Results 1 to 10 of 16
Thread: Disable Start/Stop system MQB
    Nov 2018
    Europe - Hungary
    Hello.
    I tried this script:
    StartVCDS()
    OpenUnit("19")
        TestComponent("GW MQB",1)
        TestAdpChannel("Start/stop start voltage limit","12.1", 1)
        ChangeAdpChannel("Start/stop start voltage limit", "12.1")
    CloseUnit()
    but not working.
    This is the error message:
    Desired value is not active in adaptation channel. Script is cancelled.
    Tartu, Estonia
    Because You're testing adp channel to have value 12.1. That it's not plausible.
    The world is my oyster...
    May 2014
    ^^^Golfi_vend: are you absolutely sure? I had understood that the maximum voltage for this adp channel was 12.1V - albeit it's not necessary to use the MAX value for this tweak (12V would be perfectly OK)
    Nov 2018
    Europe - Hungary
    I don't think this is the failure.
    If I try 12, 9, 8 the results are same.
    Tartu, Estonia
    Why then You don't change it manually and not with a script?
    Issue here is that Your script checks it to have a value 12.1 before even applying the 12.1 value.
    See it how it's wrong? - Check to have 12.1 then change to 12.1.
  6. Likes PetrolDave, Eric, Dana liked this post
    Jun 2017
    Correct!
    This line of code tests if the current value is already 12.1. If not, exit with an error.
  8. Likes Eric, Dana liked this post
    Nov 2018
    Europe - Hungary
    This would be a part of my script. I would like to set the all car to default and I would like to make another script with all possible coding.
    If I comment the Test line and run the script an alert window appears with questions (workshop code or something) and the script finishes with error (timeout)
  10. #8
    Jun 2017
    Quote Originally Posted by Amarton View Post
    Missing Workshop code is not covered by the logics of the scripter. Ouch!
    As this dialog window is not planned in the sequence, it exits.
  11. #9
    Jun 2017
    Stop. Now I get your point.
    You have to set the third parameter of TestAdpChannel to 0 instead of 1.
    0 means that the whole untit will be skipped if the condition isn't fullfilled instead of exiting with an error.
    But that doesn't solve the missing workshop code issue.
  12. Likes PetrolDave liked this post
  13. #10
    Jun 2014
    I did in my MK7 in gateway - Start Stop voltage limit ......from 12V to 7V and SS not work any longer
