Redir Fail! Golf 4 v5 1998 (Engine code AGZ)
JohanHalekor
NL
C?ID=247713
I've tried to scan a Golf Mk4 V5 with AGZ engine but it gives a redir error on the engine control module. Any idea how to fix this?
Part of the scan:
Saturday,04,May,2019,21:14:57:04650
VCDS Version: 18.9.1.0 (x64)
Dealer/Shop Name: *****
VIN:    License Plate: ANTHONYV5
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
          76
   Part No: 071 906 018
   Component: MOTRONIC M3.8.3  HS V03
   Coding: 00010
   Shop #: WSC 01317
   VCID: 50AF0B1790F119CA0D-4B00
00553 - Mass Air Flow Sensor (G70)
            31-10 - Open or Short to Ground - Intermittent
01165 - Throttle Body Control Module (J338)
            20-00 - Malfunction in Basic Setting
17973 - Throttle Actuator (J338)
            P1565 - 35-00 - Lower Stop not Reached
00282 - Throttle Position Actuator (V60)
            29-00 - Short to Ground
Readiness: 0000 0001
That file is only available in German at present. If a German label file would be helpful, download and install the German installer here and copy the file into from C:\Ross-Tech\VCDS-DRV\Labels\DRV\ to C:\Ross-Tech\VCDS\Labels\
This one: 071-906-018-AGZ.LBL
Oops, I can't believe I didn't include the name of the file. :facepalm:
I'll use the excuse that it was at 11:00pm and the coffee had worn off. :D
JohanHalekor
NL
C?ID=247713
Thanks for your answers! I will have a look at it later this week. :)
