Results 1 to 6 of 6
Thread: A4 20TFSI QUATRO 2010 OVER FUELING
    Apr 2018
    South Africa
    Hi Guys Audi A4 20tfsi Q CDN came in over fueling badly only 105000km on the clock.
    only fault was mixture to rich,we replaced new injectors from agents,and decated the exhaust still no luck
    cold its ok then as she warms up starts puffing out black smoke until she cuts out and plugs are wet with fuel.
    any suggestions ?
    Apr 2018
    South Africa
    Monday,20,May,2019,10:50:42:16946
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
    Dealer/Shop Name: AUDI VW AUTO CLINIC
    Workshop Code: 996 02232 000010
    VIN: WAUZZZ8K6CA097093   License Plate:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72 77
    VIN: WAUZZZ8K6CA097093   Mileage: 105510km-65560miles
    Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
       Part No SW: 8K2 907 115 P    HW: 8K2 907 115 D
       Component: 2.0l R4/4V TF H20 0009
       Revision: E1H20---
       Coding: 0104000C240F0160
       Shop #: WSC 06324 000 00000
       ASAM Dataset: EV_ECM20TFS8K2907115P A01011
       ROD: EV_ECM20AVS.rod
       VCID: 3C34D153B72995AAC1-8068
    Readiness: 1110 0101
       Part No SW: 8K1 927 156 G    HW: 0B5 927 156 F
       Component: 0B5 20TFSIRdW H10 0009
       Revision: --H10---    Serial number: 0000000645
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ROD: EV_TCMDL501.rod
       VCID: 393AC847B81BA082DA-806C
       Part No SW: 8K0 907 379 BG    HW: 8K0 907 379 BG
       Component: ESP8 quattro  H04 0020
       Coding: 090500
       VCID: 7F4EE65FEEBF4EB2A4-802A
       Part No SW: 8K0 907 064 CC    HW: 8K0 907 064 CC
       Component: BCM2 2.0      H05 0435
       Coding: 011100
       VCID: 73A63A6FD2F71AD2D0-8026
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0811000184858007
       Serial number: 2311000239308006
       Part No SW: 8T2 820 043 AF    HW: 8T2 820 043 AF
       Component: KLIMA 3 ZONEN H08 0180
       Revision: D0000000    Serial number: 01141120110232
       Coding: 64040000
       VCID: 76A0037BC1850FFAF7-8022
       Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
       Component: BCM1 1.0      H30 0392
       Revision: 09030001    Serial number: 00000001123954
       Coding: 2600D0914034AF010001000000001D0D0F1D430802010141000000
       VCID: 3A38D74BB51DAB9AD3-806E
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 061111  H06 0070
       Serial number: SWF11110065132
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 11773079
       Coding: 025028
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002810111272
       Part No SW: 8K0 959 655 L    HW: 8K0 959 655 L
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003JMD0HDJL+
       Coding: 30533435363030303030554A3052384B3053
       VCID: 46C0B3BBF9E5DF7AA7-8012
       Serial number: 6334MSME671239359
       Serial number: 6344MSME65524F7CU
       Serial number: 6352QSME38643358H
       Serial number: 6362QSME38643D7AW
       Serial number: 63732SME40631270M
       Serial number: 63832SME40630E44Z
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372KK9001AN
       Coding: 000036
       VCID: 3D32DC57A4339CA2F6-8068
       Component: E221 - MFL  H02 0010
       Part No SW: 8K0 920 930 M    HW: 8K0 920 930 M
       Component: KOMBIINSTR.   H31 0258
       Revision: 00000000    Serial number: EJ84214CC
       Coding: 2F06090002000008010000
       VCID: 373ECE7F860FB6F22C-8062
       Part No SW: 8T0 907 468 AF    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0120
       Revision: GB901054    Serial number: 5400G11B0281CE
       Coding: 00C303
       VCID: 054274B78C631462EE-8050
       Component: J367-BDMHella  H03 8040
       Serial number: 5118785801
       Part No SW: 8T0 959 793 M    HW: 8T0 959 793 D
       Component: TSG FA        H08 1501
       Coding: 011C02204001410001
       VCID: 53E69AEF32B77AD230-8006
       Revision: 00002001    Serial number: 0163286618
       Coding: 011E062200B904008130013280000000
       Shop #: WSC 03163 996 87872
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
       Part No SW: 8T0 035 223 AH    HW: 8T0 035 223
       Component: DSP STD       H07 0230
       Revision: S2200000
       Coding: 0203010102
       VCID: 74A43973D7F91DEAC9-8020
       Part No SW: 8T0 959 792 M    HW: 8T0 959 792 D
       Component: TSG BF        H08 1501
       VCID: 52E89FEB0DAD73DA3B-8006
       Revision: 00000003    Serial number: 20000000145102
       VCID: 3424F97397795DEA09-8060
       Serial number: 111109-0002-034
       Coding: 1171A41010000200
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2D12EC177C530C2246-8078
       Part No SW: 8T2 035 186 P    HW: 8T2 035 186 P
       Component: Concert3      H06 0350
       Revision: 00000011    Serial number: AUZ5Z6K1669305
       Coding: 0502008201018D000359070000
       VCID: 45C2B4B7CCE3D462AE-8010
       Subsystem 1 - Part No SW: 8T0 919 603 F    HW: 8T0 919 603 F
       Component: Display
       Part No SW: 8T0 959 795 N    HW: 8T0 959 795 B
       Component: TSG HL        H06 1501
       Coding: 010C02204001210001
       VCID: 56E063FB21456FFAD7-8002
       Component: TSG HR        H06 1501
       Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005447011
       Coding: 0010390
       VCID: 3D32DC5764339CA2F6-8068
    End----------(Elapsed Time: 01:30, VBatt start/end: 12.7V/12.7V)-----------
    Apr 2018
    South Africa
    first fault found
    bank 1,system too rich at idle
    P2188/00(101)
    fault status 0000001
    fault priority 2
    fault frequency 2
    engine speed 813.00/min
    normal load value 12.9%
    coolest temp 97deg
    intake temp 39 deg
    ambient air pressue 1010mbar
    voltage terminal 30 14.065v
    Scratching head. My first reaction was that the ECU might not be seeing the engine warming up (temperature sensor problem), but that seems to be shot down by the freeze-frame data of 97deg.
    I would check fuel pressure next.
    IDE00201 -- High fuel pressure: specified value
    IDE00589-ENG167462 -- Fuel pressure OBD
    Apr 2018
    South Africa
    thanks Uwe..will do so
