Results 1 to 6 of 6
Thread: Can not get rid of module 69
    May 2019
    Sweden
    Hey! I have installed a towbar on my audi A6 2014! And tried to coding the car-specific power kit! Added module 69 But now that I run the scan, vcds gets stuck at module 69 and i have to forse stopp! So I think there is something wrong with the electric kit or does not work on my car! So now I have decided to plug in a regular canbus kit that I have at home! But the problem is that I cannot remove module 69! I uncheck and save coding coding accepted! But module 69 is still there and i cant get a scan the vcds get stuck at modul 69! What can i do?
    Oct 2014
    Arandjelovac, Serbia
    Please unplug problematic module and post an Auto Scan for beginning. Which interface You use?
  3. Likes Uwe liked this post
    May 2019
    Sweden
    Thanks for answer Boki Ar! I have HEX-USB+Can! I try to remove everything from this problem kit tomorow when i have time! And try to do a clean scan
  5. Likes Boki Ar liked this post
  6. #4
    Magdeburg, Germany
    The question as to which interface probably related to what electric kit you are using (i.e. which supplier). That said, the Auto-Scan is mandatory, especially in cases like this.
  8. #5
    May 2019
    Sweden
    That solved the problem! Now its all normal and bypass kit is installed and works! Thanks
  9. #6
    May 2019
    Sweden
    https://www.transportsysteme24.de/el...22-ts24-5.html
    It was this kit that did not work for me
