hi this VW beetle will not run it cranks fine but will not run , if i clear the codes if will run for like 2 second then dead nothing will not run just crank any help on this please
kind regards
Bo
kind regards
Bo
Wednesday,15,May,2019,23:25:40:45815
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4437.4
VIN: WVWZZZ16ZCM614145 License Plate: TMD33
Mileage: 66720km-41457mi Repair Order:
Chassis Type: 16-VW32 (6N0)
Scan: 01 03 08 09 10 15 17 19 25 37 44 56
VIN: WVWZZZ16ZCM614145 Mileage: 66720km-41457miles
04-Steering Angle -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 JD HW: 03F 907 309
Component: SIMOS10.12AH10 2663
Revision: --H10--- Serial number: 00000000000000
Coding: 001900D6232400080000
Shop #: WSC 00066 000 00070
ASAM Dataset: EV_ECM12TFS02103F906070JD 004004
ROD: EV_ECM12TFS02103F906070FP.rod
VCID: 6D87C80ABD1AD11F45B-8038
13628 - Throttle Actuator (J338)
P1564 00 [037] - Under-Voltage during Basic Setting
Mileage: 66722 km
Date: 2019.05.15
Time: 01:42:08
Coolant temperature: 21 °C
Intake air temperature: 23 °C
Voltage terminal 30: 12.593 V
TPS_AD_CDN_MIS: 32
Battery voltage: 12.5 V
VP_TPS_1: 0.8301 V
VP_TPS_2: 4.1846 V
6450 - System Voltage
P0562 00 [037] - Too Low
Mileage: 66722 km
Date: 2019.05.15
Time: 01:41:39
Voltage terminal 30: 12.491 V
CTR_RST_MC: 0
CTR_RST_MU: 0
Ambient temperature: 20.25 °C
Engine torque: 102.75000 Nm
Readiness: 0110 0101
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: E13B20F8092300FE870C04E8901E0040210000
Shop #: WSC 00066 000 00000
VCID: 7BA3F652F3EE4FAFCBF-802E
Reset counter: 21
Mileage: 66722 km
Date: 2013.10.05
Time: 01:41:11
Count: 3
Count: 2
Count: 20992
Count: 166
Count: 44800
Count: 508
Reset counter: 21
Mileage: 66722 km
Date: 2013.10.05
Time: 01:41:11
Count: 3
Count: 2
Count: 20992
Count: 8213
Count: 44800
Count: 508
Fault Status: 01101100
Reset counter: 21
Mileage: 66722 km
Date: 2013.10.05
Time: 01:41:11
Count: 3
Count: 2
Count: 20992
Count: 64
Count: 44800
Count: 508
Part No SW: 5C0 907 044 B HW: 5C0 907 044 B
Component: Climatronic H02 0101
Revision: 00001001
Coding: 3010004002
Shop #: WSC 00066 000 00231
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 221DEB363444DE67A89-8076
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 5C5 937 087 HW: 5C5 937 087
Component: BCM25 JLB H+4 H48 0251
Revision: B7048001 Serial number: 04441267110134
Coding: 6CB829380801080001A008006C0F86C400C2430F60840000B20004000000
VCID: 6FBBD202B796230F777-803A
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 250811 05 54 0403
Coding: 02300A
Subsystem 2 - Part No SW: 6R0 959 801 AP HW: 6R0 959 801 AP Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 1060
Serial number: KU0KU019031300010466
Coding: 0CBC30
Subsystem 3 - Part No SW: 6R0 959 802 BC HW: 6R0 959 802 BC Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 1060
Serial number: KU0KU018121200011073
Coding: 0CBC30
03429 - Activation of Right Adaptive Light
Fault Status: 01101011
Reset counter: 21
Mileage: 66722 km
Date: 2013.10.05
Time: 01:41:11
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 5C5 919 475 HW: 7E0 919 475 A
Component: PARKHILFE 8K H10 0005
Revision: -------- Serial number: 84091124300338
Coding: 108001
Shop #: WSC 00066 000 00125
ASAM Dataset: EV_EPHVA18VW3240000 001004
ROD: EV_EPHVA18VW3240000.rod
VCID: 70B9D17EAA283CF76ED-8024
Part No SW: 5C0 959 655 F HW: 5C0 959 655 F
Component: AirbagVW10 012 0613
Serial number: 003JQD01557-
Coding: 0000424B
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3537206A95CA59DF7DB-8060
Serial number: 3572MSME63001463ZZZG
Serial number: 3582MSME72031463ZZZK
Part No SW: 5C5 920 870 HW: 5C5 920 870
Component: KOMBI H10 0015
Revision: X0010005 Serial number:
Coding: 150B00
ASAM Dataset: EV_KombiUDSMM9RM10 A04305
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
VCID: 678BBA229FE6FB4F3F7-8032
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [137] - -
[Steuergerät für Lenkhilfe: keine Kommunikation]
Reset counter: 21
Mileage: 66722 km
Date: 2019.05.15
Time: 01:41:12
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C5 937 087
Component: GW-K-CAN TP20 H48 0251
Revision: B7048001
Coding: 402000
VCID: 70B9D17EAAA83CF76ED-8024
Reset counter: 21
Mileage: 66722 km
Date: 2013.10.05
Time: 01:41:11
Reset counter: 21
Mileage: 66722 km
Date: 2013.10.05
Time: 01:41:11
Part No SW: 5K0 953 234 HW: 5C5 920 870
Component: IMMO H10 0015
ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A8DC3168CF4C627209-803E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 D HW: 3C0 035 279 D
Component: RNS315-EU H33 0263
Serial number: VWZAZ2L3829555
Coding: 000004310400020000008000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 2411ED2E2E50D057DA5-8070
Component: EUR_W_0031 0031
1048599 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
[tweeter rear left open load]
Reset counter: 21
Mileage: 66722 km
Date: 2019.05.15
Time: 01:41:13
Address 44: Steering Assist
End----------(Elapsed Time: 01:08, VBatt start/end: 12.5V/12.6V)-----------
