Results 1 to 7 of 7
Thread: T5 Intermitant Boost Issue HELP struggling
    Oct 2018
    T5
    Had a new egr just fitted but still some faults remain
    4795 - Mass Air Flow Sensor (G70) BUT brand new unit fitted also.
    5171 - Boost Pressure Regulation ?
    Fault is very intermitant only seems to do it once a day
    Friday,10,May,2019,10:56:10:43739
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
    VIN: WV1ZZZ7HZAH221278   License Plate: CV10XKU
    Mileage: 127710km-79355mi   Repair Order:
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 03 04 09 15 17 19 25 56 0B
    VIN: WV1ZZZ7HZAH221278   Mileage: 127710km-79355miles
    Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 022 CB    HW: 03L 907 309 K
       Component: R4 2,0L EDC   H31 9116
       Revision: 26H31---    Serial number: 00000000000000
       Coding: 01114010230400080000
       Shop #: WSC 00440 210 92315
       ASAM Dataset: EV_ECM20TDI01103L906022CB 002012
       ROD: EV_ECM20TDI01103L906022CB_002.rod
       VCID: 679E43A89EC70F727C-8032
              P0101 00 [101] - Implausible Signal
                        Mileage: 127706 km
                        Date: 2019.05.10
                        Time: 08:12:01
                        Engine speed: 1228.00 /min
                        Vehicle speed: 38 km/h
                        Coolant temperature: 74 C
                        Intake air temperature: 19 C
                        Voltage terminal 30: 14.400 V
                        Air mass: actual value (mg/stroke): 695.3 mg/stroke
                        Standardized airflow ratio: filtered: 0.7844
                        EGR Solen.val.: actual value: 99.34 %
                        Throttle valve adapter: actual value: 99.71 %
                        Charge air pressure specified value: 1060 hPa
                        Charge air pressure: actual value: 1138.2 hPa
                        Mean injection quantity: 0.00 mg/stroke
              P0299 00 [101] - Control Range Not Reached
                        Mileage: 127710 km
                        Date: 2019.05.10
                        Time: 10:29:17
                        Engine speed: 2462.00 /min
                        Normed load value: 99.6 %
                        Vehicle speed: 75 km/h
                        Coolant temperature: 33 C
                        Intake air temperature: 29 C
                        Charge air pressure specified value: 2111 hPa
                        Charge air pressure: actual value: 1652.2 hPa
                        Air mass: actual value (mg/stroke): 1258.1 mg/stroke
                        Air cleaner degree of soiling: 2.26 %
                        Throttle valve adapter: actual value: 99.94 %
                        Charge Pressure Actuator: acknowledgment: 73.67 %
                        Mean injection quantity: 39.67 mg/stroke
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 E    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0103
       Revision: 00H43001
       Coding: 508724AD89A60A9624A49178A96610
       Shop #: WSC 02736 790 49152
       VCID: 3424E4E49791B4EA09-8060
       Part No SW: 7H0 937 086 B    HW: 7H0 937 086 B
       Component: BCM T5GP M++4 H46 0207
       Revision: BM046001    Serial number: 0154 329090754
       Coding: A0A0203A0E212021002000003C2B8C500000430F60060000300000000000
       Shop #: WSC 02759 790 00000
       VCID: 3228E2FC6D85BADA1B-8066
       Subsystem 1 - Part No SW: 7E0 959 801 C    HW: 7E0 959 801 C  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  003 3310
       Coding: 050000
       Subsystem 2 - Part No SW: 7E0 959 802 C    HW: 7E0 959 802 C  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  003 3310
       Coding: 040000
    03303 - Response Closing Status of Rear Left Door
                        Fault Frequency: 91
                        Reset counter: 63
                        Mileage: 126912 km
                        Date: 2013.08.30
                        Time: 12:45:17
       Part No SW: 7E0 959 655 A    HW: 7E0 959 655 A
       Component: VW10Airbag00Y H05 0011
       Revision: --------    Serial number: 003E5000JRYG
       Coding: 000000000000000000000000000000003059
       Shop #: WSC 02734 790 50316
       ASAM Dataset: EV_AirbaVW10BPAVN750 A01001
       VCID: 3424E4E49F91B4EA09-8060
       Part No SW: 7E0 920 960 A    HW: 7E0 920 960 A
       Component: KOMBI         H16 0111
       Coding: 460200
       Shop #: WSC 02736 790 50316
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04041
       VCID: 271E03A85E47CF72BC-8072
       Part No SW: 6N0 909 901     HW: 7H0 937 086 B
       Component: GW-K-CAN TP20 0207
       Coding: 042300
       VCID: 70AC28F4A309C8CA2D-8024
    Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
       Component: IMMO          H16 0111
       Part No SW: 7E0 035 156     HW: 7E0 035 156
       Component: Radio         H21 0058
       Revision: R0000000    Serial number: VWZAZ1I9806432
       Coding: 0000020001
       Shop #: WSC 02736 790 00000
       VCID: 608C58B473E9784ABD-8034
    End----------(Elapsed Time: 01:05, VBatt start/end: 12.3V/12.3V)-----------
    Jul 2014
    Hi sheepie,
    Genuine MAF? Have you made sure all the pipework and vac hoses are in place after the EGR change? Was it a genuine EGR by the way?
    Regards HMC
    Verify requested versus actual boost and that boost control is achieved at all loads.
    Maybe a leak as HMC aforementioned or maybe plugged exhaust or Intake or maybe wastegate stuck/unadjusted/linearized.
  5. Likes Uwe liked this post
  6. #4
    Oct 2018
    Genuine egr and maf all hoses look intact and fault is so intermitant i cant catch it doing it . Do you think it is worth changing map sensor ?
    I done a dpf regen so think exhaust is free plus no fumes coming from back of turbo that happens then it becomes clogged .
    egr was blocked up bad and so was the pipe work feeding it wonder if i have missed something
    Jul 2014
    What condition does this happen at, general driving, full load acceleration etc? Have you checked for sticking waste gate mechanism/veins?
    Regards HMC
    EGR Cooler????
    Oct 2018
    The intercooler had a very slight crack in it .
  10. Likes Uwe liked this post
