2005 Touareg V8 - Air Suspension leak voltage when car is OFF.
TechNorris
Terrebonne, QC, Canada
C?ID=353427
I had battery issues for months, I now tested that I lose around 0,30Amp on the Air Suspension "Fuze" when car is OFF.
Is there something specific I should check from there? Should it be coming form the computer module or the air shock itself?
DrPeter
16.4905° S, 151.7375° W
The controller that you are checking may not be fully asleep yet. Are you sure this is the fuse for the level Controller? You can use the Official Factory repair manuals and wiring diagrams to trace back the components on that specific fuse.
I also recommend to have a look at this Volkswagen technical bulletin, Parasitic draw testing through fuse panel VW technical bulletin 270711
This technical bulletin will outline the proper way to accurately measure for parasitic draws on these vehicles. One very important thing this document mentions is the recommend TWO Hour wait period that is needed for ALL the controllers to go to sleep.
Observe sleep state current draw after vehicle is left untouched for TWO HOURS
Also post an Auto-Scan if possible, this can help when searching for updates and other information about the vehicle and it's controllers.
Hope this helps,
drpeter
TechNorris
C?ID=353427
Thanks for your help.
I did'nt wait for 2 hours but 20 minutes. that was the time when all but that fuze were down. I indeed tested the old fashion way. Wait 2 hours also, mean I need to leave my ohmmeter ON for 2 hour while connected between ground and BAT -.
The Volkswagen technical bulletin is very informative. I did'nt know about the other way of testing from the fuze. Funny to read we need to keep the door closed and test the fuze. Is it enough to keep the door open but manually lock the door locking module to simulate it's closed?
Either way to test, I am pretty confident that I have this leak anyway. But still will not be sure how to find the origin of the leak.
Hope this helps,
drpeter
TechNorris
C?ID=353427
Here is my AutoScan. Any idea to diagnose the exact cause of the current leak?
Thanks!
Wednesday,12,June,2019,12:14:17:55476
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 19.6.0.6 (x64)  HEX-V2 CB: 0.4505.4
VIN: WVGMM67L75D055257   License Plate:
Mileage: 203460km-126424mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGMM67L75D055257   Mileage: 203460km-126424miles
Address 01: Engine        Labels: 077-907-560-AXQ.lbl
   Part No SW: 4D0 907 560 DB    HW: 8E0 907 560
   Component: 4.2L V8/5V      G   0010
   Revision: 00000000    Serial number: VWZ3Z0D7284728
   Coding: 0007875
   Shop #: WSC 94713 999 52438
   VCID: 698FBF8C0564690F7DB-5161
17887 - Brake Boost Vacuum System
            P1479 - 008 - Mechanical Failure
18104 - Powertrain Data Bus
            P1696 - 002 - Implausible Message from Steering Column Controller - Intermittent
16826 - EVAP Emission Control Sys
            P0442 - 001 - Small Leak - MIL ON
17417 - Mass Air Flow Sensor 1/2
            P1009 - 004 - Implausible Signal from Load Calculation
Readiness: 0000 0001
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0014594
   Shop #: WSC 31414 000 00000
   VCID: 3D273BDC216C25AFE13-5161
02054 - Control Module for Differential Locks (J647)
   Part No SW: 3D0 909 135 R    HW: 5WK 470 26
   Component: 17 Kessy            6610
   Revision: 66105312    Serial number: VWZ3Z0D7284728
   Coding: 0131304
   VCID: 34311EF81226E4E71ED-5161
00087 - Terminal 30 for Starting Relevant Consumers
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77ABE9F443D0CFFFFBF-5161
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 H
   Component: CLIMAtronic R/L   X 3716
   Coding: 0000030
   VCID: 353723FC195CFDEF293-5161
02193 - Supply Voltage for Regulator for Fresh Air Blower
            010 - Open or Short to Plus
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 M
   Component:                     3001
   Coding: 0105695
   VCID: 46D5543074BA6677B09-5161
02196 - Fuse for Control Module for Power Supply to Vehicle Battery (S287)
   Part No: 3D0 909 601 E
   Component: 0C Airbag 8.4E+ H10 0952
   Coding: 0012355
   VCID: 2517F3BCA9FC8D6F993-5161
01221 - Crash Sensor Side Airbag; Driver Side (G179)
            011 - Open Circuit - MIL ON
            012 - Electrical Fault in Circuit - MIL ON
   Part No: 7L6 953 549 E
   Component: Lenksäulenmodul     3301
   Coding: 0000232
   VCID: 41DF472C5D94414F85B-5161
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 881 D
   Component: KOMBIINSTRUMENT RB8 3135
   Coding: 0005331
   Shop #: WSC 94713 999 59229
   VCID: 392F2FCC3544198FCDB-5161
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B9D2E826BE98C73A5-5161
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   VCID: 45D7533C49BC6D6FB93-5161
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  0001
   Coding: 0000003
   VCID: 6695B4B0147A4677509-5185
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   Shop #: WSC 94706 999 999999
   VCID: 363524F0045AF6F7209-5161
Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
   Part No: 7L6 919 887 C
   Component:      Navigation     0047
   Coding: 0000101
   Part No: 3D0 909 158
   Coding: 0000003
   VCID: 678BB9B413705F7F6BF-5161
00492 - Body Pitch Angle from Level Control Module
   Part No: 7L0 959 933 E
   Component: H6 HSG              0201
   Coding: 0000085
   VCID: 3E253CD02C6A3EB7F89-4B01
   Subsystem 1 - Part No: 7L0 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Subsystem 4 - Part No: 7L0 959 704 D
01134 - Alarm Horn (H12)
00901 - Back-Up Lamps
01735 - Potentiometer for Mirror Adj. Horizontal; Pass. Side
Address 56: Radio        Labels: 7L6-035-186-CD.lbl
   Part No: 7L6 035 186 A
   Component:        Radio        0047
   Coding: 0014062
   VCID: 313F17ECED34D1CF75B-5161
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000855
   Shop #: WSC 31414 000 376832
   VCID: 3C2136D83A762CA7D6D-5161
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00217125
   Shop #: WSC 31414
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 K
   Component: DACHDISPLAY         0538
   Revision: 00700538    Serial number: 2009289.06
   VCID: 3FDB41D42B6037BFF3F-5161
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
No Faults Found
End----(Elapsed Time: 08:20, VBatt start/end: 11.6V/11.9V. VIgn 11.9V)-----
DrPeter
Yes, there are four steps listed in the TSB that explain what to do next.
Identification of component:
1.Once fused circuit is identified,use service repair and wiring diagram information in ElsaWeb to identify all components on circuit
2.Disconnect components from the circuit one by one and allow sleep current to stabilize after each elimination.
3.Measure vehicle current consumption and voltage drop across fuse once again. If with in normal range, as specified in the table (see Current Consumption Matrix attachment), the component with excessive consumption is identified.
4.Repeat steps above until component is identified causing excessive current draw.
Ref: Volkswagen technical bulletin, Parasitic draw testing through fuse panel VW technical bulletin 270711 - Bentley Publishers
Let us know what you find,
drpeter
