Page 16 of 18 FirstFirst ... 61415161718 LastLast
Results 151 to 160 of 172
Thread: Passat B8 early 2015, Retrofitting A5 front camera + DLA + Lane assist- Finished
  1. #151
    Verified VCDS User sam1754's Avatar
    Mar 2019
    France
    Quote Originally Posted by symb View Post
    Edit: In fact my car first demanded to take over the steering wheel in like 10 seconds? I don't remember what exactly did I do for it to change... Hmmm.
    So, WHAT WHAT WHAT!!! That's THE question!
    I'll take time to check adaptations but first, I noticed you have enabled Lane assistant menu in 5F (no link with take off time) but that's why you should have some functions that aren't implemented in your car (side assist, curve assist...).
  2. #152
    Mar 2019
    France
    That's what I thought.
    Those two lines are on my A5 adamap but not on your's.
    IDE07596-Personalization of lane dept. warning Cl. 15 on,activated ,1
    IDE10871-System mode: lane depart. warn:,Selection via menu ,1
    So I think warning menu intensity is linked to the firmware.
    I also noticed that you don't have enabled ACC menu on 5F???
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
    ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
  3. #153
    Feb 2019
    Quote Originally Posted by sam1754 View Post
    Yes, I don't have ACC in my car.
    I think I got some time today so I'm going to do some poking with vcds on this hands off intensity.
  4. #154
    May 2017
    From a polish site.
    I don't think that's correct information.
    I propose to read this one, this explains very well the whole driver assist scheme : https://vwts.ru/pps/pps_890253_vw_dr...ystems_eng.pdf
    Only thing the front camera adds is an advance warning up to 210km/h with MRR radars but it does not extend the radar range itself. The limitation of the radar is still 160km/h.
    Quote :
    Multifunctional Front Camera
    This camera detects vehicles that may be invisible to the
    front radar system by using an actual camera to monitor the
    area in front of the vehicle.
    The camera monitors the area in front of the vehicle when
    stationary, preparing for a restart of the ACC system. It can
    also detect lane markings for lane departure warning (Lane
    Assist)
    I really don't see how it could detect object farther away reliably if it's designed to monitor the front of the vehicle?
  5. #155
    May 2017
    Ok, here's the adamap from my Tiguan's A5 module. Exactly the same camera. I have a little bit newer software 272 vs. 271 on Symb's camera.
    Otherwise the same and I don't have warning intensity menu visible in driver assist menu in MIB. This is the same what pretty much everyone except Symb are reporting to be the case.
    ;SW:3Q0-980-654-H   HW:3Q0-980-654-A ---  Frt Sens. Drv. Assist
    ;Component:MQB_B_MFK     H06 0272, Coding:000307060000040100220047C056890088000E200040
    ;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_001_VW36.rod
    ;Saturday,23,November,2019,15:36:11:44693
    ;VCDS Version: Test 19.9.3 (x64)  Data version: 20190930 DS314.0
    ;VCID: 3C2A5FB846E14EB7C21-8068
    IDE00001-Production mode,Deactivating ,3
    IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated ,1
    IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated ,1
    IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated ,1
    IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated ,1
    IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated ,1
    IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated ,1
    IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated ,1
    IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated ,1
    IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h,2
    IDE04733-Road sign detection fusion mode,Road sign fusion ,1
    IDE07358-Distance to calibration field,1500 mm,2
    IDE09375-IDE05717-Axle offset-Front axle transverse position,5.96046e-006 mm,4
    IDE09375-IDE05718-Axle offset-Rear axle transverse position,-3.99999 mm,4
    IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,783 mm,8
    IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,783 mm,8
    IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,790 mm,8
    IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,790 mm,8
    IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2460 mm,24
    IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,742 mm,24
    IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1697 mm,24
    IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2460 mm,24
    IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-742 mm,24
    IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1697 mm,24
    IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2460 mm,24
    IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,742 mm,24
    IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,1103 mm,24
    IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2460 mm,24
    IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-742 mm,24
    IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,1103 mm,24
    IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
    IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
    IDE10872-Warning intensity: lane depart. warning,Selection via menu ,1
    IDE10873-BAP personalization,activated ,1
    IDE10924-MAS02479-Initial calibration: result-Yaw angle,-0.315 ,8
    IDE10924-MAS05286-Initial calibration: result-Roll angle,0.269 ,8
    IDE10924-MAS05287-Initial calibration: result-Pitch angle,-0.113 ,8
    IDE10924-MAS10678-Initial calibration: result-Camera height,1476 mm,8
    ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0 ,3
    ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0 ,3
    ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic ,3
    ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled ,3
    ENG120319-Mask_error_reactions_for_development,not activated ,1
    ENG107577-Masked_fault_classes-,255 ,4
    ENG130777-standstill_mode,not activated ,1
    ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,1 ,5
    ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,20 ,5
    ENG130779-Xcp_interface,not activated ,1
    Elapsed Time: 00:07
  6. Likes Uwe liked this post
  7. #156
    Mar 2019
    France
    Thanks for this excellent document. After reading it, I say you're 100% right!
    In Luxembourg, I often see Audi's and Touareg's bi-LRR radars. So, all standard VW cars come with MRR radars and ACC up to 160km/h... My Passat never went over 145km/h, so it's not a problem for me
    I also read that despite many comment, the camera is really a grayscale one so that's limiting the lane assist. Touareg and Audi A6 A8 have color camera with great definition!!!
    I go to the dealer shop right now and I'll change my Passat for an Audi! desillusion
    No, I like my Passat, even in Charlie Chaplin's movies mode
  8. #157
    Feb 2019
    Quote :
    Assist)
    Interesting that there is no mention about the dynamic light assist function and the part that camera plays in it. Of course it is different kind of image processing, but very very precisely working one. In dark, clear straight road it detects oncoming lights from around max 1000+ meters.
    And oddly in some parts like the camera hardware presentation, the document seems somehow outdated? At least in the 3Q0 980 654 all the image processing is done in the same package.
    Here is the second gen bosch camera brochure (3Q0 980 654).
    It has color and 1280x960 imager size. Correct me if I'm wrong.
    http://auto2015.bosch.com.cn/ebrochu...tt_mpc2_en.pdf
  9. Likes downtime liked this post
  10. #158
    May 2017
    Measuring light intensity vs measuring object movement are two completely different things. The latter one will need stereo camera to reliably measure the movement. Single view camera is not very accurate as the view is monotonic.
    Bosch’s brochure also only mentions forward collision warning. Sensor fusion is well explained in the document by the way.
  11. #159
    Oct 2014
    I have added the extra wires from the A5 Camera to the 13 Front Radar and coded them in but not really sure what difference there is.
    Done these codings...
    Coding related to the ACC/front assist and A5 front camera:
    Module 13 byte 3 bit 6 enable (front camera installed)
    Module A5 byte 11 bit 2 enable (acc coded)
    Module A5 byte 14 bit 0 enable (radar interface coded)
    My 2018 polo only has front assist But yet before I added the 2 canbus wires and coded these in it made the Lane Assist Deactivate.
    Scott
  12. #160
    May 2017
    Did you change to ACC type to stop&go 8T8 in engine control module as well after adding lane assist camera? Also ABS coding will be different.
