Results 1 to 3 of 3
Thread: 2013 VW Transporter ABS control module coding
    Apr 2019
    South Africa
    Looking for 2013 VW Transporter ABS control module coding
    Quote Originally Posted by Neels View Post
    We'll need you to post a full unedited VCDS Auto-Scan to be able to suggest coding for the ABS - it's dependent on how the vehicle is equipped, etc.
  3. Likes Uwe liked this post
    Apr 2019
    South Africa
    Monday,13,May,2019,09:55:14:31883
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
    VIN: WV2ZZZ7HZEH044981   License Plate: CA519290
    Mileage: 156090km-96989mi   Repair Order: kma
    Chassis Type: 7H-VN75 (6N0)
    Scan: 01 03 04 08 09 15 17 19 25 56 69 0B
    VIN: WV2ZZZ7HZEH044981   Mileage: 156090km-96989miles
    56-Radio -- Status: Not registered 0011
    69-Trailer -- Status: Not registered 0001
    Address 01: Engine (J623-CAAB)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 022 CC    HW: 03L 907 309 K
       Component: R4 2,0L EDC   H45 9970
       Revision: 26H45---    Serial number: 00000000000000
       Coding: 01110012231400080000
       Shop #: WSC 02756 790 50316
       ASAM Dataset: EV_ECM20TDI01103L906022CC 002014
       ROD: EV_ECM20TDI01103L906019AQ_002.rod
       VCID: 68884CD312F413F736D-803C
    Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
       Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
       Component: ESP MK25A XT  H43 0110
       Revision: 00H43001
       Coding: 108724AD09AC089A24A69076AA5E10
       Shop #: WSC 02736 790 49152
       VCID: 3A2CC69B3C585167909-806E
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 230
                        Mileage: 156099 km
                        Date: 2019.05.10
                        Time: 10:21:25
                        Count: 16512
                        Count: 769
                        Count: 4163
                        Count: 766
       Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
       Component: Climatic-T5   H20 0505
       Revision: 00001010
       Coding: 0000000002
       Shop #: WSC 02736 790 50316
       ROD: EV_ClimaT5Basis.rod
       VCID: 7BA2039F7362A86FCBF-802E
    Address 09: Cent. Elect. (J519)       Labels:. 7H0-937-08x-09.clb
       Part No SW: 7H0 937 087 M    HW: 7H0 937 087
       Component: BCM T5GP H+4  H34 0411
       Revision: BO034001    Serial number: 0573 253130112
       Coding: A8A439B80AF3241390204810242F8CD40000412F60040000320000000000
       Shop #: WSC 02756 790 12345
       VCID: 3E24CA8B20707D47AC1-806A
       Subsystem 1 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
       Component: J386__TSG_FT  002 3313
       Subsystem 2 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
       Component: J387__TSG_BT  002 3313
                        Reset counter: 10
                        Mileage: 155986 km
                        Date: 2019.05.06
                        Time: 01:52:56
    03156 - Sensor for Anti-Theft System (G578)
                        Reset counter: 221
                        Mileage: 155715 km
                        Date: 2019.05.04
                        Time: 00:00:51
                        Fault Frequency: 20
                        Reset counter: 12
                        Mileage: 155728 km
                        Date: 2019.05.04
                        Time: 02:21:14
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag009 H07 0013
       Revision: --------    Serial number: 003HL00FK921
       Coding: 000000000000000000000000000000003039
       Shop #: WSC 02734 790 50316
       VCID: 3536D5A715C6BE1F7DB-8060
       Part No SW: 7E0 920 860 J    HW: 7E0 920 860 J
       Component: KOMBI         H04 0709
       Coding: 160201
       VCID: 2F3AE7CFF79A84CF377-807A
       Part No SW: 6N0 909 901     HW: 7H0 937 087
       Component: GW-K-CAN TP20 H34 0411
       Revision: BO034001
       Coding: 042300
       VCID: 70B824B32AA4DB376ED-8024
                000 -  -
                        Mileage: 155715 km
                        Date: 2019.05.04
                        Time: 00:00:46
       Component: IMMO          H04 0709
       VCID: 6A8C36DB0CF821E7209-803E
       Part No SW: 5M0 035 156 D    HW: 5M0 035 156 D
       Component: Radio         553 0555
       Revision: R0553007    Serial number: VWZ5Z1M0797610
       Coding: 0000000000
       VCID: 2A0CF6DBCCF8E1E7E09-807E
                000 -  -
                        Reset counter: 0
       Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
       Component: Anhaenger     H10 0110
       Revision: 3B001001    Serial number: 00000189675052
       Coding: 410D000101000000
       Shop #: WSC 02736 790 00000
       VCID: 313EE1B7E12E923F213-8064
    End----------(Elapsed Time: 01:22, VBatt start/end: 12.1V/12.1V)-----------
