Results 1 to 3 of 3
Thread: VCDS: Coding out cold diagnosis for bulbs
    May 2019
    AU
    Hi Everyone,
    I'm trying to find a way to code out cold diagnosis for bulbs, I noticed in the older version of VCDS there used to be options under Byte 18 however in the new version, I can't seem find it. Is there another way to disable the bulb out warnings.
    Vehicle: 2011, Audi R8 V10 Spyder
    Thank you in advance.
    Jeff
    Auto-Scan
    Friday,10,May,2019,10:59:53:19800
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WUAZZZ42XBN002196   License Plate: STARK8
    Mileage: 71020km-44129mi   Repair Order:
    a
    a
    Chassis Type: 42-AU35 (8P0)
    Scan: 01 02 03 08 09 10 11 31 14 15 16 17 19 20 25 26 2E 37 3D 42
              46 47 52 56 61 6C 77 A6
    VIN: WUAZZZ42XBN002196   Mileage: 71020km-44129miles
    20-High Beam Assist. -- Status: Malfunction 0010
    3D-Special Function -- Status: OK 0000
    A6-Microphone -- Status: Malfunction 0010
    Address 01: Engine (BUJ)       Labels: None
       Part No SW: 424 910 552 J    HW: 420 907 552 B
       Component: 5.2L V10HDZ/4V F   0010
       Revision: F5H07---    Serial number: AUX7Z0K0FNJ0K7
       Coding: 0110000C1B0F0120
       Shop #: WSC 66565 257 00032
       VCID: 1A6D2E37309B6C57709-804E
    012313 - Valve for Exhaust Flap 1 (N321)
                   P3019 - 004 - Open Circuit
                        Mileage: 70500 km
                        RPM: 219 /min
                        Load: 66.6 %
                        Temperature: 51.0C
                        Temperature: 37.0C
                        Absolute Pres.: 1010.0 mbar
                        Voltage: 10.922 V
    Address 02: Auto Trans        Labels: 420-910-156-V2.clb
       Part No SW: 420 910 156 L    HW: 420 927 156
       Component: SL600 5.2L FSI HDZ  0030
       Revision: SBH03001    Serial number: 8+3N5UI1L
       Shop #: WSC 02197 785 00200
       VCID: 1869343FCE977E4746D-804C
       Subsystem 1 - Part No: 420 713 041 C
       Component: A11 C02  03.01.11   0A11
    049478 - No Communication with Diagnostic Gateway
                   U0146 - 000 -  - Intermittent
                        Mileage: 70644 km
                        Torque: 0.0 Nm
                        Temperature: 21.0C
                            0.00 %
    Address 03: ABS Brakes        Labels: None
       Part No SW: 420 907 379     HW: 420 614 517 D
       Component: ESP8 quattro    H01 0200
       Coding: 0000268
       VCID: 59EF713B751DA74FB93-800C
       Part No SW: 420 820 043 E    HW: 420 820 043 E
       Component: J255  Klima 1 Zone  0090
       Revision: 00H06007    Serial number: 00000001171133
       Coding: 1574026
       Shop #: WSC 03109 822 100551
       VCID: 0C41586F8A4F82E7F25-8058
    Address 09: Cent. Elect. (J519)       Labels:. 8P0-907-063.clb
       Part No SW: 8P0 907 063 R    HW: 8P0 907 063 H
       Component: BCM PQ35  H   108 0667
       Revision: 00108 AE
       Coding: 4F000A20A817F320207060E825200048D0726800B120C92ADC080E1C0045
       Shop #: WSC 03109 822 179116
       VCID: 43D3B353EB910D9FC3F-8016
       Subsystem 1 - Part No SW: 427 955 114 A    HW: 427 955 114 A
       Component: Wischer AudiR  H23 0011
       Coding: 005912
       Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSEN  H04 0003
       Coding: 025B32
       Subsystem 3 - Part No: 8J0 951 177
       Component: DWA-Sensor H0  H03 0030
    01598 - Drive Battery Voltage
                        Fault Status: 00101011
                        Reset counter: 173
                        Mileage: 70633 km
                        Date: 2019.05.06
                        Time: 00:54:01
                        Voltage: 14.15 V
                            Term 50 On
    02739 - Bulb for Tail/Brake Light; Right
                        Fault Status: 00101010
                        Reset counter: 174
                        Mileage: 70654 km
                        Date: 2019.05.06
                        Time: 09:23:42
                        Voltage: 14.40 V
                            Term 50 On
    Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X2.clb
       Part No SW: 8P0 919 475 N    HW: 8P0 919 475 N
       Component: PARKHILFE 8K  H01 0140
       Revision: 11001001    Serial number: 12591102065480
       Coding: 30010C
       Shop #: WSC 02391 823 56573
       VCID: 49CFA17BC9BDD7CF093-801C
    01543 - Parking Aid Warning Chime (H15)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 128
                        Mileage: 70538 km
                        Date: 2019.05.05
                        Time: 02:43:46
                        Temperature: 17.0C
    01625 - Front Parking Aid Warning Chime (H22)
                        Fault Status: 00101001
                        Fault Frequency: 10
                        Reset counter: 175
                        Time Indication: 15
                        Temperature: 18.0C
    Address 11: Engine II        Labels: None
    Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
       Part No SW: 420 910 376 A    HW: 420 907 376 A
       Component: J250 Raddaempfung   0170
       Revision: --H16---    Serial number: 190DPH 0326018
       Coding: 0000054
       VCID: 117F491BED6DAF0F013-8044
    Address 15: Airbags        Labels: None
       Part No SW: 427 959 655     HW: 427 959 655
       Component: 13 Airbag 9.43  H02 0030
       Revision: 93H02003    Serial number: 003B800027C0
       Coding: 0012595
       VCID: 649150CF425F6AA71A5-8030
       Subsystem 1 - Serial number: 63328RB405E903B8S
       Subsystem 2 - Serial number: 63428RB405E8FC50
       Subsystem 3 - Serial number: 63747RB405FD18CA4
       Subsystem 4 - Serial number: 63847RB405FD18C4%
    Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
       Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
       Coding: 0004141
       VCID: 41DFB95BFD8D1F8FD13-8014
       Component: E0221           H06 0040
    01304 - Radio
    Address 17: Instruments        Labels: 420-920-xxx-17.clb
       Part No SW: 420 920 930 K    HW: 420 920 930 K
       Component: KOMBIINSTR. VDO H01 0596
       Revision: D0H01004    Serial number: 2240K004001056
       Coding: 0064728
       Shop #: WSC 14252 002 104857
       Part No SW: 8P0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H43 0311
       Revision:   H43       Serial number: 100111F2001049
       Coding: 355101
       VCID: 3333E393BB31BD1F53F-8066
                        Reset counter: 128
                        Mileage: 70538 km
                        Date: 2019.05.05
                        Time: 02:43:51
                        Reset counter: 128
                        Mileage: 70538 km
                        Date: 2019.05.05
                        Time: 02:43:51
    01304 - Radio
                        Reset counter: 128
                        Mileage: 70538 km
                        Date: 2019.05.05
                        Time: 02:43:51
       Part No SW: 8J0 857 511 G    HW: 8J0 857 511 G
       Component: FLA           H03 0004
       Revision: AA002001
       Coding: 04029C64747464545425363E
       VCID: 3431E08FBE3FBA274A5-8060
                        Reset counter: 173
                        Mileage: 70654 km
                        Date: 2019.05.06
                        Time: 09:21:48
       Revision: D0H01004    Serial number: AUX7Z0K0FNJ0K7
    Address 26: Auto Roof (J256)       Labels:| 427-959-255.clb
       Part No SW: 427 959 255 B    HW: 427 959 255 B
       Component: VSG-AU715     H04 0100
       Coding: 000001
       Shop #: WSC 02197 785 00000
       ASAM Dataset: EV_ElectRoofContrAU715 001006
       ROD: EV_ElectRoofContrAU715.rod
       VCID: 221D16D7144B2497A89-8076
    Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
       Part No SW: 420 035 785     HW: 420 035 785
       Component: SG ext.Player H08 0100
       Revision: 00000000
       Coding: 020202
       VCID: 52FD861724EB9417789-8006
    01304 - Radio
                        Reset counter: 128
                        Mileage: 70538 km
                        Date: 2019.05.05
                        Time: 09:54:08
    Address 37: Navigation
    Address 3D: Special Function        Labels: 8K0-907-440.clb
       Part No SW: 8K0 907 440 A    HW: 8K0 907 440
       Component: STS             H04 0030
       Revision: S0H04000    Serial number: 00000000029741
       Coding: 01010101000000000000000102
       VCID: 2C01F8EF6A0FE2E7125-8078
    Address 42: Door Elect, Driver        Labels: None
       Part No SW: 427 959 801 E    HW: 427 959 801 E
       Component: Tuer-SG         H05 0106
       Coding: 0021117
       VCID: 221D16D718CB2497A89-8076
    Address 47: Sound System
    Address 52: Door Elect, Pass.        Labels: None
       Part No SW: 427 959 802 E    HW: 427 959 802 E
       Coding: 0021117
       VCID: 231313D307D12D9FA3F-8076
    Address 56: Radio
       Part No SW: 8P0 907 534     HW: 1K0 907 951
       Component: Batt.regelung H43 0311
       Coding: F32201FE
       VCID: 74B1208FFEBFFA278A5-8020
       Subsystem 1 - Part No SW: 420 915 181     HW: 420 915 181
       Component: J367-BDM  H07 0140
       Serial number: 00000000005650453896
                        Fault Status: 00100011
                        Fault Frequency: 20
                        Reset counter: 173
                        Mileage: 70633 km
                        Date: 2019.05.06
                        Time: 00:54:01
    Address 6C: Back-up Cam.        Labels: 420-910-441.clb
       Part No SW: 420 910 441 A    HW: 7L6 907 441 C
       Component: J772__Rearview      0010
       Revision: --H13---    Serial number: 525PA8-J11601L
       Coding: 1020412
       VCID: 0A4D5E77803B9CD7C09-805E
    02203 - Audio / Video Input 1
                        Reset counter: 128
                        Mileage: 70538 km
                        Date: 2019.05.05
                        Time: 02:43:46
                            Reverse OFF
                        Count: 3
       Part No SW: 8P1 862 335     HW: 8P1 862 335
       Component: FSE_256x BT     H41 0650
       Revision: 00000000    Serial number: 00000005270076
       Coding: 0011492
       Shop #: WSC 02556 785 00200
       VCID: 74B1208FF2BFFA278A5-8020
    02503 - Output Wire to Radio
                        Reset counter: 128
                        Mileage: 70538 km
                        Date: 2019.05.05
                        Time: 02:43:46
    01304 - Radio
                        Fault Frequency: 27
                        Reset counter: 135
                        Mileage: 70538 km
                        Date: 2019.05.05
                        Time: 02:43:46
    Address A6: Microphone (J886)       Labels:. 420-907-394.clb
       Part No SW: 420 907 394     HW: 420 907 394
       Component: BELTMICBOX    H09 0060
       Coding: 0100010202
       ASAM Dataset: EV_BeltMicAU715 002011
       ROD: EV_BeltMicAU715_002.rod
       VCID: 56F57A0708838837941-8002
    6 Faults Found:
    0032 - Microphone 1 for Passenver Side
              B1206 13 [009] - Open Circuit
    0048 - Microphone 2 for Passenver Side
              B1207 13 [009] - Open Circuit
    0064 - Microphone 3 for Passenver Side
              B1208 13 [009] - Open Circuit
    0080 - Microphone 1 for Drivers Side
              B1203 13 [009] - Open Circuit
    0096 - Microphone 2 for Drivers Side
              B1204 13 [009] - Open Circuit
    0112 - Microphone 3 for Drivers Side
              B1205 13 [009] - Open Circuit
    End----------(Elapsed Time: 01:35, VBatt start/end: 12.2V/12.1V)-----------
  2. Likes Uwe liked this post
  3. #2
    Dec 2016
    DE
    To my understanding Byte 18 and all of its magic still applies to your car. However I would not recommend to fiddle with it, as hard-to-fix problems could appear.
    Instead you better find someone who can modify the cars BCM EEPROM parameters to adjust just what you want to accomplish. Changing the options via another Byte 18 setting can be like moving to another home just because the porch lightbulbs need to be replaced.
  4. Likes Uwe liked this post
  5. #3
    Jun 2017
    @Uwe
    VCDS could implement a power-user feature for exporting and re-importing the (in the meantime) well-known Byte-area of the PQ BCM lighting configuration...
    Something special hidden and non-intuitive like changing diagnostic sessions
    This could push VCDS for solving these Byte 18 issues...
  6. Likes Uwe, PetrolDave liked this post
