Results 1 to 4 of 4
Thread: 07 Jetta ABS Module No Communication
    New User
    May 2019
    VA, USA
    2007 VW Jetta 2.5L
    Issue:
    Car has the following dash board lights on and the speedometer and odometer are not functional.
    * ABS
    * Flashing Brake Light
    * EPC
    * Power Steering
    * Check Engine
    Backstory: Vehicle registration expired so I had stopped driving the car until I could sort out the paperwork; about 2-months. During that time I had to start and move the car multiple times, but never gave the battery a chance to re-charge. The vehicle began to have trouble starting so I put an automatic trickle charger on the battery (while in the car). Once the battery was charged I began to experience these issues.
    Trouble shooting performed:
    * Battery tested at Advance Autoparts, CCA were within range
    * Battery voltage at terminal, not running: ~12.5
    * Battery voltage at terminal, running: ~14.5
    * All fuses inspected in engine bay.
    * All fuses inspected in left dash.
    I read through this post on TDIClub with someone who had similar issues. I am assuming that the ABS module is bad on my car. I wanted to try to confirm this before starting to replace parts; or get pointed in the correct direction for troubleshooting.
    I also have an older scan of the vehicle when even-thing was functional if necessary. Any help would be great, thanks in advance.
    -Ryan
    VCDS Auto-Scan:
    Wednesday,01,May,2019,19:53:42:34904
    VCDS Version: 18.9.1.0 (x64)
    VIN: 3VWGF71K27M141386   License Plate:
    Mileage: 243440km-151266mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
    VIN: 3VWGF71K27M141386   Mileage: 243440km-151266miles
    03-ABS Brakes -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Sporadic communication error 1000
    Address 01: Engine        Labels: 06A-906-032-BGP.lbl
       Part No SW: 07K 906 032 S    HW: 07K 906 032 Q
       Component: 2.5l R5/4V      G   9652
       Revision: --H01---    Serial number: VWZ7Z0G9034731
       Coding: 0000003
       VCID: 39796EC970D1CA82DA-806C
    049441 - No Communication with ABS Brake Control Module
                   U0121 - 008 -
                        Mileage: 243448 km
                        Temperature: 18.0°C
                        Temperature: 20.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 12.192 V
                   U0121 - 008 -
                        Mileage: 243448 km
                        Temperature: 18.0°C
                        Temperature: 20.0°C
                        Voltage: 12.192 V
                   U0121 - 008 -
                        Fault Frequency: 22
                        Mileage: 243448 km
                        RPM: 1696 /min
                        Load: 40.4 %
                        Temperature: 18.0°C
                        Temperature: 20.0°C
                        Voltage: 11.557 V
    001281 - Vehicle Speed Sensor
                   P0501 - 002 - Implausible Signal - MIL ON
                        Fault Status: 11100010
                        Mileage: 243449 km
                        Time: 06:59:02
                        RPM: 1279 /min
                        Load: 16.5 %
                        Temperature: 86.0°C
                        Temperature: 36.0°C
                        Voltage: 14.351 V
    Readiness: 0000 1100
       Part No SW: 09G 927 750 FL    HW: 09G 927 750 FL
       Component: AQ 250 6F           0920
       Revision: 00H69000    Serial number:
       Coding: 0000072
       VCID: 000FC32D538B5B4ADD-8054
    Address 03: ABS Brakes
       Part No: 1K0 820 047 GR
       Component: Climatic PQ35   120 0606
       VCID: 7AFBB1C53557019A93-802E
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
       Component: Bordnetz-SG     H52 2002
       Revision: 00H52000    Serial number: 00000000565573
       Coding: 14050E234004150007140000001400000008730B5C0000
       VCID: 6BD584814A0DA81218-803E
       Component: Wischer 260207 020  0501
       Coding: 00038805
    6 Faults Found:
    01259 - Fuel Pump Relay (J17)
                        Fault Status: 00101001
                        Reset counter: 36
                        Mileage: 243449 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.40 V
    00906 - Horn (H1)
                        Reset counter: 36
                        Mileage: 243449 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.35 V
    00834 - Signal for Activation of Heated Rear Window
                        Reset counter: 36
                        Mileage: 243449 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.40 V
                        Reset counter: 26
                        Mileage: 243338 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.35 V
    00059 - Terminal 30 for Interior Lighting
                        Fault Status: 00101100
                        Reset counter: 36
                        Mileage: 243449 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.45 V
    00926 - Terminal 30
                        Fault Status: 00101011
                        Reset counter: 36
                        Mileage: 243449 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 5.00 V
       Revision: 05034000    Serial number: 003B6M013GDW
       Coding: 0013889
       VCID: 6CD7879D4F03AF2A11-8038
       Subsystem 2 - Serial number: 6332MSME150D0207%
       Subsystem 3 - Serial number: 6342MSME154E00376
       Subsystem 4 - Serial number: 6351HSME0C46334FE
       Subsystem 5 - Serial number: 6361HSME0C37043B8
       Subsystem 6 - Serial number: 63727SME0B404A31-
       Subsystem 7 - Serial number: 63827SME0B404266.
       Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
       Component: Lenksäulenmodul 036 0070
       Coding: 0010021
       Part No SW: 1K0 920 953 P    HW: 1K0 920 953 P
       Component: KOMBIINSTRUMENT 3HL 1610
       Revision: V0003000    Serial number: VWZ7Z0G9034731
       Coding: 0023207
       Shop #: WSC 09412 444 67060
       VCID: 387F6BCD4BDBD38A25-806C
                        Fault Frequency: 9
                        Reset counter: 251
                        Mileage: 243448 km
                        Time: 19:29:06
       Part No SW: 1K0 907 530 K    HW: 1K0 907 951
       Component: J533__Gateway   H04 0021
       Revision:   H04 02    Serial number: 140207F1001225
       Coding: 3FBF034007001002
       VCID: 2F6D5091BE95143274-807A
                        Reset counter: 246
                        Mileage: 243448 km
                        Time: 19:29:07
                        Fault Status: 00110100
                        Reset counter: 35
                        Mileage: 243449 km
                        Time: 06:27:57
                        Reset counter: 25
                        Mileage: 243338 km
                        Time: 16:05:49
                        Reset counter: 251
                        Mileage: 131791 km
                        Time: 09:49:52
       Component: IMMO            3HL 1610
       Component: J386  TUER-SG FT    1133
       Revision: 32008001    Serial number: 00000554078130
       Coding: 0001205
       VCID: 3B7574C17AEDF892C8-806E
                        Fault Status: 01111000
                        Reset counter: 251
    00105 - Signal Central Locking SAVE/LOCK Drivers Side
                        Reset counter: 33
                        Mileage: 243449 km
       Part No: 1K1 909 144 L
       Component: EPS_ZFLS Kl.070 H07 1806
       VCID: 34675FFD57B337EA09-8060
    00625 - Vehicle Speed Signal
                        Mileage: 243440 km
                        Temperature: 18.0°C
                        Voltage: 10.80 V
                        Voltage: 10.60 V
       Component:    KSG PQ35 RDK 052 0218
       Coding: 13900F880186281B0904058FB0880F0488DCA0
       VCID: 0407CF3D4793476AF9-8050
                        Reset counter: 251
                        Mileage: 243449 km
                        Time: 06:49:54
       Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
       Component: J387  TUER-SG BT    1133
       Revision: 32008001    Serial number: 00000561578125
       Coding: 0001204
       VCID: 3C7777DD7FE3FFAAC1-8068
    Address 56: Radio
       Part No SW: 1K0 959 703 Q    HW: 1K0 959 795 J
       Component: J388   TUER-SG HL   1120
       Revision: 12006001    Serial number: 00000001120542
       Coding: 0001168
       VCID: 3E737DD569FFEDBAEF-806A
       Component:    RDK              0440
       Coding: 0100101
                        Reset counter: 31
                        Mileage: 242449 km
                        Time: 04:15:18
                        Reset counter: 251
                        Mileage: 243449 km
                        Time: 06:30:28
       Part No SW: 1K0 959 704 Q    HW: 1K0 959 794 J
       Component: J389   TUER-SG HR   1120
       Revision: 12006001    Serial number: 00000001170091
       Coding: 0001168
       VCID: 3F8D00D16EF5E4B2E4-806A
    Your ABS is clearly off-line; neither the car's Gateway nor VCDS can talk to it.
    To trouble-shoot this using a means other than just plugging in a different ABS, you're going to need wiring diagrams to check power(s), ground(s) and CAN bus connections at the ABS module's connector.
  3. Likes PetrolDave, DrPeter liked this post
    New User
    May 2019
    VA, USA
    Thanks for the direction forward!
    I borrowed a copy of the Bentley manual so I could test the connections on the harness, unfortunately it only had the pinout for the 47 pin connector and mine is the 26? pin connector. I compared the pictures of the two connectors and they are very similar. I was able to assume the power and ground were in the same location (larger blade style pins).
    I was able to verify I had power power and ground.
    I purchased a used abs module off of ebay and plugged it in. After clearing all the codes and re-testing, I am successfully able to talk to the abs module!
    I am still assuming that the trickle charger damaged the original ABS module.
    Now I have to tackle removing and installing the pump & module.
    Quote Originally Posted by kiefer_squared View Post
    I doubt that. The only mechanism I can think of for a charger to damage a module is with excessive voltage, but I'd expect to have seen some "voltage too high" codes in other modules if that happened.
  6. Likes PetrolDave liked this post
