Results 1 to 9 of 9
Thread: A3 8V 2.0 TDI electronic parking brake issues
    May 2019
    Cambridgeshire, UK
    Hi, has anyone had issues where the EPB stops working on Auto release method. The only way I can release the handbrake is by pressing the button with either the brake or gas pedal pressed. Ran an auto scan on vcds and no errors.
    Previously changed the 12v battery (was 12.1v) as my cars 6 years old. Chanting the battery inadvertently resolved the issue and the handbrake started to auto release again. But 2 months on and suddenly the same problem. Battery currently at 12.8v but only 13.2v when the engine is at idle?? This drops to 12.9v under heavy load.... Can this be the cause (i.e alternator).
    Any thoughts?
    Oct 2014
    Arandjelovac, Serbia
    Post full Auto Scan, please.
    May 2019
    Cambridgeshire, UK
    Wednesday,15,May,2019,21:31:35:11164
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WAUZZZ8V1EA******   License Plate:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F BB BC
    VIN: WAUZZZ8V1EA******   Mileage: 134191km-83382miles
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 7544
       Revision: 83H22---
       Coding: 02190012030501082000
       Shop #: WSC 03080 002 1048576
       ASAM Dataset: EV_ECM20TDI01104L906021DS 002012
       ROD: EV_ECM20TDI01104L906021DS_002.rod
       VCID: 79ACE5F1C95BEB0FD93-802C
       Part No SW: 5Q0 907 379 AA    HW: 5Q0 907 379 G
       Component: ESC           H31 0457
       Revision: 00000000    Serial number: 63163000001DFC
       Coding: 12F18AA224200A730180060441C9294851245080608294F2004300388608
       Shop #: WSC 06314 790 00021
       ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
       VCID: 7BA0FFF9C367D91FCBF-802E
       Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
       Component: AC Automat    H13 0052
       Revision: 20026000    Serial number: 00000000196227
       Coding: 03100104002000011000000000001100
       VCID: 323E12DD54ADD857589-8066
       Serial number: B0480AD6000000000001
       Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
       Component: BCM MQBAB H   H16 0124
       Serial number: 00011332400918
       Coding: 07040A42C24120DD03844004B31C07A80000000000000000000000000000
       ASAM Dataset: EV_BCMCONTI 012001
       ROD: EV_BCMBOSCH_012.rod
       Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS370 131111 041 0580
       Serial number:         131112193237
       Coding: 0A47F7
       Subsystem 2 - Part No SW: 8V0 941 531 J    HW: 8V0 941 531 J
       Serial number: 10 07 2013 00000203
       Subsystem 3 - Part No SW: 8V0 951 177     HW: 5Q0 951 172
       Component: Sensor, DWA 005 0315
       Serial number: 000000000ZY132802XMB
       Serial number: 00000000000028330265
       Subsystem 5 - Part No SW: 8U0 955 559     HW: 8U0 955 559
       Component: G355_FeuchteS H07 0002
       Serial number: 20565825
       Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
       Serial number: 003M2R043PZZ
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 4BC06F39D347A99F3BF-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 002 111 13
       Serial number: 35767000000B182C3E0-
       Subsystem 2 - Part No SW: -----------    HW: 480 002 111 13
       Serial number: 35867000000B172C3E0-
       Subsystem 3 - Part No SW: -----------    HW: 480 401 911 13
       Serial number: 3516502A51230BB280E3
       Subsystem 4 - Part No SW: -----------    HW: 480 401 911 13
       Serial number: 3526502C91118A3202A$
       Subsystem 5 - Part No SW: -----------    HW: 480 400 410 13
       Serial number: 3556502BB1142C8370CC
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 911 13
       Component: PedP_Sensor_D 001 6149
       Serial number: 2286502AF1118A34A259
       Subsystem 7 - Part No SW: -----------    HW: 480 400 911 13
       Component: PedP_Sensor_P 001 6149
       Serial number: 22965029F1118A3283FG
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 911 13
       Component: PedP_Sensor_C 001 6149
       Serial number: 2306502B11118A3162EY
       Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
       Component: Lenks. Modul 002 0110
       Revision: --------    Serial number: 19111304401009
       Coding: 8408
       VCID: 06569E0D88A594F7A41-8052
       Part No SW: 8V0 920 970 N    HW: 8V0 920 970 N
       Component: KOMBI         H03 2220
       Coding: 278509002B8046000100BA00100000
       VCID: 47C85309CF2F4DFF1F7-8012
       Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1164
       Revision: --------    Serial number: 0001277863
       Coding: 030100040B0876005B000248080B00000001000000000000000000000000
       ASAM Dataset: EV_GatewLear 010015
       ROD: EV_GatewLear_010.rod
       VCID: 3FD84BE997FF053FA77-806A
       Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
       Serial number: 25 10 2013 D0337903
       Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella H03 8043
       Serial number: 5066051803
       Serial number: 11111306071280
       Coding: 00108E204001040000001002
       VCID: 40DA4815EA017AC7DED-8014
       Component: EPS_MQB_ZFLS 122 1043
       Coding: 8103
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 41DC4D11E10B73CFD13-8014
       Serial number: 13111302091525
       Coding: 001086204001040000001002
       Coding: 019C000001000000
       VCID: 75B4E9C1E5438F6FBDB-8020
    Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
       Part No SW: 8V0 035 874 B    HW: 8V0 035 874 B
       Component: MU-S-ND-ER    040 0420
       Serial number: A7F02411132757
       Coding: 01730301FF00000021111101000A00002F0001460100010006
       ASAM Dataset: EV_MUStd4CPASE 002018
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 3B203FF983E7191F8BF-806E
       Subsystem 1 - Part No SW: 8V0 919 603 B    HW: 8V0 919 603 B
       Component: DU Std H48 0013
       Serial number: AUZ8Z9DM700NFR
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
       Component: ControlUnit_B H33 0037
       Serial number: C1000003101300020047
       Part No SW: 5Q0 959 595 B    HW: 5Q0 959 595 B
       Component: TSG HFS       020 0025
       Serial number: 04111303110194
       Coding: 000086204001040000001002
       VCID: 42DE421DE40D68D7C89-8016
       Component: TSG HBFS      020 0025
       Serial number: 04111306070192
    End----------(Elapsed Time: 01:16, VBatt start/end: 12.3V/12.3V)-----------
    Quote Originally Posted by Ashbash516 View Post
    Any thoughts?
    ABS module (with integrated parking brake) does not seem to have a new version available.
    Is it possible the car things one of the seat belts that should be buckled isn't? I'm pretty sure that will cause the behavior you describe without setting any faults.
    Another idea: I wonder if the "cold boot" of all systems when you change the battery is what actually fixed the problem (as opposed to a "new" battery). You might try disconnecting your battery for a bit, then reconnecting it to see if that fixes it again.
    May 2019
    Cambridgeshire, UK
    Thank you for your help, being a vcds novice how does one apply the new version of the ABS Module? (I only know as much as following YouTube videos to add additional features like needle sweeps and drl brightness chnages).
    Yes the car is doing the type of behaviour as if the driver's seatbelt wasn't buckled (but it is in fact bucked in at all times when testing/ driving).
    Finally when the battery was changed for me the mechanic did plug in a portable power supply during the battery change to save the cars memory. Should I still try disconnecting the battery?
    I did forget to mention that I temporarily over came the problem (on numerous occasions prior to the battery change) by topping up the battery with my ctek 5.0 smart charger. I have since tried this method again but only got an a short lived tempory fix where the auto release started to work for about 50% of the times for 1 short (and now back to not releasing again).
  6. #6
    May 2019
    Cambridgeshire, UK
    Quote Originally Posted by Boki Ar View Post
    Auto scan added, thank you
  7. #7
    Sep 2015
    After battery replacement, did you also code the replacement in CAN gateway...? If not, your car still thinks it has the old battery and that may (or may not) cause many weird things.
    http://wiki.ross-tech.com/wiki/index...28UDS.2FODX.29
  8. Likes Dana liked this post
  9. #8
    May 2019
    Cambridgeshire, UK
    Quote Originally Posted by Mika_M View Post
    Yes all coded up
  10. Likes Dana liked this post
  11. #9
    Since there is no newer version available, it doesn't really matter. But if there was a newer version available, the path of least resistance would be to ask a dealer to install it.
    Interesting. In that case, a cold boot probably won't help.
    You might want to monitor these in the ABS module itself:
    IDE03680-IDE04444 -- Supply voltages - Terminal 30 voltage for pump
    IDE03680-IDE04445 -- Supply voltages - Terminal 30 voltage for valves
    I'm wondering if you have a dodgy connection somewhere that's causing them ABS to see voltages lower than they really are?
  12. Likes Dana liked this post
