Results 1 to 10 of 20
Thread: Audi A3 8V TPMS retrofit
    Feb 2019
    Brazil
    Hi, 've finished my TPMS retrofit some weeks ago but I'm looking for some help because I still couldn't make it display the tyre pressure screen on MMI. The system seems to be partially working since it can correctly get pressures and temperatures from the sensors and generates alerts when there's some tyre below pressure. Diagnostic scans with VCDS show that pressures and wheel positions recived by the TPMS module are accurate.
    Problem is, instead of displaying the direct TPMS scren with the tyre diagram, MMI displays the "store tyre pressures" screens, as if I was using indirect TPMS.
    Of course, I've disabled indirect TPMS as part of the coding process changing bytes 27 and 28 on ABS module changed from 3882 to 0802 (back to what it was originally coded from factory).
    I though it might be related with some wrong coding for Instruments ou Information Electronics, but I did some tests some time ago with another TMPS module from a Passat (P/N: 5Q0907273) and I did get the direct TPMS tyre pressure diagram on the MMI screen. Of course it didn't work properly (the Passat module doesn't handle temperatures, only pressures). So now I've tested that again and replaced the 8V module (P/N: 8S0907273) with the Passat unit without changing any coding. And then the direct tire pressure diagram appeared. Removing the Passat unit and reinstalling the 8V module, the diagram was no longer displayed and again I had only the indirect TPMS "store tyre pressures" screen. So I'm sure my MMI is able to display the right screen. The strange thing is that it displays the right screen with the wrong module, and the wrong screen with the right module.
    Any ideas?
    An Auto-Scan would help
  3. Likes Uwe liked this post
    Feb 2019
    Brazil
    Scan made weeks ago, but nothing changed since then:
    Tuesday,02,April,2019,09:20:27:36513
    VIN: WAUAYJ8V7F1098558   License Plate:
    Mileage: 111140km-69059mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 08 09 15 16 17 19 42 44 52 55 5F 65
    VIN: WAUAYJ8V7F1098558   Mileage: 111140km-69059miles
    Address 01: Engine (J623-CXSA)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04E 906 016 DM    HW: 04E 907 309 A
       Component: 1.4l R4 TSI   H10 7593
       Revision: WAH10---
       Coding: 02250012232401082000
       Shop #: WSC 14315 003 1048576
       ASAM Dataset: EV_ECM14TFS01104E906016DM 002005
       ROD: EV_ECM14TFS01104E906016DM.rod
       VCID: 70B9D2640A2BF9976ED-8024
    Readiness: 0000 0001
       Part No SW: 0CW 300 047 D    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H44 5205
       Revision: 00044014    Serial number: CU501810245075
       Shop #: WSC 04940 001 00001
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 3C21365416E34DF7825-8068
       Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
       Component: ESC           H42 0609
       Revision: 00000000    Serial number: 63494000000525
       Coding: 13F16AA224291274037C060541CB29C8562448C0608294F7024100080208
       Shop #: WSC 43394 001 104857
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
       VCID: 3D273B500DF944FFB5B-8068
    Address 08: Auto HVAC (E87)       Labels:| 8V0-820-047.clb
       Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
       Component: AC Manuell el H11 0052
       Revision: 20021000    Serial number: 00000000114276
       Coding: 03000004100000001000000000000000
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_AirCondiFrontManAU37X 008018
       ROD: EV_AirCondiFrontManAU37X.rod
       VCID: 372B29782FC56EAF6F7-8062
       Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
       Component: BCM MQBAB H   H18 0137
       Serial number: 01011434902151
       Coding: 04041A42C241227D03A04004B10807080008000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 005982A43A8BE9179ED-8054
       Component: WWS371 141207  042 0585
       Serial number:         141212051257
       Coding: 0A47F7
       Serial number: 21916940
       Coding: 07006C
       Subsystem 3 - Part No SW: 8V0 941 531 AE    HW: 8V0 941 531 AE
       Serial number: 30 06 2015  00000017
       Serial number: 000000000ZY160110RLS
       Serial number: 00000000000061329321
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [009] - Electrical Failure
                        Reset counter: 153
                        Mileage: 110985 km
                        Date: 2019.03.28
                        Time: 18:22:44
       Part No SW: 5Q0 959 655 AB    HW: 5Q0 959 655 AB
       Component: AirbagVW20    014 0385
       Serial number: 003MMR02PGB%
       Coding: 98CCC000000000005C540000004800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       Subsystem 1 - Part No SW: -----------    HW: 480 001 312 14
       Serial number: 3576700000099084221K
       Subsystem 2 - Part No SW: -----------    HW: 480 001 312 14
       Serial number: 35867000000A6084221J
       Subsystem 3 - Part No SW: -----------    HW: 480 400 512 14
       Serial number: 3516502B118B3AB1919C
       Subsystem 4 - Part No SW: -----------    HW: 480 400 512 14
       Serial number: 3526502A31811B93F177
       Subsystem 5 - Part No SW: -----------    HW: 480 400 210 14
       Serial number: 3556502C1175A9207183
       Part No SW: 8V0 953 521 BT    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 17121404401354
       Coding: A018
       VCID: 0D47AB907DD9B47FE5B-8058
       Part No SW: 8V0 920 860 G    HW: 8V0 920 860 G
       Component: KOMBI         H01 4291
       Coding: 07A519882A8008081A00AA041000000000000000
       Shop #: WSC 48154 001 1048576
       VCID: 3E253C5C00FF5FE7AC1-806A
       Revision: --------    Serial number: 06121410802201
       Coding: 030100043F0864005B000248180B00000001010000000000000000000000
       VCID: 72BDD86C0427CB87989-8026
       Subsystem 2 - Part No SW: 8U0 951 528 B    HW: 8U0 951 528 B
       Serial number: 06 12 2014  B0020121
       Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
       Component: J367-BDMConti  H02 1011
       Serial number: 74185703001411282349
       Part No SW: 5Q0 959 593 C    HW: 5Q0 959 593 B
       Component: TSG FS        020 0026
       Serial number: 12071303110144
       Coding: 001042305000048000000000
       VCID: 41DF47A07101201FD13-8014
       Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000004642551
       Coding: 110000
       Component: EPS_MQB_ZFLS  126 1061
       Coding: 0103
       VCID: 43D34DA86B1D320FC3F-8016
       Part No SW: 5Q0 959 592 C    HW: 5Q0 959 592 B
       Component: TSG BFS       020 0026
       Serial number: 19071304080306
       Coding: 001044305C00048000000000
       VCID: 40D942A47A0B2917DED-8014
       Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000004731789
       Coding: 090000
       Coding: 0198000001000000
       VCID: 75B7E3707549DCBFBDB-8020
    Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
       Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
       Component: MU-S--ER      041 0420
       Serial number: A3E01712141994
       Coding: 01730100FF0A000021220001001A00002F0001040100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE.rod
       VCID: 34311E743EB385B74A5-8060
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0014
       Serial number: AUZ8Z9EY308AJE
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Component: ControlUnit_B  H41 0054
       Serial number: C1000029101400040286
    Address 65: Tire Pressure (J502)       Labels: None
       Part No SW: 8S0 907 273     HW: 4M0 907 273 B
       Component: RDKHUFAU736   H04 0002
       Serial number: 30000000004720
       ROD: EV_RDKHUFAU736_AU37.rod
       VCID: 77ABE9786F45AEAFAF7-8022
    End----------(Elapsed Time: 01:18, VBatt start/end: 12.4V/12.4V)-----------
    What have you got in these two Adaptation Channels in the 5F-Infortainement module?
    IDE04307-ENG117704 -- Vehicle function list BAP - tire_pressure_system_0x07
    IDE04307-ENG117705 -- Vehicle function list BAP - tire_pressure_system_0x07_msg_bus
    Feb 2016
    Quote Originally Posted by Ronaldo View Post
       Revision: WAH10---
       Coding: 0A47F7
       Coding: 07006C
                        Reset counter: 153
                        Mileage: 110985 km
                        Date: 2019.03.28
                        Time: 18:22:44
       Coding: A018
       Coding: 110000
       Coding: 0103
       Coding: 090000
    if i google the hardware number it comes up with a Q7 part but googling the software number comes up with an rs3/tt.
    i've working TPMS on my 2015 A3 with 2017 MMI 2 high and part number is 5Q0907273B. I also got DJAlex to parameterize my module. Not sure if that helps at all.
    Feb 2019
    Brazil
    Vehicle function list BAP - tire_pressure_system_0x07: Activate
    Vehicle function list BAP - tire_pressure_system_0x07_msg_bus: Databus Extended
    Feb 2019
    Brazil
    Quote Originally Posted by Ewan MacNee View Post
    My module was parameterised in the UK by DJAlix too, then shipped to me so I could install it. The part number I used was correct, according to him. As far as I know, the module with part number 5Q0907273B wouldn't work well with the A3 8V because it doesn't handle tire temperatures, only pressures (when I tested it, the temperatures where always displayed as -60.0º) so I abandoned the tests with it. Is your TPMS displaying temperatures?
  9. #8
    Since this is a retrofit, I'll ask: Which CAN bus is the TPMS module wired to?
    I understand this question may sound silly, but we have seem instances of problems with retrofits because they were wired to the wrong bus.
  10. Likes Somnus liked this post
  11. #9
    Feb 2019
    Brazil
    After looking for a solution for nearly two months with no success I think no question is silly at this point. I connected the wires from the TPMS receiver to a pair of wires identified in Audi electrical diagrams as CAN bus ext. High (an orange/gray wire) and CAN bus ext. Low (orange/brown). Electrical connection seems to be OK as the module can be accessed by VCDS and it can generate alerts on the instrument cluster when there's something wrong with the tires. Also, as I told in my initial post, when I replace the module with the other one from the Passat, without changing any coding, the TPMS diagram begins to be shown normally, and the module is connected to the same bus.
  12. Likes Uwe liked this post
  13. #10
    Tartu, Estonia
    TPMS-Direct came to A3-platform with RS3 and TTRS from 2017. I believe that Your MIB unit just doesn't handle the TPMS with temperature display with such new TPMS module.
    https://forums.ross-tech.com/showthr...is-it-possible
    The world is my oyster...
