Results 1 to 5 of 5
Thread: Starting Issue - 2009 Caddy Maxi Life (UK Car)
    New User
    Feb 2017
    Hi all,
    I've recently acquired a '58 Caddy Maxi Life and have been slowly working through its issues. The latest one to happen, is a totally unresponsive starter only a couple of hours after I had stopped the car. I went back to it a few hours later again and it started without hesitation.
    I have previously noticed a hesitation when starting warm, this may be unrelated.
    Fault codes for terminal 30 and cam sensor have been persistent, as was the ignition switch. The ignition switch has since been replaced and the fault code has disappeared (newer scan)
    The cambelt has just been replaced and this sensor fault may well stay clear if the belt was stretched, but not sure about that one.
    Other than starting or not, as the case may be, there appears to be no other issue, even the wipers work as they should, although the fault code for terminal 30 appears to indicate a fault with them.
    Ignore the radio faults - That's resolved also.
    Scan below.
    Thursday,02,May,2019,16:59:59:38737VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 18.9.1.0 (x64)
    VIN: WV2ZZZ2KZ9X030324   License Plate:
    Mileage: 182160km-113188mi   Repair Order: Pre mods
    Chassis Type: 2K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 46 52 56
    VIN: WV2ZZZ2KZ9X030324   Mileage: 182160km-113188miles
    Address 01: Engine        Labels: 03G-906-021-BLS.clb
       Part No SW: 03G 906 021 PD    HW: 03G 906 021 CG
       Component: R4 1,9L EDC  000SG  2387
       Revision: --H08---    Serial number: VWX7Z0H53NR1C7
       Coding: 0000071
       Shop #: WSC 35110 377 00162
       VCID: 70E5EC60633442CA2D-8024
    012295 - Camshaft Position Sensor (G40)
                   P3007 - 000 - No Signal - Intermittent
                        Fault Status: 00110000
                        Fault Frequency: 82
                        Mileage: 181814 km
                        Time: 11:00:31
                        RPM: 1428 /min
                        Speed: 47.0 km/h
                        Load: 0.0 %
                        Voltage: 14.44 V
                        Bin. Bits: 00000000
                        Idle Stabilization: -3.9°KW
                        (no units): 48.0
    Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
       Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
       Component: MABS MK70M          0104
       Revision: 00H32001
       Coding: 0020801
       VCID: 76E9DA7801506CFAF7-8022
       Part No SW: 1K0 820 047 HM    HW: 1K0 820 047 HM
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       Revision: 00H54000    Serial number: 01000008687319
       Coding: 01884F030004100057000000000000000008FF075C000120000000000000
       Shop #: WSC 35110 377 08192
       VCID: 336F236C52A239D210-8066
       Subsystem 1 - Part No: 2K2 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 200608 021  0501
       Coding: 00038805
       Shop #: WSC 35110
                        Fault Status: 00101010
                        Reset counter: 59
                        Mileage: 181816 km
                        Voltage: 5.00 V
    00926 - Terminal 30
                        Fault Status: 01101011
                        Reset counter: 19
                        Mileage: 181807 km
                        Voltage: 5.00 V
    Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
       Part No SW: 6Q0 909 605 AJ    HW: 6Q0 909 605 AJ
       Component: 1C AIRBAG VW52  025 2400
       Revision: 06025000    Serial number: 0037UR00GASZ
       Coding: 0012611
       VCID: 7F073F5C2E6A2DB2A4-802A
       Part No SW: 1K0 953 549 BT    HW: 1K0 953 549 BT
       Component: J0527           752 0101
       VCID: 050BADB44CB67762EE-8050
    00576 - Terminal 15
    00885 - Ignition Switch (D) Terminal 50
       Part No SW: 1T0 920 954 C    HW: 1T0 920 954 C
       Component: KOMBIINSTRUMENT VDD 1222
       Revision: V0002000    Serial number: VWX7Z0H53NR1C7
       Coding: 0016401
       Shop #: WSC 80093 222 69422
       VCID: 356B1D745CD627E23E-8060
       Component: J533  Gateway   H07 0062
       Revision:   H07 01    Serial number: 040708F2001496
       Coding: 89801F060002027401
       Component: IMMO            VDD 1222
       Part No SW: 1T0 959 701 H    HW: 1T0 959 701 H
       Component: Tuer-SG         006 1206
       Coding: 0000532
       VCID: 3C7D08507FFCF6AAC1-8068
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 CP
       Coding: 818B04087F2D8405485AC61010C0
       VCID: 0005BCA05394524ADD-8054
       Subsystem 5 - Part No: 2K0 951 172
       Component: Innenraumueberw.009 4807
       Coding: 00000000
       Subsystem 7 - Part No: 1K0 907 719 C
       Component: Neigungssensor  005 0003
       Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
       Component: Tuer-SG         005 0929
       Coding: 0000532
       VCID: 3973114470CEC382DA-806C
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  013 0036
       Revision: 00000000    Serial number: VWZ1Z2I6675681
       Coding: 0100040004
       VCID: 65CB8D346CF697624E-8030
    00856 - Radio Antenna
                        Reset counter: 19
                        Mileage: 182165 km
                        Time: 00:00:09
                        Reset counter: 19
                        Mileage: 182165 km
                        Time: 00:00:09
                000 -  -
                        Reset counter: 19
                        Mileage: 182165 km
                        Time: 16:59:03
    End-------------------------(Elapsed Time: 01:25)-------------------------
    The camshaft position sensor can cause "hesitation" (longer cranking) while the ECU figures things out, but it shouldn't cause a no-crank at all; that's likely the ignition switch.
    New User
    Feb 2017
    Thank you for the response.
    I have cleared all faults now apart from the no signal - intermittent on the G40.
    Re the ignition switch, it is new and has not thrown any fault codes, unlike the one that I replaced. I cannot rule out an intermittent fault with it, but would have thought that it would have given a code if faulty.
    I'm concentrating on the CMP sensor right now and have two pins with 5v, presumably a B+, a signal from the ECU and I have a ground, but the ground has 10 ohms on it. That seems high for a ground, unless going through something else. Are there wiring diagrams available to find the location of the ground, as I don't really want to be pulling the loom apart unnecessarily.
    Many thanks
    New User
    Feb 2017
    Camshaft sensor replaced.
    Fault changed from "no signal - intermittent" to "no signal" hard fault. Old sensor refitted and fault back to intermittent.
    That doesn't really help though, just indicates an unserviceable new unit.
    New User
    Feb 2017
    Car failed to start again, a tap on the solenoid brought it back to life. The starter was change and it did feel a bit rough, so crossed fingers that it's resolved.
    Still would like the wiring for the cam sensor though, that's bound to reappear.
  6. Likes Uwe liked this post
