Results 1 to 10 of 11
Thread: Audi A5 0BK ZF 8HP transmission -- adaptation reset / basic settings
    Nov 2018
    I was looking thru the wiki but couldn't find the procedure, so I figured maybe I can ask here.
    What is the proper way to reset the adaptation for this TCU?
    I tried "Fast Adaptation" but the text box shows "aborted -- safety reasons" so I stopped. The engine wasn't running, so please let me know if the engine needs to be running as well.
    Thanks.
    Alex
    Feb 2018
    I’d also be interested to know how to do this. Thanks mark
    Moving to Car Repair Support.
    What's wrong with the tranny that makes you think it could benefit from this?
    Please post an Auto-Scan so people can see exactly what TCU this car has.
  4. Likes Jack@European_Parts liked this post
    Chances are it won't!
    Feb 2018
    Hello. Thank you for taking an interest. I will post a scan log when I get home.
    If stationery, in drive and at idle my car sounds as expected. If I shift to either Park, Reverse or Neutral it makes a soft knocking noise. If I increase the rpm it goes away. Also if cold it tends not to be there (again the revs are higher when cold).
    I have read that a adaption of the box is required (but have no real idea myself).
    Any suggestions welcome. Thank you Mark.
    Mar 2014
    North West UK
    Dual Mass Flywheel ?
    Feb 2018
    Dual Mass Flywheel - I hadn't considered that - thought that was only on manuals - clearly not.
  9. #8
    Feb 2018
    Monday,08,July,2019,20:47:13:24455
    VCDS Version: 19.6.1.0 (x64)
    VIN: WAUZZZ********796   License Plate: ******
    Mileage: 42490km-26402mi   Repair Order: 08-07-2019
    Chassis Type: 8R-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 22 42 44 46 52 53 56 5F 62 6D
              72 A9 AC C0
    VIN: WAUZZZ********796   Mileage: 42490km-26402miles
    Address 01: Engine (J623-DEHA)       Labels:. 059-907-401-V2.clb
       Part No SW: 8K5 907 589 C    HW: 4G0 907 589 B
       Component: 3.0BTD EDC17  H23 0004
       Revision: 54H23---
       Coding: 2A2A4032252603030000
       Shop #: WSC 06208 000 00000
       ASAM Dataset: EV_ECM30BTD0118K5907589C 001006
       ROD: EV_ECM30BTD0118K5907589C.rod
       VCID: 41834E32D0D64D47D6-8014
       Part No SW: 8R0 927 158 BC    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRDW H19 1003
       Revision: --H19---
       VCID: 7F0708CAE6A2FBB7E0-802A
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 BF    HW: 8R0 907 379 BF
       Coding: 385DCE01
       Shop #: WSC 06335 000 00000
       VCID: 050B9A228C7EA167AA-8050
       Part No SW: 8K0 907 064 KG    HW: 8K0 907 064 KG
       Component: BCM2 2.0      H15 0711
       Coding: 01B54040000000000000
       VCID: 7F0708CAEEA2FBB7E0-802A
       Subsystem 1 - Part No SW: 8K0 959 754 BM    HW: 8K0 959 754 BM
       Serial number: 0816000029683005
       Serial number: 3216000031757016
       Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
       Revision: D1000000    Serial number: 01070320162107
       Coding: 3625028000
       VCID: 78F5E3D6CB8CCC8FA1-802C
       Revision: 08016001    Serial number: 00001303100201
       Coding: 260000108034AFE01781404300001D0D0F9D470827090201000008004400030100000024000000
       Shop #: WSC 06335 123 12345
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 160222  H13 0050
       Serial number: 90243015160202145339
       Coding: 01DD13
       Serial number: 61453192
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000203160313
       Component: AQ_Hum_Sensor  H03 0005
       Serial number: FDE8861800PAG0MUFU01
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
       Component: AirbagVW-AU10 H49 0610
       Serial number: 003JPDD1TZ09
       Coding: 30473531313030303030554A305238523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 48955316F3EC7C0F11-801C
       Serial number: 6334MSME572A0C46J
       Serial number: 6344MSME572B6949R
       Serial number: 6352QSME49762278M
       Serial number: 6362QSME24514C76J
       Serial number: 63732SME43763262W
       Serial number: 63832SME437647480
       Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
       Revision: --------    Serial number: 90372PC200044
       Coding: 000037
       VCID: 448D4726C7C4586FFD-8010
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 950 T    HW: 8R0 920 950 T
       Component: KOMBIINSTR.   H35 0567
       Revision: 00200000    Serial number: 03F22593H
       Coding: 33A7220083012600010000
       VCID: 4797502AF6F2737718-8012
       Part No SW: 8R0 907 468 T    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H11 0070
       Revision: 1Y090032    Serial number: 3241Y16218092B
       Coding: 80CD07FF00
       VCID: 50A57B7603BCB4CF49-8004
       Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
       Component: J367-BDMHella  H07 8043
       Serial number: 1866917603
       Serial number: 16068004209011200181
       Component: 4 Wheel Drive H15 0100
       Serial number: 000303160001008
       VCID: 2F67188A7642CB3730-807A
    0057 - Please Check Fault Codes in Body Control / Central Electric Module
              U1021 00 [009] - -
                        Reset counter: 90
                        Mileage: 42492 km
                        Date: 2019.07.08
                        Time: 20:41:36
       Component: TSG FA        H03 0511
       Revision:             Serial number: 0000188863247
       Coding: 011D02214001440004
       VCID: 4FA7780A1E82AB3750-801A
       Part No SW: 8R0 909 144 Q    HW: 8R0 909 144 L
       Component: RCevo         H54 0702
       Revision: 00000002    Serial number: 0000714968
       Coding: 100000010001
       Shop #: WSC 06334 123 12345
       ASAM Dataset: EV_RCEPSAU48X 104002
       ROD: EV_RCEPSAU48X_104.rod
       VCID: 46895D2EF9F86A7FE3-8012
       Revision: 00002001    Serial number: 0397921012
       Coding: 013B0622A0B930148720053680040047
       Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H04 0090
       Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H04 0090
       Revision:             Serial number: 0000189182048
       VCID: 4E99650E1988A23F5B-801A
       Component: EPB-4         H03 0005
       Revision: --------    Serial number: 10000000649248
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A7139DEBD001E9F97-806E
       Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
       Component: Radio U DAB   H60 0150
       Revision: AB001007    Serial number: 109CY0G2537516
       Coding: 010103020100000001
       VCID: 2B5F0C9A4A5AB7171C-807E
    00417 - Left Front DSP Mid-Bass Speaker (R101)
                        Fault Status: 01101011
                        Reset counter: 90
                        Mileage: 42492 km
                        Date: 2019.07.08
                        Time: 20:41:39
                        Voltage: 12.30 V
    00418 - Front Right DSP Mid-Bass Speaker (R102)
                        Reset counter: 90
                        Mileage: 42492 km
                        Date: 2019.07.08
                        Time: 20:41:39
                        Voltage: 12.30 V
    02558 - Rear Left Mid-Range/Woofer Loudspeaker (R159)
                        Reset counter: 90
                        Mileage: 42492 km
                        Date: 2019.07.08
                        Time: 20:41:39
                        Voltage: 12.30 V
    02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                        Reset counter: 90
                        Mileage: 42492 km
                        Date: 2019.07.08
                        Time: 20:41:39
                        Voltage: 12.30 V
       Part No SW: 8R2 035 666 K    HW: 8R2 035 666 H
       Component: H-BN-EU       H49 0946
       Revision: --------    Serial number: 515CA0GS009523
       Coding: 1A0101060205A1ED05808B5E00000403E40000020000000000
       VCID: 41834E32D8D64D47D6-8014
       Subsystem 1 - Part No: 8R0 060 884 DF
       Component: EUR 2016  2204
       Component: DU7 High  H42 0104
       Serial number: A130CN0G3542064
       Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
       Serial number: 00000002483434
       Component: CD-Database  6890
       Component: TSG HL        H02 0510
       Revision:             Serial number: 0000189790786
       Coding: 010C02204001240004
       VCID: 46895D2EF1F86A7FE3-8012
       Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
       Component: J605  Master  H56 0330
       Revision: --------    Serial number: 8R0827851D
       VCID: 3D7B32C2A42E29A7B2-8068
       Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
       Component: J756  Slave  H56 0330
       Serial number: 8R0827852D
       Component: TSG HR        H02 0510
       Revision:             Serial number: 0000189790878
       Part No SW: 8R0 907 159     HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0007
       Serial number: 160210201456
       VCID: 79F3E6D2F886D587DE-802C
       Part No SW: 4G0 907 355 G    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0013
       Revision: 00000000    Serial number: 160421420
       ROD: EV_RDCMA00100_008.rod
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 8R0 907 160 A    HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H10 0008
       Serial number: 160223200194
       VCID: 326111FE6570E6DF5F-8066
    End-------------------------(Elapsed Time: 04:26)--------------------------
  10. #9
    Feb 2018
    Oh well thanks to those who helped.
  11. #10
    Nov 2018
    Just wanted to revive this thread a little.
    According to SSP 385 (pg 58) for the ZF 6HP transmission, it is necessary to read, evaluate, or delete adaptation values and carry out an adaptation run after:
    - following complaints about gearshift comfort
    - after repair work has been done on gearbox
    - after replacing the gearbox
    - after replacing the ATF
    - after replacing the mechatronics
    - after software update
    - after engine repairs
    So it stands to reason that the 8HP transmission has similar requirements. So is it possible to delete the adaptation values? I'll post the autoscan for my car asap. But this should apply to mrdeli as well.
    The procedure outline in the SSP 385 (pg 63) basically says the below. SSP 457 (pg 53) says to use the same procedure for 0BK and 0BL gearboxes.
    1) 02 - gear box
    2) 006 - basic settings
    3) delete system-specific adaptation values
    4) start
    Perhaps step 3 above corresponds to "IDE00794 - Erasing of system-specific adaptation values"" mentioned in this thread?
    Thanks!
    Alex
