2011 vw caddy ABS function test active
Winst
C?ID=224170
Hi Guys n Gals
A few weeks ago I was driving along and got the 3 brake lights on my instrument cluster (abs, handbrake & esp) after doing an auto scan it came up with
Monday,01,October,2018,16:32:41:28228
VCDS Version: 18.1.0.2
VIN: WV1ZZZ2KZCX031974   License Plate: RYLOMAK1/10/18
Mileage: 42760km-26569mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 09 15 16 17 19 25 2E 37 3D 42 44 46 52 56 6C 77
VIN: WV1ZZZ2KZCX031974   Mileage: 42760km-26569miles
2E-Media Player 3 -- Status: Cannot be reached 1100
3D-Special Function -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 1010
6C-Back-up Cam. -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 NF    HW: 03L 907 309 R
   Component: R4 2,0L EDC   H25 0660
   Revision: 42H25---    Serial number: 00000000000000
   Coding: 00190010042500080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906018NF 003001
   ROD: EV_ECM20TDI01103L906018NF_VN35.rod
   VCID: 7BF5D657F28B249DE0-802E
4714 - Steering Column Control Module
          U0212 00 [047] - No Communications
                    Mileage: 41555 km
                    Date: 2018.09.06
                    Time: 20:39:12
                    Coolant temperature: 80 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 12.400 V
                    Limitation: accelerator pedal: 126.6 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 200
                    selected gear-Bits 0-7: 0
4891 - EGR Valve (N18)
          P0403 00 [040] - Malfunction
                    Fault Frequency: 10
                    Mileage: 41555 km
                    Date: 2018.09.06
                    Time: 20:40:45
                    Engine speed: 811.50 /min
                    Normed load value: 35.3 %
                    Vehicle speed: 1 km/h
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 14.140 V
                    Unlearning counter according OBD: 28
                    Air mass: actual value (mg/stroke): 488.7 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 15.00 %
                    EGR Solen.val.: actual value: 94.95 %
                    EGR valve: offset closed: 1.25 %
                    Actuator for high pressure EGR: status-Bits 0-7: 0
                    Actuator for high pressure EGR: status-Bits 0-7: 55
                    Actuator for high pressure EGR: status-Bits 0-7: 7
                    Actuator for high pressure EGR: status-Bits 0-7: 4
                    High press EGR actuator: actual unconditioned volt val: 1114.2 mV
Readiness: 0 1 0 0 0
   Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
   Revision: 00H31001
   Coding: 433C400D092503FBC21402EB901DC082300000
   Shop #: WSC 35110 377 08192
   VCID: 79F9CC5FF0B7168DF2-802C
01276 - ABS Hydraulic Pump (V64)
                    Fault Status: 00101110
                    Reset counter: 199
                    Mileage: 42555 km
                    Date: 2018.10.01
                    Time: 02:35:37
                    Count: 7
                    Count: 4608
                    Count: 104
                    Count: 50433
                    Count: 65280
01130 - ABS Operation
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 199
                    Mileage: 42539 km
                    Date: 2018.10.01
                    Time: 02:12:27
                    Count: 32768
                    Count: 4608
                    Count: 100
                    Count: 50944
                    Count: 1
   Part No SW: 5K0 937 087 AC    HW: 5K0 937 087 AC
   Component: BCM PQ35 H+   122 0174
   Revision: BF122001
   Coding: 411A0A3AC025186A08480080950010E803F0740872210560E48400000048
   Shop #: WSC 19861 123 12345
   VCID: 76E3C763C1A979F59F-8022
   Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 19071  26  0512
   Coding: 009795
   Component: RLS 201211 05  54  0403
   Coding: 0750ED
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 198
                    Mileage: 42451 km
                    Date: 2018.09.30
                    Time: 23:41:43
                        Term 15 On
                    Voltage: 11.75 V
                    Reset counter: 198
                    Mileage: 42451 km
                    Date: 2018.09.30
                    Time: 23:33:34
                        Term 15 On
                    Voltage: 11.55 V
                    Reset counter: 198
                    Mileage: 42451 km
                    Date: 2018.09.30
                    Time: 23:33:34
                        Term 15 On
                    Voltage: 11.55 V
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag00U H06 0013
   Revision: --------    Serial number: 003HL006USR3
   Coding: 000000000000000000000000000000003055
   VCID: 3561006F942F32ED56-8060
9437211 - Igniter for Driver's Airbag
          B1000 1B [136] - Resistance Too High
                    Mileage: 42451 km
                    Date: 2018.09.30
                    Time: 23:44:50
   Part No SW: 5K0 953 507 BA    HW: 5K0 953 549 C
   Revision: --------    Serial number:  90849LGP0004F
   Coding: 1080040000
   Shop #: WSC 00004 123 12345
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 70EFF17BABCD57C545-8024
   Part No SW: 1T0 920 985 G    HW: 1T0 920 985 G
   Component: KOMBI         H03 0705
   Coding: 781800
   Shop #: WSC 01342 020 12345
   VCID: 3D71184FAC1FEAAD9E-8068
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 220711F1000133
   Coding: 357401
   VCID: 3561006F9C2F32ED56-8060
                    Fault Status: 00110100
                    Reset counter: 225
                    Mileage: 41580 km
                    Date: 2018.09.08
                    Time: 12:34:48
                    Fault Status: 01101011
                    Fault Frequency: 83
                    Reset counter: 199
                    Mileage: 41767 km
                    Date: 2018.09.09
                    Time: 22:23:26
                    Reset counter: 181
                    Mileage: 41531 km
                    Date: 2018.09.05
                    Time: 17:02:29
03272 - Control Module for Audio Interface
                    Reset counter: 181
                    Mileage: 41531 km
                    Date: 2018.09.05
                    Time: 17:02:29
   Component: IMMO          H03 0705
   VCID: 6ADBE3138D11AD150B-803E
Address 2E: Media Player 3
Address 37: Navigation
Address 3D: Special Function        Labels: None
   Part No SW: 1F9 909 919 A    HW: 1F9 909 919 A
   Component: MultifunctionDevice 0067
   Revision: 00H03000    Serial number: 00000000000134
   Coding: 198073
   Shop #: WSC 12345 123 12345
   VCID: 36630763412939F55F-8062
   Subsystem 1 - Part No: Unknown
   Component: Slave HW Part
02071 - Local Databus
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2110
   Coding: 0000626
   VCID: 489F799B3BDDBF053D-801C
01552 - Motor for Central Locking; Drivers Door (V56); Lock
00096 - Drivers Door Central Locking (Safe) Motor (V161)
01030 - Central Locking Key Switch; Driver Side; Lock
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 140    3201
   Revision: 00H20000
   VCID: 34673D6B57552BE561-8060
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000626
   VCID: 479D7AA736C3B07D34-8012
01553 - Motor for Central Locking; Passenger Door (V57); Lock
00097 - Front Passengers Central Locking (Safe) Motor (V162)
Address 56: Radio
Address 6C: Back-up Cam.
Address 77: Telephone
End-------------------------(Elapsed Time: 03:00)--------------------------
so I decided to change the ABS module for one ending in BJ, at first the new module wouldn't except my original code, so found out via a friend I had to knock off the basic settings after doing the coding and do a security login between each basic setting (40168) and its seems to have held the code, but in doing this I have activated function brake test and I cant seem to clear it/ complete it..... I followed the ESP function test but I cant seem to get a change in the warning lights as it suggests (no matter how hard I press the pedal) there's obviously something I'm doing wrong could anyone please point me in the right direction please?
here is yesterday's auto scan
Saturday,04,May,2019,16:31:43:28228
VCDS Version: 18.9.1.0
VIN: WV1ZZZ2KZCX031974   License Plate: RY10 MAK
Mileage: 43930km-27296mi   Repair Order:
Scan: 01 03 09 15 16 17 19 25 2E 37 3D 42 44 46 52 56 77
VIN: WV1ZZZ2KZCX031974   Mileage: 43930km-27296miles
   VCID: 7BF5D657F28B249288-802E
   Revision: 00H31001
   VCID: 7BF5D657FA8B249288-802E
            000 -  -
                    Reset counter: 229
                    Mileage: 43932 km
                    Date: 2019.05.04
                    Time: 16:27:15
                    Count: 3
                    Count: 29184
                    Count: 320
                    Count: 50432
                    Count: 1
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 229
                    Mileage: 43932 km
                    Date: 2019.05.04
                    Time: 16:27:15
                    Count: 3
                    Count: 29184
                    Count: 143
                    Count: 50432
                    Count: 1
   Revision: BF122001
   Coding: 411A0A3A8025186A08800082900009EC03950000526D0160E48400040040
   VCID: 76E3C763C1A979FAF7-8022
   Coding: 009795
                    Reset counter: 229
                    Mileage: 43932 km
                    Date: 2019.05.04
                    Time: 16:27:19
                        Term 15 On
                    Voltage: 13.90 V
   VCID: 3561006F942F32E23E-8060
   Coding: 1080040000
   VCID: 70EFF17BABCD57CA2D-8024
   Coding: 781800
   VCID: 3D71184FAC1FEAA2F6-8068
   Coding: 357401
   VCID: 3561006F9C2F32E23E-8060
                    Reset counter: 229
                    Mileage: 43932 km
                    Date: 2019.05.04
                    Time: 16:27:20
   VCID: 6ADBE3138D11AD1A63-803E
   Coding: 198073
   VCID: 36630763412939FA37-8062
   Subsystem 1 - Part No: 6C0 959 442 C
   Component: E221__MFL-DC1
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2113
   Coding: 0004726
   Shop #: WSC 12345 935 45725
   VCID: 326B3B73AD4125DA1B-8066
   Revision: 00H20000
   VCID: 34673D6B57552BEA09-8060
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Component: Tuer-SG         009 2121
   Coding: 0004720
   VCID: 489F799B3BDDBF0A55-801C
Address 56: Radio
End-------------------------(Elapsed Time: 02:14)--------------------------
Any help would be greatly appreciated
Thanks
Winst
C?ID=224170
Hi thanks for the reply, yes I did try that but I can’t seem to get confirmation with the warnings lights that I can begin the test (no matter how hard I press the pedal) just wondering if I’m doing something wrong.
Winst
C?ID=224170
Hi thanks very much for the link I will give that a go. Not done that yet.
Winst
C?ID=224170
little bit of an update on this, carried out the basic settings test and cleared any faults, after cycling the ignition the traction control light went off but left the ABS light on and as soon as I moved the van traction control light came back on, its coming up with a ABS wheel speed sensor fault which I'll change next, but its also still coming up with the function test active.
todays auto scan
Monday,13,May,2019,19:24:47:28228
Mileage: 43950km-27309mi   Repair Order:
Scan: 01 03 09 10 15 16 17 19 25 2E 37 3D 42 44 46 52 56 77
VIN: WV1ZZZ2KZCX031974   Mileage: 43950km-27309miles
10-Park/Steer Assist -- Status: Cannot be reached 1100
   Revision: 00H31001
            000 -  -
                    Reset counter: 232
                    Mileage: 43956 km
                    Date: 2019.05.13
                    Time: 19:20:18
                    Count: 3
                    Count: 20480
                    Count: 320
                    Count: 42496
                    Fault Status: 01101100
                    Reset counter: 232
                    Mileage: 43956 km
                    Date: 2019.05.13
                    Time: 19:20:18
                    Count: 3
                    Count: 20480
                    Count: 64
                    Count: 42496
   Revision: BF122001
   Coding: 009795
                    Reset counter: 232
                    Mileage: 43956 km
                    Date: 2019.05.13
                    Time: 19:20:23
                        Term 15 On
                    Voltage: 11.85 V
Address 10: Park/Steer Assist
   Coding: 1080040000
   Coding: 781800
12671232 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 232
                    Mileage: 43956 km
                    Date: 2019.05.13
                    Time: 19:20:18
   Coding: 357401
03075 - Parallel Parking Assistance Control Module (J791)
                    Reset counter: 232
                    Mileage: 43956 km
                    Date: 2019.05.13
                    Time: 19:20:19
                    Reset counter: 232
                    Mileage: 43956 km
                    Date: 2019.05.13
                    Time: 19:20:23
   Coding: 198073
   Coding: 0004726
   Revision: 00H20000
01316 - ABS Control Module
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 232
                    Mileage: 43956 km
                    Date: 2019.05.13
                    Time: 19:20:18
                    Voltage: 12.00 V
                        DD
                    Temperature: 25.0°C
   Coding: 0004720
Address 56: Radio
End-------------------------(Elapsed Time: 02:22)--------------------------
I don't think you'll ever get rid of the Function Test DTC until everything with the ABS is in working order.
Correct Uwe and he may need to start ADP over and done in 0x44 first before completion in 0x03
Winst
C?ID=224170
Thanks for the replies, I agree Uwe, I’ve had faulty wheel speed sensors on other cars in the past cause all kinds of problems, so I’ll get that changed next, got 1 on order.
Hi Jack, what is ADP please?
Dana
Western PA, USA
Absolutely agree on the wheel speed sensors. Do get that corrected before you struggle with the ESP function test.
Jack was referencing the G85 calibration. Although it should be completed in address 03-ABS brakes (because you have ESP) .. some cars don't play by the rules. When you have a stubborn one it can't hurt to calibrate G85 directly in address 44 first because that's where G85 is located on this Golf 6 based model. After doing it the alternative way, repeating the G85 procedure in address 03 may be successful.
Winst
C?ID=224170
Thanks for the reply Dana, wheel speed sensor is on route, will get that changed firstly, and I’ll calibrate g85 in address 44 and again in address 03, and hopefully it’ll get me back on track.
Winst
C?ID=224170
Just an update, fitted wheel speed sensor and completed the calibration test as per the last link, and down to 1 light (ABS),
went to the local rugby club car park, pressed brake pedal firmly and hey presto the ABS warning indication light started to flash, so carried out function test (took me a few tries) and ABS light went out, so thanks guys for all your help, seems to have done the trick, I’m replacing CAN tomorrow so hopefully that will go better����
