Xenon adaption
CocoPops
C?ID=65608
Am I right in thinking I need to use VCDS to adjust my headlamps?
Off to Europe next week (from UK drive in left) to France (drive in right).
So module 55?
What do I need to do?
golfi_vend
Tartu, Estonia
C?ID=195131
Well using a crystal ball could help
/If you know what i mean ;) /
CocoPops
C?ID=65608
No idea... But I assume you mean autos an? (Quoting from a previous post)
As I understand it, the Q3 uses the MK6 underpinnings, thus no Module 46.
I had quite a few label-less modules when I ran a recent scan on my 2014 (July built) Q3:
Friday,26,September,2014,14:09:05:09724
VCDS Version: 12.12.3.0 (x64)
Data version: 20140822
VIN: WAUZZZ8U2ER111234   License Plate:
Mileage: 859miles   Repair Order:
Chassis Type: 8U (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 56 5F
          62 72
Address 01: Engine (J623-CFGC)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 PH    HW: 03L 906 018 ES
   Component: R4 2,0L EDC   H28 6636
   Revision: 41H28---    Serial number:
   Coding: 00250012043701080000
   Shop #: WSC 00049 770 00118
   ASAM Dataset: EV_ECM20TDI01103L906018PH 003006
   ROD: EV_ECM20TDI01103L906018PH.rod
   VCID: 7F06CC35E6D880E6E27-802A
Address 02: Auto Trans (J743)       Labels: 0BH-927-711.clb
   Part No SW: 0BH 300 012 A    HW: 0BH 927 711 C
   Component: DSG DQ500-7A  H08 2233
   Revision: 00H08V01
   ROD: EV_TCMDQ500021_AU21.rod
   VCID: 21422A4D30EC1616B43-8074
Address 03: ABS Brakes        Labels: NONE
   Part No SW: 5N0 614 109 BA    HW: 5N0 614 109 BA
   Component: J104   C6 450M VD16 0160
   Revision: --H07---    Serial number: 00000008231167
   Coding: 0056717
   Shop #: WSC 00049 770 00153
   VCID: 6BDE08654AA00C465EF-803E
Address 08: Auto HVAC        Labels: 8P0-820-043.LBL
   Part No SW: 8U0 820 043 E    HW: 8U0 820 043 E
   Component: E87  Klimavoll      0100
   Revision: 00H04000    Serial number: 8U0820043E
   VCID: 336ED0055210948656F-8066
Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.CLB
   Part No SW: 8X0 907 063 R    HW: 8X0 907 063 R
   Component: BCM PQ35  M   113 0811
   Revision: AD113811
   Coding: 0E000A2FA805F1C0201841C02104094C53FF84AA216F912BE408878400C5
   Shop #: WSC 00049 770 00008
   VCID: 4B9EA8E5EAE0EC463EF-801E
   Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119
   Component: WWS316 140515  H37 0085
   Coding: 0047F7
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
Address 10: Park/Steer Assist (J446)       Labels: 8X0-919-475.clb
   Part No SW: 8X0 919 475 N    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0050
   Revision: 11001001    Serial number: 61061416201043
   Coding: 88C305
   ASAM Dataset: EV_EPHVA18AU21X0000 003006
   ROD: EV_EPHVA18AU21X0000.rod
   VCID: 51A2BA8D00CCC696443-8004
Address 15: Airbags (J234)       Labels: 8X0-959-655.clb
   Part No SW: 8U0 959 655 B    HW: 8U0 959 655 B
   Component: AirbagVW-AU10 H09 0520
   Serial number: 003LRR08GZ5D
   Coding: 30393132313030303030554A305238553053
   ASAM Dataset: EV_AirbaAU10SMEAU316 001005
   ROD: EV_AirbaAU10SMEAU316.rod
   VCID: 468899D1F982112EE11-8013
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME0648232FZZZ-
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME7F67232FZZZ2
   Serial number: 3516KSME6361232FZZZR
   Serial number: 3526KSME2977232FZZZ.
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME520D5C2DZZZB
Address 16: Steering wheel (J527)       Labels: 8X0-953-569.clb
   Part No SW: 8X0 953 521 D    HW: 5K0 953 569 AE
   Revision: FF010018    Serial number: 20140616101321
   Coding: 1894204000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 3D7AF63DAC5452F6B0B-8068
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
Address 17: Instruments (J285)       Labels: 8X0-920-xxx-17.clb
   Part No SW: 8U0 920 990 E    HW: 8U0 920 990 E
   Component: KOMBI_COLOUR  H01 0240
   Coding: 42CF01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 3F868C35A65840E6A27-806A
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.CLB
   Part No SW: 8U0 907 468 AE    HW: 8U0 907 468 J
   Component: GAT 4CAN 2L M H13 0072
   Revision: 1R150039    Serial number: 3941R1452503D8
   Coding: FBCF1A5A050B05610353
   VCID: 850ADEDD0C045A3628B-80D0
   Subsystem 1 - Part No SW: 8U0 959 591     HW: 8V3 959 591
   Component: J245 PS11.018  H02 0007
   Coding: 901E00
   Subsystem 2 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Subsystem 3 - Part No SW: 8U0 959 591     HW: 8V3 959 591
   Component: J394 PS11.018  H02 0007
   Coding: 801E00
   Subsystem 4 - Part No SW: 8K0 959 663     HW: 8K0 959 663
Address 22: AWD (J492)       Labels: None
   Part No SW: 0AY 907 554 F    HW: 0AY 907 554 F
   Component: Haldex4Motion H52 7521
   Serial number: HA1-00023.05.14
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4E98A1F111F2D96E591-801B
   Component: IMMO          H01 0240
   Coding: 000002
   ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
   ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.CLB
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H10 0415
   Coding: 011E06200401000000
   VCID: 52A0B5810DCABD8E7D9-8007
Address 44: Steering Assist        Labels: NONE
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 296    3501
   Revision: 00H22000
   VCID: 40848FC913A63F1EDBD-8015
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.CLB
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H10 0415
   VCID: 51A2BA8D08CCC696443-8004
Address 53: Parking Brake        Labels: 3AA-907-801.CLB
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000079643
   Coding: 0025166
   VCID: 3874E7294B7677DE63D-806D
Address 55: Xenon Range (J431)       Labels: 8X0-907-357.clb
   Serial number: 140606-0002-070
   Coding: 1157A41010002500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 428085C1D5AA2D0ECD9-8017
Address 56: Radio (R)       Labels: REDIR FAIL!
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109F50E7934298
   Coding: 010105020100000002
   VCID: 285437695BD6E75EF3D-807D
   Part No SW: 8U0 035 666 J    HW: 8U0 035 666 D
   Component: H-BN-EU       H46 H-BN-EU       H46 08140814
   Revision: --------    Serial number: 199F/0EB002147
   Coding: 0E010106000AE1E90180033600000001E00100020000000000
   VCID: 41828ACDD8AC3616D43-8014
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Subsystem 2 - Part No SW: 8U0 919 604 A    HW: 8U0 919 604 A
   Component: DU High AU316  H42 0018
   Subsystem 3 - Part No: 8R0 060 961 G
   Component: CD-Database  5950
Address 62: Door, Rear Left (J388)       Labels: NONE
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H07 0415
   Coding: 010E06200001000000
   VCID: 4FA6BCF51EF8D066527-801A
Address 72: Door, Rear Right (J389)       Labels: NONE
   Component: TSG HR        H07 0415
Running a level2 debug produced the following files, which I sent to Ross-Tech support:
03-5N0-614-109-BA.PLA
03-5N0-614-109-BA.PLB
44-5N0-909-144-R.PLA
44-5N0-909-144-R.PLB
56-4G0-035-061-N.PLA
56-4G0-035-061-N.PLB
5F-8U0-035-666-J.PLA
5F-8U0-035-666-J.PLB
62-8X0-959-795-C.PLA
62-8X0-959-795-C.PLB
72-8X0-959-795-C.PLA
72-8X0-959-795-C.PLB
So hopefully they can make sense of them :D
I'm not sure why there are so many missing labels, given the Q3 platform is not that new? 2012 I think?
Although, the US is only just starting to get the Q3, so that may be why?
Cheers,
Lee.
[Select]
[55-Xenon Range]
[Coding]
[Long Coding Helper]
Have a look at Byte 6, Bit 1.
CocoPops
C?ID=65608
There is no long coding helper for me :(
CocoPops
C?ID=65608
I have a Left/Right Drive Adaption but if I set it to Active, nothing happens.
CocoPops
C?ID=65608
Adaption Log:
Saturday,13,December,2014,17:25:16:09724
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WAUZZZ8U2ER111920   License Plate:
Mileage: 4260km-2647mi   Repair Order:
UDS Adaptation Channel: Activate left/right hand drive switch-over
Stored value active
Here's the latest AutoScan as well:
Saturday,13,December,2014,17:16:37:09724
          62 72
VIN: WAUZZZ8U2ER111920   Mileage: 4260km-2647miles
   ROD: EV_ECM20TDI01103L906018EQ.rod
   VCID: 7F06CC35E6D880D9161-802A
   Revision: 00H08V01
   VCID: 21422A4D30EC1629405-8074
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Component: J104   C6 450M VD63 0160
   Coding: 0056717
   VCID: 6BDE08654AA00C79AA9-803E
   VCID: 336ED005521094B9A29-8066
Address 09: Cent. Elect. (J519)       Labels: 8X0-907-063.clb
   Revision: AD113811
   VCID: 4B9EA8E5EAE0EC79CA9-801E
   Coding: 0047F7
   Coding: 02006E
   Coding: 88C305
   VCID: 51A2BA8D00CCC6A9B05-8004
   VCID: 468899D1F9821111157-8013
   Coding: 1894204000
   VCID: 3D7AF63DAC5452C944D-8068
   Coding: 42CF01
   VCID: 3F868C35A65840D9561-806A
Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
   VCID: 050A5EDD8C04DA095CD-8050
   Coding: 901E00
   Coding: 801E00
   Coding: 0001
   VCID: 4E98A1F111F2D951AD7-801B
   Coding: 000002
Address 42: Door Elect, Driver (J386)       Labels: 8X0-959-793.clb
   VCID: 52A0B5810DCABDB189F-8007
   Revision: 00H22000
   VCID: 40848FC913A63F212FB-8015
Address 52: Door Elect, Pass. (J387)       Labels: 8X0-959-792.clb
   VCID: 51A2BA8D08CCC6A9B05-8004
   Coding: 0025166
   VCID: 3874E7294B7677E197B-806D
Address 55: Headlight Range (J431)       Labels: 8X0-907-357.clb
   Coding: 1157A41010002700
   VCID: 428085C1D5AA2D3139F-8017
   VCID: 285437695BD6E76107B-807D
   Component: H-BN-EU       H46 0814
   Coding: 0E010106000AE1E901800F3600000001E00100020000000000
   VCID: 41828ACDD8AC3629205-8014
   VCID: 4FA6BCF51EF8D059A61-801A
End-------------------------(Elapsed Time: 04:19)--------------------------
pronet
Romania
C?ID=157414
Check to activate Tourist mode on 55 Xenon range.
Byte 6, Bit 1 should be: Tourist Mode selectable via MMI. Set that bit and then look for the setting in your MMI.
golfi_vend
Tartu, Estonia
C?ID=195131
Or paste this coding to coding menu.
1157A41010002700
CocoPops
C?ID=65608
Finally got round to this...
That coding is what I already have...
I also found that Byte6 Bit 1 was already set.
CocoPops
C?ID=65608
CocoPops
C?ID=65608
In MMI, I have an "External Lights" under the Car Menu, but that only allows me to select Coming/Leaving Home On/Off.
CocoPops
C?ID=65608
Found this on an a4/a5 page:
Enable ‘Tourist’ Mode – Headlight Convertor (MMI 2G)
[09-Central Elect]
[Coding – 07]
[Long Coding Helper] - Byte 4, Bit 6 = 1
Enables the 'connection' between Cent. Elect and the Headlight Convertor MMI menu item
[55-Xenon Range]
[Adaptation – 10]
[Channel 10] - 0 = Disable 1 = Enable
Press ‘Test’ and then ‘Save’
Enables the Headlight Convertor MMI item under the CAR button.
Restart MMI to see changes.
Source: http://ludocar.free.fr/Audimodif/Au...013/9/24_A4_8K___A5_8T_Modif_Vagcom_VCDS.html
So do I need to try this?
I've not done anything to Central Elect module.
Good question. None of us have a Q3. It also bothers me a bit that this is for a 2G MMI, and it looks like your car is a 3G. OTOH, there's probably no harm in setting that bit to see if it produces the results you're looking for. If it doesn't, just un-set it again.
CocoPops
C?ID=65608
Yep, hoping a few more Q3s appear in these walls ;)
Meh, I like Audi cars, but if I want a truck, I'll buy a VW thanks! :D
CocoPops
C?ID=65608
Cent Elec, byte 4 bit 6 is linked to sunroof closure.
So not that....
