Results 1 to 10 of 14
Thread: Euro switch and led taillight coding help
    May 2019
    Indiana, USA
    I've had my 2013 U.S. golf tdi for a couple months now and love it, I did Celis led tails a couple weeks ago with no coding and no issues, they have rear fog so I wanted to get it working, I got a euro switch and 2 trigger wires and got them installed, and swapped the wires in the black and brown plugs, I also have factory xenon headlights with drl's, I've done quite a bit of searching and thot coding would be mod. 9 byte 18 bit 04, but that didn't work for me, I've tried quite a few different things the past couple days so I can't remember them all and what things stopped working, but what I want is my drl's to work as they should and be off with headlights on, I'm pretty sure I'm running mod. 9 byte 18 bit 02 now, but my drl's are not working but the drl light is on on the dash like they are working, and I have bulb out errors, but the rear fog is working as it should as well as my headlights/fogs/taillights, there were a few bits I tried that would turn off my outer tails, what and how do I need to get/do to show my coding to you guys for help or who has some ideas to try? Or is it even possible for me to have what I want? Thanks in advance.
    Hi and welcome.
    Please post an Auto-Scan so people can see exactly how your car is equipped and configured.
    May 2019
    Indiana, USA
    Tuesday,07,May,2019,20:33:26:08324
    VIN: WVWMM7AJXDW098155   License Plate:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55 56
    VIN: WVWMM7AJXDW098155   Mileage: 60650km-37686miles
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 997 030 D    HW: 03L 907 309 AA
       Component: R4 2.0l TDI G000SG  9983
       Revision: 12H15---    Serial number:
       Coding: 0050072
       Shop #: WSC 74291 008 00000
       VCID: 2F3B12040B1F443F377-807A
    001612 - Glow Plug Control Module
                   P064C - 000 -  - Intermittent
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:10:14
                        Voltage: 7.52 V
                        Temperature: 8.1°C
                        Bin. Bits: 00010000
                        Time: 2.52 s
                        Temperature: 8.1°C
                   P064C - 001 -  - Intermittent
                        Fault Status: 00100001
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:10:14
                        Voltage: 7.52 V
                        Temperature: 8.1°C
                        Bin. Bits: 00010000
                        Time: 2.52 s
                        Temperature: 8.1°C
    Readiness: 0 0 0 X X
       Revision: 00H31001
       Coding: 114B400C492B0002880C02E9921E0042B70000
       VCID: 7DA7F84C9DF366AFF5B-8028
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:09:46
                        Count: 7
                        Count: 3
                        Count: 20992
                        Count: 128
                        Count: 25600
                        Count: 512
                        Reset counter: 3
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:03:26
                        Count: 3
                        Count: 3
                        Count: 4096
                        Count: 16390
                        Count: 31744
                        Count: 512
       Component: VWKESSYPQ35GP 086 1101
       Revision: 00086000    Serial number: 0186422223
       Coding: 030C0C
       ROD: EV_KESSYPQ35G_A02_VW36.rod
       VCID: 34311D68EEB967E74A5-8060
    65813 - Supply voltage
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:02:30
    1057547 - Antenna for Keyless Entry System; Interior Antenna 1
              B1172 13 [008] - Open Circuit
                        Reset counter: 1
                        Time: 00:00:00
       Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
       Component: AC Manuell    H20 0505
       Revision: 00001018
       Coding: 0010002002
       VCID: 7BA3F6548367689FCBF-802E
              U1111 00 [008] - -
              [Motorsteuergerät - kein Signal/Kommunikation]
                        Reset counter: 228
                        Mileage: 59261 km
                        Date: 2019.04.12
                        Time: 00:04:18
    13635840 - Supply voltage
              [Versorgungsspannung - unterer Grenzwert unterschritten]
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:00:38
       Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
       Component: BCM PQ35  M   111 0717
       Revision: AC111709
       Coding: 6F180ABA90272A04108800C170008D4448850286574D85B0E48400248040
       Shop #: WSC 12345 123 61029
       VCID: 41DF44BCA18BC24FD13-8014
       Component: Wischer 17091  26  0512
       Coding: 009795
    13 Faults Found:
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:03:26
                        Voltage: 8.90 V
                            Term 50 Off
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:03:26
                        Voltage: 8.90 V
                            Term 50 Off
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:09:42
                        Voltage: 8.00 V
                            Term 50 Off
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Fault Frequency: 25
                        Reset counter: 225
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:24:01
                        Voltage: 11.80 V
                            Term 50 Off
                        Fault Frequency: 15
                        Reset counter: 227
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:24:02
                        Voltage: 11.85 V
                            Term 50 Off
                        Fault Status: 00101010
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:29:56
                        Voltage: 7.30 V
                            Term 50 Off
    01800 - Light Switch (E1)
                        Reset counter: 2
                        Mileage: 60397 km
                        Date: 2019.05.03
                        Time: 22:01:38
                            Term 15 Off
                        Voltage: 11.85 V
                            Term 50 Off
                        Fault Frequency: 7
                        Reset counter: 227
                        Mileage: 60598 km
                        Date: 2019.05.06
                        Time: 16:54:29
                        Voltage: 13.80 V
                            Term 50 Off
                        Reset counter: 12
                        Mileage: 60598 km
                        Date: 2019.05.06
                        Time: 16:56:20
                        Voltage: 12.45 V
                            Term 50 Off
    01502 - Bulb for Rear Fog; Left (L46)
                        Reset counter: 10
                        Mileage: 60598 km
                        Date: 2019.05.06
                        Time: 16:58:48
                        Voltage: 11.95 V
                            Term 50 Off
    01506 - Bulb for Rear Fog; Right (L47)
                        Reset counter: 225
                        Mileage: 60598 km
                        Date: 2019.05.06
                        Time: 16:58:48
                        Voltage: 11.95 V
                            Term 50 Off
                        Reset counter: 227
                        Mileage: 60650 km
                        Date: 2019.05.07
                        Time: 20:27:46
                        Voltage: 12.20 V
                            Term 50 Off
                        Reset counter: 227
                        Mileage: 60650 km
                        Date: 2019.05.07
                        Time: 20:27:47
                        Voltage: 12.20 V
                            Term 50 Off
       Part No SW: 5C0 959 655 M    HW: 5C0 959 655 M
       Component: AirbagVW10G   014 0726
       Serial number: 003L4R00SNXA
       Coding: 00004737
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3C213548C6E9AFA7825-8068
       Serial number: ---0000R--000050RV00
       Serial number: 3572MSME74215074ZZZN
       Serial number: 3582MSME41655474ZZZU
       Serial number: 3512QSME56092119ZZZO
       Serial number: 3522QSME74562072ZZZP
       Serial number: 35527SME5D014C2EZZZR
       Serial number: 35627SME2C064C2EZZZT
              [Powersupply  lower threshold fall short of]
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:03:35
    9483264 - Seat Occupied Recognition
              B10B4 00 [008] - Function Restriction due to Undervoltage
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:02:51
       Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
       Revision: FF010041    Serial number: 20120921300078
       Coding: 100A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DA7F84C9D7366AFF5B-8028
       Coding: E20000
    114178 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:09:42
       Part No SW: 5K0 920 973 C    HW: 5K0 920 973 C
       Coding: 270F01
       VCID: 313F147C11AB52CF213-8064
              [Supply voltage too low]
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:02:39
       Part No SW: 7N0 907 530 AB    HW: 7N0 907 530 AB
       Component: J533  Gateway H47 1633
       Revision:   H47       Serial number: 030912F2000927
       Coding: 350000
       VCID: 70B9D178DAA11BC76ED-8024
       Coding: 000007
       VCID: 6A8DC310FCFDE117209-803E
       Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
       Component: ELV-PQ35      H20 0240
       Revision: 00000000    Serial number: 12000220108001
       Coding: 4100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2F3B1204079F443F377-807A
              [Under voltage (continued)]
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:03:05
                        ELV State: 04
                        Information Clamps: 77 60
                        CoCo State: B0 01
                        WFS State: 00 1A
                        Vehicle speed: 0.00 km/h
                        Voltage: 4A
              U1400 00 [008] - -
              [Under voltage (temporary)]
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:00:02
                        ELV State: 04
                        CoCo State: B0 01
                        WFS State: 00 1A
                        Voltage: 49
       Component: SG EXT.PLAYER H18 0546
       Revision: A1001003    Serial number: 7663483778
       Coding: 020100
       VCID: 2A0D03103CFD2117E09-807E
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:02:45
    00532 - Supply Voltage B+
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:04:42
       Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
       Component: RNS315-NAR    H55 0319
       Serial number: VWZAZ2M4285667
       Coding: 04050001010005000000100A
       ROD: EV_RNS315NARV2UDS_VW32.rod
       VCID: 2517F02C55630E6FCDB-8070
    1048580 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [restriction due to undervoltage]
                        Reset counter: 1
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:02:47
              B11CF 53 [009] - Deactivated
                        Reset counter: 216
                        Mileage: 60371 km
                        Date: 2019.05.01
                        Time: 00:18:47
       Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
       Component: Tuer-SG         009 2103
       Coding: 0001076
       VCID: 372B2A64F34F8CFF6F7-8062
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 70     3305
       Revision: 00H22000
                        Reset counter: 228
                        Mileage: 59261 km
                        Date: 2019.04.12
                        Time: 00:04:17
                        Voltage: 13.25 V
                            DU
                        Temperature: 21.0°C
                        RPM: 1498 /min
                        Fault Status: 00101101
                        Reset counter: 248
                        Mileage: 60177 km
                        Date: 2019.04.25
                        Time: 17:08:56
                        Voltage: 11.63 V
                            DD
                        Temperature: 15.0°C
       Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
       Component: KonzernAmp 8K H07 0368
       Revision: --------    Serial number: EAA085A0043225
       VCID: 290FFC1C397B2A0FE93-807C
       Component: Tuer-SG         009 2117
       Coding: 0001076
       VCID: 323D1B70182D69D7589-8066
       Coding: 1446940
       VCID: 34311D68E23967E74A5-8060
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Coding: 00000022
    End----------(Elapsed Time: 01:10, VBatt start/end: 12.2V/12.2V)-----------
    May 2019
    Indiana, USA
    I've tried 04, 43,15,33,44, all either had my outer tails not working or some other undesired effect, I did just try 3F and it had my DRL's and all parking lights and tails working, but in the switch off position. rear fog was also working as it should. but I just want my DRL's to work all by themselves with no other lights as they did before the euro switch, I would rather have them off when the headlights are on, but either way is fine.
    OP is now Verified; moving to Retrofits.
    May 2019
    Indiana, USA
    So anyone have any ideas?!!!!!!
  7. #7
    May 2019
    Indiana, USA
    So if nobody can help me with coding, can you help with wiring? I feel like one way had everything working except one of my drl lights out, pass side maybe, could I put the wires together to get both working?
  8. #8
    May 2019
    Indiana, USA
    Hello?!!!! Is anybody there?!!!!
  9. #9
    Many people are here, but it seems nobody with experience of your problem is online at present.
    Please be patient, someone will come along...
  10. Likes Uwe liked this post
  11. #10
    May 2019
    Indiana, USA
    Does anyone know if it would hurt anything to try all the codes listed to see what happens? I can always code back to what's somewhat working.
