;SW:3Q0-980-654-L HW:3Q0-980-654-A --- Frt Sens. Drv. Assist
;Component:MQB_B_MFK H09 0610, Coding:000408020000040100221344C046810090000E20002000
;EV_MFKBoschMQBB,002041,EV_MFKBoschMQBB_002.rod
;Saturday,14,November,2020,21:01:36:16465
;VCDS Version: Release 20.4.2 (x64) Data version: 20200730 DS317.0
;VCID: 40D9BD399A07C61B123-8014
Group,Description,Actual
IDE00018,Voltage terminal 15,11.3, V
IDE00030,Status of actuator test,not active,
IDE00102,Control Module temperature,35, °C
IDE00322,Status of basic setting,not active,
IDE00323,Security Access: Number of invalid keys,0,
IDE00326-MAS02471,Steering wheel angle-Sign,Negative,
IDE00326,Steering wheel angle,1.3, °
IDE00767,No. of unscheduled ECU resets,0,
IDE00925-MAS02471,Yaw rate-Sign,Negative,
IDE00925,Yaw rate,0.04, °/s
IDE00973,Outside air temperature,17.5, °C
IDE01968,Dynamic calibration: yaw angle offset,0.000, °
IDE01969,Dynamic calibration: pitch angle offset,0.000, °
IDE01970,Dynamic calibration: roll angle offset,0.000, °
IDE01971,Lowest recorded control module temperature,-4, °C
IDE01972,Highest recorded control module temperature,70, °C
IDE02057,Dynamic calibration: status,Passive: no values stored,
IDE02486,Data logger triggering,not active,
IDE03222-MAS02534,Blindness detection-Clear view,No,
IDE03222-MAS03365,Blindness detection-Blind vehicle detection during darkness,No,
IDE03222-MAS03366,Blindness detection-Blind traffic sign detection,No,
IDE03222-MAS03399,Blindness detection-Blindness automatic distance control,No,
IDE03222-MAS09886,Blindness detection-Blind during pedestrian recognition,No,
IDE03222-MAS09887,Blindness detection-Blind during object recognition,No,
IDE03222-MAS09888,Blindness detection-Blind during lane recognition,No,
IDE03222-MAS10690,Blindness detection-Activation condition,activated,
IDE03222-MAS11902,Blindness detection-Blind DTC memory entry,No,
IDE03222-MAS11936,Blindness detection-Causes of blindness,Fuzziness/Diffusion,
IDE03222-MAS11937,Blindness detection-Pixel failure,0, %
IDE03222-MAS11949,Blindness detection-Windshield heater blindness,No,
IDE03354-MAS01632,Dynamic calibration: details-Status,Calibration not yet performed,
IDE03354-MAS02552,Dynamic calibration: details-Distance traveled with active dynamic calibration,0, km
IDE04036,High beam assistant: status,not active,
IDE04037,High beam recommendation,OFF,
IDE04123,High beam: reason for shut-off,20,
IDE04125,Visibility,Not Used,
IDE06425-IDE02766,Roller test bench mode: functional-Malfunction status,no error,
IDE06425-MAS06026,Roller test bench mode: functional-Activation stages,not activated,
IDE07214,Dynamic calibration: camera height offset,0, mm
IDE07543,Vehicle speed,0.00, km/h
IDE09424,Number of recognized lane markings,0,
IDE09433-MAS01632,Perception module for light assistant-Status,passive,
IDE09433-MAS08885,Perception module for light assistant-Object 1 removal,Unknown (384),
IDE09433-MAS08886,Perception module for light assistant-Object 2 removal,Unknown (384),
IDE09433-MAS08887,Perception module for light assistant-Object 1 horizontal position,Unknown (896),
IDE09433-MAS08888,Perception module for light assistant-Object 2 horizontal position,Unknown (896),
IDE09433-MAS08889,Perception module for light assistant-Object 1 vertical position,Unknown (0),
IDE09433-MAS08890,Perception module for light assistant-Object 2 vertical position,Unknown (0),
IDE09433-MAS08891,Perception module for light assistant-Object 1 horizontal expansion,0, °
IDE09433-MAS08892,Perception module for light assistant-Object 2 horizontal expansion,0, °
IDE09433-MAS08893,Perception module for light assistant-Object 1 ID,0,
IDE09433-MAS08894,Perception module for light assistant-Object 2 ID,0,
IDE09433-MAS08895,Perception module for light assistant-Object 1 replacement value,No,
IDE09433-MAS08896,Perception module for light assistant-Object 2 replacement value,No,
IDE09433-MAS08897,Perception module for light assistant-Object 1 horizontal quality left,0, °
IDE09433-MAS08898,Perception module for light assistant-Object 2 horizontal quality left,0, °
IDE09433-MAS08899,Perception module for light assistant-Object 1 horizontal quality right,0, °
IDE09433-MAS08900,Perception module for light assistant-Object 2 horizontal quality right,0, °
IDE09433-MAS08901,Perception module for light assistant-Object 1 vertical quality,0, °
IDE09433-MAS08902,Perception module for light assistant-Object 2 vertical quality,0, °
IDE09433-MAS08903,Perception module for light assistant-Object 1 Object type,No object,
IDE09433-MAS08904,Perception module for light assistant-Object 2 Object type,No object,
IDE09433-MAS08905,Perception module for light assistant-Object 1 Object quality,<= 50%,
IDE09433-MAS08906,Perception module for light assistant-Object 2 Object quality,<= 50%,
IDE09433-MAS08907,Perception module for light assistant-Cause for passive switching,Ambient brightness too high,
IDE09436,Recognized street illumination,no streetlight,
IDE09438,Drive sequence,Left hand driv.,
IDE10220,Initial online calibration active,not active,
IDE10398-MAS10691,Self-glare-Self-glare quality,0, %
IDE10398-MAS11502,Self-glare-Self-glare recognition,No,
IDE10398-MAS11503,Self-glare-Self-glare status,not active,
IDE10403,Current initial calibration: status,Initial static calibration KD OK.,
IDE10404-MAS10704,Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality,1.0000,
IDE10404-MAS10705,Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality,1.0000,
IDE10404-MAS10706,Dynamic calibration: quality-Dynamic calibration: roll angle offset quality,1.0000,
IDE10404-MAS10707,Dynamic calibration: quality-Dynamic calibration: camera height offset quality,1.0000,
IDE10405-MAS10708,Initial dynamic calibration: details-Initial dynamic calibration: roll angle,-0.298, °
IDE10405-MAS10709,Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality,1.0000,
IDE10405-MAS10710,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle,-2.693, °
IDE10405-MAS10711,Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality,1.0000,
IDE10405-MAS10712,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle,-0.390, °
IDE10405-MAS10713,Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality,1.0000,
IDE10405-MAS10714,Initial dynamic calibration: details-Initial dynamic calibration: Camera height,1308, mm
IDE10405-MAS10715,Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality,1.0000,
IDE10405-MAS10716,Initial dynamic calibration: details-Distance traveled with active initial calibration,0, m
IDE10406-MAS10994,Last initial calibrations: details-Last initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10995,Last initial calibrations: details-Penultimate initial calibration: error code,No calibration relevant malfunction,
IDE10406-MAS10996,Last initial calibrations: details-Third-to-last initial calibration: error code,Installation position incorrect,
IDE10406-MAS10997,Last initial calibrations: details-Fourth-to-last initial calibration: error code,No calibration relevant malfunction,
IDE10547,Status of camera,Camera operating,
IDE10664-MAS00106,Current initial calibration: details-Year,2020,
IDE10664-MAS00107,Current initial calibration: details-Month,11,
IDE10664-MAS00108,Current initial calibration: details-Day,14,
IDE10664-MAS00109,Current initial calibration: details-Hours,19,
IDE10664-MAS00110,Current initial calibration: details-Minutes,9,
IDE10664-MAS00111,Current initial calibration: details-Seconds,21,
IDE10664-MAS00711,Current initial calibration: details-Odometer reading,69202,
IDE10664-MAS01632,Current initial calibration: details-Status,No calibration relevant malfunction,
IDE10664-MAS02541,Current initial calibration: details-Rear projection fault,0,
IDE10664-MAS02542,Current initial calibration: details-Calibration marks,00111111 ,
IDE10664-MAS02543,Current initial calibration: details-VIN determined during calibration,WVWZZZ3CZGE009717,
IDE10664-MAS03010,Current initial calibration: details-Focal length,1382,
IDE10664-MAS03075,Current initial calibration: details-Calibration point X coordinates on imaging sensor,641,
IDE10664-MAS03076,Current initial calibration: details-Calibration point Y coordinates on imaging sensor,362,
IDE10664,Current initial calibration: details,00110011 ,
IDE10664,Current initial calibration: details,00111111 ,
IDE11956,Boot manager version,31 12 30 13,
MAS00464-MAS00106,Standard - ambient data 1-Year,2020,
MAS00464-MAS00107,Standard - ambient data 1-Month,11,
MAS00464-MAS00108,Standard - ambient data 1-Day,14,
MAS00464-MAS00109,Standard - ambient data 1-Hours,21,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,1,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,37,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,142,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,69202, km
ENG130818-MAS01505,Windscreen_heater_camera-Engine off,Yes,
ENG130818-MAS02374,Windscreen_heater_camera-System malfunction,no error,
ENG130818-MAS03849,Windscreen_heater_camera-Crash signal,not active,
ENG130818-ENG120256,Windscreen_heater_camera-par_Actuator_test,not active,
ENG130818-ENG120266,Windscreen_heater_camera-par_Ambient_temperature_too_low,No,
ENG130818-ENG120257,Windscreen_heater_camera-par_Blindness_activation,no request,
ENG130818-ENG120260,Windscreen_heater_camera-par_camera_temperature_too_high,No,
ENG130818-ENG120258,Windscreen_heater_camera-par_condensation_danger_activation,no request,
ENG130818-ENG120268,Windscreen_heater_camera-par_current_windscreen_heater,0.0, A
ENG130818-ENG120265,Windscreen_heater_camera-par_Heating_time_exceeded,No,
ENG130818-ENG120259,Windscreen_heater_camera-par_initial_heating,not active,
ENG130818-ENG130881,Windscreen_heater_camera-par_preventive_heating,not active,
ENG130818-ENG120264,Windscreen_heater_camera-par_Windscreenheater_error,not active,
ENG130818-ENG101577,Windscreen_heater_camera-Windscreen_heater_state_of_activation,not active,
Elapsed Time: 00:36
