HEX-NET will to read engine addresses
BinsuJiro
Hudson Valley, USA
C?ID=63476
I have a 2008 2.0T A4 Quattro which showed a check engine light two days ago. The A4 seems to be running well, but I cannot gain access to the OBD-II fault codes, and when I run a diagnostic none of the engine addresses are read. All other addresses are read normally and there is no data that indicates what might be wrong.
Any Ideas??? Best Binsu
You're presumably doing this with VCDS-Mobile?
What happens if you just do [Select] -> [01-Engine]?
Shaun had a 2008 A4 2.0T for several years while working on the HEX-NET and VCDS-Mobile. So I'm pretty confident it should work. :)
Zenerdiode
Newcastle, England
C?ID=24330
My A4q is a 2.0TFSi too, however it is the CDNC engine and I believe on your side of the pond, you have the CAEB. My HN works flawlessly wired with a USB cable, Access Point with VCDS, and stand-alone with VCDS-Mobile.
I’m pretty sure I’ve seen VCDS logs with the CAEB, but not sure of CAEB with VCDS-Mobile.
BinsuJiro
Hudson Valley, USA
C?ID=63476
Yes, I'm using VCDS mobile, and I will try to select. But, I still cannot access the OBD-II data to find out what codes are being thrown.
Best, V
BinsuJiro
Hudson Valley, USA
C?ID=63476
I have been unable to even access the OBD-II fault codes, and all of the other addresses output results. One anomaly I noticed is that some engine data appeared for a split second when I first started the diagnostic, but immediately disappeared. Thanks, Binsu
Shaun
If you go to [Select] -> [Engine] -> [Functions] -> [Fault codes] do you see anything?
BinsuJiro
Hudson Valley, USA
C?ID=63476
Dear Uwe, I tried that and the HEX-NET makes three attempts to initiate the K-line and will not load any address from 01 through 07. OBD-II data is unavailable. However, the Check Engine Light [CEL] has gone off.
My son drives the car, so I have no first hand knowledge of the conditions under which the CEL will light, and there were no apparent symptoms that I could hear, see or feel. There could have been a possibility that either the oil filler cap or the gas cap may have been loose. He got fuel yesterday and the light is off now.
However, it is disconcerting that I am unable to diagnose this particular A4. I do know that Audi can read the engine codes and addresses 01 through 07.
This is frustrating and puzzling. Any assistance would be appreciated.
Best, Binsu
BinsuJiro
Hudson Valley, USA
C?ID=63476
Shaun, thanks for your advise; please see my reply to Uwe. Best, Binsu
Shaun
It sounds like you might have problems with one of the klines. Does this car have an aftermarket radio? Plugged into car, what does [Options] -> [Self Test] show for K1 and K2 status? Can you post a whole autoscan so we can see what is and is not talking?
Except on a 2008 US model A4 , the ECU will be on CAN, as is 02-Auto Trans (if it has one), and 03-ABS. Furthermore, the powertrain CAN is brought directly to pins 6 and 14 on the DLC, and there is no Gateway. I wonder if he's got a problem with the wiring to those pins.
Shaun
Oh right, so this is like my old car. What does [Options] -> [Self Test] show for CAN status, with engine running? If it shows "Testing" you might have a problem with the wiring to the DLC, like Uwe said, because there should definitely be CAN traffic on the port.
BinsuJiro
Hudson Valley, USA
C?ID=63476
OK, Shaun, I'll go out and run a complete autoscan, and I will try the Options -> Self Test for K1 and K2. BTW, this car does not have any aftermarket equipment installed anywhere. I'll be back soon.
Yep, which is why I'm pretty confident it should work, despite being quite odd in terms of how it works. ;)
BinsuJiro
Hudson Valley, USA
C?ID=63476
Shaun, here is the entire scan. Addresses 01 through 07 did not read. The self test read:
APP Id (1) CodeBlock V0.4437 API V4 FW version: 0.254. Dataset: 60000055
K1: OK, K2: OK, CAN Not ready, VCDS-Cloud: Testing, Config: OK.
Mon,May,13,2019,22:56:52
VCDS Mobile 0.4437.0.4
VIN: WAUAF78E48Axxxxxx
Chassis Type:8E
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Address 08: Auto HVAC	Labels: 8E0-820-043.lbl
Part No SW: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000 000
VCID: 6D9D5AB72C63FF8B4354E7-5160
01272 - Positioning Motor for Central Flap (V70)
41-00 - Blocked or No Voltage
Address 09: Cent. Elect.	Labels: 8E0-907-279-8EC.lbl
Part No SW: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 00003
Shop #: WSC 06335 000
VCID: 3D3DAAF73C83AF0BB374F7-4B00
No fault codes found.
Address 16: Steering wheel	Labels: 8E0-953-549.lbl
Part No SW: 8E0 953 549 Q
Component: Lenksäulenmodul 0801
Coding: 02141
VCID: 41C5D607407BCBEBD79C9B-4B00
Address 17: Instruments	Labels: 8E-17.clb
Part No SW: 8E0 920 951 N	HW: 8E0920951N
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial Number: 00000000000000
Coding: 0022268
Shop #: WSC 08201 444 85739
VCID: 352DB2D704B3674B7B041F-5184
Address 46: Central Conv.	Labels: 8E0-959-433-MAX.lbl
Part No SW: 8E0 959 433 CP
Component: Komfortgerät T7B 4336
Coding: 11820
VCID: 8145960780FB8BEB171CDB-4B00
Subsystem 1 - Part No SW: 8E1-959-801-G
Component: Türsteuer.FS BRM 0706
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
35-00 - -
Address 56: Radio	Labels: 8J0-035-1xx-56.clb
Part No SW: 8E0 035 195 AF	HW: 8E0035195AF
Component: R Symphony2+ H01 0270
Revision: 00H01000	Serial Number: AUZ1Z4G6904208
Coding: 0210012
Shop #: WSC 06335 000 00000
VCID: 6B9954AF1277E2BB5D20C9-5160
BinsuJiro
Hudson Valley, USA
C?ID=63476
Dear Uwe, please see the scan data I sent to Shaun. BTW the CAN reads as not ready, but Audi seems to be able to read the 01 through 07 addresses, and on some occasions I can read those addresses. As I mentioned earlier in the thread, the 01 was seen momentarily on the first scan, but no data was saved or appeared on the scan output.
The 01-Engine, 02-Auto Trans and the 03-ABS have all been read at one time or another.
The following is from a time that I was able to read addresses 01, 02, and 03:
#hndoc:?docid=00003624&xt=hnh:DFBF8CCC722EA2E86F267FF6A70056A599DB843CB5345CFECDC2E0D58D470C34
VCDS Mobile 0.4401.0.4
Chassis Type:8D Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine	Labels: 06F-907-115-AXX.clb
Part No SW: 8E1 910 115 G	HW: 8E0907115D
Component: 2.0l R4/4V TFSI 0010 Revision: 5EH15— Serial Number: XXXXXXXXXXXXXX
Coding: 0104010A02070120
VCID: 260F659BC9151DD3C27FA4DAC0-8073
1 Fault Found: 008577 - Performance Malfunction in Cooling System
P2181 - 008 - Implausible Signal - MIL ON Freeze Frame:
Fault Status: 11101000
Fault Frequency: 6
Mileage: 178865 km
RPM: 2273 /min
Load: 28.6
Speed: 74.0 km/h
Temperature: 75.0°C Temperature: 23.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.097 V
Address 02: Auto Trans	Labels: 8E-02.lbl
Part No SW: 8E5 910 155 A	HW: 01J927156HT
Component: V30 01J 2.0TFSI USA 0010 Revision: 00000009	Serial Number: 00000001165153 Coding: 0000001 Shop #: WSC 06335 000 00000 VCID: 28136BA3C3010BA3F093BAF23A-807D
Address 03: ABS Brakes	Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 H	HW: 8E0614517BF
Component: ESP8 FRONT H06 0140
Revision: 00000000
Coding: 0004525
VCID: 2C1B97B3D7F9278314BBE6020E-8079
In the scan two posts up, everything that talks in on K-Line, and everything that doesn't is on CAN.
"CAN Not Ready" could be a lack of connection to the car's CAN bus, possibly dodgy pins in the car's DLC, or a wiring problem in the car, or it could be some sort of internal failure in the HEX-NET.
I think the only way to sort this out is process of elimination. What other cars do you have available that you can plug the HEX-NET into?
BinsuJiro
Hudson Valley, USA
C?ID=63476
Hi Uwe, I have one outside now; Ill try to run the diagnostic on that one now. Back in a few.
BinsuJiro
Hudson Valley, USA
C?ID=63476
Dear Uwe,
Well, I got side tracked and didn't get a chance to try the HEX-NET on the other Audi, a 2015 A4 Quattro Prestige until two days ago. The HEX-NET did read the CAN bus. It did take a bit of time for the CAN bus to be ready, but all of the addresses were read.
Can you suggest a protocol for trouble shooting the inability the HEX-NET to read the CAN bus on my 2008 A4?
Binsu
BinsuJiro
Hudson Valley, USA
C?ID=63476
I tried the HEX-NET on the other Audi, a 2015 A4 Quattro Prestige, and the HEX-NET did read the CAN bus. If I'm trouble shooting the cars OBD-II bus at pins 6 and 14, how would I be able to do that and what readiness should I expect to get?
Would you have a photo of the OBD-II connector showing which pins 6 & 14 are?
Thank you,
Binsu
