- Joined
- May 14, 2019
- Messages
- 13
- Reaction score
- 24
- Location
- Netherlands
- VCDS Serial number
- C?ID=129250
I am using VCDs for 12 years now but never had this issue. I have 2 cars a 2019 A3 8V and a Audi Q2 with the same problems. I will post the autoscan from the Q2. The problem is as follows. I can do a full autoscan with no problems. And coding the gateway is no problem also but when trying to get in every other module will give the error: Controller refused to send a seed! Error : Unknown (0x00). Tryed a lot off things also tryed VCP but this gave the same issue. How can i solves this problem or what is the reason this error acure?
Address 17,81A 920 750 D,recoded (Long Coding-exp),from,05A4220C2B8000080D80E8001000000000000000,to,05A5220C2B8000080D80E8001000000000000000,(06314/790/00021),
Tuesday,16,April,2019,18:32:57:27059
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4436.4
Dealer/Shop Name: Tunincenter Lowering
VIN: WAUZZZGAXKA050866 License Plate: XX560P
Mileage: 793km-492mi Repair Order:
Chassis Type: GA-AU37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 29 39 42 44 4B 52 5F BB BC D6
D7
VIN: WAUZZZGAXKA050866 Mileage: 793km-492miles
4B-Multifunc. Module -- Status: Malfunction 0010
Address 01: Engine (J623-DADA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 R HW: 05E 907 309
Component: R4 1.5l TFS H22 6090
Revision: 81H22000
Coding: 022500322324150820000000000000000000000000000000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM15TFS01105E906018R 003002
ROD: EV_ECM15TFS01105E906018R.rod
VCID: 3424D10F9F52DCEA09-8060
23765 - Control unit for information electronics 1
U1054 00 [032] - No Communication
[Information electronics control module 1No Communication]
Mileage: 522 km
Date: 2019.04.13
Time: 13:58:44
Engine speed: 1307.50 /min
Normed load value: 4.3 %
Vehicle speed: 24 km/h
Coolant temperature: 98 °C
Intake air temperature: 30 °C
Voltage terminal 30: 13.360 V
Unlearning counter according OBD: 32
Outside air temperature: 13 °C
Absolute intake pressure: 34 kPa abs
Engine torque: 36.9 Nm
Fuel: tank fill level: 50.0 l
Oxygen sensor bank 1 sensor 1: specified value: 1.0000
Particulate filter: loading stage: 0
Overrun cut-off-Bits 0-7: 0
Address 02: Auto Trans (J743) Labels: None
Part No SW: 0CW 300 043 D HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1607
Revision: 00005008 Serial number: CU501902205272
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW31.rod
VCID: 383CE53F833A388A25-806C
Part No SW: 5Q0 614 517 EE HW: 5Q0 614 517 BN
Component: ESC H35 0107
Revision: 00000000 Serial number: 53548000005226
Coding: 34006A8D2025246C8B7F0E0662C9242C560424D1704624F31221F074921B4A0300000633D2D21212FF35351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038_AU37.rod
VCID: 78BC253FC3BAF88AE5-802C
Part No SW: 8V0 820 043 AA HW: 8V0 820 043 AA
Component: AC Automat H03 0140
Revision: 20001000 Serial number: 00000001760141
Coding: 06000004000000001000000000001000
ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
VCID: 71AA181BA0C0A9C222-8024
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 96D2D29900PAG0MUFU03
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H38 0273
Serial number: 00001905801365
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7CB4392FF782D4AA81-8028
Subsystem 1 - Part No SW: 81A 955 555 A HW: 81A 955 555
Serial number: 22540563X81A955555A0
Coding: 80005E
Light switch:
Subsystem 2 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 05 12 2018 20001159
Steering Column Switch:
Subsystem 3 - Part No SW: 82A 953 521 B HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000015021904400014
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 C HW: 5QA 919 283
Component: PDC 4 KanalH07 0050
Serial number: 000308419619055
Coding: 0600040011
ASAM Dataset: EV_EPHVA14AU3700000 009037
ROD: EV_EPHVA14AU3700000.rod
VCID: 4AD8AFF7EDD6BA1A43-801E
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 Q HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0342
Coding: 3200000150F78728747C61450040A700000000000000000008
ASAM Dataset: EV_ACCMRRCONTIVW376 003015
ROD: EV_ACCMRRCONTIVW376.rod
VCID: 42C887D7D5E6625A8B-8016
1127 - Databus
[FAULT_TIMEOUT_PSD_04]
Reset counter: 55
Mileage: 522 km
Date: 2019.04.13
Time: 13:58:45
Voltage terminal 15: 13.3 V
Control Module temperature: 29 °C
Velocity_vehicle_reference: 6.92 m/s
Longitudinal_acceleration_vehicle_reference: 0.09 m/s²
1218 - Databus
[FAULT_TIMEOUT_PSD_05]
Reset counter: 55
Mileage: 522 km
Date: 2019.04.13
Time: 13:58:45
Voltage terminal 15: 13.4 V
Velocity_vehicle_reference: 6.93 m/s
Longitudinal_acceleration_vehicle_reference: 0.06 m/s²
1219 - Databus
[FAULT_TIMEOUT_PSD_06]
Reset counter: 55
Mileage: 522 km
Date: 2019.04.13
Time: 13:58:45
Part No SW: 5Q0 959 655 BN HW: 5Q0 959 655 BN
Component: AirbagVW21 007 0403
Serial number: 003FHR529BCF
Coding: 88CCF0C000000000585400DFC048000000C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 0D5264EBDC38ED22A6-8058
Subsystem 1 - Part No SW: ----------- HW: 480 002 602 19
Serial number: 357000000005D475A93S
Subsystem 2 - Part No SW: ----------- HW: 480 002 602 19
Serial number: 35800000000FD475A93$
Subsystem 3 - Part No SW: ----------- HW: 480 402 202 19
Component: SideSensor_Dr 003 6149
Serial number: 3510001C52E4B1B3821+
Subsystem 4 - Part No SW: ----------- HW: 480 402 202 19
Component: SideSensor_Pr 003 6149
Serial number: 3520001C52E4B1B282DA
Subsystem 5 - Part No SW: ----------- HW: 480 400 702 19
Component: FrontSensor_D 004 6149
Serial number: 3550001022C0098283FW
Front Sensor Passenger:
Subsystem 6 - Part No SW: ----------- HW: 480 400 702 19
Component: FrontSensor_P 004 6149
Serial number: 3560001022C0098285CW
Part No SW: 81A 920 750 D HW: 81A 920 750 D
Component: KOMBI H21 2603
Coding: 05A4220C2B8000080D80E8001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
VCID: 25023C4B2488B5628E-8070
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_Audio_0x31 keine Kommunikation]
Reset counter: 55
Mileage: 522 km
Date: 2019.04.13
Time: 13:58:48
16777020 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Reset counter: 55
Mileage: 522 km
Date: 2019.04.13
Time: 13:58:48
16777022 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_NAV SD_0x32 keine Kommunikation]
Reset counter: 55
Mileage: 522 km
Date: 2019.04.13
Time: 13:58:48
16777026 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_MFL_Jokerfunktion_0x34 keine Kommunikation]
Reset counter: 55
Mileage: 522 km
Date: 2019.04.13
Time: 13:58:48
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4367
Revision: -------- Serial number: 0009156350
Coding: 030100043F0857005B00004A180B00000001010000000000000000000000
ROD: EV_GatewNF_VW37.rod
VCID: 6E900367B1FEB63A3F-803A
Component: 1-01-02-01-04
Subsystem 2 - Part No SW: 81A 951 523 HW: 81A 951 523
Component: J453 MFL H04 0004
Serial number: 20190211165438 22161
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1051
Serial number: 75886003911901281B75
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
[Globaler Timeout CAN-Infotainment]
Reset counter: 55
Mileage: 522 km
Date: 2019.04.13
Time: 13:58:45
Supply voltage: Terminal 30: 13.2 V
Terminal 15: On
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 C HW: 8S0 907 397 C
Component: LCM_MQB H07 0022
ASAM Dataset: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_VW41.rod
VCID: 41CA88DBD0E0794292-8014
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
ASAM Dataset: EV_LCMRightCONTIAU426 001009
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007SBF1391D
Coding: 00148B204000000000001002
VCID: 44C481CFCFF26C6AB9-8010
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 011F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: 3C34F92FB70214AAC1-8068
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 16021910802851
Coding: 000000050900116200102B03020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3522EC0B9428C5E23E-8060
13705489 - Databus
[PSD_04 data bus missing message]
Reset counter: 55
Mileage: 522 km
Date: 2019.04.13
Time: 13:58:45
Part No SW: 5Q0 959 392 F HW: 5Q0 959 392 F
Component: TSG BFS001 0287
Serial number: YE007SBG07106
Coding: 001483204000000000001002
Part No SW: 81A 035 193 E HW: 81A 035 193
Component: MU-HS-LN-EU 050 0235
Coding: 01720601FF00000011110001000A00102F00364401F00100CE
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP_AU37.rod
VCID: 2404214F2FB24C6A99-8070
Subsystem 1 - Part No SW: V03 959 802 LD HW: -----------
Component: ECE 2019 --- 0038
Subsystem 2 - Part No SW: 81A 919 604 B HW: 81A 919 604 B
Component: DU Std AU216 H42 0100
Serial number: INX00106121800020247
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 81B 919 614 A HW: 81B 919 614 A
Component: ControlUnit_B H20 0200
Serial number: APVAK106121800010143
0006 - Antenna Amplifier 2 for Radio
B126E 13 [008] - Open Circuit
Reset counter: 44
Mileage: 166 km
Date: 2019.04.08
Time: 14:29:58
Voltage terminal 30: 14.8 V
Status of antenna 2 for radio-Antenna current: 0 mA
Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
Status of antenna 2 for radio-Reception level antenna 2: 27 dBµV
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS003 0189
Serial number: YE007SBJ0762E
Coding: 000083004000000000001002
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 4ED0A3E711BE963A1F-801A
Component: TSG HBFS003 0189
Serial number: YE007SBJ07768
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 177E0683EEE417F20C-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
End----------(Elapsed Time: 01:22, VBatt start/end: 12.3V/12.3V)-----------
