Results 1 to 10 of 12
Thread: 2011 vw caddy ABS function test active
    Feb 2015
    Hi Guys n Gals
    A few weeks ago I was driving along and got the 3 brake lights on my instrument cluster (abs, handbrake & esp) after doing an auto scan it came up with
    Monday,01,October,2018,16:32:41:28228
    VCDS Version: 18.1.0.2
    VIN: WV1ZZZ2KZCX031974   License Plate: RYLOMAK1/10/18
    Mileage: 42760km-26569mi   Repair Order:
    Chassis Type: 2K-VN35 (7N0)
    Scan: 01 03 09 15 16 17 19 25 2E 37 3D 42 44 46 52 56 6C 77
    VIN: WV1ZZZ2KZCX031974   Mileage: 42760km-26569miles
    2E-Media Player 3 -- Status: Cannot be reached 1100
    3D-Special Function -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 1010
    6C-Back-up Cam. -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 NF    HW: 03L 907 309 R
       Component: R4 2,0L EDC   H25 0660
       Revision: 42H25---    Serial number: 00000000000000
       Coding: 00190010042500080000
       Shop #: WSC 35110 790 50316
       ASAM Dataset: EV_ECM20TDI01103L906018NF 003001
       ROD: EV_ECM20TDI01103L906018NF_VN35.rod
       VCID: 7BF5D657F28B249DE0-802E
    4714 - Steering Column Control Module
              U0212 00 [047] - No Communications
                        Mileage: 41555 km
                        Date: 2018.09.06
                        Time: 20:39:12
                        Coolant temperature: 80 °C
                        Intake air temperature: 30 °C
                        Voltage terminal 30: 12.400 V
                        Limitation: accelerator pedal: 126.6 Nm
                        Cruise Control System (CCS): status-Bits 0-7: 200
                        selected gear-Bits 0-7: 0
    4891 - EGR Valve (N18)
              P0403 00 [040] - Malfunction
                        Fault Frequency: 10
                        Mileage: 41555 km
                        Date: 2018.09.06
                        Time: 20:40:45
                        Engine speed: 811.50 /min
                        Normed load value: 35.3 %
                        Vehicle speed: 1 km/h
                        Intake air temperature: 29 °C
                        Voltage terminal 30: 14.140 V
                        Unlearning counter according OBD: 28
                        Air mass: actual value (mg/stroke): 488.7 mg/stroke
                        EGR Vacuum Regulator Solen.val.: activation: 15.00 %
                        EGR Solen.val.: actual value: 94.95 %
                        EGR valve: offset closed: 1.25 %
                        Actuator for high pressure EGR: status-Bits 0-7: 0
                        Actuator for high pressure EGR: status-Bits 0-7: 55
                        Actuator for high pressure EGR: status-Bits 0-7: 7
                        Actuator for high pressure EGR: status-Bits 0-7: 4
                        High press EGR actuator: actual unconditioned volt val: 1114.2 mV
    Readiness: 0 1 0 0 0
       Part No SW: 1K0 907 379 BH    HW: 1K0 907 379 BH
       Revision: 00H31001
       Coding: 433C400D092503FBC21402EB901DC082300000
       Shop #: WSC 35110 377 08192
       VCID: 79F9CC5FF0B7168DF2-802C
                        Fault Status: 00101110
                        Reset counter: 199
                        Mileage: 42555 km
                        Date: 2018.10.01
                        Time: 02:35:37
                        Count: 7
                        Count: 4608
                        Count: 104
                        Count: 50433
                        Count: 65280
    01130 - ABS Operation
                        Reset counter: 199
                        Mileage: 42539 km
                        Date: 2018.10.01
                        Time: 02:12:27
                        Count: 32768
                        Count: 4608
                        Count: 100
                        Count: 50944
                        Count: 1
       Part No SW: 5K0 937 087 AC    HW: 5K0 937 087 AC
       Component: BCM PQ35 H+   122 0174
       Revision: BF122001
       Coding: 411A0A3AC025186A08480080950010E803F0740872210560E48400000048
       Shop #: WSC 19861 123 12345
       VCID: 76E3C763C1A979F59F-8022
       Subsystem 1 - Part No: 1T2 955 119 A  Labels: 1KX-955-119.CLB
       Component: Wischer 19071  26  0512
       Coding: 009795
       Component: RLS 201211 05  54  0403
       Coding: 0750ED
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 198
                        Mileage: 42451 km
                        Date: 2018.09.30
                        Time: 23:41:43
                        Voltage: 11.75 V
                        Reset counter: 198
                        Mileage: 42451 km
                        Date: 2018.09.30
                        Time: 23:33:34
                        Voltage: 11.55 V
                        Reset counter: 198
                        Mileage: 42451 km
                        Date: 2018.09.30
                        Time: 23:33:34
                        Voltage: 11.55 V
       Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
       Component: VW10Airbag00U H06 0013
       Revision: --------    Serial number: 003HL006USR3
       Coding: 000000000000000000000000000000003055
       VCID: 3561006F942F32ED56-8060
              B1000 1B [136] - Resistance Too High
                        Mileage: 42451 km
                        Date: 2018.09.30
                        Time: 23:44:50
       Part No SW: 5K0 953 507 BA    HW: 5K0 953 549 C
       Revision: --------    Serial number:  90849LGP0004F
       Coding: 1080040000
       Shop #: WSC 00004 123 12345
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 70EFF17BABCD57C545-8024
       Part No SW: 1T0 920 985 G    HW: 1T0 920 985 G
       Component: KOMBI         H03 0705
       Coding: 781800
       Shop #: WSC 01342 020 12345
       VCID: 3D71184FAC1FEAAD9E-8068
       Revision:   H42       Serial number: 220711F1000133
       Coding: 357401
       VCID: 3561006F9C2F32ED56-8060
                        Fault Status: 00110100
                        Reset counter: 225
                        Mileage: 41580 km
                        Date: 2018.09.08
                        Time: 12:34:48
    00469 - Infotainment Databus in Single Wire Operation
                        Fault Frequency: 83
                        Reset counter: 199
                        Mileage: 41767 km
                        Date: 2018.09.09
                        Time: 22:23:26
                        Reset counter: 181
                        Mileage: 41531 km
                        Date: 2018.09.05
                        Time: 17:02:29
    03272 - Control Module for Audio Interface
                        Reset counter: 181
                        Mileage: 41531 km
                        Date: 2018.09.05
                        Time: 17:02:29
       Component: IMMO          H03 0705
       VCID: 6ADBE3138D11AD150B-803E
    Address 2E: Media Player 3
    Address 37: Navigation
    Address 3D: Special Function        Labels: None
       Part No SW: 1F9 909 919 A    HW: 1F9 909 919 A
       Component: MultifunctionDevice 0067
       Revision: 00H03000    Serial number: 00000000000134
       Coding: 198073
       VCID: 36630763412939F55F-8062
       Subsystem 1 - Part No: Unknown
       Component: Slave HW Part
    02071 - Local Databus
       Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
       Component: Tuer-SG         009 2110
       Coding: 0000626
       VCID: 489F799B3BDDBF053D-801C
    00096 - Drivers Door Central Locking (Safe) Motor (V161)
    01030 - Central Locking Key Switch; Driver Side; Lock
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 140    3201
       Revision: 00H20000
       VCID: 34673D6B57552BE561-8060
       Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
       Coding: 0000626
       VCID: 479D7AA736C3B07D34-8012
    01553 - Motor for Central Locking; Passenger Door (V57); Lock
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
    Address 56: Radio
    Address 6C: Back-up Cam.
    Address 77: Telephone
    End-------------------------(Elapsed Time: 03:00)--------------------------
    so I decided to change the ABS module for one ending in BJ, at first the new module wouldn't except my original code, so found out via a friend I had to knock off the basic settings after doing the coding and do a security login between each basic setting (40168) and its seems to have held the code, but in doing this I have activated function brake test and I cant seem to clear it/ complete it..... I followed the ESP function test but I cant seem to get a change in the warning lights as it suggests (no matter how hard I press the pedal) there's obviously something I'm doing wrong could anyone please point me in the right direction please?
    here is yesterday's auto scan
    Saturday,04,May,2019,16:31:43:28228
    VCDS Version: 18.9.1.0
    VIN: WV1ZZZ2KZCX031974   License Plate: RY10 MAK
    Mileage: 43930km-27296mi   Repair Order:
    Scan: 01 03 09 15 16 17 19 25 2E 37 3D 42 44 46 52 56 77
    VIN: WV1ZZZ2KZCX031974   Mileage: 43930km-27296miles
       VCID: 7BF5D657F28B249288-802E
       Revision: 00H31001
       VCID: 7BF5D657FA8B249288-802E
                        Reset counter: 229
                        Mileage: 43932 km
                        Date: 2019.05.04
                        Time: 16:27:15
                        Count: 3
                        Count: 29184
                        Count: 320
                        Count: 50432
                        Count: 1
    00003 - Control Module
                        Fault Status: 01100101
                        Reset counter: 229
                        Mileage: 43932 km
                        Date: 2019.05.04
                        Time: 16:27:15
                        Count: 3
                        Count: 29184
                        Count: 143
                        Count: 50432
                        Count: 1
       Revision: BF122001
       Coding: 411A0A3A8025186A08800082900009EC03950000526D0160E48400040040
       VCID: 76E3C763C1A979FAF7-8022
       Coding: 009795
                        Reset counter: 229
                        Mileage: 43932 km
                        Date: 2019.05.04
                        Time: 16:27:19
                        Voltage: 13.90 V
       VCID: 3561006F942F32E23E-8060
       Coding: 1080040000
       VCID: 70EFF17BABCD57CA2D-8024
       Coding: 781800
       VCID: 3D71184FAC1FEAA2F6-8068
       Coding: 357401
       VCID: 3561006F9C2F32E23E-8060
                        Reset counter: 229
                        Mileage: 43932 km
                        Date: 2019.05.04
                        Time: 16:27:20
       VCID: 6ADBE3138D11AD1A63-803E
       Coding: 198073
       VCID: 36630763412939FA37-8062
       Subsystem 1 - Part No: 6C0 959 442 C
       Component: E221__MFL-DC1
       Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
       Component: Tuer-SG         009 2113
       Coding: 0004726
       Shop #: WSC 12345 935 45725
       VCID: 326B3B73AD4125DA1B-8066
       Revision: 00H20000
       VCID: 34673D6B57552BEA09-8060
       Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
       Component: Tuer-SG         009 2121
       Coding: 0004720
       VCID: 489F799B3BDDBF0A55-801C
    Address 56: Radio
    End-------------------------(Elapsed Time: 02:14)--------------------------
    Any help would be greatly appreciated
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    -Wolfgang
    Drive more talk less
  3. Likes Uwe, Dana liked this post
    Feb 2015
    Hi thanks for the reply, yes I did try that but I can’t seem to get confirmation with the warnings lights that I can begin the test (no matter how hard I press the pedal) just wondering if I’m doing something wrong.
  5. Likes Dana liked this post
  6. #4
    Sep 2014
    Hello
    And what's about this?
    https://www.youtube.com/watch?v=b6lm9OmC2so
    Basic Setting for Hydraulic Unit Intake Valves and Basic Setting for Hydraulic Unit Disconnecting Valves
    -Wolfgang
  7. Likes Uwe, Dana liked this post
  8. #5
    Feb 2015
    Hi thanks very much for the link I will give that a go. Not done that yet.
  9. #6
    Feb 2015
    little bit of an update on this, carried out the basic settings test and cleared any faults, after cycling the ignition the traction control light went off but left the ABS light on and as soon as I moved the van traction control light came back on, its coming up with a ABS wheel speed sensor fault which I'll change next, but its also still coming up with the function test active.
    todays auto scan
    Monday,13,May,2019,19:24:47:28228
    Mileage: 43950km-27309mi   Repair Order:
    Scan: 01 03 09 10 15 16 17 19 25 2E 37 3D 42 44 46 52 56 77
    VIN: WV1ZZZ2KZCX031974   Mileage: 43950km-27309miles
    10-Park/Steer Assist -- Status: Cannot be reached 1100
       Revision: 00H31001
                        Reset counter: 232
                        Mileage: 43956 km
                        Date: 2019.05.13
                        Time: 19:20:18
                        Count: 3
                        Count: 20480
                        Count: 320
                        Count: 42496
                        Reset counter: 232
                        Mileage: 43956 km
                        Date: 2019.05.13
                        Time: 19:20:18
                        Count: 3
                        Count: 20480
                        Count: 64
                        Count: 42496
       Revision: BF122001
       Coding: 009795
                        Reset counter: 232
                        Mileage: 43956 km
                        Date: 2019.05.13
                        Time: 19:20:23
                        Voltage: 11.85 V
    Address 10: Park/Steer Assist
       Coding: 1080040000
       Coding: 781800
    12671232 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 232
                        Mileage: 43956 km
                        Date: 2019.05.13
                        Time: 19:20:18
       Coding: 357401
    03075 - Parallel Parking Assistance Control Module (J791)
                        Reset counter: 232
                        Mileage: 43956 km
                        Date: 2019.05.13
                        Time: 19:20:19
                        Reset counter: 232
                        Mileage: 43956 km
                        Date: 2019.05.13
                        Time: 19:20:23
       Coding: 198073
       Coding: 0004726
       Revision: 00H20000
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 232
                        Mileage: 43956 km
                        Date: 2019.05.13
                        Time: 19:20:18
                        Voltage: 12.00 V
                            DD
                        Temperature: 25.0C
       Coding: 0004720
    Address 56: Radio
    End-------------------------(Elapsed Time: 02:22)--------------------------
  10. #7
    I don't think you'll ever get rid of the Function Test DTC until everything with the ABS is in working order.
  11. #8
    Correct Uwe and he may need to start ADP over and done in 0x44 first before completion in 0x03
  12. #9
    Feb 2015
    Thanks for the replies, I agree Uwe, I’ve had faulty wheel speed sensors on other cars in the past cause all kinds of problems, so I’ll get that changed next, got 1 on order.
    Hi Jack, what is ADP please?
  13. Likes Dana liked this post
  14. #10
    United States
    Absolutely agree on the wheel speed sensors. Do get that corrected before you struggle with the ESP function test.
    Jack was referencing the G85 calibration. Although it should be completed in address 03-ABS brakes (because you have ESP) .. some cars don't play by the rules. When you have a stubborn one it can't hurt to calibrate G85 directly in address 44 first because that's where G85 is located on this Golf 6 based model. After doing it the alternative way, repeating the G85 procedure in address 03 may be successful.
  15. Likes Uwe liked this post
