Results 1 to 3 of 3
Thread: Audi Q5 Error
    Apr 2019
    Audi Q5 Error
    Hi All,
    I am getting various errors in my AUDI Q5 2011 2.0 TDI, An year ago it had EGR fault, so instead of replacing the EGR, I had an EGR and DPF delete with a remap. Recently the car has been throwing all sorts of errors to do with control modules, mostly around handbrake sensor. We also took it a garage, who think it could Crankshaft position sensor.
    However my feel is that it could be wiring issue or a faulty module/relay (based on google search, I have no clue what a relay is). It’s currently a bit freaky to drive the car when it goes to into limp mode on a motorway.
    Please share your valuable advice
    Hope i am pasting the code correctly.
    Wednesday,01,May,2019,09:57:28:18679
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WAUZZZ8R0CA0xxxxx   License Plate:
    Mileage: 137600km-85500mi   Repair Order:
    Chassis Type: 8R-AU48 (8T0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 5F 62
              6D 72
    VIN: WAUZZZ8R0CA0xxxxx   Mileage: 137600km-85500miles
    Address 01: Engine (J623-CGLB)       Labels:. 03L-906-018-CGL.clb
       Part No SW: 03L 906 018 MQ    HW: 03L 906 018 DN
       Component: R4 2,0L EDC   X25 2844
       Revision: 45X25---
       Coding: 2A254012042702080000
       Shop #: WSC 92521 052 00000
       ASAM Dataset: EV_ECM20TDI01103L906018MQ 003010
       ROD: EV_ECM20TDI01103L906018MQ.rod
       VCID: 05576DDC05A5A95FADB-8050
              U1113 00 [039] - -
                        Mileage: 137600 km
                        Date: 2019.05.01
                        Time: 09:54:38
                        Engine speed: 930.00 /min
                        Normed load value: 27.1 %
                        Coolant temperature: 73 °C
                        Intake air temperature: 22 °C
                        Voltage terminal 30: 14.440 V
                        Cruise Control System (CCS): switch position-Bits 0-7: 129
                        Cruise Control System (CCS): status-Bits 0-7: 236
                        Cruise control switch-off: irreversible-Bits 0-7: 4
                        Cruise control switch-off: reversible-Bits 0-7: 255
                        Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 16
    4124 - Sensor Reference Voltage B
              P0651 00 [167] - Open Circuit
                        Mileage: 137600 km
                        Date: 2019.05.01
                        Time: 09:54:38
                        Exh.gas temp.sen 1: 71.1 °C
                        Exh.gas temp.sen 2: -0.0 °C
                        Exh.gas temp.sen 3: 143.8 °C
                        Exh.gas temp.sen 4: 142.3 °C
                        Shut-off timer: last engine shut-off time: 211 s
       Part No SW: 8R0 927 156 T    HW: 0B5 927 156 F
       Component: 0B5 20 TDIRdW H10 0007
       Revision: --H10---    Serial number: 0000000603
       Coding: 000001
       Shop #: WSC 06335 000 00000
       ROD: EV_TCMDL501.rod
       VCID: 4CC198F8664F9817325-8018
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
       Part No SW: 8R0 907 379 G    HW: 8R0 907 379 G
       Component: ESP8 quattro  H07 0070
       Coding: 0D1540
       Shop #: WSC 06334 000 00000
       VCID: 44D1B0D84E9F5057FA5-8010
       Part No SW: 8K0 907 064 CQ    HW: 8K0 907 064 CQ
       Component: BCM2 2.0      H05 0435
       Coding: 011500
       VCID: 015F79CC110D857F913-8054
       Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0511000050165008
       Serial number: 2311000191762011
       Part No SW: 8T2 820 043 AD    HW: 8T2 820 043 AD
       Component: KLIMA 1 ZONE  H08 0182
       Revision: B0000000    Serial number: 01100920110610
       Coding: 34150000
       Shop #: WSC 36954 001 1048576
       VCID: 74B120185EBFA0D78A5-8020
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 25
                        Mileage: 137600 km
                        Date: 2019.05.01
                        Time: 09:54:34
                        Temperature: 17.0°C
                        RPM: 920 /min
       Part No SW: 8K0 907 063 N    HW: 8K0 907 063 N
       Component: BCM1 1.0      H30 0392
       Revision: 09030001    Serial number: 00000001042307
       Coding: 26001011403489010000000000001D0D401D470802010101000000
       Shop #: WSC 06335 123 12345
       VCID: 3A2DCE203C5B16A7909-806E
       Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 110826  H11 0050
       Serial number: 90243015110720004811
       Coding: 01DD13
       Component: RLS  H04 0003
       Serial number: 11656844
       Coding: 024D25
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000209110416
       Part No SW: 8K0 919 475 AA    HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H01 0081
       Revision: 11001001    Serial number: 12501125601153
       Coding: 100108
       VCID: 78A9142842D7C4B7A6D-802C
    Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
       Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
       Component: AirbagVW-AU10 H44 0610
       Serial number: 003JPD0AT10E
       Coding: 30473331313030303030554A305238523053
       ROD: EV_AirbaAU10SMEAU416.rod
       VCID: 48C9A4E87237743716D-801C
       Serial number: 6334MSME6371126FE
       Serial number: 6344MSME60543767C
       Serial number: 6352QSME1F602644F
       Serial number: 6362QSME7F5F1760Y
       Serial number: 63732SME5F67174CD
       Serial number: 63832SME5766174E7
       Component: Lenks.Modul   H17 0014
       Revision: --------    Serial number: 90372KI700142
       Coding: 000037
       Shop #: WSC 01211 210 01254
       VCID: 3D27C53C2D75219FB5B-8068
       Component: E221 - MFL  H02 0010
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 981 H    HW: 8R0 920 981 H
       Component: KOMBIINSTR.   H22 0258
       Revision: 00000000    Serial number: EK3231D9C
       Coding: 2F1F22000200A600010401
       VCID: 3FDBBF342779338FA77-806A
       Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
       Component: GW-BEM 4CAN-M H09 0117
       Revision: EC000056    Serial number: 5600E11903065F
       Coding: 00C303
       VCID: 035373C40B11976F83F-8056
       Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790403717
       Part No SW: 8K0 959 793 N    HW: 8K0 959 793 N
       Component: TSG FA        H12 0357
       Revision:             Serial number: 0000012915691
       Coding: 011002204001440004
       VCID: 4BC39BE463C19F2F3BF-801E
       Revision: 00002001    Serial number: 0157982639
       Coding: 013B062020B930808420053280000000
       Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
       Component: DSP Prem      H10 0190
       Revision: 00010001    Serial number: 34804009683802
       VCID: 7AAD0E207CDBD6A7D09-802E
       Part No SW: 8K0 959 792 N    HW: 8K0 959 792 N
       Component: TSG BF        H12 0357
       Revision:             Serial number: 0000013241116
       Coding: 011002204C01440004
       VCID: 4ACD9EE06CBB8627009-801E
       Revision: 00000003    Serial number: 00000001017958
       VCID: 3431E0181E3FE0D74A5-8060
                        Fault Status: 11101101
                        Reset counter: 25
                        Mileage: 137600 km
                        Date: 2019.05.01
                        Time: 09:54:34
                        Voltage: 14.70 V
                        Count: 58
                        Hex Value: 0x0273
                        Hex Value: 0x0001
                        Hex Value: 0x1010
       Part No: 8K0 907 357 D
       Coding: 0000006
       VCID: 3635DA100443F2C7741-8062
       Part No SW: 4G0 035 061 P    HW: 4G0 035 061
       Component: Radio U DAB   H52 0151
       Revision: AB001007    Serial number: 232IT0B7500086
       Coding: 010103010000000001
       VCID: 2A0DFE60CCFBA627E09-807E
       Part No SW: 8T2 035 652 N    HW: 8T2 035 652 D
       Component: B-BN-EU       H61 0191
       Revision: --------    Serial number: 305IP0B7530205
       Coding: 01010106010581ED01000F0E000000030000
       VCID: 41DFB9CC518D457FD13-8014
       Subsystem 1 - Part No SW: 8T0 919 604     HW: 8T0 919 604
       Component: DU6 Basic  H42 0098
       Serial number: 9465I50B0369839
       Subsystem 2 - Part No SW: 8T0 919 609     HW: 8T0 919 609
       Component: E0380 Bedient  H08 0100
       Serial number: 00000000934745
    03175 - Invalid Data Set
                        Reset counter: 25
                        Mileage: 137600 km
                        Date: 2019.05.01
                        Time: 09:54:36
                        Voltage: 14.60 V
       Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
       Component: TSG HL        H11 0357
       Revision:             Serial number: 0000013554417
       Coding: 010002204001240004
       VCID: 45D7ADDC45A5695FEDB-8010
       Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
       Revision: --------    Serial number: 8R0827851B
       VCID: 3B23CB2433612FAF8BF-806E
       Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
       Serial number: 8R0827852B
       Component: TSG HR        H11 0357
       Revision:             Serial number: 0000013554423
    End----------(Elapsed Time: 01:43, VBatt start/end: 14.5V/14.4V)-----------
    Many of those faults are "sympathy" codes.
    I would focus on the P0651 code.
    http://wiki.ross-tech.com/wiki/index...5/P0651/001617
  3. Likes Dana liked this post
    Apr 2019
    Thank you for your help
