Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Golf GTI 2010 warning light | Byte 18 and LED tail lights
    May 2019
    should I change it back to 00 since it made no difference?
    ( everything works as before)
  2. #12
    United States
    Thanks for the scan. HEX 15 would work with a newer SWL but it won't on this BCM.
    I'm reasonably confident HEX 02 was factory (under those 00's) for incandescent tails whit a rear fog light. HEX 04 should work for you in this condition providing the LED tail lights are VW (rather than aftermarket).
    P.S. Coding it back to 00 won't do any good. That was a spoofed value hiding the original coding.
  3. Likes Uwe liked this post
  4. #13
    May 2019
    Thanks, Ill give that a go & let you know!
  5. Likes Dana liked this post
  6. #14
    United States
    Sounds good.
    I managed to miss the warning from langers2k. Although I don't think you will have an issue with this Golf ... some early (2009/10 production) Golf 6 based models such as the Octavia did have issues where Coding to any of the 255 (00 through FF) possible Byte 18 issues did NOT restore lighting issues after modifications to Byte 18. In those cases you needed to tweak the EEPROM directly which isn't supported by VCDS. There was an test plan the dealer could run with GFF/ODIS and other tools (which can tweak the EEPROM directly) can be used if you know what to change.
  7. #15
    May 2019
    Thanks for this! 04 worked!
  8. Likes Uwe, Dana liked this post
