Results 1 to 8 of 8
Thread: 2011 Passat B7 Euro Spec - RVC
    Aug 2014
    Norway
    I need to replace the rear lid on my Passat estate and I was thinking of upgrading the rear view camera while I'm at it. My current RVC is mounted above the license plate next to the push button for the rear lid (3C9 827 566 A). I'd like to replace this with the "flip out" badge version (3AE 827 469) so it is less exposed to dirt, especially during winter time. I do have a couple of questions:
    - ETKA lists 3AE 827 469 as an option for notchback only. Has anyone retrofitted this on an estate? Is it room for it? Any issues?
    - Can I use the same wiring harness and/or control unit as before? Btw my current camera is a highline (i.e. has guidelines). I'll stick with the current push button for opening the read lid.
    Wednesday,01,August,2018,11:40:42:22644
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
    VCDS Version: 18.2.1.2
    VIN: WVWZZZ3CZBE325045   License Plate:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 10 13 14 15 16 17 18 19 20 22 25 36 37 42 44
              46 47 4F 52 53 55 56 61 62 65 6C 6D 72 77
    VIN: WVWZZZ3CZBE325045   Mileage: 85130km-52897miles
    Address 01: Engine (J623-CFGB)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 BN    HW: 03L 907 309 N
       Component: R4 2.0l TDI   H24 9977
       Revision: 47H24---    Serial number: 00000000000000
       Coding: 001D003A046601080000
       Shop #: WSC 40190 222 00000
       ASAM Dataset: EV_ECM20TDI01103L906018BN 003007
       ROD: EV_ECM20TDI01103L906018BN.rod
       VCID: 77D302B3CE9530FC16-8022
       Part No SW: 02E 300 013 M    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2601
       Revision: 05351112    Serial number: 00001011091155
       Shop #: WSC 05311 000 00000
       VCID: 1B1B3E03DAFDB49CD2-804E
       Part No SW: 3AA 614 109 P    HW: 3AA 614 109 P
       Component: J104   C2 450M V560 0011
       Revision: --H07---    Serial number: 00000003272703
       Coding: 0121279
       VCID: 3A55DB877507ED9429-806E
       Part No SW: 3AA 907 044 AJ    HW: 3AA 907 044 AJ
       Component: Climatronic   H03 0303
       Revision: 00001K02
       Coding: 0014004802
       Shop #: WSC 00015 115 00000
       VCID: 78D1018FC38B3F841F-802C
       Part No SW: 3AA 937 087 A    HW: 3AA 937 087 A
       Component: BCM PQ47 H    413 0452
       Revision: BB413001
       Coding: 0002000000000000000C008874000DEC43D56388676DA5607F80C7240041
       Shop #: WSC 05311 123 12345
       VCID: 3851C18F8B0BFF84DF-806C
       Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
       Component: Wischer 16111  10  0603
       Coding: 00B795
       Component: RLS 081210 05  54  0403
       Coding: 035028
    Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
       Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
       Component: PARKHILFE PLA H04 0007
       Revision: --------    Serial number: 20431034500293
       Coding: 308306
       ASAM Dataset: EV_EPHVA2C000000000 001006
       ROD: EV_EPHVA2C000000000_001_VW36.rod
       VCID: 3C59DD9FB733D3A43B-8068
    Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
       Part No SW: 3AA 907 567     HW: 3AA 907 567
       Component: AC201  RDW A    031 0143
       Revision: 00031000    Serial number: 00000000078439
       Coding: 0010000
       Shop #: WSC 05311 000 08193
       VCID: 77D302B3069530FC16-8022
       Revision: 00000000    Serial number: 23111002930001
       Coding: 030180
       Shop #: WSC 05314 000 00000
       VCID: 277312F356B5607C46-8072
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__101 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0PQS5JZW
       Coding: 0012337
       VCID: 4CB98D5F2F9363248B-8018
       Subsystem 1 - Serial number: 6332MTS673593060
       Subsystem 2 - Serial number: 6342MTS651483070
       Subsystem 3 - Serial number: 6351HTS6VLNTH9KR
       Subsystem 4 - Serial number: 6361HTS6PHRTF6KJ
       Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101130301577
       Coding: 399AA50001
       VCID: 75CF08BBD49942EC04-8020
       Coding: E30000
       Part No SW: 3AA 920 880 A    HW: 3AA 920 880 A
       Component: KOMBI         H02 0206
       Coding: 161F00
       Shop #: WSC 05314 115 12345
       VCID: 3147FCAB60712ECC98-8064
    Address 18: Aux. Heat        Labels: 1K0-815-007.clb
       Part No: 7N0 963 272 A
       Component: Standheizer     043 4730
       Revision: 00043000    Serial number: 09022127000000
       Coding: 0031032
       VCID: 334BF6A3526D1CDCEA-8066
       Part No SW: 7N0 907 530 G    HW: 1K0 907 951
       Component: J533  Gateway H41 1614
       Revision:   H41       Serial number: 091210F1003001
       Coding: 462006
       Shop #: WSC 05314 123 12345
       VCID: 3449F5BF97631BE4F3-8060
       Part No SW: 5K0 857 511 B    HW: 8P0 857 511 C
       Component: FLA           H04 0006
       Revision: AA001002
       Coding: 01018E67727261565623393E00
       VCID: 2D7FE0DB74494A2CBC-8078
       Part No SW: 0BS 907 554 B    HW: 0BS 907 554 B
       Component: Haldex 4Motion      4015
       Coding: 0000005
       VCID: 45AFB87B0CF9926C54-8010
       Part No SW: 3AA 959 799     HW: 3AA 959 799
       Component:    IMMO         083 0399
       Revision: 00083000    Serial number: VWZCZ000000000
       VCID: 052F787B4C79526C14-8050
    Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
       Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
       Component: Sitzmemory    H05 2201
       Revision: 00H05000
       Coding: 000039
       VCID: 334BF6A3926D1CDCEA-8066
       Part No SW: 1T0 035 686 E    HW: 1T0 035 686 E
       Component: RNS-MID       H21 6270
       Revision: AB001001    Serial number: VWZ6Z7N9312149
       Coding: 00050002010000800000
       VCID: 364DCFB7811F09F4CD-8062
       Subsystem 1 - Part No: 1T0 919 859 B
       Component: EU West V15  8515
       Component: TUER-SG FT    002 0529
       Revision: 12110009    Serial number: 0001828416
       Coding: 0211FF
       Shop #: WSC 05311 115 00000
       VCID: 354FC8BB941902ECC4-8060
       Slave Driver:
       Subsystem 1 - Part No SW: 3AA 959 703     HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0407
       Serial number: 00000001741953
       Coding: 0000D8
       Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.318 0802
       Revision: 1AH03729    Serial number: 00103360113601
       Coding: 0000258
       VCID: 3B5BDE837A3DD49C32-806E
    Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
       Component: 02 KESSY PQ47   083 0323
       Coding: 01900A00D2C30E76300494157E00CFCE705801030424B8
       Subsystem 1 - Part No: 1K8 951 605 A
       Component: LIN BACKUP HORN H11 9004
       Part No SW: 3AA 035 456 A    HW: 3AA 035 456 A
       Component: DSP 10 Kanal        0020
       Revision: 00H02001    Serial number: 75818000267704
       VCID: 2D7FE0DBB4494A2CBC-8078
       Component: EZE_2         H41 1614
       Coding: 050B0508
       VCID: 6FC33AD3BEC5783CCE-803A
       Subsystem 3 - Part No SW: 3AA 919 204     HW: 3AA 919 204
       Component: Analoguhr  003 0003
       Component: TUER-SG BT    002 0529
       Revision: 14110009    Serial number: 0001832542
       Coding: 0211FE
       VCID: 364DCFB7891F09F4CD-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3AA 959 704     HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0407
       Serial number: 00000001755172
       Coding: 0000D8
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000077057
       Coding: 0022067
       Component: AFS-ECU       H04 0111
       Coding: 02B2000003000200
       Shop #: WSC 05311 115 12345
       VCID: 3753C2B38E15F0FCD6-8062
       Subsystem 1 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo links  H04 0012
       Coding: 230000
       Subsystem 2 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H04 0012
       Coding: 230000
       Component: Batt.regelung H41 1614
       Coding: 030B185A
       VCID: 71C73CABA8F16ECCD8-8024
       Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
       Component: J367-BDM  H07 0150
       Serial number: 00000000009370219854
       Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
       Component: RDKBERU30     H04 0011
       Serial number: 30000000049734
       ASAM Dataset: EV_RDKBERU30 005005
       ROD: EV_RDKBERU30_005.rod
       Part No SW: 3C9 907 441     HW: 3C9 907 441
       Component: J772__Rearview      0020
       Revision: 00H08000    Serial number: 525PA8-J0X1596
       Coding: 0020007
       VCID: 68F151CF5B2BAF048F-803C
       Part No SW: 3C9 827 383 J    HW: 3C9 827 383 J
       Component: J605  HECKDECKEL    0804
       Revision: 00H27001
       VCID: 3851C18F4B0BFF84DF-806C
       Subsystem 1 - Part No: 3C9 827 384 J
       Component: J756  HECKDECKEL    0804
       Subsystem 2 - Serial number: 1000H27001001B0090
       Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
       Component: Telefon       022 0946
       Revision: --------    Serial number: 35502105030069
       Coding: 020000000100010000000001
       ASAM Dataset: EV_UHVPremi 002708
       ROD: EV_UHVPremi.rod
       VCID: 246905FF2F838B6463-8070
    End-------------------------(Elapsed Time: 04:28)--------------------------
    Mar 2015
    Australia
    I've seen it done online. Involves a bit of cutting of the existing sheet metal in the boot to make a hole for the camera:
    https://www.drive2.ru/l/7098739/
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
    Jul 2014
    Tallinn, Estonia
    There is another easier way - installing the RVC washer by swapping out the rear lid button case and installing a washer line splitter from an Audi A4 B9 to feed the washer. I've done this to my B7 and it has been working fine. It sprays when you activate your rear wiper and spray.
    https://www.ebay.co.uk/itm/Original-...QAAOSw42JZAkDy
    https://www.drive2.ru/l/481262562743156879/
  4. Likes kamold, bjornix liked this post
    Mar 2015
    Australia
    Wow that's a neat solution!
    I've never even thought about it because the only things we need to wash off the camera lens here are spiders, drop bears (look them up) and crocodiles
    Aug 2014
    Norway
    @siLc: That does look a lot easier than cutting of the existing sheet metal, and would undoubtedly work with the existing wiring. But does it really get the job done when the lens is covered with dirt?
    Jul 2014
    Tallinn, Estonia
    I mainly used it in the wintertime when watery dirt covered the RVC and it took care of it fine. Havent had the chance to use it in a drier time of year.
    Aug 2014
    Norway
    Great, thanks! Think I will give the rear lid button case with integrated washer nozzle a try. Do you happen to have the part numbers for the extra parts needed? Splitter, coupling elements, hoses etc. Tried to search ETKA, but couldn't find the A4 Y-splitter you mentioned. Don't know if something like this would work?
  9. #8
    Jul 2014
    Tallinn, Estonia
    You can make do with only the splitter, which is 8W9 955 934. This is my setup.
    I was retrofitting a MIB2 compatible highline RVC at the time and I had to file the sides and back of the camera to fit inside the rear lid button case. Since you have the older style of camera, you may or may not have to do the same.
