Results 1 to 3 of 3
Thread: Tiguan 2011 MFSW retrofit questions
    New User
    May 2019
    Poland
    Question Tiguan 2011 MFSW retrofit questions
    Hello everyone, I'm new here.
    I'd like to retrofit my 2011 Tiguan with MFSW wheel and upgrade my radio.
    (I know there is a separate Retrofit forum section, but I'm not verified VCDS user. I have reviewed similar posts here, but I'm not car electronics expert like you guys and I want to check facts before I purchase any gear.)
    The current steering wheel is 3-arm, bare plastic.
    What I would like to get:
    Control the radio and computer from the steering wheel, as shown here in VW Golf MFSW retrofit:
    https://www.youtube.com/watch?v=-YeCorwqiUU
    The questions here:
    - Can I also get cruise control in steering wheel? Will such a newer steering wheel model work with the SCM module that can be installed in my Tiguan?
    - Is it possible to get control of the DSG gearbox in steering wheel? Is the steering wheel with DSG blades model supported?
    - does moving the computer to the steering wheel force replacement of the right hand shifter?
    If the cruise control and DSG blades are too much risk that it will not work, I would be satisfied with a 12-button steering wheel: just radio and computer control.
    Currently, the radio is some crappy knockoff (it was like that when I bought the car) - that's why it is not shown in VCDS scan.
    Radio I want to buy the Rcd330 Plus 6RD 035 187B with the reversing camera, I saw that in Golf the exchange went smoothly:
    https://www.youtube.com/watch?v=b0NqfNYi2n4
    Can you please help me pick right parts for the job? Particularly, which SCM module, what MFSW steering wheel will work?
    My Tiguan VCDS scan result:
    Thursday, 09, May, 2019.20: 46: 00: 51,167
    VCDS - VAG / VAS emulator working in Windows environment, running on Windows 7 x64
    VCDS version: AKP 18.9.1.0 HEX-V2 CB: 0.4437.4
    Data version: 20190205 DS296.0
    www.vcds.pl
    VIN: WVGAF25NXBW057272 Registration number:
    Mileage: 151620km Repair number:
    Chassis type: 5N-VW36 (7N0)
    Scanning: 01 02 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 56 62 72
    VIN: WVGAF25NXBW057272 Mileage: 151620km
    01-Engine - Condition: OK 0000
    02-Gearbox - Condition: OK 0000
    03-ABS / brakes - Condition: OK 0000
    04-Steering wheel angle - Status: OK 0000
    08-Air conditioning - Condition: OK 0000
    09-Power unit center - Condition: Fault 0010
    10-Assist. Park / guide. - Status: OK 0000
    15-Airbag - Condition: OK 0000
    16 -wheel steering wheel - Condition: OK 0000
    17-Set-ups - Status: OK 0000
    19-CAN Gateway - Status: Fault 0010
    22-4x4 / AWD - Condition: OK 0000
    25-Immobilizer - Condition: OK 0000
    42-Electric door. - Condition: OK 0000
    44-Steering assist - Condition: OK 0000
    46-Comfort module - Condition: OK 0000
    52-Electric door pas(?). - Status: OK 0000
    53-Parking brake - Condition: Fault 0010
    56-Radio - Status: Fault 0010
    62-Rear left door - Condition: OK 0000
    72-Rear right door - Condition: OK 0000
    Address 01: Engine (CCZ) Label file :. 06J-907-115-CCZ.clb
       Designation of the element SW: 06J 906 026 FL HW: 06J 906 026 DA
       Component: MED17.5 7330
       Verification: AAH18 --- Serial number:
       Coding: 04230010240F0160
       Service code: WSC 01324 020 00200
       VCID: 79ACE52C65D52F3FD93-802C
    No bugs found.
    Standby codes: 0000 0001
    Address 02: Gearbox (J217) Label file :. 0BH-927-711.clb
       Designation of the element SW: 0BH 300 011 E HW: 0BH 927 711 C
       Component: DSG DQ500-7A H04 1203
       Verification: 00H04V01
       Service code: WSC 00000,000 00000
       ASAM data set: EV_TCMDQ500021 001001
       ROD: EV_TCMDQ500021.rod
       VCID: 2412E458BE5782D7DA5-8070
    No bugs found.
    Address 03: ABS / brakes. Label file: 5N0-614-109-C4.clb
       Designation of the element SW: 5N0 614 109 P HW: 5N0 614 109 P
       Component: J104 C4 450 V1DB 0006
       Verification: - H28 --- Serial number: 00000003309320
       Coding: 0002372
       VCID: 382A20281E5FF63766D-806C
    No bugs found.
    Address 08: Air-conditioning (J301) Label file: | 3C8-907-336.clb
       Designation of the element SW: 3C8 907 336 AB HW: 3C8 907 336 AB
       Component: Climatic H14 0305
       Verification: 00009001
       Coding: 0000001002
       ASAM data set: EV_Climatic A01005
       ROD: EV_ClimaBasis_VW36.rod
       VCID: 6D84C17C2D1D839F45B-8038
    No bugs found.
    Address 09: Power unit center (J519) Label file :. ACP \ 1K0-937-08x-09.clb
       Designation of the element SW: 5K0 937 086 F HW: 5K0 937 086 F
       Component: BCM PQ35 M 011 0035
       Verification: BC011001
       Coding: 40180A3B80251AC0400800801000012443013088524D89605C8000000040
       VCID: 372823141F41F94F6F7-8062
       Subsystem 1 - Designation of the SW element: 5N1 955 119 HW: Label file: 1KX-955-119.CLB
       Component: Wischer 22101 012 0203
       Serial number: ?? N1955119 ∞203!
       Coding: 009795
    No bugs found.
    Address 10: Assist. Park / guide. (J446) Label file :. 3C8-919-475.clb
       Designation of the element SW: 5N0 919 475 B HW: 5N0 919 475
       Component: PARKHILFE 4K H07 0023
       Verification: -------- Serial number: 11131023104432
       Coding: 100102
       VCID: 382A2028125FF63766D-806C
    No bugs found.
    Address 15: Airbag. Label file: 5N0-959-655.lbl
       Designation of the element SW: 5N0 959 655 R HW: 5N0 959 655 R
       Component: J234__200 VW10 HI 1918
       Verification: 22014000 Serial number: 003K0PM8KZ15
       Coding: 0012336
       VCID: 4CC26CF87AC76A97325-8018
       Subsystem 1 - Serial number: 6332MTS607492840
       Subsystem 2 - Serial number: 6342MTS608102840
       Subsystem 3 - Serial number: 6351HTS63SCEF9KR
       Subsystem 4 - Serial number: 6361HTS6JIGEF9KJ
    No bugs found.
    Address 16: Steering wheel (J527) Label file: | 5K0-953-569.clb
       Designation of the element SW: 5K0 953 501 AQ HW: 5K0 953 569 F
       Component: LENKS.MODUL 009 0136
       Verification: FF010039 Serial number: 20101019300684
       Coding: 5980140000
       ASAM data set: EV_VW360SteerWheelUDS A03004
       VCID: 79ACE52C69552F3FD93-802C
    No bugs found.
    Address 17: Set-up (J285) Label file: | 5K0-920-xxx-17.clb-SRI1
       Designation of the element SW: 5N0 920 872 HW: 5N0 920 872
       Component: KOMBI H20 0420
       Coding: 110F00
       ASAM data set: EV_Kombi_UDS_VDD_RM09 A04089
       VCID: 6FB8DB742711718F777-803A
    No bugs found.
    Address 19: CAN Gateway. Label file :. ACP \ 7N0-907-530-V1.clb
       Designation of the element SW: 7N0 907 530 HW: 1K0 907 951
       Component: J533 Gateway H27 5603
       Verification: H27 Serial number: 171010F2001386
       Coding: FDA27F0600020200006002
       VCID: 6D84C17C219D839F45B-8038
    Found 1 error:
    01305 - Infotainment data bus
                004 - No signal / no communication
                 Frame frozen:
                        Error status: 01100100
                        Priority of error: 1
                        Frequency of error: 1
                        Int. Error counter: 184
                        Mileage: 146218 km
                        Time indicator: 0
                        Date: 2013.04.29
                        Time: 18:54:34
    Address 22: 4x4 / AWD Label file: 0AY-907-554-V1.clb
       Designation of item SW: 0AY 907 554 D HW: 0AY 907 554 D
       Component: Haldex 4Motion 0042
       Coding: 0000005
    No bugs found.
    Address 25: Immobilizer (J334) Label file: | 5K0-920-xxx-25.clb
       Designation of the element SW: 5K0 953 234 HW: 5K0 953 234
       Component: IMMO H20 0420
       ASAM data set: EV_Immo_UDS_VDD_RM09 A03008
       VCID: 6A8ECA601CF394A7209-803E
    No bugs found.
    Address 42: Electric door. Door label file :. ACP \ 1K0-959-701-MIN3.clb
       Designation of the element SW: 5N0 959 701 D HW: 5N0 959 701 D
       Component: Tuer-SG 009 2101
       Coding: 0000188
       VCID: 36362E10144B0047741-8062
    No bugs found.
    Address 44: Supporters Label file: 5N1-909-144.clb
       Designation of the element SW: 5N1 909 144 L HW: 5N1 909 148 G
       Component: J500__APA-BS KL.286 0802
       Verification: 1AH03831 Serial number: 00102840057701
       Coding: 0000258
       VCID: 3B203F242F69DD2F8BF-806E
    No bugs found.
    Address 52: Electr. door pas(?). Label file :. ACP \ 1K0-959-702-MIN3.clb
       Designation of the element SW: 5N0 959 702 D HW: 5N0 959 702 D
       Coding: 0000188
       VCID: 372823141341F94F6F7-8062
    No bugs found.
    Address 53: Parking brake Label file: 3AA-907-801.clb
       Designation of the element SW: 3AA 907 801 E HW: 3AA 907 801 E
       Component: J540 EPB4 VW-55183 0007
       Verification: H18 Serial number: 00000000010135
       Coding: 0023057
       VCID: 333017040739156F53F-8066
    Found 1 error:
    16353 - Driver - internal fault
                014 - defective - Occasional
                 Frame frozen:
                        Error status: 00101110
                        Internal error counter: 126
                        Mileage: 149304 km
                        Time indicator: 0
                        Date: 2013.08.07
                        Time: 19:07:04
                 Frame frozen:
                        Voltage: 12.10 V
                        Counting: 154
                        Hex value: 0x12F0
                        Hex value: 0x0081
                        Hex value: 0x0202
    Address 56: Radio
    Can not be achieved
    Address 62: Rear left door. Label file :. ACP \ 1K0-959-703-GEN3.clb
       Designation of the element SW: 5N0 959 703 D HW: 5N0 959 703 D
       Component: Tuer-SG 007 2102
       Coding: 0000144
       Service code: WSC 01324 020 1012552
    No bugs found.
    Address 72: Rear right door. Label file :. ACP \ 1K0-959-704-GEN3.clb
       Designation of the element SW: 5N0 959 704 D HW: 5N0 959 704 D
       Coding: 0000144
       VCID: 392C252C2555EF3F993-806C
    No bugs found.
    End (Durability scanning: 01:11, Battery voltage - at the beginning of the scan / at the end of the scan: 12.3V / 12.3V)
    Any help is much appreciated!
    Best,
    Blazej
    Admin Note: Please don't try to translate scans back to English; instead please use the standard English version to post data in this forum. You can download it from this page and it will happily coexist with the Polish translation you are currently using.
    New User
    May 2019
    Poland
    Thanks @UWE, noted. VCDS software I was using was my friend's courtesy, so I couldn't make any changes to his settings.
    Best,
    Blazej
  4. Likes Uwe liked this post
