Good evening,
I have replaced the ABS of a VW Caddy. I managed to get the original coding from the original module. I have coded that and it has been accepted. I have done the basic settings for all sensors etc but Im still getting the ABS and Traction control light on the dash. Here is the auto scan and module ID's just incase the coding of ABS is incorrect
Any help is greatly appreciated.
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 09 15 16 17 19 25 42 44 46 52 56 61
VIN: WV1ZZZ2KZCX105739 Mileage: 195990km-121782miles
Address 01: Engine (J623-CAYD) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PD HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 0870
Revision: --H43--- Serial number: 00000000000000
Coding: 00114010032501080000
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023PD 003003
ROD: EV_ECM16TDI02103L906023PB.rod
VCID: 77FD18EECED348F2EC-8022
7332 - Mass Air Flow Sensor (G70)
P0103 00 [032] - Signal too High
Mileage: 195981 km
Time: 00:00:00
Coolant temperature: 17 °C
Intake air temperature: 14 °C
Voltage terminal 30: 11.859 V
Engine speed: 0 /min
Battery voltage: 11.9 V
EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
Throttle_actuator_commanded_value-ANG_SP_THR[0]: 96.001 %
Air mass: specified value-MAF_SP_MMV: 239.95 mg/stroke
Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [100] - -
Fault Frequency: 45
Mileage: 195981 km
Date: 2019.05.07
Time: 00:00:00
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 12.1 V
10443 - Neutral Gear Sensor
P15A1 00 [096] - Implausible Signal
Mileage: 195315 km
Date: 2019.03.07
Time: 18:26:13
Engine speed: 1873.25 /min
Normed load value: 58.4 %
Vehicle speed: 61 km/h
Coolant temperature: 47 °C
Intake air temperature: 16 °C
Voltage terminal 30: 14.908 V
Unlearning counter according OBD: 12
Transmission neutral position sensor voltage-VP_NEUT_GEAR: 1.3525 V
Clutch Position Sensor-Starter control: clutch switch: 00000000
Neutral position sensor: current transmission angle-ANG_NEUT_GEAR: 20.001 °
Neutral position sensor: adapted transmission angle-ANG_NEUT_GEAR_AD_NEUT: -0.945 °
Engaged gear: calculated-DRI_MT_BAS: 3
Engine torque-TQI_SP: 159.88 Nm
Torque losses-TQ_LOSS: -26.41 Nm
10444 - Neutral Gear Sensor
Mileage: 195315 km
Date: 2019.03.07
Time: 18:25:17
Engine speed: 2058.50 /min
Normed load value: 84.7 %
Vehicle speed: 34 km/h
Coolant temperature: 36 °C
Voltage terminal 30: 14.795 V
Transmission neutral position sensor voltage-VP_NEUT_GEAR: 2.8369 V
Neutral position sensor: current transmission angle-ANG_NEUT_GEAR: 13.024 °
Engaged gear: calculated-DRI_MT_BAS: 2
Engine torque-TQI_SP: 237.03 Nm
Torque losses-TQ_LOSS: -30.25 Nm
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 433C400D092203FFC21202E79022C091310000
Shop #: WSC 00040 040 00001
VCID: 7BF504DEFAFB6C9288-802E
00003 - Control Module
Fault Status: 01100101
Reset counter: 43
Mileage: 195992 km
Date: 2013.09.29
Time: 03:35:06
Count: 3
Count: 29184
Count: 338
Count: 52480
Count: 1278
Reset counter: 43
Mileage: 195992 km
Date: 2013.09.29
Time: 03:35:06
Count: 3
Count: 29184
Count: 320
Count: 52480
Count: 1278
Part No SW: 5K0 937 085 R HW: 5K0 937 085 R
Component: BCM PQ35 B+ 021 0064
Revision: BB021001
Coding: 411A583A8025182A088000829000006403017288424F0160648087000041
Shop #: WSC 35110 377 08192
VCID: 428BB93ADD91DD5A8B-8016
Subsystem 1 - Part No: 1T2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer 03011 26 0512
Coding: 009795
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag02B H06 0013
Revision: -------- Serial number: 003HL009V4CB
Coding: 000000000000000000000000000000003242
VCID: 3561D2E6945F7AE23E-8060
Part No SW: 5K0 953 507 AT HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440KLN000VB
Coding: 1080160000
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 020B793A95111D5ACB-8056
Part No SW: 2K0 920 965 E HW: 2K0 920 965 E
Component: KOMBI H03 0606
Coding: 480201
VCID: 3169E6F6603756C262-8064
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 83
Mileage: 195991 km
Date: 2019.05.07
Time: 00:51:00
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 160112F1001091
Coding: 357401
VCID: 3B75C4DEBA7BAC92C8-806E
Component: IMMO H03 0606
VCID: 6ADB319A8D61E51A63-803E
Address 42: Door Elect, Driver Labels: 1K0-959-793.lbl
Part No: 1K0 959 793
Component: Tuersteuergeraet 74 0160
Coding: 0000000
VCID: 76E315EA01D931FAF7-8022
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 140 3305
Revision: 00H22000
VCID: 377DD8EE465388F22C-8062
Address 52: Door Elect, Pass. Labels: 1K0-959-792.lbl
Part No: 1K0 959 792
Component: Tuersteuergeraet 02 0160
Coding: 0000000
VCID: 75E112E61CDF3AE2FE-8020
Part No SW: 5K0 035 156 A HW: 5K0 035 156 A
Component: Radio H42 0105
Revision: R0000000 Serial number: VWZAZ1L2147315
Coding: 0500020001
VCID: 254102A62CFF0A628E-8070
00625 - Vehicle Speed Signal
Fault Status: 00110100
Reset counter: 83
Mileage: 195991 km
Date: 2013.09.27
Time: 00:50:56
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: 030F1859
VCID: 71E926F6A8B716C222-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900458494
End-------------------------(Elapsed Time: 01:53)--------------------------
433c400d092203ffc21202e79022c091310000
Thursday,09,May,2019,08:31:57:07692
VCDS Version: Release 18.9.1 (x64)
Control Module Part Number: 1K0 907 379 BJ
Component and/or Version: ESP MK60EC1 H31 0121
Software Coding: 433C400D092203FFC21202E79022C091310000
Work Shop Code: WSC 00040
Advanced Identification
Identification: TT1-012
Revision: 00H31001
Date: 23.09.11
Manufacturer number: 0304
Test stand number: 1462
Flash Status
Programming Attempts(application): 0
Successful Attempts(application): 0
Programming Status: 00000000
Flash Date: 2000.14.00
Flash Tool Code: 00000 000 00000
Misc.
Hardware number: 1K0 907 379 BJ
Workshop System Name: J104
VCDS Info:
Labels: 1K0-907-379-60EC1F.clb
Thursday,09,May,2019,08:32:33:07692
Address 01: Engine
Control Module Part Number: 03L 906 023 PD
Component and/or Version: 1,6l R4 CR td H43 0870
Software Coding: 00114010032501080000
Work Shop Code: WSC 35110
Advanced Identification/FAZIT
Identification: SJ8-FST
Revision: --H43---
Date: 14.01.12
Manufacturer number: 0011
Test stand number: 0029
Flash Status
Programming Attempts(application): 0/0/0
Successful Attempts(application): 0/0/0
Flash Date: 00.00.00
Misc.
Hardware number: 03L 907 425 C
Workshop System Name: J623
ASAM Dataset Revision: 003003
Car Info
Chassis Number: WV1ZZZ2KZCX105739
Engine code: CAYD
VCDS Info:
Labels: 03L-906-023-CAY.clb
Readiness: No script available
Thursday,09,May,2019,08:39:04:07692
Control Module Part Number: 5K0 953 234
Component and/or Version: IMMO H03 0606
Software Coding: 000000
Work Shop Code: WSC 00000
Identification: VDD-024
Date: 22.01.12
Manufacturer number: 1901
Test stand number: 3035
Flash Status
Software
OSEK-OS: 03.14.00
HiSpd Net: 01.12.01
Misc.
Hardware number: 5K0 953 234
Workshop System Name: J334
Equipment/PR Code: 2D2D2D2D2D2D2D2D
Dataset Number: -----------
Dataset Version: ----
End of Line Equipment Level: ------------------
ASAM Dataset Revision: A03009
Car Info
Immobilizer
Transponder ID (Current val.): E07C1075
Transponder ID 1: E0740051
Transponder ID 2: E07C1075
VCDS Info:
Labels: 5K0-920-xxx-25.clb
