    	15.92	1386	ON	969	90.3
    	16.07	1407	ON	979.2	90.3
    	16.23	1407	ON	989.4	90.3
    	16.38	1386	ON	999.6	90.3
    	16.56	1386	ON	999.6	90.3
    	16.71	1407	ON	1009.8	90.3
    	16.87	1407	ON	1009.8	90.3
    	17.02	1407	ON	1009.8	90.3
    	17.2	1386	ON	1020	90.3
    	17.35	1407	ON	1020	90.3
    	17.51	1407	ON	1020	90.3
    	17.66	1407	ON	1020	90.3
    	17.84	1407	ON	1020	90.3
    	17.99	1386	ON	1030.2	90.3
    	18.15	1386	ON	1030.2	90.3
    	18.3	1407	ON	1030.2	90.3
    	18.47	1407	ON	1030.2	90.3
    	18.63	1407	ON	1030.2	90.3
    	18.79	1386	ON	1030.2	90.3
    	18.94	1407	ON	1030.2	90.3
    	19.12	1407	ON	1030.2	90.3
    	19.27	1407	ON	1030.2	90.3
    	19.43	1386	ON	1030.2	90.3
    	19.58	1407	ON	1030.2	90.3
    	19.75	1407	ON	1030.2	90.3
    	19.91	1407	ON	1030.2	90.3
    	20.07	1386	ON	1030.2	90.3
    	20.22	1386	ON	1030.2	90.3
    	20.4	1407	ON	1030.2	90.3
    	20.54	1407	ON	1030.2	90.3
    	20.71	1407	ON	1030.2	90.3
    	20.85	1407	ON	1030.2	90.3
    	21.02	1407	ON	1030.2	90.3
    	21.17	1407	ON	1030.2	90.3
    	21.31	1407	ON	1030.2	90.3
    	21.46	1407	ON	1030.2	90.3
    	21.63	1407	ON	1030.2	90.3
    	21.78	1407	ON	1030.2	90.3
    	21.93	1407	ON	1030.2	90.3
    	22.08	1386	ON	1030.2	90.3
    	22.25	1386	ON	1030.2	90.3
    	22.4	1407	ON	1030.2	90.3
    	22.55	1386	ON	1030.2	90.3
    	22.72	1386	ON	1030.2	90.3
    	22.89	1386	ON	1030.2	90.3
    	23.04	1407	ON	1030.2	90.3
    	23.19	1407	ON	1030.2	90.3
    	23.33	1407	ON	1030.2	90.3
    	23.51	1407	ON	1030.2	90.3
    	23.66	1407	ON	1030.2	90.3
    	23.82	1407	ON	1030.2	90.3
    	23.97	1386	ON	1030.2	90.3
    	24.15	1386	ON	1030.2	90.3
    	24.3	1407	ON	1030.2	90.3
    	24.46	1407	ON	1030.2	90.3
    	24.61	1386	ON	1030.2	90.3
    	24.77	1386	ON	1030.2	90.3
    	24.93	1407	ON	1030.2	90.3
    	25.08	1407	ON	1030.2	90.3
    	25.24	1407	ON	1030.2	90.3
    	25.41	1386	ON	1030.2	90.3
    	25.57	1428	OFF	1030.2	9.9
    	25.72	1428	OFF	1009.8	9.9
    	25.88	1428	OFF	999.6	9.9
    	26.05	1407	OFF	979.2	9.9
    	26.21	1407	OFF	979.2	9.9
    	26.36	1407	OFF	969	9.9
    	26.52	1407	OFF	969	9.9
    	26.69	1407	OFF	969	9.9
    	26.85	1407	OFF	958.8	9.9
    	27	1407	OFF	958.8	9.9
    	27.16	1407	OFF	958.8	9.9
    	27.34	1407	OFF	958.8	9.9
    	27.49	1407	OFF	958.8	9.9
    	27.64	1386	OFF	958.8	9.9
    	27.8	1407	OFF	958.8	9.9
    	27.97	1407	OFF	958.8	9.9
    	28.13	1407	OFF	958.8	9.9
    	28.28	1386	OFF	958.8	9.9
    	28.44	1386	OFF	958.8	9.9
    	28.61	1407	OFF	958.8	9.9
    	28.77	1407	OFF	958.8	9.9
    	28.92	1407	OFF	958.8	9.9
    	29.08	1386	OFF	958.8	9.9
    	29.25	1407	OFF	958.8	9.9
    	29.41	1407	OFF	958.8	9.9
    	29.56	1407	OFF	958.8	9.9
    	29.72	1407	OFF	958.8	9.9
    	29.89	1407	OFF	958.8	9.9
    	30.05	1386	OFF	958.8	9.9
    	30.2	1407	OFF	958.8	9.9
    	30.36	1407	OFF	958.8	9.9
    	30.53	1386	OFF	958.8	9.9
    	30.69	1407	OFF	958.8	9.9
    	30.84	1428	OFF	958.8	9.9
    	31.17	1407	OFF	958.8	9.9
    	31.33	1386	OFF	958.8	9.9
    	31.48	1407	OFF	958.8	9.9
    	31.64	1407	OFF	958.8	9.9
    	31.81	1407	OFF	958.8	9.9
    	31.97	1386	OFF	958.8	9.9
    	32.12	1386	OFF	958.8	9.9
    	32.28	1407	OFF	958.8	9.9
    	32.46	1428	OFF	958.8	9.9
    	32.61	1386	OFF	958.8	9.9
    	32.76	1407	OFF	958.8	9.9
    	32.92	1407	OFF	958.8	9.9
    	33.09	1407	OFF	958.8	9.9
    	33.25	1407	OFF	958.8	9.9
    	33.4	1407	OFF	958.8	9.9
    	33.56	1386	OFF	958.8	9.9
    	33.73	1407	OFF	958.8	9.9
    	33.89	1407	OFF	958.8	9.9
    	34.04	1407	OFF	958.8	9.9
    	34.2	1386	OFF	958.8	9.9
    	34.37	1407	OFF	958.8	9.9
    	34.53	1407	OFF	958.8	9.9
    	34.68	1407	OFF	958.8	9.9
    	34.83	1386	OFF	958.8	9.9
    	35.01	1386	OFF	958.8	9.9
    	35.17	1407	OFF	958.8	9.9
    	35.32	1407	OFF	958.8	9.9
    	35.48	1386	ON	958.8	90.3
    	35.65	1386	ON	958.8	90.3
    	35.81	1386	ON	969	90.3
    	35.96	1407	ON	979.2	90.3
    	36.12	1386	ON	989.4	90.3
    	36.28	1386	ON	999.6	90.3
    	36.44	1407	ON	999.6	90.3
    	36.59	1407	ON	1009.8	90.3
    	36.76	1407	ON	1009.8	90.3
    	36.92	1386	ON	1009.8	90.3
    	37.09	1386	ON	1020	90.3
    	37.24	1386	ON	1020	90.3
    	37.4	1407	ON	1020	90.3
    	37.57	1407	ON	1030.2	90.3
    	37.72	1386	ON	1020	90.3
    	37.87	1407	ON	1030.2	90.3
    	38.03	1407	ON	1030.2	90.3
    	38.2	1407	ON	1030.2	90.3
    	38.36	1386	ON	1030.2	90.3
    	38.51	1407	ON	1030.2	90.3
    	38.67	1407	ON	1030.2	90.3
    	38.84	1407	ON	1030.2	90.3
    	39	1407	ON	1030.2	90.3
    	39.15	1386	ON	1030.2	90.3
    	39.31	1386	ON	1030.2	90.3
    	39.48	1407	ON	1030.2	90.3
    	39.64	1407	ON	1030.2	90.3
    	39.79	1407	ON	1030.2	90.3
    	39.95	1386	ON	1030.2	90.3
    	40.12	1407	ON	1030.2	90.3
    	40.28	1407	ON	1030.2	90.3
    	40.43	1407	ON	1030.2	90.3
    	40.59	1386	ON	1030.2	90.3
    	40.76	1386	ON	1030.2	90.3
    	40.92	1407	ON	1030.2	90.3
    	41.07	1407	ON	1030.2	90.3
    	41.23	1386	ON	1030.2	90.3
    	41.4	1386	ON	1030.2	90.3
    	41.56	1407	ON	1030.2	90.3
    	41.71	1407	ON	1030.2	90.3
    	41.87	1407	ON	1030.2	90.3
    	42.04	1407	ON	1030.2	90.3
    	42.2	1386	ON	1030.2	90.3
    	42.35	1407	ON	1030.2	90.3
    	42.51	1407	ON	1030.2	90.3
    	42.69	1386	ON	1030.2	90.3
    	42.84	1386	ON	1030.2	90.3
    	42.99	1407	ON	1030.2	90.3
    	43.15	1407	ON	1030.2	90.3
    	43.32	1407	ON	1030.2	90.3
    	43.48	1407	ON	1030.2	90.3
    	43.63	1407	ON	1030.2	90.3
    	43.79	1407	ON	1030.2	90.3
    	43.97	1407	ON	1030.2	90.3
    	44.12	1407	ON	1030.2	90.3
    	44.27	1386	ON	1030.2	90.3
    	44.43	1407	ON	1030.2	90.3
    	44.6	1407	ON	1030.2	90.3
    	44.76	1407	ON	1030.2	90.3
    	45.09	1386	ON	1030.2	90.3
    	45.18	1407	ON	1030.2	90.3
    	45.33	1386	ON	1030.2	90.3
    	45.49	1407	OFF	1030.2	9.9
    	45.65	1428	OFF	1020	9.9
    	45.82	1428	OFF	999.6	9.9
    	45.97	1407	OFF	989.4	9.9
    	46.12	1407	OFF	979.2	9.9
    	46.27	1407	OFF	979.2	9.9
    	46.45	1407	OFF	969	9.9
    	46.6	1407	OFF	969	9.9
    	46.75	1407	OFF	969	9.9
    	46.89	1407	OFF	958.8	9.9
    	47.05	1407	OFF	958.8	9.9
    	47.21	1407	OFF	958.8	9.9
    	47.36	1407	OFF	958.8	9.9
    	47.5	1407	OFF	958.8	9.9
    	47.66	1407	OFF	958.8	9.9
    	47.82	1386	OFF	958.8	9.9
    	47.97	1386	OFF	958.8	9.9
    	48.13	1407	OFF	958.8	9.9
    	48.31	1407	OFF	958.8	9.9
    	48.46	1407	OFF	958.8	9.9
    	48.61	1407	OFF	958.8	9.9
    	48.77	1407	OFF	958.8	9.9
    	48.94	1407	OFF	958.8	9.9
    	49.1	1407	OFF	958.8	9.9
    	49.25	1386	OFF	958.8	9.9
    	49.41	1407	OFF	958.8	9.9
    	49.57	1386	OFF	958.8	9.9
    	49.73	1407	OFF	958.8	9.9
    	49.88	1386	OFF	958.8	9.9
    	50.05	1386	OFF	958.8	9.9
    Thursday	16	May	2019	19:15:38:53717-VCID:63CF59B0A2846D52A0-8036	VCDS Version: Release 18.9.1 (x64)	Data version: 20190114 DS296.0
    	0	840	5.8	989.4	67.9
    	0.16	819	6.3	989.4	67.9
    	0.31	840	6	989.4	67.9
    	0.47	840	5.8	989.4	67.9
    	0.65	840	5.5	999.6	67.9
    	0.8	840	5.8	999.6	67.9
    	0.95	840	5.5	999.6	67.9
    	1.11	840	5.5	999.6	67.9
    	1.28	819	6	999.6	67.9
    	1.44	819	5.8	999.6	67.9
    	1.59	819	5.8	999.6	67.9
    	1.75	819	5.8	999.6	67.9
    	2.04	819	5.8	999.6	67.9
    	2.19	819	5.8	999.6	67.9
    	2.34	819	6	999.6	67.9
    	2.5	840	5.5	999.6	67.9
    	2.67	840	5.5	999.6	67.9
    	2.83	840	5.5	999.6	67.9
    	2.98	819	5.5	999.6	67.9
    	3.14	819	5.8	999.6	67.9
    	3.31	819	5.8	999.6	67.9
    	3.46	819	6	999.6	67.9
    	3.59	840	5.5	999.6	67.9
    	3.75	819	5.8	999.6	67.9
    	3.92	819	5.8	999.6	67.9
    	4.07	840	5.5	999.6	67.9
    	4.22	819	5.5	999.6	67.9
    	4.36	819	5.8	1009.8	67.9
    	4.53	819	5.8	1009.8	67.9
    	4.69	840	5.5	1009.8	67.9
    	4.85	819	5.8	1009.8	67.9
    	4.99	819	5.5	1009.8	67.9
    	5.16	840	5.5	1009.8	67.9
    	5.32	819	5.8	1009.8	67.9
    	5.47	819	5.5	1009.8	67.9
    	5.63	819	5.5	1009.8	67.9
    	5.81	840	5.5	1009.8	67.9
    	5.97	819	5.5	1009.8	67.9
    	6.13	840	5.2	1009.8	67.9
    	6.28	819	5.5	1009.8	67.9
    	6.46	819	6	1009.8	67.9
    	6.61	840	5.5	1009.8	67.9
    	6.76	819	5.5	999.6	67.9
    	6.91	819	5.5	1009.8	67.9
    	7.08	819	5.5	1009.8	67.9
    	7.23	819	5.5	1009.8	67.9
    Thursday	16	May	2019	19:15:53:53717-VCID:63CF59B0A2846D52A0-8036	VCDS Version: Release 18.9.1 (x64)	Data version: 20190114 DS296.0
    	0	1197	ON	1030.2	90.3
    	0.16	1176	ON	1030.2	90.3
    	0.33	1197	ON	1030.2	90.3
    	0.48	1218	ON	1030.2	90.3
    	0.62	1218	ON	1040.4	90.3
    	0.77	1239	ON	1040.4	90.3
    	0.95	1239	ON	1040.4	90.3
    	1.11	1239	ON	1040.4	90.3
    	1.27	1260	ON	1040.4	90.3
    	1.42	1260	ON	1040.4	90.3
    	1.59	1281	ON	1040.4	90.3
    	1.75	1281	ON	1040.4	90.3
    	1.91	1302	ON	1040.4	90.3
    	2.06	1302	ON	1040.4	90.3
    	2.24	1323	ON	1040.4	90.3
    	2.39	1323	ON	1040.4	90.3
    	2.54	1344	ON	1040.4	90.3
    	2.68	1344	ON	1050.6	90.3
    	2.84	1365	ON	1050.6	90.3
    	3	1365	ON	1050.6	90.3
    	3.15	1365	ON	1050.6	90.3
    	3.31	1386	ON	1050.6	90.3
    	3.48	1407	ON	1050.6	90.3
    	3.64	1407	ON	1050.6	90.3
    	3.79	1386	ON	1050.6	90.3
    	3.93	1407	ON	1050.6	90.3
    	4.09	1407	ON	1060.8	90.3
    	4.25	1407	ON	1060.8	90.3
    	4.4	1407	ON	1060.8	90.3
    	4.56	1407	ON	1060.8	90.3
    	4.73	1407	OFF	1060.8	9.9
    	4.89	1407	OFF	1060.8	9.9
    	5.04	1407	OFF	1040.4	9.9
    	5.2	1407	OFF	1020	9.9
    	5.37	1428	OFF	1009.8	9.9
    	5.53	1407	OFF	999.6	9.9
    	5.68	1407	OFF	989.4	9.9
    	5.84	1407	OFF	989.4	9.9
    	6.02	1407	OFF	979.2	9.9
    	6.17	1386	OFF	979.2	9.9
    	6.32	1386	OFF	979.2	9.9
    	6.48	1407	OFF	979.2	9.9
    	6.64	1407	OFF	979.2	9.9
    	6.81	1407	OFF	979.2	9.9
    	6.95	1407	OFF	979.2	9.9
    	7.12	1407	OFF	979.2	9.9
    	7.29	1407	OFF	979.2	9.9
    	7.44	1386	OFF	979.2	9.9
    	7.6	1386	OFF	979.2	9.9
    	7.76	1407	OFF	979.2	9.9
    	7.92	1407	OFF	979.2	9.9
    	8.08	1407	OFF	979.2	9.9
    	8.23	1407	OFF	979.2	9.9
    	8.39	1407	OFF	979.2	9.9
    	8.56	1407	OFF	979.2	9.9
    	8.72	1386	OFF	979.2	9.9
    	8.87	1386	OFF	979.2	9.9
    	9.03	1407	OFF	979.2	9.9
    	9.2	1407	OFF	979.2	9.9
    	9.36	1386	OFF	979.2	9.9
    	9.52	1407	OFF	979.2	9.9
    	9.67	1407	OFF	979.2	9.9
    	9.84	1407	OFF	979.2	9.9
    	10	1386	OFF	979.2	9.9
    	10.15	1386	OFF	979.2	9.9
    	10.31	1407	OFF	979.2	9.9
    	10.48	1407	OFF	979.2	9.9
    	10.64	1386	OFF	979.2	9.9
    	10.79	1407	OFF	979.2	9.9
    	10.95	1428	OFF	979.2	9.9
    	11.13	1407	OFF	979.2	9.9
    	11.28	1386	OFF	979.2	9.9
    	11.43	1386	OFF	979.2	9.9
    	11.59	1407	OFF	979.2	9.9
    	11.76	1407	OFF	979.2	9.9
    	11.92	1386	OFF	979.2	9.9
    	12.07	1407	OFF	979.2	9.9
    	12.23	1407	OFF	979.2	9.9
    	12.4	1407	OFF	979.2	9.9
    	12.56	1386	OFF	979.2	9.9
    	12.71	1407	OFF	979.2	9.9
    	12.87	1407	OFF	979.2	9.9
    	13.04	1407	OFF	979.2	9.9
    	13.2	1386	OFF	979.2	9.9
    	13.35	1407	OFF	979.2	9.9
    	13.51	1428	OFF	979.2	9.9
    	13.68	1407	OFF	979.2	9.9
    	13.84	1386	OFF	979.2	9.9
    	13.99	1407	OFF	979.2	9.9
    	14.13	1407	OFF	979.2	9.9
    	14.29	1386	OFF	979.2	9.9
    	14.45	1386	OFF	979.2	9.9
    	14.6	1407	OFF	979.2	9.9
    	14.76	1407	ON	979.2	90.3
    	14.93	1386	ON	979.2	90.3
    	15.09	1386	ON	989.4	90.3
    	15.24	1407	ON	999.6	90.3
    	15.4	1407	ON	1009.8	90.3
    	15.57	1386	ON	1020	90.3
    	15.73	1386	ON	1030.2	90.3
    	15.88	1407	ON	1040.4	90.3
    	16.04	1407	ON	1040.4	90.3
    	16.22	1386	ON	1050.6	90.3
    	16.36	1407	ON	1050.6	90.3
    	16.51	1428	ON	1050.6	90.3
    	16.66	1386	ON	1050.6	90.3
    	16.84	1386	ON	1060.8	90.3
    	16.99	1407	ON	1060.8	90.3
    	17.15	1407	ON	1060.8	90.3
    	17.3	1407	ON	1060.8	90.3
    	17.48	1386	ON	1060.8	90.3
    	17.63	1407	ON	1060.8	90.3
    	17.79	1407	ON	1060.8	90.3
    	17.94	1386	ON	1060.8	90.3
    	18.12	1386	ON	1060.8	90.3
    	18.27	1407	ON	1060.8	90.3
    	18.43	1407	ON	1060.8	90.3
    	18.58	1407	ON	1060.8	90.3
    	18.76	1386	ON	1060.8	90.3
    	18.91	1407	ON	1060.8	90.3
    	19.07	1428	ON	1060.8	90.3
    	19.22	1386	ON	1060.8	90.3
    	19.4	1386	ON	1060.8	90.3
    	19.55	1407	ON	1060.8	90.3
    	19.7	1407	ON	1050.6	90.3
    	19.86	1386	ON	1060.8	90.3
    	20.04	1386	ON	1050.6	90.3
    	20.19	1407	ON	1050.6	90.3
    	20.35	1407	ON	1050.6	90.3
    	20.5	1386	ON	1050.6	90.3
    	20.68	1386	ON	1050.6	90.3
    	20.83	1407	ON	1050.6	90.3
    	20.98	1407	ON	1050.6	90.3
    	21.14	1407	ON	1050.6	90.3
    	21.32	1386	ON	1050.6	90.3
    	21.48	1407	ON	1050.6	90.3
    	21.63	1407	ON	1050.6	90.3
    	21.79	1386	ON	1050.6	90.3
    	21.96	1386	ON	1050.6	90.3
    	22.12	1407	ON	1050.6	90.3
    	22.28	1407	ON	1050.6	90.3
    	22.44	1407	ON	1050.6	90.3
    	22.61	1386	ON	1050.6	90.3
    	22.76	1407	ON	1050.6	90.3
    	22.91	1407	ON	1050.6	90.3
    	23.07	1386	ON	1050.6	90.3
    	23.24	1386	ON	1050.6	90.3
    	23.4	1407	ON	1050.6	90.3
    	23.55	1407	ON	1050.6	90.3
    	23.71	1386	ON	1050.6	90.3
    	23.88	1386	ON	1050.6	90.3
    	24.04	1407	ON	1050.6	90.3
    	24.19	1407	ON	1050.6	90.3
    	24.35	1386	ON	1050.6	90.3
    	24.52	1407	ON	1050.6	90.3
    	24.68	1407	OFF	1050.6	9.9
    	24.83	1428	OFF	1050.6	9.9
    	24.99	1407	OFF	1030.2	9.9
    	25.16	1407	OFF	1020	9.9
    	25.32	1407	OFF	999.6	9.9
    	25.47	1407	OFF	999.6	9.9
    	25.63	1407	OFF	989.4	9.9
    	25.8	1407	OFF	989.4	9.9
    	25.96	1407	OFF	989.4	9.9
    	26.11	1407	OFF	979.2	9.9
    	26.27	1386	OFF	979.2	9.9
    	26.45	1386	OFF	979.2	9.9
    	26.6	1407	OFF	979.2	9.9
    	26.75	1407	OFF	979.2	9.9
    	26.91	1386	OFF	979.2	9.9
    	27.08	1407	OFF	979.2	9.9
    	27.24	1407	OFF	979.2	9.9
    	27.39	1407	OFF	979.2	9.9
    	27.55	1386	OFF	979.2	9.9
    	27.72	1386	OFF	979.2	9.9
    	27.87	1407	OFF	979.2	9.9
    	28.02	1407	OFF	979.2	9.9
    	28.17	1386	OFF	979.2	9.9
    	28.35	1386	OFF	979.2	9.9
    	28.5	1407	OFF	979.2	9.9
    	28.66	1407	OFF	979.2	9.9
    	28.81	1386	OFF	979.2	9.9
    	28.99	1407	OFF	979.2	9.9
    	29.14	1407	OFF	979.2	9.9
    	29.3	1407	OFF	979.2	9.9
    	29.45	1386	OFF	979.2	9.9
    	29.63	1386	OFF	979.2	9.9
    	29.78	1407	OFF	979.2	9.9
    	29.94	1407	OFF	979.2	9.9
    	30.09	1407	OFF	979.2	9.9
    	30.27	1407	OFF	979.2	9.9
    	30.42	1407	OFF	979.2	9.9
    	30.58	1407	OFF	979.2	9.9
    	30.73	1386	OFF	979.2	9.9
    	30.91	1386	OFF	979.2	9.9
    	31.06	1407	OFF	979.2	9.9
    	31.22	1407	OFF	979.2	9.9
    	31.37	1386	OFF	979.2	9.9
    	31.56	1386	OFF	979.2	9.9
    	31.72	1407	OFF	979.2	9.9
    	31.87	1407	OFF	979.2	9.9
    	32.03	1386	OFF	979.2	9.9
    	32.2	1407	OFF	979.2	9.9
    	32.36	1407	OFF	979.2	9.9
    	32.51	1407	OFF	979.2	9.9
    	32.67	1407	OFF	979.2	9.9
    	32.84	1407	OFF	979.2	9.9
    	33	1407	OFF	979.2	9.9
    	33.15	1407	OFF	979.2	9.9
    	33.31	1386	OFF	979.2	9.9
    	33.48	1386	OFF	979.2	9.9
    	33.64	1407	OFF	979.2	9.9
    	33.79	1407	OFF	979.2	9.9
    	33.95	1386	OFF	979.2	9.9
    	34.11	1407	OFF	979.2	9.9
    	34.27	1407	OFF	979.2	9.9
    	34.43	1407	OFF	979.2	9.9
    	34.58	1386	OFF	979.2	9.9
    	34.75	1407	ON	979.2	90.3
    	34.92	1407	ON	979.2	90.3
    	35.07	1386	ON	989.4	90.3
    	35.23	1386	ON	999.6	90.3
    	35.4	1407	ON	1009.8	90.3
    	35.56	1407	ON	1020	90.3
    	35.7	1407	ON	1030.2	90.3
    	35.86	1386	ON	1040.4	90.3
    	36.03	1386	ON	1040.4	90.3
    	36.19	1407	ON	1050.6	90.3
    	36.34	1386	ON	1050.6	90.3
    	36.5	1386	ON	1050.6	90.3
    	36.68	1407	ON	1050.6	90.3
    	36.83	1407	ON	1050.6	90.3
    	36.99	1407	ON	1060.8	90.3
    	37.14	1386	ON	1060.8	90.3
    	37.32	1386	ON	1060.8	90.3
    	37.48	1407	ON	1060.8	90.3
    	37.62	1407	ON	1060.8	90.3
    	37.78	1386	ON	1060.8	90.3
    	37.95	1407	ON	1060.8	90.3
    	38.11	1407	ON	1060.8	90.3
    	38.26	1407	ON	1060.8	90.3
    	38.42	1386	ON	1060.8	90.3
    	38.59	1386	ON	1060.8	90.3
    	38.75	1407	ON	1060.8	90.3
    	38.9	1407	ON	1060.8	90.3
    	39.06	1386	ON	1060.8	90.3
    	39.23	1407	ON	1060.8	90.3
    	39.39	1407	ON	1060.8	90.3
    	39.54	1407	ON	1060.8	90.3
    	39.7	1407	ON	1060.8	90.3
    	39.87	1386	ON	1060.8	90.3
    	40.03	1407	ON	1060.8	90.3
    	40.18	1407	ON	1060.8	90.3
    	40.34	1386	ON	1060.8	90.3
    	40.51	1407	ON	1060.8	90.3
    	40.67	1407	ON	1060.8	90.3
    	40.82	1407	ON	1060.8	90.3
    	40.98	1386	ON	1060.8	90.3
    	41.15	1386	ON	1060.8	90.3
    	41.31	1407	ON	1050.6	90.3
    	41.46	1407	ON	1050.6	90.3
    	41.62	1386	ON	1050.6	90.3
    	41.8	1407	ON	1050.6	90.3
    	41.95	1407	ON	1050.6	90.3
    	42.1	1386	ON	1050.6	90.3
    	42.26	1386	ON	1050.6	90.3
    	42.43	1407	ON	1050.6	90.3
    	42.59	1407	ON	1050.6	90.3
    	42.74	1407	ON	1050.6	90.3
    	42.9	1386	ON	1050.6	90.3
    	43.07	1407	ON	1050.6	90.3
    	43.23	1407	ON	1050.6	90.3
    	43.38	1407	ON	1050.6	90.3
    	43.54	1407	ON	1050.6	90.3
    	43.71	1407	ON	1050.6	90.3
    	43.87	1407	ON	1050.6	90.3
    	44.02	1407	ON	1050.6	90.3
    	44.18	1386	ON	1050.6	90.3
    	44.35	1407	ON	1050.6	90.3
    	44.51	1407	ON	1050.6	90.3
    	44.66	1386	OFF	1050.6	90.3
    	44.82	1428	OFF	1050.6	9.9
    	44.99	1428	OFF	1030.2	9.9
    	45.15	1407	OFF	1020	9.9
    	45.3	1407	OFF	1009.8	9.9
    	45.46	1407	OFF	999.6	9.9
    	45.63	1407	OFF	989.4	9.9
    	45.79	1407	OFF	989.4	9.9
    	45.94	1407	OFF	989.4	9.9
    	46.1	1407	OFF	979.2	9.9
    	46.43	1407	OFF	979.2	9.9
    	46.58	1407	OFF	979.2	9.9
    	46.74	1407	OFF	979.2	9.9
    	46.92	1386	OFF	979.2	9.9
    	47.07	1407	OFF	979.2	9.9
    	47.22	1386	OFF	979.2	9.9
    	47.38	1407	OFF	979.2	9.9
    	47.55	1407	OFF	979.2	9.9
    	47.71	1407	OFF	979.2	9.9
    	47.86	1386	OFF	979.2	9.9
    	48.02	1386	OFF	979.2	9.9
    	48.19	1386	OFF	979.2	9.9
    	48.35	1407	OFF	979.2	9.9
    	48.5	1407	OFF	969	9.9
    	48.65	1407	OFF	969	9.9
    	48.82	1407	OFF	969	9.9
    	48.99	1407	OFF	969	9.9
    	49.13	1386	OFF	969	9.9
    	49.29	1386	OFF	969	9.9
    	49.46	1386	OFF	969	9.9
    	49.62	1407	OFF	969	9.9
    	49.78	1386	OFF	969	9.9
    	49.94	1386	OFF	969	9.9
    	50.11	1407	OFF	969	9.9
    	50.27	1407	OFF	969	9.9
    	50.42	1407	OFF	969	9.9
    	50.57	1407	OFF	969	9.9
    	50.74	1386	OFF	969	9.9
    	50.9	1407	OFF	969	9.9
    	51.05	1386	OFF	969	9.9
    	51.21	1386	OFF	969	9.9
    	51.38	1407	OFF	969	9.9
    	51.54	1428	OFF	969	9.9
    	51.69	1386	OFF	969	9.9
    	51.86	1407	OFF	969	9.9
    	52.03	1407	OFF	969	9.9
    	52.18	1407	OFF	969	9.9
    	52.33	1386	OFF	969	9.9
    	52.49	1386	OFF	969	9.9
    	52.66	1386	OFF	969	9.9
    	52.82	1407	OFF	969	9.9
    	52.97	1407	OFF	969	9.9
    	53.13	1407	OFF	969	9.9
    	53.3	1407	OFF	969	9.9
    	53.46	1407	OFF	969	9.9
    	53.61	1386	OFF	969	9.9
    	53.77	1386	OFF	969	9.9
    	53.94	1407	OFF	969	9.9
    	54.1	1407	OFF	969	9.9
    	54.25	1386	OFF	969	9.9
    	54.41	1407	OFF	969	9.9
    	54.58	1407	OFF	969	9.9
    	54.74	1407	ON	969	90.3
    	54.89	1386	ON	979.2	90.3
    	55.05	1386	ON	989.4	90.3
    	55.22	1386	ON	999.6	90.3
    	55.38	1407	ON	1009.8	90.3
    	55.53	1386	ON	1020	90.3
    	55.69	1386	ON	1030.2	90.3
    	55.86	1407	ON	1040.4	90.3
    	56.02	1407	ON	1040.4	90.3
    	56.17	1386	ON	1040.4	90.3
    	56.33	1386	ON	1050.6	90.3
    	56.5	1407	ON	1050.6	90.3
    	56.66	1407	ON	1050.6	90.3
    	56.81	1386	ON	1050.6	90.3
    	56.97	1407	ON	1050.6	90.3
    	57.15	1407	ON	1050.6	90.3
    	57.3	1407	ON	1050.6	90.3
    	57.45	1386	ON	1060.8	90.3
    	57.61	1386	ON	1060.8	90.3
    	57.78	1407	ON	1060.8	90.3
    	57.94	1407	ON	1060.8	90.3
    	58.09	1386	ON	1060.8	90.3
    	58.25	1407	ON	1060.8	90.3
    	58.42	1407	ON	1060.8	90.3
    	58.58	1407	ON	1060.8	90.3
    	58.73	1386	ON	1060.8	90.3
    	58.89	1386	ON	1060.8	90.3
    	59.06	1407	ON	1060.8	90.3
    	59.22	1407	ON	1060.8	90.3
    	59.37	1386	ON	1060.8	90.3
    	59.53	1407	ON	1060.8	90.3
    	59.7	1407	ON	1060.8	90.3
    	59.86	1407	ON	1050.6	90.3
    	60.01	1386	ON	1060.8	90.3
    	60.17	1407	ON	1060.8	90.3
    	60.34	1407	ON	1060.8	90.3
    	60.5	1407	ON	1060.8	90.3
    	60.65	1386	ON	1050.6	90.3
    	60.81	1407	ON	1050.6	90.3
    	60.98	1407	ON	1050.6	90.3
    	61.14	1407	ON	1050.6	90.3
    	61.29	1386	ON	1060.8	90.3
    	61.45	1386	ON	1050.6	90.3
    	61.62	1407	ON	1050.6	90.3
    	61.78	1407	ON	1050.6	90.3
    	61.93	1386	ON	1050.6	90.3
    	62.09	1407	ON	1050.6	90.3
    	62.27	1407	ON	1050.6	90.3
    	62.42	1407	ON	1050.6	90.3
    	62.57	1386	ON	1050.6	90.3
    	62.73	1407	ON	1050.6	90.3
    	62.9	1407	ON	1050.6	90.3
    	63.06	1407	ON	1050.6	90.3
    	63.21	1386	ON	1050.6	90.3
    	63.36	1407	ON	1050.6	90.3
    	63.54	1407	ON	1050.6	90.3
    	63.69	1407	ON	1050.6	90.3
    	63.84	1407	ON	1050.6	90.3
    	64.01	1407	ON	1050.6	90.3
    	64.18	1407	ON	1050.6	90.3
    	64.34	1407	ON	1050.6	90.3
    	64.49	1386	ON	1050.6	90.3
    	64.65	1407	OFF	1050.6	90.3
    	64.82	1428	OFF	1050.6	9.9
    	64.97	1407	OFF	1030.2	9.9
    	65.12	1407	OFF	1020	9.9
    	65.28	1407	OFF	1009.8	9.9
    	65.45	1407	OFF	999.6	9.9
    	65.61	1407	OFF	989.4	9.9
    	65.76	1386	OFF	989.4	9.9
    	65.92	1407	OFF	989.4	9.9
    	66.09	1407	OFF	979.2	9.9
    	66.25	1407	OFF	979.2	9.9
    	66.4	1407	OFF	979.2	9.9
    	66.56	1407	OFF	979.2	9.9
    	66.73	1407	OFF	979.2	9.9
    	66.89	1407	OFF	979.2	9.9
    	67.04	1386	OFF	979.2	9.9
    	67.2	1407	OFF	979.2	9.9
    	67.38	1407	OFF	979.2	9.9
    	67.53	1386	OFF	979.2	9.9
    	67.68	1407	OFF	979.2	9.9
    	67.84	1407	OFF	979.2	9.9
    	68.01	1407	OFF	979.2	9.9
    	68.17	1407	OFF	979.2	9.9
    and MAP MAF sensor while driving:
    Thursday	16	May	2019	19:03:47:53717-VCID:63CF59B0A2846D52A0-8036	VCDS Version: Release 18.9.1 (x64)	Data version: 20190114 DS296.0
    	Group A:	'002				Group B:	'006				Group C:	'010
    		Engine Speed	Accel. Pedal Pos.	Operation Status	Coolant		Vehicle Speed	Cruise Control	Accel. Pedal Pos.	Cruise Control		Mass Air Flow	Atmospheric	Boost Pressure	Accel. Pedal Pos.
    	TIME	(G28)	Sensor 1 (G79)		Temperature (G62)	TIME	(actual)	Pedal Monitoring	Sensor 1 (G79)	Switch Monitoring	TIME	(actual)	Pressure	(actual)	Sensor 1 (G79)
    Marker	STAMP	 /min	 %		C	STAMP	 km/h		 %		STAMP	 mg/str	 mbar	 mbar	 %
    	0.16	0	0	 0 01  0	46.8	0.32	0	1100	0	0	0.48	0	989.4	979.2	0
    	114.27	819	0	 0 01  0	53.1	113.93	0	1011	0	0	114.1	340	999.6	989.4	0
    	114.75	819	0	 0 01  0	54	114.43	0	1011	0	0	114.6	390	999.6	989.4	0
    	115.25	840	0	 0 01  0	54	114.93	0	1100	0	0	115.1	350	999.6	989.4	0
    	115.75	840	0	 0 01  0	54	115.41	0	1100	0	0	115.59	360	999.6	989.4	0
    	116.25	819	0	 0 01  0	54	115.91	0	1100	0	0	116.07	365	999.6	989.4	0
    	116.72	819	0	 0 01  0	54	116.41	0	1100	0	0	116.56	330	999.6	989.4	0
    	117.21	819	0	 0 01  0	54	116.89	0	1111	0	0	117.05	395	999.6	989.4	0
    	117.74	819	0	 0 01  0	54	117.41	0	1111	0	0	117.57	340	999.6	989.4	0
    	127.85	840	0	 0 01  0	54	128.01	0	1011	0	0	127.67	355	999.6	989.4	0
    	128.33	840	0	 0 01  0	54	128.52	0	1111	0	0	128.17	380	999.6	989.4	0
    	128.84	819	0	 0 01  0	54	129.02	0	1111	0	0	128.68	330	999.6	989.4	0
    	129.34	819	0	 0 01  0	54	129.5	0	1111	0	0	129.18	390	999.6	989.4	0
    	129.86	819	0	 0 01  0	54	130.03	0	1111	0	0	129.69	345	999.6	989.4	0
    	130.39	819	0	 0 01  0	54	130.56	0	1111	0	0	130.22	405	999.6	989.4	0
    	130.89	819	0	 0 01  0	54	131.06	0	1111	0	0	130.73	350	999.6	989.4	0
    	131.42	840	0	 0 01  0	54	131.59	0	1111	0	0	131.25	375	999.6	989.4	0
    	131.95	840	0	 0 01  0	54	132.12	0	1100	0	0	131.78	390	999.6	989.4	0
    	132.45	840	0	 0 01  0	54	132.62	0	1100	0	0	132.29	335	999.6	989.4	0
    	132.95	840	0	 0 01  0	54	133.12	0	1100	0	0	132.77	360	999.6	989.4	0
    	133.46	945	6.3	 0 00  0	54	133.62	0	1100	11	0	133.29	335	999.6	989.4	0
    	133.95	1491	15.7	 0 00  0	54	134.14	0	1100	18.4	0	133.79	345	999.6	989.4	14.9
    	134.46	1197	20.4	 0 00  0	54	134.62	1	1100	20.4	0	134.3	415	999.6	1040.4	20.4
    	134.98	1113	20.8	 0 00  0	54	135.15	5	1100	20.8	0	134.81	410	999.6	1060.8	20.8
    	135.51	1071	20.8	 0 00  0	54	135.68	8	1100	23.5	0	135.34	370	999.6	1071	20.8
    	136.01	1281	29.4	 0 00  0	54	136.18	11	1000	29.8	0	135.85	405	999.6	1060.8	26.7
    	136.54	1512	32.5	 0 00  0	54	136.71	13	1000	32.9	0	136.37	380	999.6	1081.2	31.4
    	137.07	1701	34.9	 0 00  0	54	137.23	14	1000	34.9	0	136.9	400	999.6	1132.2	34.9
    	137.56	1848	35.3	 0 00  0	54.9	137.74	16	1000	35.7	0	137.41	435	999.6	1203.6	35.3
    	138.07	1974	28.2	 0 00  0	54.9	138.23	17	1100	0	0	137.91	470	999.6	1285.2	35.7
    	138.57	1155	0	 0 01  0	54.9	138.74	17	1100	17.3	0	138.41	455	999.6	1254.6	0
    	139.09	1302	35.7	 0 00  0	54.9	139.26	18	1100	38.4	0	138.93	370	999.6	1111.8	34.9
    	139.6	1197	38.4	 0 00  0	54.9	139.76	19	1000	41.2	0	139.44	400	999.6	1132.2	38.4
    	140.12	1323	43.9	 0 00  0	54.9	140.3	21	1000	44.3	0	139.95	390	999.6	1142.4	41.2
    	140.65	1449	44.3	 0 00  0	54.9	140.82	23	1000	45.5	0	140.48	425	999.6	1173	44.3
    	141.15	1575	47.5	 0 00  0	54.9	141.3	25	1000	47.5	0	140.99	485	999.6	1234.2	46.7
    	141.63	1722	49	 0 00  0	54.9	141.79	27	1000	49	0	141.46	520	999.6	1315.8	47.8
    	142.15	1848	47.8	 0 00  0	54.9	142.32	30	1000	47.8	0	141.96	565	999.6	1428	48.6
    	142.66	1953	47.5	 0 00  0	54.9	142.82	32	1000	47.5	0	142.49	600	999.6	1560.6	47.8
    	143.13	2037	47.8	 0 00  0	54.9	143.3	33	1000	47.8	0	142.97	605	999.6	1642.2	47.8
    	143.63	2121	47.8	 0 00  0	54.9	143.82	35	1000	47.8	0	143.46	620	999.6	1703.4	47.8
    	144.16	1974	0	 0 01  0	54.9	144.33	36	1100	0	0	143.99	560	999.6	1744.2	7.8
    	144.64	1302	0	 0 01  0	54.9	144.8	36	1100	28.2	0	144.49	430	999.6	1295.4	0
    	145.14	1680	45.1	 0 00  0	54.9	145.3	36	1100	45.9	0	144.98	410	999.6	1101.6	43.5
    	145.63	1449	47.8	 0 00  0	54.9	145.8	37	1000	49	0	145.47	490	999.6	1254.6	45.9
    	146.16	1533	50.2	 0 00  0	54.9	146.33	38	1000	50.2	0	145.99	525	999.6	1315.8	50.2
    	146.66	1554	50.2	 0 00  0	54.9	146.83	40	1000	50.6	0	146.5	540	999.6	1377	50.2
    	147.17	1638	51.4	 0 00  0	54.9	147.33	42	1000	51.4	0	146.99	570	999.6	1438.2	50.6
    	147.67	1701	51.8	 0 00  0	54.9	147.83	43	1000	51.8	0	147.5	580	999.6	1519.8	51.8
    	148.14	1785	52.2	 0 00  0	54.9	148.31	45	1000	52.2	0	147.98	570	999.6	1581	52.2
    	148.63	1806	52.5	 0 00  0	54.9	148.8	46	1000	52.9	0	148.47	635	999.6	1652.4	52.2
    	149.16	1869	54.9	 0 00  0	54.9	149.33	48	1000	54.9	0	148.99	635	999.6	1713.6	53.7
    	149.67	1911	54.9	 0 00  0	55.8	149.83	49	1000	54.9	0	149.51	655	999.6	1774.8	54.9
    	150.19	1995	54.9	 0 00  0	55.8	150.36	50	1000	54.9	0	150.03	630	999.6	1836	54.9
    	150.72	2037	54.9	 0 00  0	55.8	150.89	52	1000	54.9	0	150.55	625	999.6	1866.6	54.9
    	151.25	2037	0	 0 01  0	55.8	151.42	52	1100	0	0	151.08	570	999.6	1876.8	54.9
    	151.74	1302	0	 0 01  0	55.8	151.91	52	1100	30.6	0	151.58	430	999.6	1468.8	0
    	152.25	1659	45.9	 0 00  0	55.8	152.41	52	1100	47.8	0	152.07	380	999.6	1162.8	45.1
    	152.73	1449	52.9	 0 00  0	55.8	152.9	53	1000	52.9	0	152.57	505	999.6	1295.4	52.9
    	153.22	1512	53.3	 0 00  0	55.8	153.39	53	1000	53.7	0	153.06	500	999.6	1366.8	53.3
    	153.72	1554	55.3	 0 00  0	55.8	153.88	54	1000	55.3	0	153.55	525	999.6	1417.8	55.3
    	154.22	1533	55.3	 0 00  0	55.8	154.37	55	1000	55.3	0	154.06	535	999.6	1479	55.3
    	154.71	1596	55.7	 0 00  0	55.8	154.86	56	1000	56.9	0	154.53	535	999.6	1519.8	55.3
    	155.21	1575	57.3	 0 00  0	56.7	155.37	57	1000	57.3	0	155.03	580	999.6	1560.6	57.3
    	155.69	1680	57.3	 0 00  0	56.7	155.88	58	1000	57.3	0	155.53	550	999.6	1601.4	57.3
    	156.2	1680	57.3	 0 00  0	56.7	156.36	60	1000	57.3	0	156.04	580	999.6	1632	57.3
    	156.72	1680	56.9	 0 00  0	56.7	156.89	60	1000	56.9	0	156.55	550	999.6	1652.4	56.9
    	157.25	1743	56.1	 0 00  0	56.7	157.4	61	1000	54.5	0	157.08	555	999.6	1662.6	56.9
    	157.75	1764	49.8	 0 00  0	56.7	157.92	62	1000	47.1	0	157.58	535	999.6	1672.8	52.9
    	158.25	1743	41.2	 0 00  0	56.7	158.42	63	1000	40.8	0	158.09	570	999.6	1662.6	43.1
    	158.78	1764	38	 0 00  0	56.7	158.95	63	1000	37.6	0	158.61	515	999.6	1591.2	38.4
    	159.28	1743	34.9	 0 00  0	57.6	159.45	63	1000	34.5	0	159.12	525	999.6	1499.4	36.1
    	159.78	1743	32.5	 0 00  0	57.6	159.95	63	1000	31.4	0	159.62	490	999.6	1448.4	32.9
    	160.31	1743	31.4	 0 00  0	57.6	160.48	63	1000	31.4	0	160.14	470	999.6	1387.2	31.4
    	160.82	1743	11.4	 0 00  0	57.6	160.98	62	1000	0	0	160.66	445	999.6	1346.4	31.4
    	161.34	1680	0	 0 01  0	57.6	161.51	61	1000	0	0	161.17	395	999.6	1254.6	0
    	161.84	1659	0	 0 01  0	57.6	162.01	60	1000	0	0	161.68	410	999.6	1152.6	0
    	162.37	1617	0	 0 01  0	58.5	162.54	59	1000	0	0	162.2	420	999.6	1111.8	0
    	162.87	1575	0	 0 01  0	58.5	163.04	57	1000	0	0	162.71	400	999.6	1091.4	0
    	163.37	1533	0	 0 01  0	58.5	163.54	56	1011	0	0	163.19	415	999.6	1071	0
    	163.88	1470	0	 0 01  0	58.5	164.04	53	1011	0	0	163.71	395	999.6	1060.8	0
    	164.35	1386	0	 0 01  0	58.5	164.52	51	1011	0	0	164.19	400	999.6	1050.6	0
    	164.83	1302	0	 0 01  0	58.5	164.99	48	1011	0	0	164.68	415	999.6	1040.4	0
    	165.32	1218	0	 0 01  0	59.4	165.49	45	1011	0	0	165.16	400	999.6	1030.2	0
    	165.85	1113	0	 0 01  0	59.4	166	41	1011	0	0	165.69	385	999.6	1020	0
    	166.34	1008	0	 0 01  0	59.4	166.49	37	1111	0	0	166.17	385	999.6	1020	0
    	166.83	819	0	 0 01  0	59.4	166.99	34	1111	0	0	166.65	375	999.6	1009.8	0
    	167.35	798	0	 0 01  0	59.4	167.52	30	1111	0	0	167.16	385	999.6	999.6	0
    	167.85	840	0	 0 01  0	59.4	168.01	26	1011	0	0	167.68	355	999.6	999.6	0
    	168.32	819	0	 0 01  0	60.3	168.49	23	1011	0	0	168.16	400	999.6	999.6	0
    	168.8	840	0	 0 01  0	60.3	168.96	20	1011	0	0	168.65	370	999.6	999.6	0
    	169.31	840	0	 0 01  0	60.3	169.46	16	1011	0	0	169.15	360	999.6	999.6	0
    	169.8	819	0	 0 01  0	60.3	169.96	13	1011	0	0	169.62	380	999.6	999.6	0
    	170.3	840	0	 0 01  0	60.3	170.46	9	1011	0	0	170.12	350	999.6	999.6	0
    	170.77	819	0	 0 01  0	60.3	170.96	5	1011	0	0	170.61	395	999.6	999.6	0
    	171.29	840	0	 0 01  0	61.2	171.48	3	1011	0	0	171.13	360	999.6	999.6	0
    	171.82	777	0	 0 01  0	61.2	172.01	1	1011	0	0	171.65	385	999.6	999.6	0
    	172.35	819	0	 0 01  0	61.2	172.54	0	1011	0	0	172.18	355	999.6	999.6	0
    	172.88	840	0	 0 01  0	61.2	173.05	0	1011	0	0	172.71	360	999.6	999.6	0
    	173.38	819	0	 0 01  0	61.2	173.55	0	1011	0	0	173.21	395	999.6	999.6	0
    	173.88	819	0	 0 01  0	61.2	174.07	0	1011	0	0	173.71	355	999.6	999.6	0
    	174.41	819	0	 0 01  0	61.2	174.6	0	1011	0	0	174.24	390	999.6	999.6	0
    	174.92	840	0	 0 01  0	62.1	175.08	0	1011	0	0	174.77	345	999.6	999.6	0
    	175.41	819	0	 0 01  0	62.1	175.58	0	1011	0	0	175.25	400	999.6	999.6	0
    	175.91	840	0	 0 01  0	62.1	176.08	0	1011	0	0	175.73	360	999.6	999.6	0
    	176.42	819	0	 0 01  0	62.1	176.58	0	1011	0	0	176.23	370	999.6	999.6	0
    	176.89	819	0	 0 01  0	62.1	177.06	0	1011	0	0	176.73	350	999.6	999.6	0
    	177.39	840	0	 0 01  0	62.1	177.56	0	1011	0	0	177.22	340	999.6	999.6	0
    	177.89	819	0	 0 01  0	62.1	178.05	0	1011	0	0	177.72	400	999.6	999.6	0
    	178.41	840	0	 0 01  0	62.1	178.58	0	1011	0	0	178.24	365	999.6	999.6	0
    	178.94	819	0	 0 01  0	63	179.11	0	1011	0	0	178.77	315	999.6	999.6	0
    	179.47	819	0	 0 01  0	63	179.64	0	1011	0	0	179.3	405	999.6	999.6	0
    	179.96	840	0	 0 01  0	63	180.12	0	1011	0	0	179.81	340	999.6	989.4	0
    	180.47	819	0	 0 01  0	63	180.64	0	1011	0	0	180.28	385	999.6	989.4	0
    	181	819	0	 0 01  0	63	181.17	0	1011	0	0	180.81	350	999.6	989.4	0
    	181.51	819	0	 0 01  0	63	181.67	0	1011	0	0	181.33	385	999.6	999.6	0
    	182	840	0	 0 01  0	63	182.16	0	1011	0	0	181.83	350	999.6	989.4	0
    	182.5	819	0	 0 01  0	63	182.66	0	1011	0	0	182.33	395	999.6	989.4	0
    	183.02	819	0	 0 01  0	63	183.19	0	1011	0	0	182.83	335	999.6	999.6	0
    	183.53	840	0	 0 01  0	63	183.69	0	1011	0	0	183.36	375	999.6	999.6	0
    	184.01	819	0	 0 01  0	63	184.19	0	1011	0	0	183.86	360	999.6	989.4	0
    	184.53	840	0	 0 01  0	63	184.7	0	1011	0	0	184.36	380	999.6	999.6	0
    	185.03	819	0	 0 01  0	63.9	185.19	0	1011	0	0	184.86	345	999.6	989.4	0
    	185.53	819	0	 0 01  0	63.9	185.68	0	1011	0	0	185.37	390	999.6	989.4	0
    	186.01	819	0	 0 01  0	63.9	186.17	0	1011	0	0	185.84	335	999.6	999.6	0
    	186.53	819	0	 0 01  0	63.9	186.7	0	1011	0	0	186.34	380	999.6	989.4	0
    	187.03	840	0	 0 01  0	63.9	187.2	0	1011	0	0	186.85	360	999.6	999.6	0
    	187.51	819	0	 0 01  0	63.9	187.68	0	1011	0	0	187.35	385	999.6	989.4	0
    	188	819	0	 0 01  0	63.9	188.17	0	1011	0	0	187.84	370	999.6	999.6	0
    	188.52	819	0	 0 01  0	63.9	188.68	0	1011	0	0	188.36	380	999.6	989.4	0
    	189.01	840	0	 0 01  0	63.9	189.16	0	1011	0	0	188.85	370	999.6	999.6	0
    	189.5	819	0	 0 01  0	63.9	189.66	0	1011	0	0	189.32	340	999.6	999.6	0
    	189.98	840	0	 0 01  0	63.9	190.17	0	1011	0	0	189.82	400	999.6	989.4	0
    	190.51	819	0	 0 01  0	63.9	190.68	0	1011	0	0	190.34	345	999.6	989.4	0
    	191.01	819	0	 0 01  0	63.9	191.2	0	1011	0	0	190.84	395	999.6	989.4	0
    	191.54	819	0	 0 01  0	63.9	191.72	0	1011	0	0	191.37	345	999.6	989.4	0
    	192.04	819	0	 0 01  0	63.9	192.23	0	1011	0	0	191.88	375	999.6	999.6	0
    	192.57	840	0	 0 01  0	63.9	192.74	0	1011	0	0	192.4	385	999.6	989.4	0
    	193.07	819	0	 0 01  0	63.9	193.22	0	1011	0	0	192.9	375	999.6	999.6	0
    	193.57	819	0	 0 01  0	63.9	193.74	0	1011	0	0	193.4	350	999.6	989.4	0
    	194.07	819	0	 0 01  0	63.9	194.24	0	1011	0	0	193.91	365	999.6	999.6	0
    	194.58	819	0	 0 01  0	63.9	194.74	0	1011	0	0	194.4	345	999.6	989.4	0
    	195.05	840	0	 0 01  0	63.9	195.22	0	1011	0	0	194.89	405	999.6	989.4	0
    	195.55	819	0	 0 01  0	63.9	195.71	0	1011	0	0	195.38	330	999.6	999.6	0
    	196.06	819	0	 0 01  0	64.8	196.23	0	1011	0	0	195.89	400	999.6	989.4	0
    	196.59	819	0	 0 01  0	64.8	196.76	0	1011	0	0	196.43	340	999.6	989.4	0
    	197.12	819	0	 0 01  0	64.8	197.29	0	1011	0	0	196.96	340	999.6	999.6	0
    	197.65	840	0	 0 01  0	64.8	197.8	0	1011	0	0	197.48	395	999.6	989.4	0
    	198.13	819	0	 0 01  0	64.8	198.29	0	1011	0	0	197.96	370	999.6	999.6	0
    	198.6	840	0	 0 01  0	64.8	198.77	0	1011	0	0	198.44	350	999.6	989.4	0
    	199.1	840	0	 0 01  0	64.8	199.27	0	1011	0	0	198.94	390	999.6	989.4	0
    	199.6	840	0	 0 01  0	64.8	199.75	0	1011	0	0	199.43	355	999.6	999.6	0
    	200.1	840	0	 0 01  0	64.8	200.26	0	1011	0	0	199.93	395	999.6	989.4	0
    	200.6	819	0	 0 01  0	64.8	200.77	0	1011	0	0	200.44	330	999.6	999.6	0
    	201.11	819	0	 0 01  0	64.8	201.27	0	1011	0	0	200.93	385	999.6	989.4	0
    	201.58	840	0	 0 01  0	64.8	201.75	0	1011	0	0	201.42	370	999.6	999.6	0
    	202.07	819	0	 0 01  0	64.8	202.24	0	1011	0	0	201.91	370	999.6	989.4	0
    	202.6	819	0	 0 01  0	64.8	202.77	0	1011	0	0	202.44	380	999.6	999.6	0
    	203.13	819	0	 0 01  0	64.8	203.3	0	1011	0	0	202.96	380	999.6	989.4	0
    	203.63	840	0	 0 01  0	64.8	203.8	0	1011	0	0	203.47	335	999.6	999.6	0
    	204.13	840	0	 0 01  0	64.8	204.3	0	1011	0	0	203.97	380	999.6	989.4	0
    	204.66	819	0	 0 01  0	64.8	204.83	0	1011	0	0	204.49	340	999.6	999.6	0
    	205.16	840	0	 0 01  0	64.8	205.33	0	1011	0	0	205	400	999.6	989.4	0
    	205.65	819	0	 0 01  0	64.8	205.81	0	1011	0	0	205.5	335	999.6	999.6	0
    	206.16	819	0	 0 01  0	64.8	206.33	0	1011	0	0	205.97	365	999.6	989.4	0
    	206.67	819	0	 0 01  0	64.8	206.83	0	1011	0	0	206.5	350	999.6	999.6	0
    	207.17	819	0	 0 01  0	64.8	207.32	0	1011	0	0	207	370	999.6	989.4	0
    	207.64	819	0	 0 01  0	64.8	207.84	0	1011	0	0	207.48	405	999.6	989.4	0
    	208.17	819	0	 0 01  0	64.8	208.36	0	1011	0	0	208	365	999.6	989.4	0
    	208.68	840	0	 0 01  0	64.8	208.84	0	1011	0	0	208.53	360	999.6	999.6	0
    	209.17	840	0	 0 01  0	64.8	209.34	0	1011	0	0	209.01	375	999.6	989.4	0
    	209.67	819	0	 0 01  0	64.8	209.84	0	1011	0	0	209.51	385	999.6	999.6	0
    	210.19	819	0	 0 01  0	64.8	210.34	0	1011	0	0	210.02	385	999.6	989.4	0
    	210.67	840	0	 0 01  0	64.8	210.84	0	1011	0	0	210.5	385	999.6	999.6	0
    	211.17	819	0	 0 01  0	64.8	211.33	0	1011	0	0	211	355	999.6	989.4	0
    	211.69	819	0	 0 01  0	64.8	211.86	0	1011	0	0	211.51	400	999.6	989.4	0
    	212.2	819	0	 0 01  0	64.8	212.36	0	1011	0	0	212.03	340	999.6	989.4	0
    	212.67	819	0	 0 01  0	64.8	212.85	0	1011	0	0	212.51	400	999.6	989.4	0
    	213.17	819	0	 0 01  0	64.8	213.33	0	1011	0	0	213.01	335	999.6	999.6	0
    	213.68	819	0	 0 01  0	64.8	213.84	0	1011	0	0	213.52	400	999.6	989.4	0
    	214.19	840	0	 0 01  0	64.8	214.36	0	1011	0	0	214	360	999.6	999.6	0
    	214.72	819	0	 0 01  0	64.8	214.89	0	1011	0	0	214.53	385	999.6	989.4	0
    	215.23	819	0	 0 01  0	64.8	215.39	0	1011	0	0	215.06	375	999.6	989.4	0
    	215.75	840	0	 0 01  0	64.8	215.92	0	1011	0	0	215.56	390	999.6	989.4	0
    	216.26	819	0	 0 01  0	64.8	216.42	0	1011	0	0	216.09	370	999.6	989.4	0
    	216.78	819	0	 0 01  0	64.8	216.95	0	1011	0	0	216.59	390	999.6	989.4	0
    	217.31	819	0	 0 01  0	64.8	217.48	0	1011	0	0	217.12	390	999.6	989.4	0
    	217.82	819	0	 0 01  0	64.8	217.98	0	1011	0	0	217.65	355	999.6	999.6	0
    	218.29	840	0	 0 01  0	64.8	218.47	0	1011	0	0	218.13	370	999.6	989.4	0
    	218.79	819	0	 0 01  0	64.8	218.95	0	1011	0	0	218.63	370	999.6	999.6	0
    	219.29	819	0	 0 01  0	64.8	219.46	0	1011	0	0	219.13	360	999.6	989.4	0
    	219.79	819	0	 0 01  0	64.8	219.94	0	1011	0	0	219.63	385	999.6	999.6	0
    	220.27	840	0	 0 01  0	64.8	220.43	0	1011	0	0	220.1	355	999.6	989.4	0
    	220.74	819	0	 0 01  0	64.8	220.91	0	1011	0	0	220.58	385	999.6	989.4	0
    	221.24	840	0	 0 01  0	64.8	221.41	0	1011	0	0	221.07	375	999.6	999.6	0
    	221.72	840	0	 0 01  0	64.8	221.88	0	1011	0	0	221.57	365	999.6	989.4	0
    	222.22	819	0	 0 01  0	64.8	222.38	0	1011	0	0	222.06	395	999.6	989.4	0
    	222.73	819	0	 0 01  0	64.8	222.89	0	1011	0	0	222.54	355	999.6	999.6	0
    	223.22	819	0	 0 01  0	64.8	223.38	0	1011	0	0	223.05	385	999.6	989.4	0
    	223.69	840	0	 0 01  0	64.8	223.87	0	1111	0	0	223.53	375	999.6	999.6	0
    	224.18	819	0	 0 01  0	64.8	224.35	0	1111	0	0	224.02	365	999.6	989.4	0
    	224.69	819	0	 0 01  0	64.8	224.87	0	1111	0	0	224.52	410	999.6	989.4	0
    	225.2	819	0	 0 01  0	64.8	225.38	0	1111	0	0	225.04	375	999.6	989.4	0
    	225.69	819	0	 0 01  0	64.8	225.85	0	1111	0	0	225.54	370	999.6	999.6	0
    	226.18	840	0	 0 01  0	64.8	226.35	0	1111	0	0	226.02	330	999.6	999.6	0
    	226.68	819	0	 0 01  0	64.8	226.85	0	1111	0	0	226.52	400	999.6	989.4	0
    	227.2	819	0	 0 01  0	64.8	227.36	0	1111	0	0	227.01	350	999.6	999.6	0
    	227.68	819	0	 0 01  0	64.8	227.87	0	1111	0	0	227.52	385	999.6	989.4	0
    	228.21	819	0	 0 01  0	64.8	228.4	0	1111	0	0	228.04	340	999.6	999.6	0
    	228.74	840	0	 0 01  0	64.8	228.92	0	1100	14.1	0	228.57	380	999.6	999.6	0
    	229.24	1449	22.4	 0 00  0	64.8	229.43	0	1100	27.5	0	229.08	330	999.6	989.4	21.2
    	229.77	1239	27.8	 0 00  0	64.8	229.94	2	1100	27.8	0	229.6	390	999.6	1060.8	27.8
    	230.27	1197	27.8	 0 00  0	64.8	230.46	5	1100	27.8	0	230.1	380	999.6	1101.6	27.8
    	230.8	1155	28.2	 0 00  0	64.8	230.97	9	1100	32.2	0	230.63	415	999.6	1111.8	27.8
    	231.3	1407	33.3	 0 00  0	64.8	231.49	12	1000	35.3	0	231.13	395	999.6	1111.8	33.3
    	231.81	1659	39.6	 0 00  0	64.8	231.97	14	1000	41.2	0	231.66	465	999.6	1152.6	36.5
    	232.3	1869	43.5	 0 00  0	64.8	232.47	16	1000	43.5	0	232.14	490	999.6	1244.4	42.4
    	232.81	2079	42	 0 00  0	64.8	232.97	18	1100	0	0	232.63	515	999.6	1387.2	43.5
    	233.28	1680	0	 0 01  0	64.8	233.46	19	1100	0	0	233.12	500	999.6	1468.8	0
    	233.8	1428	38.8	 0 00  0	64.8	234	19	1100	44.7	0	233.63	415	999.6	1111.8	27.5
    	234.33	1281	44.7	 0 00  0	64.8	234.5	20	1100	44.7	0	234.16	490	999.6	1152.6	44.7
    	234.81	1344	45.1	 0 00  0	64.8	234.97	22	1000	45.1	0	234.65	455	999.6	1193.4	44.7
    	235.33	1491	45.1	 0 00  0	64.8	235.5	24	1000	45.1	0	235.16	450	999.6	1244.4	45.1
    	235.86	1617	45.5	 0 00  0	64.8	236.03	26	1000	46.7	0	235.69	500	999.6	1315.8	45.5
    	236.39	1785	46.7	 0 00  0	64.8	236.54	29	1000	46.7	0	236.22	540	999.6	1417.8	46.7
    	236.89	1890	49	 0 00  0	64.8	237.06	31	1000	49	0	236.72	600	999.6	1519.8	49.4
    	237.42	2037	51	 0 00  0	64.8	237.59	33	1000	51.4	0	237.25	610	999.6	1652.4	49
    	237.92	2205	57.3	 0 00  0	64.8	238.08	36	1000	58.8	0	237.76	635	999.6	1764.6	53.7
    	238.41	2331	61.6	 0 00  0	64.8	238.58	38	1000	61.6	0	238.24	545	999.6	1856.4	59.6
    	238.89	2478	61.6	 0 00  0	64.8	239.07	40	1000	61.6	0	238.73	475	999.6	1948.2	61.6
    	239.39	2562	26.7	 0 00  0	64.8	239.56	42	1100	0	0	239.23	425	999.6	1978.8	61.6
    	239.9	1911	0	 0 01  0	64.8	240.06	43	1100	0	0	239.75	440	999.6	1550.4	0
    	240.39	1974	51	 0 00  0	65.7	240.55	44	1100	53.3	0	240.22	425	999.6	1142.4	26.3
    	240.91	1848	60.4	 0 00  0	65.7	241.08	46	1000	64.7	0	240.72	560	999.6	1305.6	56.1
    	241.44	1932	68.6	 0 00  0	65.7	241.61	49	1000	68.6	0	241.25	640	999.6	1581	68.2
    	241.95	2037	69.4	 0 00  0	65.7	242.11	52	1000	72.5	0	241.78	770	999.6	1958.4	68.6
    	242.43	2205	73.7	 0 00  0	65.7	242.61	55	1000	73.7	0	242.28	840	999.6	2274.6	73.7
    	242.95	2373	76.1	 0 00  0	65.7	243.12	59	1000	76.1	0	242.78	1015	999.6	2570.4	74.9
    	243.45	2562	75.7	 0 00  0	65.7	243.6	63	1000	75.7	0	243.28	1100	999.6	2580.6	76.1
    	243.95	2709	67.8	 0 00  0	65.7	244.1	68	1000	64.7	0	243.78	890	999.6	2468.4	72.5
    	244.44	2814	58.4	 0 00  0	65.7	244.6	71	1000	52.9	0	244.26	830	999.6	2091	62.7
    	244.94	2667	0	 0 01  0	65.7	245.1	73	1100	0	0	244.76	730	999.6	1876.8	0
    	245.42	1869	0	 0 01  0	65.7	245.6	73	1100	0	0	245.26	435	999.6	1224	0
    	245.91	1596	20.4	 0 00  0	65.7	246.07	73	1100	20.4	0	245.76	405	999.6	1060.8	15.7
    	246.41	1974	19.2	 0 00  0	65.7	246.57	72	1100	19.2	0	246.25	410	999.6	1060.8	19.6
    	246.92	1974	0	 0 01  0	65.7	247.09	71	1000	0	0	246.73	460	999.6	1142.4	0
    	247.43	1953	0	 0 01  0	65.7	247.59	70	1000	0	0	247.26	440	999.6	1101.6	0
    	247.93	1911	0	 0 01  0	65.7	248.09	69	1000	0	0	247.76	435	999.6	1071	0
    	248.45	1869	0	 0 01  0	66.6	248.62	68	1000	0	0	248.26	435	999.6	1050.6	0
    	248.96	1848	0	 0 01  0	66.6	249.12	67	1000	0	0	248.79	430	999.6	1040.4	0
    	249.48	1806	0	 0 01  0	66.6	249.65	65	1000	0	0	249.29	440	999.6	1030.2	0
    	249.99	1785	0	 0 01  0	66.6	250.15	64	1000	0	0	249.82	435	999.6	1030.2	0
    	250.51	1743	0	 0 01  0	66.6	250.68	63	1000	0	0	250.32	435	999.6	1020	0
    	251.02	1701	0	 0 01  0	66.6	251.18	61	1000	0	0	250.85	425	999.6	1020	0
    	251.54	1659	0	 0 01  0	66.6	251.71	60	1000	0	0	251.35	435	999.6	1020	0
    	252.07	1596	0	 0 01  0	66.6	252.24	58	1000	0	0	251.88	430	999.6	1020	0
    	252.59	1554	0	 0 01  0	67.5	252.77	57	1000	0	0	252.41	425	999.6	1020	0
    	253.1	1512	0	 0 01  0	67.5	253.27	55	1000	0	0	252.93	410	999.6	1030.2	0
    	253.61	1449	0	 0 01  0	67.5	253.76	53	1100	0	0	253.43	410	999.6	1030.2	0
    	254.13	819	0	 0 01  0	67.5	254.29	51	1100	0	0	253.94	410	999.6	1030.2	0
    	254.64	1092	16.1	 0 00  0	67.5	254.8	50	1100	19.2	0	254.46	405	999.6	1020	0
    	255.11	1806	19.2	 0 00  0	67.5	255.29	48	1100	20.4	0	254.96	370	999.6	999.6	19.2
    	255.61	1785	24.7	 0 00  0	67.5	255.8	47	1000	32.5	0	255.46	455	999.6	1081.2	22.4
    	256.13	1785	41.2	 0 00  0	68.4	256.3	46	1000	41.6	0	255.96	480	999.6	1142.4	38
    	256.61	1785	35.7	 0 00  0	68.4	256.77	46	1000	33.3	0	256.46	545	999.6	1254.6	36.1
    	257.1	1764	31	 0 00  0	68.4	257.25	45	1000	31	0	256.94	530	999.6	1305.6	31.4
    	257.58	1764	30.6	 0 00  0	68.4	257.74	45	1000	30.6	0	257.41	515	999.6	1295.4	30.6
    	258.07	1743	30.6	 0 00  0	68.4	258.26	45	1000	30.6	0	257.91	510	999.6	1295.4	30.6
    	258.58	1743	30.6	 0 00  0	68.4	258.75	45	1000	30.6	0	258.42	505	999.6	1285.2	30.6
    	259.07	1743	30.6	 0 00  0	68.4	259.26	45	1000	30.6	0	258.91	495	999.6	1285.2	30.6
    	259.58	1722	30.6	 0 00  0	68.4	259.74	45	1000	30.6	0	259.42	510	999.6	1285.2	30.6
    	260.1	1743	30.6	 0 00  0	68.4	260.27	45	1000	30.6	0	259.94	485	999.6	1285.2	30.6
    	260.61	1722	28.2	 0 00  0	68.4	260.77	45	1000	26.7	0	260.45	500	999.6	1285.2	28.6
    	261.13	1722	23.5	 0 00  0	69.3	261.3	44	1000	23.1	0	260.96	465	999.6	1264.8	24.7
    	261.66	1722	22.7	 0 00  0	69.3	261.83	44	1000	22.7	0	261.49	460	999.6	1234.2	22.7
    	262.16	1701	22	 0 00  0	69.3	262.33	44	1000	21.6	0	262	455	999.6	1203.6	22.7
    	262.69	1680	21.6	 0 00  0	69.3	262.86	43	1000	21.6	0	262.52	435	989.4	1193.4	21.6
    	263.22	1680	22.4	 0 00  0	69.3	263.39	43	1000	22.4	0	263.05	435	999.6	1183.2	21.6
    	263.75	1680	22.7	 0 00  0	69.3	263.9	43	1000	22.7	0	263.58	435	999.6	1173	22.4
    	264.23	1680	22.7	 0 00  0	69.3	264.39	43	1000	22.7	0	264.06	435	989.4	1173	22.7
    	264.72	1680	23.1	 0 00  0	69.3	264.91	43	1000	26.7	0	264.56	445	999.6	1173	22.7
    	265.25	1701	26.7	 0 00  0	69.3	265.44	44	1000	27.5	0	265.08	440	999.6	1183.2	26.7
    	265.78	1722	27.5	 0 00  0	69.3	265.96	44	1000	27.5	0	265.61	465	989.4	1203.6	27.5
    	266.28	1743	30.2	 0 00  0	69.3	266.47	44	1000	30.6	0	266.12	460	989.4	1213.8	27.8
    	266.81	1764	30.6	 0 00  0	70.2	267	45	1000	30.6	0	266.64	465	989.4	1234.2	30.6
    	267.33	1785	30.6	 0 00  0	70.2	267.5	46	1000	30.6	0	267.16	470	989.4	1264.8	30.6
    	267.83	1806	30.6	 0 00  0	70.2	267.98	46	1000	35.3	0	267.67	500	989.4	1275	30.6
    	268.34	1848	43.9	 0 00  0	70.2	268.51	47	1000	44.7	0	268.16	490	989.4	1295.4	43.9
    	268.87	1869	55.7	 0 00  0	70.2	269.03	48	1000	58.4	0	268.69	515	989.4	1377	52.2
    	269.36	1932	60.4	 0 00  0	70.2	269.53	49	1000	63.1	0	269.2	560	999.6	1499.4	59.2
    	269.86	1953	65.5	 0 00  0	70.2	270.03	51	1000	66.3	0	269.7	545	989.4	1601.4	65.5
    	270.36	2079	71	 0 00  0	70.2	270.53	52	1000	71.8	0	270.18	535	989.4	1693.2	68.6
    	270.88	2100	72.2	 0 00  0	70.2	271.04	54	1000	72.2	0	270.7	515	999.6	1774.8	71.8
    	271.35	2121	76.1	 0 00  0	70.2	271.53	55	1000	80	0	271.2	495	999.6	1836	72.9
    	271.87	2100	82.4	 0 00  0	70.2	272.04	56	1000	56.9	0	271.7	495	999.6	1866.6	82.4
    	272.37	2226	27.5	 0 00  0	70.2	272.53	56	1000	45.9	0	272.2	550	989.4	1917.6	48.2
    	272.89	2226	56.1	 0 00  0	71.1	273.06	57	1000	58.8	0	272.72	645	989.4	1693.2	51.8
    	273.42	2268	62.7	 0 00  0	71.1	273.59	57	1000	63.9	0	273.25	585	989.4	1825.8	60
    	273.95	2268	66.3	 0 00  0	71.1	274.12	58	1000	66.7	0	273.78	455	989.4	1866.6	65.1
    	274.48	2268	67.1	 0 00  0	71.1	274.65	58	1000	67.8	0	274.31	470	989.4	1846.2	66.7
    	274.98	2289	68.2	 0 00  0	71.1	275.15	58	1000	69	0	274.82	430	989.4	1815.6	68.2
    	275.48	2268	69	 0 00  0	71.1	275.65	59	1000	68.6	0	275.3	330	989.4	1774.8	69
    	276	2268	68.2	 0 00  0	71.1	276.16	59	1000	68.2	0	275.82	400	989.4	1723.8	68.2
    	276.48	2289	60	 0 00  0	71.1	276.66	59	1000	58.4	0	276.32	340	989.4	1703.4	68.2
    	276.97	2310	57.3	 0 00  0	71.1	277.13	59	1000	57.3	0	276.82	375	989.4	1672.8	57.3
    	277.46	2289	57.3	 0 00  0	71.1	277.63	59	1000	55.7	0	277.3	350	989.4	1621.8	57.3
    	277.98	2310	55.7	 0 00  0	71.1	278.15	59	1000	55.3	0	277.79	340	989.4	1591.2	55.7
    	278.51	1995	0	 0 01  0	72	278.68	59	1100	0	0	278.32	345	989.4	1560.6	0
    	279.02	945	0	 0 01  0	72	279.18	59	1100	0	0	278.85	320	989.4	1336.2	0
    	279.54	1050	15.7	 0 00  0	72	279.71	58	1100	24.3	0	279.35	400	989.4	1142.4	0
    	280.05	2205	28.2	 0 00  0	72	280.21	57	1100	28.2	0	279.88	350	989.4	1081.2	28.2
    	280.55	2184	31.4	 0 00  0	72	280.71	57	1000	31.4	0	280.38	420	989.4	1203.6	30.2
    	281.08	2184	40.8	 0 00  0	72	281.24	56	1000	41.2	0	280.88	455	989.4	1315.8	36.1
    	281.6	2205	41.2	 0 00  0	72	281.76	56	1000	41.2	0	281.41	470	989.4	1407.6	41.2
    	282.11	2184	42.4	 0 00  0	72.9	282.26	57	1000	44.3	0	281.93	495	989.4	1479	42
    	282.6	2205	44.3	 0 00  0	72.9	282.76	57	1000	43.9	0	282.43	480	989.4	1519.8	44.3
    	283.12	2226	43.9	 0 00  0	72.9	283.29	57	1000	43.9	0	282.93	480	989.4	1550.4	43.9
    	283.65	2247	44.7	 0 00  0	72.9	283.82	57	1000	46.3	0	283.47	490	989.4	1570.8	43.9
    	284.13	2247	50.2	 0 00  0	72.9	284.3	58	1000	50.2	0	283.97	470	989.4	1581	47.8
    	284.63	2268	51	 0 00  0	72.9	284.79	58	1000	51	0	284.46	425	989.4	1601.4	50.6
    	285.15	2289	51.8	 0 00  0	73.8	285.32	58	1000	53.7	0	284.98	420	989.4	1621.8	51
    	285.68	2310	53.7	 0 00  0	73.8	285.85	59	1000	53.7	0	285.51	405	989.4	1632	53.7
    	286.21	2310	53.7	 0 00  0	73.8	286.38	59	1000	53.7	0	286.04	395	989.4	1621.8	53.7
    	286.74	2268	0	 0 01  0	73.8	286.91	59	1100	0	0	286.58	380	989.4	1591.2	49.4
    	287.27	1533	36.1	 0 00  0	73.8	287.44	59	1100	39.2	0	287.1	485	989.4	1346.4	0
    	287.77	1638	39.6	 0 00  0	74.7	287.94	59	1000	42.4	0	287.61	460	989.4	1234.2	39.6
    	288.28	1638	42.7	 0 00  0	74.7	288.44	59	1000	42.7	0	288.1	430	989.4	1295.4	42.7
    	288.78	1680	44.7	 0 00  0	74.7	288.94	59	1000	44.7	0	288.61	445	989.4	1336.2	44.7
    	289.25	1659	44.7	 0 00  0	74.7	289.42	60	1000	44.7	0	289.09	440	989.4	1366.8	44.7
    	289.73	1638	44.7	 0 00  0	74.7	289.89	60	1000	44.7	0	289.58	480	989.4	1387.2	44.7
    	290.22	1659	44.7	 0 00  0	75.6	290.37	60	1000	44.7	0	290.06	475	989.4	1417.8	44.7
    	290.7	1701	44.7	 0 00  0	75.6	290.86	60	1000	44.7	0	290.53	435	989.4	1428	44.7
    	291.19	1680	44.7	 0 00  0	75.6	291.37	60	1000	44.7	0	291.03	445	989.4	1417.8	44.7
    	291.68	1659	44.3	 0 00  0	75.6	291.84	60	1000	44.3	0	291.53	435	989.4	1428	44.7
    	292.19	1659	44.3	 0 00  0	75.6	292.36	60	1000	44.3	0	292.02	485	989.4	1428	44.3
    	292.7	1680	44.3	 0 00  0	75.6	292.86	60	1000	44.3	0	292.54	440	989.4	1428	44.3
    	293.21	1680	43.1	 0 00  0	76.5	293.37	60	1000	41.2	0	293.05	435	989.4	1417.8	43.9
    	293.7	1659	39.6	 0 00  0	76.5	293.85	60	1000	39.6	0	293.53	435	989.4	1407.6	40
    	294.17	1659	39.6	 0 00  0	76.5	294.36	59	1000	38.4	0	294.01	480	989.4	1387.2	39.6
    	294.7	1638	37.6	 0 00  0	76.5	294.89	59	1000	37.6	0	294.53	510	989.4	1377	38
    	295.23	1638	35.7	 0 00  0	76.5	295.39	59	1000	34.9	0	295.06	480	989.4	1366.8	36.9
    	295.71	1638	31	 0 00  0	77.4	295.86	59	1000	29	0	295.55	455	989.4	1346.4	33.3
    	296.2	1617	27.5	 0 00  0	77.4	296.37	58	1000	27.1	0	296.03	405	989.4	1305.6	27.8
    	296.73	1596	22.4	 0 00  0	77.4	296.89	58	1000	0	0	296.56	375	989.4	1264.8	25.5
    	297.23	1575	0	 0 01  0	77.4	297.39	56	1000	0	0	297.07	345	989.4	1213.8	0
    	297.73	1512	0	 0 01  0	77.4	297.89	55	1000	0	0	297.55	380	989.4	1142.4	0
    	298.2	1470	0	 0 01  0	77.4	298.37	54	1000	0	0	298.05	385	989.4	1101.6	0
    	298.7	1428	0	 0 01  0	78.3	298.87	52	1000	0	0	298.53	355	989.4	1081.2	0
    	299.18	1386	0	 0 01  0	78.3	299.34	51	1000	0	0	299.03	350	989.4	1071	0
    	299.67	1365	0	 0 01  0	78.3	299.82	49	1000	0	0	299.51	375	989.4	1060.8	0
    	300.15	1323	0	 0 01  0	78.3	300.31	48	1000	0	0	299.98	350	989.4	1050.6	0
    	300.67	1281	0	 0 01  0	78.3	300.84	46	1011	0	0	300.49	380	989.4	1050.6	0
    	301.18	1218	0	 0 01  0	78.3	301.34	44	1011	0	0	301	340	989.4	1040.4	0
    	301.67	1050	0	 0 01  0	79.2	301.85	42	1111	0	0	301.5	340	989.4	1040.4	0
    	302.17	798	0	 0 01  0	79.2	302.34	39	1111	0	0	302.01	320	989.4	1030.2	0
    	302.7	819	0	 0 01  0	79.2	302.87	35	1111	0	0	302.54	375	989.4	1020	0
    	303.2	840	0	 0 01  0	79.2	303.37	31	1111	0	0	303.04	350	989.4	1009.8	0
    	303.73	840	0	 0 01  0	79.2	303.9	26	1111	0	0	303.56	325	989.4	1009.8	0
    	304.26	819	0	 0 01  0	79.2	304.43	22	1111	0	0	304.09	390	989.4	999.6	0
    	304.76	819	0	 0 01  0	80.1	304.93	18	1111	0	0	304.6	335	989.4	1009.8	0
    	305.27	819	0	 0 01  0	80.1	305.43	15	1111	0	0	305.09	365	989.4	999.6	0
    	305.75	819	0	 0 01  0	80.1	305.93	13	1111	0	0	305.6	335	989.4	1009.8	0
    	306.24	819	0	 0 01  0	80.1	306.4	12	1111	0	0	306.08	350	989.4	999.6	0
    	306.75	840	0	 0 01  0	80.1	306.91	11	1111	0	0	306.59	370	989.4	999.6	0
    	307.26	819	0	 0 01  0	80.1	307.43	11	1111	0	0	307.07	330	989.4	999.6	0
    	307.78	819	0	 0 01  0	81	307.94	10	1111	0	0	307.6	380	989.4	999.6	0
    	308.29	819	0	 0 01  0	81	308.46	9	1111	0	0	308.1	345	989.4	999.6	0
    	308.8	819	0	 0 01  0	81	308.96	8	1111	0	0	308.63	320	989.4	999.6	0
    	309.32	819	0	 0 01  0	81	309.49	6	1111	0	0	309.13	350	989.4	999.6	0
    	309.83	819	0	 0 01  0	81	309.98	4	1111	0	0	309.65	335	989.4	999.6	0
    	310.32	819	0	 0 01  0	81	310.48	2	1111	0	0	310.15	400	989.4	999.6	0
    	310.84	840	0	 0 01  0	81	311.01	1	1111	0	0	310.66	335	989.4	999.6	0
    	311.37	819	0	 0 01  0	81.9	311.54	0	1100	0	0	311.19	390	989.4	999.6	0
    	311.85	840	0	 0 01  0	81.9	312.02	0	1100	0	0	311.69	345	989.4	999.6	0
    	312.35	819	0	 0 01  0	81.9	312.52	1	1100	0	0	312.18	380	989.4	999.6	0
    	312.85	1428	11.4	 0 00  0	81.9	313.05	1	1100	12.5	0	312.68	320	989.4	999.6	7.8
    	313.36	1197	12.5	 0 00  0	81.9	313.52	3	1100	12.5	0	313.21	360	989.4	1040.4	12.5
    	313.85	1092	11.8	 0 00  0	81.9	314.02	6	1100	11.8	0	313.69	410	989.4	1071	11.8
    	314.35	1134	13.7	 0 00  0	81.9	314.52	9	1100	14.5	0	314.19	340	989.4	1081.2	11.8
    	314.88	1323	21.2	 0 00  0	81.9	315.05	11	1000	25.5	0	314.71	315	989.4	1071	14.5
    	315.38	1512	30.2	 0 00  0	81.9	315.55	13	1000	32.2	0	315.22	405	989.4	1081.2	29.8
    	315.88	1764	34.9	 0 00  0	81.9	316.05	15	1000	35.7	0	315.7	420	989.4	1142.4	34.5
    	316.38	1995	36.5	 0 00  0	81.9	316.55	17	1000	36.5	0	316.2	455	989.4	1234.2	36.5
    	316.89	2184	13.7	 0 00  0	81.9	317.05	19	1100	0	0	316.72	470	989.4	1356.6	36.5
    	317.36	1491	0	 0 01  0	82.8	317.53	20	1100	11	0	317.2	495	989.4	1366.8	0
    	317.86	1596	37.3	 0 00  0	82.8	318.05	21	1100	40	0	317.69	380	989.4	1173	35.7
    	318.39	1470	40.8	 0 00  0	82.8	318.57	24	1100	42.7	0	318.22	525	989.4	1244.4	40.8
    	318.89	1680	42.7	 0 00  0	82.8	319.05	26	1000	42.7	0	318.73	525	989.4	1315.8	42.7
    	319.4	1827	46.3	 0 00  0	82.8	319.56	29	1000	49	0	319.24	605	989.4	1407.6	44.3
    	319.91	2016	49.8	 0 00  0	82.8	320.08	33	1000	51.4	0	319.72	610	989.4	1550.4	49
    	320.44	2184	53.3	 0 00  0	82.8	320.61	35	1000	54.9	0	320.25	600	989.4	1693.2	51.8
    	320.95	2310	56.5	 0 00  0	82.8	321.11	38	1000	56.9	0	320.78	585	989.4	1815.6	55.7
    	321.47	2457	60	 0 00  0	82.8	321.64	40	1000	60	0	321.28	525	989.4	1897.2	58.4
    	321.98	2562	61.6	 0 00  0	82.8	322.14	42	1000	61.6	0	321.81	480	989.4	1978.8	60.8
    	322.5	2688	62.7	 0 00  0	82.8	322.67	44	1000	62.7	0	322.31	450	989.4	2019.6	62
    	323.03	2793	63.1	 0 00  0	82.8	323.2	46	1000	61.2	0	322.84	415	989.4	2070.6	63.1
    	323.56	2478	0	 0 01  0	82.8	323.73	48	1100	0	0	323.37	725	989.4	2091	0
    	324.04	1785	0	 0 01  0	82.8	324.21	48	1100	28.6	0	323.88	445	989.4	1275	0
    	324.54	1995	57.6	 0 00  0	82.8	324.69	49	1100	60	0	324.37	410	989.4	1101.6	52.2
    	325.05	1995	66.7	 0 00  0	82.8	325.23	51	1000	70.6	0	324.89	480	989.4	1377	64.7
    	325.58	2037	76.1	 0 00  0	82.8	325.75	52	1000	26.7	0	325.41	415	989.4	1530	74.1
    	326.08	2037	4.3	 0 00  0	82.8	326.25	54	1000	26.7	0	325.92	680	989.4	1591.2	0
    	326.58	2142	32.5	 0 00  0	82.8	326.76	54	1000	34.1	0	326.4	455	989.4	1254.6	28.2
    	327.09	2163	36.9	 0 00  0	82.8	327.25	55	1000	38.4	0	326.92	545	989.4	1346.4	34.1
    	327.57	2184	39.6	 0 00  0	82.8	327.75	56	1000	42.4	0	327.42	615	989.4	1499.4	38.4
    	328.07	2247	42.7	 0 00  0	83.7	328.23	57	1000	42.7	0	327.92	640	989.4	1611.6	42.7
    	328.56	2289	42.7	 0 00  0	83.7	328.74	58	1000	44.3	0	328.4	675	989.4	1703.4	42.7
    	329.09	2331	44.3	 0 00  0	83.7	329.24	60	1000	44.3	0	328.92	690	989.4	1785	44.3
    	329.58	2394	44.3	 0 00  0	83.7	329.74	61	1000	44.7	0	329.4	715	989.4	1795.2	44.3
    	330.06	2457	53.7	 0 00  0	83.7	330.25	63	1000	60.4	0	329.9	675	989.4	1652.4	51.4
    	330.59	2562	65.9	 0 00  0	83.7	330.78	65	1000	65.9	0	330.42	815	989.4	1846.2	63.5
    	331.12	2688	67.1	 0 00  0	83.7	331.29	68	1000	69.4	0	330.95	840	989.4	2070.6	65.9
    	331.62	2856	79.2	 0 00  0	83.7	331.81	72	1000	79.6	0	331.45	805	989.4	1989	74.5
    	332.15	3024	79.6	 0 00  0	83.7	332.34	76	1000	79.6	0	331.98	875	989.4	2142	79.6
    	332.66	3192	71	 0 00  0	83.7	332.84	80	1000	0	0	332.51	885	989.4	2264.4	77.3
    	333.18	2667	0	 0 01  0	83.7	333.35	82	1100	0	0	333.01	560	989.4	1948.2	0
    	333.68	2415	56.5	 0 00  0	83.7	333.87	82	1100	75.3	0	333.51	425	989.4	1213.8	34.1
    	334.21	2352	83.9	 0 00  0	83.7	334.4	84	1000	88.2	0	334.04	685	989.4	1468.8	81.2
    	334.72	2436	92.5	 0 00  0	84.6	334.88	86	1000	94.9	0	334.57	945	989.4	2050.2	89.8
    	335.22	2541	91.4	 0 00  0	84.6	335.38	90	1000	76.5	0	335.06	990	989.4	2356.2	94.9
    	335.74	2604	34.5	 0 00  0	84.6	335.91	93	1000	0	0	335.57	995	989.4	2427.6	58
    	336.24	2604	0	 0 01  0	84.6	336.41	93	1000	0	0	336.08	420	989.4	1550.4	0
    	336.75	2562	0	 0 01  0	84.6	336.91	92	1000	0	0	336.57	400	989.4	1122	0
    	337.24	2541	0	 0 01  0	84.6	337.43	91	1011	0	0	337.07	395	989.4	1040.4	0
    	337.77	2478	0	 0 01  0	84.6	337.94	90	1011	0	0	337.6	400	989.4	1040.4	0
    	338.26	2436	0	 0 01  0	84.6	338.46	88	1011	0	0	338.1	400	989.4	1040.4	0
    	338.8	2373	0	 0 01  0	84.6	338.99	86	1011	0	0	338.63	405	989.4	1040.4	0
    	339.33	2310	0	 0 01  0	84.6	339.51	84	1011	0	0	339.16	405	989.4	1040.4	0
    	339.84	2247	0	 0 01  0	85.5	339.99	82	1011	0	0	339.68	405	989.4	1040.4	0
    	340.33	2205	0	 0 01  0	85.5	340.49	80	1011	0	0	340.17	410	989.4	1040.4	0
    	340.84	2184	0	 0 01  0	85.5	341.01	79	1011	0	0	340.65	415	989.4	1030.2	0
    	341.37	2142	0	 0 01  0	85.5	341.54	77	1011	0	0	341.18	415	989.4	1030.2	0
    	341.88	2121	0	 0 01  0	85.5	342.03	76	1011	0	0	341.71	415	989.4	1030.2	0
    	342.35	2079	0	 0 01  0	85.5	342.54	75	1011	0	0	342.19	410	989.4	1030.2	0
    	342.88	2058	0	 0 01  0	85.5	343.07	74	1011	0	0	342.72	410	989.4	1030.2	0
    	343.41	2016	0	 0 01  0	85.5	343.58	73	1011	0	0	343.24	420	989.4	1020	0
    	343.91	1995	0	 0 01  0	85.5	344.06	72	1011	0	0	343.74	415	989.4	1020	0
    	344.41	1953	0	 0 01  0	86.4	344.58	71	1011	0	0	344.24	425	989.4	1020	0
    	344.91	1911	0	 0 01  0	86.4	345.08	69	1011	0	0	344.75	425	989.4	1020	0
    	345.42	1869	0	 0 01  0	86.4	345.58	68	1011	0	0	345.23	425	989.4	1020	0
    	345.91	1827	0	 0 01  0	86.4	346.08	66	1011	0	0	345.73	430	989.4	1020	0
    	346.42	1785	0	 0 01  0	86.4	346.58	65	1011	0	0	346.25	430	989.4	1020	0
    	346.89	1743	0	 0 01  0	86.4	347.06	63	1011	0	0	346.73	435	989.4	1020	0
    	347.39	1722	0	 0 01  0	86.4	347.55	62	1000	0	0	347.22	430	989.4	1030.2	0
    	347.9	1701	0	 0 01  0	86.4	348.06	61	1000	0	0	347.74	420	989.4	1030.2	0
    	348.41	1680	0	 0 01  0	86.4	348.58	60	1000	0	0	348.22	435	989.4	1030.2	0
    	348.92	1638	0	 0 01  0	87.3	349.08	59	1000	0	0	348.75	425	989.4	1040.4	0
    	349.44	1617	0	 0 01  0	87.3	349.61	59	1000	0	0	349.25	425	989.4	1040.4	0
    	349.97	1617	0	 0 01  0	87.3	350.14	58	1000	0	0	349.78	425	989.4	1040.4	0
    	350.49	1596	0	 0 01  0	87.3	350.65	57	1000	0	0	350.31	425	989.4	1040.4	0
    	351	1575	0	 0 01  0	87.3	351.17	57	1000	0	0	350.81	430	989.4	1040.4	0
    	351.53	1575	0	 0 01  0	87.3	351.7	56	1000	0	0	351.34	420	989.4	1040.4	0
    	352.04	1554	0	 0 01  0	87.3	352.19	56	1000	0	0	351.87	420	989.4	1040.4	0
    	352.53	1554	0	 0 01  0	87.3	352.71	56	1000	0	0	352.36	430	989.4	1040.4	0
    	353.02	1554	0	 0 01  0	87.3	353.18	56	1000	0	0	352.87	425	989.4	1040.4	0
    	353.51	1554	0	 0 01  0	87.3	353.68	56	1000	0	0	353.35	415	989.4	1040.4	0
    	354	1554	0	 0 01  0	87.3	354.15	56	1011	0	0	353.85	425	989.4	1050.6	0
    	354.48	1533	0	 0 01  0	87.3	354.64	55	1011	0	0	354.31	430	989.4	1050.6	0
    	354.97	1512	0	 0 01  0	87.3	355.16	54	1011	0	0	354.81	415	989.4	1050.6	0
    	355.48	1470	0	 0 01  0	87.3	355.64	53	1011	0	0	355.32	425	989.4	1050.6	0
    	355.98	1428	0	 0 01  0	87.3	356.14	52	1011	0	0	355.82	425	999.6	1050.6	0
    	356.5	1428	0	 0 01  0	87.3	356.67	51	1000	0	0	356.33	415	999.6	1040.4	0
    	357.03	1449	0	 0 01  0	87.3	357.2	52	1000	0	0	356.86	410	989.4	1040.4	0
    	357.56	1449	0	 0 01  0	87.3	357.73	52	1000	0	0	357.39	400	999.6	1040.4	0
    	358.06	1470	9	 0 00  0	87.3	358.23	52	1000	12.5	0	357.9	420	999.6	1040.4	0
    	358.56	1533	12.5	 0 00  0	87.3	358.73	53	1000	12.5	0	358.38	380	999.6	1050.6	12.9
    	359.07	1512	12.5	 0 00  0	87.3	359.23	54	1000	12.5	0	358.9	375	999.6	1071	12.5
    	359.54	1533	12.5	 0 00  0	87.3	359.71	55	1000	12.5	0	359.38	380	999.6	1081.2	12.5
    	360.04	1554	12.5	 0 00  0	87.3	360.19	55	1000	12.5	0	359.87	375	999.6	1091.4	12.5
    	360.54	1554	13.3	 0 00  0	87.3	360.69	56	1000	12.5	0	360.37	390	999.6	1091.4	13.3
    	361.03	1554	12.5	 0 00  0	87.3	361.19	56	1000	12.5	0	360.85	400	999.6	1101.6	12.5
    	361.51	1575	12.2	 0 00  0	87.3	361.7	57	1000	12.9	0	361.35	385	999.6	1101.6	11.4
    	362.04	1596	13.3	 0 00  0	87.3	362.23	57	1000	13.3	0	361.87	390	999.6	1101.6	12.9
    	362.57	1596	14.1	 0 00  0	87.3	362.74	57	1000	14.1	0	362.4	385	999.6	1111.8	13.3
    	363.07	1575	13.7	 0 00  0	87.3	363.24	57	1000	13.7	0	362.9	395	999.6	1111.8	14.1
    	363.57	1596	13.7	 0 00  0	87.3	363.76	57	1000	13.7	0	363.4	395	999.6	1122	13.7
    	364.1	1575	13.7	 0 00  0	87.3	364.29	57	1000	13.3	0	363.93	380	999.6	1122	13.7
    	364.63	1575	13.3	 0 00  0	87.3	364.8	57	1000	13.3	0	364.46	395	999.6	1122	13.3
    	365.13	1575	13.3	 0 00  0	87.3	365.32	57	1000	12.5	0	364.96	390	999.6	1122	13.3
    	365.66	1554	12.5	 0 00  0	86.4	365.85	56	1000	12.5	0	365.49	385	999.6	1122	12.5
    	366.17	1575	12.5	 0 00  0	86.4	366.36	56	1000	12.5	0	366.02	390	999.6	1111.8	12.5
    	366.69	1554	12.2	 0 00  0	86.4	366.86	56	1000	12.2	0	366.52	385	999.6	1111.8	12.5
    	367.19	1554	9.8	 0 00  0	86.4	367.38	56	1000	9.8	0	367.02	400	999.6	1111.8	12.2
    	367.71	1575	9.8	 0 00  0	86.4	367.88	56	1000	9.8	0	367.55	405	999.6	1101.6	9.8
    	368.21	1554	9.4	 0 00  0	86.4	368.39	56	1000	9.4	0	368.05	375	999.6	1101.6	9.4
    	368.72	1533	9.4	 0 00  0	86.4	368.91	55	1000	9.4	0	368.54	395	999.6	1091.4	9.4
    	369.25	1512	9.4	 0 00  0	86.4	369.43	54	1000	9.4	0	369.08	390	999.6	1091.4	9.4
    	369.75	1491	7.1	 0 00  0	86.4	369.91	54	1000	0	0	369.6	395	999.6	1091.4	8.6
    	370.24	1470	0	 0 01  0	86.4	370.4	53	1000	0	0	370.08	425	999.6	1081.2	0
    	370.76	1449	0	 0 01  0	86.4	370.92	52	1000	0	0	370.57	410	999.6	1071	0
    	371.24	1407	0	 0 01  0	86.4	371.42	51	1000	0	0	371.08	415	999.6	1060.8	0
    	371.74	1386	0	 0 01  0	86.4	371.93	50	1000	0	0	371.58	415	999.6	1060.8	0
    	372.27	1344	0	 0 01  0	86.4	372.46	49	1011	0	0	372.1	415	999.6	1050.6	0
    	372.8	1302	0	 0 01  0	86.4	372.99	47	1011	0	0	372.63	420	999.6	1050.6	0
    	373.31	1239	0	 0 01  0	86.4	373.49	45	1111	0	0	373.16	395	999.6	1040.4	0
    	373.83	861	0	 0 01  0	86.4	374	43	1111	0	0	373.66	420	999.6	1040.4	0
    	374.33	777	0	 0 01  0	86.4	374.52	40	1111	0	0	374.16	390	999.6	1030.2	0
    	374.86	819	0	 0 01  0	85.5	375.03	37	1111	0	0	374.69	415	999.6	1020	0
    	375.36	840	0	 0 01  0	85.5	375.51	34	1111	0	0	375.19	365	999.6	1009.8	0
    	375.86	819	0	 0 01  0	85.5	376.03	30	1111	0	0	375.69	410	999.6	1009.8	0
    	376.36	819	0	 0 01  0	85.5	376.53	26	1111	0	0	376.2	370	999.6	1009.8	0
    	376.88	819	0	 0 01  0	85.5	377.04	23	1111	0	0	376.69	415	999.6	1009.8	0
    	377.37	819	0	 0 01  0	85.5	377.53	20	1111	0	0	377.2	355	999.6	1009.8	0
    	377.86	819	0	 0 01  0	85.5	378.05	17	1111	0	0	377.7	385	999.6	1009.8	0
    	378.39	840	0	 0 01  0	85.5	378.58	14	1111	0	0	378.22	355	999.6	1009.8	0
    	378.9	819	0	 0 01  0	85.5	379.06	12	1111	0	0	378.74	410	999.6	1009.8	0
    	379.39	819	0	 0 01  0	85.5	379.56	9	1111	0	0	379.23	360	999.6	1009.8	0
    	379.92	819	0	 0 01  0	85.5	380.09	6	1111	0	0	379.75	400	999.6	1009.8	0
    	380.42	819	0	 0 01  0	85.5	380.59	4	1111	0	0	380.26	360	999.6	1009.8	0
    	380.95	840	0	 0 01  0	85.5	381.12	3	1100	0	0	380.78	390	999.6	1009.8	0
    	381.48	819	0	 0 01  0	85.5	381.64	3	1100	7.8	0	381.31	400	999.6	1009.8	0
    	381.97	1470	9.8	 0 00  0	85.5	382.15	3	1100	12.5	0	381.82	335	999.6	999.6	9.4
    	382.49	1260	17.3	 0 00  0	85.5	382.65	4	1100	18.8	0	382.29	405	999.6	1050.6	16.9
    	382.99	1239	25.1	 0 00  0	85.5	383.15	7	1100	25.1	0	382.82	410	999.6	1101.6	22.4
    	383.47	1281	25.9	 0 00  0	85.5	383.65	10	1100	29.4	0	383.31	410	999.6	1132.2	25.1
    	383.97	1617	33.3	 0 00  0	85.5	384.14	13	1000	34.5	0	383.81	475	999.6	1142.4	30.2
    	384.51	1932	39.2	 0 00  0	85.5	384.67	16	1000	39.2	0	384.33	485	999.6	1213.8	37.6
    	385.03	2226	40.4	 0 00  0	85.5	385.2	19	1000	32.5	0	384.86	570	999.6	1377	40.4
    	385.53	2100	0	 0 01  0	85.5	385.7	21	1100	0	0	385.37	640	999.6	1540.2	0
    	386.03	1638	36.5	 0 00  0	85.5	386.2	22	1100	47.8	0	385.85	445	999.6	1162.8	0
    	386.53	1533	50.6	 0 00  0	85.5	386.7	25	1100	51	0	386.35	520	999.6	1152.6	50.6
    	387.06	1764	54.9	 0 00  0	85.5	387.23	28	1000	55.3	0	386.87	515	999.6	1326	53.7
    	387.57	1995	54.5	 0 00  0	85.5	387.73	31	1000	53.7	0	387.38	600	999.6	1499.4	55.3
    	388.07	2163	58.4	 0 00  0	85.5	388.23	35	1000	59.6	0	387.9	600	999.6	1662.6	54.5
    	388.59	2310	60	 0 00  0	85.5	388.76	38	1000	60	0	388.4	525	999.6	1795.2	59.2
    	389.1	2478	0	 0 01  0	85.5	389.26	40	1100	0	0	388.93	435	999.6	1856.4	59.2
    	389.6	1869	0	 0 01  0	85.5	389.76	41	1100	20	0	389.43	445	999.6	1458.6	0
    	390.12	1659	61.2	 0 00  0	85.5	390.29	43	1100	64.7	0	389.93	450	999.6	1142.4	48.2
    	390.63	1764	64.7	 0 00  0	85.5	390.79	45	1000	64.7	0	390.46	540	999.6	1356.6	64.7
    	391.13	1869	65.1	 0 00  0	85.5	391.29	47	1000	65.1	0	390.96	610	999.6	1581	65.1
    	391.63	1995	65.1	 0 00  0	85.5	391.79	50	1000	65.9	0	391.46	595	999.6	1764.6	65.1
    	392.15	2142	67.5	 0 00  0	85.5	392.32	53	1000	67.5	0	391.96	600	999.6	1897.2	67.5
    	392.67	2163	67.8	 0 00  0	85.5	392.83	55	1000	67.8	0	392.49	560	999.6	1989	67.5
    	393.18	2268	67.8	 0 00  0	85.5	393.35	58	1000	62.4	0	392.99	560	999.6	2060.4	67.8
    	393.71	2352	59.2	 0 00  0	85.5	393.88	60	1000	60	0	393.52	525	999.6	2111.4	59.2
    	394.22	2415	61.6	 0 00  0	85.5	394.38	61	1000	61.6	0	394.05	510	999.6	2091	62
    	394.7	2436	63.1	 0 00  0	85.5	394.88	62	1000	66.3	0	394.55	445	999.6	2060.4	61.6
    	395.22	2499	66.7	 0 00  0	85.5	395.41	63	1000	66.7	0	395.05	390	999.6	1978.8	66.7
    	395.74	2541	66.7	 0 00  0	85.5	395.91	64	1000	54.1	0	395.58	335	999.6	1846.2	66.7
    	396.22	2541	51	 0 00  0	85.5	396.38	65	1000	58.4	0	396.08	440	999.6	1744.2	46.3
    	396.73	2562	63.5	 0 00  0	85.5	396.89	65	1000	62.4	0	396.57	220	999.6	1754.4	61.2
    	397.24	2541	51	 0 00  0	85.5	397.41	66	1000	45.9	0	397.05	260	999.6	1581	51
    	397.76	2604	51	 0 00  0	85.5	397.93	66	1000	52.2	0	397.57	280	999.6	1499.4	47.8
    	398.27	2583	52.2	 0 00  0	85.5	398.43	66	1000	52.2	0	398.1	290	999.6	1468.8	52.2
    	398.8	2604	50.6	 0 00  0	85.5	398.96	67	1000	51	0	398.6	290	999.6	1458.6	50.6
    	399.32	2583	50.6	 0 00  0	85.5	399.49	67	1000	37.6	0	399.13	305	999.6	1458.6	51.4
    	399.83	2541	32.5	 0 00  0	85.5	399.99	67	1000	31.4	0	399.66	290	999.6	1438.2	35.3
    	400.35	2583	32.9	 0 00  0	85.5	400.52	66	1000	32.9	0	400.16	325	999.6	1366.8	32.9
    	400.88	2541	19.6	 0 00  0	86.4	401.05	66	1000	18.8	0	400.69	340	999.6	1336.2	26.7
    	401.36	2499	0	 0 01  0	86.4	401.53	65	1000	0	0	401.2	365	999.6	1285.2	0
    	401.84	2478	0	 0 01  0	86.4	402	64	1000	0	0	401.69	380	999.6	1264.8	0
    	402.34	2457	0	 0 01  0	86.4	402.5	63	1000	0	0	402.18	455	999.6	1275	0
    	402.85	2415	0	 0 01  0	86.4	403.01	62	1000	0	0	402.66	445	999.6	1193.4	0
    	403.34	2394	0	 0 01  0	86.4	403.5	62	1000	0	0	403.17	420	999.6	1142.4	0
    	403.85	2352	0	 0 01  0	86.4	404.01	61	1000	0	0	403.66	430	999.6	1122	0
    	404.33	2331	0	 0 01  0	86.4	404.51	60	1000	0	0	404.17	425	999.6	1101.6	0
    	404.83	2310	0	 0 01  0	86.4	405.02	60	1000	0	0	404.67	425	999.6	1091.4	0
    	405.34	2289	0	 0 01  0	86.4	405.5	59	1000	0	0	405.18	420	999.6	1081.2	0
    	405.86	2268	0	 0 01  0	87.3	406.03	58	1000	0	0	405.69	425	999.6	1071	0
    	406.39	2226	0	 0 01  0	87.3	406.56	57	1011	0	0	406.22	430	999.6	1071	0
    	406.89	2163	0	 0 01  0	87.3	407.06	56	1011	0	0	406.73	420	999.6	1071	0
    	407.39	2079	0	 0 01  0	87.3	407.56	54	1011	0	0	407.21	430	999.6	1060.8	0
    	407.87	2016	0	 0 01  0	87.3	408.05	53	1011	0	0	407.71	435	999.6	1050.6	0
    	408.37	1953	0	 0 01  0	87.3	408.53	51	1011	0	0	408.21	435	999.6	1050.6	0
    	408.87	1869	0	 0 01  0	87.3	409.02	49	1011	0	0	408.71	430	999.6	1040.4	0
    	409.36	1785	0	 0 01  0	87.3	409.52	47	1011	0	0	409.18	435	999.6	1040.4	0
    	409.84	1701	0	 0 01  0	87.3	410.03	45	1011	0	0	409.68	435	999.6	1040.4	0
    	410.36	1617	0	 0 01  0	87.3	410.53	42	1011	0	0	410.2	435	999.6	1040.4	0
    	410.86	1533	0	 0 01  0	87.3	411.06	40	1111	0	0	410.69	430	999.6	1040.4	0
    	411.39	1029	0	 0 01  0	87.3	411.59	37	1111	0	0	411.22	430	999.6	1050.6	0
    	411.93	819	0	 0 01  0	88.2	412.12	35	1111	0	0	411.76	395	999.6	1040.4	0
    	412.45	819	0	 0 01  0	88.2	412.62	32	1111	0	0	412.28	370	999.6	1020	0
    	412.95	819	0	 0 01  0	88.2	413.11	29	1111	0	0	412.78	385	999.6	1009.8	0
    	413.45	840	0	 0 01  0	88.2	413.62	26	1111	0	0	413.29	380	999.6	1009.8	0
    	413.95	1323	0	 0 01  0	88.2	414.1	23	1111	0	0	413.79	370	999.6	1009.8	0
    	414.43	1218	0	 0 01  0	88.2	414.59	21	1100	0	0	414.26	415	999.6	1020	0
    	414.9	1176	0	 0 01  0	88.2	415.07	20	1000	0	0	414.74	405	999.6	1030.2	0
    	415.4	1134	7.5	 0 00  0	88.2	415.56	19	1000	9	0	415.23	380	999.6	1030.2	1.2
    	415.9	1218	15.3	 0 00  0	88.2	416.06	19	1000	15.3	0	415.74	365	999.6	1030.2	11.4
    	416.42	1197	15.3	 0 00  0	88.2	416.59	20	1000	15.7	0	416.23	390	999.6	1050.6	15.3
    	416.95	1302	17.3	 0 00  0	88.2	417.12	21	1000	19.6	0	416.76	370	999.6	1071	16.5
    	417.46	1386	22	 0 00  0	88.2	417.62	22	1000	22	0	417.29	410	999.6	1091.4	22
    	417.94	1407	22	 0 00  0	88.2	418.12	23	1000	23.1	0	417.79	435	999.6	1122	22
    	418.46	1449	27.1	 0 00  0	88.2	418.64	24	1000	27.5	0	418.29	440	999.6	1142.4	24.3
    	418.96	1491	27.5	 0 00  0	88.2	419.12	24	1000	27.5	0	418.8	475	999.6	1173	27.5
    	419.46	1512	29	 0 00  0	88.2	419.63	25	1000	29.8	0	419.3	475	999.6	1203.6	28.2
    	419.97	1533	31	 0 00  0	88.2	420.13	25	1000	31.4	0	419.79	475	999.6	1224	30.2
    	420.46	1575	32.9	 0 00  0	88.2	420.65	26	1000	32.9	0	420.29	485	999.6	1254.6	32.2
    	420.99	1638	34.1	 0 00  0	88.2	421.16	27	1000	34.1	0	420.82	530	999.6	1295.4	33.7
    	421.47	1659	34.1	 0 00  0	88.2	421.63	27	1000	34.5	0	421.31	510	999.6	1326	34.1
    	421.99	1701	35.7	 0 00  0	88.2	422.16	28	1000	35.7	0	421.82	525	999.6	1366.8	35.3
    	422.49	1722	36.1	 0 00  0	88.2	422.66	28	1000	36.9	0	422.33	550	999.6	1397.4	36.1
    	422.99	1722	36.9	 0 00  0	88.2	423.16	29	1000	37.6	0	422.81	535	999.6	1428	36.9
    	423.47	1743	38	 0 00  0	88.2	423.64	29	1000	38	0	423.31	550	999.6	1448.4	37.6
    	423.97	1743	38	 0 00  0	88.2	424.12	29	1000	38	0	423.8	565	999.6	1468.8	38
  6. Likes Uwe liked this post
  7. #16
    Dallas (McKinney) ,TX ,USA
    Quote Originally Posted by atikovi View Post
    Holds for over 5 minutes at full vacuum.
    Starts moving at 6 psi.
    Stops at 19 psi.
    That is to late , needs to start at 4 and finish at 17 max 18. That is probably why you do not have power before 2200 rpm.
    You need to adjust VNT actuator , but on that car is very hard to do it .
    Marker	STAMP	 /min	 mbar	 mbar	 %	STAMP					STAMP
    	0.1	0	1183.2	979.2	0
    	0.25	0	1183.2	979.2	0
    	0.42	0	1183.2	979.2	0
    	0.61	0	1183.2	979.2	0
    	0.78	0	1183.2	979.2	0
    	0.95	0	1183.2	979.2	0
    	1.14	0	1183.2	979.2	0
    	1.3	0	1183.2	979.2	0
    	1.46	0	1183.2	979.2	0
    	1.63	0	1183.2	979.2	0
    	1.8	0	1183.2	979.2	0
    This is way to much 202 difference But also RPM is 0 which not making sense , is this with Engine running or just ignition On?
    One thing I can tell you , The Place who rebuilt Turbo I think have no idea about VW turbos.
    BY the way , you have Rocketchip stage 1F chip tune .
    Immobilizer/ECU
    email : marinmm2001@gmail.com
  8. #17
    Apr 2017
    So 1 or 2 psi makes such a big difference? I could imagine the accuracy of the gauge might be off that much. Arrgh! Removing the turbo was such a pain. I'll double check for sure before taking it back out. Does the stop screw need to be adjusted or the length of the actuator rod?
    Must have started logging before beginning the test. How do you tell what tune it has?
  9. #18
    03G 906 016 AB RC s01f EDC G000SG 7550
    Rocketchip does this signature.
    Immobilizer/ECU
  10. Likes Jack@European_Parts, Uwe liked this post
  11. #19
    Thursday 16 May 2019 14:04:44:53717-VCID:63CF59B0A2846D52A0-8036 VCDS Version: Release 18.9.1 (x64) Data version: 20190114 DS296.0
    03G 906 016 AB RC s01fEDC G000SG 7550
    Indeed Marin.....
    Anything over a 150 to 200 MBAR MAP value deviation, negative or positive, will result in limp mode!
  12. Likes Jetta ,97 liked this post
