Results 1 to 10 of 15
Thread: Golf GTI 2010 warning light | Byte 18 and LED tail lights
Hybrid View
    May 2019
    Hi, I have a 2010 Golf GTI 2010 Mk6 & have a dash warning light on telling me I have a fault in rear right tail lamp. This is since I fitted LED tail; lamps. I read I can code this out on long coding byte 18 but when I go there I get a warning that any changes may cause damage. Then even if I do try to make any changes, I cannot do so!
    Is there any way I can do this?
    ( I dont wish to fit resistors to the led's)
    Thanks,
    Simon
    Hello OP and welcome to the VCDS forum.
    Post an auto-scan please and un-modify your car to complete a repair which comports with RTFB or see the retrofit forum to play in that forbidden fruit basket.
    https://forums.ross-tech.com/forumdi...p?10-Retrofits
    JPPSG
    May 2019
    Ok, I managed to change byte 18 code 00 to 15 but that has made no difference! Any ideas?
    United States
    HEX 15 only applies to specific BCM software versions. We need to see the complete Auto-Scan: https://forums.ross-tech.com/showthr...t-an-Auto-Scan
    P.S. Thanks Jack. I moved this to the Retrofits sub-forum with a slightly modified subject (from Golf GTI 2010 warning light -to- Golf GTI 2010 warning light | Byte 18 and LED tail lights).
  5. Likes Uwe liked this post
    May 2019
    Hi, Ive got the logs saved to my laptop but I am unable to copy & paste them here for some reason?
    Will I just write out the relevant part of the log?
    Quote Originally Posted by missmouse View Post
    Huh? I can't think of any reason why you wouldn't be able to copy & paste text here.
    Are you trying to copy & paste an entire file? You need to open the file with Notepad, select the text you want to copy, then copy & paste that text.
    May 2019
    Managed it! I had to email it to myself first!
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZAW095150   Mileage: 190290km-118240miles
    Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
       Part No SW: 5K0 907 115     HW: 1K0 907 115 AA
       Component: 2.0l R4/4V TFSI*    0050
       Revision: AAH06---    Serial number:
       Coding: 0403000C1C070060
       Shop #: WSC 66565 257 00032
       VCID: 67D9DE77563B88727C-8032
    005727 - Oil Pressure Regulation Valve
                   P165F - 000 - Short to GND - Intermittent
                        Fault Frequency: 22
                        Mileage: 190285 km
                        Date: 2013.10.16
                        Time: 14:25:28
                        RPM: 185 /min
                        Load: 96.4 %
                        Temperature: 25.0C
                        Temperature: 24.0C
                        Absolute Pres.: 1030.0 mbar
                        Voltage: 10.287 V
    006469 - Control Module 1 for Cooling Fan
                   P1945 - 000 - Output Short Circuit
                        Mileage: 190286 km
                        Date: 2013.10.16
                        Time: 14:27:31
                        RPM: 1813 /min
                        Load: 41.2 %
                        Speed: 36.0 km/h
                        Temperature: 52.0C
                        Temperature: 24.0C
                        Voltage: 14.097 V
       Part No SW: 02E 300 051 R    HW: 02E 927 770 AM
       Component: GSG DSG AG6     521 1975
       Revision: 05652104    Serial number: 00001306260661
       Shop #: WSC 04940 001 00001
       VCID: 224F8F63FD99AD5AEB-8076
       Part No SW: 1K0 907 379 AM    HW: 1K0 907 379 AM
       Component: ESP MK60EC1   H45 0108
       Revision: 00H45001
       Coding: 163B600D892B00FF680C06E991190081B108
       VCID: 7DF59C1FE4A732A2B6-8028
       Part No SW: 5K0 907 044 BC    HW: 5K0 907 044 BC
       Component: Climatronic   H14 0608
       Revision: 00003001
       Coding: 0000000000
       ASAM Dataset: EV_Climatronic A01001
       VCID: 6DD5AC5FBCC7A22206-8038
    13701888 - Function Restriction due to Faults in Other Modules
              U1113 00 [008] - -
                        Reset counter: 250
                        Mileage: 190297 km
                        Date: 2019.05.27
                        Time: 09:08:06
    9481988 - Air Quality Sensor
              B10AF 04 [009] - Internal System Fault
                        Reset counter: 210
                        Mileage: 190297 km
                        Date: 2019.05.27
                        Time: 09:08:06
       Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
       Component: BCM PQ35  M   103 0541
       Revision: 00103 AE
       Coding: 00180A3F9033F1C044080080140001E443D11588536D8960648000200000
       VCID: 306B752B63750FCA6D-8064
       Component: Wischer 30070  21  0501
       Coding: 009795
       Component: RLS 300709 05  54  0402
       Coding: 0330AD
       Subsystem 4 - Part No: 1K8 951 605
       Component: LIN BACKUP HO  H09 9002
       Part No SW: 5K0 959 655     HW: 5K0 959 655
       Component: AirbagVW10    035 0604
       Serial number: 003C2RA1VM3P
       Coding: 00003233
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 77F98E37CE9B18F2EC-8022
       Serial number: 71695449ZZZZZZZZZZZZ
       Serial number: 246D1249ZZZZZZZZZZZZ
       Serial number: 36022B08ZZZZZZZZZZZZ
       Serial number: 28023145ZZZZZZZZZZZZ
       Part No SW: 1K0 953 549 CE    HW: 1K0 953 549 CE
       Component: J0527           055 0111
       Coding: 0001602
       VCID: 77F98E37069B18F2EC-8022
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000131
       Part No SW: 5K6 920 970 B    HW: 5K6 920 970 B
       Component: KOMBI         H05 0206
       Coding: 470900
       VCID: 33617A279A6334D210-8066
       Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
       Component: J533  Gateway   H07 0081
       Revision:   H07 01    Serial number: 220709F2002672
       Coding: ED807F06000212000003
       VCID: 66C7D3735131917A47-8032
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H05 0206
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Revision: A1001003    Serial number: 7667522868
       VCID: 2647937351B1517A87-8072
       Component: Tuer-SG         009 2110
       Coding: 0000692
       VCID: 316D702FA87F06C262-8064
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 74     2901
       Revision: 00H17000
       VCID: 2F697657BE4B103274-807A
       Coding: 0000692
       VCID: 326F7F23AD793DDA1B-8066
       Part No SW: 3C8 035 195 G    HW: 3C8 035 195 G
       Component: Radio RCD510  050 0207
       Revision: 00000001    Serial number: VWZ1Z3L6688143
       Coding: 01000400040005
       VCID: 2C53615B4F5D6B2A51-8078
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       VCID: 3463793B576D33EA09-8060
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0000144
       VCID: 3565443F5C172AE23E-8060
    End-------------------------(Elapsed Time: 02:20)--------------------------
  9. Likes Uwe, Dana liked this post
  10. #8
    Oct 2014
    I'm not 100% sure if that BCM will support LED lighting, I know I've had issues with some 087 units running SW:05xx and below.
    Where in the UK are you? It sounds like you might need to find a VCP or ODIS-e user to tweak the lighting config.
  11. #9
    May 2019
    Hi, Im near Glasgow, however if its not possible to code out the warning light I understand a resistor can be added to the circuit to fool the BCU?
  12. #10
    Oct 2014
    Too far away for me to take a look.
    You can add resistors, just make sure they are well attached to something that can take the heat as they will warm up.
    You might also want to check all the exterior lamps (sidelight, indicators, fogs, reverse, brakes, DRL?) are working correctly since you changed the byte 18 value.
