The attached has a faulty MAF.
I've ordered a new one.
When fitting do the adaptations have to be cleared similar to what you do with BMW?
Tuesday,07,May,2019,11:07:31:34893
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUZZZ4LXED016144 License Plate: GF63 ZPK
Mileage: 175560km-109087mi Repair Order:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 10 15 16 17 18 19 34 3D 42 46 47 4F 52 55
56 5F 62 6C 6D 6F 72
VIN: WAUZZZ4LXED016144 Mileage: 175560km-109087miles
3D-Special Function -- Status: Malfunction 0010
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 4L2 910 401 B HW: 4L0 907 401 C
Component: 3.0TDI EDC17 H41 0003
Revision: 53H41--- Serial number:
Coding: 2A2A4012A52701020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L2910401B 001003
ROD: EV_ECM30TDI0114L1910401H.rod
VCID: 2313EDB52B5D7CCFA3F-8076
4795 - Mass Air Flow Sensor (G70)
P0101 00 [237] - Implausible Signal
Mileage: 175455 km
Date: 2019.05.05
Time: 19:03:00
Engine speed: 1444.00 /min
Vehicle speed: 73 km/h
Coolant temperature: 89 °C
Intake air temperature: 18 °C
Voltage terminal 30: 14.540 V
Mean injection quantity: 0.00 mg/stroke
Control Module temperature: 31.8 °C
EGR_governor_deviation: -56.0 mg/stroke
Inj Ctl q Curr: 0.00 mg/stroke
Mass_air_flow_sensor_drift: 0.6906
Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 159.2 kg/h
Actual charge pressure: 1131 hPa
10065 - Mass Air Flow Sensor (G70)
P0104 00 [175] - Intermittent
Fault Frequency: 23
Mileage: 175434 km
Date: 2019.05.05
Time: 18:34:26
Engine speed: 3006.00 /min
Normed load value: 80.8 %
Vehicle speed: 87 km/h
Voltage terminal 30: 14.440 V
Mean injection quantity: 38.25 mg/stroke
Control Module temperature: 28.5 °C
EGR_governor_deviation: 524.0 mg/stroke
Inj Ctl q Curr: 29.69 mg/stroke
Mass_air_flow_sensor_drift: 1.5468
Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 474.2 kg/h
Actual charge pressure: 2337 hPa
Readiness: 1 2 0 0 0
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AL HW: 0C8 927 750 AL
Component: AL1000 AISIN 002 2447
Coding: 001578
Shop #: WSC 38524 002 1048576
ROD: EV_TCMAL991031_002.rod
VCID: 76B5E4E1C84FB967B41-8022
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 2200689
VCID: 34311EE99233EB774A5-8060
Reset counter: 73
Mileage: 171541 km
Date: 2018.11.29
Time: 20:03:07
Count: 2117
Count: 128
Count: 29696
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0200
Revision: 00H08000 Serial number: 10603702085846
Coding: 0000211
VCID: 2517F3AD29E982FFCDB-8070
Subsystem 1 - Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H04 0020
Component: FBSAUDIC6 IDG H01 0054
Fault Frequency: 7
Reset counter: 73
Mileage: 171541 km
Date: 2018.11.29
Time: 20:19:54
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AP
Revision: 00---031 Serial number: 00000030304348
Coding: 01009416
VCID: 2517F3AD25E982FFCDB-8070
Reset counter: 73
Mileage: 171541 km
Date: 2018.11.29
Time: 20:03:36
Voltage: 11.10 V
Part No SW: 4F0 910 279 AH HW: 4F0 907 279 D
Component: ILM Fahrer H31 0400
Coding: 0033121
VCID: 6FBBD185BB9588AF777-803A
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H13 0110
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 10: Park/Steer Assist (J446) Labels:| 4L0-919-475-7X2.clb
Part No SW: 4L0 919 475 A HW: 4H0 919 475 C
Component: PARKHILFE 8K H07 0011
Revision: 11001001 Serial number: 55931327101317
Coding: 24031F
ASAM Dataset: EV_EPHVA18AU7160000 001001
ROD: EV_EPHVA18AU7160000.rod
VCID: 34311EE99EB3EB774A5-8060
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
Reset counter: 73
Mileage: 171541 km
Date: 2018.11.29
Time: 20:19:35
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH44 0230
Revision: 05H44000 Serial number: 00399D0D0LSA
Coding: 0014129
VCID: 2E050C817C1FC1A73C1-807A
Subsystem 1 - Serial number: 6332QSME1841045A8
Subsystem 2 - Serial number: 6342QSME5E413462F
Subsystem 3 - Serial number: 6352QSME5E412F66U
Subsystem 4 - Serial number: 6362QSME37373760E
Subsystem 5 - Serial number: 63734SME70364768%
Subsystem 6 - Serial number: 63834SME76360D420
Part No SW: 4F0 910 549 B HW: 4F0 953 549 E
Component: J0527 0830
Revision: 00H09000 Serial number: 90026131880316
Coding: 0102142
VCID: 2809FA995EFB9F97F6D-807C
Component: E0221 H03 0040
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 985 N HW: 4L0 920 985 N
Component: KOMBIINSTR. H35 0332
Revision: 00000000 Serial number: X2P22V1AE
Coding: 3356630400012600010404
VCID: 3FDB41C5A775382FA77-806A
Reset counter: 73
Mileage: 171541 km
Date: 2018.12.08
Time: 12:46:14
01310 - Level Control System Control Module (J197)
Reset counter: 73
Mileage: 171541 km
Date: 2018.12.08
Time: 12:46:14
Address 18: Aux. Heat Labels: None
Part No SW: 4L0 910 105 HW: 4L0 815 071 H
Component: Heizgeraet H10 0140
Revision: 0000000A Serial number: 00000009024928
Coding: 0000101
VCID: 6099A2B9764B27D7FED-8034
01444 - Under-Voltage Shut-Off (Automatic)
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 R HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0058
Revision: LB600036 Serial number: 3600L139080174
Coding: 00CF07
VCID: 3E253CC1A07F3127AC1-806A
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 40262629184121094153
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 13267002761021200181
Fault Status: 00101011
Fault Frequency: 23
Reset counter: 108
Mileage: 169133 km
Date: 2018.10.09
Time: 23:50:59
Bin. Bits: 11111
Voltage: 13.50 V
Count: 7
Bin. Bits: 10011
Fault Frequency: 13
Reset counter: 106
Mileage: 171541 km
Date: 2018.11.29
Time: 18:03:38
Bin. Bits: 10000
Voltage: 11.40 V
Count: 8
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 L HW: 4L0 907 553 E
Component: LUFTFDR.-CDC H04 7890
Revision: --H04001 Serial number: 15.1528-0194.2
Coding: 0015510
VCID: 33331DF5973DEC4F53F-8066
01577 - Turn-Off due to Over-Temp
Fault Status: 00100001
Reset counter: 88
Mileage: 169137 km
Date: 2018.10.18
Time: 22:54:20
Error Code: 68
Reset counter: 73
Mileage: 171541 km
Date: 2018.11.29
Time: 20:21:13
Error Code: 13
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 HW: 8K0 907 440
Component: STS H04 0040
Revision: S0H04000 Serial number: 00000000087199
Coding: 01010101000000000001000202
VCID: 6B83C5958F8D748F5BF-803E
Fault Status: 00101101
Reset counter: 73
Mileage: 171541 km
Date: 2018.11.29
Time: 20:15:34
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0362
Revision: Serial number: 0000076726036
Coding: 011F06205061440004
VCID: 48C95A19F2BB7F9716D-801C
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 K HW: 4L0 907 289 K
Component: Komfortgeraet H12 0130
Revision: 0130 --- Serial number: 01937586190000
Coding: 4071931
VCID: 38292AD98E5B0F1766D-806C
Part No SW: 4L0 035 223 J HW: 4L0 035 223 G
Component: BOSE G3 Q7 H04 0160
Revision: CH004001 Serial number: 00000000019393
Coding: 030000
VCID: 290FFF9D49F1A69FE93-807C
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H16 0100
Revision: Serial number: 00000000337803
Coding: 0011101
VCID: 5EE59C414C3F1127CC1-800A
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0362
Revision: Serial number: 0000077197234
VCID: 47CB5925FFA570EF1F7-8012
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Serial number: 130927-0004-045
Coding: 11476F1010000500
ROD: EV_HeadlRegulBasic.rod
VCID: 42DD4831D40755C7C89-8016
Part No SW: 4G0 035 061 L HW: 4G0 035 061
Component: Radio U DAB H60 0133
Revision: AB001007 Serial number: 109I$0D7708900
Coding: 010103010000000000
VCID: 2615F4A158EF89E7C41-8072
Part No SW: 4L2 035 670 H HW: 4L2 035 670 D
Component: H-BNT-EU H46 0739
Revision: -------- Serial number: 220IY0D7516670
Coding: 180101060004D3EF010003556F632003040000000100000000
VCID: 2F3B11857715C8AF377-807A
Subsystem 1 - Part No: 8R0 060 884 BC
Component: EUR 2013/2014 1603
Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
Component: DU7 High H42 0104
Serial number: A130I-0D2837239
Subsystem 3 - Part No SW: 4L0 919 614 B HW: 4L0 919 614 B
Component: E0380 Bedient H01 0060
Serial number: 00000002134870
Component: CD-Database 5298
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0362
Revision: Serial number: 0000077199569
Coding: 010E06204061230004
VCID: 46D55421F8AF69E7E41-8012
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H08--- Serial number: 525PA8-J3940KC
Coding: 1021001
00532 - Supply Voltage B+
Reset counter: 73
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H57 0500
Revision: --H57001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C81C6898A8373B7525-8038
Subsystem 2 - Serial number: .
ó
Subsystem 3 - Serial number: RD20.09.13--H57001002G0024ÿ
Subsystem 4 - Serial number: 2G0024ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H08 0080
Revision: AAH08080 Serial number: 0077012845----
Coding: 0003587
VCID: 2615F4A154EF89E7C41-8072
Component: J_245_EE16_SKB10H14 0220
Component: J_394_EE16_SKB10H14 0220
Component: J_392_EE16_SKB10H14 0220
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0362
Revision: Serial number: 0000077199659
End----------(Elapsed Time: 02:12, VBatt start/end: 14.0V/14.8V)-----------
Address 17,4L0 920 985 N,recoded (Long Coding),from,3356630400012600010404,to,2356630400012600010404,(31414/790/00001),
Address 01: DTCs cleared
Address 18: DTCs cleared
Gateway Installation List: 4F0 907 468 R
3D-Special Function -- Status: OK 0000
