Page 1 of 18 12311 ... LastLast
Results 1 to 10 of 172
Thread: Passat B8 early 2015, Retrofitting A5 front camera + DLA + Lane assist- Finished
    Feb 2019
    The car is factory equipped with front assist (no ACC), led HIGH, park assist etc.. etc.
    Retrofitted A5 camera is calibrated at dealer and seems to be satisfied, though I can only see some 40km of dynamic calibration there - does this trigger when you actually start to use lane assist and the camera is learning/reading the markings? It's reading and showing speed signs very accurately - so actually one more retrofit, which is already done and working!
    The DLA:
    Is working except for the that the "MDF" - position of the cylindrical mask won't roll up when the camera starts adjusting the lights, thus I can't drive with DLA active yet because it's dazzling other road users.
    I tried to PM golfi_vend since he seems to know a trick to these early 2015 B8's and I'm looking for confirmation to it, the trick being activating different parameter set for the module 55, via VCP or ODIS. I would like to know if you can do this with the latter, because I have access to it. Too bad I didn't remember/thought about this earlier when the camera was being calibrated and I could toy around with the "other" tool.
    Maybe with this thread I can lure him or someone else out to confirm this. Here is a photo of the magic. In later models I believe everything can be done by vcds coding & adaptations to activate the DLA function properly.
    Here is proof that all the bells and whistles are in there, every "LED HIGH" unit has them.
    Main beam mask active
    No dazzle
    Mask active
    And menu items.
    Menu
    DLA active
    I put some more photos about the project later.
    Lane assist:
    I still have issues with lane assist, I've been able to make the codings/adaptations so that lane assist appears in MFD, but says "not available" when trying to activate. It also shows up in the infotainment car menu; "adaptive lane assist" or something, but it is greyed out. Not sure what I have missed out here, also there is side assist and rear traffic monitor (?) or something selectable in the car menu now, which is strange since I don't remember coding anything associated to those.
    So, I hope the DLA issue gets solved next week or if someone here has any ideas?
    Here is my autoscan of the current situation and feel free to request admaps of any modules and I shall post them here.
    Thanks for any contribution in advance!
    Friday,03,May,2019,22:08:44:29066
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN: WVWZZZ3CZFE439463   License Plate:
    Mileage: 228152km-141767mi   Repair Order:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F A5
    VIN: WVWZZZ3CZFE439463   Mileage: 228152km-141767miles
    Address 01: Engine (J623-DCXA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 GJ    HW: 04L 907 309 R
       Component: R4 1.6l TDI   H21 1991
       Revision: B5H21---
       Coding: 0119003A03241D093000
       Shop #: WSC 41930 002 1048576
       ASAM Dataset: EV_ECM16TDI01104L906026GJ 002002
       ROD: EV_ECM16TDI01104L906026GJ.rod
       VCID: 78A9EAB672545367A6D-802C
       Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
       Component: ESC           H42 0625
       Revision: 00000000    Serial number: 63464000002522
       Coding: 0FEC6A8F34230B75077B060641C649F0562CD0E0608292F13040F078C002
       VCID: 7EA5FCAE50706D57EC1-802A
       Part No SW: 3Q0 959 435     HW: 3Q0 959 435
       Component: VWKESSYMQB    023 0522
       Revision: 00023000    Serial number: 0356001440
       Coding: 000F1E0603
       Shop #: WSC 05311 115 00309
       ASAM Dataset: EV_KessyHellaMQBAB 004027
       VCID: 77ABE98A7F4A5C1FAF7-8022
       Part No SW: 5G0 907 044 AK    HW: 5G0 907 044 AK
       Revision: 00001K10
       Coding: 12020104204101012015504000101802
       Shop #: WSC 00015 115 00001
       VCID: 70B9D2961A240B276ED-8024
       Air quality sensor:
       Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
       Component: BCM PQ37BOSCH 028 0146
       Revision: --------    Serial number: 86581212141103
       Coding: 00010E46C24102FF4BE44004001C07081C80000000000000000000000000
       ROD: EV_BCMBOSCH_014.rod
       VCID: 7DA7FBA25D76764FF5B-8028
       Component: WWS    141122  042 0607
       Serial number:         141128155550
       Component: RLHS  037 0059
       Serial number: S4Y14M12D18H09M48S35
       Coding: 05A8DD
       Serial number: 27 10 2014  00000508
       Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
       Component: PLA 3.0 12KH08 0013
       Serial number: ATW-00118.12.14
       Coding: 0051063041
       Shop #: WSC 05311 115 00083
       ASAM Dataset: EV_EPHVA2CAU3700000 008017
       ROD: EV_EPHVA2CAU3700000_008_VW48.rod
       VCID: 3FDB41AA17FAA45FA77-806A
       Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
       Component: ACC BOSCH MQB H04 0126
       Coding: 2A21604310FFC428949C8044
       ASAM Dataset: EV_ACCBOSCHVW48X 001007
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 33331D9A2BB2703F53F-8066
       Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
       Component: Airbag VW20   012 0195
       Revision: --------    Serial number: 003R2PS7HWLX
       Coding: 88CCC000008000005C5400CC000800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 025D885E248809B7889-8056
       Subsystem 1 - Part No SW: -----------    HW: 454 000 912 14
       Serial number: 3576U0000005C1C03211
       Subsystem 2 - Part No SW: -----------    HW: 454 000 912 14
       Serial number: 3586U000000A29D03216
       Subsystem 3 - Part No SW: -----------    HW: 454 801 812 14
       Serial number: 3516RDB4965050000009
       Subsystem 4 - Part No SW: -----------    HW: 454 800 912 14
       Serial number: 3526R54AE67050000008
       Subsystem 5 - Part No SW: -----------    HW: 454 801 011 14
       Serial number: 3556VC9D012050000006
       Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
       Revision: FF032032    Serial number: 20141212400693
       Coding: 0400
       ROD: EV_SMLSVALEOMQB.rod
       VCID: 3D273BA21DF6B64FB5B-8068
       Part No SW: 3G0 920 741     HW: 3G0 920 741
       Component: KOMBI         209 4311
       Coding: 03A509106B84000801883A021001000000000000
       Shop #: WSC 58575 001 104857
       ASAM Dataset: EV_DashBoardVDDMQBAB 009043
       ROD: EV_DashBoardVDDMQBAB_VW48.rod
       VCID: 619FA7D2C1CEB2AFF13-8034
       Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
       Component: STH-MQB       006 0069
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002014
       VCID: 3635248E38C06517741-8062
       Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
       Component: R149 T91-LIN  003 0301
       Serial number: 00000000000001048974
       Revision: --------    Serial number: 06121410800841
       Coding: 030300044F015900EF00024A080F00010001070000000000000000000000
       ROD: EV_GatewConti_011_VW48.rod
       VCID: 72BDD89E14283937989-8026
       Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H16 0038
       Serial number: 27140003054030124492
       Coding: 28FFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
       Serial number: 5488785203
       Analog clock:
       Serial number: 14000312745010
       Coding: 0000000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71BFD792112E022F613-8024
       Serial number: 061214BL601949
       Coding: 00350B208000020000001000
       VCID: 42DD485E6408C9B7C89-8016
       Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000564084
       Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    203 2033
       Revision: 00000000    Serial number: 0000103862
       Coding: 01010011005000
       Shop #: WSC 00015 115 00315
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
       ROD: EV_SteerAssisVWBSMQBA_008.rod
       VCID: 3B2335BA03E2B87F8BF-806E
       Serial number: 271114AKR02464
       Coding: 003501208C00020000001000
       VCID: 41DF4752610ED2AFD13-8014
       Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000000598768
       Coding: 090000
       Coding: 039A00004F200200
       Shop #: WSC 24433 123 104857
       Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 0001
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 0001
       Coding: E02400
       Coding: E02400
       Component: LeiMo rechts  H02 0003
       Coding: E02400
       Part No SW: 5G0 035 869     HW: 5G0 035 869
       Component: MU-E--ER      820 6220
       Serial number: 10101400011002
       Coding: 02840200FF00000041110001000000001F0004840000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001017
       VCID: 6B83C5FA3302E8FF5BF-803E
       Component: MQB_B_MFK     H06 0271
       Serial number: 08101612P11893
       Coding: 000408020000040100220044C040810090000E300040
       Shop #: WSC 48779 003 104857
       VCID: 3C2136A606ECBF47825-8068
    End----(Elapsed Time: 01:54, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
  2. Likes Zenerdiode, jyoung8607, eden liked this post
  3. #2
    Feb 2019
    Update: A5 camera is ok, I monitored it while driving the highway, dynamic cal is active and gaining more kilometers. It's detecting lane markings well etc.
    Quess I need to undo and redo some coding regarding lane assist.
    Feb 2019
    Aight, an update. Unexpected one, since none of the coding guides seem to be spot on with these early models.
    Lane assist (adaptive) is working! And I must say I'm impressed, it keeps the car in the middle of the lane like nailed!
    Im going to post some detailed info later on.
    Lane Assist ready
    Lane Assist active
    Traffic sign recognition - nailed
    Adaptive lane assist - nailed
    Dynamic light assist - pending. (Coding ok, function ok but missing the masking feature.) Still waiting for clearance on this. Parameters can't be done via vcds. With VCP, do I need one of these ZDC-files or are the parameters already in the module, you just activate different parameter set? Refering to this screenshot taken from VCP.
  5. Likes Gremling liked this post
    Mar 2015
    Australia
    You need to load the parameter set for DLA.
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
  7. Likes symb liked this post
  8. #5
    Feb 2019
    Quote Originally Posted by kamold View Post
    Yes indeed, golfi_vend also confirmed this to me.
    There seems to be lot of misinformation in different forums regarding this, and probably quite some DLA retrofits that aren't properly functioning.
    So, do all the B8 models require the correct parameters set, or only the earlier models? If an 2018 arteon with 4b module instead of 55 requires it too, hmm.. makes me wonder.
  9. #6
    Mar 2015
    Australia
    Yes Arteon with 4B requires a parameter set also as far as I am aware. Agree that there is a lot of poor information out there which makes it very confusing for people.
  10. #7
    Feb 2019
    On this post I will go through the physical part of the A5 camera retrofit.
    This retrofit was done with the more expensive way of replacing the windscreen to a dap one.
    It's the certain way to get precise camera position, 100% calibration success and trouble free dynamic cal phase after that.
    Vw workshop here charged around 100€ for the camera calibration which - when done properly - involves 4-wheel laser alignment of the calibration board with the car.
    Reasons for me to do it this way:
    - Old windshield was good to go anyway.
    - The car was a taxi in a former life, driven 200000km in rural area in just 3 years, so I got it for around couple of
    grands cheaper than the market price.
    - Passat B8 MY15 with 1.6 TDI and manual gearbox, with these DAP features is pretty damn rare here.
    Depending on the factory equipment of your car you get to have one or more of the following:
    Traffic Sign Recognition
    Lane Assist/Adaptive Lane Tracking
    (Lane Departure Warning) Not 100% sure about this since not interested on the particular feature.
    Dynamic Light Assist / High Beam Assist depending on your light setup.
    The car needs to have the CAN HIGH gateway with the Extended BUS, because that's the network that A5 camera, and the
    majority of the driver assist systems are combined on.
    If there's Front assist / ACC, there is CAN HIGH.
    If there's Led HIGH headlights, there is CAN HIGH, etc...
    If you get the camera + cable set from kufatec, they will provide you with detailed wiring instructions (which I will not provide in this guide) and great, really great customer support if problems occur in i.e., coding.
    The camera also comes with the correct parameters set according to your VIN.
    It is of course possible to scrape these details from other sources too.
    After physical installations you just add it to the gateway, check that the ONLY fault in A5 is "no basic setting", and get
    it calibrated. If there's any other faults active it will prevent calibration. So, no coding prior to the cal.
    Required parts:
    (DAP windshield for your car. "VW" tagged or pilkington.) OR, some DIY solution including some 3d-printed bracket for
    the camera etc. Official vw workshops/dealers might not want to get involved in these and there might be risk of the
    calibration not succeeding or failing later on, and/or some of the features not working as accurately as they're supposed to.
    Of course you can get official calibrations from other providers too.
    Camera 3Q0 980 654 - mine was labeled G and software is H.- from kufatec (my suggestion).
    Cables - from kufatec (my suggestion). What you need is +12v (ignition), ground, two pairs for can hi/lo and possibly one
    more separate cable with can hi/lo pair for sensor fusion (front assist acc <> camera). And then the additional wiring (+
    and ground) from camera to the heater/defog trim. And correct connectors and wire terminals.
    Defog/heater trim 3G0 862 505 - from dealer (marbledesk), surprisingly inexpensive.
    Plastic trimmings: 3G0 868 437, 3G0 858 634, 3G0 858 633 (color of these: "titan black") - from dealer.
    Reason for this detailed following guide is that at least most of the any existing guides are pretty cumbersome, those too that do include detailed wiring instructions, so perhaps I can save time of other individuals, possibly doing something as foolish as this. This should be a good addition to any other guides.
    Starting point:
    New windscreen installed, waiting for the camera:
    Before going further, I suggest to remove the interior lights / sunglasses holder. This might not be mandatory but gives
    you more room to play with the cables and attaching the camera.
    To do so:
    Pry off the plastic piece from the rear end first, then unscrew the 2 torxes.
    Then remove the panel where the lights are by prying from the edges. These come off pretty easily without breaking anything.
    Then remove the black plastic frame to gain access to 2 more torx screws above it, in the front.
    Then release the cables from the holders attached on top of the sunglasses holder and remove the holder.
    The light panel and it's frame can be left there hanging or removed out of the way completely by unplugging the cables.
    Heater trim in it's place. Here you can see the dap windshield plastic clips for the wires.
    Rain/light sensor, the new sensor gel pad comes with the windshield. Remove the old one, put in the new one and apply contact spray.
    Metal clip attaches this to the windshield. Easy to install and remove with a small flat screwdriver. Clean the spot on the glass where the sensor attaches.
    Camera in it's place. I found it easiest to plug in the cable first then carefully slip the camera in, front first, and
    then snap the rear side up in the metal clips, simultaneously helping the cable connector to slip past the plastic frame of
    the interior lights. The original cable harness including the rearview mirror and the rain sensor wiring need to be strip
    off from some of the tape so that those can be separated and rerouted around the camera to their new - a bit more further position.
    The rearview mirror attaches to the windshield by placing it "on top" of the rain/light sensor and turning clockwise.
    To remove it just turn counterclockwise.
    To be continued...
  11. Likes Zenerdiode, Uwe, jyoung8607 liked this post
  12. #8
    Feb 2019
    Removing the a-pillar trim is probably the hardest part. Please note that there is an airbag element in there attached to the pillar.
    First remove the side panel and the vertical plastic trim.
    The a-pillar trim itself is attached with three clips. Two that just snap out and in and one that comes out for a certain
    amount and then you need to slide it off of the trimming. First pull the trim off from the front end, then middle and then
    the rear. Then you can pry it a bit so that you can release the last clip with i.e. a small screwdriver by sliding it out of the trim piece.
    Here you can see how it's actually attached.
    The two front end clips.
    The trim side of the last clip.
    The chassis side, front clips
    And the last painful 2-stage clip.
    When I installed the trim back I disassembled this painful clip (it can be figured out how, by staring at the evil clip for
    some time) to it's two separate pieces so I could pull it out and place it to the trim side first, and then wiggled the whole
    trim back to its initial position, starting from the front, targeting the 2 front clips first and then pushing the trim back to its place, starting from front.
    I pulled the new cable harness in above the headlining without removing any of it. This can be done with a cable pulling
    spring like electricians use or some other makeshift tool. I think this solution is better than just pushing it in the top-front-end of the headlining as suggested in many guides.
    The camera end of the route.
    The a-pillar end.
    This is the only right way to route and attach the cable because of the airbag.
    The rest of the route you can figure out by following the existing harness.
    The sensor fusion can pair goes to the coupling point here.
    You need to remove the plastic trim around the bonnet opening handle, and part of the floor/door edge trimming.
    Down there is a proper grounding point.
    The other pair (CAN extended) goes to the CAN gateway located on top of the steering column.
    To gain access there you need to remove the plastic with the footwell light, and the piece of plastic air duct. The latter is attached with one screw.
    It's a tight spot and if you're doing this you probably have front assist/acc or led HIGH headlights thus meaning that you
    have CAN gateway of HIGH type with extended bus, thus meaning that the target pins are already reserved, so it's a soldering
    job (this is by far the easiest and most reliable way of doing it).
    CAN gateway there with the red connector. In this photo new wires already attached.
    Gateway to camera - wires soldered, vulcanized and isolated properly.
    I loved the ergonomy while soldering.
    To be continued...
  13. Likes Zenerdiode, Uwe, jyoung8607, eden liked this post
  14. #9
    Feb 2019
    And the last part:
    Okay, then the sensor fusion can cabling. Meaning that the camera and the front radar are directly connected to each other
    in addition of the connection they already have in the CAN bus extended. For my understanding there is another coupling point in the engine compartment, but I realized this when I was already at the radar with the cable, so I just directly routed the cable from the a-column coupling point to the radar, unplugged the
    existing pair of wires (going to the aforementioned under-bonnet-coupling point), and plugged in my new guaranteed sensor
    fusion connection. This particular connector can be dismantled without breaking anything, and most of the ready cable sets
    available have the correct type of terminals on the wires).
    In the existing cable route to the cabin, there is a big grommet that actually has another unused very small grommet in it,
    just for cases like this. So I routed the new cable through there:
    To gain clear access to the front radar, the front grille must be removed.
    Below is a link to a video where you can see that the lower side of the grille is held in place with the typical plastic
    clip that you just pull out of thinking that you definitely break something but you don't. So just unscrew the screws
    holding the top of the grille in its place, and gently but firmly pull the lower grille out starting from either side.
    Passat B8 front grille removal
    Then you are greeted by the front radar unit.
    The last part would be giving the camera some +12v ignition on - juice.
    The row of 7.5, 5, 7.5, 10, 10, 10 - fuses are switched on ignition. I'd say that an add-a-fuse solution would be the easiest, fastest and cleanest way.
    I did my own with a DIY add-a-fuse because on my box there was no free ignition switched fuses available, although some of
    the empty bigger fuse spots could be switched on - type too.
    Then, everything wired, ignition on, fire up vcds - of course - and go add the module A5 to the gateway installation list.
    The gateway is already screaming there that it has detected a new module.
    Check that the only fault code in module A5 is "no default setting". Next step, calibration.
    Here is the final looks of my retrofit, not sure what is the thing determining the color of those plastic trims but I like it this way. Neat and sleek.
    Next, when I have time I try to sum up the codings done for particular features, targeting this early MY15 passat B8.
    Thanks.
  15. #10
    Jul 2014
    Tallinn, Estonia
    A few comments...
    For connecting the A5 to Extended CAN at the GW, a more user-friendly method is to make/use a Y-splitter. One can rather easily make and cheaply make one with very common Audi connectors 4B0972623, 8E0972763 and their corresponding crimp terminals.
    A better accessible factory ground point for the A5 is under the front dome light panel but I guess Kufatec wanted the retrofitter to use other ground points...
    Under bonnet coupling point for the ACC radar is better accessed from the underside, preferrably with the car on a lift and the skid plate off. Connecting directly to the radar connector might hinder the possbile removal of the front bumper in the future.
  16. Likes symb, Gremling liked this post
