Results 1 to 5 of 5
Thread: 2017 Audi A3 - deactivated airbags
    Sep 2014
    Guatemala
    Hi guys,
    I had never seen this "deactivated" message on airbags, the car apparently was in the dealer and suffered a rear crash, guy bought the cars at an auction and need to fix it. A suggestion for me to fix it if it's something easy as all belts look in good condition.
    Monday,13,May,2019,15:32:32:22246
    VIN: WAUBFGFF1F1009463   License Plate:
    Chassis Type: FF-AU37 (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 22 42 44 52 55 5F BB BC
    VIN: WAUBFGFF1F1009463   Mileage: 2003km-1244miles
    Address 01: Engine (J623-CNTC)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259 A    HW: 06K 907 425 B
       Revision: --H13---
       Coding: 0A1D00124426000F2000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0205G0906259A 001004
       ROD: EV_ECM20TFS0205G0906259A_AU37.rod
       VCID: 2C010756968E5907125-8078
    15214 - Manifold Pressure / Boost Sensor (G31)
              P0236 00 [175] - Implausible Signal
                        Mileage: 1991 km
                        Date: 2019.03.17
                        Time: 13:10:43
                        Coolant temperature: 54 °C
                        Intake air temperature: 17 °C
                        Ambient air pressure: 850 mbar
                        Voltage terminal 30: 12.187 V
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 85 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.943 V
                        FAC_TPS_1_SAE: 16.015625 %
                        FUP_H_SAE: 4470.0 kPa
    Readiness: 0010 0101
       Part No SW: 0D9 300 011 S    HW: 02E 927 770 AQ
       Component: DQ250-6A MQB  H52 4312
       Revision: 05852204    Serial number: TFK01402042348
       Shop #: WSC 04742 780 00200
       ROD: EV_TCMDQ250021.rod
       VCID: 2517F272F564684FCDB-8070
       Revision: 00000000    Serial number: 603940000000C1
       Coding: 13FF6A9234200A75017B030681C629C8562C5080C08194B4024100588608
       ROD: EV_Brake1UDSContiMK100IPB_033_AU37.rod
       VCID: 7BA3F40A23600EBFCBF-802E
    Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
       Part No SW: 8V0 820 047 E    HW: 8V0 820 047 E
       Component: AC Manuell el H11 0052
       Revision: 20021000    Serial number: 00000000050179
       Coding: 03000004000000000000000000000000
       ASAM Dataset: EV_AirCondiFrontManAU37X 008018
       ROD: EV_AirCondiFrontManAU37X.rod
       VCID: 38292B0652D6E5A766D-806C
       Part No SW: 5Q0 937 085 S    HW: 5Q0 937 085 S
       Component: BCM MQBAB MNA H16 0124
       Serial number: 00011403500132
       Coding: 04141A46C041227541C04004511007000000000000000000000000000000
       ROD: EV_BCMBOSCH_012.rod
       VCID: 49CF5EC2393C6C2F093-801C
       Component: WWS371 140131  041 0585
       Serial number:         140206123832
       Coding: 0A47F7
       Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
       Component: G397_RLS  H06 0002
       Serial number: 20135809
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 K    HW: 8V0 941 531 K
       Serial number: 27 11 2013  00000668
       Serial number: 00000000000058826276
       Sun Roof:
       Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.009  H02 0007
       Serial number:     WOO27091957
       Coding: 101F00
       Serial number: 003GCR005TJP
       Coding: 9DCCFCC0000000005000001AC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CB58FA2F289A5F1F7-8012
       Belt Pretensioner left:
       Belt Pretensioner right:
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 6940000Y14000128DV0R
       Coding: 303139
       Subsystem 4 - Part No SW: -----------    HW: 480 003 101 14
       Serial number: 357000000002348D9E0P
       Subsystem 5 - Part No SW: -----------    HW: 480 003 101 14
       Serial number: 358000000003D38D9E0-
       Subsystem 6 - Part No SW: -----------    HW: 480 400 302 14
       Serial number: 3510002C113013F4A34P
       Subsystem 7 - Part No SW: -----------    HW: 480 400 302 14
       Serial number: 3520002AF12AB1B1D089
       Subsystem 8 - Part No SW: -----------    HW: 480 402 501 14
       Serial number: 3550002C912FAE215178
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 402 501 14
       Serial number: 3560002BF12FAE2140DI
    9 Faults Found:
    9438803 - Igniter for Seat Belt Tensioner; Driver's Side
              B1006 53 [009] - Deactivated
                        Mileage: 1964 km
                        Date: 2018.08.10
                        Time: 00:07:09
    9439059 - Igniter for Seat Belt Tensioner; Passenger's Side
              B1007 53 [009] - Deactivated
                        Mileage: 1964 km
                        Date: 2018.08.10
                        Time: 00:07:09
    9439571 - Seat Belt Tensioner Igniter; rear; driver's side
              B1009 53 [009] - Deactivated
                        Mileage: 1964 km
                        Date: 2018.08.10
                        Time: 00:07:09
    9439315 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
              B1008 53 [009] - Deactivated
                        Mileage: 1964 km
                        Date: 2018.08.10
                        Time: 00:07:09
    9442074 - Driver's Belt Force Limiter Igniter
              B1013 1A [136] - Resistance Too Low
                        Mileage: 1964 km
                        Date: 2018.08.12
                        Time: 18:27:14
    9442131 - Driver's Belt Force Limiter Igniter
              B1013 53 [009] - Deactivated
                        Mileage: 1964 km
                        Date: 2018.08.10
                        Time: 00:07:09
    9442387 - Passenger's Belt Force Limiter Igniter
              B1014 53 [009] - Deactivated
                        Mileage: 1964 km
                        Date: 2018.08.10
                        Time: 00:07:09
    9634899 - Control Module for Front Left Belt Tensioner
              B1304 53 [009] - Deactivated
                        Mileage: 1964 km
                        Date: 2018.08.10
                        Time: 00:07:09
    9635155 - Control Module for Front Right Belt Tensioner
              B1305 53 [009] - Deactivated
                        Mileage: 1964 km
                        Date: 2018.08.10
                        Time: 00:07:09
       Part No SW: 8V0 953 521 CB    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 14021408490773
       Coding: A018
       ROD: EV_SMLSKLOMQB_012_AU37.rod
       VCID: 7CA1F716266E0987C25-8028
       Part No SW: 8V0 920 960 B    HW: 8V0 920 960 B
       Component: KOMBI         H02 2220
       Coding: 0BF418092B80B7050200A800180000
       VCID: 3A2D310E6CDAF7B7909-806E
       Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2163
       Revision: --------    Serial number: 16021410800307
       Coding: 0101000820085A005B00020C180B00000001000000000000000000000000
       ASAM Dataset: EV_GatewConti 010015
       ROD: EV_GatewConti_010.rod
       VCID: 3FDB401A77F8D29FA77-806A
       Serial number: 22 01 2014  A0174867
       Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
       Component: Haldex4Motion H52 7076
       Serial number: HA1-00023.01.14
       Coding: 0001
       VCID: 46D555FE28228357E41-8012
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 09021401101060
       Coding: 00100F204000048000000002
       VCID: 3E253D1E70F2DB97AC1-806A
       Component: EPS_MQB_ZFLS  123 1043
       Coding: 0102
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 41DF46E2010CA46FD13-8014
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 01021402091264
       Coding: 001007204000048000000002
       VCID: 3D273A127DF4C08FB5B-8068
       Coding: 012A000101000000
       VCID: 75B7E232054458CFBDB-8020
       Part No SW: 8V0 035 844     HW: 8V0 035 844
       Component: MU-S-S-US     012 0626
       Serial number: A7A01502140451
       Coding: 01730100FF0A000011220001001A00002F0001040100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE.rod
       VCID: 76B5E53E184253D7B41-8022
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9EY301REM
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
       Component: ControlUnit_B  H33 0037
       Serial number: C1000030111300020127
              B11CF 53 [009] - Deactivated
                        Reset counter: 155
                        Mileage: 1964 km
                        Date: 2018.08.10
                        Time: 00:07:11
                        Voltage terminal 30: 13.8 V
       Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0025
       Serial number: 04021403110446
       Coding: 000007204000048000000002
       VCID: 40D943E60A06AD67DED-8014
       Component: TSG HBFS      020 0025
       Serial number: 04021403110448
    End----------(Elapsed Time: 01:53, VBatt start/end: 12.2V/12.2V)-----------
    There are Adaptation Channels for all those those igniters that can be changed from 'activated' to 'blocked', which I suppose is the same as deactivated.
    Just because the belts look good doesn't mean the igniters weren't fired off.
  3. Likes Ashraf6119, Golftwincharged liked this post
    Sep 2014
    Guatemala
    I have a hypothesis, if the car was at the dealership parking and wasn't ready to be "delivered" or sold that maybe it was in some kind of transport mode and airbags weren't active, as it's like coincidental that all of them have the same "response"
    Jun 2016
    Guyana
    Seems like everything that was deactivated using Adp Channels which were faulty , and was deactivated to keep SRS light to staying off after a few blinks , if you activate the channels you may find the issues there.
  6. Likes jyoung8607, Uwe liked this post
    Sep 2014
    Guatemala
    Quote Originally Posted by Golftwincharged View Post
    Thanks a lot!
  8. Likes Golftwincharged liked this post
