Results 1 to 10 of 10
Thread: HEX-NET Issue Changing Adaptation
    Jan 2018
    I am getting this message when inputting 0 as a value. Note that 0 is a valid and in my case the default value from factory:
    Auto-scan and Channel 09 Admap available in the Retrofit thread I started here: https://forums.ross-tech.com/showthr...ght-Check-Bulb
    EDIT:
    I have now updated to VCDS Beta 19.4.0
    HEX-NET firmware updated to:
    CB: 04504
    FW: 0.256
    CFB: 0.10
    BL: 0.28
    DS: 60000057
  2. Likes jyoung8607 liked this post
  3. #2
    Just enter 00 for now. I'll see why VCDS is complaining about needing the totality of the channel size (16 bytes) instead of just the required user input (1 byte).
  4. Likes Chimuel liked this post
  5. #3
    Fixed the error message in source.
  6. Likes jyoung8607, Chimuel liked this post
  7. #4
    Jan 2018
    Thanks for the quick response --is 00 the same as 0 for the CECM? The reason I am setting 0 is to disable the fog light bulb check warning/error checking by setting that adaptation channel to 0 (as recommended by DV52 in my Retrofits thread).
    I set it to 00 but I still get the notification pop up on my instrument cluster and in the infotainment car status screen.
  8. #5
    Can't speak to what 0/00 is supposed to do inside the CECM firmware, but since it's a numeric, they're both the same as far as the CECM is concerned. VCDS is just being extra-cautious validating your input: it wants to see a double "digit" number even if it's less than 10.
  9. #6
    Jan 2018
    Are there plans to fix this so that it can accept a single 0?
  10. #7
    May 2014
    Quote Originally Posted by Chimuel View Post
    hmm......... odd indeed. As I have said, I was able to stop lamp monitoring on individual Leuchte-sets by changing the "DTC-DFCC" channel setting on my test-bench.
    Last suggestion is to also turn-off the Lampendefektbitposition channel (again, by setting the value to "0" ) in each of the Leuchte-sets. Perhaps Uw's point about different firmware versions in our two hex09 modules enforces this additional requirement for your BCM- long shot, I admit
  11. #8
    Jan 2018
    Last suggestion is to also turn-off the channel (again, by setting the value to "0" ) in each of the Leuchte-sets. Perhaps Uw's point about different firmware versions in our two hex09 modules enforces this additional requirement for your BCM- long shot, I admit
    No luck with that one... I now have:
    IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren > in Betrieb lassen
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 > 00
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 > 00
    Lampendefektbitposition (both LB45 and RB5) > 00
    Maybe in the CECM 00 =/= 0?
  12. #9
    Ugh, no. Again, we're not sending text, we're sending numbers. The CECM has no interest in how you as a human choose to represent that number.
  13. Likes Uwe, Zenerdiode, Chimuel liked this post
  14. #10
    Jan 2018
    Thanks. In my work, programming large scale energy SCADA systems, a 00 and a 0 do not represent the same thing which is why I kept going down that thought process.
    I appreciate the responses! --cheers
