- Joined
- Sep 5, 2016
- Messages
- 1,229
- Reaction score
- 1,311
- Location
- Riga, Latvia
- VCDS Serial number
- C?ID=268515
Glow plug light is flashing, CCS does not work, this is the only one DTC. After clearing it comes back after restarting ignition. Car is stock, without any modifications, how far I know. Any ideas what direction to dig, what parts or circuits to check etc are welcome.
Wednesday,08,May,2019,20:51:05:32442
VCDS Version: 18.9.1.0
VIN: WVWZZZ3CZEE138371 License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53 56
61 62 72
VIN: WVWZZZ3CZEE138371 Mileage: 105180km-65355miles
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 PR HW: 03L 907 309 AE
Component: R4 2.0l TDI H28 9979
Revision: 41H28--- Serial number: 00000000000000
Coding: 00190012042401080000
Shop #: WSC 33468 001 1048576
ASAM Dataset: EV_ECM20TDI01103L906018PR 003007
ROD: EV_ECM20TDI01103L906018PR.rod
VCID: 0919F71BA847F8028A-805C
2650 - Implausible Data Received from ABS Control Module
U0415 00 [167] - -
Mileage: 105186 km
Date: 2019.05.08
Time: 19:46:57
Coolant temperature: 35 °C
Intake air temperature: 16 °C
Voltage terminal 30: 12.280 V
Limitation: accelerator pedal: 126.7 Nm
Cruise Control System (CCS): status-Bits 0-7: 42
selected gear-Bits 0-7: 0
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AQ HW: 3AA 614 109 AQ
Component: J104 C2 450M VD07 0030
Revision: --H07--- Serial number: 00000008010088
Coding: 0003504
Shop #: WSC 05311 000 00001
VCID: 7CF79ECF3F95DDAA81-8028
Part No SW: 3AA 907 044 BQ HW: 3AA 907 044 BQ
Component: Climatronic H05 0505
Revision: 00001K02
Coding: 061400C803
Shop #: WSC 00015 115 00001
VCID: 000FEA3F9B7DB94ADD-8054
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 N HW: 3AA 937 087 N
Component: BCM PQ47 M 422 0475
Revision: BA422001
Coding: 0008000000000000009800805000006403010088424D85606480C7200041
VCID: 45813B2BCCDF5C62AE-8010
Subsystem 1 - Part No SW: 3AB 955 419 A HW: 3AB 955 419 A Labels: 1KX-955-119.CLB
Component: WWS471 100314 24 0654
Coding: 044D9D
Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
Part No SW: 3AE 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H06 0018
Revision: -------- Serial number: 28231410102213
Coding: 108002
ASAM Dataset: EV_EPHVA18VW47X0000 001006
ROD: EV_EPHVA18VW47X0000.rod
VCID: 3F8D29C3A60306B2E4-806A
Part No SW: 5N0 959 655 AA HW: 5N0 959 655 AA
Component: J234__107 VW10 HI 2518
Revision: 27019000 Serial number: 003L7P7HFXBA
Coding: 0012343
Subsystem 1 - Serial number: 6332MTS665490874
Subsystem 2 - Serial number: 6342MTS633710884
Subsystem 3 - Serial number: 6351HTS6O6RRQCKJ
Subsystem 4 - Serial number: 6361HTS6CH9TQCKJ
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 DB HW: 5K0 953 569 AT
Component: LENKS.MODUL 0140
Revision: FF010042 Serial number: 20140309100303
Coding: 5180250000
VCID: 6CD7AE8F87F54D2A11-8038
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 870 P HW: 3AA 920 870 P
Component: KOMBI H04 0811
Coding: 161F01
Shop #: WSC 05314 115 00001
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 060414F1003846
Coding: 462006
Shop #: WSC 05314 000 00001
VCID: 7BF59DD3FA9BDA9288-802E
Part No SW: 3AA 959 433 B HW: 3AA 959 433 B
Component: IMMO 043 0407
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 387F42DF4B2D318A25-806C
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7666074631
Coding: 020100
VCID: 2B556D934A7B8A1258-807E
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C8 035 279 F HW: 3C8 035 279 F
Component: RNS315-EU H77 0410
Serial number: VWZAZ2P0210389
Coding: 040004110400110000011301
ROD: EV_RNS315EUV2UDS.rod
VCID: 2E5364877169FF3A7F-807A
Component: EUR_W_V5 0055
Part No SW: 3AA 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0533
Revision: 13110009 Serial number: 0008315074
Coding: 0204B5
Shop #: WSC 05311 115 00001
VCID: 74E7B6EFDFC595EAC9-8020
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 005 0503
Serial number: 00000003930193
Coding: 010490
Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
Component: J500__APA-BS KL.309 1401
Revision: 1BH04739 Serial number: 00140940362101
Coding: 0000258
VCID: 41892F3B18F7704292-8014
Component: KSG PQ47 ELV 043 0645
Coding: 0291028052830E76340494157C084F0B605C00
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 00000008
VCID: 6FEDB983BEE3B63234-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Part No SW: 3AA 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0533
Revision: 15110009 Serial number: 0008404183
Coding: 0204B4
ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
VCID: 75E18BEBD4BF8CE2FE-8020
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 005 0503
Serial number: 00000003931649
Coding: 010490
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000002138466
Coding: 0022167
VCID: 36634CE74139C7FA37-8062
Part No SW: 7N0 907 534 HW: 7N0 907 530 AM
Component: Batt.regelung H55 1642
Coding: 030F1859
VCID: 71E9BFFBA8D7A0C222-8024
Component: J367-BDM H07 0180
Serial number: 31086L10061491996634
End-------------------------(Elapsed Time: 03:10)--------------------------
