Results 1 to 5 of 5
Thread: 2009 Caddy - 1.9 TDI - G83 Sensor Radiator
    Jan 2019
    2009 Caddy - 1.9 TDI - G83 Sensor Radiator fault.
    I've tried replacing the sensor however it hasnt seemed to help. I've tried using a testmeter to check the voltage however none of them have any connectivity through the wire that connects into the sensor.
    Sunday,12,May,2019,14:07:36:18214
    VIN: WV1ZZZ2KZAX063763   License Plate: SCAN
    Mileage: 245250km-152391mi   Repair Order:
    Chassis Type: 2K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 46 52 56
    VIN: WV1ZZZ2KZAX063763   Mileage: 245250km-152391miles
    Address 01: Engine        Labels: 03G-906-021-BLS.clb
       Part No SW: 03G 906 021 PD    HW: 03G 906 021 CG
       Component: R4 1,9L EDC  000SG  2387
       Revision: --H11---    Serial number: VWX7Z0I93NQ0KX
       Coding: 0000071
       Shop #: WSC 00000 256 01574
       VCID: 70B9D32AE6A761E76ED-8024
    008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
                   P2185 - 000 - Signal too High
                        Mileage: 245250 km
                        Time: 13:47:34
                        Voltage: 11.55 V
                        Bin. Bits: 00000100
                        Temperature: 16.2C
                        Temperature: 11.7C
    Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
       Part No SW: 1K0 907 379 AF    HW: 1K0 907 379 AF
       Component: MABS MK70M          0104
       Revision: 00H32001
       Coding: 0020801
       Shop #: WSC 35110 377 00157
       VCID: 76B5E53284C34FD7B41-8022
       Part No SW: 2K0 820 047 BM    HW: 2K0 820 047 BM
       Component: Climatic PQ35   143 1515
       Revision: 00143033    Serial number: 00000000000000
       VCID: 71BFD62EEDAD68EF613-8024
       Revision: 00H54000    Serial number: 01000003455243
       Coding: 00804F030004100057000000000000000008FB075C000120000000000000
       Shop #: WSC 35110 377 08192
       VCID: 323D1922282B13F7589-8066
       Subsystem 1 - Part No: 1T2 955 119   Labels: 1KX-955-119.CLB
       Component: Wischer 071009 021  0512
       Coding: 00038805
       Shop #: WSC 35110
    Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
       Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
       Component: 2Q AIRBAG VW52  025 2400
       Revision: 06025000    Serial number: 0037TR05HC4I
       Coding: 0012881
       VCID: 7DA7FA1EA1F51C8FF5B-8028
       Part No SW: 1K0 953 549 CT    HW: 1K0 953 549 CT
       Component: J0527           053 0111
       VCID: 065595F2F4235F57A41-8052
       Part No SW: 2K0 920 944 C    HW: 2K0 920 944 C
       Component: KOMBIINSTRUMENT VDD 1222
       Revision: V0002000    Serial number: VWX7Z0I93NQ0KX
       Coding: 0016401
       Shop #: WSC 00288 210 87232
       VCID: 2C01075A0A0F4507125-8078
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H07 0111
       Revision:   H07 01    Serial number: 221009F1000624
       Coding: 89801F06000202007401
       VCID: 698FBE4EC57D902F293-803C
       Component: IMMO            VDD 1222
    Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
       Part No: 1K0 959 793
       Component: Tuersteuergeraet 02 0160
       Coding: 0000000
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 CP
       Coding: 018A0C087F2D84054858061000C0
       VCID: 005983EAD60771679ED-8054
    Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
       Part No: 1K0 959 792
       Coding: 0000000
       VCID: 75B7E23E99C544CFBDB-8020
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  013 0036
       Revision: 00000000    Serial number: VWZ1Z2I6759399
       Coding: 0000020001
       VCID: 6597B27E2565B44F0DB-8030
    End----(Elapsed Time: 00:50, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)-----
    Quote Originally Posted by Gashhey View Post
    Please explain what you mean by this. How exactly did you test this?
    Did you observe WD to familiarize yourself with possible connection issues, cross or test procedures in the RTFB?
  4. Likes Fredrick Awuor liked this post
    Jan 2019
    My bad.
    Checked the connector that plugs into the sensor (I think) and its not showing any voltage and isnt it meant to show 5V?
    What does RTFB say?
