Results 11 to 20 of 23
Thread: HEX-NET will to read engine addresses
    Oh right, so this is like my old car. What does [Options] -> [Self Test] show for CAN status, with engine running? If it shows "Testing" you might have a problem with the wiring to the DLC, like Uwe said, because there should definitely be CAN traffic on the port.
  2. Likes Uwe liked this post
  3. #12
    Hudson Valley
    Quote Originally Posted by Shaun View Post
    It sounds like you might have problems with one of the klines. Does this car have an aftermarket radio? Plugged into car, what does [Options] -> [Self Test] show for K1 and K2 status? Can you post a whole autoscan so we can see what is and is not talking?
    OK, Shaun, I'll go out and run a complete autoscan, and I will try the Options -> Self Test for K1 and K2. BTW, this car does not have any aftermarket equipment installed anywhere. I'll be back soon.
  4. #13
    Yep, which is why I'm pretty confident it should work, despite being quite odd in terms of how it works.
  5. #14
    Hudson Valley
    Shaun, here is the entire scan. Addresses 01 through 07 did not read. The self test read:
    APP Id (1) CodeBlock V0.4437 API V4 FW version: 0.254. Dataset: 60000055
    K1: OK, K2: OK, CAN Not ready, VCDS-Cloud: Testing, Config: OK.
    Mon,May,13,2019,22:56:52
    VCDS Mobile 0.4437.0.4
    VIN: WAUAF78E48Axxxxxx
    Chassis Type:8E
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    Address 08: Auto HVAC	Labels: 8E0-820-043.lbl
    Part No SW: 8E0 820 043 BM
    Component: A4 Klimaautomat 3233
    Coding: 00000
    Shop #: WSC 00000 000
    VCID: 6D9D5AB72C63FF8B4354E7-5160
    01272 - Positioning Motor for Central Flap (V70)
    41-00 - Blocked or No Voltage
    Address 09: Cent. Elect.	Labels: 8E0-907-279-8EC.lbl
    Part No SW: 8E0 907 279 N
    Component: int. Lastmodul USA 0907
    Coding: 00003
    Shop #: WSC 06335 000
    VCID: 3D3DAAF73C83AF0BB374F7-4B00
    No fault codes found.
    Address 16: Steering wheel	Labels: 8E0-953-549.lbl
    Part No SW: 8E0 953 549 Q
    Component: Lenksäulenmodul 0801
    Coding: 02141
    VCID: 41C5D607407BCBEBD79C9B-4B00
    Address 17: Instruments	Labels: 8E-17.clb
    Part No SW: 8E0 920 951 N	HW: 8E0920951N
    Component: KOMBI+WFS 4 H14 0200
    Revision: 0200 Serial Number: 00000000000000
    Coding: 0022268
    Shop #: WSC 08201 444 85739
    VCID: 352DB2D704B3674B7B041F-5184
    Address 46: Central Conv.	Labels: 8E0-959-433-MAX.lbl
    Part No SW: 8E0 959 433 CP
    Component: Komfortgerät T7B 4336
    Coding: 11820
    VCID: 8145960780FB8BEB171CDB-4B00
    Subsystem 1 - Part No SW: 8E1-959-801-G
    Component: Türsteuer.FS BRM 0706
    35-00 - -
    01574 - Alarm triggered by Door Contact Switch; Rear Right
    35-00 - -
    01573 - Alarm triggered by Door Contact Switch; Rear Left
    35-00 - -
    Address 56: Radio	Labels: 8J0-035-1xx-56.clb
    Part No SW: 8E0 035 195 AF	HW: 8E0035195AF
    Component: R Symphony2+ H01 0270
    Revision: 00H01000	Serial Number: AUZ1Z4G6904208
    Coding: 0210012
    Shop #: WSC 06335 000 00000
    VCID: 6B9954AF1277E2BB5D20C9-5160
  6. #15
    Hudson Valley
    Except on a 2008 US model A4 , the ECU will be on CAN, as is 02-Auto Trans (if it has one), and 03-ABS. Furthermore, the powertrain CAN is brought directly to pins 6 and 14 on the DLC, and there is no Gateway. I wonder if he's got a problem with the wiring to those pins.
    Dear Uwe, please see the scan data I sent to Shaun. BTW the CAN reads as not ready, but Audi seems to be able to read the 01 through 07 addresses, and on some occasions I can read those addresses. As I mentioned earlier in the thread, the 01 was seen momentarily on the first scan, but no data was saved or appeared on the scan output.
    The 01-Engine, 02-Auto Trans and the 03-ABS have all been read at one time or another.
    The following is from a time that I was able to read addresses 01, 02, and 03:
    #hndoc:?docid=00003624&xt=hnh:DFBF8CCC722EA2E86F267FF6A70056A599DB843CB5345CFECDC2E0D58D470C34
    VCDS Mobile 0.4401.0.4
    Chassis Type:8D Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
    Address 01: Engine	Labels: 06F-907-115-AXX.clb
    Part No SW: 8E1 910 115 G	HW: 8E0907115D
    Component: 2.0l R4/4V TFSI 0010 Revision: 5EH15— Serial Number: XXXXXXXXXXXXXX
    Coding: 0104010A02070120
    VCID: 260F659BC9151DD3C27FA4DAC0-8073
    1 Fault Found: 008577 - Performance Malfunction in Cooling System
    P2181 - 008 - Implausible Signal - MIL ON Freeze Frame:
    Fault Status: 11101000
    Mileage: 178865 km
    RPM: 2273 /min
    Load: 28.6
    Speed: 74.0 km/h
    Temperature: 75.0°C Temperature: 23.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.097 V
    Address 02: Auto Trans	Labels: 8E-02.lbl
    Part No SW: 8E5 910 155 A	HW: 01J927156HT
    Component: V30 01J 2.0TFSI USA 0010 Revision: 00000009	Serial Number: 00000001165153 Coding: 0000001 Shop #: WSC 06335 000 00000 VCID: 28136BA3C3010BA3F093BAF23A-807D
    Address 03: ABS Brakes	Labels: 8E0-910-517.clb
    Part No SW: 8E0 910 517 H	HW: 8E0614517BF
    Component: ESP8 FRONT H06 0140
    Revision: 00000000
    Coding: 0004525
    VCID: 2C1B97B3D7F9278314BBE6020E-8079
  7. #16
    In the scan two posts up, everything that talks in on K-Line, and everything that doesn't is on CAN.
    "CAN Not Ready" could be a lack of connection to the car's CAN bus, possibly dodgy pins in the car's DLC, or a wiring problem in the car, or it could be some sort of internal failure in the HEX-NET.
    I think the only way to sort this out is process of elimination. What other cars do you have available that you can plug the HEX-NET into?
  8. #17
    Hudson Valley
    Hi Uwe, I have one outside now; Ill try to run the diagnostic on that one now. Back in a few.
  9. #18
    Hudson Valley
    Dear Uwe,
    Well, I got side tracked and didn't get a chance to try the HEX-NET on the other Audi, a 2015 A4 Quattro Prestige until two days ago. The HEX-NET did read the CAN bus. It did take a bit of time for the CAN bus to be ready, but all of the addresses were read.
    Can you suggest a protocol for trouble shooting the inability the HEX-NET to read the CAN bus on my 2008 A4?
    Binsu
  10. Likes jyoung8607 liked this post
  11. #19
    Hudson Valley
    I tried the HEX-NET on the other Audi, a 2015 A4 Quattro Prestige, and the HEX-NET did read the CAN bus. If I'm trouble shooting the cars OBD-II bus at pins 6 and 14, how would I be able to do that and what readiness should I expect to get?
    Would you have a photo of the OBD-II connector showing which pins 6 & 14 are?
    Thank you,
    Binsu
  12. #20
